[U-Boot] [PATCH] ARM: uniphier: correct spelling of "invalid"
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/dram_init.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index d121a3b..1cd354e 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -117,7 +117,7 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) size = SZ_1G; break; default: - pr_err("error: invald value is set to MEMCONF ch0 size\n"); + pr_err("error: invalid value is set to MEMCONF ch0 size\n"); return -EINVAL; }
@@ -157,7 +157,7 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) size = SZ_1G; break; default: - pr_err("error: invald value is set to MEMCONF ch1 size\n"); + pr_err("error: invalid value is set to MEMCONF ch1 size\n"); return -EINVAL; }
@@ -189,7 +189,7 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) size = SZ_1G; break; default: - pr_err("error: invald value is set to MEMCONF ch2 size\n"); + pr_err("error: invalid value is set to MEMCONF ch2 size\n"); return -EINVAL; }
2017-02-20 12:09 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier.
Masahiro Yamada
