[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit 2271e7c6e8eef883b834fb7d07911848a54fde13:
Ethernut 5: fix build error (2012-02-29 01:06:56 +0100)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Dirk Behme (1): mx6q: mx6qsabrelite: Update the README
Marek Vasut (3): M28: Fix LCD PINMUX M28: Support for the old M28 SoM v1.0 i.MX28: Reformat the DRAM memory configuration data
Robert Delien (5): i.mx28: Added register definitions for DIGCTL registers i.mx28: Replaced magic numbers for scratch register addresses with register definitions Renamed mx28_register to mx28_register_32 to prepare for mx28_register_8 Introducing 8-bit wide register, mx28_register_8 Fix erroneous 32-bit access to hw_clkctrl_frac0 and hw_clkctrl_frac1 registers
Wolfgang Grandegger (2): usb/ehci: Add USB support for the MX6Q mx6qsabrelite: add and enable USB Host 1 support
arch/arm/cpu/arm926ejs/mx28/clock.c | 74 +++----- arch/arm/cpu/arm926ejs/mx28/iomux.c | 6 +- arch/arm/cpu/arm926ejs/mx28/mx28.c | 14 +- arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c | 120 ++++++------ arch/arm/cpu/armv7/mx6/clock.c | 13 ++ arch/arm/include/asm/arch-mx28/imx-regs.h | 1 + arch/arm/include/asm/arch-mx28/regs-apbh.h | 254 ++++++++++++------------ arch/arm/include/asm/arch-mx28/regs-bch.h | 42 ++-- arch/arm/include/asm/arch-mx28/regs-clkctrl.h | 98 ++++------ arch/arm/include/asm/arch-mx28/regs-common.h | 28 ++- arch/arm/include/asm/arch-mx28/regs-digctl.h | 155 +++++++++++++++ arch/arm/include/asm/arch-mx28/regs-gpmi.h | 26 ++-- arch/arm/include/asm/arch-mx28/regs-i2c.h | 28 ++-- arch/arm/include/asm/arch-mx28/regs-ocotp.h | 86 ++++---- arch/arm/include/asm/arch-mx28/regs-pinctrl.h | 168 ++++++++-------- arch/arm/include/asm/arch-mx28/regs-power.h | 28 ++-- arch/arm/include/asm/arch-mx28/regs-rtc.h | 28 ++-- arch/arm/include/asm/arch-mx28/regs-ssp.h | 40 ++-- arch/arm/include/asm/arch-mx28/regs-timrot.h | 38 ++-- arch/arm/include/asm/arch-mx28/regs-usbphy.h | 20 +- arch/arm/include/asm/arch-mx28/sys_proto.h | 10 +- arch/arm/include/asm/arch-mx6/clock.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 3 + board/denx/m28evk/spl_boot.c | 16 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 18 ++ doc/README.mx6qsabrelite | 12 +- drivers/gpio/mxs_gpio.c | 16 +- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-mx6.c | 205 ++++++++++++++++++++ drivers/usb/host/ehci-mxs.c | 8 +- include/configs/mx6qsabrelite.h | 13 ++ 31 files changed, 988 insertions(+), 582 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx28/regs-digctl.h create mode 100644 drivers/usb/host/ehci-mx6.c
Best regards, Stefano Babic
Hi Stefano,
Le 03/03/2012 12:38, Stefano Babic a écrit :
Hi Albert,
Applied to u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
Stefano Babic
