[U-Boot] [PATCH] Fix NAND booting make target
Without this fix, the NAND_SPL target (in nand_spl/) is not built at all.
Signed-off-by: Stefan Roese sr@denx.de --- Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index b4aae89..e9797d6 100644 --- a/Makefile +++ b/Makefile @@ -287,7 +287,7 @@ LDPPFLAGS += \ $(shell $(LD) --version | \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
-ifeq ($(CONFIG_NAND_U_BOOT),y) +ifeq ($(CONFIG_NAND_U_BOOT),"y") NAND_SPL = nand_spl U_BOOT_NAND = $(obj)u-boot-nand.bin endif
It builds for me without it, on mpc8315erdb (I tried some 4xx boards but they don't build at all), as of current master branch (fa722ea76be565de6823ca04c107cc4fbd96b776). Applying this change stops it from building.
-Scott
Hi Scott,
Yes, current git head fails to build an many 4xx boards. My patch is on top of Wolfgangs patchset "[PATCH 0/7] Address partial linking issues" from 2010-11-21 which fixes most of the 4xx problems. But without this patch, no object was built in the nand_spl directory at all. Not sure if I overlooked something though.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
On Tue, 23 Nov 2010 19:16:47 +0100 Stefan Roese sr@denx.de wrote:
Hi Scott,
Perhaps it has to do with the 4xx boards having NAND_U_BOOT directly in boards.cfg, while the Freescale boards typically have NAND there, and define NAND_U_BOOT in the makefile.
I think the proper fix is to figure out how those quotes are being injected into the make variable.
-Scott
Hi Scott,
Try removing the "=y" in boards.cfg. tools/scripts/define2mk.sed will add quotes to things that aren't numbers, but it has special handling to turn empty defines (or the number 1) into an unquoted y.
-Scott
Yes, this works as well. I'll send an updated patch tomorrow.
Thanks.
Cheers, Stefan
Scott Wood
Stefan Roese
