[PATCH] net: ipv6: Add missing break into IPv6 protocol handler
IPv6 protocol handler is not terminated with a break statment. It can lead to running unexpected code.
Signed-off-by: Viacheslav Mitrofanov v.v.mitrofanov@yadro.com --- net/net.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/net/net.c b/net/net.c index 1c39acc493..57da9bda85 100644 --- a/net/net.c +++ b/net/net.c @@ -1269,6 +1269,7 @@ void net_process_received_packet(uchar *in_packet, int len) #if IS_ENABLED(CONFIG_IPV6) case PROT_IP6: net_ip6_handler(et, (struct ip6_hdr *)ip, len); + break; #endif case PROT_IP: debug_cond(DEBUG_NET_PKT, "Got IP\n");
thanks for the quick fix
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
#endif case PROT_IP: debug_cond(DEBUG_NET_PKT, "Got IP\n");break;
Signed-off-by: Viacheslav Mitrofanov v.v.mitrofanov@yadro.com Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Daniel Schwierzeck
