[PATCH v2] Kconfig: Don't use RSA_FREESCALE_EXP on MX7ULP
The CAAM on IMX7ULP doesn't support public key hardware acceleration (PKHA), as in other NXP parts. Disable RSA_FREESCALE_EXP for IMX7ULP too.
Fixed: f4e9ff7135 ("Kconfig: Don't use RSA_FREESCALE_EXP on IMX") Signed-off-by: Ricardo Salveti ricardo@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
Changes in v2: - add a dependency rule for RSA_FREESCALE_EXP
lib/rsa/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/rsa/Kconfig b/lib/rsa/Kconfig index a90d67e5a8..634c9e5fa9 100644 --- a/lib/rsa/Kconfig +++ b/lib/rsa/Kconfig @@ -1,6 +1,6 @@ config RSA bool "Use RSA Library" - select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX6 && !ARCH_MX5 + select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX7ULP && !ARCH_MX6 && !ARCH_MX5 select RSA_SOFTWARE_EXP if !RSA_FREESCALE_EXP help RSA support. This enables the RSA algorithm used for FIT image @@ -56,7 +56,7 @@ config RSA_SOFTWARE_EXP
config RSA_FREESCALE_EXP bool "Enable RSA Modular Exponentiation with FSL crypto accelerator" - depends on DM && FSL_CAAM && !ARCH_MX7 && !ARCH_MX6 && !ARCH_MX5 + depends on DM && FSL_CAAM && !ARCH_MX7 && !ARCH_MX7ULP && !ARCH_MX6 && !ARCH_MX5 help Enables driver for RSA modular exponentiation using Freescale cryptographic accelerator - CAAM.
From: Ricardo Salveti ricardo@foundries.io The CAAM on IMX7ULP doesn't support public key hardware acceleration (PKHA), as in other NXP parts. Disable RSA_FREESCALE_EXP for IMX7ULP too. Fixed: f4e9ff7135 ("Kconfig: Don't use RSA_FREESCALE_EXP on IMX") Signed-off-by: Ricardo Salveti ricardo@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io
Best regards, Stefano Babic
Oleksandr Suvorov
sbabic@denx.de
