[PATCH 1/3] buildman: Write output even on fatal error
At present buildman does not write any output (to the 'out' and 'err) files if the build terminates with a fatal error. This is to avoid adding lots of spam to the logs.
However there are times when this is actually useful, such as when the build fails for an obscure reason such as a Kconfig loop.
Update the logic to always write the output, so that the user gets a clue as to what is happening.
tools/buildman/builderthread.py | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index 48128cf6732..3e450e40670 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -300,16 +300,12 @@ class BuilderThread(threading.Thread): work_in_output: Use the output directory as the work directory and don't write to a separate output directory. """ - # Fatal error - if result.return_code < 0: - return - # If we think this might have been aborted with Ctrl-C, record the # failure but not that we are 'done' with this board. A retry may fix # it. - maybe_aborted = result.stderr and 'No child processes' in result.stderr + maybe_aborted = result.stderr and 'No child processes' in result.stderr
- if result.already_done: + if result.return_code >= 0 and result.already_done: return
# Write the output and stderr @@ -332,6 +328,10 @@ class BuilderThread(threading.Thread): elif os.path.exists(errfile): os.remove(errfile)
+ # Fatal error + if result.return_code < 0: + return + if result.toolchain: # Write the build result and toolchain information. done_file = self.builder.GetDoneFile(result.commit_upto,
Hex and int Kconfig options are supposed to have defaults. This is so we can configure U-Boot without having to enter particular values for the items that don't have specific values in the board's defconfig file.
If this rule is not followed, then introducing a new Kconfig can produce a loop like this:
Break things (BREAK_ME) [] (NEW) Error in reading or end of file.
The continues forever since buildman passes /dev/null to 'conf', and the build system just tries again. Eventually there is so much output that buildman runs out of memory.
We can detect this situation by looking for a symbol (like 'BREAK_ME') which has no default (the '[]' above) and is marked as new. If this appears multiple times in the output, we know something is wrong.
Add a filter function for the output which detects this situation. Allow it to return True to terminate the process. Implement this termination in cros_subprocess.
With this we get a nice message:
buildman --board sandbox -T0 Building current source for 1 boards (0 threads, 32 jobs per thread) sandbox: w+ sandbox +.config:66:warning: symbol value '' invalid for BREAK_ME + +Error in reading or end of file. +make[3]: *** [scripts/kconfig/Makefile:75: syncconfig] Terminated +make[2]: *** [Makefile:569: syncconfig] Terminated +make: *** [Makefile:177: sub-make] Terminated +(** did you define an int/hex Kconfig with no default? **)
tools/buildman/builder.py | 43 ++++++++++++++++++++++++++++++++- tools/patman/command.py | 7 ++++-- tools/patman/cros_subprocess.py | 10 ++++++-- 3 files changed, 55 insertions(+), 5 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index ce852eb03a3..122f0d14065 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -24,6 +24,17 @@ from patman import gitutil from patman import terminal from patman.terminal import Print
+# This indicates an new int or hex Kconfig property with no default +# It hangs the build since the 'conf' tool cannot proceed without valid input. +# +# We get a repeat sequence of something like this: +# >> +# Break things (BREAK_ME) [] (NEW) +# Error in reading or end of file. +# << +# which indicates that BREAK_ME has an empty default +RE_NO_DEFAULT = re.compile(b'((\w+)) [] (NEW)') + """ Theory of Operation
@@ -200,6 +211,8 @@ class Builder: _working_dir: Base working directory containing all threads _single_builder: BuilderThread object for the singer builder, if threading is not being used + _terminated: Thread was terminated due to an error + _restarting_config: True if 'Restart config' is detected in output """ class Outcome: """Records a build outcome for a single make invocation @@ -304,6 +317,8 @@ class Builder: self.work_in_output = work_in_output if not self.squash_config_y: self.config_filenames += EXTRA_CONFIG_FILENAMES + self._terminated = False + self._restarting_config = False
self.warnings_as_errors = warnings_as_errors self.col = terminal.Color() @@ -429,9 +444,35 @@ class Builder: args: Arguments to pass to make kwargs: Arguments to pass to command.RunPipe() """ + + def check_output(stream, data): + if b'Restart config' in data: + self._restarting_config = True + + # If we see 'Restart config' following by multiple errors + if self._restarting_config: + m = RE_NO_DEFAULT.findall(data) + + # Number of occurences of each Kconfig item + multiple = [m.count(val) for val in set(m)] + + # If any of them occur more than once, we have a loop + if [val for val in multiple if val > 1]: + self._terminated = True + return True + return False + + self._restarting_config = False + self._terminated = False cmd = [self.gnu_make] + list(args) result = command.RunPipe([cmd], capture=True, capture_stderr=True, - cwd=cwd, raise_on_error=False, infile='/dev/null', **kwargs) + cwd=cwd, raise_on_error=False, infile='/dev/null', + output_func=check_output, **kwargs) + + if self._terminated: + # Try to be helpful + result.stderr += '(** did you define an int/hex Kconfig with no default? **)' + if self.verbose_build: result.stdout = '%s\n' % (' '.join(cmd)) + result.stdout result.combined = '%s\n' % (' '.join(cmd)) + result.combined diff --git a/tools/patman/command.py b/tools/patman/command.py index bf8ea6c8c3c..d54b1e0efce 100644 --- a/tools/patman/command.py +++ b/tools/patman/command.py @@ -49,7 +49,8 @@ test_result = None
def RunPipe(pipe_list, infile=None, outfile=None, capture=False, capture_stderr=False, oneline=False, - raise_on_error=True, cwd=None, binary=False, **kwargs): + raise_on_error=True, cwd=None, binary=False, + output_func=None, **kwargs): """ Perform a command pipeline, with optional input/output filenames.
@@ -63,6 +64,8 @@ def RunPipe(pipe_list, infile=None, outfile=None, capture: True to capture output capture_stderr: True to capture stderr oneline: True to strip newline chars from output + output_func: Output function to call with each output fragment + (if it returns True the function terminates) kwargs: Additional keyword arguments to cros_subprocess.Popen() Returns: CommandResult object @@ -105,7 +108,7 @@ def RunPipe(pipe_list, infile=None, outfile=None,
if capture: result.stdout, result.stderr, result.combined = ( - last_pipe.CommunicateFilter(None)) + last_pipe.CommunicateFilter(output_func)) if result.stdout and oneline: result.output = result.stdout.rstrip(b'\r\n') result.return_code = last_pipe.wait() diff --git a/tools/patman/cros_subprocess.py b/tools/patman/cros_subprocess.py index fdd51386856..88a4693feff 100644 --- a/tools/patman/cros_subprocess.py +++ b/tools/patman/cros_subprocess.py @@ -128,6 +128,9 @@ class Popen(subprocess.Popen): sys.stdout or sys.stderr. data: a string containing the data
+ Returns: + True to terminate the process + Note: The data read is buffered in memory, so do not use this method if the data size is large or unlimited.
@@ -175,6 +178,7 @@ class Popen(subprocess.Popen): stderr = bytearray() combined = bytearray()
+ stop_now = False input_offset = 0 while read_set or write_set: try: @@ -212,7 +216,7 @@ class Popen(subprocess.Popen): stdout += data combined += data if output: - output(sys.stdout, data) + stop_now = output(sys.stdout, data) if self.stderr in rlist: data = b'' # We will get an error on read if the pty is closed @@ -227,7 +231,9 @@ class Popen(subprocess.Popen): stderr += data combined += data if output: - output(sys.stderr, data) + stop_now = output(sys.stderr, data) + if stop_now: + self.terminate()
# All data exchanged. Translate lists into strings. stdout = self.ConvertData(stdout)
That's not true. All symbols that we can make reasonable defaults for get them. It's just that for boolean n is a reasonable default. int/hex often just need to be entered, period.
Everything else is fine however, thanks for digging in to this.
Hi Tom,
I got that from there and it made sense as to why we have this problem:
https://docs.zephyrproject.org/2.4.0/guides/kconfig/tips.html#redundant-defa...
But I think you are right if we should update the commit message here to avoid confusion. Shall I send v2?
On Thu, Oct 21, 2021 at 10:09:56AM -0600, Simon Glass wrote:
Hi Tom,
Yeah, we're just in the bad spot because of things not being fully migrated.
Yes please.
Hi Simon,
Hi Tom,
Yes please.
As delta...
I applied 1-2 to u-boot-imx (else I was stuck), and they are already merged as part of my PR. Your patches are already on -master.
Regards, Stefano
Hi Stefano,
On Thu, 21 Oct 2021 at 10:35, Stefano Babic sbabic@denx.de wrote:
Hi Simon,
Hi Tom,
Yes please.
As delta...
Oh I can't do that as it was the commit message that needed to change.
It's fine, just an error that I doubt people will not notice / get confused by.
Stefano Babic
