[PATCHv2] cmd/gpt: Address error cases during gpt rename more correctly
New analysis by the tool has shown that we have some cases where we weren't handling the error exit condition correctly. When we ran into the ENOMEM case we wouldn't exit the function and thus incorrect things could happen. Rework the unwinding such that we don't need a helper function now and free what we may have allocated.
Fixes: 18030d04d25d ("GPT: fix memory leaks identified by Coverity") Reported-by: Coverity (CID: 275475, 275476) Cc: Alison Chaiken alison@she-devel.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Jordy jordy@simplyhacker.com Signed-off-by: Tom Rini trini@konsulko.com
--- Changes in v2: - Initialize str_disk_guid to NULL to be sure we can test that it has been set later on (Simon, Jordy).
cmd/gpt.c | 37 +++++++++---------------------------- 1 file changed, 9 insertions(+), 28 deletions(-)
diff --git a/cmd/gpt.c b/cmd/gpt.c index 0c4349f4b249..c0e3c5161789 100644 --- a/cmd/gpt.c +++ b/cmd/gpt.c @@ -633,21 +633,6 @@ static int do_disk_guid(struct blk_desc *dev_desc, char * const namestr) }
#ifdef CONFIG_CMD_GPT_RENAME -/* - * There are 3 malloc() calls in set_gpt_info() and there is no info about which - * failed. - */ -static void set_gpt_cleanup(char **str_disk_guid, - disk_partition_t **partitions) -{ -#ifdef CONFIG_RANDOM_UUID - if (str_disk_guid) - free(str_disk_guid); -#endif - if (partitions) - free(partitions); -} - static int do_rename_gpt_parts(struct blk_desc *dev_desc, char *subcomm, char *name1, char *name2) { @@ -655,7 +640,7 @@ static int do_rename_gpt_parts(struct blk_desc *dev_desc, char *subcomm, struct disk_part *curr; disk_partition_t *new_partitions = NULL; char disk_guid[UUID_STR_LEN + 1]; - char *partitions_list, *str_disk_guid; + char *partitions_list, *str_disk_guid = NULL; u8 part_count = 0; int partlistlen, ret, numparts = 0, partnum, i = 1, ctr1 = 0, ctr2 = 0;
@@ -699,11 +684,7 @@ static int do_rename_gpt_parts(struct blk_desc *dev_desc, char *subcomm, &new_partitions, &part_count); if (ret < 0) { del_gpt_info(); - free(partitions_list); - if (ret == -ENOMEM) - set_gpt_cleanup(&str_disk_guid, &new_partitions); - else - goto out; + goto out; }
if (!strcmp(subcomm, "swap")) { @@ -768,11 +749,7 @@ static int do_rename_gpt_parts(struct blk_desc *dev_desc, char *subcomm, */ if (ret < 0) { del_gpt_info(); - free(partitions_list); - if (ret == -ENOMEM) - set_gpt_cleanup(&str_disk_guid, &new_partitions); - else - goto out; + goto out; }
debug("Writing new partition table\n"); @@ -797,8 +774,12 @@ static int do_rename_gpt_parts(struct blk_desc *dev_desc, char *subcomm, print_gpt_info(); del_gpt_info(); out: - free(new_partitions); - free(str_disk_guid); +#ifdef CONFIG_RANDOM_UUID + if (str_disk_guid) + free(str_disk_guid); +#endif + if (new_partitions) + free(new_partitions); free(partitions_list); return ret; }
Changes in v2:
- There are 3 malloc() calls in set_gpt_info() and there is no info about which
- failed.
if (str_disk_guid)
-#endif
if (partitions)
free(partitions);
if (ret == -ENOMEM)
else
goto out;
goto out; } if (!strcmp(subcomm, "swap")) {
if (ret == -ENOMEM)
else
goto out;
goto out; } debug("Writing new partition table\n");
OK, so the freeing below looks good to me now. However, what worries me is that when reaching 'out:' via different code flows, del_gpt_info is not always called. I think that could lead to memory leaks when calling this code again, as get_gpt_info just reinitializes the list head without checking if there's actually something allocated in the list.
Maybe we should move the last call to del_gpt_info below 'out:' so that it is always called?
if (str_disk_guid)
if (new_partitions)
2.17.1
Changes in v2:
- failed.
if (str_disk_guid)
-#endif
if (partitions)
free(partitions);
if (ret == -ENOMEM)
else
goto out;
if (ret == -ENOMEM)
else
goto out;
I think that's safe to do, yes. v3 coming up..
Simon Goldschmidt
