[PATCH 1/1] riscv: sifive: fu540: redundant initialization
We should not initialize a variable if the value is overwritten before being read.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/riscv/cpu/fu540/cache.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/riscv/cpu/fu540/cache.c b/arch/riscv/cpu/fu540/cache.c index 9ee364b509..54de14238c 100644 --- a/arch/riscv/cpu/fu540/cache.c +++ b/arch/riscv/cpu/fu540/cache.c @@ -22,7 +22,7 @@ DECLARE_GLOBAL_DATA_PTR; int cache_enable_ways(void) { const void *blob = gd->fdt_blob; - int node = (-FDT_ERR_NOTFOUND); + int node; fdt_addr_t base; u32 config; u32 ways; -- 2.27.0
Reviewed-by: Bin Meng bin.meng@windriver.com
-----Original Message----- From: Heinrich Schuchardt xypron.glpk@gmx.de Sent: 04 August 2020 02:40 To: Rick Chen rick@andestech.com Cc: Pragnesh Patel pragnesh.patel@sifive.com; Bin Meng bmeng.cn@gmail.com; u-boot@lists.denx.de; Heinrich Schuchardt xypron.glpk@gmx.de Subject: [PATCH 1/1] riscv: sifive: fu540: redundant initialization
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Reviewed-by: Pragnesh Patel pragnesh.patel@sifive.com Tested-by: Pragnesh Patel pragnesh.patel@sifive.com
Bin Meng
Pragnesh Patel
