[PATCH v3 06/17] mmc: rockchip_sdhci: Use set_clock and config_dll sdhci_ops
Change to configure clock and DLL in set_clock and config_dll ops instead of in the set_ios_post ops.
With this change the output clock is turned off while configuring DLL parameters, according to the design recommendations.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v3: - Resolve conflict with "rockchip: sdhci: rk3568: fix clock setting logic" at [1] - Collect r-b tag
v2: - No change
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230307212646.56576-1-anar...
drivers/mmc/rockchip_sdhci.c | 28 +++++++++++++++------------- 1 file changed, 15 insertions(+), 13 deletions(-)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 85858f3ed9a3..e56043fce88e 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -291,18 +291,24 @@ static int rk3399_sdhci_set_ios_post(struct sdhci_host *host) return 0; }
-static int rk3568_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clock) +static void rk3568_sdhci_set_clock(struct sdhci_host *host, u32 div) { struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct mmc *mmc = host->mmc; + ulong rate; + + rate = clk_set_rate(&priv->emmc_clk, mmc->clock); + if (IS_ERR_VALUE(rate)) + printf("%s: Set clock rate failed: %ld\n", __func__, (long)rate); +} + +static int rk3568_sdhci_config_dll(struct sdhci_host *host, u32 clock, bool enable) +{ int val, ret; u32 extra;
- if (clock > host->max_clk) - clock = host->max_clk; - if (clock) - clk_set_rate(&priv->emmc_clk, clock); - - sdhci_set_clock(host->mmc, clock); + if (!enable) + return 0;
if (clock >= 100 * MHz) { /* reset DLL */ @@ -386,14 +392,8 @@ static int rk3568_sdhci_set_enhanced_strobe(struct sdhci_host *host) static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; - uint clock = mmc->clock; u32 reg, vendor_reg;
- if (mmc->tran_speed && mmc->clock > mmc->tran_speed) - clock = mmc->tran_speed; - - rk3568_sdhci_emmc_set_clock(host, clock); - if (mmc->selected_mode == MMC_HS_400 || mmc->selected_mode == MMC_HS_400_ES) { reg = sdhci_readw(host, SDHCI_HOST_CONTROL2); reg &= ~SDHCI_CTRL_UHS_MASK; @@ -601,6 +601,8 @@ static const struct sdhci_data rk3399_data = { static const struct sdhci_data rk3568_data = { .get_phy = rk3568_emmc_get_phy, .set_ios_post = rk3568_sdhci_set_ios_post, + .set_clock = rk3568_sdhci_set_clock, + .config_dll = rk3568_sdhci_config_dll, .set_enhanced_strobe = rk3568_sdhci_set_enhanced_strobe, };
Jonas Karlman
