[U-Boot] [PATCH 2/2] PPC MPC83xx: Fix MPC8323ERDB build warning
Fix:
mpc8323erdb.c: In function 'mac_read_from_eeprom': mpc8323erdb.c:198:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
Signed-off-by: Wolfgang Denk wd@denx.de cc: Michael Barkowski michael.barkowski@freescale.com cc: Kim Phillips kim.phillips@freescale.com --- board/freescale/mpc8323erdb/mpc8323erdb.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index f29b2f4..533cb08 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -195,7 +195,11 @@ int mac_read_from_eeprom(void) printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CONFIG_SYS_I2C_EEPROM_ADDR); } else { - if (crc32(crc, buf, 24) == *(unsigned int *)&buf[24]) { + unsigned int crc_buf; + + memcpy(&crc_buf, &buf[24], sizeof(unsigned int)); + + if (crc32(crc, buf, 24) == crc_buf) { printf("Reading MAC from EEPROM\n"); for (i = 0; i < 4; i++) { if (memcmp(&buf[i * 6], "\0\0\0\0\0\0", 6)) {
Dear Kim,
The address of the board maintainer bounces:
| Delivery has failed to these recipients or groups: | | Michael Barkowski | (michael.barkowski@freescale.com)mailto:michael.barkowski@freescale.com | The e-mail address you entered couldn't be found. Please check the | recipient's e-mail address and try to resend the message. If the | problem continues, please contact your helpdesk. | | The following organization rejected your message: | tx30smr01.am.freescale.net.
Do you know if there is a new maintainer for this board, or should we enter it as orphaned?
On Fri, Jun 14, 2013 at 4:14 AM, Wolfgang Denk wd@denx.de wrote:
Dear Kim,
| Delivery has failed to these recipients or groups: | | Michael Barkowski | (michael.barkowski@freescale.com)<mailto:michael.barkowski@freescale.com
Well, he hasn't been at Freescale for years, now, so that's not surprising. It's not entirely clear to me whether that board is one we actively support, but I suspect we can get away with maintenance moving over to Kim. That said, I guess I shouldn't volunteer him. :)
Andy
There's been a lot of churn at Freescale over the past couple years. I think a lot of the email addresses are no longer valid. It's probably time for an update.
For the record, I actually have an mpc8323erdb. I'm not sure if I want to be the maintainer for it, though.
I have that board too and can run regular tests if that is any help
-- sinan
Dear Timur Tabi,
In message CAOZdJXWiKuGm5wOXQ5NwkPnBUgoEUSLOZPsbT1jJLn2c+M+kOw@mail.gmail.com you wrote:
Well, while you're discussing a potential new maintainer for this board, can please anybody ACK/NAK or - even better - pull that patch so we can fix the build warnings for the release?
Thanks.
Dear Kim,
ping!!
In message 1371198068-3581-1-git-send-email-wd@denx.de I wrote:
Fix:
-- 1.7.11.7
This should be a uint32_t, because you specifically want only four bytes.
If you fix that,
Acked-by: Timur Tabi timur@tabi.org
Fix:
Signed-off-by: Wolfgang Denk wd@denx.de cc: Timur Tabi timur@tabi.org cc: Kim Phillips kim.phillips@freescale.com --- V2: use uint32_t for crc_buf to make sure we always get exactly 32 bit; thanks to Timur Tabi for pointing out.
diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index f29b2f4..533cb08 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -195,7 +195,11 @@ int mac_read_from_eeprom(void) printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CONFIG_SYS_I2C_EEPROM_ADDR); } else { - if (crc32(crc, buf, 24) == *(unsigned int *)&buf[24]) { + uint32_t crc_buf; + + memcpy(&crc_buf, &buf[24], sizeof(unsigned int)); + + if (crc32(crc, buf, 24) == crc_buf) { printf("Reading MAC from EEPROM\n"); for (i = 0; i < 4; i++) { if (memcmp(&buf[i * 6], "\0\0\0\0\0\0", 6)) {
On 07/08/2013 01:19 PM, Wolfgang Denk wrote:
uint32_t crc_buf;
Well, this is wrong, because it should be sizeof(uint32_t). Or maybe sizeof(crc_buf).
Dear Timur Tabi,
uint32_t crc_buf;
Indedd. Sorry. V3 on the way.
Thanks!
Fix:
Fix:
Signed-off-by: Wolfgang Denk wd@denx.de cc: Timur Tabi timur@tabi.org cc: Kim Phillips kim.phillips@freescale.com --- V2: use uint32_t for crc_buf to make sure we always get exactly 32 bit; thanks to Timur Tabi for pointing out. V3: also use uint32_t for the size of the memcpy(), again thanks to Timur Tabi for pointing out.
diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index f29b2f4..533cb08 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -195,7 +195,11 @@ int mac_read_from_eeprom(void) printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CONFIG_SYS_I2C_EEPROM_ADDR); } else { - if (crc32(crc, buf, 24) == *(unsigned int *)&buf[24]) { + uint32_t crc_buf; + + memcpy(&crc_buf, &buf[24], sizeof(uint32_t)); + + if (crc32(crc, buf, 24) == crc_buf) { printf("Reading MAC from EEPROM\n"); for (i = 0; i < 4; i++) { if (memcmp(&buf[i * 6], "\0\0\0\0\0\0", 6)) {
Signed-off-by: Wolfgang Denkwd@denx.de cc: Timur Tabitimur@tabi.org cc: Kim Phillipskim.phillips@freescale.com
Ack.
On Sun, Jul 14, 2013 at 07:42:40PM +0200, Wolfgang Denk wrote:
Fix:
participants (5)
Andy Fleming
Sinan Akman
Timur Tabi
