[U-Boot] Pull request, u-boot-tegra/master
Tom,
Please pull u-boot-tegra/master into U-Boot/master. Thanks!
All tegra builds are OK (32-bit and 64-bit), and P2571 T210 64-bit boots to cmd prompt OK.
The following changes since commit 038be18fd95aa6283eafb85ceabc0b880976424b:
nios2: add 3c120 and 10m50 devboards MAINTAINERS (2015-11-12 08:26:59 +0800)
git://git.denx.de/u-boot-tegra.git master
for you to fetch changes up to e1cf5278024eb5c72abd69d6bda266ffc5832941:
ARM: tegra: note that p2371-2180 is Jetson TX1 (2015-11-12 09:27:16 -0700)
---------------------------------------------------------------- Alexandre Courbot (3): ARM: tegra: remove vpr_configured() function ARM: tegra: simplify GPU setup ARM: tegra: rename GPU functions
Stephen Warren (16): ARM: tegra210: implement PLLE init procedure from TRM pci: tegra: clip RAM size to 32-bits pci: tegra: use #address-/size-cells from DT pci: tegra: implement PCA enable workaround pci: tegra: call tegra_pcie_board_init() earlier pci: tegra: add/enable support for Tegra210 ARM: tegra: add PCI to Tegra210 SoC DT ARM: tegra: enable PCI support of p2371-2180 ARM: tegra: rename dummy XUSB padctl implementation ARM: tegra: clean up XUSB padctl error() calls ARM: tegra: create common XUSB padctl driver file ARM: tegra: parameterize common XUSB code ARM: tegra: switch Tegra210 to common XUSB padctl ARM: tegra: add lane tables to Tegra210 XUSB padctl ARM: tegra: error check Tegra210 XUSB padctl waits ARM: tegra: note that p2371-2180 is Jetson TX1
Tom Warren (1): Tegra: T210: Add QSPI driver
arch/arm/dts/tegra210-p2371-2180.dts | 50 +++ arch/arm/dts/tegra210.dtsi | 66 ++++ arch/arm/include/asm/arch-tegra/gpu.h | 14 +- arch/arm/mach-tegra/Makefile | 2 +- arch/arm/mach-tegra/board2.c | 22 +- arch/arm/mach-tegra/gpu.c | 11 +- arch/arm/mach-tegra/tegra124/Makefile | 1 + arch/arm/mach-tegra/tegra124/xusb-padctl.c | 431 ++------------------- arch/arm/mach-tegra/tegra210/Kconfig | 10 +- arch/arm/mach-tegra/tegra210/Makefile | 1 + arch/arm/mach-tegra/tegra210/clock.c | 179 ++++++--- arch/arm/mach-tegra/tegra210/xusb-padctl.c | 248 +++++------- arch/arm/mach-tegra/xusb-padctl-common.c | 305 +++++++++++++++ arch/arm/mach-tegra/xusb-padctl-common.h | 101 +++++ .../{xusb-padctl.c => xusb-padctl-dummy.c} | 0 board/nvidia/jetson-tk1/jetson-tk1.c | 8 - board/nvidia/p2371-2180/p2371-2180.c | 30 ++ board/nvidia/p2571/p2571.c | 7 - board/nvidia/venice2/venice2.c | 8 - drivers/pci/pci_tegra.c | 83 +++- drivers/spi/Kconfig | 7 + drivers/spi/Makefile | 1 + drivers/spi/tegra210_qspi.c | 417 ++++++++++++++++++++ include/configs/jetson-tk1.h | 2 - include/configs/p2371-2180.h | 10 + include/configs/p2571.h | 2 - include/configs/tegra-common.h | 2 + include/configs/venice2.h | 2 - include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 30 files changed, 1353 insertions(+), 669 deletions(-) create mode 100644 arch/arm/mach-tegra/xusb-padctl-common.c create mode 100644 arch/arm/mach-tegra/xusb-padctl-common.h rename arch/arm/mach-tegra/{xusb-padctl.c => xusb-padctl-dummy.c} (100%) create mode 100644 drivers/spi/tegra210_qspi.c
On Thu, Nov 12, 2015 at 01:53:31PM -0700, Tom Warren wrote:
Tom,
Tom Warren
