[PATCH] arm64: zynqmp: Add multiboot support for SPL/SPI offset calculation
In case of A/B update systems there should be an option to load the same binary/binaries to different location and they should work. Before this patch boot.bin with U-Boot SPL can be added to whatever 32k offset in SPI and SPL finds u-boot.itb at CONFIG_SYS_SPI_U_BOOT_OFFS offset. In case of A/B update systems that means that SPL is at different locations but it still points to the same u-boot.itb which is not correct. That's why include multiboot value to offset calculation to be able to point to image from the same base. It doesn't affect any current system which starts from 0 offset.
This patch also change Kria defconfig which uses A/B setup. Partition A starts at multiboot 64, partition B at multiboot 496.
And also print message about used SPI offset which is useful for all cases.
Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/zynqmp/zynqmp.c | 15 +++++++++++++++ configs/xilinx_zynqmp_kria_defconfig | 2 +- 2 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index f16280308483..59feaaf6f32f 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -681,3 +681,18 @@ void set_dfu_alt_info(char *interface, char *devstr) puts("DFU alt info setting: done\n"); } #endif + +#if defined(CONFIG_SPL_SPI_LOAD) +unsigned int spl_spi_get_uboot_offs(struct spi_flash *flash) +{ + u32 offset; + int multiboot = multi_boot(); + + offset = multiboot * SZ_32K; + offset += CONFIG_SYS_SPI_U_BOOT_OFFS; + + log_info("SPI offset:\t0x%x\n", offset); + + return offset; +} +#endif diff --git a/configs/xilinx_zynqmp_kria_defconfig b/configs/xilinx_zynqmp_kria_defconfig index daedf1de01ea..a20df1a4072f 100644 --- a/configs/xilinx_zynqmp_kria_defconfig +++ b/configs/xilinx_zynqmp_kria_defconfig @@ -48,7 +48,7 @@ CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x8000000 CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_SYS_MAXARGS=64
- u32 offset;
- int multiboot = multi_boot();
- offset = multiboot * SZ_32K;
- offset += CONFIG_SYS_SPI_U_BOOT_OFFS;
- log_info("SPI offset:\t0x%x\n", offset);
- return offset;
Applied. M
Michal Simek
