[PATCH 0/6 v3] Loadfile2 for initrd loading
Hi! This is v2 of [1]
Changes since v2: - Lengths checks when interpreting a device path, to make sure we aren't going out of bounds - renamed efi_get_file_size -> efi_file size and moved it itn efi_file.c - Fix uninitialized variable related errors reported by Cppcheck - Fixed various error messages for easier end user readbility - renamed _efi_dp_append() -> efi_dp_append_or_concatenate() - Picked up Reviewed-by tags - Enabling the protocol by default
Changes since v1: - minor coding style fixes from Heinrich - changed the DP format. Instead of VenMedia - 0x01 - initrd, we skip the 0x01 between VenMedia and the first file. - final device path is stripped in efi_get_dp_from_boot() instead of get_initrd_fp() - Fixed comments on documentation
[1] https://lists.denx.de/pipermail/u-boot/2021-March/443399.html
Ilias Apalodimas (6): efi_selftest: Remove loadfile2 for initrd selftests efi_loader: Add device path related functions for initrd via Boot#### efi_loader: Add helper functions for EFI efi_loader: Replace config option for initrd loading efidebug: add multiple device path instances on Boot#### doc: Update uefi documentation for initrd loading options
cmd/bootefi.c | 3 + cmd/efidebug.c | 193 ++++++++++++--- doc/board/emulation/qemu_capsule_update.rst | 4 +- doc/uefi/uefi.rst | 24 +- include/efi_loader.h | 12 + lib/efi_loader/Kconfig | 17 +- lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_bootmgr.c | 19 +- lib/efi_loader/efi_device_path.c | 106 ++++++++- lib/efi_loader/efi_file.c | 39 ++++ lib/efi_loader/efi_helper.c | 98 ++++++++ lib/efi_loader/efi_load_initrd.c | 202 +++++++++------- lib/efi_loader/efi_var_common.c | 33 +++ lib/efi_selftest/Makefile | 1 - lib/efi_selftest/efi_selftest_load_initrd.c | 221 ------------------ .../test_efi_capsule/test_capsule_firmware.py | 6 +- test/py/tests/test_efi_secboot/test_signed.py | 16 +- .../test_efi_secboot/test_signed_intca.py | 8 +- .../tests/test_efi_secboot/test_unsigned.py | 8 +- 19 files changed, 626 insertions(+), 385 deletions(-) create mode 100644 lib/efi_loader/efi_helper.c delete mode 100644 lib/efi_selftest/efi_selftest_load_initrd.c
We are redefining how u-boot locates the initrd to load via the kernel LoadFile2 protocol. This selftest is not relevant any more, so remove it. A new one will be added later
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 1 - lib/efi_selftest/efi_selftest_load_initrd.c | 221 -------------------- 2 files changed, 222 deletions(-) delete mode 100644 lib/efi_selftest/efi_selftest_load_initrd.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index b02fd56e0a79..50de581b7763 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -61,7 +61,6 @@ obj-$(CONFIG_CPU_V7) += efi_selftest_unaligned.o obj-$(CONFIG_EFI_LOADER_HII) += efi_selftest_hii.o obj-$(CONFIG_EFI_RNG_PROTOCOL) += efi_selftest_rng.o obj-$(CONFIG_EFI_GET_TIME) += efi_selftest_rtc.o -obj-$(CONFIG_EFI_LOAD_FILE2_INITRD) += efi_selftest_load_initrd.o obj-$(CONFIG_EFI_TCG2_PROTOCOL) += efi_selftest_tcg2.o
ifeq ($(CONFIG_GENERATE_ACPI_TABLE),) diff --git a/lib/efi_selftest/efi_selftest_load_initrd.c b/lib/efi_selftest/efi_selftest_load_initrd.c deleted file mode 100644 index f591dcd2115e..000000000000 --- a/lib/efi_selftest/efi_selftest_load_initrd.c +++ /dev/null @@ -1,221 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * efi_selftest_load_initrd - * - * Copyright (c) 2020 Ilias Apalodimas ilias.apalodimas@linaro.org - * - * This test checks the FileLoad2 protocol. - * A known file is read from the file system and verified. - * - * An example usage - given a file image with a file system in partition 1 - * holding file initrd - is: - * - * * Configure the sandbox with - * - * CONFIG_EFI_SELFTEST=y - * CONFIG_EFI_LOAD_FILE2_INITRD=y - * CONFIG_EFI_INITRD_FILESPEC="host 0:1 initrd" - * - * * Run ./u-boot and execute - * - * host bind 0 image - * setenv efi_selftest load initrd - * bootefi selftest - * - * This would provide a test output like: - * - * Testing EFI API implementation - * - * Selected test: 'load initrd' - * - * Setting up 'load initrd' - * Setting up 'load initrd' succeeded - * - * Executing 'load initrd' - * Loaded 12378613 bytes - * CRC32 2997478465 - * - * Now the size and CRC32 can be compared to the provided file. - */ - -#include <efi_selftest.h> -#include <efi_loader.h> -#include <efi_load_initrd.h> - -static struct efi_boot_services *boottime; - -static struct efi_initrd_dp dp = { - .vendor = { - { - DEVICE_PATH_TYPE_MEDIA_DEVICE, - DEVICE_PATH_SUB_TYPE_VENDOR_PATH, - sizeof(dp.vendor), - }, - EFI_INITRD_MEDIA_GUID, - }, - .end = { - DEVICE_PATH_TYPE_END, - DEVICE_PATH_SUB_TYPE_END, - sizeof(dp.end), - } -}; - -static struct efi_initrd_dp dp_invalid = { - .vendor = { - { - DEVICE_PATH_TYPE_MEDIA_DEVICE, - DEVICE_PATH_SUB_TYPE_VENDOR_PATH, - sizeof(dp.vendor), - }, - EFI_INITRD_MEDIA_GUID, - }, - .end = { - 0x8f, /* invalid */ - 0xfe, /* invalid */ - sizeof(dp.end), - } -}; - -static int setup(const efi_handle_t handle, - const struct efi_system_table *systable) -{ - boottime = systable->boottime; - - return EFI_ST_SUCCESS; -} - -static int execute(void) -{ - struct efi_load_file_protocol *lf2; - struct efi_device_path *dp2, *dp2_invalid; - efi_status_t status; - efi_handle_t handle; - char buffer[64]; - efi_uintn_t buffer_size; - void *buf; - u32 crc32; - - memset(buffer, 0, sizeof(buffer)); - - dp2 = (struct efi_device_path *)&dp; - status = boottime->locate_device_path(&efi_guid_load_file2_protocol, - &dp2, &handle); - if (status != EFI_SUCCESS) { - efi_st_error("Unable to locate device path\n"); - return EFI_ST_FAILURE; - } - - status = boottime->handle_protocol(handle, - &efi_guid_load_file2_protocol, - (void **)&lf2); - if (status != EFI_SUCCESS) { - efi_st_error("Unable to locate protocol\n"); - return EFI_ST_FAILURE; - } - - /* Case 1: - * buffer_size can't be NULL - * protocol can't be NULL - */ - status = lf2->load_file(lf2, dp2, false, NULL, &buffer); - if (status != EFI_INVALID_PARAMETER) { - efi_st_error("Buffer size can't be NULL\n"); - return EFI_ST_FAILURE; - } - buffer_size = sizeof(buffer); - status = lf2->load_file(NULL, dp2, false, &buffer_size, &buffer); - if (status != EFI_INVALID_PARAMETER) { - efi_st_error("Protocol can't be NULL\n"); - return EFI_ST_FAILURE; - } - - /* - * Case 2: Match end node type/sub-type on device path - */ - dp2_invalid = (struct efi_device_path *)&dp_invalid; - buffer_size = sizeof(buffer); - status = lf2->load_file(lf2, dp2_invalid, false, &buffer_size, &buffer); - if (status != EFI_INVALID_PARAMETER) { - efi_st_error("Invalid device path type must return EFI_INVALID_PARAMETER\n"); - return EFI_ST_FAILURE; - } - - status = lf2->load_file(lf2, dp2_invalid, false, &buffer_size, &buffer); - if (status != EFI_INVALID_PARAMETER) { - efi_st_error("Invalid device path sub-type must return EFI_INVALID_PARAMETER\n"); - return EFI_ST_FAILURE; - } - - /* - * Case 3: - * BootPolicy 'true' must return EFI_UNSUPPORTED - */ - buffer_size = sizeof(buffer); - status = lf2->load_file(lf2, dp2, true, &buffer_size, &buffer); - if (status != EFI_UNSUPPORTED) { - efi_st_error("BootPolicy true must return EFI_UNSUPPORTED\n"); - return EFI_ST_FAILURE; - } - - /* - * Case: Pass buffer size as zero, firmware must return - * EFI_BUFFER_TOO_SMALL and an appropriate size - */ - buffer_size = 0; - status = lf2->load_file(lf2, dp2, false, &buffer_size, NULL); - if (status != EFI_BUFFER_TOO_SMALL || !buffer_size) { - efi_st_printf("buffer_size: %u\n", (unsigned int)buffer_size); - efi_st_printf("status: %x\n", (unsigned int)status); - efi_st_error("Buffer size not updated\n"); - return EFI_ST_FAILURE; - } - - /* - * Case: Pass buffer size as smaller than the file_size, - * firmware must return * EFI_BUFFER_TOO_SMALL and an appropriate size - */ - buffer_size = 1; - status = lf2->load_file(lf2, dp2, false, &buffer_size, &buffer); - if (status != EFI_BUFFER_TOO_SMALL || buffer_size <= 1) { - efi_st_error("Buffer size not updated\n"); - return EFI_ST_FAILURE; - } - - status = boottime->allocate_pool(EFI_BOOT_SERVICES_DATA, buffer_size, - &buf); - if (status != EFI_SUCCESS) { - efi_st_error("Cannot allocate buffer\n"); - return EFI_ST_FAILURE; - } - - /* Case: Pass correct buffer, load the file and verify checksum*/ - status = lf2->load_file(lf2, dp2, false, &buffer_size, buf); - if (status != EFI_SUCCESS) { - efi_st_error("Loading initrd failed\n"); - return EFI_ST_FAILURE; - } - - efi_st_printf("Loaded %u bytes\n", (unsigned int)buffer_size); - status = boottime->calculate_crc32(buf, buffer_size, &crc32); - if (status != EFI_SUCCESS) { - efi_st_error("Could not determine CRC32\n"); - return EFI_ST_FAILURE; - } - efi_st_printf("CRC32 %.8x\n", (unsigned int)crc32); - - status = boottime->free_pool(buf); - if (status != EFI_SUCCESS) { - efi_st_error("Cannot free buffer\n"); - return EFI_ST_FAILURE; - } - - return EFI_ST_SUCCESS; -} - -EFI_UNIT_TEST(load_initrd) = { - .name = "load initrd", - .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, - .setup = setup, - .execute = execute, - .on_request = true, -};
Applied to origin/master
On the following patches we allow for an initrd path to be stored in Boot#### variables. Specifically we encode in the FIlePathList[] of the EFI_LOAD_OPTIONS for each Boot#### variable.
The FilePathList[] array looks like this: kernel - 0xff - VenMedia(initrd GUID) - initrd1 - 0x01 initrd2 - 0xff So let's add the relevant functions to concatenate and retrieve a device path based on a Vendor GUID.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/efi_loader.h | 4 ++ lib/efi_loader/efi_device_path.c | 106 +++++++++++++++++++++++++++++-- 2 files changed, 105 insertions(+), 5 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index f470bbd636f4..eb11a8c7d4b1 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -738,6 +738,10 @@ struct efi_load_option { const u8 *optional_data; };
+struct efi_device_path *efi_dp_from_lo(struct efi_load_option *lo, + efi_uintn_t *size, efi_guid_t guid); +struct efi_device_path *efi_dp_concat(const struct efi_device_path *dp1, + const struct efi_device_path *dp2); efi_status_t efi_deserialize_load_option(struct efi_load_option *lo, u8 *data, efi_uintn_t *size); unsigned long efi_serialize_load_option(struct efi_load_option *lo, u8 **data); diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index c9315dd45857..1491251e224b 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -282,11 +282,30 @@ struct efi_device_path *efi_dp_dup(const struct efi_device_path *dp) return ndp; }
-struct efi_device_path *efi_dp_append(const struct efi_device_path *dp1, - const struct efi_device_path *dp2) +/** efi_dp_append_or_concatenate() - Append or concatenate two device paths. + * Concatenated device path will be separated + * by a sub-type 0xff end node + * + * @dp1: First device path + * @dp2: Second device path + * @concat: If true the two device paths will be concatenated and separated + * by an end of entrire device path sub-type 0xff end node. + * If true the second device path will be appended to the first and + * terminated by an end node + * + * Return: concatenated device path or NULL. Caller must free the returned + * value + */ +static struct +efi_device_path *efi_dp_append_or_concatenate(const struct efi_device_path *dp1, + const struct efi_device_path *dp2, + bool concat) { struct efi_device_path *ret; + size_t end_size = sizeof(END);
+ if (concat) + end_size = 2 * sizeof(END); if (!dp1 && !dp2) { /* return an end node */ ret = efi_dp_dup(&END); @@ -298,18 +317,56 @@ struct efi_device_path *efi_dp_append(const struct efi_device_path *dp1, /* both dp1 and dp2 are non-null */ unsigned sz1 = efi_dp_size(dp1); unsigned sz2 = efi_dp_size(dp2); - void *p = dp_alloc(sz1 + sz2 + sizeof(END)); + void *p = dp_alloc(sz1 + sz2 + end_size); if (!p) return NULL; + ret = p; memcpy(p, dp1, sz1); + p += sz1; + + if (concat) { + memcpy(p, &END, sizeof(END)); + p += sizeof(END); + } + /* the end node of the second device path has to be retained */ - memcpy(p + sz1, dp2, sz2 + sizeof(END)); - ret = p; + memcpy(p, dp2, sz2); + p += sz2; + memcpy(p, &END, sizeof(END)); }
return ret; }
+/** efi_dp_append() - Append a device to an existing device path. + * + * @dp1: First device path + * @dp2: Second device path + * + * Return: concatenated device path or NULL. Caller must free the returned + * value + */ +struct efi_device_path *efi_dp_append(const struct efi_device_path *dp1, + const struct efi_device_path *dp2) +{ + return efi_dp_append_or_concatenate(dp1, dp2, false); +} + +/** efi_dp_concat() - Concatenate 2 device paths. The final device path will + * contain two device paths separated by and end node (0xff). + * + * @dp1: First device path + * @dp2: Second device path + * + * Return: concatenated device path or NULL. Caller must free the returned + * value + */ +struct efi_device_path *efi_dp_concat(const struct efi_device_path *dp1, + const struct efi_device_path *dp2) +{ + return efi_dp_append_or_concatenate(dp1, dp2, true); +} + struct efi_device_path *efi_dp_append_node(const struct efi_device_path *dp, const struct efi_device_path *node) { @@ -1160,3 +1217,42 @@ ssize_t efi_dp_check_length(const struct efi_device_path *dp, dp = (const struct efi_device_path *)((const u8 *)dp + len); } } + +/** + * efi_dp_from_lo() - Get the instance of a VenMedia node in a + * multi-instance device path that matches + * a specific GUID. This kind of device paths + * is found in Boot#### options describing an + * initrd location + * + * @load_option: EFI_LOAD_OPTION containing a valid device path + * @size: size of the discovered device path + * @guid: guid to search for + * + * Return: device path including the VenMedia node or NULL. + * Caller must free the returned value + */ +struct +efi_device_path *efi_dp_from_lo(struct efi_load_option *lo, + efi_uintn_t *size, efi_guid_t guid) +{ + struct efi_device_path *fp = lo->file_path; + struct efi_device_path_vendor *vendor; + int lo_len = lo->file_path_length; + + for (; lo_len >= sizeof(struct efi_device_path); + lo_len -= fp->length, fp = (void *)fp + fp->length) { + if (lo_len < 0 || efi_dp_check_length(fp, lo_len) < 0) + break; + if (fp->type != DEVICE_PATH_TYPE_MEDIA_DEVICE || + fp->sub_type != DEVICE_PATH_SUB_TYPE_VENDOR_PATH) + continue; + + vendor = (struct efi_device_path_vendor *)fp; + if (!guidcmp(&vendor->guid, &guid)) + return efi_dp_dup(fp); + } + log_debug("VenMedia(%pUl) not found in %ls\n", &guid, lo->label); + + return NULL; +}
A following patch introduces a different logic for loading initrd's based on the EFI_LOAD_FILE2_PROTOCOL. Since similar logic can be applied in the future for other system files (i.e DTBs), let's add some helper functions which will retrieve and parse file paths stored in EFI variables.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/efi_loader.h | 7 +++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_file.c | 39 +++++++++++++ lib/efi_loader/efi_helper.c | 98 +++++++++++++++++++++++++++++++++ lib/efi_loader/efi_var_common.c | 33 +++++++++++ 5 files changed, 178 insertions(+) create mode 100644 lib/efi_loader/efi_helper.c
diff --git a/include/efi_loader.h b/include/efi_loader.h index eb11a8c7d4b1..25302628d8a8 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -552,6 +552,11 @@ struct efi_simple_file_system_protocol *efi_simple_file_system( /* open file from device-path: */ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp);
+efi_status_t efi_file_size(struct efi_file_handle *fh, efi_uintn_t *size); + +/* get a device path from a Boot#### option */ +struct efi_device_path *efi_get_dp_from_boot(const efi_guid_t guid); + /** * efi_size_in_pages() - convert size in bytes to size in pages * @@ -717,6 +722,8 @@ efi_status_t EFIAPI efi_query_variable_info( u64 *remaining_variable_storage_size, u64 *maximum_variable_size);
+void *efi_get_var(u16 *name, const efi_guid_t *vendor, efi_uintn_t *size); + /* * See section 3.1.3 in the v2.7 UEFI spec for more details on * the layout of EFI_LOAD_OPTION. In short it is: diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 10b42e8847bf..da2741adecfa 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -23,6 +23,7 @@ endif obj-$(CONFIG_CMD_BOOTEFI_HELLO) += helloworld_efi.o obj-$(CONFIG_CMD_BOOTEFI_BOOTMGR) += efi_bootmgr.o obj-y += efi_boottime.o +obj-y += efi_helper.o obj-$(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) += efi_capsule.o obj-$(CONFIG_EFI_CAPSULE_FIRMWARE) += efi_firmware.o obj-y += efi_console.o diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 8ece8e71ee1c..bebcb520272a 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -409,6 +409,45 @@ static efi_status_t efi_get_file_size(struct file_handle *fh, return EFI_SUCCESS; }
+/** + * efi_file_size() - Get the size of a file using an EFI file handle + * + * @handle: EFI file handle + * @size: buffer to fill in the discovered size + * + * Return: size of the file + */ +efi_status_t efi_file_size(struct efi_file_handle *fh, efi_uintn_t *size) +{ + struct efi_file_info *info = NULL; + efi_uintn_t bs = 0; + efi_status_t ret; + + *size = 0; + ret = EFI_CALL(fh->getinfo(fh, (efi_guid_t *)&efi_file_info_guid, &bs, + info)); + if (ret != EFI_BUFFER_TOO_SMALL) { + ret = EFI_DEVICE_ERROR; + goto out; + } + + info = malloc(bs); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + ret = EFI_CALL(fh->getinfo(fh, (efi_guid_t *)&efi_file_info_guid, &bs, + info)); + if (ret != EFI_SUCCESS) + goto out; + + *size = info->file_size; + +out: + free(info); + return ret; +} + static efi_status_t file_read(struct file_handle *fh, u64 *buffer_size, void *buffer) { diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c new file mode 100644 index 000000000000..d03a7364615e --- /dev/null +++ b/lib/efi_loader/efi_helper.c @@ -0,0 +1,98 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020, Linaro Limited + */ + +#define LOG_CATEGORY LOGC_EFI +#include <common.h> +#include <env.h> +#include <malloc.h> +#include <dm.h> +#include <fs.h> +#include <efi_load_initrd.h> +#include <efi_loader.h> +#include <efi_variable.h> + +/** + * efi_create_current_boot_var() - Return Boot#### name were #### is replaced by + * the value of BootCurrent + * + * @var_name: variable name + * @var_name_size: size of var_name + * + * Return: Status code + */ +static efi_status_t efi_create_current_boot_var(u16 var_name[], + size_t var_name_size) +{ + efi_uintn_t boot_current_size; + efi_status_t ret; + u16 boot_current; + u16 *pos; + + boot_current_size = sizeof(boot_current); + ret = efi_get_variable_int(L"BootCurrent", + &efi_global_variable_guid, NULL, + &boot_current_size, &boot_current, NULL); + if (ret != EFI_SUCCESS) + goto out; + + pos = efi_create_indexed_name(var_name, var_name_size, "Boot", + boot_current); + if (!pos) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + +out: + return ret; +} + +/** + * efi_get_dp_from_boot() - Retrieve and return a device path from an EFI + * Boot### variable. + * A boot option may contain an array of device paths. + * We use a VenMedia() with a specific GUID to identify + * the usage of the array members. This function is + * used to extract a specific device path + * + * @guid: vendor GUID of the VenMedia() device path node identifying the + * device path + * + * Return: device path or NULL. Caller must free the returned value + */ +struct efi_device_path *efi_get_dp_from_boot(const efi_guid_t guid) +{ + struct efi_device_path *file_path = NULL; + struct efi_device_path *tmp = NULL; + struct efi_load_option lo; + void *var_value = NULL; + efi_uintn_t size; + efi_status_t ret; + u16 var_name[16]; + + ret = efi_create_current_boot_var(var_name, sizeof(var_name)); + if (ret != EFI_SUCCESS) + return NULL; + + var_value = efi_get_var(var_name, &efi_global_variable_guid, &size); + if (!var_value) + return NULL; + + ret = efi_deserialize_load_option(&lo, var_value, &size); + if (ret != EFI_SUCCESS) + goto out; + + tmp = efi_dp_from_lo(&lo, &size, guid); + if (!tmp) + goto out; + + /* efi_dp_dup will just return NULL if efi_dp_next is NULL */ + file_path = efi_dp_dup(efi_dp_next(tmp)); + +out: + efi_free_pool(tmp); + free(var_value); + + return file_path; +} diff --git a/lib/efi_loader/efi_var_common.c b/lib/efi_loader/efi_var_common.c index 1c7459266a38..b11ed91a74a4 100644 --- a/lib/efi_loader/efi_var_common.c +++ b/lib/efi_loader/efi_var_common.c @@ -9,6 +9,7 @@ #include <common.h> #include <efi_loader.h> #include <efi_variable.h> +#include <stdlib.h>
enum efi_secure_mode { EFI_MODE_SETUP, @@ -343,3 +344,35 @@ enum efi_auth_var_type efi_auth_var_get_type(u16 *name, const efi_guid_t *guid) } return EFI_AUTH_VAR_NONE; } + +/** + * efi_get_var() - read value of an EFI variable + * + * @name: variable name + * @start: vendor GUID + * @size: size of allocated buffer + * + * Return: buffer with variable data or NULL + */ +void *efi_get_var(u16 *name, const efi_guid_t *vendor, efi_uintn_t *size) +{ + efi_status_t ret; + void *buf = NULL; + + *size = 0; + ret = efi_get_variable_int(name, vendor, NULL, size, buf, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) { + buf = malloc(*size); + if (!buf) + return NULL; + ret = efi_get_variable_int(name, vendor, NULL, size, buf, NULL); + } + + if (ret != EFI_SUCCESS) { + free(buf); + *size = 0; + return NULL; + } + + return buf; +}
- efi_size_in_pages() - convert size in bytes to size in pages
- See section 3.1.3 in the v2.7 UEFI spec for more details on
- the layout of EFI_LOAD_OPTION. In short it is:
- efi_file_size() - Get the size of a file using an EFI file handle
- @handle: EFI file handle
- @size: buffer to fill in the discovered size
'make htmldocs' fails to build.
./lib/efi_loader/efi_file.c:421: warning: Function parameter or member 'fh' not described in 'efi_file_size' ./lib/efi_loader/efi_file.c:421: warning: Excess function parameter 'handle' description in 'efi_file_size'
Best regards
Heinrich
- Return: size of the file
- struct efi_file_info *info = NULL;
- efi_uintn_t bs = 0;
- efi_status_t ret;
- *size = 0;
- ret = EFI_CALL(fh->getinfo(fh, (efi_guid_t *)&efi_file_info_guid, &bs,
info));
- if (ret != EFI_BUFFER_TOO_SMALL) {
goto out;
- info = malloc(bs);
- if (!info) {
goto out;
info));
- if (ret != EFI_SUCCESS)
goto out;
- *size = info->file_size;
+out:
- free(info);
- return ret;
- static efi_status_t file_read(struct file_handle *fh, u64 *buffer_size, void *buffer) {
- Copyright (c) 2020, Linaro Limited
- efi_create_current_boot_var() - Return Boot#### name were #### is replaced by
- @var_name: variable name
- @var_name_size: size of var_name
- Return: Status code
- efi_uintn_t boot_current_size;
- efi_status_t ret;
- u16 boot_current;
- u16 *pos;
- boot_current_size = sizeof(boot_current);
- ret = efi_get_variable_int(L"BootCurrent",
goto out;
- pos = efi_create_indexed_name(var_name, var_name_size, "Boot",
boot_current);
- if (!pos) {
goto out;
+out:
- return ret;
- efi_get_dp_from_boot() - Retrieve and return a device path from an EFI
Boot### variable.
- @guid: vendor GUID of the VenMedia() device path node identifying the
device path
- Return: device path or NULL. Caller must free the returned value
- struct efi_device_path *file_path = NULL;
- struct efi_device_path *tmp = NULL;
- struct efi_load_option lo;
- void *var_value = NULL;
- efi_uintn_t size;
- efi_status_t ret;
- u16 var_name[16];
- ret = efi_create_current_boot_var(var_name, sizeof(var_name));
return NULL;
- var_value = efi_get_var(var_name, &efi_global_variable_guid, &size);
- if (!var_value)
return NULL;
- ret = efi_deserialize_load_option(&lo, var_value, &size);
goto out;
- tmp = efi_dp_from_lo(&lo, &size, guid);
- if (!tmp)
goto out;
- /* efi_dp_dup will just return NULL if efi_dp_next is NULL */
- file_path = efi_dp_dup(efi_dp_next(tmp));
+out:
- efi_free_pool(tmp);
- free(var_value);
- return file_path;
- efi_get_var() - read value of an EFI variable
- @name: variable name
- @start: vendor GUID
- @size: size of allocated buffer
- Return: buffer with variable data or NULL
- efi_status_t ret;
- void *buf = NULL;
- *size = 0;
- ret = efi_get_variable_int(name, vendor, NULL, size, buf, NULL);
- if (ret == EFI_BUFFER_TOO_SMALL) {
if (!buf)
return NULL;
- if (ret != EFI_SUCCESS) {
free(buf);
*size = 0;
return NULL;
- return buf;
Up to now we install EFI_LOAD_FILE2_PROTOCOL to load an initrd unconditionally. Although we correctly return various EFI exit codes depending on the file status (i.e EFI_NO_MEDIA, EFI_NOT_FOUND etc), the kernel loader, only falls back to the cmdline interpreted initrd if the protocol is not installed.
This creates a problem for EFI installers, since they won't be able to load their own initrd and continue the installation. It also makes the feature hard to use, since we can either have a single initrd or we have to recompile u-boot if the filename changes.
So let's introduce a different logic that will decouple the initrd path from the config option we currently have. When defining a UEFI BootXXXX we can use the filepathlist and store a file path pointing to our initrd. Specifically the EFI spec describes:
"The first element of the array is a device path that describes the device and location of the Image for this load option. Other device paths may optionally exist in the FilePathList, but their usage is OSV specific"
When the EFI application is launched through the bootmgr, we'll try to interpret the extra device path. If that points to a file that exists on our disk, we'll now install the load_file2 and the efi-stub will be able to use it.
This opens up another path using U-Boot and defines a new boot flow. A user will be able to control the kernel/initrd pairs without explicit cmdline args or GRUB.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 3 + include/efi_loader.h | 1 + lib/efi_loader/Kconfig | 17 +-- lib/efi_loader/efi_bootmgr.c | 19 ++- lib/efi_loader/efi_load_initrd.c | 202 ++++++++++++++++++------------- 5 files changed, 144 insertions(+), 98 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 271b385edea6..cba81ffe75e4 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -358,6 +358,9 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options)
free(load_options);
+ if (IS_ENABLED(CONFIG_EFI_LOAD_FILE2_INITRD)) + efi_initrd_deregister(); + return ret; }
diff --git a/include/efi_loader.h b/include/efi_loader.h index 25302628d8a8..f17529695dd0 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -431,6 +431,7 @@ efi_status_t efi_net_register(void); /* Called by bootefi to make the watchdog available */ efi_status_t efi_watchdog_register(void); efi_status_t efi_initrd_register(void); +void efi_initrd_deregister(void); /* Called by bootefi to make SMBIOS tables available */ /** * efi_acpi_register() - write out ACPI tables diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index e729f727df11..380f86db60fc 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -315,18 +315,13 @@ config EFI_TCG2_PROTOCOL_EVENTLOG_SIZE
config EFI_LOAD_FILE2_INITRD bool "EFI_FILE_LOAD2_PROTOCOL for Linux initial ramdisk" - default n - help - Expose a EFI_FILE_LOAD2_PROTOCOL that the Linux UEFI stub can - use to load the initial ramdisk. Once this is enabled using - initrd=<ramdisk> will stop working. - -config EFI_INITRD_FILESPEC - string "initramfs path" - default "host 0:1 initrd" - depends on EFI_LOAD_FILE2_INITRD + default y help - Full path of the initramfs file, e.g. mmc 0:2 initramfs.cpio.gz. + Linux v5.7 and later can make use of this option. If the boot option + selected by the UEFI boot manager specifies an existing file to be used + as initial RAM disk, a Linux specific Load File2 protocol will be + installed and Linux 5.7+ will ignore any initrd=<ramdisk> command line + argument.
config EFI_SECURE_BOOT bool "Enable EFI secure boot support" diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 25f5cebfdb67..46c8011344b9 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -118,11 +118,13 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, ret = efi_set_variable_int(L"BootCurrent", &efi_global_variable_guid, attributes, sizeof(n), &n, false); - if (ret != EFI_SUCCESS) { - if (EFI_CALL(efi_unload_image(*handle)) - != EFI_SUCCESS) - log_err("Unloading image failed\n"); - goto error; + if (ret != EFI_SUCCESS) + goto unload; + /* try to register load file2 for initrd's */ + if (IS_ENABLED(CONFIG_EFI_LOAD_FILE2_INITRD)) { + ret = efi_initrd_register(); + if (ret != EFI_SUCCESS) + goto unload; }
log_info("Booting: %ls\n", lo.label); @@ -146,6 +148,13 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, error: free(load_option);
+ return ret; + +unload: + if (EFI_CALL(efi_unload_image(*handle)) != EFI_SUCCESS) + log_err("Unloading image failed\n"); + free(load_option); + return ret; }
diff --git a/lib/efi_loader/efi_load_initrd.c b/lib/efi_loader/efi_load_initrd.c index b9ee8839054f..e2a806302303 100644 --- a/lib/efi_loader/efi_load_initrd.c +++ b/lib/efi_loader/efi_load_initrd.c @@ -3,9 +3,11 @@ * Copyright (c) 2020, Linaro Limited */
+#define LOG_CATEGORY LOGC_EFI #include <common.h> #include <efi_loader.h> #include <efi_load_initrd.h> +#include <efi_variable.h> #include <fs.h> #include <malloc.h> #include <mapmem.h> @@ -23,57 +25,56 @@ static const struct efi_load_file_protocol efi_lf2_protocol = { * Device path defined by Linux to identify the handle providing the * EFI_LOAD_FILE2_PROTOCOL used for loading the initial ramdisk. */ -static const struct efi_initrd_dp dp = { +static const struct efi_initrd_dp dp_lf2_handle = { .vendor = { { DEVICE_PATH_TYPE_MEDIA_DEVICE, DEVICE_PATH_SUB_TYPE_VENDOR_PATH, - sizeof(dp.vendor), + sizeof(dp_lf2_handle.vendor), }, EFI_INITRD_MEDIA_GUID, }, .end = { DEVICE_PATH_TYPE_END, DEVICE_PATH_SUB_TYPE_END, - sizeof(dp.end), + sizeof(dp_lf2_handle.end), } };
+static efi_handle_t efi_initrd_handle; + /** - * get_file_size() - retrieve the size of initramfs, set efi status on error + * get_initrd_fp() - Get initrd device path from a FilePathList device path * - * @dev: device to read from, e.g. "mmc" - * @part: device partition, e.g. "0:1" - * @file: name of file - * @status: EFI exit code in case of failure + * @initrd_fp: the final initrd filepath * - * Return: size of file + * Return: status code. Caller must free initrd_fp */ -static loff_t get_file_size(const char *dev, const char *part, const char *file, - efi_status_t *status) +static efi_status_t get_initrd_fp(struct efi_device_path **initrd_fp) { - loff_t sz = 0; - int ret; - - ret = fs_set_blk_dev(dev, part, FS_TYPE_ANY); - if (ret) { - *status = EFI_NO_MEDIA; - goto out; - } + const efi_guid_t lf2_initrd_guid = EFI_INITRD_MEDIA_GUID; + struct efi_device_path *dp = NULL;
- ret = fs_size(file, &sz); - if (ret) { - sz = 0; - *status = EFI_NOT_FOUND; - goto out; - } + /* + * if bootmgr is setup with and initrd, the device path will be + * in the FilePathList[] of our load options in Boot####. + * The first device path of the multi instance device path will + * start with a VenMedia and the initrds will follow. + * + * If the device path is not found return EFI_INVALID_PARAMETER. + * We can then use this specific return value and not install the + * protocol, while allowing the boot to continue + */ + dp = efi_get_dp_from_boot(lf2_initrd_guid); + if (!dp) + return EFI_INVALID_PARAMETER;
-out: - return sz; + *initrd_fp = dp; + return EFI_SUCCESS; }
/** - * efi_load_file2initrd() - load initial RAM disk + * efi_load_file2_initrd() - load initial RAM disk * * This function implements the LoadFile service of the EFI_LOAD_FILE2_PROTOCOL * in order to load an initial RAM disk requested by the Linux kernel stub. @@ -93,102 +94,125 @@ efi_load_file2_initrd(struct efi_load_file_protocol *this, struct efi_device_path *file_path, bool boot_policy, efi_uintn_t *buffer_size, void *buffer) { - char *filespec; - efi_status_t status = EFI_NOT_FOUND; - loff_t file_sz = 0, read_sz = 0; - char *dev, *part, *file; - char *pos; - int ret; + struct efi_device_path *initrd_fp = NULL; + efi_status_t ret = EFI_NOT_FOUND; + struct efi_file_handle *f = NULL; + efi_uintn_t bs;
EFI_ENTRY("%p, %p, %d, %p, %p", this, file_path, boot_policy, buffer_size, buffer);
- filespec = strdup(CONFIG_EFI_INITRD_FILESPEC); - if (!filespec) - goto out; - pos = filespec; - if (!this || this != &efi_lf2_protocol || !buffer_size) { - status = EFI_INVALID_PARAMETER; + ret = EFI_INVALID_PARAMETER; goto out; }
- if (file_path->type != dp.end.type || - file_path->sub_type != dp.end.sub_type) { - status = EFI_INVALID_PARAMETER; + if (file_path->type != dp_lf2_handle.end.type || + file_path->sub_type != dp_lf2_handle.end.sub_type) { + ret = EFI_INVALID_PARAMETER; goto out; }
if (boot_policy) { - status = EFI_UNSUPPORTED; + ret = EFI_UNSUPPORTED; goto out; }
- /* - * expect a string with three space separated parts: - * - * * a block device type, e.g. "mmc" - * * a device and partition identifier, e.g. "0:1" - * * a file path on the block device, e.g. "/boot/initrd.cpio.gz" - */ - dev = strsep(&pos, " "); - if (!dev) + ret = get_initrd_fp(&initrd_fp); + if (ret != EFI_SUCCESS) goto out; - part = strsep(&pos, " "); - if (!part) - goto out; - file = strsep(&pos, " "); - if (!file) + + /* Open file */ + f = efi_file_from_path(initrd_fp); + if (!f) { + log_err("Can't find initrd specified in Boot####\n"); + ret = EFI_NOT_FOUND; goto out; + }
- file_sz = get_file_size(dev, part, file, &status); - if (!file_sz) + /* Get file size */ + ret = efi_file_size(f, &bs); + if (ret != EFI_SUCCESS) goto out;
- if (!buffer || *buffer_size < file_sz) { - status = EFI_BUFFER_TOO_SMALL; - *buffer_size = file_sz; + if (!buffer || *buffer_size < bs) { + ret = EFI_BUFFER_TOO_SMALL; + *buffer_size = bs; } else { - ret = fs_set_blk_dev(dev, part, FS_TYPE_ANY); - if (ret) { - status = EFI_NO_MEDIA; - goto out; - } - - ret = fs_read(file, map_to_sysmem(buffer), 0, *buffer_size, - &read_sz); - if (ret || read_sz != file_sz) - goto out; - *buffer_size = read_sz; - - status = EFI_SUCCESS; + ret = EFI_CALL(f->read(f, &bs, (void *)(uintptr_t)buffer)); + *buffer_size = bs; + } + +out: + efi_free_pool(initrd_fp); + if (f) + EFI_CALL(f->close(f)); + return EFI_EXIT(ret); +} + +/** + * check_initrd() - Determine if the file defined as an initrd in Boot#### + * load_options device path is present + * + * Return: status code + */ +static efi_status_t check_initrd(void) +{ + struct efi_device_path *initrd_fp = NULL; + struct efi_file_handle *f; + efi_status_t ret; + + ret = get_initrd_fp(&initrd_fp); + if (ret != EFI_SUCCESS) + goto out; + + /* + * If the file is not found, but the file path is set, return an error + * and trigger the bootmgr fallback + */ + f = efi_file_from_path(initrd_fp); + if (!f) { + log_err("Can't find initrd specified in Boot####\n"); + ret = EFI_NOT_FOUND; + goto out; }
+ EFI_CALL(f->close(f)); + out: - free(filespec); - return EFI_EXIT(status); + efi_free_pool(initrd_fp); + return ret; }
/** * efi_initrd_register() - create handle for loading initial RAM disk * * This function creates a new handle and installs a Linux specific vendor - * device path and an EFI_LOAD_FILE_2_PROTOCOL. Linux uses the device path + * device path and an EFI_LOAD_FILE2_PROTOCOL. Linux uses the device path * to identify the handle and then calls the LoadFile service of the - * EFI_LOAD_FILE_2_PROTOCOL to read the initial RAM disk. + * EFI_LOAD_FILE2_PROTOCOL to read the initial RAM disk. * * Return: status code */ efi_status_t efi_initrd_register(void) { - efi_handle_t efi_initrd_handle = NULL; efi_status_t ret;
+ /* + * Allow the user to continue if Boot#### file path is not set for + * an initrd + */ + ret = check_initrd(); + if (ret == EFI_INVALID_PARAMETER) + return EFI_SUCCESS; + if (ret != EFI_SUCCESS) + return ret; + ret = EFI_CALL(efi_install_multiple_protocol_interfaces (&efi_initrd_handle, /* initramfs */ - &efi_guid_device_path, &dp, + &efi_guid_device_path, &dp_lf2_handle, /* LOAD_FILE2 */ &efi_guid_load_file2_protocol, (void *)&efi_lf2_protocol, @@ -196,3 +220,17 @@ efi_status_t efi_initrd_register(void)
return ret; } + +/** + * efi_initrd_deregister() - delete the handle for loading initial RAM disk + * + * This will delete the handle containing the Linux specific vendor device + * path and EFI_LOAD_FILE2_PROTOCOL for loading an initrd + * + * Return: status code + */ +void efi_initrd_deregister(void) +{ + efi_delete_handle(efi_initrd_handle); + efi_initrd_handle = NULL; +}
The UEFI spec allows a packed array of UEFI device paths in the FilePathList[] of an EFI_LOAD_OPTION. The first file path must describe the loaded image but the rest are OS specific.
Previous patches parse the device path and try to use the second member of the array as an initrd. So let's modify efidebug slightly and install the second file described in the command line as the initrd device path.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- cmd/efidebug.c | 193 ++++++++++++++---- doc/board/emulation/qemu_capsule_update.rst | 4 +- doc/uefi/uefi.rst | 2 +- .../test_efi_capsule/test_capsule_firmware.py | 6 +- test/py/tests/test_efi_secboot/test_signed.py | 16 +- .../test_efi_secboot/test_signed_intca.py | 8 +- .../tests/test_efi_secboot/test_unsigned.py | 8 +- 7 files changed, 178 insertions(+), 59 deletions(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index bbbcb0a54643..a96146748c61 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -9,6 +9,7 @@ #include <common.h> #include <command.h> #include <efi_dt_fixup.h> +#include <efi_load_initrd.h> #include <efi_loader.h> #include <efi_rng.h> #include <exports.h> @@ -19,6 +20,7 @@ #include <part.h> #include <search.h> #include <linux/ctype.h> +#include <linux/err.h>
#define BS systab.boottime #define RT systab.runtime @@ -794,6 +796,64 @@ static int do_efi_show_tables(struct cmd_tbl *cmdtp, int flag, return CMD_RET_SUCCESS; }
+/** + * add_initrd_instance() - Append a device path to load_options pointing to an + * inirtd + * + * @dev: Device + * @part: Partition of thge disk + * @file: Filename + * @fp: Device Path containing the existing load_options + * @fp_size: New size of the device path after the addition + * Return: Pointer to the device path or ERR_PTR + * + */ +static +struct efi_device_path *add_initrd_instance(const char *dev, const char *part, + const char *file, + const struct efi_device_path *fp, + efi_uintn_t *fp_size) +{ + struct efi_device_path *tmp_dp = NULL, *tmp_fp = NULL; + struct efi_device_path *final_fp = NULL, *initrd_dp = NULL; + efi_status_t ret; + const struct efi_initrd_dp id_dp = { + .vendor = { + { + DEVICE_PATH_TYPE_MEDIA_DEVICE, + DEVICE_PATH_SUB_TYPE_VENDOR_PATH, + sizeof(id_dp.vendor), + }, + EFI_INITRD_MEDIA_GUID, + }, + .end = { + DEVICE_PATH_TYPE_END, + DEVICE_PATH_SUB_TYPE_END, + sizeof(id_dp.end), + } + }; + + ret = efi_dp_from_name(dev, part, file, &tmp_dp, &tmp_fp); + if (ret != EFI_SUCCESS) { + printf("Cannot create device path for "%s %s"\n", part, file); + goto out; + } + + initrd_dp = efi_dp_append((const struct efi_device_path *)&id_dp, + tmp_fp); + if (!initrd_dp) + goto out; + final_fp = efi_dp_concat(fp, initrd_dp); + *fp_size = efi_dp_size(fp) + efi_dp_size(initrd_dp) + + (2 * sizeof(struct efi_device_path)); + +out: + efi_free_pool(initrd_dp); + efi_free_pool(tmp_dp); + efi_free_pool(tmp_fp); + return final_fp; +} + /** * do_efi_boot_add() - set UEFI load option * @@ -806,7 +866,9 @@ static int do_efi_show_tables(struct cmd_tbl *cmdtp, int flag, * * Implement efidebug "boot add" sub-command. Create or change UEFI load option. * - * efidebug boot add <id> <label> <interface> <devnum>[:<part>] <file> <options> + * efidebug boot add -b <id> <label> <interface> <devnum>[:<part>] <file> + * -i <file> <interface2> <devnum2>[:<part>] <initrd> + * -s '<options>' */ static int do_efi_boot_add(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -819,55 +881,98 @@ static int do_efi_boot_add(struct cmd_tbl *cmdtp, int flag, size_t label_len, label_len16; u16 *label; struct efi_device_path *device_path = NULL, *file_path = NULL; + struct efi_device_path *final_fp = NULL; struct efi_load_option lo; void *data = NULL; efi_uintn_t size; + efi_uintn_t fp_size; efi_status_t ret; int r = CMD_RET_SUCCESS; - - if (argc < 6 || argc > 7) - return CMD_RET_USAGE; - - id = (int)simple_strtoul(argv[1], &endp, 16); - if (*endp != '\0' || id > 0xffff) - return CMD_RET_USAGE; - - sprintf(var_name, "Boot%04X", id); - p = var_name16; - utf8_utf16_strncpy(&p, var_name, 9); + int i;
guid = efi_global_variable_guid;
/* attributes */ lo.attributes = LOAD_OPTION_ACTIVE; /* always ACTIVE */ + lo.optional_data = NULL; + lo.label = NULL;
- /* label */ - label_len = strlen(argv[2]); - label_len16 = utf8_utf16_strnlen(argv[2], label_len); - label = malloc((label_len16 + 1) * sizeof(u16)); - if (!label) - return CMD_RET_FAILURE; - lo.label = label; /* label will be changed below */ - utf8_utf16_strncpy(&label, argv[2], label_len); + /* search for -b first since the rest of the arguments depends on that */ + for (i = 0; i < argc; i++) { + if (!strcmp(argv[i], "-b")) { + if (argc < i + 5 || lo.label) { + r = CMD_RET_USAGE; + goto out; + } + id = (int)simple_strtoul(argv[i + 1], &endp, 16); + if (*endp != '\0' || id > 0xffff) + return CMD_RET_USAGE; + + sprintf(var_name, "Boot%04X", id); + p = var_name16; + utf8_utf16_strncpy(&p, var_name, 9); + + /* label */ + label_len = strlen(argv[i + 2]); + label_len16 = utf8_utf16_strnlen(argv[i + 2], label_len); + label = malloc((label_len16 + 1) * sizeof(u16)); + if (!label) + return CMD_RET_FAILURE; + lo.label = label; /* label will be changed below */ + utf8_utf16_strncpy(&label, argv[i + 2], label_len); + + /* file path */ + ret = efi_dp_from_name(argv[i + 3], argv[i + 4], + argv[i + 5], &device_path, + &file_path); + if (ret != EFI_SUCCESS) { + printf("Cannot create device path for "%s %s"\n", + argv[3], argv[4]); + r = CMD_RET_FAILURE; + goto out; + } + fp_size = efi_dp_size(file_path) + + sizeof(struct efi_device_path); + } + }
- /* file path */ - ret = efi_dp_from_name(argv[3], argv[4], argv[5], &device_path, - &file_path); - if (ret != EFI_SUCCESS) { - printf("Cannot create device path for "%s %s"\n", - argv[3], argv[4]); - r = CMD_RET_FAILURE; + if (!file_path) { + printf("Missing binary\n"); + r = CMD_RET_USAGE; goto out; } - lo.file_path = file_path; - lo.file_path_length = efi_dp_size(file_path) - + sizeof(struct efi_device_path); /* for END */
- /* optional data */ - if (argc == 6) - lo.optional_data = NULL; - else - lo.optional_data = (const u8 *)argv[6]; + /* add now add initrd and extra data */ + for (i = 0; i < argc; i++) { + if (!strcmp(argv[i], "-i")) { + if (argc < i + 3 || final_fp) { + r = CMD_RET_USAGE; + goto out; + } + + final_fp = add_initrd_instance(argv[i + 1], argv[i + 2], + argv[i + 3], file_path, + &fp_size); + if (!final_fp) { + printf("Cannot add an initrd\n"); + r = CMD_RET_FAILURE; + goto out; + } + + /* add_initrd_instance allocates a new device path */ + efi_free_pool(file_path); + file_path = final_fp; + } else if (!strcmp(argv[i], "-s")) { + if (argc < i + 1 || lo.optional_data) { + r = CMD_RET_USAGE; + goto out; + } + lo.optional_data = (const u8 *)argv[i + 1]; + } + } + + lo.file_path = file_path; + lo.file_path_length = fp_size;
size = efi_serialize_load_option(&lo, (u8 **)&data); if (!size) { @@ -951,11 +1056,14 @@ static int do_efi_boot_rm(struct cmd_tbl *cmdtp, int flag, */ static void show_efi_boot_opt_data(u16 *varname16, void *data, size_t *size) { + struct efi_device_path *initrd_path = NULL; struct efi_load_option lo; char *label, *p; size_t label_len16, label_len; u16 *dp_str; efi_status_t ret; + efi_uintn_t initrd_dp_size; + const efi_guid_t lf2_initrd_guid = EFI_INITRD_MEDIA_GUID;
ret = efi_deserialize_load_option(&lo, data, size); if (ret != EFI_SUCCESS) { @@ -986,6 +1094,14 @@ static void show_efi_boot_opt_data(u16 *varname16, void *data, size_t *size) printf(" file_path: %ls\n", dp_str); efi_free_pool(dp_str);
+ initrd_path = efi_dp_from_lo(&lo, &initrd_dp_size, lf2_initrd_guid); + if (initrd_path) { + dp_str = efi_dp_str(initrd_path); + printf(" initrd_path: %ls\n", dp_str); + efi_free_pool(dp_str); + efi_free_pool(initrd_path); + } + printf(" data:\n"); print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, lo.optional_data, *size, true); @@ -1555,7 +1671,10 @@ static int do_efidebug(struct cmd_tbl *cmdtp, int flag, static char efidebug_help_text[] = " - UEFI Shell-like interface to configure UEFI environment\n" "\n" - "efidebug boot add <bootid> <label> <interface> <devnum>[:<part>] <file path> [<load options>]\n" + "efidebug boot add " + "-b <bootid> <label> <interface> <devnum>[:<part>] <file path> " + "-i <interface> <devnum>[:<part>] <initrd file path> " + "-s '<optional data>'\n" " - set UEFI BootXXXX variable\n" " <load options> will be passed to UEFI application\n" "efidebug boot rm <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n" @@ -1599,7 +1718,7 @@ static char efidebug_help_text[] = #endif
U_BOOT_CMD( - efidebug, 10, 0, do_efidebug, + efidebug, CONFIG_SYS_MAXARGS, 0, do_efidebug, "Configure UEFI environment", efidebug_help_text ); diff --git a/doc/board/emulation/qemu_capsule_update.rst b/doc/board/emulation/qemu_capsule_update.rst index 9fec75f8f1c9..33ce4bcd32ea 100644 --- a/doc/board/emulation/qemu_capsule_update.rst +++ b/doc/board/emulation/qemu_capsule_update.rst @@ -60,7 +60,7 @@ to be pointing to the EFI System Partition which contains the capsule file. The BootNext, BootXXXX and OsIndications variables can be set using the following commands::
- => efidebug boot add 0 Boot0000 virtio 0:1 <capsule_file_name> + => efidebug boot add -b 0 Boot0000 virtio 0:1 <capsule_file_name> => efidebug boot next 0 => setenv -e -nv -bs -rt -v OsIndications =0x04 => saveenv @@ -198,7 +198,7 @@ command line:: 3. Set the following environment and UEFI boot variables
=> setenv -e -nv -bs -rt -v OsIndications =0x04 - => efidebug boot add 0 Boot0000 virtio 0:1 <capsule_file_name> + => efidebug boot add -b 0 Boot0000 virtio 0:1 <capsule_file_name> => efidebug boot next 0 => saveenv
diff --git a/doc/uefi/uefi.rst b/doc/uefi/uefi.rst index 5a67737c1579..b3494c22e073 100644 --- a/doc/uefi/uefi.rst +++ b/doc/uefi/uefi.rst @@ -178,7 +178,7 @@ Now in U-Boot install the keys on your board::
Set up boot parameters on your board::
- efidebug boot add 1 HELLO mmc 0:1 /helloworld.efi.signed "" + efidebug boot add -b 1 HELLO mmc 0:1 /helloworld.efi.signed ""
Now your board can run the signed image via the boot manager (see below). You can also try this sequence by running Pytest, test_efi_secboot, diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware.py b/test/py/tests/test_efi_capsule/test_capsule_firmware.py index f006fa95d650..e8b0a1575453 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware.py @@ -39,7 +39,7 @@ class TestEfiCapsuleFirmwareFit(object): with u_boot_console.log.section('Test Case 1-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'efidebug boot add 1 TEST host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi ""', 'efidebug boot order 1', 'env set -e OsIndications', 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', @@ -114,7 +114,7 @@ class TestEfiCapsuleFirmwareFit(object): with u_boot_console.log.section('Test Case 2-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'efidebug boot add 1 TEST host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi ""', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', @@ -188,7 +188,7 @@ class TestEfiCapsuleFirmwareFit(object): with u_boot_console.log.section('Test Case 3-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'efidebug boot add 1 TEST host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi ""', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', diff --git a/test/py/tests/test_efi_secboot/test_signed.py b/test/py/tests/test_efi_secboot/test_signed.py index 863685e215b7..75f5ea772300 100644 --- a/test/py/tests/test_efi_secboot/test_signed.py +++ b/test/py/tests/test_efi_secboot/test_signed.py @@ -28,7 +28,7 @@ class TestEfiSignedImage(object): # Test Case 1a, run signed image if no PK output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'efidebug boot add 1 HELLO1 host 0:1 /helloworld.efi.signed ""', + 'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output) @@ -36,7 +36,7 @@ class TestEfiSignedImage(object): with u_boot_console.log.section('Test Case 1b'): # Test Case 1b, run unsigned image if no PK output = u_boot_console.run_command_list([ - 'efidebug boot add 2 HELLO2 host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 2 HELLO2 host 0:1 /helloworld.efi ""', 'efidebug boot next 2', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output) @@ -58,13 +58,13 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO1 host 0:1 /helloworld.efi.signed ""', + 'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert(''HELLO1' failed' in ''.join(output)) assert('efi_start_image() returned: 26' in ''.join(output)) output = u_boot_console.run_command_list([ - 'efidebug boot add 2 HELLO2 host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 2 HELLO2 host 0:1 /helloworld.efi ""', 'efidebug boot next 2', 'efidebug test bootmgr']) assert ''HELLO2' failed' in ''.join(output) @@ -104,7 +104,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) @@ -142,7 +142,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) @@ -169,7 +169,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed_2sigs ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed_2sigs ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert 'Hello, world!' in ''.join(output) @@ -227,7 +227,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output) diff --git a/test/py/tests/test_efi_secboot/test_signed_intca.py b/test/py/tests/test_efi_secboot/test_signed_intca.py index 70d6be00e8a8..0849572a5143 100644 --- a/test/py/tests/test_efi_secboot/test_signed_intca.py +++ b/test/py/tests/test_efi_secboot/test_signed_intca.py @@ -39,7 +39,7 @@ class TestEfiSignedImageIntca(object): assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO_a host 0:1 /helloworld.efi.signed_a ""', + 'efidebug boot add -b 1 HELLO_a host 0:1 /helloworld.efi.signed_a ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert ''HELLO_a' failed' in ''.join(output) @@ -48,7 +48,7 @@ class TestEfiSignedImageIntca(object): with u_boot_console.log.section('Test Case 1b'): # Test Case 1b, signed and authenticated by root CA output = u_boot_console.run_command_list([ - 'efidebug boot add 2 HELLO_ab host 0:1 /helloworld.efi.signed_ab ""', + 'efidebug boot add -b 2 HELLO_ab host 0:1 /helloworld.efi.signed_ab ""', 'efidebug boot next 2', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output) @@ -70,7 +70,7 @@ class TestEfiSignedImageIntca(object): assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc ""', + 'efidebug boot add -b 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert ''HELLO_abc' failed' in ''.join(output) @@ -116,7 +116,7 @@ class TestEfiSignedImageIntca(object): assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc ""', + 'efidebug boot add -b 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert 'Hello, world!' in ''.join(output) diff --git a/test/py/tests/test_efi_secboot/test_unsigned.py b/test/py/tests/test_efi_secboot/test_unsigned.py index 56f56e19eb84..8e026f7566ad 100644 --- a/test/py/tests/test_efi_secboot/test_unsigned.py +++ b/test/py/tests/test_efi_secboot/test_unsigned.py @@ -35,7 +35,7 @@ class TestEfiUnsignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi ""', 'efidebug boot next 1', 'bootefi bootmgr']) assert ''HELLO' failed' in ''.join(output) @@ -64,7 +64,7 @@ class TestEfiUnsignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi ""', 'efidebug boot next 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output) @@ -88,7 +88,7 @@ class TestEfiUnsignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ - 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi ""', + 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi ""', 'efidebug boot next 1', 'bootefi bootmgr']) assert ''HELLO' failed' in ''.join(output) @@ -106,7 +106,7 @@ class TestEfiUnsignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output)
efidebug boot add \ -b d00d label host 0:1 initrddump.efi \ -i host 0:1 startup.sh SUPERFLUOUS
efidebug boot add \ -b d00d label host 0:1 initrddump.efi SUPERFLUOUS \ -i host 0:1 startup.sh -s
efidebug boot add SUPERFLUOUS \ -b d00d label host 0:1 initrddump.efi \ -i host 0:1 startup.sh -s
These incorrect commands are accepted.
Please, correct the parsing routine.
Best regards
Heinrich
- add_initrd_instance() - Append a device path to load_options pointing to an
inirtd
- @dev: Device
- @part: Partition of thge disk
- @file: Filename
- @fp: Device Path containing the existing load_options
- @fp_size: New size of the device path after the addition
- Return: Pointer to the device path or ERR_PTR
const char *file,
- struct efi_device_path *tmp_dp = NULL, *tmp_fp = NULL;
- struct efi_device_path *final_fp = NULL, *initrd_dp = NULL;
- efi_status_t ret;
- const struct efi_initrd_dp id_dp = {
.vendor = {
.end = {
sizeof(id_dp.end),
- ret = efi_dp_from_name(dev, part, file, &tmp_dp, &tmp_fp);
printf("Cannot create device path for \"%s %s\"\n", part, file);
goto out;
- initrd_dp = efi_dp_append((const struct efi_device_path *)&id_dp,
tmp_fp);
- if (!initrd_dp)
goto out;
- final_fp = efi_dp_concat(fp, initrd_dp);
- *fp_size = efi_dp_size(fp) + efi_dp_size(initrd_dp) +
+out:
- efi_free_pool(initrd_dp);
- efi_free_pool(tmp_dp);
- efi_free_pool(tmp_fp);
- return final_fp;
- do_efi_boot_add() - set UEFI load option
- Implement efidebug "boot add" sub-command. Create or change UEFI load option.
- efidebug boot add -b <id> <label> <interface> <devnum>[:<part>] <file>
-s '<options>'
- struct efi_device_path *final_fp = NULL; struct efi_load_option lo; void *data = NULL; efi_uintn_t size;
- efi_uintn_t fp_size; efi_status_t ret; int r = CMD_RET_SUCCESS;
- p = var_name16;
int i;
lo.label = NULL;
- /* label */
- if (!label)
- /* search for -b first since the rest of the arguments depends on that */
- for (i = 0; i < argc; i++) {
r = CMD_RET_USAGE;
goto out;
p = var_name16;
/* label */
if (!label)
/* file path */
&file_path);
argv[3], argv[4]);
goto out;
- /* file path */
&file_path);
argv[3], argv[4]);
- if (!file_path) {
goto out; }r = CMD_RET_USAGE;
/* optional data */
if (argc == 6)
else
r = CMD_RET_USAGE;
goto out;
&fp_size);
if (!final_fp) {
goto out;
r = CMD_RET_USAGE;
goto out;
- initrd_path = efi_dp_from_lo(&lo, &initrd_dp_size, lf2_initrd_guid);
- if (initrd_path) {
- printf(" data:\n"); print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, lo.optional_data, *size, true);
- "efidebug boot add "
- "-b <bootid> <label> <interface> <devnum>[:<part>] <file path> "
- "-i <interface> <devnum>[:<part>] <initrd file path> "
- "-s '<optional data>'\n" " - set UEFI BootXXXX variable\n" " <load options> will be passed to UEFI application\n" "efidebug boot rm <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n"
U_BOOT_CMD(
- efidebug, CONFIG_SYS_MAXARGS, 0, do_efidebug, "Configure UEFI environment", efidebug_help_text );
- => efidebug boot add -b 0 Boot0000 virtio 0:1 <capsule_file_name> => efidebug boot next 0 => setenv -e -nv -bs -rt -v OsIndications =0x04 => saveenv
'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert('\'HELLO1\' failed' in ''.join(output)) assert('efi_start_image() returned: 26' in ''.join(output)) output = u_boot_console.run_command_list([
'efidebug boot add -b 2 HELLO2 host 0:1 /helloworld.efi ""', 'efidebug boot next 2', 'efidebug test bootmgr']) assert '\'HELLO2\' failed' in ''.join(output)
'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert '\'HELLO\' failed' in ''.join(output)
'efidebug boot add -b 1 HELLO_a host 0:1 /helloworld.efi.signed_a ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert '\'HELLO_a\' failed' in ''.join(output)
'efidebug boot add -b 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc ""', 'efidebug boot next 1', 'efidebug test bootmgr']) assert '\'HELLO_abc\' failed' in ''.join(output)
'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi ""', 'efidebug boot next 1', 'bootefi bootmgr']) assert '\'HELLO\' failed' in ''.join(output)
Document the command line options for efidebug and initrd loading
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- doc/uefi/uefi.rst | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/doc/uefi/uefi.rst b/doc/uefi/uefi.rst index b3494c22e073..d92a32016ec0 100644 --- a/doc/uefi/uefi.rst +++ b/doc/uefi/uefi.rst @@ -180,6 +180,12 @@ Set up boot parameters on your board::
+Since kernel 5.7 there's an alternative way of loading an initrd using +LoadFile2 protocol if CONFIG_EFI_LOAD_FILE2_INITRD is enabled. +The initrd path can be specified with:: + + efidebug boot add -b ABE0 'kernel' mmc 0:1 Image -i mmc 0:1 initrd + Now your board can run the signed image via the boot manager (see below). You can also try this sequence by running Pytest, test_efi_secboot, on the sandbox @@ -484,7 +490,21 @@ The load file 2 protocol can be used by the Linux kernel to load the initial RAM disk. U-Boot can be configured to provide an implementation with::
EFI_LOAD_FILE2_INITRD=y - EFI_INITRD_FILESPEC=interface dev:part path_to_initrd + +When the option is enabled the user can add the initrd path with the efidebug +command. + +Load options Boot#### have a FilePathList[] member. The first element of +the array (FilePathList[0]) is the EFI binary to execute. When an initrd +is specified the Device Path for the initrd is denoted by a VenMedia node +with the EFI_INITRD_MEDIA_GUID. Each entry of the array is terminated by the +'end of entire device path' subtype (0xff). If a user wants to define multiple +initrds, those must by separated by the 'end of this instance' identifier of +the end node (0x01). + +So our final format of the FilePathList[] is:: + + Loaded image - end node (0xff) - VenMedia - initrd_1 - [end node (0x01) - initrd_n ...] - end node (0xff)
Links -----
Ilias Apalodimas
