[U-Boot] Relocation issue on armv7 targets
Hi Albert,
I have observed an issue regarding u-boot relocation, it's working with _TEXT_BASE address but for other address in DDR it's not working. Stops at relocation offset.
I was trying this on both QEMU as well as real target.
Here are my findings: ----------------------------- VExpress# tftp 0x8000 u-boot.bin smc911x: detected LAN9118 controller smc911x: phy initialized smc911x: MAC 52:54:00:12:34:56 Using smc911x-0 device TFTP from server 192.168.0.3; our IP address is 192.168.0.4 Filename 'u-boot.bin'. Load address: 0x8000 Loading: ########################## done Bytes transferred = 128736 (1f6e0 hex) VExpress# go 0x8000 ## Starting application at 0x00008000 ...
U-Boot 2012.04.01-00004-gdd16cc2-dirty (Jun 19 2012 - 20:42:05)
U-Boot code: 60800000 -> 6081C200 BSS: -> 60851C88 monitor len: 00051C88 ramsize: 08000000 TLB table at: 67ff0000 Top of RAM usable for U-Boot at: 67ff0000 Reserving 327k for U-Boot at: 67f9e000 Reserving 144k for malloc() at: 67f7a000 Reserving 44 Bytes for Board Info at: 67f79fd4 Reserving 120 Bytes for Global Data at: 67f79f5c New Stack Pointer is: 67f79f50 DRAM: 128 MiB relocation Offset is: 0779e000 qemu: fatal: Trying to execute code outside RAM or ROM at 0x077a6a68
R00=67f79f5c R01=67f9e000 R02=00000000 R03=6081f610 R04=67f9e000 R05=67f79f5c R06=67f9e000 R07=00000002 R08=60000f80 R09=0779e000 R10=6081f610 R11=67f79ad9 R12=60000ff8 R13=67f79f50 R14=077a6a68 R15=077a6a68 PSR=600001d3 -ZC- A svc32 Aborted
From the logs, it's unable to get the exact lr value a/f relocation
happens, due to that board_init_r not been called.
Could you please help me, Do I need to change any TEXT_BASE or liker script for this.?
I have analyzed and understood the code and seems to be some wired thing on start code. I found some hack for this, but does it a valid issue or did I make any mistake.
Request for your help.
Regards, Jagan.
On Tue, Jun 19, 2012 at 09:06:48PM +0530, jagan wrote:
Hi Albert,
Running U-Boot from within U-Boot isn't allowed / supported.
Hi Jagan,
On 06/19/2012 08:36 AM, jagan wrote:
Hi Albert,
This is not quite clear to me. What's working and what's not working. Please note that according to the new relocation scheme, u-boot should start at CONFIG_SYS_TEXT_BASE. u-boot then relocates itself to the end of available SDRAM. U-Boot will not work if it starts from any other location.
Contrast this with the earlier scheme where U-boot could start from a location other than CONFIG_SYS_TEXT_BASE and then it relocates itself to CONFIG_SYS_TEXT_BASE
The following thread has some discussion on this topic. http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/95967/
br, Aneesh
From the logs, it's unable to get the exact lr value a/f relocation happens, due to that board_init_r not been called.
Regards, Jagan.
Does anyone having any idea about this issue. [u-boot XIP is not working because of this relocation issue] I have still debugging able to find some solution but needs some to clarify.
Could you please send your response.
Regards, Jagan.
Dear JagannadhaSutradharudu Teki,
Please read http://www.catb.org/~esr/faqs/smart-questions.html especially section http://www.catb.org/~esr/faqs/smart-questions.html#beprecise
participants (5)
Aneesh V
jagan
