[PATCH 0/1] Add support for Cool Pi GenBook
Support for Cool Pi GenBook is landing linux-rockchip[], so also add the support for u-boot here.
[0] https://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip.git/com...
Andy Yan (1): board: rockchip: Add support for rk3588 GenBook
.../dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi | 70 ++++ arch/arm/mach-rockchip/rk3588/Kconfig | 7 + board/coolpi/genbook/Kconfig | 12 + board/coolpi/genbook/MAINTAINERS | 7 + board/coolpi/genbook/README | 23 ++ configs/coolpi-genbook-rk3588_defconfig | 104 ++++++ .../rockchip/rk3588-coolpi-cm5-genbook.dts | 349 ++++++++++++++++++ include/configs/genbook-rk3588.h | 28 ++ 8 files changed, 600 insertions(+) create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi create mode 100644 board/coolpi/genbook/Kconfig create mode 100644 board/coolpi/genbook/MAINTAINERS create mode 100644 board/coolpi/genbook/README create mode 100644 configs/coolpi-genbook-rk3588_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts create mode 100644 include/configs/genbook-rk3588.h
Add support for Cool Pi GenBook.
Specification: - Rockchip RK3588 - LPDDR5X 8/32 GB - eMMC 64 GB - HDMI Type A out x 1 - USB 3.0 Host x 1 - USB-C 3.0 with DisplayPort AltMode - PCIE M.2 E Key for RTL8852BE Wireless connection - PCIE M.2 M Key for NVME connection - eDP panel with 1920x1080
Test by a Armbian boot on USB disk.
Signed-off-by: Andy Yan andyshrk@163.com
diff --git a/arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi b/arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi new file mode 100644 index 00000000000..5835bd4352b --- /dev/null +++ b/arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi @@ -0,0 +1,70 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588-u-boot.dtsi" + +&fspim2_pins { + bootph-pre-ram; + bootph-some-ram; +}; + +&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim2_pins>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + bootph-pre-ram; + bootph-some-ram; + spi-max-frequency = <24000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +/* For Keypad */ +&usb_host0_ehci { + status = "disabled"; +}; + +&usb_host0_ohci { + status = "disabled"; +}; + +&usb_host0_xhci { + dr_mode = "peripheral"; + maximum-speed = "high-speed"; + status = "okay"; +}; + +/* connected to a HUB for camera and BT */ +&usb_host1_ehci { + status = "disabled"; +}; + +&usb_host1_ohci { + status = "disabled"; +}; + +/* USB A out */ +&usb_host1_xhci { + snps,dis_u3_susphy_quirk; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index e751d64e1a1..dc53d559ed9 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -6,6 +6,12 @@ config TARGET_EVB_RK3588 help RK3588 EVB is a evaluation board for Rockchp RK3588.
+config TARGET_GENBOOK_RK3588 + bool "Cool Pi GenBook" + select BOARD_LATE_INIT + help + GeenBook is a notebook based on Rockchip RK3588. + config TARGET_JAGUAR_RK3588 bool "Theobroma Systems SBC-RK3588-AMR (Jaguar)" select BOARD_LATE_INIT @@ -323,5 +329,6 @@ source "board/rockchip/evb_rk3588/Kconfig" source "board/rockchip/toybrick_rk3588/Kconfig" source "board/theobroma-systems/jaguar_rk3588/Kconfig" source "board/theobroma-systems/tiger_rk3588/Kconfig" +source "board/coolpi/genbook/Kconfig"
endif diff --git a/board/coolpi/genbook/Kconfig b/board/coolpi/genbook/Kconfig new file mode 100644 index 00000000000..48a340d79c5 --- /dev/null +++ b/board/coolpi/genbook/Kconfig @@ -0,0 +1,12 @@ +if TARGET_GENBOOK_RK3588 + +config SYS_BOARD + default "genbook" + +config SYS_VENDOR + default "coolpi" + +config SYS_CONFIG_NAME + default "genbook-rk3588" + +endif diff --git a/board/coolpi/genbook/MAINTAINERS b/board/coolpi/genbook/MAINTAINERS new file mode 100644 index 00000000000..45c2ddc5fa1 --- /dev/null +++ b/board/coolpi/genbook/MAINTAINERS @@ -0,0 +1,7 @@ +GENBOOK-RK3588 +M: andyshrk andyshrk@163.com +S: Maintained +F: board/coolpi/genbook +F: include/configs/genbook-rk3588.h +F: configs/coolpi-genbook-rk3588_defconfig +F: arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi diff --git a/board/coolpi/genbook/README b/board/coolpi/genbook/README new file mode 100644 index 00000000000..ba165953154 --- /dev/null +++ b/board/coolpi/genbook/README @@ -0,0 +1,23 @@ +Compile the U-Boot +================== + + > cd u-boot + > export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.17.bin + > export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.46.elf + > make coolpi-genbook-rk3588_defconfig + > make CROSS_COMPILE=aarch64-linux-gnu- + + Get u-boot-rockchip.bin for eMMC and u-boot-rockchip-spi.bin for SPI Nor. + + +Write u-boot to eMMC or SPI Nor if you have a bootable linux system on the computer: + +Flash the image to eMMC +========================== + > dd if=u-boot-rockchip.bin of=/dev/mmcblk0 bs=512 seek=64 + +Flash the image to SPI Nor +========================== + > dd if=u-boot-rockchip-spi.bin of=/dev/mtdblock0 + +Note: The boot priority of SPI Nor is higher than that of eMMC diff --git a/configs/coolpi-genbook-rk3588_defconfig b/configs/coolpi-genbook-rk3588_defconfig new file mode 100644 index 00000000000..ae6c6c296cc --- /dev/null +++ b/configs/coolpi-genbook-rk3588_defconfig @@ -0,0 +1,104 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588-coolpi-cm5-genbook" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_GENBOOK_RK3588=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-coolpi-cm5-genbook.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +# CONFIG_CMD_BIND is not set +# CONFIG_CMD_FASTBOOT is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_SPL_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_SPL_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_ERRNO_STR=y diff --git a/dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts b/dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts new file mode 100644 index 00000000000..6418286efe4 --- /dev/null +++ b/dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts @@ -0,0 +1,349 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Rockchip Electronics Co., Ltd. + * + */ + +/dts-v1/; + +#include <dt-bindings/leds/common.h> +#include "rk3588-coolpi-cm5.dtsi" + +/ { + model = "CoolPi CM5 GenBook"; + compatible = "coolpi,pi-cm5-genbook", "coolpi,pi-cm5", "rockchip,rk3588"; + + backlight: backlight { + compatible = "pwm-backlight"; + enable-gpios = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_en>; + power-supply = <&vcc12v_dcin>; + pwms = <&pwm6 0 25000 0>; + }; + + battery: battery { + compatible = "simple-battery"; + charge-full-design-microamp-hours = <9800000>; + voltage-max-design-microvolt = <4350000>; + voltage-min-design-microvolt = <3000000>; + }; + + charger: dc-charger { + compatible = "gpio-charger"; + charger-type = "mains"; + gpios = <&gpio1 RK_PC0 GPIO_ACTIVE_LOW>; + }; + + leds: leds { + compatible = "gpio-leds"; + + heartbeat_led: led-0 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + wlan_led: led-1 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_WLAN; + gpios = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + }; + + charging_red: led-2 { + function = LED_FUNCTION_CHARGING; + color = <LED_COLOR_ID_RED>; + gpios = <&gpio3 RK_PD2 GPIO_ACTIVE_HIGH>; + }; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <7000000>; + regulator-max-microvolt = <7000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <7000000>; + regulator-max-microvolt = <7000000>; + vin-supply = <&vcc_sys>; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc3v3_lcd: vcc3v3-lcd-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_lcd"; + enable-active-high; + gpio = <&gpio1 RK_PC4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&lcdpwr_en>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-boot-on; + regulator-always-on; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 RK_PD5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_pwren>; + vin-supply = <&vcc_sys>; + }; + + vcc5v0_usb_host0: vcc5v0_usb30_host: vcc5v0-usb-host-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host"; + regulator-boot-on; + regulator-always-on; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 RK_PA7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_host_pwren>; + vin-supply = <&vcc5v0_usb>; + }; +}; + +&i2c4 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c4m3_xfer>; + + cw2015@62 { + compatible = "cellwise,cw2015"; + reg = <0x62>; + + cellwise,battery-profile = /bits/ 8 < + 0x17 0x67 0x69 0x63 0x63 0x62 0x62 0x5F + 0x52 0x73 0x4C 0x5A 0x5B 0x4B 0x42 0x3A + 0x33 0x2D 0x29 0x28 0x2E 0x31 0x3C 0x49 + 0x2C 0x2C 0x0C 0xCD 0x30 0x51 0x50 0x66 + 0x74 0x74 0x75 0x78 0x41 0x1B 0x84 0x5F + 0x0B 0x34 0x1C 0x45 0x89 0x92 0xA0 0x13 + 0x2C 0x55 0xAB 0xCB 0x80 0x5E 0x7B 0xCB + 0x2F 0x00 0x64 0xA5 0xB5 0x10 0x18 0x21 + >; + + cellwise,monitor-interval-ms = <3000>; + monitored-battery = <&battery>; + power-supplies = <&charger>; + }; +}; + +&i2c5 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c5m3_xfer>; + + touchpad: touchpad@2c { + compatible = "hid-over-i2c"; + reg = <0x2c>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PD6 IRQ_TYPE_LEVEL_LOW>; + hid-descr-addr = <0x0020>; + }; +}; + +&gmac0 { + status = "disabled"; +}; + +/* M.2 E-Key */ +&pcie2x1l0 { + reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreq &pcie_wake &pcie_rst &wifi_pwron &bt_pwron>; + status = "okay"; +}; + +&pcie2x1l2 { + status = "disabled"; +}; + +&pcie30phy { + status = "okay"; +}; + +/* M.2 M-Key ssd */ +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + status = "okay"; +}; + +&pinctrl { + lcd { + lcdpwr_en: lcdpwr-en { + rockchip,pins = <1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bl_en: bl-en { + rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + usb_pwren: usb-pwren { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + usb_otg_pwren: usb-otg-pwren { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + usb_host_pwren: usb-host-pwren { + rockchip,pins = <1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + wifi { + bt_pwron: bt-pwron { + rockchip,pins = <3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_clkreq: pcie-clkreq { + rockchip,pins = <4 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_rst: pcie-rst { + rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + wifi_pwron: wifi-pwron { + rockchip,pins = <3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_wake: pcie-wake { + rockchip,pins = <4 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm6 { + pinctrl-0 = <&pwm6m1_pins>; + status = "okay"; +}; + +&sdmmc { + status = "disabled"; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim2_pins>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <100000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +&u2phy1 { + status = "okay"; +}; + +&u2phy1_otg { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy2_host { + phy-supply = <&vcc5v0_usb_host0>; + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_usb>; + status = "okay"; +}; + +&usbdp_phy1 { + status = "okay"; +}; + +/* For Keypad */ +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +/* Type C port */ +&usb_host0_xhci { + dr_mode = "peripheral"; + maximum-speed = "high-speed"; + status = "okay"; +}; + +/* connected to a HUB for camera and BT */ +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +/* USB A out */ +&usb_host1_xhci { + dr_mode = "host"; + status = "okay"; +}; diff --git a/include/configs/genbook-rk3588.h b/include/configs/genbook-rk3588.h new file mode 100644 index 00000000000..5c5957b8bf5 --- /dev/null +++ b/include/configs/genbook-rk3588.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + */ + +#ifndef __ROCK5B_RK3588_H +#define __ROCK5B_RK3588_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#undef CFG_EXTRA_ENV_SETTINGS + +/* + * As a laptop, there is no sdmmc, and we + * want to set usb the highest boot priority + * for third-part os installation. + */ +#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ + "boot_targets=" "usb mmc0" "\0" + +#endif /* __GENBOOK_RK3588_H */
Hello Andy,
Please see a few comments below.
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
It should be mentioned that it actually uses CM5 SoM.
+&fspim2_pins {
- bootph-pre-ram;
- bootph-some-ram;
+&sdhci {
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
+&sfc {
- pinctrl-names = "default";
- pinctrl-0 = <&fspim2_pins>;
- status = "okay";
- flash@0 {
reg = <0>;
bootph-pre-ram;
bootph-some-ram;
+&u2phy0 {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&usbdp_phy0 {
- status = "okay";
- status = "disabled";
+&usb_host0_ohci {
+&usb_host0_xhci {
- dr_mode = "peripheral";
- maximum-speed = "high-speed";
- status = "okay";
+&usb_host1_ohci {
- snps,dis_u3_susphy_quirk;
It should be better to use "TARGET_GENBOOK_CM5_RK3588" instead, to leave room for support for any possible future SoMs that might be made available for the GenBook at some point.
- bool "Cool Pi GenBook"
- select BOARD_LATE_INIT
- help
It should be better to use "genbook_cm5_rk3588" as the directory name, for the same reasons as in my previous comment, and to include the SoC name in it as well.
+config SYS_BOARD
- default "genbook"
+config SYS_VENDOR
- default "coolpi"
- default "genbook-rk3588"
It should be better to use "genboook-cm5-rk3588" instead, for the same reasons as in my other comments above.
My earlier comment on "genbook_cm5_rk3588" as the directory name applies here as well, obviously.
cd u-boot exportROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.17.bin
export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.46.elf make coolpi-genbook-rk3588_defconfig make CROSS_COMPILE=aarch64-linux-gnu-- Get u-boot-rockchip.bin for eMMC and u-boot-rockchip-spi.bin for SPI
Nor.
dd if=u-boot-rockchip.bin of=/dev/mmcblk0 bs=512 seek=64+Flash the image to SPI Nor +==========================
dd if=u-boot-rockchip-spi.bin of=/dev/mtdblock0+Note: The boot priority of SPI Nor is higher than that of eMMC diff --git a/configs/coolpi-genbook-rk3588_defconfig b/configs/coolpi-genbook-rk3588_defconfig
It should be "coolpi-genbook-cm5-rk3588_defconfig" instead, as already described why above.
It should be better to use "coolpi-genbook-cm5-rk3588_defconfig" instead, as already described above.
I believe this should be turned into a separate commit, as a cherry-pick of an upstream DT commit.
- Copyright (c) 2024 Rockchip Electronics Co., Ltd.
+/dts-v1/;
- model = "CoolPi CM5 GenBook";
- compatible = "coolpi,pi-cm5-genbook", "coolpi,pi-cm5",
"rockchip,rk3588";
- backlight: backlight {
- battery: battery {
- charger: dc-charger {
- leds: leds {
wlan_led: led-1 {
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
- vcc3v3_lcd: vcc3v3-lcd-regulator {
enable-active-high;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
enable-active-high;
- vcc5v0_usb_host0: vcc5v0_usb30_host: vcc5v0-usb-host-regulator {
regulator-boot-on;
enable-active-high;
+&i2c4 {
- status = "okay";
- pinctrl-0 = <&i2c4m3_xfer>;
- cw2015@62 {
reg = <0x62>;
+&i2c5 {
- status = "okay";
- pinctrl-0 = <&i2c5m3_xfer>;
- touchpad: touchpad@2c {
reg = <0x2c>;
+&gmac0 {
- reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_sys>;
- pinctrl-0 = <&pcie_clkreq &pcie_wake &pcie_rst &wifi_pwron
&bt_pwron>;
- status = "okay";
+&pcie2x1l2 {
+&pcie30phy {
- status = "okay";
- reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pinctrl {
- lcd {
bl_en: bl-en {
- usb {
- wifi {
+&pwm6 {
- pinctrl-0 = <&pwm6m1_pins>;
- status = "okay";
+&sdmmc {
+&sfc {
- status = "okay";
- flash@0 {
reg = <0x0>;
+&u2phy0 {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&usbdp_phy0 {
- status = "okay";
+&u2phy1 {
- status = "okay";
+&u2phy1_otg {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy2_host {
- phy-supply = <&vcc5v0_usb_host0>;
- status = "okay";
+&u2phy3_host {
- phy-supply = <&vcc5v0_usb>;
- status = "okay";
+&usbdp_phy1 {
- status = "okay";
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
- status = "okay";
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
- dr_mode = "host";
- status = "okay";
As already described why above, it should be better to use "genbook-cm5-rk3588.h" instead.
Obviously, it should be "__GENBOOK_CM5_RK3588_H" instead.
- As a laptop, there is no sdmmc, and we
- want to set usb the highest boot priority
- for third-part os installation.
- "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "partitions=" PARTS_DEFAULT \
- ENV_MEM_LAYOUT_SETTINGS \
- ROCKCHIP_DEVICE_SETTINGS \
- "boot_targets=" "usb mmc0" "\0"
Pleas see the comment above.
Hello Dragan,
At 2024-08-12 05:26:36, "Dragan Simic" dsimic@manjaro.org wrote:
Hello Andy,
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
Okay,will do in v2
+&fspim2_pins {
- bootph-pre-ram;
- bootph-some-ram;
+&sdhci {
- mmc-hs200-1_8v;
+&sfc {
- status = "okay";
- flash@0 {
reg = <0>;
bootph-pre-ram;
bootph-some-ram;
+&u2phy0 {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&usbdp_phy0 {
- status = "okay";
+&usb_host0_ohci {
+&usb_host0_xhci {
- status = "okay";
+&usb_host1_ohci {
Considering the name of dts is rk3588-coolpi-cm5-genbook.dts , should we use TARGET_CM5_GENBOOK_RK3588 instead of TARGET_GENBOOK_CM5_RK3588 here ?
Hello Andy,
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
Okay,will do in v2
Great, thanks.
[snip]
That's a good question, and I already asked myself the same, before sending over my comments. It's all about the way U-Boot names the things internally, i.e. we've got it like "<carrier_board>-<SoM>-<SoC>" this time, meaning that the "dependency graph" seemingly gets usually represented that way in U-Boot.
Hi Andy,
Order alphabetically here.
We've moved the READMEs to doc/board/ so please do this as well.
You may only want to add your board to doc/board/rockchip/rockchip.rst if the instructions in that file are good enough for you. Consider extending the content if it doesn't, and if it's too much work, then creating your own readme in doc/board/ similar to how Theobroma Systems boards are documented would do just fine.
Note that those are in reStructuredText format (rST/Sphinx).
Yes, as a hint, you should be using tools/update-subtree.sh pick dts <commit> as documented here: https://docs.u-boot.org/en/latest/develop/devicetree/control.html#resyncing-...
You may need to pick more than one commit, that is fine.
The commit id comes from https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi....
Cheers, Quentin
Hi Quetin, 在 2024-08-12 16:23:06,"Quentin Schulz" quentin.schulz@cherry.de 写道:
Hi Andy,
The dts just landing linux-rockchip a few days agao,so it's not in the devicetree-rebasing repo, Does that mean I should wait before it landing devicetree-rebasing repo ?
Cheers, Quentin
Hi Andy,
Hi Andy,
Unfortunately, I believe this is the policy we have right now yes. For sure we do not allow to manually modify anything in dts/ directory, so the other option would be to have it temporarily in arch/arm/dts/ instead until it's available in that repo. It depends on Kever for that (if he agrees to have this temporarily) and also if you're really "in a hurry" to get this board supported.
Cheers, Quentin
Andy Yan
Dragan Simic
Quentin Schulz
