[U-Boot] [PATCH] sunxi: add spi flash bootcmd
Enable SPI bootcmd if CONFIG_DM_SPI_FLASH is defined.
Signed-off-by: Oskari Lemmela oskari@lemmela.net --- include/configs/sunxi-common.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 9819d9980c..b2443ef678 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -401,6 +401,21 @@ extern int soft_i2c_gpio_scl; #define BOOT_TARGET_DEVICES_USB(func) #endif
+#ifdef CONFIG_DM_SPI_FLASH +#define BOOT_TARGET_DEVICES_SPI(func) func(SPI, spi, 0) +#define BOOTENV_DEV_SPI(devtypeu, devtypel, instance) \ + "image_addr=0x100000\0" \ + "image_size=0x700000\0" \ + "bootcmd_" #devtypel #instance "=" \ + "if sf probe " #instance "; then " \ + "sf read ${ramdisk_addr_r} ${image_addr} ${image_size}; " \ + "bootm ${ramdisk_addr_r}; " \ + "fi\0" +#define BOOTENV_DEV_NAME_SPI(devtypeu, devtypel, instance) \ + #devtypel #instance " " +#else +#define BOOT_TARGET_DEVICES_SPI(func) +#endif /* FEL boot support, auto-execute boot.scr if a script address was provided */ #define BOOTENV_DEV_FEL(devtypeu, devtypel, instance) \ "bootcmd_fel=" \ @@ -416,6 +431,7 @@ extern int soft_i2c_gpio_scl; BOOT_TARGET_DEVICES_MMC(func) \ BOOT_TARGET_DEVICES_SCSI(func) \ BOOT_TARGET_DEVICES_USB(func) \ + BOOT_TARGET_DEVICES_SPI(func) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
This belongs more in include/config_distro_bootcmd.h, there's nothing really sunxi specific here.
- "image_addr=0x100000\0" \
- "image_size=0x700000\0" \
image_addr and image_size usually come from Kconfig, instead of being hardcoded
- "bootcmd_" #devtypel #instance "=" \
s/ramdisk_addr_r/kernel_addr_r/
Thanks! Maxime
On Mon, 7 Jan 2019 14:16:23 +0100 Maxime Ripard maxime.ripard@bootlin.com wrote:
Actually this whole approach looks very specific to me, if I understand this correctly, it loads 7 MB from 1MB of the SPI flash and treats this as a kernel? This looks very arbitrary to me, requires at least 8MB of SPI flash (many boards come with just 2MB) and will never hold any normal arm64 kernel (which are in the range of 16MB, typically). So this might fit some specific embedded project, but doesn't look like something we want in the default environment. If there is a use case for it, people can always either set up their specific environment (and store it in FAT), or change the default environment just for their build.
Cheers, Andre.
${image_size}; " \
Thanks! Maxime
True. I'll try to rework it that way.
Cheers, Andre.
Making image_addr and image_size configurable via Kconfig would allow this be generic approach.
Goal is not load kernel image directly as it would be too big for most of SPI flash devices. Approach is load FIT image some where else and then let u-boot uncompress and boot it.
Most likely 2MB flash device is not enough even when lzma compressing kernel.
${image_size}; " \
Reason explained earlier boot process would be loading FIT image to ramdisk_addr_r. Then u-boot will decompress kernel, dtb and ramdisk to memory and boot kernel.
Or could it be better not to use ramdisk_addr_r and replace it with some other configurable memory address?
Example boot log:
=> sf probe 0 SF: Detected w25q128bv with page size 256 Bytes, erase size 4 KiB, total 16 MiB => sf read ${ramdisk_addr_r} ${image_addr} ${image_size} device 0 offset 0x100000, size 0x700000 SF: 7340032 bytes @ 0x100000 Read: OK => bootm ${ramdisk_addr_r} ## Loading kernel from FIT Image at 4fe00000 ... Using 'config@1' configuration Trying 'kernel@1' kernel subimage Description: ARM64 Linux-4.19.13 Type: Kernel Image Compression: lzma compressed Data Start: 0x4fe000e8 Data Size: 2812412 Bytes = 2.7 MiB Architecture: AArch64 OS: Linux Load Address: 0x40080000 Entry Point: 0x40080000 Hash algo: crc32 Hash value: 27f9179d Hash algo: sha1 Hash value: f5e9b16f6958cca20013f06074ad85141ccd3cc6 Verifying Hash Integrity ... crc32+ sha1+ OK ## Loading fdt from FIT Image at 4fe00000 ... Using 'config@1' configuration Trying 'fdt@1' fdt subimage Description: ARM64 sun50i-a64-pine64-lts device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x500aec2c Data Size: 13158 Bytes = 12.8 KiB Architecture: AArch64 Hash algo: crc32 Hash value: 3d2574b7 Hash algo: sha1 Hash value: c55ea000ca7925a505a5de69425b49d8092ceb5e Verifying Hash Integrity ... crc32+ sha1+ OK Booting using the fdt blob at 0x500aec2c EHCI failed to shut down host controller. EHCI failed to shut down host controller. Uncompressing Kernel Image ... OK Loading Device Tree to 0000000049ff9000, end 0000000049fff365 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Thanks! Maxime
Thanks! Oskari
I don't think it belongs there. As the name says, this is for distros to find their kernel, using all kind of standards: boot partitions, magic filenames, config files, etc. Loading from some made up address from SPI flash doesn't belong there.
Cheers, Andre.
It would still not be generic, but I am fine with this if the whole thing is protected by Kconfig: So it only probes SPI flash if there was a flash load address specified at compile time. And by default there should be none, as I still consider this a special use case. In an ideal world the SPI flash would be owned by firmware, so we could put EFI applications (EFI shell, grub) on there, for instance.
Can you also add some documentation on this feature somewhere?
${image_size}; " \
I guess you need to, otherwise extracting the ramdisk would overwrite the image, wouldn't it?
Does bootm detect the ramdisk in a FIT image and does the right thing automatically?
Cheers, Andre.
Example boot log:
Starting kernel ...
Thanks! Maxime
Thanks! Oskari
Andre Przywara
Maxime Ripard
Oskari Lemmela
Oskari Lemmelä
