[U-Boot] [PATCH 12/25] x86: queensbay: Adapt FSP support codes
Use inline assembly codes to call FspNotify() to make sure parameters are passed on the stack as required by the FSP calling convention. Also update FSP support codes license header to use SPDX ID.
Signed-off-by: Bin Meng bmeng.cn@gmail.com --- arch/x86/cpu/queensbay/fsp_configs.c | 41 +++--------- arch/x86/cpu/queensbay/fsp_support.c | 74 +++++++++------------- arch/x86/include/asm/arch-queensbay/fsp/fsp_api.h | 34 ++-------- .../include/asm/arch-queensbay/fsp/fsp_bootmode.h | 34 ++-------- arch/x86/include/asm/arch-queensbay/fsp/fsp_ffs.h | 34 ++-------- arch/x86/include/asm/arch-queensbay/fsp/fsp_fv.h | 34 ++-------- arch/x86/include/asm/arch-queensbay/fsp/fsp_hob.h | 34 ++-------- .../asm/arch-queensbay/fsp/fsp_infoheader.h | 34 ++-------- .../include/asm/arch-queensbay/fsp/fsp_platform.h | 34 ++-------- .../include/asm/arch-queensbay/fsp/fsp_support.h | 39 ++---------- .../x86/include/asm/arch-queensbay/fsp/fsp_types.h | 34 ++-------- arch/x86/include/asm/arch-queensbay/fsp/fsp_vpd.h | 36 ++--------- 12 files changed, 90 insertions(+), 372 deletions(-)
diff --git a/arch/x86/cpu/queensbay/fsp_configs.c b/arch/x86/cpu/queensbay/fsp_configs.c index af5d737..872fae5 100644 --- a/arch/x86/cpu/queensbay/fsp_configs.c +++ b/arch/x86/cpu/queensbay/fsp_configs.c @@ -1,36 +1,11 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ - -#include <types.h> -#include <string.h> -#include "fsp_support.h" +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */ + +#include <common.h> +#include <asm/arch/fsp/fsp_support.h>
/** This function overrides the default configurations in the UPD data region. diff --git a/arch/x86/cpu/queensbay/fsp_support.c b/arch/x86/cpu/queensbay/fsp_support.c index 45f9621..5dc82b7 100644 --- a/arch/x86/cpu/queensbay/fsp_support.c +++ b/arch/x86/cpu/queensbay/fsp_support.c @@ -1,37 +1,12 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ - -#include <types.h> -#include <string.h> -#include "fsp_support.h" +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
+#include <common.h> +#include <asm/arch/fsp/fsp_support.h> +#include <asm/post.h>
/** Reads a 64-bit value from memory that may be unaligned. @@ -225,7 +200,6 @@ FindFspHeader ( @retval Never returns
**/ -#ifdef __PRE_RAM__ VOID BlContinuationFunc ( SHARED_DATA *SharedData, @@ -237,6 +211,8 @@ BlContinuationFunc ( UINT32 OldStackBaseInMemory; UINT32 OldStackTopInMemory;
+ post_code(POST_MRC); + ASSERT (Status == 0);
/* Get the migrated stack in normal memory */ @@ -253,7 +229,7 @@ BlContinuationFunc ( /* * The boot loader main function entry */ - bl_main_continue (HobListPtr, SharedData); + fsp_init_done(HobListPtr); }
/** @@ -322,6 +298,8 @@ FspInitWrapper ( SharedData.FspInfoHeader = FspInfoHeader; SharedData.NewStackTop = (UINT32 *)BlStackTop;
+ post_code(POST_PRE_MRC); + /* * Use ASM code to ensure the register value in ECX & EBX will be passed * into BlContinuationFunc @@ -331,11 +309,11 @@ FspInitWrapper ( "call *%%eax;" ".global AsmContinuation;" "AsmContinuation:;" - "popl %%eax;" /* pop out return address */ - "pushl %%ecx;" /* push SharedData pointer */ - "pushl %%eax;" /* push back return address */ + "movl %%ebx, %%eax;" /* 1st parameter SharedData pointer */ + "movl 4(%%esp), %%edx;" /* 2nd parameter Status */ + "movl 8(%%esp), %%ecx;" /* 3rd parameter HobList pointer */ "jmp BlContinuationFunc;" - : : "m"(FspInitParamsPtr), "a"(FspInitApi), "c"(&SharedData) + : : "m"(FspInitParamsPtr), "a"(FspInitApi), "b"(&SharedData) );
/* @@ -348,8 +326,6 @@ FspInitWrapper ( ASSERT (FALSE); }
-#else - /** FSP notification wrapper function. Calls into FSP code to perform platform initialization @@ -368,6 +344,7 @@ FspNotifyWrapper ( { FSP_NOTFY_PHASE NotifyPhaseProc; NOTIFY_PHASE_PARAMS NotifyPhaseParams; + NOTIFY_PHASE_PARAMS *NotifyPhaseParamsPtr; EFI_STATUS Status; FSP_INFO_HEADER *FspHeader;
@@ -385,12 +362,21 @@ FspNotifyWrapper (
NotifyPhaseProc = (FSP_NOTFY_PHASE)(FspHeader->ImageBase + FspHeader->NotifyPhaseEntry); NotifyPhaseParams.Phase = Phase; - Status = NotifyPhaseProc (&NotifyPhaseParams); + NotifyPhaseParamsPtr = &NotifyPhaseParams; + + /* + * Use ASM code to ensure correct parameter is on the stack for FspNotify + * as U-Boot is using different ABI from FSP + */ + asm volatile ( + "pushl %1;" /* push notify phase */ + "call *%%eax;" /* call FspNotify */ + "addl $4, %%esp;" /* clean up the stack */ + : "=a"(Status) : "m"(NotifyPhaseParamsPtr), "a"(NotifyPhaseProc), "m"(*NotifyPhaseParamsPtr) + ); return Status; }
-#endif /* __PRE_RAM__ */ - /** This function retrieves the top of usable low memory.
diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_api.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_api.h index 6408d2f..750c5d8 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_api.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_api.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_API_H__ #define __FSP_API_H__ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_bootmode.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_bootmode.h index 805ff4e..d6821cc 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_bootmode.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_bootmode.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_BOOT_MODE_H__ #define __FSP_BOOT_MODE_H__ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_ffs.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_ffs.h index 3515a0d..4207661 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_ffs.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_ffs.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_FFS_H__ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_fv.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_fv.h index dad6c90..d08e970 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_fv.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_fv.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_FV___ #define __FSP_FV___ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_hob.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_hob.h index 00a8a03..def4dab 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_hob.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_hob.h @@ -1,32 +1,8 @@ -/** - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_HOB_H__ #define __FSP_HOB_H__ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_infoheader.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_infoheader.h index 1af1abb..02a62f7 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_infoheader.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_infoheader.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef _FSP_INFO_HEADER_H_ #define _FSP_INFO_HEADER_H_ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_platform.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_platform.h index d73f4b4..4aeaf46 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_platform.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_platform.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_PLATFORM_H__ #define __FSP_PLATFORM_H__ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_support.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_support.h index 8960e6c..442d128 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_support.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_support.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_SUPPORT_H__ #define __FSP_SUPPORT_H__ @@ -126,9 +102,8 @@ BlContinuationFunc ( );
VOID -bl_main_continue ( - VOID *HobListPtr, - SHARED_DATA *SharedData +fsp_init_done ( + VOID *HobListPtr );
VOID * diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_types.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_types.h index 52ba06b..fc209cb 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_types.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_types.h @@ -1,32 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __FSP_TYPES_H__ diff --git a/arch/x86/include/asm/arch-queensbay/fsp/fsp_vpd.h b/arch/x86/include/asm/arch-queensbay/fsp/fsp_vpd.h index a8e1975..03e8926 100644 --- a/arch/x86/include/asm/arch-queensbay/fsp/fsp_vpd.h +++ b/arch/x86/include/asm/arch-queensbay/fsp/fsp_vpd.h @@ -1,34 +1,8 @@ -/** @file - -Copyright (C) 2013, Intel Corporation - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - - This file is automatically generated. Please do NOT modify !!! - -**/ +/* + * Copyright (C) 2013, Intel Corporation + * + * SPDX-License-Identifier: Intel + */
#ifndef __VPDHEADER_H__ #define __VPDHEADER_H__
Hi Bin,
Does this fix all the style issues introduced in the previous patch?
Hi Simon,
On Fri, Dec 5, 2014 at 6:47 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
No, the style issues are still there.
Regards, Bin
Bin Meng
