[PATCH 0/5] Add Basic support for R8A774A1 (RZ/G2M)
The R8A774A1 (RZ/G2M) a commercial SoC based off the automotive R8A7796 SoC.
This series will start the foundation to support this SoC by importing porting the device tree and bindings from Linux 5.8-rc1, then porting the clock driver, pinctrl driver, and sdhi drivers from Renesas' RZG2M repo found:
https://github.com/renesas-rz/renesas-u-boot-cip/tree/v2018.09/rzg2
Adam Ford (5): ARM: renesas: Add basic R8A774A1 Support ARM: dts: r8a774a1: Import DTS from Linux 5.8-rc1 clk: renesas: Add R8A774A1 clock tables pinctrl: renesas: Add R8A774A1 PFC tables mmc: renesas-sdhi: Enable support for R8A774A1
arch/arm/dts/r8a774a1.dtsi | 2787 ++++++++ arch/arm/mach-rmobile/Kconfig.64 | 3 + drivers/clk/renesas/Kconfig | 7 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/r8a774a1-cpg-mssr.c | 343 + drivers/mmc/renesas-sdhi.c | 2 +- drivers/pinctrl/renesas/Kconfig | 10 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a774a1.c | 6196 +++++++++++++++++ include/dt-bindings/clock/r8a774a1-cpg-mssr.h | 65 + include/dt-bindings/power/r8a774a1-sysc.h | 33 + 11 files changed, 9447 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/r8a774a1.dtsi create mode 100644 drivers/clk/renesas/r8a774a1-cpg-mssr.c create mode 100644 drivers/pinctrl/renesas/pfc-r8a774a1.c create mode 100644 include/dt-bindings/clock/r8a774a1-cpg-mssr.h create mode 100644 include/dt-bindings/power/r8a774a1-sysc.h
In order to build boards based on the R8A774A1, there needs to be a config option from which to enable other drivers and/or flags for this SoC.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index c8f93c68bb..bfd513a361 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -2,6 +2,9 @@ if RCAR_GEN3
menu "Select Target SoC"
+config R8A774A1 + bool "Renesas SoC R8A774A1" + config R8A7795 bool "Renesas SoC R8A7795" imply CLK_R8A7795
This patch imports the device tree and required bindings to permit the device tree to build for the R8Z774A1 (RZ/G2M).
diff --git a/arch/arm/dts/r8a774a1.dtsi b/arch/arm/dts/r8a774a1.dtsi new file mode 100644 index 0000000000..a603d94797 --- /dev/null +++ b/arch/arm/dts/r8a774a1.dtsi @@ -0,0 +1,2787 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the r8a774a1 SoC + * + * Copyright (C) 2018 Renesas Electronics Corp. + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/r8a774a1-cpg-mssr.h> +#include <dt-bindings/power/r8a774a1-sysc.h> + +/ { + compatible = "renesas,r8a774a1"; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; + i2c7 = &i2c_dvfs; + }; + + /* + * The external audio clocks are configured as 0 Hz fixed frequency + * clocks by default. + * Boards that provide audio clocks should override them. + */ + audio_clk_a: audio_clk_a { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_b: audio_clk_b { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_c: audio_clk_c { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + /* External CAN clock - to be overridden by boards that provide it */ + can_clk: can { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + cluster0_opp: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1500000000 { + opp-hz = /bits/ 64 <1500000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + }; + + cluster1_opp: opp_table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&a57_0>; + }; + core1 { + cpu = <&a57_1>; + }; + }; + + cluster1 { + core0 { + cpu = <&a53_0>; + }; + core1 { + cpu = <&a53_1>; + }; + core2 { + cpu = <&a53_2>; + }; + core3 { + cpu = <&a53_3>; + }; + }; + }; + + a57_0: cpu@0 { + compatible = "arm,cortex-a57"; + reg = <0x0>; + device_type = "cpu"; + power-domains = <&sysc R8A774A1_PD_CA57_CPU0>; + next-level-cache = <&L2_CA57>; + enable-method = "psci"; + dynamic-power-coefficient = <854>; + clocks = <&cpg CPG_CORE R8A774A1_CLK_Z>; + operating-points-v2 = <&cluster0_opp>; + capacity-dmips-mhz = <1024>; + #cooling-cells = <2>; + }; + + a57_1: cpu@1 { + compatible = "arm,cortex-a57"; + reg = <0x1>; + device_type = "cpu"; + power-domains = <&sysc R8A774A1_PD_CA57_CPU1>; + next-level-cache = <&L2_CA57>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774A1_CLK_Z>; + operating-points-v2 = <&cluster0_opp>; + capacity-dmips-mhz = <1024>; + #cooling-cells = <2>; + }; + + a53_0: cpu@100 { + compatible = "arm,cortex-a53"; + reg = <0x100>; + device_type = "cpu"; + power-domains = <&sysc R8A774A1_PD_CA53_CPU0>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + #cooling-cells = <2>; + dynamic-power-coefficient = <277>; + clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <560>; + }; + + a53_1: cpu@101 { + compatible = "arm,cortex-a53"; + reg = <0x101>; + device_type = "cpu"; + power-domains = <&sysc R8A774A1_PD_CA53_CPU1>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <560>; + }; + + a53_2: cpu@102 { + compatible = "arm,cortex-a53"; + reg = <0x102>; + device_type = "cpu"; + power-domains = <&sysc R8A774A1_PD_CA53_CPU2>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <560>; + }; + + a53_3: cpu@103 { + compatible = "arm,cortex-a53"; + reg = <0x103>; + device_type = "cpu"; + power-domains = <&sysc R8A774A1_PD_CA53_CPU3>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <560>; + }; + + L2_CA57: cache-controller-0 { + compatible = "cache"; + power-domains = <&sysc R8A774A1_PD_CA57_SCU>; + cache-unified; + cache-level = <2>; + }; + + L2_CA53: cache-controller-1 { + compatible = "cache"; + power-domains = <&sysc R8A774A1_PD_CA53_SCU>; + cache-unified; + cache-level = <2>; + }; + }; + + extal_clk: extal { + compatible = "fixed-clock"; + #clock-cells = <0>; + /* This value must be overridden by the board */ + clock-frequency = <0>; + }; + + extalr_clk: extalr { + compatible = "fixed-clock"; + #clock-cells = <0>; + /* This value must be overridden by the board */ + clock-frequency = <0>; + }; + + /* External PCIe clock - can be overridden by the board */ + pcie_bus_clk: pcie_bus { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + pmu_a53 { + compatible = "arm,cortex-a53-pmu"; + interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; + }; + + pmu_a57 { + compatible = "arm,cortex-a57-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a57_0>, <&a57_1>; + }; + + psci { + compatible = "arm,psci-1.0", "arm,psci-0.2"; + method = "smc"; + }; + + /* External SCIF clock - to be overridden by boards that provide it */ + scif_clk: scif { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + soc { + compatible = "simple-bus"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + rwdt: watchdog@e6020000 { + compatible = "renesas,r8a774a1-wdt", + "renesas,rcar-gen3-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + + gpio0: gpio@e6050000 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6050000 0 0x50>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 0 16>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 912>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 912>; + }; + + gpio1: gpio@e6051000 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6051000 0 0x50>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 32 29>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 911>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 911>; + }; + + gpio2: gpio@e6052000 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6052000 0 0x50>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 64 15>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 910>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 910>; + }; + + gpio3: gpio@e6053000 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6053000 0 0x50>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 96 16>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 909>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 909>; + }; + + gpio4: gpio@e6054000 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6054000 0 0x50>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 128 18>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 908>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 908>; + }; + + gpio5: gpio@e6055000 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6055000 0 0x50>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 160 26>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 907>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 907>; + }; + + gpio6: gpio@e6055400 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6055400 0 0x50>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 192 32>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 906>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 906>; + }; + + gpio7: gpio@e6055800 { + compatible = "renesas,gpio-r8a774a1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6055800 0 0x50>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 224 4>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 905>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 905>; + }; + + pfc: pin-controller@e6060000 { + compatible = "renesas,pfc-r8a774a1"; + reg = <0 0xe6060000 0 0x50c>; + }; + + cmt0: timer@e60f0000 { + compatible = "renesas,r8a774a1-cmt0", + "renesas,rcar-gen3-cmt0"; + reg = <0 0xe60f0000 0 0x1004>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 303>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 303>; + status = "disabled"; + }; + + cmt1: timer@e6130000 { + compatible = "renesas,r8a774a1-cmt1", + "renesas,rcar-gen3-cmt1"; + reg = <0 0xe6130000 0 0x1004>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 302>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 302>; + status = "disabled"; + }; + + cmt2: timer@e6140000 { + compatible = "renesas,r8a774a1-cmt1", + "renesas,rcar-gen3-cmt1"; + reg = <0 0xe6140000 0 0x1004>; + interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 301>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 301>; + status = "disabled"; + }; + + cmt3: timer@e6148000 { + compatible = "renesas,r8a774a1-cmt1", + "renesas,rcar-gen3-cmt1"; + reg = <0 0xe6148000 0 0x1004>; + interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 300>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 300>; + status = "disabled"; + }; + + cpg: clock-controller@e6150000 { + compatible = "renesas,r8a774a1-cpg-mssr"; + reg = <0 0xe6150000 0 0x0bb0>; + clocks = <&extal_clk>, <&extalr_clk>; + clock-names = "extal", "extalr"; + #clock-cells = <2>; + #power-domain-cells = <0>; + #reset-cells = <1>; + }; + + rst: reset-controller@e6160000 { + compatible = "renesas,r8a774a1-rst"; + reg = <0 0xe6160000 0 0x018c>; + }; + + sysc: system-controller@e6180000 { + compatible = "renesas,r8a774a1-sysc"; + reg = <0 0xe6180000 0 0x0400>; + #power-domain-cells = <1>; + }; + + tsc: thermal@e6198000 { + compatible = "renesas,r8a774a1-thermal"; + reg = <0 0xe6198000 0 0x100>, + <0 0xe61a0000 0 0x100>, + <0 0xe61a8000 0 0x100>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 522>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 522>; + #thermal-sensor-cells = <1>; + }; + + intc_ex: interrupt-controller@e61c0000 { + compatible = "renesas,intc-ex-r8a774a1", "renesas,irqc"; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0 0xe61c0000 0 0x200>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 407>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 407>; + }; + + tmu0: timer@e61e0000 { + compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; + reg = <0 0xe61e0000 0 0x30>; + interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 125>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 125>; + status = "disabled"; + }; + + tmu1: timer@e6fc0000 { + compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; + reg = <0 0xe6fc0000 0 0x30>; + interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 124>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 124>; + status = "disabled"; + }; + + tmu2: timer@e6fd0000 { + compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; + reg = <0 0xe6fd0000 0 0x30>; + interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 123>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 123>; + status = "disabled"; + }; + + tmu3: timer@e6fe0000 { + compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; + reg = <0 0xe6fe0000 0 0x30>; + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 122>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 122>; + status = "disabled"; + }; + + tmu4: timer@ffc00000 { + compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; + reg = <0 0xffc00000 0 0x30>; + interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 121>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 121>; + status = "disabled"; + }; + + i2c0: i2c@e6500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6500000 0 0x40>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 931>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 931>; + dmas = <&dmac1 0x91>, <&dmac1 0x90>, + <&dmac2 0x91>, <&dmac2 0x90>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c1: i2c@e6508000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6508000 0 0x40>; + interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 930>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 930>; + dmas = <&dmac1 0x93>, <&dmac1 0x92>, + <&dmac2 0x93>, <&dmac2 0x92>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c2: i2c@e6510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6510000 0 0x40>; + interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 929>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 929>; + dmas = <&dmac1 0x95>, <&dmac1 0x94>, + <&dmac2 0x95>, <&dmac2 0x94>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c3: i2c@e66d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d0000 0 0x40>; + interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 928>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 928>; + dmas = <&dmac0 0x97>, <&dmac0 0x96>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c4: i2c@e66d8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d8000 0 0x40>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 927>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 927>; + dmas = <&dmac0 0x99>, <&dmac0 0x98>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c5: i2c@e66e0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e0000 0 0x40>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 919>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 919>; + dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c6: i2c@e66e8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774a1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e8000 0 0x40>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 918>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 918>; + dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c_dvfs: i2c@e60b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,iic-r8a774a1", + "renesas,rcar-gen3-iic", + "renesas,rmobile-iic"; + reg = <0 0xe60b0000 0 0x425>; + interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 926>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 926>; + dmas = <&dmac0 0x11>, <&dmac0 0x10>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + hscif0: serial@e6540000 { + compatible = "renesas,hscif-r8a774a1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6540000 0 0x60>; + interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 520>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x31>, <&dmac1 0x30>, + <&dmac2 0x31>, <&dmac2 0x30>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 520>; + status = "disabled"; + }; + + hscif1: serial@e6550000 { + compatible = "renesas,hscif-r8a774a1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6550000 0 0x60>; + interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 519>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x33>, <&dmac1 0x32>, + <&dmac2 0x33>, <&dmac2 0x32>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 519>; + status = "disabled"; + }; + + hscif2: serial@e6560000 { + compatible = "renesas,hscif-r8a774a1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6560000 0 0x60>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 518>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x35>, <&dmac1 0x34>, + <&dmac2 0x35>, <&dmac2 0x34>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 518>; + status = "disabled"; + }; + + hscif3: serial@e66a0000 { + compatible = "renesas,hscif-r8a774a1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66a0000 0 0x60>; + interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 517>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x37>, <&dmac0 0x36>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 517>; + status = "disabled"; + }; + + hscif4: serial@e66b0000 { + compatible = "renesas,hscif-r8a774a1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66b0000 0 0x60>; + interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 516>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x39>, <&dmac0 0x38>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 516>; + status = "disabled"; + }; + + hsusb: usb@e6590000 { + compatible = "renesas,usbhs-r8a774a1", + "renesas,rcar-gen3-usbhs"; + reg = <0 0xe6590000 0 0x200>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; + dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, + <&usb_dmac1 0>, <&usb_dmac1 1>; + dma-names = "ch0", "ch1", "ch2", "ch3"; + renesas,buswait = <11>; + phys = <&usb2_phy0 3>; + phy-names = "usb"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 704>, <&cpg 703>; + status = "disabled"; + }; + + usb_dmac0: dma-controller@e65a0000 { + compatible = "renesas,r8a774a1-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65a0000 0 0x100>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 330>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 330>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb_dmac1: dma-controller@e65b0000 { + compatible = "renesas,r8a774a1-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65b0000 0 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 331>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 331>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb3_phy0: usb-phy@e65ee000 { + compatible = "renesas,r8a774a1-usb3-phy", + "renesas,rcar-gen3-usb3-phy"; + reg = <0 0xe65ee000 0 0x90>; + clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, + <&usb_extal_clk>; + clock-names = "usb3-if", "usb3s_clk", "usb_extal"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 328>; + #phy-cells = <0>; + status = "disabled"; + }; + + dmac0: dma-controller@e6700000 { + compatible = "renesas,dmac-r8a774a1", + "renesas,rcar-dmac"; + reg = <0 0xe6700000 0 0x10000>; + interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 219>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 219>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, + <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, + <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, + <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, + <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, + <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, + <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, + <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; + }; + + dmac1: dma-controller@e7300000 { + compatible = "renesas,dmac-r8a774a1", + "renesas,rcar-dmac"; + reg = <0 0xe7300000 0 0x10000>; + interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 218>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 218>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, + <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, + <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, + <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, + <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, + <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, + <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, + <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; + }; + + dmac2: dma-controller@e7310000 { + compatible = "renesas,dmac-r8a774a1", + "renesas,rcar-dmac"; + reg = <0 0xe7310000 0 0x10000>; + interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 217>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 217>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, + <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, + <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, + <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, + <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, + <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, + <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, + <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; + }; + + ipmmu_ds0: iommu@e6740000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_ds1: iommu@e7740000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_hc: iommu@e6570000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mm: iommu@e67b0000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mp: iommu@ec670000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: iommu@fd800000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 5>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv1: iommu@fd950000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xfd950000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: iommu@fe6b0000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 8>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: iommu@febd0000 { + compatible = "renesas,ipmmu-r8a774a1"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 9>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + avb: ethernet@e6800000 { + compatible = "renesas,etheravb-r8a774a1", + "renesas,etheravb-rcar-gen3"; + reg = <0 0xe6800000 0 0x800>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15", + "ch16", "ch17", "ch18", "ch19", + "ch20", "ch21", "ch22", "ch23", + "ch24"; + clocks = <&cpg CPG_MOD 812>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 812>; + phy-mode = "rgmii"; + iommus = <&ipmmu_ds0 16>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + can0: can@e6c30000 { + compatible = "renesas,can-r8a774a1", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c30000 0 0x1000>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 916>, + <&cpg CPG_CORE R8A774A1_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 916>; + status = "disabled"; + }; + + can1: can@e6c38000 { + compatible = "renesas,can-r8a774a1", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c38000 0 0x1000>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 915>, + <&cpg CPG_CORE R8A774A1_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 915>; + status = "disabled"; + }; + + canfd: can@e66c0000 { + compatible = "renesas,r8a774a1-canfd", + "renesas,rcar-gen3-canfd"; + reg = <0 0xe66c0000 0 0x8000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 914>, + <&cpg CPG_CORE R8A774A1_CLK_CANFD>, + <&can_clk>; + clock-names = "fck", "canfd", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 914>; + status = "disabled"; + + channel0 { + status = "disabled"; + }; + + channel1 { + status = "disabled"; + }; + }; + + pwm0: pwm@e6e30000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e30000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm1: pwm@e6e31000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e31000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm2: pwm@e6e32000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e32000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm3: pwm@e6e33000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e33000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm4: pwm@e6e34000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e34000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm5: pwm@e6e35000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e35000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm6: pwm@e6e36000 { + compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; + reg = <0 0xe6e36000 0 0x8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + scif0: serial@e6e60000 { + compatible = "renesas,scif-r8a774a1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e60000 0 0x40>; + interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 207>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x51>, <&dmac1 0x50>, + <&dmac2 0x51>, <&dmac2 0x50>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 207>; + status = "disabled"; + }; + + scif1: serial@e6e68000 { + compatible = "renesas,scif-r8a774a1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e68000 0 0x40>; + interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 206>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x53>, <&dmac1 0x52>, + <&dmac2 0x53>, <&dmac2 0x52>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 206>; + status = "disabled"; + }; + + scif2: serial@e6e88000 { + compatible = "renesas,scif-r8a774a1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e88000 0 0x40>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 310>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x13>, <&dmac1 0x12>, + <&dmac2 0x13>, <&dmac2 0x12>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 310>; + status = "disabled"; + }; + + scif3: serial@e6c50000 { + compatible = "renesas,scif-r8a774a1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c50000 0 0x40>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 204>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x57>, <&dmac0 0x56>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 204>; + status = "disabled"; + }; + + scif4: serial@e6c40000 { + compatible = "renesas,scif-r8a774a1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c40000 0 0x40>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 203>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x59>, <&dmac0 0x58>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 203>; + status = "disabled"; + }; + + scif5: serial@e6f30000 { + compatible = "renesas,scif-r8a774a1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6f30000 0 0x40>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 202>, + <&cpg CPG_CORE R8A774A1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, + <&dmac2 0x5b>, <&dmac2 0x5a>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 202>; + status = "disabled"; + }; + + msiof0: spi@e6e90000 { + compatible = "renesas,msiof-r8a774a1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6e90000 0 0x0064>; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 211>; + dmas = <&dmac1 0x41>, <&dmac1 0x40>, + <&dmac2 0x41>, <&dmac2 0x40>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 211>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof1: spi@e6ea0000 { + compatible = "renesas,msiof-r8a774a1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6ea0000 0 0x0064>; + interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 210>; + dmas = <&dmac1 0x43>, <&dmac1 0x42>, + <&dmac2 0x43>, <&dmac2 0x42>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 210>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof2: spi@e6c00000 { + compatible = "renesas,msiof-r8a774a1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c00000 0 0x0064>; + interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 209>; + dmas = <&dmac0 0x45>, <&dmac0 0x44>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 209>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof3: spi@e6c10000 { + compatible = "renesas,msiof-r8a774a1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c10000 0 0x0064>; + interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 208>; + dmas = <&dmac0 0x47>, <&dmac0 0x46>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 208>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + vin0: video@e6ef0000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef0000 0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 811>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 811>; + renesas,id = <0>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin0csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin0>; + }; + vin0csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin0>; + }; + }; + }; + }; + + vin1: video@e6ef1000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef1000 0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 810>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 810>; + renesas,id = <1>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin1csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin1>; + }; + vin1csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin1>; + }; + }; + }; + }; + + vin2: video@e6ef2000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef2000 0 0x1000>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 809>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 809>; + renesas,id = <2>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin2csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin2>; + }; + vin2csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin2>; + }; + }; + }; + }; + + vin3: video@e6ef3000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef3000 0 0x1000>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 808>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 808>; + renesas,id = <3>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin3csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin3>; + }; + vin3csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin3>; + }; + }; + }; + }; + + vin4: video@e6ef4000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef4000 0 0x1000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 807>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 807>; + renesas,id = <4>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin4csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin4>; + }; + vin4csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin4>; + }; + }; + }; + }; + + vin5: video@e6ef5000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef5000 0 0x1000>; + interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 806>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 806>; + renesas,id = <5>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin5csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin5>; + }; + vin5csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin5>; + }; + }; + }; + }; + + vin6: video@e6ef6000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef6000 0 0x1000>; + interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 805>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 805>; + renesas,id = <6>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin6csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin6>; + }; + vin6csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin6>; + }; + }; + }; + }; + + vin7: video@e6ef7000 { + compatible = "renesas,vin-r8a774a1"; + reg = <0 0xe6ef7000 0 0x1000>; + interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 804>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 804>; + renesas,id = <7>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin7csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin7>; + }; + vin7csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin7>; + }; + }; + }; + }; + + rcar_sound: sound@ec500000 { + /* + * #sound-dai-cells is required + * + * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; + * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; + */ + /* + * #clock-cells is required for audio_clkout0/1/2/3 + * + * clkout : #clock-cells = <0>; <&rcar_sound>; + * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; + */ + compatible = "renesas,rcar_sound-r8a774a1", "renesas,rcar_sound-gen3"; + reg = <0 0xec500000 0 0x1000>, /* SCU */ + <0 0xec5a0000 0 0x100>, /* ADG */ + <0 0xec540000 0 0x1000>, /* SSIU */ + <0 0xec541000 0 0x280>, /* SSI */ + <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ + reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; + + clocks = <&cpg CPG_MOD 1005>, + <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, + <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, + <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, + <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, + <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, + <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, + <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, + <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, + <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, + <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, + <&audio_clk_a>, <&audio_clk_b>, + <&audio_clk_c>, + <&cpg CPG_CORE R8A774A1_CLK_S0D4>; + clock-names = "ssi-all", + "ssi.9", "ssi.8", "ssi.7", "ssi.6", + "ssi.5", "ssi.4", "ssi.3", "ssi.2", + "ssi.1", "ssi.0", + "src.9", "src.8", "src.7", "src.6", + "src.5", "src.4", "src.3", "src.2", + "src.1", "src.0", + "mix.1", "mix.0", + "ctu.1", "ctu.0", + "dvc.0", "dvc.1", + "clk_a", "clk_b", "clk_c", "clk_i"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 1005>, + <&cpg 1006>, <&cpg 1007>, + <&cpg 1008>, <&cpg 1009>, + <&cpg 1010>, <&cpg 1011>, + <&cpg 1012>, <&cpg 1013>, + <&cpg 1014>, <&cpg 1015>; + reset-names = "ssi-all", + "ssi.9", "ssi.8", "ssi.7", "ssi.6", + "ssi.5", "ssi.4", "ssi.3", "ssi.2", + "ssi.1", "ssi.0"; + status = "disabled"; + + rcar_sound,ctu { + ctu00: ctu-0 { }; + ctu01: ctu-1 { }; + ctu02: ctu-2 { }; + ctu03: ctu-3 { }; + ctu10: ctu-4 { }; + ctu11: ctu-5 { }; + ctu12: ctu-6 { }; + ctu13: ctu-7 { }; + }; + + rcar_sound,dvc { + dvc0: dvc-0 { + dmas = <&audma1 0xbc>; + dma-names = "tx"; + }; + dvc1: dvc-1 { + dmas = <&audma1 0xbe>; + dma-names = "tx"; + }; + }; + + rcar_sound,mix { + mix0: mix-0 { }; + mix1: mix-1 { }; + }; + + rcar_sound,src { + src0: src-0 { + interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x85>, <&audma1 0x9a>; + dma-names = "rx", "tx"; + }; + src1: src-1 { + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x87>, <&audma1 0x9c>; + dma-names = "rx", "tx"; + }; + src2: src-2 { + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x89>, <&audma1 0x9e>; + dma-names = "rx", "tx"; + }; + src3: src-3 { + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x8b>, <&audma1 0xa0>; + dma-names = "rx", "tx"; + }; + src4: src-4 { + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x8d>, <&audma1 0xb0>; + dma-names = "rx", "tx"; + }; + src5: src-5 { + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x8f>, <&audma1 0xb2>; + dma-names = "rx", "tx"; + }; + src6: src-6 { + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x91>, <&audma1 0xb4>; + dma-names = "rx", "tx"; + }; + src7: src-7 { + interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x93>, <&audma1 0xb6>; + dma-names = "rx", "tx"; + }; + src8: src-8 { + interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x95>, <&audma1 0xb8>; + dma-names = "rx", "tx"; + }; + src9: src-9 { + interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x97>, <&audma1 0xba>; + dma-names = "rx", "tx"; + }; + }; + + rcar_sound,ssi { + ssi0: ssi-0 { + interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x01>, <&audma1 0x02>; + dma-names = "rx", "tx"; + }; + ssi1: ssi-1 { + interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x03>, <&audma1 0x04>; + dma-names = "rx", "tx"; + }; + ssi2: ssi-2 { + interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x05>, <&audma1 0x06>; + dma-names = "rx", "tx"; + }; + ssi3: ssi-3 { + interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x07>, <&audma1 0x08>; + dma-names = "rx", "tx"; + }; + ssi4: ssi-4 { + interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x09>, <&audma1 0x0a>; + dma-names = "rx", "tx"; + }; + ssi5: ssi-5 { + interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x0b>, <&audma1 0x0c>; + dma-names = "rx", "tx"; + }; + ssi6: ssi-6 { + interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x0d>, <&audma1 0x0e>; + dma-names = "rx", "tx"; + }; + ssi7: ssi-7 { + interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x0f>, <&audma1 0x10>; + dma-names = "rx", "tx"; + }; + ssi8: ssi-8 { + interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x11>, <&audma1 0x12>; + dma-names = "rx", "tx"; + }; + ssi9: ssi-9 { + interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x13>, <&audma1 0x14>; + dma-names = "rx", "tx"; + }; + }; + + rcar_sound,ssiu { + ssiu00: ssiu-0 { + dmas = <&audma0 0x15>, <&audma1 0x16>; + dma-names = "rx", "tx"; + }; + ssiu01: ssiu-1 { + dmas = <&audma0 0x35>, <&audma1 0x36>; + dma-names = "rx", "tx"; + }; + ssiu02: ssiu-2 { + dmas = <&audma0 0x37>, <&audma1 0x38>; + dma-names = "rx", "tx"; + }; + ssiu03: ssiu-3 { + dmas = <&audma0 0x47>, <&audma1 0x48>; + dma-names = "rx", "tx"; + }; + ssiu04: ssiu-4 { + dmas = <&audma0 0x3F>, <&audma1 0x40>; + dma-names = "rx", "tx"; + }; + ssiu05: ssiu-5 { + dmas = <&audma0 0x43>, <&audma1 0x44>; + dma-names = "rx", "tx"; + }; + ssiu06: ssiu-6 { + dmas = <&audma0 0x4F>, <&audma1 0x50>; + dma-names = "rx", "tx"; + }; + ssiu07: ssiu-7 { + dmas = <&audma0 0x53>, <&audma1 0x54>; + dma-names = "rx", "tx"; + }; + ssiu10: ssiu-8 { + dmas = <&audma0 0x49>, <&audma1 0x4a>; + dma-names = "rx", "tx"; + }; + ssiu11: ssiu-9 { + dmas = <&audma0 0x4B>, <&audma1 0x4C>; + dma-names = "rx", "tx"; + }; + ssiu12: ssiu-10 { + dmas = <&audma0 0x57>, <&audma1 0x58>; + dma-names = "rx", "tx"; + }; + ssiu13: ssiu-11 { + dmas = <&audma0 0x59>, <&audma1 0x5A>; + dma-names = "rx", "tx"; + }; + ssiu14: ssiu-12 { + dmas = <&audma0 0x5F>, <&audma1 0x60>; + dma-names = "rx", "tx"; + }; + ssiu15: ssiu-13 { + dmas = <&audma0 0xC3>, <&audma1 0xC4>; + dma-names = "rx", "tx"; + }; + ssiu16: ssiu-14 { + dmas = <&audma0 0xC7>, <&audma1 0xC8>; + dma-names = "rx", "tx"; + }; + ssiu17: ssiu-15 { + dmas = <&audma0 0xCB>, <&audma1 0xCC>; + dma-names = "rx", "tx"; + }; + ssiu20: ssiu-16 { + dmas = <&audma0 0x63>, <&audma1 0x64>; + dma-names = "rx", "tx"; + }; + ssiu21: ssiu-17 { + dmas = <&audma0 0x67>, <&audma1 0x68>; + dma-names = "rx", "tx"; + }; + ssiu22: ssiu-18 { + dmas = <&audma0 0x6B>, <&audma1 0x6C>; + dma-names = "rx", "tx"; + }; + ssiu23: ssiu-19 { + dmas = <&audma0 0x6D>, <&audma1 0x6E>; + dma-names = "rx", "tx"; + }; + ssiu24: ssiu-20 { + dmas = <&audma0 0xCF>, <&audma1 0xCE>; + dma-names = "rx", "tx"; + }; + ssiu25: ssiu-21 { + dmas = <&audma0 0xEB>, <&audma1 0xEC>; + dma-names = "rx", "tx"; + }; + ssiu26: ssiu-22 { + dmas = <&audma0 0xED>, <&audma1 0xEE>; + dma-names = "rx", "tx"; + }; + ssiu27: ssiu-23 { + dmas = <&audma0 0xEF>, <&audma1 0xF0>; + dma-names = "rx", "tx"; + }; + ssiu30: ssiu-24 { + dmas = <&audma0 0x6f>, <&audma1 0x70>; + dma-names = "rx", "tx"; + }; + ssiu31: ssiu-25 { + dmas = <&audma0 0x21>, <&audma1 0x22>; + dma-names = "rx", "tx"; + }; + ssiu32: ssiu-26 { + dmas = <&audma0 0x23>, <&audma1 0x24>; + dma-names = "rx", "tx"; + }; + ssiu33: ssiu-27 { + dmas = <&audma0 0x25>, <&audma1 0x26>; + dma-names = "rx", "tx"; + }; + ssiu34: ssiu-28 { + dmas = <&audma0 0x27>, <&audma1 0x28>; + dma-names = "rx", "tx"; + }; + ssiu35: ssiu-29 { + dmas = <&audma0 0x29>, <&audma1 0x2A>; + dma-names = "rx", "tx"; + }; + ssiu36: ssiu-30 { + dmas = <&audma0 0x2B>, <&audma1 0x2C>; + dma-names = "rx", "tx"; + }; + ssiu37: ssiu-31 { + dmas = <&audma0 0x2D>, <&audma1 0x2E>; + dma-names = "rx", "tx"; + }; + ssiu40: ssiu-32 { + dmas = <&audma0 0x71>, <&audma1 0x72>; + dma-names = "rx", "tx"; + }; + ssiu41: ssiu-33 { + dmas = <&audma0 0x17>, <&audma1 0x18>; + dma-names = "rx", "tx"; + }; + ssiu42: ssiu-34 { + dmas = <&audma0 0x19>, <&audma1 0x1A>; + dma-names = "rx", "tx"; + }; + ssiu43: ssiu-35 { + dmas = <&audma0 0x1B>, <&audma1 0x1C>; + dma-names = "rx", "tx"; + }; + ssiu44: ssiu-36 { + dmas = <&audma0 0x1D>, <&audma1 0x1E>; + dma-names = "rx", "tx"; + }; + ssiu45: ssiu-37 { + dmas = <&audma0 0x1F>, <&audma1 0x20>; + dma-names = "rx", "tx"; + }; + ssiu46: ssiu-38 { + dmas = <&audma0 0x31>, <&audma1 0x32>; + dma-names = "rx", "tx"; + }; + ssiu47: ssiu-39 { + dmas = <&audma0 0x33>, <&audma1 0x34>; + dma-names = "rx", "tx"; + }; + ssiu50: ssiu-40 { + dmas = <&audma0 0x73>, <&audma1 0x74>; + dma-names = "rx", "tx"; + }; + ssiu60: ssiu-41 { + dmas = <&audma0 0x75>, <&audma1 0x76>; + dma-names = "rx", "tx"; + }; + ssiu70: ssiu-42 { + dmas = <&audma0 0x79>, <&audma1 0x7a>; + dma-names = "rx", "tx"; + }; + ssiu80: ssiu-43 { + dmas = <&audma0 0x7b>, <&audma1 0x7c>; + dma-names = "rx", "tx"; + }; + ssiu90: ssiu-44 { + dmas = <&audma0 0x7d>, <&audma1 0x7e>; + dma-names = "rx", "tx"; + }; + ssiu91: ssiu-45 { + dmas = <&audma0 0x7F>, <&audma1 0x80>; + dma-names = "rx", "tx"; + }; + ssiu92: ssiu-46 { + dmas = <&audma0 0x81>, <&audma1 0x82>; + dma-names = "rx", "tx"; + }; + ssiu93: ssiu-47 { + dmas = <&audma0 0x83>, <&audma1 0x84>; + dma-names = "rx", "tx"; + }; + ssiu94: ssiu-48 { + dmas = <&audma0 0xA3>, <&audma1 0xA4>; + dma-names = "rx", "tx"; + }; + ssiu95: ssiu-49 { + dmas = <&audma0 0xA5>, <&audma1 0xA6>; + dma-names = "rx", "tx"; + }; + ssiu96: ssiu-50 { + dmas = <&audma0 0xA7>, <&audma1 0xA8>; + dma-names = "rx", "tx"; + }; + ssiu97: ssiu-51 { + dmas = <&audma0 0xA9>, <&audma1 0xAA>; + dma-names = "rx", "tx"; + }; + }; + }; + + audma0: dma-controller@ec700000 { + compatible = "renesas,dmac-r8a774a1", + "renesas,rcar-dmac"; + reg = <0 0xec700000 0 0x10000>; + interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 502>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 502>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, + <&ipmmu_mp 2>, <&ipmmu_mp 3>, + <&ipmmu_mp 4>, <&ipmmu_mp 5>, + <&ipmmu_mp 6>, <&ipmmu_mp 7>, + <&ipmmu_mp 8>, <&ipmmu_mp 9>, + <&ipmmu_mp 10>, <&ipmmu_mp 11>, + <&ipmmu_mp 12>, <&ipmmu_mp 13>, + <&ipmmu_mp 14>, <&ipmmu_mp 15>; + }; + + audma1: dma-controller@ec720000 { + compatible = "renesas,dmac-r8a774a1", + "renesas,rcar-dmac"; + reg = <0 0xec720000 0 0x10000>; + interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 501>; + clock-names = "fck"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 501>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>, + <&ipmmu_mp 18>, <&ipmmu_mp 19>, + <&ipmmu_mp 20>, <&ipmmu_mp 21>, + <&ipmmu_mp 22>, <&ipmmu_mp 23>, + <&ipmmu_mp 24>, <&ipmmu_mp 25>, + <&ipmmu_mp 26>, <&ipmmu_mp 27>, + <&ipmmu_mp 28>, <&ipmmu_mp 29>, + <&ipmmu_mp 30>, <&ipmmu_mp 31>; + }; + + xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a774a1", + "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + usb3_peri0: usb@ee020000 { + compatible = "renesas,r8a774a1-usb3-peri", + "renesas,rcar-gen3-usb3-peri"; + reg = <0 0xee020000 0 0x400>; + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + ohci0: usb@ee080000 { + compatible = "generic-ohci"; + reg = <0 0xee080000 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + phys = <&usb2_phy0 1>; + phy-names = "usb"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + status = "disabled"; + }; + + ohci1: usb@ee0a0000 { + compatible = "generic-ohci"; + reg = <0 0xee0a0000 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1 1>; + phy-names = "usb"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 702>; + status = "disabled"; + }; + + ehci0: usb@ee080100 { + compatible = "generic-ehci"; + reg = <0 0xee080100 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + phys = <&usb2_phy0 2>; + phy-names = "usb"; + companion = <&ohci0>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + status = "disabled"; + }; + + ehci1: usb@ee0a0100 { + compatible = "generic-ehci"; + reg = <0 0xee0a0100 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1 2>; + phy-names = "usb"; + companion = <&ohci1>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 702>; + status = "disabled"; + }; + + usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a774a1", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee080200 0 0x700>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + #phy-cells = <1>; + status = "disabled"; + }; + + usb2_phy1: usb-phy@ee0a0200 { + compatible = "renesas,usb2-phy-r8a774a1", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0a0200 0 0x700>; + clocks = <&cpg CPG_MOD 702>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 702>; + #phy-cells = <1>; + status = "disabled"; + }; + + sdhi0: sd@ee100000 { + compatible = "renesas,sdhi-r8a774a1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee100000 0 0x2000>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 314>; + status = "disabled"; + }; + + sdhi1: sd@ee120000 { + compatible = "renesas,sdhi-r8a774a1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee120000 0 0x2000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 313>; + status = "disabled"; + }; + + sdhi2: sd@ee140000 { + compatible = "renesas,sdhi-r8a774a1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 312>; + status = "disabled"; + }; + + sdhi3: sd@ee160000 { + compatible = "renesas,sdhi-r8a774a1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee160000 0 0x2000>; + interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 311>; + status = "disabled"; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x0 0xf1010000 0 0x1000>, + <0x0 0xf1020000 0 0x20000>, + <0x0 0xf1040000 0 0x20000>, + <0x0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 408>; + }; + + pciec0: pcie@fe000000 { + compatible = "renesas,pcie-r8a774a1", + "renesas,pcie-rcar-gen3"; + reg = <0 0xfe000000 0 0x80000>; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, + <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, + <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, + <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 319>; + status = "disabled"; + }; + + pciec1: pcie@ee800000 { + compatible = "renesas,pcie-r8a774a1", + "renesas,pcie-rcar-gen3"; + reg = <0 0xee800000 0 0x80000>; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, + <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, + <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, + <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 318>; + status = "disabled"; + }; + + fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + resets = <&cpg 119>; + renesas,fcp = <&fcpf0>; + }; + + fcpf0: fcp@fe950000 { + compatible = "renesas,fcpf"; + reg = <0 0xfe950000 0 0x200>; + clocks = <&cpg CPG_MOD 615>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + resets = <&cpg 615>; + }; + + fcpvb0: fcp@fe96f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe96f000 0 0x200>; + clocks = <&cpg CPG_MOD 607>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + resets = <&cpg 607>; + }; + + fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 603>; + iommus = <&ipmmu_vi0 8>; + }; + + fcpvd1: fcp@fea2f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea2f000 0 0x200>; + clocks = <&cpg CPG_MOD 602>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 602>; + iommus = <&ipmmu_vi0 9>; + }; + + fcpvd2: fcp@fea37000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea37000 0 0x200>; + clocks = <&cpg CPG_MOD 601>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 601>; + iommus = <&ipmmu_vi0 10>; + }; + + fcpvi0: fcp@fe9af000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe9af000 0 0x200>; + clocks = <&cpg CPG_MOD 611>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + resets = <&cpg 611>; + iommus = <&ipmmu_vc0 19>; + }; + + vspb: vsp@fe960000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe960000 0 0x8000>; + interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 626>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + resets = <&cpg 626>; + + renesas,fcp = <&fcpvb0>; + }; + + vspd0: vsp@fea20000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea20000 0 0x5000>; + interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 623>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 623>; + + renesas,fcp = <&fcpvd0>; + }; + + vspd1: vsp@fea28000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea28000 0 0x5000>; + interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 622>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 622>; + + renesas,fcp = <&fcpvd1>; + }; + + vspd2: vsp@fea30000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea30000 0 0x5000>; + interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 621>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 621>; + + renesas,fcp = <&fcpvd2>; + }; + + vspi0: vsp@fe9a0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9a0000 0 0x8000>; + interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 631>; + power-domains = <&sysc R8A774A1_PD_A3VC>; + resets = <&cpg 631>; + + renesas,fcp = <&fcpvi0>; + }; + + csi20: csi2@fea80000 { + compatible = "renesas,r8a774a1-csi2"; + reg = <0 0xfea80000 0 0x10000>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 714>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 714>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi20vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi20>; + }; + csi20vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi20>; + }; + csi20vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi20>; + }; + csi20vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi20>; + }; + csi20vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi20>; + }; + csi20vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi20>; + }; + csi20vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi20>; + }; + csi20vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi20>; + }; + }; + }; + }; + + csi40: csi2@feaa0000 { + compatible = "renesas,r8a774a1-csi2"; + reg = <0 0xfeaa0000 0 0x10000>; + interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 716>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 716>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi40vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi40>; + }; + csi40vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi40>; + }; + csi40vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi40>; + }; + csi40vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi40>; + }; + csi40vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi40>; + }; + csi40vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi40>; + }; + csi40vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi40>; + }; + csi40vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi40>; + }; + }; + + }; + }; + + hdmi0: hdmi@fead0000 { + compatible = "renesas,r8a774a1-hdmi", + "renesas,rcar-gen3-hdmi"; + reg = <0 0xfead0000 0 0x10000>; + interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 729>, + <&cpg CPG_CORE R8A774A1_CLK_HDMI>; + clock-names = "iahb", "isfr"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 729>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + dw_hdmi0_in: endpoint { + remote-endpoint = <&du_out_hdmi0>; + }; + }; + port@1 { + reg = <1>; + }; + port@2 { + /* HDMI sound */ + reg = <2>; + }; + }; + }; + + du: display@feb00000 { + compatible = "renesas,du-r8a774a1"; + reg = <0 0xfeb00000 0 0x70000>; + interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 722>; + clock-names = "du.0", "du.1", "du.2"; + resets = <&cpg 724>, <&cpg 722>; + reset-names = "du.0", "du.2"; + status = "disabled"; + + renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + du_out_rgb: endpoint { + }; + }; + port@1 { + reg = <1>; + du_out_hdmi0: endpoint { + remote-endpoint = <&dw_hdmi0_in>; + }; + }; + port@2 { + reg = <2>; + du_out_lvds0: endpoint { + remote-endpoint = <&lvds0_in>; + }; + }; + }; + }; + + lvds0: lvds@feb90000 { + compatible = "renesas,r8a774a1-lvds"; + reg = <0 0xfeb90000 0 0x14>; + clocks = <&cpg CPG_MOD 727>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 727>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + lvds0_in: endpoint { + remote-endpoint = <&du_out_lvds0>; + }; + }; + port@1 { + reg = <1>; + lvds0_out: endpoint { + }; + }; + }; + }; + + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; + }; + }; + + thermal-zones { + sensor_thermal1: sensor-thermal1 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 0>; + sustainable-power = <3874>; + + trips { + sensor1_crit: sensor1-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + sensor_thermal2: sensor-thermal2 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 1>; + sustainable-power = <3874>; + + trips { + sensor2_crit: sensor2-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + sensor_thermal3: sensor-thermal3 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 2>; + sustainable-power = <3874>; + + cooling-maps { + map0 { + trip = <&target>; + cooling-device = <&a57_0 0 2>; + contribution = <1024>; + }; + map1 { + trip = <&target>; + cooling-device = <&a53_0 0 2>; + contribution = <1024>; + }; + }; + trips { + target: trip-point1 { + temperature = <100000>; + hysteresis = <1000>; + type = "passive"; + }; + + sensor3_crit: sensor3-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; + }; + + /* External USB clocks - can be overridden by the board */ + usb3s0_clk: usb3s0 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + usb_extal_clk: usb_extal { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; +}; diff --git a/include/dt-bindings/clock/r8a774a1-cpg-mssr.h b/include/dt-bindings/clock/r8a774a1-cpg-mssr.h new file mode 100644 index 0000000000..ac3fde148c --- /dev/null +++ b/include/dt-bindings/clock/r8a774a1-cpg-mssr.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 Renesas Electronics Corp. + */ +#ifndef __DT_BINDINGS_CLOCK_R8A774A1_CPG_MSSR_H__ +#define __DT_BINDINGS_CLOCK_R8A774A1_CPG_MSSR_H__ + +#include <dt-bindings/clock/renesas-cpg-mssr.h> + +/* r8a774a1 CPG Core Clocks */ +#define R8A774A1_CLK_Z 0 +#define R8A774A1_CLK_Z2 1 +#define R8A774A1_CLK_ZR 2 +#define R8A774A1_CLK_ZG 3 +#define R8A774A1_CLK_ZTR 4 +#define R8A774A1_CLK_ZTRD2 5 +#define R8A774A1_CLK_ZT 6 +#define R8A774A1_CLK_ZX 7 +#define R8A774A1_CLK_S0D1 8 +#define R8A774A1_CLK_S0D2 9 +#define R8A774A1_CLK_S0D3 10 +#define R8A774A1_CLK_S0D4 11 +#define R8A774A1_CLK_S0D6 12 +#define R8A774A1_CLK_S0D8 13 +#define R8A774A1_CLK_S0D12 14 +#define R8A774A1_CLK_S1D1 15 +#define R8A774A1_CLK_S1D2 16 +#define R8A774A1_CLK_S1D4 17 +#define R8A774A1_CLK_S2D1 18 +#define R8A774A1_CLK_S2D2 19 +#define R8A774A1_CLK_S2D4 20 +#define R8A774A1_CLK_S3D1 21 +#define R8A774A1_CLK_S3D2 22 +#define R8A774A1_CLK_S3D4 23 +#define R8A774A1_CLK_LB 24 +#define R8A774A1_CLK_CL 25 +#define R8A774A1_CLK_ZB3 26 +#define R8A774A1_CLK_ZB3D2 27 +#define R8A774A1_CLK_ZB3D4 28 +#define R8A774A1_CLK_CR 29 +#define R8A774A1_CLK_CRD2 30 +#define R8A774A1_CLK_SD0H 31 +#define R8A774A1_CLK_SD0 32 +#define R8A774A1_CLK_SD1H 33 +#define R8A774A1_CLK_SD1 34 +#define R8A774A1_CLK_SD2H 35 +#define R8A774A1_CLK_SD2 36 +#define R8A774A1_CLK_SD3H 37 +#define R8A774A1_CLK_SD3 38 +#define R8A774A1_CLK_SSP2 39 +#define R8A774A1_CLK_SSP1 40 +#define R8A774A1_CLK_SSPRS 41 +#define R8A774A1_CLK_RPC 42 +#define R8A774A1_CLK_RPCD2 43 +#define R8A774A1_CLK_MSO 44 +#define R8A774A1_CLK_CANFD 45 +#define R8A774A1_CLK_HDMI 46 +#define R8A774A1_CLK_CSI0 47 +#define R8A774A1_CLK_CSIREF 48 +#define R8A774A1_CLK_CP 49 +#define R8A774A1_CLK_CPEX 50 +#define R8A774A1_CLK_R 51 +#define R8A774A1_CLK_OSC 52 + +#endif /* __DT_BINDINGS_CLOCK_R8A774A1_CPG_MSSR_H__ */ diff --git a/include/dt-bindings/power/r8a774a1-sysc.h b/include/dt-bindings/power/r8a774a1-sysc.h new file mode 100644 index 0000000000..d84ea0eb12 --- /dev/null +++ b/include/dt-bindings/power/r8a774a1-sysc.h @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 Renesas Electronics Corp. + */ +#ifndef __DT_BINDINGS_POWER_R8A774A1_SYSC_H__ +#define __DT_BINDINGS_POWER_R8A774A1_SYSC_H__ + +/* + * These power domain indices match the numbers of the interrupt bits + * representing the power areas in the various Interrupt Registers + * (e.g. SYSCISR, Interrupt Status Register) + */ + +#define R8A774A1_PD_CA57_CPU0 0 +#define R8A774A1_PD_CA57_CPU1 1 +#define R8A774A1_PD_CA53_CPU0 5 +#define R8A774A1_PD_CA53_CPU1 6 +#define R8A774A1_PD_CA53_CPU2 7 +#define R8A774A1_PD_CA53_CPU3 8 +#define R8A774A1_PD_CA57_SCU 12 +#define R8A774A1_PD_CR7 13 +#define R8A774A1_PD_A3VC 14 +#define R8A774A1_PD_3DG_A 17 +#define R8A774A1_PD_3DG_B 18 +#define R8A774A1_PD_CA53_SCU 21 +#define R8A774A1_PD_A3IR 24 +#define R8A774A1_PD_A2VC0 25 +#define R8A774A1_PD_A2VC1 26 + +/* Always-on power area */ +#define R8A774A1_PD_ALWAYS_ON 32 + +#endif /* __DT_BINDINGS_POWER_R8A774A1_SYSC_H__ */
This sync's the clock tables with the official release from Renesas' repo based on U-Boot 2018.09 and modified to build into the latest version of U-Boot.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/drivers/clk/renesas/Kconfig b/drivers/clk/renesas/Kconfig index e78817829b..284e2138b3 100644 --- a/drivers/clk/renesas/Kconfig +++ b/drivers/clk/renesas/Kconfig @@ -48,6 +48,13 @@ config CLK_RCAR_GEN3 help Enable this to support the clocks on Renesas RCar Gen3 SoC.
+config CLK_R8A774A1 + bool "Renesas R8A774A1 clock driver" + def_bool y if R8A774A1 + depends on CLK_RCAR_GEN3 + help + Enable this to support the clocks on Renesas R8A774A1 SoC. + config CLK_R8A7795 bool "Renesas R8A7795 clock driver" depends on CLK_RCAR_GEN3 diff --git a/drivers/clk/renesas/Makefile b/drivers/clk/renesas/Makefile index 88339e9d7e..dd599b757e 100644 --- a/drivers/clk/renesas/Makefile +++ b/drivers/clk/renesas/Makefile @@ -1,5 +1,6 @@ obj-$(CONFIG_CLK_RENESAS) += renesas-cpg-mssr.o obj-$(CONFIG_CLK_RCAR_GEN2) += clk-rcar-gen2.o +obj-$(CONFIG_CLK_R8A774A1) += r8a774a1-cpg-mssr.o obj-$(CONFIG_CLK_R8A7790) += r8a7790-cpg-mssr.o obj-$(CONFIG_CLK_R8A7791) += r8a7791-cpg-mssr.o obj-$(CONFIG_CLK_R8A7792) += r8a7792-cpg-mssr.o diff --git a/drivers/clk/renesas/r8a774a1-cpg-mssr.c b/drivers/clk/renesas/r8a774a1-cpg-mssr.c new file mode 100644 index 0000000000..0341d8e61c --- /dev/null +++ b/drivers/clk/renesas/r8a774a1-cpg-mssr.c @@ -0,0 +1,343 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Renesas R8A774A1 CPG MSSR driver + * + * Copyright (C) 2017-2019 Marek Vasut marek.vasut@gmail.com + * + * Based on the following driver from Linux kernel: + * r8a7796 Clock Pulse Generator / Module Standby and Software Reset + * + * Copyright (C) 2016 Glider bvba + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> + +#include <dt-bindings/clock/r8a774a1-cpg-mssr.h> + +#include "renesas-cpg-mssr.h" +#include "rcar-gen3-cpg.h" + +enum clk_ids { + /* Core Clock Outputs exported to DT */ + LAST_DT_CORE_CLK = R8A774A1_CLK_OSC, + + /* External Input Clocks */ + CLK_EXTAL, + CLK_EXTALR, + + /* Internal Core Clocks */ + CLK_MAIN, + CLK_PLL0, + CLK_PLL1, + CLK_PLL2, + CLK_PLL3, + CLK_PLL4, + CLK_PLL1_DIV2, + CLK_PLL1_DIV4, + CLK_S0, + CLK_S1, + CLK_S2, + CLK_S3, + CLK_SDSRC, + CLK_RPCSRC, + CLK_SSPSRC, + CLK_RINT, + + /* Module Clocks */ + MOD_CLK_BASE +}; + +static const struct cpg_core_clk r8a774a1_core_clks[] = { + /* External Clock Inputs */ + DEF_INPUT("extal", CLK_EXTAL), + DEF_INPUT("extalr", CLK_EXTALR), + + /* Internal Core Clocks */ + DEF_BASE(".main", CLK_MAIN, CLK_TYPE_GEN3_MAIN, CLK_EXTAL), + DEF_BASE(".pll0", CLK_PLL0, CLK_TYPE_GEN3_PLL0, CLK_MAIN), + DEF_BASE(".pll1", CLK_PLL1, CLK_TYPE_GEN3_PLL1, CLK_MAIN), + DEF_BASE(".pll2", CLK_PLL2, CLK_TYPE_GEN3_PLL2, CLK_MAIN), + DEF_BASE(".pll3", CLK_PLL3, CLK_TYPE_GEN3_PLL3, CLK_MAIN), + DEF_BASE(".pll4", CLK_PLL4, CLK_TYPE_GEN3_PLL4, CLK_MAIN), + + DEF_FIXED(".pll1_div2", CLK_PLL1_DIV2, CLK_PLL1, 2, 1), + DEF_FIXED(".pll1_div4", CLK_PLL1_DIV4, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s0", CLK_S0, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s1", CLK_S1, CLK_PLL1_DIV2, 3, 1), + DEF_FIXED(".s2", CLK_S2, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED(".s3", CLK_S3, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED(".sdsrc", CLK_SDSRC, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".rpcsrc", CLK_RPCSRC, CLK_PLL1, 2, 1), + + DEF_GEN3_OSC(".r", CLK_RINT, CLK_EXTAL, 32), + + /* Core Clock Outputs */ + DEF_FIXED("ztr", R8A774A1_CLK_ZTR, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED("ztrd2", R8A774A1_CLK_ZTRD2, CLK_PLL1_DIV2, 12, 1), + DEF_FIXED("zt", R8A774A1_CLK_ZT, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED("zx", R8A774A1_CLK_ZX, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED("s0d1", R8A774A1_CLK_S0D1, CLK_S0, 1, 1), + DEF_FIXED("s0d2", R8A774A1_CLK_S0D2, CLK_S0, 2, 1), + DEF_FIXED("s0d3", R8A774A1_CLK_S0D3, CLK_S0, 3, 1), + DEF_FIXED("s0d4", R8A774A1_CLK_S0D4, CLK_S0, 4, 1), + DEF_FIXED("s0d6", R8A774A1_CLK_S0D6, CLK_S0, 6, 1), + DEF_FIXED("s0d8", R8A774A1_CLK_S0D8, CLK_S0, 8, 1), + DEF_FIXED("s0d12", R8A774A1_CLK_S0D12, CLK_S0, 12, 1), + DEF_FIXED("s1d1", R8A774A1_CLK_S1D1, CLK_S1, 1, 1), + DEF_FIXED("s1d2", R8A774A1_CLK_S1D2, CLK_S1, 2, 1), + DEF_FIXED("s1d4", R8A774A1_CLK_S1D4, CLK_S1, 4, 1), + DEF_FIXED("s2d1", R8A774A1_CLK_S2D1, CLK_S2, 1, 1), + DEF_FIXED("s2d2", R8A774A1_CLK_S2D2, CLK_S2, 2, 1), + DEF_FIXED("s2d4", R8A774A1_CLK_S2D4, CLK_S2, 4, 1), + DEF_FIXED("s3d1", R8A774A1_CLK_S3D1, CLK_S3, 1, 1), + DEF_FIXED("s3d2", R8A774A1_CLK_S3D2, CLK_S3, 2, 1), + DEF_FIXED("s3d4", R8A774A1_CLK_S3D4, CLK_S3, 4, 1), + + DEF_GEN3_SD("sd0", R8A774A1_CLK_SD0, CLK_SDSRC, 0x074), + DEF_GEN3_SD("sd1", R8A774A1_CLK_SD1, CLK_SDSRC, 0x078), + DEF_GEN3_SD("sd2", R8A774A1_CLK_SD2, CLK_SDSRC, 0x268), + DEF_GEN3_SD("sd3", R8A774A1_CLK_SD3, CLK_SDSRC, 0x26c), + + DEF_GEN3_RPC("rpc", R8A774A1_CLK_RPC, CLK_RPCSRC, 0x238), + + DEF_FIXED("cl", R8A774A1_CLK_CL, CLK_PLL1_DIV2, 48, 1), + DEF_FIXED("cp", R8A774A1_CLK_CP, CLK_EXTAL, 2, 1), + + /* NOTE: HDMI, CSI, CAN etc. clock are missing */ + + DEF_BASE("r", R8A774A1_CLK_R, CLK_TYPE_GEN3_R, CLK_RINT), +}; + +static const struct mssr_mod_clk r8a774a1_mod_clks[] = { + DEF_MOD("scif5", 202, R8A774A1_CLK_S3D4), + DEF_MOD("scif4", 203, R8A774A1_CLK_S3D4), + DEF_MOD("scif3", 204, R8A774A1_CLK_S3D4), + DEF_MOD("scif1", 206, R8A774A1_CLK_S3D4), + DEF_MOD("scif0", 207, R8A774A1_CLK_S3D4), + DEF_MOD("msiof3", 208, R8A774A1_CLK_MSO), + DEF_MOD("msiof2", 209, R8A774A1_CLK_MSO), + DEF_MOD("msiof1", 210, R8A774A1_CLK_MSO), + DEF_MOD("msiof0", 211, R8A774A1_CLK_MSO), + DEF_MOD("sys-dmac2", 217, R8A774A1_CLK_S0D3), + DEF_MOD("sys-dmac1", 218, R8A774A1_CLK_S0D3), + DEF_MOD("sys-dmac0", 219, R8A774A1_CLK_S0D3), + DEF_MOD("cmt3", 300, R8A774A1_CLK_R), + DEF_MOD("cmt2", 301, R8A774A1_CLK_R), + DEF_MOD("cmt1", 302, R8A774A1_CLK_R), + DEF_MOD("cmt0", 303, R8A774A1_CLK_R), + DEF_MOD("scif2", 310, R8A774A1_CLK_S3D4), + DEF_MOD("sdif3", 311, R8A774A1_CLK_SD3), + DEF_MOD("sdif2", 312, R8A774A1_CLK_SD2), + DEF_MOD("sdif1", 313, R8A774A1_CLK_SD1), + DEF_MOD("sdif0", 314, R8A774A1_CLK_SD0), + DEF_MOD("pcie1", 318, R8A774A1_CLK_S3D1), + DEF_MOD("pcie0", 319, R8A774A1_CLK_S3D1), + DEF_MOD("usb3-if0", 328, R8A774A1_CLK_S3D1), + DEF_MOD("usb-dmac0", 330, R8A774A1_CLK_S3D1), + DEF_MOD("usb-dmac1", 331, R8A774A1_CLK_S3D1), + DEF_MOD("rwdt", 402, R8A774A1_CLK_R), + DEF_MOD("intc-ex", 407, R8A774A1_CLK_CP), + DEF_MOD("intc-ap", 408, R8A774A1_CLK_S3D1), + DEF_MOD("audmac1", 501, R8A774A1_CLK_S0D3), + DEF_MOD("audmac0", 502, R8A774A1_CLK_S0D3), + DEF_MOD("drif31", 508, R8A774A1_CLK_S3D2), + DEF_MOD("drif30", 509, R8A774A1_CLK_S3D2), + DEF_MOD("drif21", 510, R8A774A1_CLK_S3D2), + DEF_MOD("drif20", 511, R8A774A1_CLK_S3D2), + DEF_MOD("drif11", 512, R8A774A1_CLK_S3D2), + DEF_MOD("drif10", 513, R8A774A1_CLK_S3D2), + DEF_MOD("drif01", 514, R8A774A1_CLK_S3D2), + DEF_MOD("drif00", 515, R8A774A1_CLK_S3D2), + DEF_MOD("hscif4", 516, R8A774A1_CLK_S3D1), + DEF_MOD("hscif3", 517, R8A774A1_CLK_S3D1), + DEF_MOD("hscif2", 518, R8A774A1_CLK_S3D1), + DEF_MOD("hscif1", 519, R8A774A1_CLK_S3D1), + DEF_MOD("hscif0", 520, R8A774A1_CLK_S3D1), + DEF_MOD("thermal", 522, R8A774A1_CLK_CP), + DEF_MOD("pwm", 523, R8A774A1_CLK_S0D12), + DEF_MOD("fcpvd2", 601, R8A774A1_CLK_S0D2), + DEF_MOD("fcpvd1", 602, R8A774A1_CLK_S0D2), + DEF_MOD("fcpvd0", 603, R8A774A1_CLK_S0D2), + DEF_MOD("fcpvb0", 607, R8A774A1_CLK_S0D1), + DEF_MOD("fcpvi0", 611, R8A774A1_CLK_S0D1), + DEF_MOD("fcpf0", 615, R8A774A1_CLK_S0D1), + DEF_MOD("fcpci0", 617, R8A774A1_CLK_S0D2), + DEF_MOD("fcpcs", 619, R8A774A1_CLK_S0D2), + DEF_MOD("vspd2", 621, R8A774A1_CLK_S0D2), + DEF_MOD("vspd1", 622, R8A774A1_CLK_S0D2), + DEF_MOD("vspd0", 623, R8A774A1_CLK_S0D2), + DEF_MOD("vspb", 626, R8A774A1_CLK_S0D1), + DEF_MOD("vspi0", 631, R8A774A1_CLK_S0D1), + DEF_MOD("ehci1", 702, R8A774A1_CLK_S3D4), + DEF_MOD("ehci0", 703, R8A774A1_CLK_S3D4), + DEF_MOD("hsusb", 704, R8A774A1_CLK_S3D4), + DEF_MOD("csi20", 714, R8A774A1_CLK_CSI0), + DEF_MOD("csi40", 716, R8A774A1_CLK_CSI0), + DEF_MOD("du2", 722, R8A774A1_CLK_S2D1), + DEF_MOD("du1", 723, R8A774A1_CLK_S2D1), + DEF_MOD("du0", 724, R8A774A1_CLK_S2D1), + DEF_MOD("lvds", 727, R8A774A1_CLK_S2D1), + DEF_MOD("hdmi0", 729, R8A774A1_CLK_HDMI), + DEF_MOD("vin7", 804, R8A774A1_CLK_S0D2), + DEF_MOD("vin6", 805, R8A774A1_CLK_S0D2), + DEF_MOD("vin5", 806, R8A774A1_CLK_S0D2), + DEF_MOD("vin4", 807, R8A774A1_CLK_S0D2), + DEF_MOD("vin3", 808, R8A774A1_CLK_S0D2), + DEF_MOD("vin2", 809, R8A774A1_CLK_S0D2), + DEF_MOD("vin1", 810, R8A774A1_CLK_S0D2), + DEF_MOD("vin0", 811, R8A774A1_CLK_S0D2), + DEF_MOD("etheravb", 812, R8A774A1_CLK_S0D6), + DEF_MOD("imr1", 822, R8A774A1_CLK_S0D2), + DEF_MOD("imr0", 823, R8A774A1_CLK_S0D2), + DEF_MOD("gpio7", 905, R8A774A1_CLK_S3D4), + DEF_MOD("gpio6", 906, R8A774A1_CLK_S3D4), + DEF_MOD("gpio5", 907, R8A774A1_CLK_S3D4), + DEF_MOD("gpio4", 908, R8A774A1_CLK_S3D4), + DEF_MOD("gpio3", 909, R8A774A1_CLK_S3D4), + DEF_MOD("gpio2", 910, R8A774A1_CLK_S3D4), + DEF_MOD("gpio1", 911, R8A774A1_CLK_S3D4), + DEF_MOD("gpio0", 912, R8A774A1_CLK_S3D4), + DEF_MOD("can-fd", 914, R8A774A1_CLK_S3D2), + DEF_MOD("can-if1", 915, R8A774A1_CLK_S3D4), + DEF_MOD("can-if0", 916, R8A774A1_CLK_S3D4), + DEF_MOD("rpc", 917, R8A774A1_CLK_RPC), + DEF_MOD("i2c6", 918, R8A774A1_CLK_S0D6), + DEF_MOD("i2c5", 919, R8A774A1_CLK_S0D6), + DEF_MOD("i2c-dvfs", 926, R8A774A1_CLK_CP), + DEF_MOD("i2c4", 927, R8A774A1_CLK_S0D6), + DEF_MOD("i2c3", 928, R8A774A1_CLK_S0D6), + DEF_MOD("i2c2", 929, R8A774A1_CLK_S3D2), + DEF_MOD("i2c1", 930, R8A774A1_CLK_S3D2), + DEF_MOD("i2c0", 931, R8A774A1_CLK_S3D2), + DEF_MOD("ssi-all", 1005, R8A774A1_CLK_S3D4), + DEF_MOD("ssi9", 1006, MOD_CLK_ID(1005)), + DEF_MOD("ssi8", 1007, MOD_CLK_ID(1005)), + DEF_MOD("ssi7", 1008, MOD_CLK_ID(1005)), + DEF_MOD("ssi6", 1009, MOD_CLK_ID(1005)), + DEF_MOD("ssi5", 1010, MOD_CLK_ID(1005)), + DEF_MOD("ssi4", 1011, MOD_CLK_ID(1005)), + DEF_MOD("ssi3", 1012, MOD_CLK_ID(1005)), + DEF_MOD("ssi2", 1013, MOD_CLK_ID(1005)), + DEF_MOD("ssi1", 1014, MOD_CLK_ID(1005)), + DEF_MOD("ssi0", 1015, MOD_CLK_ID(1005)), + DEF_MOD("scu-all", 1017, R8A774A1_CLK_S3D4), + DEF_MOD("scu-dvc1", 1018, MOD_CLK_ID(1017)), + DEF_MOD("scu-dvc0", 1019, MOD_CLK_ID(1017)), + DEF_MOD("scu-ctu1-mix1", 1020, MOD_CLK_ID(1017)), + DEF_MOD("scu-ctu0-mix0", 1021, MOD_CLK_ID(1017)), + DEF_MOD("scu-src9", 1022, MOD_CLK_ID(1017)), + DEF_MOD("scu-src8", 1023, MOD_CLK_ID(1017)), + DEF_MOD("scu-src7", 1024, MOD_CLK_ID(1017)), + DEF_MOD("scu-src6", 1025, MOD_CLK_ID(1017)), + DEF_MOD("scu-src5", 1026, MOD_CLK_ID(1017)), + DEF_MOD("scu-src4", 1027, MOD_CLK_ID(1017)), + DEF_MOD("scu-src3", 1028, MOD_CLK_ID(1017)), + DEF_MOD("scu-src2", 1029, MOD_CLK_ID(1017)), + DEF_MOD("scu-src1", 1030, MOD_CLK_ID(1017)), + DEF_MOD("scu-src0", 1031, MOD_CLK_ID(1017)), +}; + +/* + * CPG Clock Data + */ + +/* + * MD EXTAL PLL0 PLL1 PLL2 PLL3 PLL4 + * 14 13 19 17 (MHz) + *------------------------------------------------------------------- + * 0 0 0 0 16.66 x 1 x180 x192 x144 x192 x144 + * 0 0 0 1 16.66 x 1 x180 x192 x144 x128 x144 + * 0 0 1 0 Prohibited setting + * 0 0 1 1 16.66 x 1 x180 x192 x144 x192 x144 + * 0 1 0 0 20 x 1 x150 x160 x120 x160 x120 + * 0 1 0 1 20 x 1 x150 x160 x120 x106 x120 + * 0 1 1 0 Prohibited setting + * 0 1 1 1 20 x 1 x150 x160 x120 x160 x120 + * 1 0 0 0 25 x 1 x120 x128 x96 x128 x96 + * 1 0 0 1 25 x 1 x120 x128 x96 x84 x96 + * 1 0 1 0 Prohibited setting + * 1 0 1 1 25 x 1 x120 x128 x96 x128 x96 + * 1 1 0 0 33.33 / 2 x180 x192 x144 x192 x144 + * 1 1 0 1 33.33 / 2 x180 x192 x144 x128 x144 + * 1 1 1 0 Prohibited setting + * 1 1 1 1 33.33 / 2 x180 x192 x144 x192 x144 + */ +#define CPG_PLL_CONFIG_INDEX(md) ((((md) & BIT(14)) >> 11) | \ + (((md) & BIT(13)) >> 11) | \ + (((md) & BIT(19)) >> 18) | \ + (((md) & BIT(17)) >> 17)) + +static const struct rcar_gen3_cpg_pll_config cpg_pll_configs[16] = { + /* EXTAL div PLL1 mult/div PLL3 mult/div OSC prediv */ + { 1, 192, 1, 192, 1, 16, }, + { 1, 192, 1, 128, 1, 16, }, + { 0, /* Prohibited setting */ }, + { 1, 192, 1, 192, 1, 16, }, + { 1, 160, 1, 160, 1, 16, }, + { 1, 160, 1, 106, 1, 16, }, + { 0, /* Prohibited setting */ }, + { 1, 160, 1, 160, 1, 16, }, + { 1, 128, 1, 128, 1, 16, }, + { 1, 128, 1, 84, 1, 16, }, + { 0, /* Prohibited setting */ }, + { 1, 128, 1, 128, 1, 16, }, + { 2, 192, 1, 192, 1, 16, }, + { 2, 192, 1, 128, 1, 16, }, + { 0, /* Prohibited setting */ }, + { 2, 192, 1, 192, 1, 16, }, +}; + +static const struct mstp_stop_table r8a774a1_mstp_table[] = { + { 0x00200000, 0x0, 0x00200000, 0 }, + { 0xFFFFFFFF, 0x0, 0xFFFFFFFF, 0 }, + { 0x340E2FDC, 0x2040, 0x340E2FDC, 0 }, + { 0xFFFFFFDF, 0x400, 0xFFFFFFDF, 0 }, + { 0x80000184, 0x180, 0x80000184, 0 }, + { 0xC3FFFFFF, 0x0, 0xC3FFFFFF, 0 }, + { 0xFFFFFFFF, 0x0, 0xFFFFFFFF, 0 }, + { 0xFFFFFFFF, 0x0, 0xFFFFFFFF, 0 }, + { 0x01F1FFF7, 0x0, 0x01F1FFF7, 0 }, + { 0xFFFFFFFE, 0x0, 0xFFFFFFFE, 0 }, + { 0xFFFEFFE0, 0x0, 0xFFFEFFE0, 0 }, + { 0x000000B7, 0x0, 0x000000B7, 0 }, +}; + +static const void *r8a774a1_get_pll_config(const u32 cpg_mode) +{ + return &cpg_pll_configs[CPG_PLL_CONFIG_INDEX(cpg_mode)]; +} + +static const struct cpg_mssr_info r8a774a1_cpg_mssr_info = { + .core_clk = r8a774a1_core_clks, + .core_clk_size = ARRAY_SIZE(r8a774a1_core_clks), + .mod_clk = r8a774a1_mod_clks, + .mod_clk_size = ARRAY_SIZE(r8a774a1_mod_clks), + .mstp_table = r8a774a1_mstp_table, + .mstp_table_size = ARRAY_SIZE(r8a774a1_mstp_table), + .reset_node = "renesas,r8a774a1-rst", + .extalr_node = "extalr", + .mod_clk_base = MOD_CLK_BASE, + .clk_extal_id = CLK_EXTAL, + .clk_extalr_id = CLK_EXTALR, + .get_pll_config = r8a774a1_get_pll_config, +}; + +static const struct udevice_id r8a774a1_clk_ids[] = { + { + .compatible = "renesas,r8a774a1-cpg-mssr", + .data = (ulong)&r8a774a1_cpg_mssr_info, + }, + { } +}; + +U_BOOT_DRIVER(clk_r8a774a1) = { + .name = "clk_r8a774a1", + .id = UCLASS_CLK, + .of_match = r8a774a1_clk_ids, + .priv_auto_alloc_size = sizeof(struct gen3_clk_priv), + .ops = &gen3_clk_ops, + .probe = gen3_clk_probe, + .remove = gen3_clk_remove, +};
Add R8A774A1 PFC tables based on Renesas' repo based on 2018.09.
diff --git a/drivers/pinctrl/renesas/Kconfig b/drivers/pinctrl/renesas/Kconfig index 4d3d68d307..8327bcabd6 100644 --- a/drivers/pinctrl/renesas/Kconfig +++ b/drivers/pinctrl/renesas/Kconfig @@ -77,6 +77,16 @@ config PINCTRL_PFC_R8A7796 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_PFC_R8A774A1 + bool "Renesas RCar Gen3 R8A774A1 pin control driver" + depends on PINCTRL_PFC + help + Support pin multiplexing control on Renesas RZG2M R8A774A1 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + config PINCTRL_PFC_R8A77965 bool "Renesas RCar Gen3 R8A77965 pin control driver" depends on PINCTRL_PFC diff --git a/drivers/pinctrl/renesas/Makefile b/drivers/pinctrl/renesas/Makefile index a92f787a89..cc0b0471e6 100644 --- a/drivers/pinctrl/renesas/Makefile +++ b/drivers/pinctrl/renesas/Makefile @@ -6,6 +6,7 @@ obj-$(CONFIG_PINCTRL_PFC_R8A7793) += pfc-r8a7791.o obj-$(CONFIG_PINCTRL_PFC_R8A7794) += pfc-r8a7794.o obj-$(CONFIG_PINCTRL_PFC_R8A7795) += pfc-r8a7795.o obj-$(CONFIG_PINCTRL_PFC_R8A7796) += pfc-r8a7796.o +obj-$(CONFIG_PINCTRL_PFC_R8A774A1) += pfc-r8a774a1.o obj-$(CONFIG_PINCTRL_PFC_R8A77965) += pfc-r8a77965.o obj-$(CONFIG_PINCTRL_PFC_R8A77970) += pfc-r8a77970.o obj-$(CONFIG_PINCTRL_PFC_R8A77980) += pfc-r8a77980.o diff --git a/drivers/pinctrl/renesas/pfc-r8a774a1.c b/drivers/pinctrl/renesas/pfc-r8a774a1.c new file mode 100644 index 0000000000..3647b5427f --- /dev/null +++ b/drivers/pinctrl/renesas/pfc-r8a774a1.c @@ -0,0 +1,6196 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * R8A774A1 processor support - PFC hardware block. + * + * Copyright (C) 2019 Renesas Electronics Corp. + * + * This file is based on the drivers/pinctrl/sh-pfc/pfc-r8a774a1.c + * + * R-Car Gen3 processor support - PFC hardware block. + * + * Copyright (C) 2015 Renesas Electronics Corporation + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <dm/pinctrl.h> +#include <linux/kernel.h> + +#include "sh_pfc.h" + +#define CFG_FLAGS (SH_PFC_PIN_CFG_DRIVE_STRENGTH | \ + SH_PFC_PIN_CFG_PULL_UP | \ + SH_PFC_PIN_CFG_PULL_DOWN) + +#define CPU_ALL_PORT(fn, sfx) \ + PORT_GP_CFG_16(0, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_29(1, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_15(2, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_12(3, fn, sfx, CFG_FLAGS | SH_PFC_PIN_CFG_IO_VOLTAGE), \ + PORT_GP_CFG_1(3, 12, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_1(3, 13, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_1(3, 14, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_1(3, 15, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_18(4, fn, sfx, CFG_FLAGS | SH_PFC_PIN_CFG_IO_VOLTAGE), \ + PORT_GP_CFG_26(5, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_32(6, fn, sfx, CFG_FLAGS), \ + PORT_GP_CFG_4(7, fn, sfx, CFG_FLAGS) +/* + * F_() : just information + * FM() : macro for FN_xxx / xxx_MARK + */ + +/* GPSR0 */ +#define GPSR0_15 F_(D15, IP7_11_8) +#define GPSR0_14 F_(D14, IP7_7_4) +#define GPSR0_13 F_(D13, IP7_3_0) +#define GPSR0_12 F_(D12, IP6_31_28) +#define GPSR0_11 F_(D11, IP6_27_24) +#define GPSR0_10 F_(D10, IP6_23_20) +#define GPSR0_9 F_(D9, IP6_19_16) +#define GPSR0_8 F_(D8, IP6_15_12) +#define GPSR0_7 F_(D7, IP6_11_8) +#define GPSR0_6 F_(D6, IP6_7_4) +#define GPSR0_5 F_(D5, IP6_3_0) +#define GPSR0_4 F_(D4, IP5_31_28) +#define GPSR0_3 F_(D3, IP5_27_24) +#define GPSR0_2 F_(D2, IP5_23_20) +#define GPSR0_1 F_(D1, IP5_19_16) +#define GPSR0_0 F_(D0, IP5_15_12) + +/* GPSR1 */ +#define GPSR1_28 FM(CLKOUT) +#define GPSR1_27 F_(EX_WAIT0_A, IP5_11_8) +#define GPSR1_26 F_(WE1_N, IP5_7_4) +#define GPSR1_25 F_(WE0_N, IP5_3_0) +#define GPSR1_24 F_(RD_WR_N, IP4_31_28) +#define GPSR1_23 F_(RD_N, IP4_27_24) +#define GPSR1_22 F_(BS_N, IP4_23_20) +#define GPSR1_21 F_(CS1_N, IP4_19_16) +#define GPSR1_20 F_(CS0_N, IP4_15_12) +#define GPSR1_19 F_(A19, IP4_11_8) +#define GPSR1_18 F_(A18, IP4_7_4) +#define GPSR1_17 F_(A17, IP4_3_0) +#define GPSR1_16 F_(A16, IP3_31_28) +#define GPSR1_15 F_(A15, IP3_27_24) +#define GPSR1_14 F_(A14, IP3_23_20) +#define GPSR1_13 F_(A13, IP3_19_16) +#define GPSR1_12 F_(A12, IP3_15_12) +#define GPSR1_11 F_(A11, IP3_11_8) +#define GPSR1_10 F_(A10, IP3_7_4) +#define GPSR1_9 F_(A9, IP3_3_0) +#define GPSR1_8 F_(A8, IP2_31_28) +#define GPSR1_7 F_(A7, IP2_27_24) +#define GPSR1_6 F_(A6, IP2_23_20) +#define GPSR1_5 F_(A5, IP2_19_16) +#define GPSR1_4 F_(A4, IP2_15_12) +#define GPSR1_3 F_(A3, IP2_11_8) +#define GPSR1_2 F_(A2, IP2_7_4) +#define GPSR1_1 F_(A1, IP2_3_0) +#define GPSR1_0 F_(A0, IP1_31_28) + +/* GPSR2 */ +#define GPSR2_14 F_(AVB_AVTP_CAPTURE_A, IP0_23_20) +#define GPSR2_13 F_(AVB_AVTP_MATCH_A, IP0_19_16) +#define GPSR2_12 F_(AVB_LINK, IP0_15_12) +#define GPSR2_11 F_(AVB_PHY_INT, IP0_11_8) +#define GPSR2_10 F_(AVB_MAGIC, IP0_7_4) +#define GPSR2_9 F_(AVB_MDC, IP0_3_0) +#define GPSR2_8 F_(PWM2_A, IP1_27_24) +#define GPSR2_7 F_(PWM1_A, IP1_23_20) +#define GPSR2_6 F_(PWM0, IP1_19_16) +#define GPSR2_5 F_(IRQ5, IP1_15_12) +#define GPSR2_4 F_(IRQ4, IP1_11_8) +#define GPSR2_3 F_(IRQ3, IP1_7_4) +#define GPSR2_2 F_(IRQ2, IP1_3_0) +#define GPSR2_1 F_(IRQ1, IP0_31_28) +#define GPSR2_0 F_(IRQ0, IP0_27_24) + +/* GPSR3 */ +#define GPSR3_15 F_(SD1_WP, IP11_23_20) +#define GPSR3_14 F_(SD1_CD, IP11_19_16) +#define GPSR3_13 F_(SD0_WP, IP11_15_12) +#define GPSR3_12 F_(SD0_CD, IP11_11_8) +#define GPSR3_11 F_(SD1_DAT3, IP8_31_28) +#define GPSR3_10 F_(SD1_DAT2, IP8_27_24) +#define GPSR3_9 F_(SD1_DAT1, IP8_23_20) +#define GPSR3_8 F_(SD1_DAT0, IP8_19_16) +#define GPSR3_7 F_(SD1_CMD, IP8_15_12) +#define GPSR3_6 F_(SD1_CLK, IP8_11_8) +#define GPSR3_5 F_(SD0_DAT3, IP8_7_4) +#define GPSR3_4 F_(SD0_DAT2, IP8_3_0) +#define GPSR3_3 F_(SD0_DAT1, IP7_31_28) +#define GPSR3_2 F_(SD0_DAT0, IP7_27_24) +#define GPSR3_1 F_(SD0_CMD, IP7_23_20) +#define GPSR3_0 F_(SD0_CLK, IP7_19_16) + +/* GPSR4 */ +#define GPSR4_17 F_(SD3_DS, IP11_7_4) +#define GPSR4_16 F_(SD3_DAT7, IP11_3_0) +#define GPSR4_15 F_(SD3_DAT6, IP10_31_28) +#define GPSR4_14 F_(SD3_DAT5, IP10_27_24) +#define GPSR4_13 F_(SD3_DAT4, IP10_23_20) +#define GPSR4_12 F_(SD3_DAT3, IP10_19_16) +#define GPSR4_11 F_(SD3_DAT2, IP10_15_12) +#define GPSR4_10 F_(SD3_DAT1, IP10_11_8) +#define GPSR4_9 F_(SD3_DAT0, IP10_7_4) +#define GPSR4_8 F_(SD3_CMD, IP10_3_0) +#define GPSR4_7 F_(SD3_CLK, IP9_31_28) +#define GPSR4_6 F_(SD2_DS, IP9_27_24) +#define GPSR4_5 F_(SD2_DAT3, IP9_23_20) +#define GPSR4_4 F_(SD2_DAT2, IP9_19_16) +#define GPSR4_3 F_(SD2_DAT1, IP9_15_12) +#define GPSR4_2 F_(SD2_DAT0, IP9_11_8) +#define GPSR4_1 F_(SD2_CMD, IP9_7_4) +#define GPSR4_0 F_(SD2_CLK, IP9_3_0) + +/* GPSR5 */ +#define GPSR5_25 F_(MLB_DAT, IP14_19_16) +#define GPSR5_24 F_(MLB_SIG, IP14_15_12) +#define GPSR5_23 F_(MLB_CLK, IP14_11_8) +#define GPSR5_22 FM(MSIOF0_RXD) +#define GPSR5_21 F_(MSIOF0_SS2, IP14_7_4) +#define GPSR5_20 FM(MSIOF0_TXD) +#define GPSR5_19 F_(MSIOF0_SS1, IP14_3_0) +#define GPSR5_18 F_(MSIOF0_SYNC, IP13_31_28) +#define GPSR5_17 FM(MSIOF0_SCK) +#define GPSR5_16 F_(HRTS0_N, IP13_27_24) +#define GPSR5_15 F_(HCTS0_N, IP13_23_20) +#define GPSR5_14 F_(HTX0, IP13_19_16) +#define GPSR5_13 F_(HRX0, IP13_15_12) +#define GPSR5_12 F_(HSCK0, IP13_11_8) +#define GPSR5_11 F_(RX2_A, IP13_7_4) +#define GPSR5_10 F_(TX2_A, IP13_3_0) +#define GPSR5_9 F_(SCK2, IP12_31_28) +#define GPSR5_8 F_(RTS1_N, IP12_27_24) +#define GPSR5_7 F_(CTS1_N, IP12_23_20) +#define GPSR5_6 F_(TX1_A, IP12_19_16) +#define GPSR5_5 F_(RX1_A, IP12_15_12) +#define GPSR5_4 F_(RTS0_N, IP12_11_8) +#define GPSR5_3 F_(CTS0_N, IP12_7_4) +#define GPSR5_2 F_(TX0, IP12_3_0) +#define GPSR5_1 F_(RX0, IP11_31_28) +#define GPSR5_0 F_(SCK0, IP11_27_24) + +/* GPSR6 */ +#define GPSR6_31 F_(GP6_31, IP18_7_4) +#define GPSR6_30 F_(GP6_30, IP18_3_0) +#define GPSR6_29 F_(USB30_OVC, IP17_31_28) +#define GPSR6_28 F_(USB30_PWEN, IP17_27_24) +#define GPSR6_27 F_(USB1_OVC, IP17_23_20) +#define GPSR6_26 F_(USB1_PWEN, IP17_19_16) +#define GPSR6_25 F_(USB0_OVC, IP17_15_12) +#define GPSR6_24 F_(USB0_PWEN, IP17_11_8) +#define GPSR6_23 F_(AUDIO_CLKB_B, IP17_7_4) +#define GPSR6_22 F_(AUDIO_CLKA_A, IP17_3_0) +#define GPSR6_21 F_(SSI_SDATA9_A, IP16_31_28) +#define GPSR6_20 F_(SSI_SDATA8, IP16_27_24) +#define GPSR6_19 F_(SSI_SDATA7, IP16_23_20) +#define GPSR6_18 F_(SSI_WS78, IP16_19_16) +#define GPSR6_17 F_(SSI_SCK78, IP16_15_12) +#define GPSR6_16 F_(SSI_SDATA6, IP16_11_8) +#define GPSR6_15 F_(SSI_WS6, IP16_7_4) +#define GPSR6_14 F_(SSI_SCK6, IP16_3_0) +#define GPSR6_13 FM(SSI_SDATA5) +#define GPSR6_12 FM(SSI_WS5) +#define GPSR6_11 FM(SSI_SCK5) +#define GPSR6_10 F_(SSI_SDATA4, IP15_31_28) +#define GPSR6_9 F_(SSI_WS4, IP15_27_24) +#define GPSR6_8 F_(SSI_SCK4, IP15_23_20) +#define GPSR6_7 F_(SSI_SDATA3, IP15_19_16) +#define GPSR6_6 F_(SSI_WS349, IP15_15_12) +#define GPSR6_5 F_(SSI_SCK349, IP15_11_8) +#define GPSR6_4 F_(SSI_SDATA2_A, IP15_7_4) +#define GPSR6_3 F_(SSI_SDATA1_A, IP15_3_0) +#define GPSR6_2 F_(SSI_SDATA0, IP14_31_28) +#define GPSR6_1 F_(SSI_WS01239, IP14_27_24) +#define GPSR6_0 F_(SSI_SCK01239, IP14_23_20) + +/* GPSR7 */ +#define GPSR7_3 FM(GP7_03) +#define GPSR7_2 FM(GP7_02) +#define GPSR7_1 FM(AVS2) +#define GPSR7_0 FM(AVS1) + + +/* IPSRx */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ /* 8 */ /* 9 */ /* A */ /* B */ /* C - F */ +#define IP0_3_0 FM(AVB_MDC) F_(0, 0) FM(MSIOF2_SS2_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_7_4 FM(AVB_MAGIC) F_(0, 0) FM(MSIOF2_SS1_C) FM(SCK4_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_11_8 FM(AVB_PHY_INT) F_(0, 0) FM(MSIOF2_SYNC_C) FM(RX4_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_15_12 FM(AVB_LINK) F_(0, 0) FM(MSIOF2_SCK_C) FM(TX4_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_19_16 FM(AVB_AVTP_MATCH_A) F_(0, 0) FM(MSIOF2_RXD_C) FM(CTS4_N_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_23_20 FM(AVB_AVTP_CAPTURE_A) F_(0, 0) FM(MSIOF2_TXD_C) FM(RTS4_N_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_27_24 FM(IRQ0) FM(QPOLB) F_(0, 0) FM(DU_CDE) FM(VI4_DATA0_B) FM(CAN0_TX_B) FM(CANFD0_TX_B) FM(MSIOF3_SS2_E) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP0_31_28 FM(IRQ1) FM(QPOLA) F_(0, 0) FM(DU_DISP) FM(VI4_DATA1_B) FM(CAN0_RX_B) FM(CANFD0_RX_B) FM(MSIOF3_SS1_E) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_3_0 FM(IRQ2) FM(QCPV_QDE) F_(0, 0) FM(DU_EXODDF_DU_ODDF_DISP_CDE) FM(VI4_DATA2_B) F_(0, 0) F_(0, 0) FM(MSIOF3_SYNC_E) F_(0, 0) FM(PWM3_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_7_4 FM(IRQ3) FM(QSTVB_QVE) F_(0, 0) FM(DU_DOTCLKOUT1) FM(VI4_DATA3_B) F_(0, 0) F_(0, 0) FM(MSIOF3_SCK_E) F_(0, 0) FM(PWM4_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_11_8 FM(IRQ4) FM(QSTH_QHS) F_(0, 0) FM(DU_EXHSYNC_DU_HSYNC) FM(VI4_DATA4_B) F_(0, 0) F_(0, 0) FM(MSIOF3_RXD_E) F_(0, 0) FM(PWM5_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_15_12 FM(IRQ5) FM(QSTB_QHE) F_(0, 0) FM(DU_EXVSYNC_DU_VSYNC) FM(VI4_DATA5_B) F_(0, 0) F_(0, 0) FM(MSIOF3_TXD_E) F_(0, 0) FM(PWM6_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_19_16 FM(PWM0) FM(AVB_AVTP_PPS)F_(0, 0) F_(0, 0) FM(VI4_DATA6_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(IECLK_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_23_20 FM(PWM1_A) F_(0, 0) F_(0, 0) FM(HRX3_D) FM(VI4_DATA7_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(IERX_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_27_24 FM(PWM2_A) F_(0, 0) F_(0, 0) FM(HTX3_D) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(IETX_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP1_31_28 FM(A0) FM(LCDOUT16) FM(MSIOF3_SYNC_B) F_(0, 0) FM(VI4_DATA8) F_(0, 0) FM(DU_DB0) F_(0, 0) F_(0, 0) FM(PWM3_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_3_0 FM(A1) FM(LCDOUT17) FM(MSIOF3_TXD_B) F_(0, 0) FM(VI4_DATA9) F_(0, 0) FM(DU_DB1) F_(0, 0) F_(0, 0) FM(PWM4_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_7_4 FM(A2) FM(LCDOUT18) FM(MSIOF3_SCK_B) F_(0, 0) FM(VI4_DATA10) F_(0, 0) FM(DU_DB2) F_(0, 0) F_(0, 0) FM(PWM5_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_11_8 FM(A3) FM(LCDOUT19) FM(MSIOF3_RXD_B) F_(0, 0) FM(VI4_DATA11) F_(0, 0) FM(DU_DB3) F_(0, 0) F_(0, 0) FM(PWM6_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_15_12 FM(A4) FM(LCDOUT20) FM(MSIOF3_SS1_B) F_(0, 0) FM(VI4_DATA12) FM(VI5_DATA12) FM(DU_DB4) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_19_16 FM(A5) FM(LCDOUT21) FM(MSIOF3_SS2_B) FM(SCK4_B) FM(VI4_DATA13) FM(VI5_DATA13) FM(DU_DB5) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_23_20 FM(A6) FM(LCDOUT22) FM(MSIOF2_SS1_A) FM(RX4_B) FM(VI4_DATA14) FM(VI5_DATA14) FM(DU_DB6) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_27_24 FM(A7) FM(LCDOUT23) FM(MSIOF2_SS2_A) FM(TX4_B) FM(VI4_DATA15) FM(VI5_DATA15) FM(DU_DB7) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP2_31_28 FM(A8) FM(RX3_B) FM(MSIOF2_SYNC_A) FM(HRX4_B) F_(0, 0) F_(0, 0) F_(0, 0) FM(SDA6_A) FM(AVB_AVTP_MATCH_B) FM(PWM1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_3_0 FM(A9) F_(0, 0) FM(MSIOF2_SCK_A) FM(CTS4_N_B) F_(0, 0) FM(VI5_VSYNC_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_7_4 FM(A10) F_(0, 0) FM(MSIOF2_RXD_A) FM(RTS4_N_B) F_(0, 0) FM(VI5_HSYNC_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_11_8 FM(A11) FM(TX3_B) FM(MSIOF2_TXD_A) FM(HTX4_B) FM(HSCK4) FM(VI5_FIELD) F_(0, 0) FM(SCL6_A) FM(AVB_AVTP_CAPTURE_B) FM(PWM2_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) + +/* IPSRx */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ /* 8 */ /* 9 */ /* A */ /* B */ /* C - F */ +#define IP3_15_12 FM(A12) FM(LCDOUT12) FM(MSIOF3_SCK_C) F_(0, 0) FM(HRX4_A) FM(VI5_DATA8) FM(DU_DG4) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_19_16 FM(A13) FM(LCDOUT13) FM(MSIOF3_SYNC_C) F_(0, 0) FM(HTX4_A) FM(VI5_DATA9) FM(DU_DG5) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_23_20 FM(A14) FM(LCDOUT14) FM(MSIOF3_RXD_C) F_(0, 0) FM(HCTS4_N) FM(VI5_DATA10) FM(DU_DG6) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_27_24 FM(A15) FM(LCDOUT15) FM(MSIOF3_TXD_C) F_(0, 0) FM(HRTS4_N) FM(VI5_DATA11) FM(DU_DG7) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP3_31_28 FM(A16) FM(LCDOUT8) F_(0, 0) F_(0, 0) FM(VI4_FIELD) F_(0, 0) FM(DU_DG0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_3_0 FM(A17) FM(LCDOUT9) F_(0, 0) F_(0, 0) FM(VI4_VSYNC_N) F_(0, 0) FM(DU_DG1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_7_4 FM(A18) FM(LCDOUT10) F_(0, 0) F_(0, 0) FM(VI4_HSYNC_N) F_(0, 0) FM(DU_DG2) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_11_8 FM(A19) FM(LCDOUT11) F_(0, 0) F_(0, 0) FM(VI4_CLKENB) F_(0, 0) FM(DU_DG3) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_15_12 FM(CS0_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(VI5_CLKENB) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_19_16 FM(CS1_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(VI5_CLK) F_(0, 0) FM(EX_WAIT0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_23_20 FM(BS_N) FM(QSTVA_QVS) FM(MSIOF3_SCK_D) FM(SCK3) FM(HSCK3) F_(0, 0) F_(0, 0) F_(0, 0) FM(CAN1_TX) FM(CANFD1_TX) FM(IETX_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_27_24 FM(RD_N) F_(0, 0) FM(MSIOF3_SYNC_D) FM(RX3_A) FM(HRX3_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(CAN0_TX_A) FM(CANFD0_TX_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP4_31_28 FM(RD_WR_N) F_(0, 0) FM(MSIOF3_RXD_D) FM(TX3_A) FM(HTX3_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(CAN0_RX_A) FM(CANFD0_RX_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_3_0 FM(WE0_N) F_(0, 0) FM(MSIOF3_TXD_D) FM(CTS3_N) FM(HCTS3_N) F_(0, 0) F_(0, 0) FM(SCL6_B) FM(CAN_CLK) F_(0, 0) FM(IECLK_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_7_4 FM(WE1_N) F_(0, 0) FM(MSIOF3_SS1_D) FM(RTS3_N) FM(HRTS3_N) F_(0, 0) F_(0, 0) FM(SDA6_B) FM(CAN1_RX) FM(CANFD1_RX) FM(IERX_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_11_8 FM(EX_WAIT0_A) FM(QCLK) F_(0, 0) F_(0, 0) FM(VI4_CLK) F_(0, 0) FM(DU_DOTCLKOUT0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_15_12 FM(D0) FM(MSIOF2_SS1_B)FM(MSIOF3_SCK_A) F_(0, 0) FM(VI4_DATA16) FM(VI5_DATA0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_19_16 FM(D1) FM(MSIOF2_SS2_B)FM(MSIOF3_SYNC_A) F_(0, 0) FM(VI4_DATA17) FM(VI5_DATA1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_23_20 FM(D2) F_(0, 0) FM(MSIOF3_RXD_A) F_(0, 0) FM(VI4_DATA18) FM(VI5_DATA2) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_27_24 FM(D3) F_(0, 0) FM(MSIOF3_TXD_A) F_(0, 0) FM(VI4_DATA19) FM(VI5_DATA3) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP5_31_28 FM(D4) FM(MSIOF2_SCK_B)F_(0, 0) F_(0, 0) FM(VI4_DATA20) FM(VI5_DATA4) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_3_0 FM(D5) FM(MSIOF2_SYNC_B)F_(0, 0) F_(0, 0) FM(VI4_DATA21) FM(VI5_DATA5) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_7_4 FM(D6) FM(MSIOF2_RXD_B)F_(0, 0) F_(0, 0) FM(VI4_DATA22) FM(VI5_DATA6) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_11_8 FM(D7) FM(MSIOF2_TXD_B)F_(0, 0) F_(0, 0) FM(VI4_DATA23) FM(VI5_DATA7) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_15_12 FM(D8) FM(LCDOUT0) FM(MSIOF2_SCK_D) FM(SCK4_C) FM(VI4_DATA0_A) F_(0, 0) FM(DU_DR0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_19_16 FM(D9) FM(LCDOUT1) FM(MSIOF2_SYNC_D) F_(0, 0) FM(VI4_DATA1_A) F_(0, 0) FM(DU_DR1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_23_20 FM(D10) FM(LCDOUT2) FM(MSIOF2_RXD_D) FM(HRX3_B) FM(VI4_DATA2_A) FM(CTS4_N_C) FM(DU_DR2) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_27_24 FM(D11) FM(LCDOUT3) FM(MSIOF2_TXD_D) FM(HTX3_B) FM(VI4_DATA3_A) FM(RTS4_N_C) FM(DU_DR3) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP6_31_28 FM(D12) FM(LCDOUT4) FM(MSIOF2_SS1_D) FM(RX4_C) FM(VI4_DATA4_A) F_(0, 0) FM(DU_DR4) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) + +/* IPSRx */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ /* 8 */ /* 9 */ /* A */ /* B */ /* C - F */ +#define IP7_3_0 FM(D13) FM(LCDOUT5) FM(MSIOF2_SS2_D) FM(TX4_C) FM(VI4_DATA5_A) F_(0, 0) FM(DU_DR5) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP7_7_4 FM(D14) FM(LCDOUT6) FM(MSIOF3_SS1_A) FM(HRX3_C) FM(VI4_DATA6_A) F_(0, 0) FM(DU_DR6) FM(SCL6_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP7_11_8 FM(D15) FM(LCDOUT7) FM(MSIOF3_SS2_A) FM(HTX3_C) FM(VI4_DATA7_A) F_(0, 0) FM(DU_DR7) FM(SDA6_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP7_19_16 FM(SD0_CLK) F_(0, 0) FM(MSIOF1_SCK_E) F_(0, 0) F_(0, 0) F_(0, 0) FM(STP_OPWM_0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP7_23_20 FM(SD0_CMD) F_(0, 0) FM(MSIOF1_SYNC_E) F_(0, 0) F_(0, 0) F_(0, 0) FM(STP_IVCXO27_0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP7_27_24 FM(SD0_DAT0) F_(0, 0) FM(MSIOF1_RXD_E) F_(0, 0) F_(0, 0) FM(TS_SCK0_B) FM(STP_ISCLK_0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP7_31_28 FM(SD0_DAT1) F_(0, 0) FM(MSIOF1_TXD_E) F_(0, 0) F_(0, 0) FM(TS_SPSYNC0_B)FM(STP_ISSYNC_0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_3_0 FM(SD0_DAT2) F_(0, 0) FM(MSIOF1_SS1_E) F_(0, 0) F_(0, 0) FM(TS_SDAT0_B) FM(STP_ISD_0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_7_4 FM(SD0_DAT3) F_(0, 0) FM(MSIOF1_SS2_E) F_(0, 0) F_(0, 0) FM(TS_SDEN0_B) FM(STP_ISEN_0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_11_8 FM(SD1_CLK) F_(0, 0) FM(MSIOF1_SCK_G) F_(0, 0) F_(0, 0) FM(SIM0_CLK_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_15_12 FM(SD1_CMD) F_(0, 0) FM(MSIOF1_SYNC_G) FM(NFCE_N_B) F_(0, 0) FM(SIM0_D_A) FM(STP_IVCXO27_1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_19_16 FM(SD1_DAT0) FM(SD2_DAT4) FM(MSIOF1_RXD_G) FM(NFWP_N_B) F_(0, 0) FM(TS_SCK1_B) FM(STP_ISCLK_1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_23_20 FM(SD1_DAT1) FM(SD2_DAT5) FM(MSIOF1_TXD_G) FM(NFDATA14_B) F_(0, 0) FM(TS_SPSYNC1_B)FM(STP_ISSYNC_1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_27_24 FM(SD1_DAT2) FM(SD2_DAT6) FM(MSIOF1_SS1_G) FM(NFDATA15_B) F_(0, 0) FM(TS_SDAT1_B) FM(STP_ISD_1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP8_31_28 FM(SD1_DAT3) FM(SD2_DAT7) FM(MSIOF1_SS2_G) FM(NFRB_N_B) F_(0, 0) FM(TS_SDEN1_B) FM(STP_ISEN_1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_3_0 FM(SD2_CLK) F_(0, 0) FM(NFDATA8) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_7_4 FM(SD2_CMD) F_(0, 0) FM(NFDATA9) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_11_8 FM(SD2_DAT0) F_(0, 0) FM(NFDATA10) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_15_12 FM(SD2_DAT1) F_(0, 0) FM(NFDATA11) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_19_16 FM(SD2_DAT2) F_(0, 0) FM(NFDATA12) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_23_20 FM(SD2_DAT3) F_(0, 0) FM(NFDATA13) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_27_24 FM(SD2_DS) F_(0, 0) FM(NFALE) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP9_31_28 FM(SD3_CLK) F_(0, 0) FM(NFWE_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_3_0 FM(SD3_CMD) F_(0, 0) FM(NFRE_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_7_4 FM(SD3_DAT0) F_(0, 0) FM(NFDATA0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_11_8 FM(SD3_DAT1) F_(0, 0) FM(NFDATA1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_15_12 FM(SD3_DAT2) F_(0, 0) FM(NFDATA2) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_19_16 FM(SD3_DAT3) F_(0, 0) FM(NFDATA3) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_23_20 FM(SD3_DAT4) FM(SD2_CD_A) FM(NFDATA4) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_27_24 FM(SD3_DAT5) FM(SD2_WP_A) FM(NFDATA5) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP10_31_28 FM(SD3_DAT6) FM(SD3_CD) FM(NFDATA6) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_3_0 FM(SD3_DAT7) FM(SD3_WP) FM(NFDATA7) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_7_4 FM(SD3_DS) F_(0, 0) FM(NFCLE) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_11_8 FM(SD0_CD) F_(0, 0) FM(NFDATA14_A) F_(0, 0) FM(SCL2_B) FM(SIM0_RST_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) + +/* IPSRx */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ /* 8 */ /* 9 */ /* A */ /* B */ /* C - F */ +#define IP11_15_12 FM(SD0_WP) F_(0, 0) FM(NFDATA15_A) F_(0, 0) FM(SDA2_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_19_16 FM(SD1_CD) F_(0, 0) FM(NFRB_N_A) F_(0, 0) F_(0, 0) FM(SIM0_CLK_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_23_20 FM(SD1_WP) F_(0, 0) FM(NFCE_N_A) F_(0, 0) F_(0, 0) FM(SIM0_D_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_27_24 FM(SCK0) FM(HSCK1_B) FM(MSIOF1_SS2_B) FM(AUDIO_CLKC_B) FM(SDA2_A) FM(SIM0_RST_B) FM(STP_OPWM_0_C) FM(RIF0_CLK_B) F_(0, 0) FM(ADICHS2) FM(SCK5_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP11_31_28 FM(RX0) FM(HRX1_B) F_(0, 0) F_(0, 0) F_(0, 0) FM(TS_SCK0_C) FM(STP_ISCLK_0_C) FM(RIF0_D0_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_3_0 FM(TX0) FM(HTX1_B) F_(0, 0) F_(0, 0) F_(0, 0) FM(TS_SPSYNC0_C)FM(STP_ISSYNC_0_C) FM(RIF0_D1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_7_4 FM(CTS0_N) FM(HCTS1_N_B) FM(MSIOF1_SYNC_B) F_(0, 0) F_(0, 0) FM(TS_SPSYNC1_C)FM(STP_ISSYNC_1_C) FM(RIF1_SYNC_B) FM(AUDIO_CLKOUT_C) FM(ADICS_SAMP) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_11_8 FM(RTS0_N) FM(HRTS1_N_B) FM(MSIOF1_SS1_B) FM(AUDIO_CLKA_B) FM(SCL2_A) F_(0, 0) FM(STP_IVCXO27_1_C) FM(RIF0_SYNC_B) F_(0, 0) FM(ADICHS1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_15_12 FM(RX1_A) FM(HRX1_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(TS_SDAT0_C) FM(STP_ISD_0_C) FM(RIF1_CLK_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_19_16 FM(TX1_A) FM(HTX1_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(TS_SDEN0_C) FM(STP_ISEN_0_C) FM(RIF1_D0_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_23_20 FM(CTS1_N) FM(HCTS1_N_A) FM(MSIOF1_RXD_B) F_(0, 0) F_(0, 0) FM(TS_SDEN1_C) FM(STP_ISEN_1_C) FM(RIF1_D0_B) F_(0, 0) FM(ADIDATA) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_27_24 FM(RTS1_N) FM(HRTS1_N_A) FM(MSIOF1_TXD_B) F_(0, 0) F_(0, 0) FM(TS_SDAT1_C) FM(STP_ISD_1_C) FM(RIF1_D1_B) F_(0, 0) FM(ADICHS0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP12_31_28 FM(SCK2) FM(SCIF_CLK_B) FM(MSIOF1_SCK_B) F_(0, 0) F_(0, 0) FM(TS_SCK1_C) FM(STP_ISCLK_1_C) FM(RIF1_CLK_B) F_(0, 0) FM(ADICLK) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_3_0 FM(TX2_A) F_(0, 0) F_(0, 0) FM(SD2_CD_B) FM(SCL1_A) F_(0, 0) FM(FMCLK_A) FM(RIF1_D1_C) F_(0, 0) FM(FSO_CFE_0_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_7_4 FM(RX2_A) F_(0, 0) F_(0, 0) FM(SD2_WP_B) FM(SDA1_A) F_(0, 0) FM(FMIN_A) FM(RIF1_SYNC_C) F_(0, 0) FM(FSO_CFE_1_N) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_11_8 FM(HSCK0) F_(0, 0) FM(MSIOF1_SCK_D) FM(AUDIO_CLKB_A) FM(SSI_SDATA1_B)FM(TS_SCK0_D) FM(STP_ISCLK_0_D) FM(RIF0_CLK_C) F_(0, 0) F_(0, 0) FM(RX5_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_15_12 FM(HRX0) F_(0, 0) FM(MSIOF1_RXD_D) F_(0, 0) FM(SSI_SDATA2_B)FM(TS_SDEN0_D) FM(STP_ISEN_0_D) FM(RIF0_D0_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_19_16 FM(HTX0) F_(0, 0) FM(MSIOF1_TXD_D) F_(0, 0) FM(SSI_SDATA9_B)FM(TS_SDAT0_D) FM(STP_ISD_0_D) FM(RIF0_D1_C) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_23_20 FM(HCTS0_N) FM(RX2_B) FM(MSIOF1_SYNC_D) F_(0, 0) FM(SSI_SCK9_A) FM(TS_SPSYNC0_D)FM(STP_ISSYNC_0_D) FM(RIF0_SYNC_C) FM(AUDIO_CLKOUT1_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_27_24 FM(HRTS0_N) FM(TX2_B) FM(MSIOF1_SS1_D) F_(0, 0) FM(SSI_WS9_A) F_(0, 0) FM(STP_IVCXO27_0_D) FM(BPFCLK_A) FM(AUDIO_CLKOUT2_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP13_31_28 FM(MSIOF0_SYNC) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(AUDIO_CLKOUT_A) F_(0, 0) FM(TX5_B) F_(0, 0) F_(0, 0) FM(BPFCLK_D) F_(0, 0) F_(0, 0) +#define IP14_3_0 FM(MSIOF0_SS1) FM(RX5_A) FM(NFWP_N_A) FM(AUDIO_CLKA_C) FM(SSI_SCK2_A) F_(0, 0) FM(STP_IVCXO27_0_C) F_(0, 0) FM(AUDIO_CLKOUT3_A) F_(0, 0) FM(TCLK1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP14_7_4 FM(MSIOF0_SS2) FM(TX5_A) FM(MSIOF1_SS2_D) FM(AUDIO_CLKC_A) FM(SSI_WS2_A) F_(0, 0) FM(STP_OPWM_0_D) F_(0, 0) FM(AUDIO_CLKOUT_D) F_(0, 0) FM(SPEEDIN_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP14_11_8 FM(MLB_CLK) F_(0, 0) FM(MSIOF1_SCK_F) F_(0, 0) FM(SCL1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP14_15_12 FM(MLB_SIG) FM(RX1_B) FM(MSIOF1_SYNC_F) F_(0, 0) FM(SDA1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP14_19_16 FM(MLB_DAT) FM(TX1_B) FM(MSIOF1_RXD_F) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP14_23_20 FM(SSI_SCK01239) F_(0, 0) FM(MSIOF1_TXD_F) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP14_27_24 FM(SSI_WS01239) F_(0, 0) FM(MSIOF1_SS1_F) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) + +/* IPSRx */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ /* 8 */ /* 9 */ /* A */ /* B */ /* C - F */ +#define IP14_31_28 FM(SSI_SDATA0) F_(0, 0) FM(MSIOF1_SS2_F) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_3_0 FM(SSI_SDATA1_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_7_4 FM(SSI_SDATA2_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(SSI_SCK1_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_11_8 FM(SSI_SCK349) F_(0, 0) FM(MSIOF1_SS1_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(STP_OPWM_0_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_15_12 FM(SSI_WS349) FM(HCTS2_N_A) FM(MSIOF1_SS2_A) F_(0, 0) F_(0, 0) F_(0, 0) FM(STP_IVCXO27_0_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_19_16 FM(SSI_SDATA3) FM(HRTS2_N_A) FM(MSIOF1_TXD_A) F_(0, 0) F_(0, 0) FM(TS_SCK0_A) FM(STP_ISCLK_0_A) FM(RIF0_D1_A) FM(RIF2_D0_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_23_20 FM(SSI_SCK4) FM(HRX2_A) FM(MSIOF1_SCK_A) F_(0, 0) F_(0, 0) FM(TS_SDAT0_A) FM(STP_ISD_0_A) FM(RIF0_CLK_A) FM(RIF2_CLK_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_27_24 FM(SSI_WS4) FM(HTX2_A) FM(MSIOF1_SYNC_A) F_(0, 0) F_(0, 0) FM(TS_SDEN0_A) FM(STP_ISEN_0_A) FM(RIF0_SYNC_A) FM(RIF2_SYNC_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP15_31_28 FM(SSI_SDATA4) FM(HSCK2_A) FM(MSIOF1_RXD_A) F_(0, 0) F_(0, 0) FM(TS_SPSYNC0_A)FM(STP_ISSYNC_0_A) FM(RIF0_D0_A) FM(RIF2_D1_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_3_0 FM(SSI_SCK6) F_(0, 0) F_(0, 0) FM(SIM0_RST_D) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_7_4 FM(SSI_WS6) F_(0, 0) F_(0, 0) FM(SIM0_D_D) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_11_8 FM(SSI_SDATA6) F_(0, 0) F_(0, 0) FM(SIM0_CLK_D) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(SATA_DEVSLP_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_15_12 FM(SSI_SCK78) FM(HRX2_B) FM(MSIOF1_SCK_C) F_(0, 0) F_(0, 0) FM(TS_SCK1_A) FM(STP_ISCLK_1_A) FM(RIF1_CLK_A) FM(RIF3_CLK_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_19_16 FM(SSI_WS78) FM(HTX2_B) FM(MSIOF1_SYNC_C) F_(0, 0) F_(0, 0) FM(TS_SDAT1_A) FM(STP_ISD_1_A) FM(RIF1_SYNC_A) FM(RIF3_SYNC_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_23_20 FM(SSI_SDATA7) FM(HCTS2_N_B) FM(MSIOF1_RXD_C) F_(0, 0) F_(0, 0) FM(TS_SDEN1_A) FM(STP_ISEN_1_A) FM(RIF1_D0_A) FM(RIF3_D0_A) F_(0, 0) FM(TCLK2_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_27_24 FM(SSI_SDATA8) FM(HRTS2_N_B) FM(MSIOF1_TXD_C) F_(0, 0) F_(0, 0) FM(TS_SPSYNC1_A)FM(STP_ISSYNC_1_A) FM(RIF1_D1_A) FM(RIF3_D1_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP16_31_28 FM(SSI_SDATA9_A) FM(HSCK2_B) FM(MSIOF1_SS1_C) FM(HSCK1_A) FM(SSI_WS1_B) FM(SCK1) FM(STP_IVCXO27_1_A) FM(SCK5_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP17_3_0 FM(AUDIO_CLKA_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP17_7_4 FM(AUDIO_CLKB_B) FM(SCIF_CLK_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(STP_IVCXO27_1_D) FM(REMOCON_A) F_(0, 0) F_(0, 0) FM(TCLK1_A) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP17_11_8 FM(USB0_PWEN) F_(0, 0) F_(0, 0) FM(SIM0_RST_C) F_(0, 0) FM(TS_SCK1_D) FM(STP_ISCLK_1_D) FM(BPFCLK_B) FM(RIF3_CLK_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(HSCK2_C) F_(0, 0) F_(0, 0) +#define IP17_15_12 FM(USB0_OVC) F_(0, 0) F_(0, 0) FM(SIM0_D_C) F_(0, 0) FM(TS_SDAT1_D) FM(STP_ISD_1_D) F_(0, 0) FM(RIF3_SYNC_B) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) FM(HRX2_C) F_(0, 0) F_(0, 0) +#define IP17_19_16 FM(USB1_PWEN) F_(0, 0) F_(0, 0) FM(SIM0_CLK_C) FM(SSI_SCK1_A) FM(TS_SCK0_E) FM(STP_ISCLK_0_E) FM(FMCLK_B) FM(RIF2_CLK_B) F_(0, 0) FM(SPEEDIN_A) F_(0, 0) F_(0, 0) FM(HTX2_C) F_(0, 0) F_(0, 0) +#define IP17_23_20 FM(USB1_OVC) F_(0, 0) FM(MSIOF1_SS2_C) F_(0, 0) FM(SSI_WS1_A) FM(TS_SDAT0_E) FM(STP_ISD_0_E) FM(FMIN_B) FM(RIF2_SYNC_B) F_(0, 0) FM(REMOCON_B) F_(0, 0) F_(0, 0) FM(HCTS2_N_C) F_(0, 0) F_(0, 0) +#define IP17_27_24 FM(USB30_PWEN) F_(0, 0) F_(0, 0) FM(AUDIO_CLKOUT_B) FM(SSI_SCK2_B) FM(TS_SDEN1_D) FM(STP_ISEN_1_D) FM(STP_OPWM_0_E)FM(RIF3_D0_B) F_(0, 0) FM(TCLK2_B) FM(TPU0TO0) FM(BPFCLK_C) FM(HRTS2_N_C) F_(0, 0) F_(0, 0) +#define IP17_31_28 FM(USB30_OVC) F_(0, 0) F_(0, 0) FM(AUDIO_CLKOUT1_B) FM(SSI_WS2_B) FM(TS_SPSYNC1_D)FM(STP_ISSYNC_1_D) FM(STP_IVCXO27_0_E)FM(RIF3_D1_B) F_(0, 0) FM(FSO_TOE_N) FM(TPU0TO1) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define IP18_3_0 FM(GP6_30) F_(0, 0) F_(0, 0) FM(AUDIO_CLKOUT2_B) FM(SSI_SCK9_B) FM(TS_SDEN0_E) FM(STP_ISEN_0_E) F_(0, 0) FM(RIF2_D0_B) F_(0, 0) F_(0, 0) FM(TPU0TO2) FM(FMCLK_C) FM(FMCLK_D) F_(0, 0) F_(0, 0) +#define IP18_7_4 FM(GP6_31) F_(0, 0) F_(0, 0) FM(AUDIO_CLKOUT3_B) FM(SSI_WS9_B) FM(TS_SPSYNC0_E)FM(STP_ISSYNC_0_E) F_(0, 0) FM(RIF2_D1_B) F_(0, 0) F_(0, 0) FM(TPU0TO3) FM(FMIN_C) FM(FMIN_D) F_(0, 0) F_(0, 0) + +#define PINMUX_GPSR \ +\ + GPSR6_31 \ + GPSR6_30 \ + GPSR6_29 \ + GPSR1_28 GPSR6_28 \ + GPSR1_27 GPSR6_27 \ + GPSR1_26 GPSR6_26 \ + GPSR1_25 GPSR5_25 GPSR6_25 \ + GPSR1_24 GPSR5_24 GPSR6_24 \ + GPSR1_23 GPSR5_23 GPSR6_23 \ + GPSR1_22 GPSR5_22 GPSR6_22 \ + GPSR1_21 GPSR5_21 GPSR6_21 \ + GPSR1_20 GPSR5_20 GPSR6_20 \ + GPSR1_19 GPSR5_19 GPSR6_19 \ + GPSR1_18 GPSR5_18 GPSR6_18 \ + GPSR1_17 GPSR4_17 GPSR5_17 GPSR6_17 \ + GPSR1_16 GPSR4_16 GPSR5_16 GPSR6_16 \ +GPSR0_15 GPSR1_15 GPSR3_15 GPSR4_15 GPSR5_15 GPSR6_15 \ +GPSR0_14 GPSR1_14 GPSR2_14 GPSR3_14 GPSR4_14 GPSR5_14 GPSR6_14 \ +GPSR0_13 GPSR1_13 GPSR2_13 GPSR3_13 GPSR4_13 GPSR5_13 GPSR6_13 \ +GPSR0_12 GPSR1_12 GPSR2_12 GPSR3_12 GPSR4_12 GPSR5_12 GPSR6_12 \ +GPSR0_11 GPSR1_11 GPSR2_11 GPSR3_11 GPSR4_11 GPSR5_11 GPSR6_11 \ +GPSR0_10 GPSR1_10 GPSR2_10 GPSR3_10 GPSR4_10 GPSR5_10 GPSR6_10 \ +GPSR0_9 GPSR1_9 GPSR2_9 GPSR3_9 GPSR4_9 GPSR5_9 GPSR6_9 \ +GPSR0_8 GPSR1_8 GPSR2_8 GPSR3_8 GPSR4_8 GPSR5_8 GPSR6_8 \ +GPSR0_7 GPSR1_7 GPSR2_7 GPSR3_7 GPSR4_7 GPSR5_7 GPSR6_7 \ +GPSR0_6 GPSR1_6 GPSR2_6 GPSR3_6 GPSR4_6 GPSR5_6 GPSR6_6 \ +GPSR0_5 GPSR1_5 GPSR2_5 GPSR3_5 GPSR4_5 GPSR5_5 GPSR6_5 \ +GPSR0_4 GPSR1_4 GPSR2_4 GPSR3_4 GPSR4_4 GPSR5_4 GPSR6_4 \ +GPSR0_3 GPSR1_3 GPSR2_3 GPSR3_3 GPSR4_3 GPSR5_3 GPSR6_3 GPSR7_3 \ +GPSR0_2 GPSR1_2 GPSR2_2 GPSR3_2 GPSR4_2 GPSR5_2 GPSR6_2 GPSR7_2 \ +GPSR0_1 GPSR1_1 GPSR2_1 GPSR3_1 GPSR4_1 GPSR5_1 GPSR6_1 GPSR7_1 \ +GPSR0_0 GPSR1_0 GPSR2_0 GPSR3_0 GPSR4_0 GPSR5_0 GPSR6_0 GPSR7_0 + +#define PINMUX_IPSR \ +\ +FM(IP0_3_0) IP0_3_0 FM(IP1_3_0) IP1_3_0 FM(IP2_3_0) IP2_3_0 FM(IP3_3_0) IP3_3_0 \ +FM(IP0_7_4) IP0_7_4 FM(IP1_7_4) IP1_7_4 FM(IP2_7_4) IP2_7_4 FM(IP3_7_4) IP3_7_4 \ +FM(IP0_11_8) IP0_11_8 FM(IP1_11_8) IP1_11_8 FM(IP2_11_8) IP2_11_8 FM(IP3_11_8) IP3_11_8 \ +FM(IP0_15_12) IP0_15_12 FM(IP1_15_12) IP1_15_12 FM(IP2_15_12) IP2_15_12 FM(IP3_15_12) IP3_15_12 \ +FM(IP0_19_16) IP0_19_16 FM(IP1_19_16) IP1_19_16 FM(IP2_19_16) IP2_19_16 FM(IP3_19_16) IP3_19_16 \ +FM(IP0_23_20) IP0_23_20 FM(IP1_23_20) IP1_23_20 FM(IP2_23_20) IP2_23_20 FM(IP3_23_20) IP3_23_20 \ +FM(IP0_27_24) IP0_27_24 FM(IP1_27_24) IP1_27_24 FM(IP2_27_24) IP2_27_24 FM(IP3_27_24) IP3_27_24 \ +FM(IP0_31_28) IP0_31_28 FM(IP1_31_28) IP1_31_28 FM(IP2_31_28) IP2_31_28 FM(IP3_31_28) IP3_31_28 \ +\ +FM(IP4_3_0) IP4_3_0 FM(IP5_3_0) IP5_3_0 FM(IP6_3_0) IP6_3_0 FM(IP7_3_0) IP7_3_0 \ +FM(IP4_7_4) IP4_7_4 FM(IP5_7_4) IP5_7_4 FM(IP6_7_4) IP6_7_4 FM(IP7_7_4) IP7_7_4 \ +FM(IP4_11_8) IP4_11_8 FM(IP5_11_8) IP5_11_8 FM(IP6_11_8) IP6_11_8 FM(IP7_11_8) IP7_11_8 \ +FM(IP4_15_12) IP4_15_12 FM(IP5_15_12) IP5_15_12 FM(IP6_15_12) IP6_15_12 \ +FM(IP4_19_16) IP4_19_16 FM(IP5_19_16) IP5_19_16 FM(IP6_19_16) IP6_19_16 FM(IP7_19_16) IP7_19_16 \ +FM(IP4_23_20) IP4_23_20 FM(IP5_23_20) IP5_23_20 FM(IP6_23_20) IP6_23_20 FM(IP7_23_20) IP7_23_20 \ +FM(IP4_27_24) IP4_27_24 FM(IP5_27_24) IP5_27_24 FM(IP6_27_24) IP6_27_24 FM(IP7_27_24) IP7_27_24 \ +FM(IP4_31_28) IP4_31_28 FM(IP5_31_28) IP5_31_28 FM(IP6_31_28) IP6_31_28 FM(IP7_31_28) IP7_31_28 \ +\ +FM(IP8_3_0) IP8_3_0 FM(IP9_3_0) IP9_3_0 FM(IP10_3_0) IP10_3_0 FM(IP11_3_0) IP11_3_0 \ +FM(IP8_7_4) IP8_7_4 FM(IP9_7_4) IP9_7_4 FM(IP10_7_4) IP10_7_4 FM(IP11_7_4) IP11_7_4 \ +FM(IP8_11_8) IP8_11_8 FM(IP9_11_8) IP9_11_8 FM(IP10_11_8) IP10_11_8 FM(IP11_11_8) IP11_11_8 \ +FM(IP8_15_12) IP8_15_12 FM(IP9_15_12) IP9_15_12 FM(IP10_15_12) IP10_15_12 FM(IP11_15_12) IP11_15_12 \ +FM(IP8_19_16) IP8_19_16 FM(IP9_19_16) IP9_19_16 FM(IP10_19_16) IP10_19_16 FM(IP11_19_16) IP11_19_16 \ +FM(IP8_23_20) IP8_23_20 FM(IP9_23_20) IP9_23_20 FM(IP10_23_20) IP10_23_20 FM(IP11_23_20) IP11_23_20 \ +FM(IP8_27_24) IP8_27_24 FM(IP9_27_24) IP9_27_24 FM(IP10_27_24) IP10_27_24 FM(IP11_27_24) IP11_27_24 \ +FM(IP8_31_28) IP8_31_28 FM(IP9_31_28) IP9_31_28 FM(IP10_31_28) IP10_31_28 FM(IP11_31_28) IP11_31_28 \ +\ +FM(IP12_3_0) IP12_3_0 FM(IP13_3_0) IP13_3_0 FM(IP14_3_0) IP14_3_0 FM(IP15_3_0) IP15_3_0 \ +FM(IP12_7_4) IP12_7_4 FM(IP13_7_4) IP13_7_4 FM(IP14_7_4) IP14_7_4 FM(IP15_7_4) IP15_7_4 \ +FM(IP12_11_8) IP12_11_8 FM(IP13_11_8) IP13_11_8 FM(IP14_11_8) IP14_11_8 FM(IP15_11_8) IP15_11_8 \ +FM(IP12_15_12) IP12_15_12 FM(IP13_15_12) IP13_15_12 FM(IP14_15_12) IP14_15_12 FM(IP15_15_12) IP15_15_12 \ +FM(IP12_19_16) IP12_19_16 FM(IP13_19_16) IP13_19_16 FM(IP14_19_16) IP14_19_16 FM(IP15_19_16) IP15_19_16 \ +FM(IP12_23_20) IP12_23_20 FM(IP13_23_20) IP13_23_20 FM(IP14_23_20) IP14_23_20 FM(IP15_23_20) IP15_23_20 \ +FM(IP12_27_24) IP12_27_24 FM(IP13_27_24) IP13_27_24 FM(IP14_27_24) IP14_27_24 FM(IP15_27_24) IP15_27_24 \ +FM(IP12_31_28) IP12_31_28 FM(IP13_31_28) IP13_31_28 FM(IP14_31_28) IP14_31_28 FM(IP15_31_28) IP15_31_28 \ +\ +FM(IP16_3_0) IP16_3_0 FM(IP17_3_0) IP17_3_0 FM(IP18_3_0) IP18_3_0 \ +FM(IP16_7_4) IP16_7_4 FM(IP17_7_4) IP17_7_4 FM(IP18_7_4) IP18_7_4 \ +FM(IP16_11_8) IP16_11_8 FM(IP17_11_8) IP17_11_8 \ +FM(IP16_15_12) IP16_15_12 FM(IP17_15_12) IP17_15_12 \ +FM(IP16_19_16) IP16_19_16 FM(IP17_19_16) IP17_19_16 \ +FM(IP16_23_20) IP16_23_20 FM(IP17_23_20) IP17_23_20 \ +FM(IP16_27_24) IP16_27_24 FM(IP17_27_24) IP17_27_24 \ +FM(IP16_31_28) IP16_31_28 FM(IP17_31_28) IP17_31_28 + +/* MOD_SEL0 */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ +#define MOD_SEL0_31_30_29 FM(SEL_MSIOF3_0) FM(SEL_MSIOF3_1) FM(SEL_MSIOF3_2) FM(SEL_MSIOF3_3) FM(SEL_MSIOF3_4) F_(0, 0) F_(0, 0) F_(0, 0) +#define MOD_SEL0_28_27 FM(SEL_MSIOF2_0) FM(SEL_MSIOF2_1) FM(SEL_MSIOF2_2) FM(SEL_MSIOF2_3) +#define MOD_SEL0_26_25_24 FM(SEL_MSIOF1_0) FM(SEL_MSIOF1_1) FM(SEL_MSIOF1_2) FM(SEL_MSIOF1_3) FM(SEL_MSIOF1_4) FM(SEL_MSIOF1_5) FM(SEL_MSIOF1_6) F_(0, 0) +#define MOD_SEL0_23 FM(SEL_LBSC_0) FM(SEL_LBSC_1) +#define MOD_SEL0_22 FM(SEL_IEBUS_0) FM(SEL_IEBUS_1) +#define MOD_SEL0_21 FM(SEL_I2C2_0) FM(SEL_I2C2_1) +#define MOD_SEL0_20 FM(SEL_I2C1_0) FM(SEL_I2C1_1) +#define MOD_SEL0_19 FM(SEL_HSCIF4_0) FM(SEL_HSCIF4_1) +#define MOD_SEL0_18_17 FM(SEL_HSCIF3_0) FM(SEL_HSCIF3_1) FM(SEL_HSCIF3_2) FM(SEL_HSCIF3_3) +#define MOD_SEL0_16 FM(SEL_HSCIF1_0) FM(SEL_HSCIF1_1) +#define MOD_SEL0_14_13 FM(SEL_HSCIF2_0) FM(SEL_HSCIF2_1) FM(SEL_HSCIF2_2) F_(0, 0) +#define MOD_SEL0_12 FM(SEL_ETHERAVB_0) FM(SEL_ETHERAVB_1) +#define MOD_SEL0_11 FM(SEL_DRIF3_0) FM(SEL_DRIF3_1) +#define MOD_SEL0_10 FM(SEL_DRIF2_0) FM(SEL_DRIF2_1) +#define MOD_SEL0_9_8 FM(SEL_DRIF1_0) FM(SEL_DRIF1_1) FM(SEL_DRIF1_2) F_(0, 0) +#define MOD_SEL0_7_6 FM(SEL_DRIF0_0) FM(SEL_DRIF0_1) FM(SEL_DRIF0_2) F_(0, 0) +#define MOD_SEL0_5 FM(SEL_CANFD0_0) FM(SEL_CANFD0_1) +#define MOD_SEL0_4_3 FM(SEL_ADGA_0) FM(SEL_ADGA_1) FM(SEL_ADGA_2) FM(SEL_ADGA_3) + +/* MOD_SEL1 */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ +#define MOD_SEL1_31_30 FM(SEL_TSIF1_0) FM(SEL_TSIF1_1) FM(SEL_TSIF1_2) FM(SEL_TSIF1_3) +#define MOD_SEL1_29_28_27 FM(SEL_TSIF0_0) FM(SEL_TSIF0_1) FM(SEL_TSIF0_2) FM(SEL_TSIF0_3) FM(SEL_TSIF0_4) F_(0, 0) F_(0, 0) F_(0, 0) +#define MOD_SEL1_26 FM(SEL_TIMER_TMU_0) FM(SEL_TIMER_TMU_1) +#define MOD_SEL1_25_24 FM(SEL_SSP1_1_0) FM(SEL_SSP1_1_1) FM(SEL_SSP1_1_2) FM(SEL_SSP1_1_3) +#define MOD_SEL1_23_22_21 FM(SEL_SSP1_0_0) FM(SEL_SSP1_0_1) FM(SEL_SSP1_0_2) FM(SEL_SSP1_0_3) FM(SEL_SSP1_0_4) F_(0, 0) F_(0, 0) F_(0, 0) +#define MOD_SEL1_20 FM(SEL_SSI1_0) FM(SEL_SSI1_1) +#define MOD_SEL1_19 FM(SEL_SPEED_PULSE_0) FM(SEL_SPEED_PULSE_1) +#define MOD_SEL1_18_17 FM(SEL_SIMCARD_0) FM(SEL_SIMCARD_1) FM(SEL_SIMCARD_2) FM(SEL_SIMCARD_3) +#define MOD_SEL1_16 FM(SEL_SDHI2_0) FM(SEL_SDHI2_1) +#define MOD_SEL1_15_14 FM(SEL_SCIF4_0) FM(SEL_SCIF4_1) FM(SEL_SCIF4_2) F_(0, 0) +#define MOD_SEL1_13 FM(SEL_SCIF3_0) FM(SEL_SCIF3_1) +#define MOD_SEL1_12 FM(SEL_SCIF2_0) FM(SEL_SCIF2_1) +#define MOD_SEL1_11 FM(SEL_SCIF1_0) FM(SEL_SCIF1_1) +#define MOD_SEL1_10 FM(SEL_SCIF_0) FM(SEL_SCIF_1) +#define MOD_SEL1_9 FM(SEL_REMOCON_0) FM(SEL_REMOCON_1) +#define MOD_SEL1_6 FM(SEL_RCAN0_0) FM(SEL_RCAN0_1) +#define MOD_SEL1_5 FM(SEL_PWM6_0) FM(SEL_PWM6_1) +#define MOD_SEL1_4 FM(SEL_PWM5_0) FM(SEL_PWM5_1) +#define MOD_SEL1_3 FM(SEL_PWM4_0) FM(SEL_PWM4_1) +#define MOD_SEL1_2 FM(SEL_PWM3_0) FM(SEL_PWM3_1) +#define MOD_SEL1_1 FM(SEL_PWM2_0) FM(SEL_PWM2_1) +#define MOD_SEL1_0 FM(SEL_PWM1_0) FM(SEL_PWM1_1) + +/* MOD_SEL2 */ /* 0 */ /* 1 */ /* 2 */ /* 3 */ /* 4 */ /* 5 */ /* 6 */ /* 7 */ +#define MOD_SEL2_31 FM(I2C_SEL_5_0) FM(I2C_SEL_5_1) +#define MOD_SEL2_30 FM(I2C_SEL_3_0) FM(I2C_SEL_3_1) +#define MOD_SEL2_29 FM(I2C_SEL_0_0) FM(I2C_SEL_0_1) +#define MOD_SEL2_28_27 FM(SEL_FM_0) FM(SEL_FM_1) FM(SEL_FM_2) FM(SEL_FM_3) +#define MOD_SEL2_26 FM(SEL_SCIF5_0) FM(SEL_SCIF5_1) +#define MOD_SEL2_25_24_23 FM(SEL_I2C6_0) FM(SEL_I2C6_1) FM(SEL_I2C6_2) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) F_(0, 0) +#define MOD_SEL2_22 FM(SEL_NDF_0) FM(SEL_NDF_1) +#define MOD_SEL2_21 FM(SEL_SSI2_0) FM(SEL_SSI2_1) +#define MOD_SEL2_20 FM(SEL_SSI9_0) FM(SEL_SSI9_1) +#define MOD_SEL2_19 FM(SEL_TIMER_TMU2_0) FM(SEL_TIMER_TMU2_1) +#define MOD_SEL2_18 FM(SEL_ADGB_0) FM(SEL_ADGB_1) +#define MOD_SEL2_17 FM(SEL_ADGC_0) FM(SEL_ADGC_1) +#define MOD_SEL2_0 FM(SEL_VIN4_0) FM(SEL_VIN4_1) + +#define PINMUX_MOD_SELS \ +\ +MOD_SEL0_31_30_29 MOD_SEL1_31_30 MOD_SEL2_31 \ + MOD_SEL2_30 \ + MOD_SEL1_29_28_27 MOD_SEL2_29 \ +MOD_SEL0_28_27 MOD_SEL2_28_27 \ +MOD_SEL0_26_25_24 MOD_SEL1_26 MOD_SEL2_26 \ + MOD_SEL1_25_24 MOD_SEL2_25_24_23 \ +MOD_SEL0_23 MOD_SEL1_23_22_21 \ +MOD_SEL0_22 MOD_SEL2_22 \ +MOD_SEL0_21 MOD_SEL2_21 \ +MOD_SEL0_20 MOD_SEL1_20 MOD_SEL2_20 \ +MOD_SEL0_19 MOD_SEL1_19 MOD_SEL2_19 \ +MOD_SEL0_18_17 MOD_SEL1_18_17 MOD_SEL2_18 \ + MOD_SEL2_17 \ +MOD_SEL0_16 MOD_SEL1_16 \ + MOD_SEL1_15_14 \ +MOD_SEL0_14_13 \ + MOD_SEL1_13 \ +MOD_SEL0_12 MOD_SEL1_12 \ +MOD_SEL0_11 MOD_SEL1_11 \ +MOD_SEL0_10 MOD_SEL1_10 \ +MOD_SEL0_9_8 MOD_SEL1_9 \ +MOD_SEL0_7_6 \ + MOD_SEL1_6 \ +MOD_SEL0_5 MOD_SEL1_5 \ +MOD_SEL0_4_3 MOD_SEL1_4 \ + MOD_SEL1_3 \ + MOD_SEL1_2 \ + MOD_SEL1_1 \ + MOD_SEL1_0 MOD_SEL2_0 + +/* + * These pins are not able to be muxed but have other properties + * that can be set, such as drive-strength or pull-up/pull-down enable. + */ +#define PINMUX_STATIC \ + FM(QSPI0_SPCLK) FM(QSPI0_SSL) FM(QSPI0_MOSI_IO0) FM(QSPI0_MISO_IO1) \ + FM(QSPI0_IO2) FM(QSPI0_IO3) \ + FM(QSPI1_SPCLK) FM(QSPI1_SSL) FM(QSPI1_MOSI_IO0) FM(QSPI1_MISO_IO1) \ + FM(QSPI1_IO2) FM(QSPI1_IO3) \ + FM(RPC_INT) FM(RPC_WP) FM(RPC_RESET) \ + FM(AVB_TX_CTL) FM(AVB_TXC) FM(AVB_TD0) FM(AVB_TD1) FM(AVB_TD2) FM(AVB_TD3) \ + FM(AVB_RX_CTL) FM(AVB_RXC) FM(AVB_RD0) FM(AVB_RD1) FM(AVB_RD2) FM(AVB_RD3) \ + FM(AVB_TXCREFCLK) FM(AVB_MDIO) \ + FM(PRESETOUT) \ + FM(DU_DOTCLKIN0) FM(DU_DOTCLKIN1) FM(DU_DOTCLKIN2) \ + FM(TMS) FM(TDO) FM(ASEBRK) FM(MLB_REF) FM(TDI) FM(TCK) FM(TRST) FM(EXTALR) + +enum { + PINMUX_RESERVED = 0, + + PINMUX_DATA_BEGIN, + GP_ALL(DATA), + PINMUX_DATA_END, + +#define F_(x, y) +#define FM(x) FN_##x, + PINMUX_FUNCTION_BEGIN, + GP_ALL(FN), + PINMUX_GPSR + PINMUX_IPSR + PINMUX_MOD_SELS + PINMUX_FUNCTION_END, +#undef F_ +#undef FM + +#define F_(x, y) +#define FM(x) x##_MARK, + PINMUX_MARK_BEGIN, + PINMUX_GPSR + PINMUX_IPSR + PINMUX_MOD_SELS + PINMUX_STATIC + PINMUX_MARK_END, +#undef F_ +#undef FM +}; + +static const u16 pinmux_data[] = { + PINMUX_DATA_GP_ALL(), + + PINMUX_SINGLE(AVS1), + PINMUX_SINGLE(AVS2), + PINMUX_SINGLE(CLKOUT), + PINMUX_SINGLE(GP7_03), + PINMUX_SINGLE(GP7_02), + PINMUX_SINGLE(MSIOF0_RXD), + PINMUX_SINGLE(MSIOF0_SCK), + PINMUX_SINGLE(MSIOF0_TXD), + PINMUX_SINGLE(SSI_SCK5), + PINMUX_SINGLE(SSI_SDATA5), + PINMUX_SINGLE(SSI_WS5), + + /* IPSR0 */ + PINMUX_IPSR_GPSR(IP0_3_0, AVB_MDC), + PINMUX_IPSR_MSEL(IP0_3_0, MSIOF2_SS2_C, SEL_MSIOF2_2), + + PINMUX_IPSR_GPSR(IP0_7_4, AVB_MAGIC), + PINMUX_IPSR_MSEL(IP0_7_4, MSIOF2_SS1_C, SEL_MSIOF2_2), + PINMUX_IPSR_MSEL(IP0_7_4, SCK4_A, SEL_SCIF4_0), + + PINMUX_IPSR_GPSR(IP0_11_8, AVB_PHY_INT), + PINMUX_IPSR_MSEL(IP0_11_8, MSIOF2_SYNC_C, SEL_MSIOF2_2), + PINMUX_IPSR_MSEL(IP0_11_8, RX4_A, SEL_SCIF4_0), + + PINMUX_IPSR_GPSR(IP0_15_12, AVB_LINK), + PINMUX_IPSR_MSEL(IP0_15_12, MSIOF2_SCK_C, SEL_MSIOF2_2), + PINMUX_IPSR_MSEL(IP0_15_12, TX4_A, SEL_SCIF4_0), + + PINMUX_IPSR_MSEL(IP0_19_16, AVB_AVTP_MATCH_A, SEL_ETHERAVB_0), + PINMUX_IPSR_MSEL(IP0_19_16, MSIOF2_RXD_C, SEL_MSIOF2_2), + PINMUX_IPSR_MSEL(IP0_19_16, CTS4_N_A, SEL_SCIF4_0), + + PINMUX_IPSR_MSEL(IP0_23_20, AVB_AVTP_CAPTURE_A, SEL_ETHERAVB_0), + PINMUX_IPSR_MSEL(IP0_23_20, MSIOF2_TXD_C, SEL_MSIOF2_2), + PINMUX_IPSR_MSEL(IP0_23_20, RTS4_N_A, SEL_SCIF4_0), + + PINMUX_IPSR_GPSR(IP0_27_24, IRQ0), + PINMUX_IPSR_GPSR(IP0_27_24, QPOLB), + PINMUX_IPSR_GPSR(IP0_27_24, DU_CDE), + PINMUX_IPSR_MSEL(IP0_27_24, VI4_DATA0_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP0_27_24, CAN0_TX_B, SEL_RCAN0_1), + PINMUX_IPSR_MSEL(IP0_27_24, CANFD0_TX_B, SEL_CANFD0_1), + PINMUX_IPSR_MSEL(IP0_27_24, MSIOF3_SS2_E, SEL_MSIOF3_4), + + PINMUX_IPSR_GPSR(IP0_31_28, IRQ1), + PINMUX_IPSR_GPSR(IP0_31_28, QPOLA), + PINMUX_IPSR_GPSR(IP0_31_28, DU_DISP), + PINMUX_IPSR_MSEL(IP0_31_28, VI4_DATA1_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP0_31_28, CAN0_RX_B, SEL_RCAN0_1), + PINMUX_IPSR_MSEL(IP0_31_28, CANFD0_RX_B, SEL_CANFD0_1), + PINMUX_IPSR_MSEL(IP0_31_28, MSIOF3_SS1_E, SEL_MSIOF3_4), + + /* IPSR1 */ + PINMUX_IPSR_GPSR(IP1_3_0, IRQ2), + PINMUX_IPSR_GPSR(IP1_3_0, QCPV_QDE), + PINMUX_IPSR_GPSR(IP1_3_0, DU_EXODDF_DU_ODDF_DISP_CDE), + PINMUX_IPSR_MSEL(IP1_3_0, VI4_DATA2_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP1_3_0, PWM3_B, SEL_PWM3_1), + PINMUX_IPSR_MSEL(IP1_3_0, MSIOF3_SYNC_E, SEL_MSIOF3_4), + + PINMUX_IPSR_GPSR(IP1_7_4, IRQ3), + PINMUX_IPSR_GPSR(IP1_7_4, QSTVB_QVE), + PINMUX_IPSR_GPSR(IP1_7_4, DU_DOTCLKOUT1), + PINMUX_IPSR_MSEL(IP1_7_4, VI4_DATA3_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP1_7_4, PWM4_B, SEL_PWM4_1), + PINMUX_IPSR_MSEL(IP1_7_4, MSIOF3_SCK_E, SEL_MSIOF3_4), + + PINMUX_IPSR_GPSR(IP1_11_8, IRQ4), + PINMUX_IPSR_GPSR(IP1_11_8, QSTH_QHS), + PINMUX_IPSR_GPSR(IP1_11_8, DU_EXHSYNC_DU_HSYNC), + PINMUX_IPSR_MSEL(IP1_11_8, VI4_DATA4_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP1_11_8, PWM5_B, SEL_PWM5_1), + PINMUX_IPSR_MSEL(IP1_11_8, MSIOF3_RXD_E, SEL_MSIOF3_4), + + PINMUX_IPSR_GPSR(IP1_15_12, IRQ5), + PINMUX_IPSR_GPSR(IP1_15_12, QSTB_QHE), + PINMUX_IPSR_GPSR(IP1_15_12, DU_EXVSYNC_DU_VSYNC), + PINMUX_IPSR_MSEL(IP1_15_12, VI4_DATA5_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP1_15_12, PWM6_B, SEL_PWM6_1), + PINMUX_IPSR_MSEL(IP1_15_12, MSIOF3_TXD_E, SEL_MSIOF3_4), + + PINMUX_IPSR_GPSR(IP1_19_16, PWM0), + PINMUX_IPSR_GPSR(IP1_19_16, AVB_AVTP_PPS), + PINMUX_IPSR_MSEL(IP1_19_16, VI4_DATA6_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP1_19_16, IECLK_B, SEL_IEBUS_1), + + PINMUX_IPSR_MSEL(IP1_23_20, PWM1_A, SEL_PWM1_0), + PINMUX_IPSR_MSEL(IP1_23_20, HRX3_D, SEL_HSCIF3_3), + PINMUX_IPSR_MSEL(IP1_23_20, VI4_DATA7_B, SEL_VIN4_1), + PINMUX_IPSR_MSEL(IP1_23_20, IERX_B, SEL_IEBUS_1), + + PINMUX_IPSR_MSEL(IP1_27_24, PWM2_A, SEL_PWM2_0), + PINMUX_IPSR_MSEL(IP1_27_24, HTX3_D, SEL_HSCIF3_3), + PINMUX_IPSR_MSEL(IP1_27_24, IETX_B, SEL_IEBUS_1), + + PINMUX_IPSR_GPSR(IP1_31_28, A0), + PINMUX_IPSR_GPSR(IP1_31_28, LCDOUT16), + PINMUX_IPSR_MSEL(IP1_31_28, MSIOF3_SYNC_B, SEL_MSIOF3_1), + PINMUX_IPSR_GPSR(IP1_31_28, VI4_DATA8), + PINMUX_IPSR_GPSR(IP1_31_28, DU_DB0), + PINMUX_IPSR_MSEL(IP1_31_28, PWM3_A, SEL_PWM3_0), + + /* IPSR2 */ + PINMUX_IPSR_GPSR(IP2_3_0, A1), + PINMUX_IPSR_GPSR(IP2_3_0, LCDOUT17), + PINMUX_IPSR_MSEL(IP2_3_0, MSIOF3_TXD_B, SEL_MSIOF3_1), + PINMUX_IPSR_GPSR(IP2_3_0, VI4_DATA9), + PINMUX_IPSR_GPSR(IP2_3_0, DU_DB1), + PINMUX_IPSR_MSEL(IP2_3_0, PWM4_A, SEL_PWM4_0), + + PINMUX_IPSR_GPSR(IP2_7_4, A2), + PINMUX_IPSR_GPSR(IP2_7_4, LCDOUT18), + PINMUX_IPSR_MSEL(IP2_7_4, MSIOF3_SCK_B, SEL_MSIOF3_1), + PINMUX_IPSR_GPSR(IP2_7_4, VI4_DATA10), + PINMUX_IPSR_GPSR(IP2_7_4, DU_DB2), + PINMUX_IPSR_MSEL(IP2_7_4, PWM5_A, SEL_PWM5_0), + + PINMUX_IPSR_GPSR(IP2_11_8, A3), + PINMUX_IPSR_GPSR(IP2_11_8, LCDOUT19), + PINMUX_IPSR_MSEL(IP2_11_8, MSIOF3_RXD_B, SEL_MSIOF3_1), + PINMUX_IPSR_GPSR(IP2_11_8, VI4_DATA11), + PINMUX_IPSR_GPSR(IP2_11_8, DU_DB3), + PINMUX_IPSR_MSEL(IP2_11_8, PWM6_A, SEL_PWM6_0), + + PINMUX_IPSR_GPSR(IP2_15_12, A4), + PINMUX_IPSR_GPSR(IP2_15_12, LCDOUT20), + PINMUX_IPSR_MSEL(IP2_15_12, MSIOF3_SS1_B, SEL_MSIOF3_1), + PINMUX_IPSR_GPSR(IP2_15_12, VI4_DATA12), + PINMUX_IPSR_GPSR(IP2_15_12, VI5_DATA12), + PINMUX_IPSR_GPSR(IP2_15_12, DU_DB4), + + PINMUX_IPSR_GPSR(IP2_19_16, A5), + PINMUX_IPSR_GPSR(IP2_19_16, LCDOUT21), + PINMUX_IPSR_MSEL(IP2_19_16, MSIOF3_SS2_B, SEL_MSIOF3_1), + PINMUX_IPSR_MSEL(IP2_19_16, SCK4_B, SEL_SCIF4_1), + PINMUX_IPSR_GPSR(IP2_19_16, VI4_DATA13), + PINMUX_IPSR_GPSR(IP2_19_16, VI5_DATA13), + PINMUX_IPSR_GPSR(IP2_19_16, DU_DB5), + + PINMUX_IPSR_GPSR(IP2_23_20, A6), + PINMUX_IPSR_GPSR(IP2_23_20, LCDOUT22), + PINMUX_IPSR_MSEL(IP2_23_20, MSIOF2_SS1_A, SEL_MSIOF2_0), + PINMUX_IPSR_MSEL(IP2_23_20, RX4_B, SEL_SCIF4_1), + PINMUX_IPSR_GPSR(IP2_23_20, VI4_DATA14), + PINMUX_IPSR_GPSR(IP2_23_20, VI5_DATA14), + PINMUX_IPSR_GPSR(IP2_23_20, DU_DB6), + + PINMUX_IPSR_GPSR(IP2_27_24, A7), + PINMUX_IPSR_GPSR(IP2_27_24, LCDOUT23), + PINMUX_IPSR_MSEL(IP2_27_24, MSIOF2_SS2_A, SEL_MSIOF2_0), + PINMUX_IPSR_MSEL(IP2_27_24, TX4_B, SEL_SCIF4_1), + PINMUX_IPSR_GPSR(IP2_27_24, VI4_DATA15), + PINMUX_IPSR_GPSR(IP2_27_24, VI5_DATA15), + PINMUX_IPSR_GPSR(IP2_27_24, DU_DB7), + + PINMUX_IPSR_GPSR(IP2_31_28, A8), + PINMUX_IPSR_MSEL(IP2_31_28, RX3_B, SEL_SCIF3_1), + PINMUX_IPSR_MSEL(IP2_31_28, MSIOF2_SYNC_A, SEL_MSIOF2_0), + PINMUX_IPSR_MSEL(IP2_31_28, HRX4_B, SEL_HSCIF4_1), + PINMUX_IPSR_MSEL(IP2_31_28, SDA6_A, SEL_I2C6_0), + PINMUX_IPSR_MSEL(IP2_31_28, AVB_AVTP_MATCH_B, SEL_ETHERAVB_1), + PINMUX_IPSR_MSEL(IP2_31_28, PWM1_B, SEL_PWM1_1), + + /* IPSR3 */ + PINMUX_IPSR_GPSR(IP3_3_0, A9), + PINMUX_IPSR_MSEL(IP3_3_0, MSIOF2_SCK_A, SEL_MSIOF2_0), + PINMUX_IPSR_MSEL(IP3_3_0, CTS4_N_B, SEL_SCIF4_1), + PINMUX_IPSR_GPSR(IP3_3_0, VI5_VSYNC_N), + + PINMUX_IPSR_GPSR(IP3_7_4, A10), + PINMUX_IPSR_MSEL(IP3_7_4, MSIOF2_RXD_A, SEL_MSIOF2_0), + PINMUX_IPSR_MSEL(IP3_7_4, RTS4_N_B, SEL_SCIF4_1), + PINMUX_IPSR_GPSR(IP3_7_4, VI5_HSYNC_N), + + PINMUX_IPSR_GPSR(IP3_11_8, A11), + PINMUX_IPSR_MSEL(IP3_11_8, TX3_B, SEL_SCIF3_1), + PINMUX_IPSR_MSEL(IP3_11_8, MSIOF2_TXD_A, SEL_MSIOF2_0), + PINMUX_IPSR_MSEL(IP3_11_8, HTX4_B, SEL_HSCIF4_1), + PINMUX_IPSR_GPSR(IP3_11_8, HSCK4), + PINMUX_IPSR_GPSR(IP3_11_8, VI5_FIELD), + PINMUX_IPSR_MSEL(IP3_11_8, SCL6_A, SEL_I2C6_0), + PINMUX_IPSR_MSEL(IP3_11_8, AVB_AVTP_CAPTURE_B, SEL_ETHERAVB_1), + PINMUX_IPSR_MSEL(IP3_11_8, PWM2_B, SEL_PWM2_1), + + PINMUX_IPSR_GPSR(IP3_15_12, A12), + PINMUX_IPSR_GPSR(IP3_15_12, LCDOUT12), + PINMUX_IPSR_MSEL(IP3_15_12, MSIOF3_SCK_C, SEL_MSIOF3_2), + PINMUX_IPSR_MSEL(IP3_15_12, HRX4_A, SEL_HSCIF4_0), + PINMUX_IPSR_GPSR(IP3_15_12, VI5_DATA8), + PINMUX_IPSR_GPSR(IP3_15_12, DU_DG4), + + PINMUX_IPSR_GPSR(IP3_19_16, A13), + PINMUX_IPSR_GPSR(IP3_19_16, LCDOUT13), + PINMUX_IPSR_MSEL(IP3_19_16, MSIOF3_SYNC_C, SEL_MSIOF3_2), + PINMUX_IPSR_MSEL(IP3_19_16, HTX4_A, SEL_HSCIF4_0), + PINMUX_IPSR_GPSR(IP3_19_16, VI5_DATA9), + PINMUX_IPSR_GPSR(IP3_19_16, DU_DG5), + + PINMUX_IPSR_GPSR(IP3_23_20, A14), + PINMUX_IPSR_GPSR(IP3_23_20, LCDOUT14), + PINMUX_IPSR_MSEL(IP3_23_20, MSIOF3_RXD_C, SEL_MSIOF3_2), + PINMUX_IPSR_GPSR(IP3_23_20, HCTS4_N), + PINMUX_IPSR_GPSR(IP3_23_20, VI5_DATA10), + PINMUX_IPSR_GPSR(IP3_23_20, DU_DG6), + + PINMUX_IPSR_GPSR(IP3_27_24, A15), + PINMUX_IPSR_GPSR(IP3_27_24, LCDOUT15), + PINMUX_IPSR_MSEL(IP3_27_24, MSIOF3_TXD_C, SEL_MSIOF3_2), + PINMUX_IPSR_GPSR(IP3_27_24, HRTS4_N), + PINMUX_IPSR_GPSR(IP3_27_24, VI5_DATA11), + PINMUX_IPSR_GPSR(IP3_27_24, DU_DG7), + + PINMUX_IPSR_GPSR(IP3_31_28, A16), + PINMUX_IPSR_GPSR(IP3_31_28, LCDOUT8), + PINMUX_IPSR_GPSR(IP3_31_28, VI4_FIELD), + PINMUX_IPSR_GPSR(IP3_31_28, DU_DG0), + + /* IPSR4 */ + PINMUX_IPSR_GPSR(IP4_3_0, A17), + PINMUX_IPSR_GPSR(IP4_3_0, LCDOUT9), + PINMUX_IPSR_GPSR(IP4_3_0, VI4_VSYNC_N), + PINMUX_IPSR_GPSR(IP4_3_0, DU_DG1), + + PINMUX_IPSR_GPSR(IP4_7_4, A18), + PINMUX_IPSR_GPSR(IP4_7_4, LCDOUT10), + PINMUX_IPSR_GPSR(IP4_7_4, VI4_HSYNC_N), + PINMUX_IPSR_GPSR(IP4_7_4, DU_DG2), + + PINMUX_IPSR_GPSR(IP4_11_8, A19), + PINMUX_IPSR_GPSR(IP4_11_8, LCDOUT11), + PINMUX_IPSR_GPSR(IP4_11_8, VI4_CLKENB), + PINMUX_IPSR_GPSR(IP4_11_8, DU_DG3), + + PINMUX_IPSR_GPSR(IP4_15_12, CS0_N), + PINMUX_IPSR_GPSR(IP4_15_12, VI5_CLKENB), + + PINMUX_IPSR_GPSR(IP4_19_16, CS1_N), + PINMUX_IPSR_GPSR(IP4_19_16, VI5_CLK), + PINMUX_IPSR_MSEL(IP4_19_16, EX_WAIT0_B, SEL_LBSC_1), + + PINMUX_IPSR_GPSR(IP4_23_20, BS_N), + PINMUX_IPSR_GPSR(IP4_23_20, QSTVA_QVS), + PINMUX_IPSR_MSEL(IP4_23_20, MSIOF3_SCK_D, SEL_MSIOF3_3), + PINMUX_IPSR_GPSR(IP4_23_20, SCK3), + PINMUX_IPSR_GPSR(IP4_23_20, HSCK3), + PINMUX_IPSR_GPSR(IP4_23_20, CAN1_TX), + PINMUX_IPSR_GPSR(IP4_23_20, CANFD1_TX), + PINMUX_IPSR_MSEL(IP4_23_20, IETX_A, SEL_IEBUS_0), + + PINMUX_IPSR_GPSR(IP4_27_24, RD_N), + PINMUX_IPSR_MSEL(IP4_27_24, MSIOF3_SYNC_D, SEL_MSIOF3_3), + PINMUX_IPSR_MSEL(IP4_27_24, RX3_A, SEL_SCIF3_0), + PINMUX_IPSR_MSEL(IP4_27_24, HRX3_A, SEL_HSCIF3_0), + PINMUX_IPSR_MSEL(IP4_27_24, CAN0_TX_A, SEL_RCAN0_0), + PINMUX_IPSR_MSEL(IP4_27_24, CANFD0_TX_A, SEL_CANFD0_0), + + PINMUX_IPSR_GPSR(IP4_31_28, RD_WR_N), + PINMUX_IPSR_MSEL(IP4_31_28, MSIOF3_RXD_D, SEL_MSIOF3_3), + PINMUX_IPSR_MSEL(IP4_31_28, TX3_A, SEL_SCIF3_0), + PINMUX_IPSR_MSEL(IP4_31_28, HTX3_A, SEL_HSCIF3_0), + PINMUX_IPSR_MSEL(IP4_31_28, CAN0_RX_A, SEL_RCAN0_0), + PINMUX_IPSR_MSEL(IP4_31_28, CANFD0_RX_A, SEL_CANFD0_0), + + /* IPSR5 */ + PINMUX_IPSR_GPSR(IP5_3_0, WE0_N), + PINMUX_IPSR_MSEL(IP5_3_0, MSIOF3_TXD_D, SEL_MSIOF3_3), + PINMUX_IPSR_GPSR(IP5_3_0, CTS3_N), + PINMUX_IPSR_GPSR(IP5_3_0, HCTS3_N), + PINMUX_IPSR_MSEL(IP5_3_0, SCL6_B, SEL_I2C6_1), + PINMUX_IPSR_GPSR(IP5_3_0, CAN_CLK), + PINMUX_IPSR_MSEL(IP5_3_0, IECLK_A, SEL_IEBUS_0), + + PINMUX_IPSR_GPSR(IP5_7_4, WE1_N), + PINMUX_IPSR_MSEL(IP5_7_4, MSIOF3_SS1_D, SEL_MSIOF3_3), + PINMUX_IPSR_GPSR(IP5_7_4, RTS3_N), + PINMUX_IPSR_GPSR(IP5_7_4, HRTS3_N), + PINMUX_IPSR_MSEL(IP5_7_4, SDA6_B, SEL_I2C6_1), + PINMUX_IPSR_GPSR(IP5_7_4, CAN1_RX), + PINMUX_IPSR_GPSR(IP5_7_4, CANFD1_RX), + PINMUX_IPSR_MSEL(IP5_7_4, IERX_A, SEL_IEBUS_0), + + PINMUX_IPSR_MSEL(IP5_11_8, EX_WAIT0_A, SEL_LBSC_0), + PINMUX_IPSR_GPSR(IP5_11_8, QCLK), + PINMUX_IPSR_GPSR(IP5_11_8, VI4_CLK), + PINMUX_IPSR_GPSR(IP5_11_8, DU_DOTCLKOUT0), + + PINMUX_IPSR_GPSR(IP5_15_12, D0), + PINMUX_IPSR_MSEL(IP5_15_12, MSIOF2_SS1_B, SEL_MSIOF2_1), + PINMUX_IPSR_MSEL(IP5_15_12, MSIOF3_SCK_A, SEL_MSIOF3_0), + PINMUX_IPSR_GPSR(IP5_15_12, VI4_DATA16), + PINMUX_IPSR_GPSR(IP5_15_12, VI5_DATA0), + + PINMUX_IPSR_GPSR(IP5_19_16, D1), + PINMUX_IPSR_MSEL(IP5_19_16, MSIOF2_SS2_B, SEL_MSIOF2_1), + PINMUX_IPSR_MSEL(IP5_19_16, MSIOF3_SYNC_A, SEL_MSIOF3_0), + PINMUX_IPSR_GPSR(IP5_19_16, VI4_DATA17), + PINMUX_IPSR_GPSR(IP5_19_16, VI5_DATA1), + + PINMUX_IPSR_GPSR(IP5_23_20, D2), + PINMUX_IPSR_MSEL(IP5_23_20, MSIOF3_RXD_A, SEL_MSIOF3_0), + PINMUX_IPSR_GPSR(IP5_23_20, VI4_DATA18), + PINMUX_IPSR_GPSR(IP5_23_20, VI5_DATA2), + + PINMUX_IPSR_GPSR(IP5_27_24, D3), + PINMUX_IPSR_MSEL(IP5_27_24, MSIOF3_TXD_A, SEL_MSIOF3_0), + PINMUX_IPSR_GPSR(IP5_27_24, VI4_DATA19), + PINMUX_IPSR_GPSR(IP5_27_24, VI5_DATA3), + + PINMUX_IPSR_GPSR(IP5_31_28, D4), + PINMUX_IPSR_MSEL(IP5_31_28, MSIOF2_SCK_B, SEL_MSIOF2_1), + PINMUX_IPSR_GPSR(IP5_31_28, VI4_DATA20), + PINMUX_IPSR_GPSR(IP5_31_28, VI5_DATA4), + + /* IPSR6 */ + PINMUX_IPSR_GPSR(IP6_3_0, D5), + PINMUX_IPSR_MSEL(IP6_3_0, MSIOF2_SYNC_B, SEL_MSIOF2_1), + PINMUX_IPSR_GPSR(IP6_3_0, VI4_DATA21), + PINMUX_IPSR_GPSR(IP6_3_0, VI5_DATA5), + + PINMUX_IPSR_GPSR(IP6_7_4, D6), + PINMUX_IPSR_MSEL(IP6_7_4, MSIOF2_RXD_B, SEL_MSIOF2_1), + PINMUX_IPSR_GPSR(IP6_7_4, VI4_DATA22), + PINMUX_IPSR_GPSR(IP6_7_4, VI5_DATA6), + + PINMUX_IPSR_GPSR(IP6_11_8, D7), + PINMUX_IPSR_MSEL(IP6_11_8, MSIOF2_TXD_B, SEL_MSIOF2_1), + PINMUX_IPSR_GPSR(IP6_11_8, VI4_DATA23), + PINMUX_IPSR_GPSR(IP6_11_8, VI5_DATA7), + + PINMUX_IPSR_GPSR(IP6_15_12, D8), + PINMUX_IPSR_GPSR(IP6_15_12, LCDOUT0), + PINMUX_IPSR_MSEL(IP6_15_12, MSIOF2_SCK_D, SEL_MSIOF2_3), + PINMUX_IPSR_MSEL(IP6_15_12, SCK4_C, SEL_SCIF4_2), + PINMUX_IPSR_MSEL(IP6_15_12, VI4_DATA0_A, SEL_VIN4_0), + PINMUX_IPSR_GPSR(IP6_15_12, DU_DR0), + + PINMUX_IPSR_GPSR(IP6_19_16, D9), + PINMUX_IPSR_GPSR(IP6_19_16, LCDOUT1), + PINMUX_IPSR_MSEL(IP6_19_16, MSIOF2_SYNC_D, SEL_MSIOF2_3), + PINMUX_IPSR_MSEL(IP6_19_16, VI4_DATA1_A, SEL_VIN4_0), + PINMUX_IPSR_GPSR(IP6_19_16, DU_DR1), + + PINMUX_IPSR_GPSR(IP6_23_20, D10), + PINMUX_IPSR_GPSR(IP6_23_20, LCDOUT2), + PINMUX_IPSR_MSEL(IP6_23_20, MSIOF2_RXD_D, SEL_MSIOF2_3), + PINMUX_IPSR_MSEL(IP6_23_20, HRX3_B, SEL_HSCIF3_1), + PINMUX_IPSR_MSEL(IP6_23_20, VI4_DATA2_A, SEL_VIN4_0), + PINMUX_IPSR_MSEL(IP6_23_20, CTS4_N_C, SEL_SCIF4_2), + PINMUX_IPSR_GPSR(IP6_23_20, DU_DR2), + + PINMUX_IPSR_GPSR(IP6_27_24, D11), + PINMUX_IPSR_GPSR(IP6_27_24, LCDOUT3), + PINMUX_IPSR_MSEL(IP6_27_24, MSIOF2_TXD_D, SEL_MSIOF2_3), + PINMUX_IPSR_MSEL(IP6_27_24, HTX3_B, SEL_HSCIF3_1), + PINMUX_IPSR_MSEL(IP6_27_24, VI4_DATA3_A, SEL_VIN4_0), + PINMUX_IPSR_MSEL(IP6_27_24, RTS4_N_C, SEL_SCIF4_2), + PINMUX_IPSR_GPSR(IP6_27_24, DU_DR3), + + PINMUX_IPSR_GPSR(IP6_31_28, D12), + PINMUX_IPSR_GPSR(IP6_31_28, LCDOUT4), + PINMUX_IPSR_MSEL(IP6_31_28, MSIOF2_SS1_D, SEL_MSIOF2_3), + PINMUX_IPSR_MSEL(IP6_31_28, RX4_C, SEL_SCIF4_2), + PINMUX_IPSR_MSEL(IP6_31_28, VI4_DATA4_A, SEL_VIN4_0), + PINMUX_IPSR_GPSR(IP6_31_28, DU_DR4), + + /* IPSR7 */ + PINMUX_IPSR_GPSR(IP7_3_0, D13), + PINMUX_IPSR_GPSR(IP7_3_0, LCDOUT5), + PINMUX_IPSR_MSEL(IP7_3_0, MSIOF2_SS2_D, SEL_MSIOF2_3), + PINMUX_IPSR_MSEL(IP7_3_0, TX4_C, SEL_SCIF4_2), + PINMUX_IPSR_MSEL(IP7_3_0, VI4_DATA5_A, SEL_VIN4_0), + PINMUX_IPSR_GPSR(IP7_3_0, DU_DR5), + + PINMUX_IPSR_GPSR(IP7_7_4, D14), + PINMUX_IPSR_GPSR(IP7_7_4, LCDOUT6), + PINMUX_IPSR_MSEL(IP7_7_4, MSIOF3_SS1_A, SEL_MSIOF3_0), + PINMUX_IPSR_MSEL(IP7_7_4, HRX3_C, SEL_HSCIF3_2), + PINMUX_IPSR_MSEL(IP7_7_4, VI4_DATA6_A, SEL_VIN4_0), + PINMUX_IPSR_GPSR(IP7_7_4, DU_DR6), + PINMUX_IPSR_MSEL(IP7_7_4, SCL6_C, SEL_I2C6_2), + + PINMUX_IPSR_GPSR(IP7_11_8, D15), + PINMUX_IPSR_GPSR(IP7_11_8, LCDOUT7), + PINMUX_IPSR_MSEL(IP7_11_8, MSIOF3_SS2_A, SEL_MSIOF3_0), + PINMUX_IPSR_MSEL(IP7_11_8, HTX3_C, SEL_HSCIF3_2), + PINMUX_IPSR_MSEL(IP7_11_8, VI4_DATA7_A, SEL_VIN4_0), + PINMUX_IPSR_GPSR(IP7_11_8, DU_DR7), + PINMUX_IPSR_MSEL(IP7_11_8, SDA6_C, SEL_I2C6_2), + + PINMUX_IPSR_GPSR(IP7_19_16, SD0_CLK), + PINMUX_IPSR_MSEL(IP7_19_16, MSIOF1_SCK_E, SEL_MSIOF1_4), + PINMUX_IPSR_MSEL(IP7_19_16, STP_OPWM_0_B, SEL_SSP1_0_1), + + PINMUX_IPSR_GPSR(IP7_23_20, SD0_CMD), + PINMUX_IPSR_MSEL(IP7_23_20, MSIOF1_SYNC_E, SEL_MSIOF1_4), + PINMUX_IPSR_MSEL(IP7_23_20, STP_IVCXO27_0_B, SEL_SSP1_0_1), + + PINMUX_IPSR_GPSR(IP7_27_24, SD0_DAT0), + PINMUX_IPSR_MSEL(IP7_27_24, MSIOF1_RXD_E, SEL_MSIOF1_4), + PINMUX_IPSR_MSEL(IP7_27_24, TS_SCK0_B, SEL_TSIF0_1), + PINMUX_IPSR_MSEL(IP7_27_24, STP_ISCLK_0_B, SEL_SSP1_0_1), + + PINMUX_IPSR_GPSR(IP7_31_28, SD0_DAT1), + PINMUX_IPSR_MSEL(IP7_31_28, MSIOF1_TXD_E, SEL_MSIOF1_4), + PINMUX_IPSR_MSEL(IP7_31_28, TS_SPSYNC0_B, SEL_TSIF0_1), + PINMUX_IPSR_MSEL(IP7_31_28, STP_ISSYNC_0_B, SEL_SSP1_0_1), + + /* IPSR8 */ + PINMUX_IPSR_GPSR(IP8_3_0, SD0_DAT2), + PINMUX_IPSR_MSEL(IP8_3_0, MSIOF1_SS1_E, SEL_MSIOF1_4), + PINMUX_IPSR_MSEL(IP8_3_0, TS_SDAT0_B, SEL_TSIF0_1), + PINMUX_IPSR_MSEL(IP8_3_0, STP_ISD_0_B, SEL_SSP1_0_1), + + PINMUX_IPSR_GPSR(IP8_7_4, SD0_DAT3), + PINMUX_IPSR_MSEL(IP8_7_4, MSIOF1_SS2_E, SEL_MSIOF1_4), + PINMUX_IPSR_MSEL(IP8_7_4, TS_SDEN0_B, SEL_TSIF0_1), + PINMUX_IPSR_MSEL(IP8_7_4, STP_ISEN_0_B, SEL_SSP1_0_1), + + PINMUX_IPSR_GPSR(IP8_11_8, SD1_CLK), + PINMUX_IPSR_MSEL(IP8_11_8, MSIOF1_SCK_G, SEL_MSIOF1_6), + PINMUX_IPSR_MSEL(IP8_11_8, SIM0_CLK_A, SEL_SIMCARD_0), + + PINMUX_IPSR_GPSR(IP8_15_12, SD1_CMD), + PINMUX_IPSR_MSEL(IP8_15_12, MSIOF1_SYNC_G, SEL_MSIOF1_6), + PINMUX_IPSR_MSEL(IP8_15_12, NFCE_N_B, SEL_NDF_1), + PINMUX_IPSR_MSEL(IP8_15_12, SIM0_D_A, SEL_SIMCARD_0), + PINMUX_IPSR_MSEL(IP8_15_12, STP_IVCXO27_1_B, SEL_SSP1_1_1), + + PINMUX_IPSR_GPSR(IP8_19_16, SD1_DAT0), + PINMUX_IPSR_GPSR(IP8_19_16, SD2_DAT4), + PINMUX_IPSR_MSEL(IP8_19_16, MSIOF1_RXD_G, SEL_MSIOF1_6), + PINMUX_IPSR_MSEL(IP8_19_16, NFWP_N_B, SEL_NDF_1), + PINMUX_IPSR_MSEL(IP8_19_16, TS_SCK1_B, SEL_TSIF1_1), + PINMUX_IPSR_MSEL(IP8_19_16, STP_ISCLK_1_B, SEL_SSP1_1_1), + + PINMUX_IPSR_GPSR(IP8_23_20, SD1_DAT1), + PINMUX_IPSR_GPSR(IP8_23_20, SD2_DAT5), + PINMUX_IPSR_MSEL(IP8_23_20, MSIOF1_TXD_G, SEL_MSIOF1_6), + PINMUX_IPSR_MSEL(IP8_23_20, NFDATA14_B, SEL_NDF_1), + PINMUX_IPSR_MSEL(IP8_23_20, TS_SPSYNC1_B, SEL_TSIF1_1), + PINMUX_IPSR_MSEL(IP8_23_20, STP_ISSYNC_1_B, SEL_SSP1_1_1), + + PINMUX_IPSR_GPSR(IP8_27_24, SD1_DAT2), + PINMUX_IPSR_GPSR(IP8_27_24, SD2_DAT6), + PINMUX_IPSR_MSEL(IP8_27_24, MSIOF1_SS1_G, SEL_MSIOF1_6), + PINMUX_IPSR_MSEL(IP8_27_24, NFDATA15_B, SEL_NDF_1), + PINMUX_IPSR_MSEL(IP8_27_24, TS_SDAT1_B, SEL_TSIF1_1), + PINMUX_IPSR_MSEL(IP8_27_24, STP_ISD_1_B, SEL_SSP1_1_1), + + PINMUX_IPSR_GPSR(IP8_31_28, SD1_DAT3), + PINMUX_IPSR_GPSR(IP8_31_28, SD2_DAT7), + PINMUX_IPSR_MSEL(IP8_31_28, MSIOF1_SS2_G, SEL_MSIOF1_6), + PINMUX_IPSR_MSEL(IP8_31_28, NFRB_N_B, SEL_NDF_1), + PINMUX_IPSR_MSEL(IP8_31_28, TS_SDEN1_B, SEL_TSIF1_1), + PINMUX_IPSR_MSEL(IP8_31_28, STP_ISEN_1_B, SEL_SSP1_1_1), + + /* IPSR9 */ + PINMUX_IPSR_GPSR(IP9_3_0, SD2_CLK), + PINMUX_IPSR_GPSR(IP9_3_0, NFDATA8), + + PINMUX_IPSR_GPSR(IP9_7_4, SD2_CMD), + PINMUX_IPSR_GPSR(IP9_7_4, NFDATA9), + + PINMUX_IPSR_GPSR(IP9_11_8, SD2_DAT0), + PINMUX_IPSR_GPSR(IP9_11_8, NFDATA10), + + PINMUX_IPSR_GPSR(IP9_15_12, SD2_DAT1), + PINMUX_IPSR_GPSR(IP9_15_12, NFDATA11), + + PINMUX_IPSR_GPSR(IP9_19_16, SD2_DAT2), + PINMUX_IPSR_GPSR(IP9_19_16, NFDATA12), + + PINMUX_IPSR_GPSR(IP9_23_20, SD2_DAT3), + PINMUX_IPSR_GPSR(IP9_23_20, NFDATA13), + + PINMUX_IPSR_GPSR(IP9_27_24, SD2_DS), + PINMUX_IPSR_GPSR(IP9_27_24, NFALE), + + PINMUX_IPSR_GPSR(IP9_31_28, SD3_CLK), + PINMUX_IPSR_GPSR(IP9_31_28, NFWE_N), + + /* IPSR10 */ + PINMUX_IPSR_GPSR(IP10_3_0, SD3_CMD), + PINMUX_IPSR_GPSR(IP10_3_0, NFRE_N), + + PINMUX_IPSR_GPSR(IP10_7_4, SD3_DAT0), + PINMUX_IPSR_GPSR(IP10_7_4, NFDATA0), + + PINMUX_IPSR_GPSR(IP10_11_8, SD3_DAT1), + PINMUX_IPSR_GPSR(IP10_11_8, NFDATA1), + + PINMUX_IPSR_GPSR(IP10_15_12, SD3_DAT2), + PINMUX_IPSR_GPSR(IP10_15_12, NFDATA2), + + PINMUX_IPSR_GPSR(IP10_19_16, SD3_DAT3), + PINMUX_IPSR_GPSR(IP10_19_16, NFDATA3), + + PINMUX_IPSR_GPSR(IP10_23_20, SD3_DAT4), + PINMUX_IPSR_MSEL(IP10_23_20, SD2_CD_A, SEL_SDHI2_0), + PINMUX_IPSR_GPSR(IP10_23_20, NFDATA4), + + PINMUX_IPSR_GPSR(IP10_27_24, SD3_DAT5), + PINMUX_IPSR_MSEL(IP10_27_24, SD2_WP_A, SEL_SDHI2_0), + PINMUX_IPSR_GPSR(IP10_27_24, NFDATA5), + + PINMUX_IPSR_GPSR(IP10_31_28, SD3_DAT6), + PINMUX_IPSR_GPSR(IP10_31_28, SD3_CD), + PINMUX_IPSR_GPSR(IP10_31_28, NFDATA6), + + /* IPSR11 */ + PINMUX_IPSR_GPSR(IP11_3_0, SD3_DAT7), + PINMUX_IPSR_GPSR(IP11_3_0, SD3_WP), + PINMUX_IPSR_GPSR(IP11_3_0, NFDATA7), + + PINMUX_IPSR_GPSR(IP11_7_4, SD3_DS), + PINMUX_IPSR_GPSR(IP11_7_4, NFCLE), + + PINMUX_IPSR_GPSR(IP11_11_8, SD0_CD), + PINMUX_IPSR_MSEL(IP11_11_8, NFDATA14_A, SEL_NDF_0), + PINMUX_IPSR_MSEL(IP11_11_8, SCL2_B, SEL_I2C2_1), + PINMUX_IPSR_MSEL(IP11_11_8, SIM0_RST_A, SEL_SIMCARD_0), + + PINMUX_IPSR_GPSR(IP11_15_12, SD0_WP), + PINMUX_IPSR_MSEL(IP11_15_12, NFDATA15_A, SEL_NDF_0), + PINMUX_IPSR_MSEL(IP11_15_12, SDA2_B, SEL_I2C2_1), + + PINMUX_IPSR_GPSR(IP11_19_16, SD1_CD), + PINMUX_IPSR_MSEL(IP11_19_16, NFRB_N_A, SEL_NDF_0), + PINMUX_IPSR_MSEL(IP11_19_16, SIM0_CLK_B, SEL_SIMCARD_1), + + PINMUX_IPSR_GPSR(IP11_23_20, SD1_WP), + PINMUX_IPSR_MSEL(IP11_23_20, NFCE_N_A, SEL_NDF_0), + PINMUX_IPSR_MSEL(IP11_23_20, SIM0_D_B, SEL_SIMCARD_1), + + PINMUX_IPSR_GPSR(IP11_27_24, SCK0), + PINMUX_IPSR_MSEL(IP11_27_24, HSCK1_B, SEL_HSCIF1_1), + PINMUX_IPSR_MSEL(IP11_27_24, MSIOF1_SS2_B, SEL_MSIOF1_1), + PINMUX_IPSR_MSEL(IP11_27_24, AUDIO_CLKC_B, SEL_ADGC_1), + PINMUX_IPSR_MSEL(IP11_27_24, SDA2_A, SEL_I2C2_0), + PINMUX_IPSR_MSEL(IP11_27_24, SIM0_RST_B, SEL_SIMCARD_1), + PINMUX_IPSR_MSEL(IP11_27_24, STP_OPWM_0_C, SEL_SSP1_0_2), + PINMUX_IPSR_MSEL(IP11_27_24, RIF0_CLK_B, SEL_DRIF0_1), + PINMUX_IPSR_GPSR(IP11_27_24, ADICHS2), + PINMUX_IPSR_MSEL(IP11_27_24, SCK5_B, SEL_SCIF5_1), + + PINMUX_IPSR_GPSR(IP11_31_28, RX0), + PINMUX_IPSR_MSEL(IP11_31_28, HRX1_B, SEL_HSCIF1_1), + PINMUX_IPSR_MSEL(IP11_31_28, TS_SCK0_C, SEL_TSIF0_2), + PINMUX_IPSR_MSEL(IP11_31_28, STP_ISCLK_0_C, SEL_SSP1_0_2), + PINMUX_IPSR_MSEL(IP11_31_28, RIF0_D0_B, SEL_DRIF0_1), + + /* IPSR12 */ + PINMUX_IPSR_GPSR(IP12_3_0, TX0), + PINMUX_IPSR_MSEL(IP12_3_0, HTX1_B, SEL_HSCIF1_1), + PINMUX_IPSR_MSEL(IP12_3_0, TS_SPSYNC0_C, SEL_TSIF0_2), + PINMUX_IPSR_MSEL(IP12_3_0, STP_ISSYNC_0_C, SEL_SSP1_0_2), + PINMUX_IPSR_MSEL(IP12_3_0, RIF0_D1_B, SEL_DRIF0_1), + + PINMUX_IPSR_GPSR(IP12_7_4, CTS0_N), + PINMUX_IPSR_MSEL(IP12_7_4, HCTS1_N_B, SEL_HSCIF1_1), + PINMUX_IPSR_MSEL(IP12_7_4, MSIOF1_SYNC_B, SEL_MSIOF1_1), + PINMUX_IPSR_MSEL(IP12_7_4, TS_SPSYNC1_C, SEL_TSIF1_2), + PINMUX_IPSR_MSEL(IP12_7_4, STP_ISSYNC_1_C, SEL_SSP1_1_2), + PINMUX_IPSR_MSEL(IP12_7_4, RIF1_SYNC_B, SEL_DRIF1_1), + PINMUX_IPSR_GPSR(IP12_7_4, AUDIO_CLKOUT_C), + PINMUX_IPSR_GPSR(IP12_7_4, ADICS_SAMP), + + PINMUX_IPSR_GPSR(IP12_11_8, RTS0_N), + PINMUX_IPSR_MSEL(IP12_11_8, HRTS1_N_B, SEL_HSCIF1_1), + PINMUX_IPSR_MSEL(IP12_11_8, MSIOF1_SS1_B, SEL_MSIOF1_1), + PINMUX_IPSR_MSEL(IP12_11_8, AUDIO_CLKA_B, SEL_ADGA_1), + PINMUX_IPSR_MSEL(IP12_11_8, SCL2_A, SEL_I2C2_0), + PINMUX_IPSR_MSEL(IP12_11_8, STP_IVCXO27_1_C, SEL_SSP1_1_2), + PINMUX_IPSR_MSEL(IP12_11_8, RIF0_SYNC_B, SEL_DRIF0_1), + PINMUX_IPSR_GPSR(IP12_11_8, ADICHS1), + + PINMUX_IPSR_MSEL(IP12_15_12, RX1_A, SEL_SCIF1_0), + PINMUX_IPSR_MSEL(IP12_15_12, HRX1_A, SEL_HSCIF1_0), + PINMUX_IPSR_MSEL(IP12_15_12, TS_SDAT0_C, SEL_TSIF0_2), + PINMUX_IPSR_MSEL(IP12_15_12, STP_ISD_0_C, SEL_SSP1_0_2), + PINMUX_IPSR_MSEL(IP12_15_12, RIF1_CLK_C, SEL_DRIF1_2), + + PINMUX_IPSR_MSEL(IP12_19_16, TX1_A, SEL_SCIF1_0), + PINMUX_IPSR_MSEL(IP12_19_16, HTX1_A, SEL_HSCIF1_0), + PINMUX_IPSR_MSEL(IP12_19_16, TS_SDEN0_C, SEL_TSIF0_2), + PINMUX_IPSR_MSEL(IP12_19_16, STP_ISEN_0_C, SEL_SSP1_0_2), + PINMUX_IPSR_MSEL(IP12_19_16, RIF1_D0_C, SEL_DRIF1_2), + + PINMUX_IPSR_GPSR(IP12_23_20, CTS1_N), + PINMUX_IPSR_MSEL(IP12_23_20, HCTS1_N_A, SEL_HSCIF1_0), + PINMUX_IPSR_MSEL(IP12_23_20, MSIOF1_RXD_B, SEL_MSIOF1_1), + PINMUX_IPSR_MSEL(IP12_23_20, TS_SDEN1_C, SEL_TSIF1_2), + PINMUX_IPSR_MSEL(IP12_23_20, STP_ISEN_1_C, SEL_SSP1_1_2), + PINMUX_IPSR_MSEL(IP12_23_20, RIF1_D0_B, SEL_DRIF1_1), + PINMUX_IPSR_GPSR(IP12_23_20, ADIDATA), + + PINMUX_IPSR_GPSR(IP12_27_24, RTS1_N), + PINMUX_IPSR_MSEL(IP12_27_24, HRTS1_N_A, SEL_HSCIF1_0), + PINMUX_IPSR_MSEL(IP12_27_24, MSIOF1_TXD_B, SEL_MSIOF1_1), + PINMUX_IPSR_MSEL(IP12_27_24, TS_SDAT1_C, SEL_TSIF1_2), + PINMUX_IPSR_MSEL(IP12_27_24, STP_ISD_1_C, SEL_SSP1_1_2), + PINMUX_IPSR_MSEL(IP12_27_24, RIF1_D1_B, SEL_DRIF1_1), + PINMUX_IPSR_GPSR(IP12_27_24, ADICHS0), + + PINMUX_IPSR_GPSR(IP12_31_28, SCK2), + PINMUX_IPSR_MSEL(IP12_31_28, SCIF_CLK_B, SEL_SCIF_1), + PINMUX_IPSR_MSEL(IP12_31_28, MSIOF1_SCK_B, SEL_MSIOF1_1), + PINMUX_IPSR_MSEL(IP12_31_28, TS_SCK1_C, SEL_TSIF1_2), + PINMUX_IPSR_MSEL(IP12_31_28, STP_ISCLK_1_C, SEL_SSP1_1_2), + PINMUX_IPSR_MSEL(IP12_31_28, RIF1_CLK_B, SEL_DRIF1_1), + PINMUX_IPSR_GPSR(IP12_31_28, ADICLK), + + /* IPSR13 */ + PINMUX_IPSR_MSEL(IP13_3_0, TX2_A, SEL_SCIF2_0), + PINMUX_IPSR_MSEL(IP13_3_0, SD2_CD_B, SEL_SDHI2_1), + PINMUX_IPSR_MSEL(IP13_3_0, SCL1_A, SEL_I2C1_0), + PINMUX_IPSR_MSEL(IP13_3_0, FMCLK_A, SEL_FM_0), + PINMUX_IPSR_MSEL(IP13_3_0, RIF1_D1_C, SEL_DRIF1_2), + PINMUX_IPSR_GPSR(IP13_3_0, FSO_CFE_0_N), + + PINMUX_IPSR_MSEL(IP13_7_4, RX2_A, SEL_SCIF2_0), + PINMUX_IPSR_MSEL(IP13_7_4, SD2_WP_B, SEL_SDHI2_1), + PINMUX_IPSR_MSEL(IP13_7_4, SDA1_A, SEL_I2C1_0), + PINMUX_IPSR_MSEL(IP13_7_4, FMIN_A, SEL_FM_0), + PINMUX_IPSR_MSEL(IP13_7_4, RIF1_SYNC_C, SEL_DRIF1_2), + PINMUX_IPSR_GPSR(IP13_7_4, FSO_CFE_1_N), + + PINMUX_IPSR_GPSR(IP13_11_8, HSCK0), + PINMUX_IPSR_MSEL(IP13_11_8, MSIOF1_SCK_D, SEL_MSIOF1_3), + PINMUX_IPSR_MSEL(IP13_11_8, AUDIO_CLKB_A, SEL_ADGB_0), + PINMUX_IPSR_MSEL(IP13_11_8, SSI_SDATA1_B, SEL_SSI1_1), + PINMUX_IPSR_MSEL(IP13_11_8, TS_SCK0_D, SEL_TSIF0_3), + PINMUX_IPSR_MSEL(IP13_11_8, STP_ISCLK_0_D, SEL_SSP1_0_3), + PINMUX_IPSR_MSEL(IP13_11_8, RIF0_CLK_C, SEL_DRIF0_2), + PINMUX_IPSR_MSEL(IP13_11_8, RX5_B, SEL_SCIF5_1), + + PINMUX_IPSR_GPSR(IP13_15_12, HRX0), + PINMUX_IPSR_MSEL(IP13_15_12, MSIOF1_RXD_D, SEL_MSIOF1_3), + PINMUX_IPSR_MSEL(IP13_15_12, SSI_SDATA2_B, SEL_SSI2_1), + PINMUX_IPSR_MSEL(IP13_15_12, TS_SDEN0_D, SEL_TSIF0_3), + PINMUX_IPSR_MSEL(IP13_15_12, STP_ISEN_0_D, SEL_SSP1_0_3), + PINMUX_IPSR_MSEL(IP13_15_12, RIF0_D0_C, SEL_DRIF0_2), + + PINMUX_IPSR_GPSR(IP13_19_16, HTX0), + PINMUX_IPSR_MSEL(IP13_19_16, MSIOF1_TXD_D, SEL_MSIOF1_3), + PINMUX_IPSR_MSEL(IP13_19_16, SSI_SDATA9_B, SEL_SSI9_1), + PINMUX_IPSR_MSEL(IP13_19_16, TS_SDAT0_D, SEL_TSIF0_3), + PINMUX_IPSR_MSEL(IP13_19_16, STP_ISD_0_D, SEL_SSP1_0_3), + PINMUX_IPSR_MSEL(IP13_19_16, RIF0_D1_C, SEL_DRIF0_2), + + PINMUX_IPSR_GPSR(IP13_23_20, HCTS0_N), + PINMUX_IPSR_MSEL(IP13_23_20, RX2_B, SEL_SCIF2_1), + PINMUX_IPSR_MSEL(IP13_23_20, MSIOF1_SYNC_D, SEL_MSIOF1_3), + PINMUX_IPSR_MSEL(IP13_23_20, SSI_SCK9_A, SEL_SSI9_0), + PINMUX_IPSR_MSEL(IP13_23_20, TS_SPSYNC0_D, SEL_TSIF0_3), + PINMUX_IPSR_MSEL(IP13_23_20, STP_ISSYNC_0_D, SEL_SSP1_0_3), + PINMUX_IPSR_MSEL(IP13_23_20, RIF0_SYNC_C, SEL_DRIF0_2), + PINMUX_IPSR_GPSR(IP13_23_20, AUDIO_CLKOUT1_A), + + PINMUX_IPSR_GPSR(IP13_27_24, HRTS0_N), + PINMUX_IPSR_MSEL(IP13_27_24, TX2_B, SEL_SCIF2_1), + PINMUX_IPSR_MSEL(IP13_27_24, MSIOF1_SS1_D, SEL_MSIOF1_3), + PINMUX_IPSR_MSEL(IP13_27_24, SSI_WS9_A, SEL_SSI9_0), + PINMUX_IPSR_MSEL(IP13_27_24, STP_IVCXO27_0_D, SEL_SSP1_0_3), + PINMUX_IPSR_MSEL(IP13_27_24, BPFCLK_A, SEL_FM_0), + PINMUX_IPSR_GPSR(IP13_27_24, AUDIO_CLKOUT2_A), + + PINMUX_IPSR_GPSR(IP13_31_28, MSIOF0_SYNC), + PINMUX_IPSR_GPSR(IP13_31_28, AUDIO_CLKOUT_A), + PINMUX_IPSR_MSEL(IP13_31_28, TX5_B, SEL_SCIF5_1), + PINMUX_IPSR_MSEL(IP13_31_28, BPFCLK_D, SEL_FM_3), + + /* IPSR14 */ + PINMUX_IPSR_GPSR(IP14_3_0, MSIOF0_SS1), + PINMUX_IPSR_MSEL(IP14_3_0, RX5_A, SEL_SCIF5_0), + PINMUX_IPSR_MSEL(IP14_3_0, NFWP_N_A, SEL_NDF_0), + PINMUX_IPSR_MSEL(IP14_3_0, AUDIO_CLKA_C, SEL_ADGA_2), + PINMUX_IPSR_MSEL(IP14_3_0, SSI_SCK2_A, SEL_SSI2_0), + PINMUX_IPSR_MSEL(IP14_3_0, STP_IVCXO27_0_C, SEL_SSP1_0_2), + PINMUX_IPSR_GPSR(IP14_3_0, AUDIO_CLKOUT3_A), + PINMUX_IPSR_MSEL(IP14_3_0, TCLK1_B, SEL_TIMER_TMU_1), + + PINMUX_IPSR_GPSR(IP14_7_4, MSIOF0_SS2), + PINMUX_IPSR_MSEL(IP14_7_4, TX5_A, SEL_SCIF5_0), + PINMUX_IPSR_MSEL(IP14_7_4, MSIOF1_SS2_D, SEL_MSIOF1_3), + PINMUX_IPSR_MSEL(IP14_7_4, AUDIO_CLKC_A, SEL_ADGC_0), + PINMUX_IPSR_MSEL(IP14_7_4, SSI_WS2_A, SEL_SSI2_0), + PINMUX_IPSR_MSEL(IP14_7_4, STP_OPWM_0_D, SEL_SSP1_0_3), + PINMUX_IPSR_GPSR(IP14_7_4, AUDIO_CLKOUT_D), + PINMUX_IPSR_MSEL(IP14_7_4, SPEEDIN_B, SEL_SPEED_PULSE_1), + + PINMUX_IPSR_GPSR(IP14_11_8, MLB_CLK), + PINMUX_IPSR_MSEL(IP14_11_8, MSIOF1_SCK_F, SEL_MSIOF1_5), + PINMUX_IPSR_MSEL(IP14_11_8, SCL1_B, SEL_I2C1_1), + + PINMUX_IPSR_GPSR(IP14_15_12, MLB_SIG), + PINMUX_IPSR_MSEL(IP14_15_12, RX1_B, SEL_SCIF1_1), + PINMUX_IPSR_MSEL(IP14_15_12, MSIOF1_SYNC_F, SEL_MSIOF1_5), + PINMUX_IPSR_MSEL(IP14_15_12, SDA1_B, SEL_I2C1_1), + + PINMUX_IPSR_GPSR(IP14_19_16, MLB_DAT), + PINMUX_IPSR_MSEL(IP14_19_16, TX1_B, SEL_SCIF1_1), + PINMUX_IPSR_MSEL(IP14_19_16, MSIOF1_RXD_F, SEL_MSIOF1_5), + + PINMUX_IPSR_GPSR(IP14_23_20, SSI_SCK01239), + PINMUX_IPSR_MSEL(IP14_23_20, MSIOF1_TXD_F, SEL_MSIOF1_5), + + PINMUX_IPSR_GPSR(IP14_27_24, SSI_WS01239), + PINMUX_IPSR_MSEL(IP14_27_24, MSIOF1_SS1_F, SEL_MSIOF1_5), + + PINMUX_IPSR_GPSR(IP14_31_28, SSI_SDATA0), + PINMUX_IPSR_MSEL(IP14_31_28, MSIOF1_SS2_F, SEL_MSIOF1_5), + + /* IPSR15 */ + PINMUX_IPSR_MSEL(IP15_3_0, SSI_SDATA1_A, SEL_SSI1_0), + + PINMUX_IPSR_MSEL(IP15_7_4, SSI_SDATA2_A, SEL_SSI2_0), + PINMUX_IPSR_MSEL(IP15_7_4, SSI_SCK1_B, SEL_SSI1_1), + + PINMUX_IPSR_GPSR(IP15_11_8, SSI_SCK349), + PINMUX_IPSR_MSEL(IP15_11_8, MSIOF1_SS1_A, SEL_MSIOF1_0), + PINMUX_IPSR_MSEL(IP15_11_8, STP_OPWM_0_A, SEL_SSP1_0_0), + + PINMUX_IPSR_GPSR(IP15_15_12, SSI_WS349), + PINMUX_IPSR_MSEL(IP15_15_12, HCTS2_N_A, SEL_HSCIF2_0), + PINMUX_IPSR_MSEL(IP15_15_12, MSIOF1_SS2_A, SEL_MSIOF1_0), + PINMUX_IPSR_MSEL(IP15_15_12, STP_IVCXO27_0_A, SEL_SSP1_0_0), + + PINMUX_IPSR_GPSR(IP15_19_16, SSI_SDATA3), + PINMUX_IPSR_MSEL(IP15_19_16, HRTS2_N_A, SEL_HSCIF2_0), + PINMUX_IPSR_MSEL(IP15_19_16, MSIOF1_TXD_A, SEL_MSIOF1_0), + PINMUX_IPSR_MSEL(IP15_19_16, TS_SCK0_A, SEL_TSIF0_0), + PINMUX_IPSR_MSEL(IP15_19_16, STP_ISCLK_0_A, SEL_SSP1_0_0), + PINMUX_IPSR_MSEL(IP15_19_16, RIF0_D1_A, SEL_DRIF0_0), + PINMUX_IPSR_MSEL(IP15_19_16, RIF2_D0_A, SEL_DRIF2_0), + + PINMUX_IPSR_GPSR(IP15_23_20, SSI_SCK4), + PINMUX_IPSR_MSEL(IP15_23_20, HRX2_A, SEL_HSCIF2_0), + PINMUX_IPSR_MSEL(IP15_23_20, MSIOF1_SCK_A, SEL_MSIOF1_0), + PINMUX_IPSR_MSEL(IP15_23_20, TS_SDAT0_A, SEL_TSIF0_0), + PINMUX_IPSR_MSEL(IP15_23_20, STP_ISD_0_A, SEL_SSP1_0_0), + PINMUX_IPSR_MSEL(IP15_23_20, RIF0_CLK_A, SEL_DRIF0_0), + PINMUX_IPSR_MSEL(IP15_23_20, RIF2_CLK_A, SEL_DRIF2_0), + + PINMUX_IPSR_GPSR(IP15_27_24, SSI_WS4), + PINMUX_IPSR_MSEL(IP15_27_24, HTX2_A, SEL_HSCIF2_0), + PINMUX_IPSR_MSEL(IP15_27_24, MSIOF1_SYNC_A, SEL_MSIOF1_0), + PINMUX_IPSR_MSEL(IP15_27_24, TS_SDEN0_A, SEL_TSIF0_0), + PINMUX_IPSR_MSEL(IP15_27_24, STP_ISEN_0_A, SEL_SSP1_0_0), + PINMUX_IPSR_MSEL(IP15_27_24, RIF0_SYNC_A, SEL_DRIF0_0), + PINMUX_IPSR_MSEL(IP15_27_24, RIF2_SYNC_A, SEL_DRIF2_0), + + PINMUX_IPSR_GPSR(IP15_31_28, SSI_SDATA4), + PINMUX_IPSR_MSEL(IP15_31_28, HSCK2_A, SEL_HSCIF2_0), + PINMUX_IPSR_MSEL(IP15_31_28, MSIOF1_RXD_A, SEL_MSIOF1_0), + PINMUX_IPSR_MSEL(IP15_31_28, TS_SPSYNC0_A, SEL_TSIF0_0), + PINMUX_IPSR_MSEL(IP15_31_28, STP_ISSYNC_0_A, SEL_SSP1_0_0), + PINMUX_IPSR_MSEL(IP15_31_28, RIF0_D0_A, SEL_DRIF0_0), + PINMUX_IPSR_MSEL(IP15_31_28, RIF2_D1_A, SEL_DRIF2_0), + + /* IPSR16 */ + PINMUX_IPSR_GPSR(IP16_3_0, SSI_SCK6), + PINMUX_IPSR_MSEL(IP16_3_0, SIM0_RST_D, SEL_SIMCARD_3), + + PINMUX_IPSR_GPSR(IP16_7_4, SSI_WS6), + PINMUX_IPSR_MSEL(IP16_7_4, SIM0_D_D, SEL_SIMCARD_3), + + PINMUX_IPSR_GPSR(IP16_11_8, SSI_SDATA6), + PINMUX_IPSR_MSEL(IP16_11_8, SIM0_CLK_D, SEL_SIMCARD_3), + PINMUX_IPSR_GPSR(IP16_11_8, SATA_DEVSLP_A), + + PINMUX_IPSR_GPSR(IP16_15_12, SSI_SCK78), + PINMUX_IPSR_MSEL(IP16_15_12, HRX2_B, SEL_HSCIF2_1), + PINMUX_IPSR_MSEL(IP16_15_12, MSIOF1_SCK_C, SEL_MSIOF1_2), + PINMUX_IPSR_MSEL(IP16_15_12, TS_SCK1_A, SEL_TSIF1_0), + PINMUX_IPSR_MSEL(IP16_15_12, STP_ISCLK_1_A, SEL_SSP1_1_0), + PINMUX_IPSR_MSEL(IP16_15_12, RIF1_CLK_A, SEL_DRIF1_0), + PINMUX_IPSR_MSEL(IP16_15_12, RIF3_CLK_A, SEL_DRIF3_0), + + PINMUX_IPSR_GPSR(IP16_19_16, SSI_WS78), + PINMUX_IPSR_MSEL(IP16_19_16, HTX2_B, SEL_HSCIF2_1), + PINMUX_IPSR_MSEL(IP16_19_16, MSIOF1_SYNC_C, SEL_MSIOF1_2), + PINMUX_IPSR_MSEL(IP16_19_16, TS_SDAT1_A, SEL_TSIF1_0), + PINMUX_IPSR_MSEL(IP16_19_16, STP_ISD_1_A, SEL_SSP1_1_0), + PINMUX_IPSR_MSEL(IP16_19_16, RIF1_SYNC_A, SEL_DRIF1_0), + PINMUX_IPSR_MSEL(IP16_19_16, RIF3_SYNC_A, SEL_DRIF3_0), + + PINMUX_IPSR_GPSR(IP16_23_20, SSI_SDATA7), + PINMUX_IPSR_MSEL(IP16_23_20, HCTS2_N_B, SEL_HSCIF2_1), + PINMUX_IPSR_MSEL(IP16_23_20, MSIOF1_RXD_C, SEL_MSIOF1_2), + PINMUX_IPSR_MSEL(IP16_23_20, TS_SDEN1_A, SEL_TSIF1_0), + PINMUX_IPSR_MSEL(IP16_23_20, STP_ISEN_1_A, SEL_SSP1_1_0), + PINMUX_IPSR_MSEL(IP16_23_20, RIF1_D0_A, SEL_DRIF1_0), + PINMUX_IPSR_MSEL(IP16_23_20, RIF3_D0_A, SEL_DRIF3_0), + PINMUX_IPSR_MSEL(IP16_23_20, TCLK2_A, SEL_TIMER_TMU2_0), + + PINMUX_IPSR_GPSR(IP16_27_24, SSI_SDATA8), + PINMUX_IPSR_MSEL(IP16_27_24, HRTS2_N_B, SEL_HSCIF2_1), + PINMUX_IPSR_MSEL(IP16_27_24, MSIOF1_TXD_C, SEL_MSIOF1_2), + PINMUX_IPSR_MSEL(IP16_27_24, TS_SPSYNC1_A, SEL_TSIF1_0), + PINMUX_IPSR_MSEL(IP16_27_24, STP_ISSYNC_1_A, SEL_SSP1_1_0), + PINMUX_IPSR_MSEL(IP16_27_24, RIF1_D1_A, SEL_DRIF1_0), + PINMUX_IPSR_MSEL(IP16_27_24, RIF3_D1_A, SEL_DRIF3_0), + + PINMUX_IPSR_MSEL(IP16_31_28, SSI_SDATA9_A, SEL_SSI9_0), + PINMUX_IPSR_MSEL(IP16_31_28, HSCK2_B, SEL_HSCIF2_1), + PINMUX_IPSR_MSEL(IP16_31_28, MSIOF1_SS1_C, SEL_MSIOF1_2), + PINMUX_IPSR_MSEL(IP16_31_28, HSCK1_A, SEL_HSCIF1_0), + PINMUX_IPSR_MSEL(IP16_31_28, SSI_WS1_B, SEL_SSI1_1), + PINMUX_IPSR_GPSR(IP16_31_28, SCK1), + PINMUX_IPSR_MSEL(IP16_31_28, STP_IVCXO27_1_A, SEL_SSP1_1_0), + PINMUX_IPSR_MSEL(IP16_31_28, SCK5_A, SEL_SCIF5_0), + + /* IPSR17 */ + PINMUX_IPSR_MSEL(IP17_3_0, AUDIO_CLKA_A, SEL_ADGA_0), + + PINMUX_IPSR_MSEL(IP17_7_4, AUDIO_CLKB_B, SEL_ADGB_1), + PINMUX_IPSR_MSEL(IP17_7_4, SCIF_CLK_A, SEL_SCIF_0), + PINMUX_IPSR_MSEL(IP17_7_4, STP_IVCXO27_1_D, SEL_SSP1_1_3), + PINMUX_IPSR_MSEL(IP17_7_4, REMOCON_A, SEL_REMOCON_0), + PINMUX_IPSR_MSEL(IP17_7_4, TCLK1_A, SEL_TIMER_TMU_0), + + PINMUX_IPSR_GPSR(IP17_11_8, USB0_PWEN), + PINMUX_IPSR_MSEL(IP17_11_8, SIM0_RST_C, SEL_SIMCARD_2), + PINMUX_IPSR_MSEL(IP17_11_8, TS_SCK1_D, SEL_TSIF1_3), + PINMUX_IPSR_MSEL(IP17_11_8, STP_ISCLK_1_D, SEL_SSP1_1_3), + PINMUX_IPSR_MSEL(IP17_11_8, BPFCLK_B, SEL_FM_1), + PINMUX_IPSR_MSEL(IP17_11_8, RIF3_CLK_B, SEL_DRIF3_1), + PINMUX_IPSR_MSEL(IP17_11_8, HSCK2_C, SEL_HSCIF2_2), + + PINMUX_IPSR_GPSR(IP17_15_12, USB0_OVC), + PINMUX_IPSR_MSEL(IP17_15_12, SIM0_D_C, SEL_SIMCARD_2), + PINMUX_IPSR_MSEL(IP17_15_12, TS_SDAT1_D, SEL_TSIF1_3), + PINMUX_IPSR_MSEL(IP17_15_12, STP_ISD_1_D, SEL_SSP1_1_3), + PINMUX_IPSR_MSEL(IP17_15_12, RIF3_SYNC_B, SEL_DRIF3_1), + PINMUX_IPSR_MSEL(IP17_15_12, HRX2_C, SEL_HSCIF2_2), + + PINMUX_IPSR_GPSR(IP17_19_16, USB1_PWEN), + PINMUX_IPSR_MSEL(IP17_19_16, SIM0_CLK_C, SEL_SIMCARD_2), + PINMUX_IPSR_MSEL(IP17_19_16, SSI_SCK1_A, SEL_SSI1_0), + PINMUX_IPSR_MSEL(IP17_19_16, TS_SCK0_E, SEL_TSIF0_4), + PINMUX_IPSR_MSEL(IP17_19_16, STP_ISCLK_0_E, SEL_SSP1_0_4), + PINMUX_IPSR_MSEL(IP17_19_16, FMCLK_B, SEL_FM_1), + PINMUX_IPSR_MSEL(IP17_19_16, RIF2_CLK_B, SEL_DRIF2_1), + PINMUX_IPSR_MSEL(IP17_19_16, SPEEDIN_A, SEL_SPEED_PULSE_0), + PINMUX_IPSR_MSEL(IP17_19_16, HTX2_C, SEL_HSCIF2_2), + + PINMUX_IPSR_GPSR(IP17_23_20, USB1_OVC), + PINMUX_IPSR_MSEL(IP17_23_20, MSIOF1_SS2_C, SEL_MSIOF1_2), + PINMUX_IPSR_MSEL(IP17_23_20, SSI_WS1_A, SEL_SSI1_0), + PINMUX_IPSR_MSEL(IP17_23_20, TS_SDAT0_E, SEL_TSIF0_4), + PINMUX_IPSR_MSEL(IP17_23_20, STP_ISD_0_E, SEL_SSP1_0_4), + PINMUX_IPSR_MSEL(IP17_23_20, FMIN_B, SEL_FM_1), + PINMUX_IPSR_MSEL(IP17_23_20, RIF2_SYNC_B, SEL_DRIF2_1), + PINMUX_IPSR_MSEL(IP17_23_20, REMOCON_B, SEL_REMOCON_1), + PINMUX_IPSR_MSEL(IP17_23_20, HCTS2_N_C, SEL_HSCIF2_2), + + PINMUX_IPSR_GPSR(IP17_27_24, USB30_PWEN), + PINMUX_IPSR_GPSR(IP17_27_24, AUDIO_CLKOUT_B), + PINMUX_IPSR_MSEL(IP17_27_24, SSI_SCK2_B, SEL_SSI2_1), + PINMUX_IPSR_MSEL(IP17_27_24, TS_SDEN1_D, SEL_TSIF1_3), + PINMUX_IPSR_MSEL(IP17_27_24, STP_ISEN_1_D, SEL_SSP1_1_3), + PINMUX_IPSR_MSEL(IP17_27_24, STP_OPWM_0_E, SEL_SSP1_0_4), + PINMUX_IPSR_MSEL(IP17_27_24, RIF3_D0_B, SEL_DRIF3_1), + PINMUX_IPSR_MSEL(IP17_27_24, TCLK2_B, SEL_TIMER_TMU2_1), + PINMUX_IPSR_GPSR(IP17_27_24, TPU0TO0), + PINMUX_IPSR_MSEL(IP17_27_24, BPFCLK_C, SEL_FM_2), + PINMUX_IPSR_MSEL(IP17_27_24, HRTS2_N_C, SEL_HSCIF2_2), + + PINMUX_IPSR_GPSR(IP17_31_28, USB30_OVC), + PINMUX_IPSR_GPSR(IP17_31_28, AUDIO_CLKOUT1_B), + PINMUX_IPSR_MSEL(IP17_31_28, SSI_WS2_B, SEL_SSI2_1), + PINMUX_IPSR_MSEL(IP17_31_28, TS_SPSYNC1_D, SEL_TSIF1_3), + PINMUX_IPSR_MSEL(IP17_31_28, STP_ISSYNC_1_D, SEL_SSP1_1_3), + PINMUX_IPSR_MSEL(IP17_31_28, STP_IVCXO27_0_E, SEL_SSP1_0_4), + PINMUX_IPSR_MSEL(IP17_31_28, RIF3_D1_B, SEL_DRIF3_1), + PINMUX_IPSR_GPSR(IP17_31_28, FSO_TOE_N), + PINMUX_IPSR_GPSR(IP17_31_28, TPU0TO1), + + /* IPSR18 */ + PINMUX_IPSR_GPSR(IP18_3_0, GP6_30), + PINMUX_IPSR_GPSR(IP18_3_0, AUDIO_CLKOUT2_B), + PINMUX_IPSR_MSEL(IP18_3_0, SSI_SCK9_B, SEL_SSI9_1), + PINMUX_IPSR_MSEL(IP18_3_0, TS_SDEN0_E, SEL_TSIF0_4), + PINMUX_IPSR_MSEL(IP18_3_0, STP_ISEN_0_E, SEL_SSP1_0_4), + PINMUX_IPSR_MSEL(IP18_3_0, RIF2_D0_B, SEL_DRIF2_1), + PINMUX_IPSR_GPSR(IP18_3_0, TPU0TO2), + PINMUX_IPSR_MSEL(IP18_3_0, FMCLK_C, SEL_FM_2), + PINMUX_IPSR_MSEL(IP18_3_0, FMCLK_D, SEL_FM_3), + + PINMUX_IPSR_GPSR(IP18_7_4, GP6_31), + PINMUX_IPSR_GPSR(IP18_7_4, AUDIO_CLKOUT3_B), + PINMUX_IPSR_MSEL(IP18_7_4, SSI_WS9_B, SEL_SSI9_1), + PINMUX_IPSR_MSEL(IP18_7_4, TS_SPSYNC0_E, SEL_TSIF0_4), + PINMUX_IPSR_MSEL(IP18_7_4, STP_ISSYNC_0_E, SEL_SSP1_0_4), + PINMUX_IPSR_MSEL(IP18_7_4, RIF2_D1_B, SEL_DRIF2_1), + PINMUX_IPSR_GPSR(IP18_7_4, TPU0TO3), + PINMUX_IPSR_MSEL(IP18_7_4, FMIN_C, SEL_FM_2), + PINMUX_IPSR_MSEL(IP18_7_4, FMIN_D, SEL_FM_3), + + /* I2C */ + PINMUX_IPSR_NOGP(0, I2C_SEL_0_1), + PINMUX_IPSR_NOGP(0, I2C_SEL_3_1), + PINMUX_IPSR_NOGP(0, I2C_SEL_5_1), + +/* + * Static pins can not be muxed between different functions but + * still needs a mark entry in the pinmux list. Add each static + * pin to the list without an associated function. The sh-pfc + * core will do the right thing and skip trying to mux then pin + * while still applying configuration to it + */ +#define FM(x) PINMUX_DATA(x##_MARK, 0), + PINMUX_STATIC +#undef FM +}; + +/* + * R8A774a1 has 8 banks with 32 GPIOs in each => 256 GPIOs. + * Physical layout rows: A - AW, cols: 1 - 39. + */ +#define ROW_GROUP_A(r) ('Z' - 'A' + 1 + (r)) +#define PIN_NUMBER(r, c) (((r) - 'A') * 39 + (c) + 300) +#define PIN_A_NUMBER(r, c) PIN_NUMBER(ROW_GROUP_A(r), c) +#define PIN_NONE U16_MAX + +static const struct sh_pfc_pin pinmux_pins[] = { + PINMUX_GPIO_GP_ALL(), + + /* + * Pins not associated with a GPIO port. + * + * The pin positions are different between different r8a774a1 + * packages, all that is needed for the pfc driver is a unique + * number for each pin. To this end use the pin layout from + * R-Car M3SiP to calculate a unique number for each pin. + */ + SH_PFC_PIN_NAMED_CFG('A', 8, AVB_TX_CTL, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 9, AVB_MDIO, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 12, AVB_TXCREFCLK, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 13, AVB_RD0, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 14, AVB_RD2, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 16, AVB_RX_CTL, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 17, AVB_TD2, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 18, AVB_TD0, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('A', 19, AVB_TXC, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('B', 13, AVB_RD1, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('B', 14, AVB_RD3, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('B', 17, AVB_TD3, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('B', 18, AVB_TD1, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('B', 19, AVB_RXC, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('C', 1, PRESETOUT#, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('H', 37, MLB_REF, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('V', 3, QSPI1_SPCLK, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('V', 5, QSPI1_SSL, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('V', 6, RPC_WP#, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('V', 7, RPC_RESET#, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('W', 3, QSPI0_SPCLK, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('Y', 3, QSPI0_SSL, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('Y', 6, QSPI0_IO2, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG('Y', 7, RPC_INT#, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('B'), 4, QSPI0_MISO_IO1, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('B'), 6, QSPI0_IO3, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('C'), 3, QSPI1_IO3, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('C'), 5, QSPI0_MOSI_IO0, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('C'), 7, QSPI1_MOSI_IO0, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('D'), 38, FSCLKST, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('D'), 39, EXTALR, SH_PFC_PIN_CFG_PULL_UP | SH_PFC_PIN_CFG_PULL_DOWN), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('E'), 4, QSPI1_IO2, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('E'), 5, QSPI1_MISO_IO1, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('P'), 7, DU_DOTCLKIN0, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('P'), 8, DU_DOTCLKIN1, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('R'), 8, DU_DOTCLKIN2, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('R'), 26, TRST#, SH_PFC_PIN_CFG_PULL_UP | SH_PFC_PIN_CFG_PULL_DOWN), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('R'), 29, TDI, SH_PFC_PIN_CFG_PULL_UP | SH_PFC_PIN_CFG_PULL_DOWN), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('R'), 30, TMS, CFG_FLAGS), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('T'), 27, TCK, SH_PFC_PIN_CFG_PULL_UP | SH_PFC_PIN_CFG_PULL_DOWN), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('T'), 28, TDO, SH_PFC_PIN_CFG_DRIVE_STRENGTH), + SH_PFC_PIN_NAMED_CFG(ROW_GROUP_A('T'), 30, ASEBRK, CFG_FLAGS), +}; + +/* - AUDIO CLOCK ------------------------------------------------------------ */ +static const unsigned int audio_clk_a_a_pins[] = { + /* CLK A */ + RCAR_GP_PIN(6, 22), +}; +static const unsigned int audio_clk_a_a_mux[] = { + AUDIO_CLKA_A_MARK, +}; +static const unsigned int audio_clk_a_b_pins[] = { + /* CLK A */ + RCAR_GP_PIN(5, 4), +}; +static const unsigned int audio_clk_a_b_mux[] = { + AUDIO_CLKA_B_MARK, +}; +static const unsigned int audio_clk_a_c_pins[] = { + /* CLK A */ + RCAR_GP_PIN(5, 19), +}; +static const unsigned int audio_clk_a_c_mux[] = { + AUDIO_CLKA_C_MARK, +}; +static const unsigned int audio_clk_b_a_pins[] = { + /* CLK B */ + RCAR_GP_PIN(5, 12), +}; +static const unsigned int audio_clk_b_a_mux[] = { + AUDIO_CLKB_A_MARK, +}; +static const unsigned int audio_clk_b_b_pins[] = { + /* CLK B */ + RCAR_GP_PIN(6, 23), +}; +static const unsigned int audio_clk_b_b_mux[] = { + AUDIO_CLKB_B_MARK, +}; +static const unsigned int audio_clk_c_a_pins[] = { + /* CLK C */ + RCAR_GP_PIN(5, 21), +}; +static const unsigned int audio_clk_c_a_mux[] = { + AUDIO_CLKC_A_MARK, +}; +static const unsigned int audio_clk_c_b_pins[] = { + /* CLK C */ + RCAR_GP_PIN(5, 0), +}; +static const unsigned int audio_clk_c_b_mux[] = { + AUDIO_CLKC_B_MARK, +}; +static const unsigned int audio_clkout_a_pins[] = { + /* CLKOUT */ + RCAR_GP_PIN(5, 18), +}; +static const unsigned int audio_clkout_a_mux[] = { + AUDIO_CLKOUT_A_MARK, +}; +static const unsigned int audio_clkout_b_pins[] = { + /* CLKOUT */ + RCAR_GP_PIN(6, 28), +}; +static const unsigned int audio_clkout_b_mux[] = { + AUDIO_CLKOUT_B_MARK, +}; +static const unsigned int audio_clkout_c_pins[] = { + /* CLKOUT */ + RCAR_GP_PIN(5, 3), +}; +static const unsigned int audio_clkout_c_mux[] = { + AUDIO_CLKOUT_C_MARK, +}; +static const unsigned int audio_clkout_d_pins[] = { + /* CLKOUT */ + RCAR_GP_PIN(5, 21), +}; +static const unsigned int audio_clkout_d_mux[] = { + AUDIO_CLKOUT_D_MARK, +}; +static const unsigned int audio_clkout1_a_pins[] = { + /* CLKOUT1 */ + RCAR_GP_PIN(5, 15), +}; +static const unsigned int audio_clkout1_a_mux[] = { + AUDIO_CLKOUT1_A_MARK, +}; +static const unsigned int audio_clkout1_b_pins[] = { + /* CLKOUT1 */ + RCAR_GP_PIN(6, 29), +}; +static const unsigned int audio_clkout1_b_mux[] = { + AUDIO_CLKOUT1_B_MARK, +}; +static const unsigned int audio_clkout2_a_pins[] = { + /* CLKOUT2 */ + RCAR_GP_PIN(5, 16), +}; +static const unsigned int audio_clkout2_a_mux[] = { + AUDIO_CLKOUT2_A_MARK, +}; +static const unsigned int audio_clkout2_b_pins[] = { + /* CLKOUT2 */ + RCAR_GP_PIN(6, 30), +}; +static const unsigned int audio_clkout2_b_mux[] = { + AUDIO_CLKOUT2_B_MARK, +}; + +static const unsigned int audio_clkout3_a_pins[] = { + /* CLKOUT3 */ + RCAR_GP_PIN(5, 19), +}; +static const unsigned int audio_clkout3_a_mux[] = { + AUDIO_CLKOUT3_A_MARK, +}; +static const unsigned int audio_clkout3_b_pins[] = { + /* CLKOUT3 */ + RCAR_GP_PIN(6, 31), +}; +static const unsigned int audio_clkout3_b_mux[] = { + AUDIO_CLKOUT3_B_MARK, +}; + +/* - EtherAVB --------------------------------------------------------------- */ +static const unsigned int avb_link_pins[] = { + /* AVB_LINK */ + RCAR_GP_PIN(2, 12), +}; +static const unsigned int avb_link_mux[] = { + AVB_LINK_MARK, +}; +static const unsigned int avb_magic_pins[] = { + /* AVB_MAGIC_ */ + RCAR_GP_PIN(2, 10), +}; +static const unsigned int avb_magic_mux[] = { + AVB_MAGIC_MARK, +}; +static const unsigned int avb_phy_int_pins[] = { + /* AVB_PHY_INT */ + RCAR_GP_PIN(2, 11), +}; +static const unsigned int avb_phy_int_mux[] = { + AVB_PHY_INT_MARK, +}; +static const unsigned int avb_mdio_pins[] = { + /* AVB_MDC, AVB_MDIO */ + RCAR_GP_PIN(2, 9), PIN_NUMBER('A', 9), +}; +static const unsigned int avb_mdio_mux[] = { + AVB_MDC_MARK, AVB_MDIO_MARK, +}; +static const unsigned int avb_mii_pins[] = { + /* + * AVB_TX_CTL, AVB_TXC, AVB_TD0, + * AVB_TD1, AVB_TD2, AVB_TD3, + * AVB_RX_CTL, AVB_RXC, AVB_RD0, + * AVB_RD1, AVB_RD2, AVB_RD3, + * AVB_TXCREFCLK + */ + PIN_NUMBER('A', 8), PIN_NUMBER('A', 19), PIN_NUMBER('A', 18), + PIN_NUMBER('B', 18), PIN_NUMBER('A', 17), PIN_NUMBER('B', 17), + PIN_NUMBER('A', 16), PIN_NUMBER('B', 19), PIN_NUMBER('A', 13), + PIN_NUMBER('B', 13), PIN_NUMBER('A', 14), PIN_NUMBER('B', 14), + PIN_NUMBER('A', 12), + +}; +static const unsigned int avb_mii_mux[] = { + AVB_TX_CTL_MARK, AVB_TXC_MARK, AVB_TD0_MARK, + AVB_TD1_MARK, AVB_TD2_MARK, AVB_TD3_MARK, + AVB_RX_CTL_MARK, AVB_RXC_MARK, AVB_RD0_MARK, + AVB_RD1_MARK, AVB_RD2_MARK, AVB_RD3_MARK, + AVB_TXCREFCLK_MARK, +}; +static const unsigned int avb_avtp_pps_pins[] = { + /* AVB_AVTP_PPS */ + RCAR_GP_PIN(2, 6), +}; +static const unsigned int avb_avtp_pps_mux[] = { + AVB_AVTP_PPS_MARK, +}; +static const unsigned int avb_avtp_match_a_pins[] = { + /* AVB_AVTP_MATCH_A */ + RCAR_GP_PIN(2, 13), +}; +static const unsigned int avb_avtp_match_a_mux[] = { + AVB_AVTP_MATCH_A_MARK, +}; +static const unsigned int avb_avtp_capture_a_pins[] = { + /* AVB_AVTP_CAPTURE_A */ + RCAR_GP_PIN(2, 14), +}; +static const unsigned int avb_avtp_capture_a_mux[] = { + AVB_AVTP_CAPTURE_A_MARK, +}; +static const unsigned int avb_avtp_match_b_pins[] = { + /* AVB_AVTP_MATCH_B */ + RCAR_GP_PIN(1, 8), +}; +static const unsigned int avb_avtp_match_b_mux[] = { + AVB_AVTP_MATCH_B_MARK, +}; +static const unsigned int avb_avtp_capture_b_pins[] = { + /* AVB_AVTP_CAPTURE_B */ + RCAR_GP_PIN(1, 11), +}; +static const unsigned int avb_avtp_capture_b_mux[] = { + AVB_AVTP_CAPTURE_B_MARK, +}; + +/* - CAN ------------------------------------------------------------------ */ +static const unsigned int can0_data_a_pins[] = { + /* TX, RX */ + RCAR_GP_PIN(1, 23), RCAR_GP_PIN(1, 24), +}; +static const unsigned int can0_data_a_mux[] = { + CAN0_TX_A_MARK, CAN0_RX_A_MARK, +}; +static const unsigned int can0_data_b_pins[] = { + /* TX, RX */ + RCAR_GP_PIN(2, 0), RCAR_GP_PIN(2, 1), +}; +static const unsigned int can0_data_b_mux[] = { + CAN0_TX_B_MARK, CAN0_RX_B_MARK, +}; +static const unsigned int can1_data_pins[] = { + /* TX, RX */ + RCAR_GP_PIN(1, 22), RCAR_GP_PIN(1, 26), +}; +static const unsigned int can1_data_mux[] = { + CAN1_TX_MARK, CAN1_RX_MARK, +}; + +/* - CAN Clock -------------------------------------------------------------- */ +static const unsigned int can_clk_pins[] = { + /* CLK */ + RCAR_GP_PIN(1, 25), +}; +static const unsigned int can_clk_mux[] = { + CAN_CLK_MARK, +}; + +/* - CAN FD --------------------------------------------------------------- */ +static const unsigned int canfd0_data_a_pins[] = { + /* TX, RX */ + RCAR_GP_PIN(1, 23), RCAR_GP_PIN(1, 24), +}; +static const unsigned int canfd0_data_a_mux[] = { + CANFD0_TX_A_MARK, CANFD0_RX_A_MARK, +}; +static const unsigned int canfd0_data_b_pins[] = { + /* TX, RX */ + RCAR_GP_PIN(2, 0), RCAR_GP_PIN(2, 1), +}; +static const unsigned int canfd0_data_b_mux[] = { + CANFD0_TX_B_MARK, CANFD0_RX_B_MARK, +}; +static const unsigned int canfd1_data_pins[] = { + /* TX, RX */ + RCAR_GP_PIN(1, 22), RCAR_GP_PIN(1, 26), +}; +static const unsigned int canfd1_data_mux[] = { + CANFD1_TX_MARK, CANFD1_RX_MARK, +}; + +/* - DRIF0 --------------------------------------------------------------- */ +static const unsigned int drif0_ctrl_a_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(6, 8), RCAR_GP_PIN(6, 9), +}; +static const unsigned int drif0_ctrl_a_mux[] = { + RIF0_CLK_A_MARK, RIF0_SYNC_A_MARK, +}; +static const unsigned int drif0_data0_a_pins[] = { + /* D0 */ + RCAR_GP_PIN(6, 10), +}; +static const unsigned int drif0_data0_a_mux[] = { + RIF0_D0_A_MARK, +}; +static const unsigned int drif0_data1_a_pins[] = { + /* D1 */ + RCAR_GP_PIN(6, 7), +}; +static const unsigned int drif0_data1_a_mux[] = { + RIF0_D1_A_MARK, +}; +static const unsigned int drif0_ctrl_b_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(5, 0), RCAR_GP_PIN(5, 4), +}; +static const unsigned int drif0_ctrl_b_mux[] = { + RIF0_CLK_B_MARK, RIF0_SYNC_B_MARK, +}; +static const unsigned int drif0_data0_b_pins[] = { + /* D0 */ + RCAR_GP_PIN(5, 1), +}; +static const unsigned int drif0_data0_b_mux[] = { + RIF0_D0_B_MARK, +}; +static const unsigned int drif0_data1_b_pins[] = { + /* D1 */ + RCAR_GP_PIN(5, 2), +}; +static const unsigned int drif0_data1_b_mux[] = { + RIF0_D1_B_MARK, +}; +static const unsigned int drif0_ctrl_c_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(5, 12), RCAR_GP_PIN(5, 15), +}; +static const unsigned int drif0_ctrl_c_mux[] = { + RIF0_CLK_C_MARK, RIF0_SYNC_C_MARK, +}; +static const unsigned int drif0_data0_c_pins[] = { + /* D0 */ + RCAR_GP_PIN(5, 13), +}; +static const unsigned int drif0_data0_c_mux[] = { + RIF0_D0_C_MARK, +}; +static const unsigned int drif0_data1_c_pins[] = { + /* D1 */ + RCAR_GP_PIN(5, 14), +}; +static const unsigned int drif0_data1_c_mux[] = { + RIF0_D1_C_MARK, +}; +/* - DRIF1 --------------------------------------------------------------- */ +static const unsigned int drif1_ctrl_a_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(6, 17), RCAR_GP_PIN(6, 18), +}; +static const unsigned int drif1_ctrl_a_mux[] = { + RIF1_CLK_A_MARK, RIF1_SYNC_A_MARK, +}; +static const unsigned int drif1_data0_a_pins[] = { + /* D0 */ + RCAR_GP_PIN(6, 19), +}; +static const unsigned int drif1_data0_a_mux[] = { + RIF1_D0_A_MARK, +}; +static const unsigned int drif1_data1_a_pins[] = { + /* D1 */ + RCAR_GP_PIN(6, 20), +}; +static const unsigned int drif1_data1_a_mux[] = { + RIF1_D1_A_MARK, +}; +static const unsigned int drif1_ctrl_b_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(5, 9), RCAR_GP_PIN(5, 3), +}; +static const unsigned int drif1_ctrl_b_mux[] = { + RIF1_CLK_B_MARK, RIF1_SYNC_B_MARK, +}; +static const unsigned int drif1_data0_b_pins[] = { + /* D0 */ + RCAR_GP_PIN(5, 7), +}; +static const unsigned int drif1_data0_b_mux[] = { + RIF1_D0_B_MARK, +}; +static const unsigned int drif1_data1_b_pins[] = { + /* D1 */ + RCAR_GP_PIN(5, 8), +}; +static const unsigned int drif1_data1_b_mux[] = { + RIF1_D1_B_MARK, +}; +static const unsigned int drif1_ctrl_c_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(5, 5), RCAR_GP_PIN(5, 11), +}; +static const unsigned int drif1_ctrl_c_mux[] = { + RIF1_CLK_C_MARK, RIF1_SYNC_C_MARK, +}; +static const unsigned int drif1_data0_c_pins[] = { + /* D0 */ + RCAR_GP_PIN(5, 6), +}; +static const unsigned int drif1_data0_c_mux[] = { + RIF1_D0_C_MARK, +}; +static const unsigned int drif1_data1_c_pins[] = { + /* D1 */ + RCAR_GP_PIN(5, 10), +}; +static const unsigned int drif1_data1_c_mux[] = { + RIF1_D1_C_MARK, +}; +/* - DRIF2 --------------------------------------------------------------- */ +static const unsigned int drif2_ctrl_a_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(6, 8), RCAR_GP_PIN(6, 9), +}; +static const unsigned int drif2_ctrl_a_mux[] = { + RIF2_CLK_A_MARK, RIF2_SYNC_A_MARK, +}; +static const unsigned int drif2_data0_a_pins[] = { + /* D0 */ + RCAR_GP_PIN(6, 7), +}; +static const unsigned int drif2_data0_a_mux[] = { + RIF2_D0_A_MARK, +}; +static const unsigned int drif2_data1_a_pins[] = { + /* D1 */ + RCAR_GP_PIN(6, 10), +}; +static const unsigned int drif2_data1_a_mux[] = { + RIF2_D1_A_MARK, +}; +static const unsigned int drif2_ctrl_b_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(6, 26), RCAR_GP_PIN(6, 27), +}; +static const unsigned int drif2_ctrl_b_mux[] = { + RIF2_CLK_B_MARK, RIF2_SYNC_B_MARK, +}; +static const unsigned int drif2_data0_b_pins[] = { + /* D0 */ + RCAR_GP_PIN(6, 30), +}; +static const unsigned int drif2_data0_b_mux[] = { + RIF2_D0_B_MARK, +}; +static const unsigned int drif2_data1_b_pins[] = { + /* D1 */ + RCAR_GP_PIN(6, 31), +}; +static const unsigned int drif2_data1_b_mux[] = { + RIF2_D1_B_MARK, +}; +/* - DRIF3 --------------------------------------------------------------- */ +static const unsigned int drif3_ctrl_a_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(6, 17), RCAR_GP_PIN(6, 18), +}; +static const unsigned int drif3_ctrl_a_mux[] = { + RIF3_CLK_A_MARK, RIF3_SYNC_A_MARK, +}; +static const unsigned int drif3_data0_a_pins[] = { + /* D0 */ + RCAR_GP_PIN(6, 19), +}; +static const unsigned int drif3_data0_a_mux[] = { + RIF3_D0_A_MARK, +}; +static const unsigned int drif3_data1_a_pins[] = { + /* D1 */ + RCAR_GP_PIN(6, 20), +}; +static const unsigned int drif3_data1_a_mux[] = { + RIF3_D1_A_MARK, +}; +static const unsigned int drif3_ctrl_b_pins[] = { + /* CLK, SYNC */ + RCAR_GP_PIN(6, 24), RCAR_GP_PIN(6, 25), +}; +static const unsigned int drif3_ctrl_b_mux[] = { + RIF3_CLK_B_MARK, RIF3_SYNC_B_MARK, +}; +static const unsigned int drif3_data0_b_pins[] = { + /* D0 */ + RCAR_GP_PIN(6, 28), +}; +static const unsigned int drif3_data0_b_mux[] = { + RIF3_D0_B_MARK, +}; +static const unsigned int drif3_data1_b_pins[] = { + /* D1 */ + RCAR_GP_PIN(6, 29), +}; +static const unsigned int drif3_data1_b_mux[] = { + RIF3_D1_B_MARK, +}; + +/* - DU --------------------------------------------------------------------- */ +static const unsigned int du_rgb666_pins[] = { + /* R[7:2], G[7:2], B[7:2] */ + RCAR_GP_PIN(0, 15), RCAR_GP_PIN(0, 14), RCAR_GP_PIN(0, 13), + RCAR_GP_PIN(0, 12), RCAR_GP_PIN(0, 11), RCAR_GP_PIN(0, 10), + RCAR_GP_PIN(1, 15), RCAR_GP_PIN(1, 14), RCAR_GP_PIN(1, 13), + RCAR_GP_PIN(1, 12), RCAR_GP_PIN(1, 19), RCAR_GP_PIN(1, 18), + RCAR_GP_PIN(1, 7), RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 3), RCAR_GP_PIN(1, 2), +}; +static const unsigned int du_rgb666_mux[] = { + DU_DR7_MARK, DU_DR6_MARK, DU_DR5_MARK, DU_DR4_MARK, + DU_DR3_MARK, DU_DR2_MARK, + DU_DG7_MARK, DU_DG6_MARK, DU_DG5_MARK, DU_DG4_MARK, + DU_DG3_MARK, DU_DG2_MARK, + DU_DB7_MARK, DU_DB6_MARK, DU_DB5_MARK, DU_DB4_MARK, + DU_DB3_MARK, DU_DB2_MARK, +}; +static const unsigned int du_rgb888_pins[] = { + /* R[7:0], G[7:0], B[7:0] */ + RCAR_GP_PIN(0, 15), RCAR_GP_PIN(0, 14), RCAR_GP_PIN(0, 13), + RCAR_GP_PIN(0, 12), RCAR_GP_PIN(0, 11), RCAR_GP_PIN(0, 10), + RCAR_GP_PIN(0, 9), RCAR_GP_PIN(0, 8), + RCAR_GP_PIN(1, 15), RCAR_GP_PIN(1, 14), RCAR_GP_PIN(1, 13), + RCAR_GP_PIN(1, 12), RCAR_GP_PIN(1, 19), RCAR_GP_PIN(1, 18), + RCAR_GP_PIN(1, 17), RCAR_GP_PIN(1, 16), + RCAR_GP_PIN(1, 7), RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 3), RCAR_GP_PIN(1, 2), + RCAR_GP_PIN(1, 1), RCAR_GP_PIN(1, 0), +}; +static const unsigned int du_rgb888_mux[] = { + DU_DR7_MARK, DU_DR6_MARK, DU_DR5_MARK, DU_DR4_MARK, + DU_DR3_MARK, DU_DR2_MARK, DU_DR1_MARK, DU_DR0_MARK, + DU_DG7_MARK, DU_DG6_MARK, DU_DG5_MARK, DU_DG4_MARK, + DU_DG3_MARK, DU_DG2_MARK, DU_DG1_MARK, DU_DG0_MARK, + DU_DB7_MARK, DU_DB6_MARK, DU_DB5_MARK, DU_DB4_MARK, + DU_DB3_MARK, DU_DB2_MARK, DU_DB1_MARK, DU_DB0_MARK, +}; +static const unsigned int du_clk_out_0_pins[] = { + /* CLKOUT */ + RCAR_GP_PIN(1, 27), +}; +static const unsigned int du_clk_out_0_mux[] = { + DU_DOTCLKOUT0_MARK +}; +static const unsigned int du_clk_out_1_pins[] = { + /* CLKOUT */ + RCAR_GP_PIN(2, 3), +}; +static const unsigned int du_clk_out_1_mux[] = { + DU_DOTCLKOUT1_MARK +}; +static const unsigned int du_sync_pins[] = { + /* EXVSYNC/VSYNC, EXHSYNC/HSYNC */ + RCAR_GP_PIN(2, 5), RCAR_GP_PIN(2, 4), +}; +static const unsigned int du_sync_mux[] = { + DU_EXVSYNC_DU_VSYNC_MARK, DU_EXHSYNC_DU_HSYNC_MARK +}; +static const unsigned int du_oddf_pins[] = { + /* EXDISP/EXODDF/EXCDE */ + RCAR_GP_PIN(2, 2), +}; +static const unsigned int du_oddf_mux[] = { + DU_EXODDF_DU_ODDF_DISP_CDE_MARK, +}; +static const unsigned int du_cde_pins[] = { + /* CDE */ + RCAR_GP_PIN(2, 0), +}; +static const unsigned int du_cde_mux[] = { + DU_CDE_MARK, +}; +static const unsigned int du_disp_pins[] = { + /* DISP */ + RCAR_GP_PIN(2, 1), +}; +static const unsigned int du_disp_mux[] = { + DU_DISP_MARK, +}; + +/* - GP7_02/03 -------------------------------------------------------------- */ +static const unsigned int gp7_02_pins[] = { + /* GP7_02 */ + RCAR_GP_PIN(7, 2), +}; + +static const unsigned int gp7_02_mux[] = { + GP7_02_MARK, +}; + +static const unsigned int gp7_03_pins[] = { + /* GP7_03 */ + RCAR_GP_PIN(7, 3), +}; + +static const unsigned int gp7_03_mux[] = { + GP7_03_MARK, +}; + +/* - HSCIF0 ----------------------------------------------------------------- */ +static const unsigned int hscif0_data_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 13), RCAR_GP_PIN(5, 14), +}; +static const unsigned int hscif0_data_mux[] = { + HRX0_MARK, HTX0_MARK, +}; +static const unsigned int hscif0_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 12), +}; +static const unsigned int hscif0_clk_mux[] = { + HSCK0_MARK, +}; +static const unsigned int hscif0_ctrl_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(5, 16), RCAR_GP_PIN(5, 15), +}; +static const unsigned int hscif0_ctrl_mux[] = { + HRTS0_N_MARK, HCTS0_N_MARK, +}; +/* - HSCIF1 ----------------------------------------------------------------- */ +static const unsigned int hscif1_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 5), RCAR_GP_PIN(5, 6), +}; +static const unsigned int hscif1_data_a_mux[] = { + HRX1_A_MARK, HTX1_A_MARK, +}; +static const unsigned int hscif1_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 21), +}; +static const unsigned int hscif1_clk_a_mux[] = { + HSCK1_A_MARK, +}; +static const unsigned int hscif1_ctrl_a_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(5, 8), RCAR_GP_PIN(5, 7), +}; +static const unsigned int hscif1_ctrl_a_mux[] = { + HRTS1_N_A_MARK, HCTS1_N_A_MARK, +}; + +static const unsigned int hscif1_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 1), RCAR_GP_PIN(5, 2), +}; +static const unsigned int hscif1_data_b_mux[] = { + HRX1_B_MARK, HTX1_B_MARK, +}; +static const unsigned int hscif1_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 0), +}; +static const unsigned int hscif1_clk_b_mux[] = { + HSCK1_B_MARK, +}; +static const unsigned int hscif1_ctrl_b_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(5, 4), RCAR_GP_PIN(5, 3), +}; +static const unsigned int hscif1_ctrl_b_mux[] = { + HRTS1_N_B_MARK, HCTS1_N_B_MARK, +}; +/* - HSCIF2 ----------------------------------------------------------------- */ +static const unsigned int hscif2_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(6, 8), RCAR_GP_PIN(6, 9), +}; +static const unsigned int hscif2_data_a_mux[] = { + HRX2_A_MARK, HTX2_A_MARK, +}; +static const unsigned int hscif2_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 10), +}; +static const unsigned int hscif2_clk_a_mux[] = { + HSCK2_A_MARK, +}; +static const unsigned int hscif2_ctrl_a_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(6, 7), RCAR_GP_PIN(6, 6), +}; +static const unsigned int hscif2_ctrl_a_mux[] = { + HRTS2_N_A_MARK, HCTS2_N_A_MARK, +}; + +static const unsigned int hscif2_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(6, 17), RCAR_GP_PIN(6, 18), +}; +static const unsigned int hscif2_data_b_mux[] = { + HRX2_B_MARK, HTX2_B_MARK, +}; +static const unsigned int hscif2_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 21), +}; +static const unsigned int hscif2_clk_b_mux[] = { + HSCK2_B_MARK, +}; +static const unsigned int hscif2_ctrl_b_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(6, 20), RCAR_GP_PIN(6, 19), +}; +static const unsigned int hscif2_ctrl_b_mux[] = { + HRTS2_N_B_MARK, HCTS2_N_B_MARK, +}; + +static const unsigned int hscif2_data_c_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(6, 25), RCAR_GP_PIN(6, 26), +}; +static const unsigned int hscif2_data_c_mux[] = { + HRX2_C_MARK, HTX2_C_MARK, +}; +static const unsigned int hscif2_clk_c_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 24), +}; +static const unsigned int hscif2_clk_c_mux[] = { + HSCK2_C_MARK, +}; +static const unsigned int hscif2_ctrl_c_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(6, 28), RCAR_GP_PIN(6, 27), +}; +static const unsigned int hscif2_ctrl_c_mux[] = { + HRTS2_N_C_MARK, HCTS2_N_C_MARK, +}; +/* - HSCIF3 ----------------------------------------------------------------- */ +static const unsigned int hscif3_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(1, 23), RCAR_GP_PIN(1, 24), +}; +static const unsigned int hscif3_data_a_mux[] = { + HRX3_A_MARK, HTX3_A_MARK, +}; +static const unsigned int hscif3_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 22), +}; +static const unsigned int hscif3_clk_mux[] = { + HSCK3_MARK, +}; +static const unsigned int hscif3_ctrl_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(1, 26), RCAR_GP_PIN(1, 25), +}; +static const unsigned int hscif3_ctrl_mux[] = { + HRTS3_N_MARK, HCTS3_N_MARK, +}; + +static const unsigned int hscif3_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(0, 10), RCAR_GP_PIN(0, 11), +}; +static const unsigned int hscif3_data_b_mux[] = { + HRX3_B_MARK, HTX3_B_MARK, +}; +static const unsigned int hscif3_data_c_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(0, 14), RCAR_GP_PIN(0, 15), +}; +static const unsigned int hscif3_data_c_mux[] = { + HRX3_C_MARK, HTX3_C_MARK, +}; +static const unsigned int hscif3_data_d_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(2, 7), RCAR_GP_PIN(2, 8), +}; +static const unsigned int hscif3_data_d_mux[] = { + HRX3_D_MARK, HTX3_D_MARK, +}; +/* - HSCIF4 ----------------------------------------------------------------- */ +static const unsigned int hscif4_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(1, 12), RCAR_GP_PIN(1, 13), +}; +static const unsigned int hscif4_data_a_mux[] = { + HRX4_A_MARK, HTX4_A_MARK, +}; +static const unsigned int hscif4_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 11), +}; +static const unsigned int hscif4_clk_mux[] = { + HSCK4_MARK, +}; +static const unsigned int hscif4_ctrl_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(1, 15), RCAR_GP_PIN(1, 14), +}; +static const unsigned int hscif4_ctrl_mux[] = { + HRTS4_N_MARK, HCTS4_N_MARK, +}; + +static const unsigned int hscif4_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(1, 8), RCAR_GP_PIN(1, 11), +}; +static const unsigned int hscif4_data_b_mux[] = { + HRX4_B_MARK, HTX4_B_MARK, +}; + +/* - I2C -------------------------------------------------------------------- */ +static const unsigned int i2c1_a_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(5, 11), RCAR_GP_PIN(5, 10), +}; +static const unsigned int i2c1_a_mux[] = { + SDA1_A_MARK, SCL1_A_MARK, +}; +static const unsigned int i2c1_b_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(5, 24), RCAR_GP_PIN(5, 23), +}; +static const unsigned int i2c1_b_mux[] = { + SDA1_B_MARK, SCL1_B_MARK, +}; +static const unsigned int i2c2_a_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(5, 0), RCAR_GP_PIN(5, 4), +}; +static const unsigned int i2c2_a_mux[] = { + SDA2_A_MARK, SCL2_A_MARK, +}; +static const unsigned int i2c2_b_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(3, 13), RCAR_GP_PIN(3, 12), +}; +static const unsigned int i2c2_b_mux[] = { + SDA2_B_MARK, SCL2_B_MARK, +}; +static const unsigned int i2c6_a_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(1, 8), RCAR_GP_PIN(1, 11), +}; +static const unsigned int i2c6_a_mux[] = { + SDA6_A_MARK, SCL6_A_MARK, +}; +static const unsigned int i2c6_b_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(1, 26), RCAR_GP_PIN(1, 25), +}; +static const unsigned int i2c6_b_mux[] = { + SDA6_B_MARK, SCL6_B_MARK, +}; +static const unsigned int i2c6_c_pins[] = { + /* SDA, SCL */ + RCAR_GP_PIN(0, 15), RCAR_GP_PIN(0, 14), +}; +static const unsigned int i2c6_c_mux[] = { + SDA6_C_MARK, SCL6_C_MARK, +}; + +/* - INTC-EX ---------------------------------------------------------------- */ +static const unsigned int intc_ex_irq0_pins[] = { + /* IRQ0 */ + RCAR_GP_PIN(2, 0), +}; +static const unsigned int intc_ex_irq0_mux[] = { + IRQ0_MARK, +}; +static const unsigned int intc_ex_irq1_pins[] = { + /* IRQ1 */ + RCAR_GP_PIN(2, 1), +}; +static const unsigned int intc_ex_irq1_mux[] = { + IRQ1_MARK, +}; +static const unsigned int intc_ex_irq2_pins[] = { + /* IRQ2 */ + RCAR_GP_PIN(2, 2), +}; +static const unsigned int intc_ex_irq2_mux[] = { + IRQ2_MARK, +}; +static const unsigned int intc_ex_irq3_pins[] = { + /* IRQ3 */ + RCAR_GP_PIN(2, 3), +}; +static const unsigned int intc_ex_irq3_mux[] = { + IRQ3_MARK, +}; +static const unsigned int intc_ex_irq4_pins[] = { + /* IRQ4 */ + RCAR_GP_PIN(2, 4), +}; +static const unsigned int intc_ex_irq4_mux[] = { + IRQ4_MARK, +}; +static const unsigned int intc_ex_irq5_pins[] = { + /* IRQ5 */ + RCAR_GP_PIN(2, 5), +}; +static const unsigned int intc_ex_irq5_mux[] = { + IRQ5_MARK, +}; + +/* - MSIOF0 ----------------------------------------------------------------- */ +static const unsigned int msiof0_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 17), +}; +static const unsigned int msiof0_clk_mux[] = { + MSIOF0_SCK_MARK, +}; +static const unsigned int msiof0_sync_pins[] = { + /* SYNC */ + RCAR_GP_PIN(5, 18), +}; +static const unsigned int msiof0_sync_mux[] = { + MSIOF0_SYNC_MARK, +}; +static const unsigned int msiof0_ss1_pins[] = { + /* SS1 */ + RCAR_GP_PIN(5, 19), +}; +static const unsigned int msiof0_ss1_mux[] = { + MSIOF0_SS1_MARK, +}; +static const unsigned int msiof0_ss2_pins[] = { + /* SS2 */ + RCAR_GP_PIN(5, 21), +}; +static const unsigned int msiof0_ss2_mux[] = { + MSIOF0_SS2_MARK, +}; +static const unsigned int msiof0_txd_pins[] = { + /* TXD */ + RCAR_GP_PIN(5, 20), +}; +static const unsigned int msiof0_txd_mux[] = { + MSIOF0_TXD_MARK, +}; +static const unsigned int msiof0_rxd_pins[] = { + /* RXD */ + RCAR_GP_PIN(5, 22), +}; +static const unsigned int msiof0_rxd_mux[] = { + MSIOF0_RXD_MARK, +}; +/* - MSIOF1 ----------------------------------------------------------------- */ +static const unsigned int msiof1_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 8), +}; +static const unsigned int msiof1_clk_a_mux[] = { + MSIOF1_SCK_A_MARK, +}; +static const unsigned int msiof1_sync_a_pins[] = { + /* SYNC */ + RCAR_GP_PIN(6, 9), +}; +static const unsigned int msiof1_sync_a_mux[] = { + MSIOF1_SYNC_A_MARK, +}; +static const unsigned int msiof1_ss1_a_pins[] = { + /* SS1 */ + RCAR_GP_PIN(6, 5), +}; +static const unsigned int msiof1_ss1_a_mux[] = { + MSIOF1_SS1_A_MARK, +}; +static const unsigned int msiof1_ss2_a_pins[] = { + /* SS2 */ + RCAR_GP_PIN(6, 6), +}; +static const unsigned int msiof1_ss2_a_mux[] = { + MSIOF1_SS2_A_MARK, +}; +static const unsigned int msiof1_txd_a_pins[] = { + /* TXD */ + RCAR_GP_PIN(6, 7), +}; +static const unsigned int msiof1_txd_a_mux[] = { + MSIOF1_TXD_A_MARK, +}; +static const unsigned int msiof1_rxd_a_pins[] = { + /* RXD */ + RCAR_GP_PIN(6, 10), +}; +static const unsigned int msiof1_rxd_a_mux[] = { + MSIOF1_RXD_A_MARK, +}; +static const unsigned int msiof1_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 9), +}; +static const unsigned int msiof1_clk_b_mux[] = { + MSIOF1_SCK_B_MARK, +}; +static const unsigned int msiof1_sync_b_pins[] = { + /* SYNC */ + RCAR_GP_PIN(5, 3), +}; +static const unsigned int msiof1_sync_b_mux[] = { + MSIOF1_SYNC_B_MARK, +}; +static const unsigned int msiof1_ss1_b_pins[] = { + /* SS1 */ + RCAR_GP_PIN(5, 4), +}; +static const unsigned int msiof1_ss1_b_mux[] = { + MSIOF1_SS1_B_MARK, +}; +static const unsigned int msiof1_ss2_b_pins[] = { + /* SS2 */ + RCAR_GP_PIN(5, 0), +}; +static const unsigned int msiof1_ss2_b_mux[] = { + MSIOF1_SS2_B_MARK, +}; +static const unsigned int msiof1_txd_b_pins[] = { + /* TXD */ + RCAR_GP_PIN(5, 8), +}; +static const unsigned int msiof1_txd_b_mux[] = { + MSIOF1_TXD_B_MARK, +}; +static const unsigned int msiof1_rxd_b_pins[] = { + /* RXD */ + RCAR_GP_PIN(5, 7), +}; +static const unsigned int msiof1_rxd_b_mux[] = { + MSIOF1_RXD_B_MARK, +}; +static const unsigned int msiof1_clk_c_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 17), +}; +static const unsigned int msiof1_clk_c_mux[] = { + MSIOF1_SCK_C_MARK, +}; +static const unsigned int msiof1_sync_c_pins[] = { + /* SYNC */ + RCAR_GP_PIN(6, 18), +}; +static const unsigned int msiof1_sync_c_mux[] = { + MSIOF1_SYNC_C_MARK, +}; +static const unsigned int msiof1_ss1_c_pins[] = { + /* SS1 */ + RCAR_GP_PIN(6, 21), +}; +static const unsigned int msiof1_ss1_c_mux[] = { + MSIOF1_SS1_C_MARK, +}; +static const unsigned int msiof1_ss2_c_pins[] = { + /* SS2 */ + RCAR_GP_PIN(6, 27), +}; +static const unsigned int msiof1_ss2_c_mux[] = { + MSIOF1_SS2_C_MARK, +}; +static const unsigned int msiof1_txd_c_pins[] = { + /* TXD */ + RCAR_GP_PIN(6, 20), +}; +static const unsigned int msiof1_txd_c_mux[] = { + MSIOF1_TXD_C_MARK, +}; +static const unsigned int msiof1_rxd_c_pins[] = { + /* RXD */ + RCAR_GP_PIN(6, 19), +}; +static const unsigned int msiof1_rxd_c_mux[] = { + MSIOF1_RXD_C_MARK, +}; +static const unsigned int msiof1_clk_d_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 12), +}; +static const unsigned int msiof1_clk_d_mux[] = { + MSIOF1_SCK_D_MARK, +}; +static const unsigned int msiof1_sync_d_pins[] = { + /* SYNC */ + RCAR_GP_PIN(5, 15), +}; +static const unsigned int msiof1_sync_d_mux[] = { + MSIOF1_SYNC_D_MARK, +}; +static const unsigned int msiof1_ss1_d_pins[] = { + /* SS1 */ + RCAR_GP_PIN(5, 16), +}; +static const unsigned int msiof1_ss1_d_mux[] = { + MSIOF1_SS1_D_MARK, +}; +static const unsigned int msiof1_ss2_d_pins[] = { + /* SS2 */ + RCAR_GP_PIN(5, 21), +}; +static const unsigned int msiof1_ss2_d_mux[] = { + MSIOF1_SS2_D_MARK, +}; +static const unsigned int msiof1_txd_d_pins[] = { + /* TXD */ + RCAR_GP_PIN(5, 14), +}; +static const unsigned int msiof1_txd_d_mux[] = { + MSIOF1_TXD_D_MARK, +}; +static const unsigned int msiof1_rxd_d_pins[] = { + /* RXD */ + RCAR_GP_PIN(5, 13), +}; +static const unsigned int msiof1_rxd_d_mux[] = { + MSIOF1_RXD_D_MARK, +}; +static const unsigned int msiof1_clk_e_pins[] = { + /* SCK */ + RCAR_GP_PIN(3, 0), +}; +static const unsigned int msiof1_clk_e_mux[] = { + MSIOF1_SCK_E_MARK, +}; +static const unsigned int msiof1_sync_e_pins[] = { + /* SYNC */ + RCAR_GP_PIN(3, 1), +}; +static const unsigned int msiof1_sync_e_mux[] = { + MSIOF1_SYNC_E_MARK, +}; +static const unsigned int msiof1_ss1_e_pins[] = { + /* SS1 */ + RCAR_GP_PIN(3, 4), +}; +static const unsigned int msiof1_ss1_e_mux[] = { + MSIOF1_SS1_E_MARK, +}; +static const unsigned int msiof1_ss2_e_pins[] = { + /* SS2 */ + RCAR_GP_PIN(3, 5), +}; +static const unsigned int msiof1_ss2_e_mux[] = { + MSIOF1_SS2_E_MARK, +}; +static const unsigned int msiof1_txd_e_pins[] = { + /* TXD */ + RCAR_GP_PIN(3, 3), +}; +static const unsigned int msiof1_txd_e_mux[] = { + MSIOF1_TXD_E_MARK, +}; +static const unsigned int msiof1_rxd_e_pins[] = { + /* RXD */ + RCAR_GP_PIN(3, 2), +}; +static const unsigned int msiof1_rxd_e_mux[] = { + MSIOF1_RXD_E_MARK, +}; +static const unsigned int msiof1_clk_f_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 23), +}; +static const unsigned int msiof1_clk_f_mux[] = { + MSIOF1_SCK_F_MARK, +}; +static const unsigned int msiof1_sync_f_pins[] = { + /* SYNC */ + RCAR_GP_PIN(5, 24), +}; +static const unsigned int msiof1_sync_f_mux[] = { + MSIOF1_SYNC_F_MARK, +}; +static const unsigned int msiof1_ss1_f_pins[] = { + /* SS1 */ + RCAR_GP_PIN(6, 1), +}; +static const unsigned int msiof1_ss1_f_mux[] = { + MSIOF1_SS1_F_MARK, +}; +static const unsigned int msiof1_ss2_f_pins[] = { + /* SS2 */ + RCAR_GP_PIN(6, 2), +}; +static const unsigned int msiof1_ss2_f_mux[] = { + MSIOF1_SS2_F_MARK, +}; +static const unsigned int msiof1_txd_f_pins[] = { + /* TXD */ + RCAR_GP_PIN(6, 0), +}; +static const unsigned int msiof1_txd_f_mux[] = { + MSIOF1_TXD_F_MARK, +}; +static const unsigned int msiof1_rxd_f_pins[] = { + /* RXD */ + RCAR_GP_PIN(5, 25), +}; +static const unsigned int msiof1_rxd_f_mux[] = { + MSIOF1_RXD_F_MARK, +}; +static const unsigned int msiof1_clk_g_pins[] = { + /* SCK */ + RCAR_GP_PIN(3, 6), +}; +static const unsigned int msiof1_clk_g_mux[] = { + MSIOF1_SCK_G_MARK, +}; +static const unsigned int msiof1_sync_g_pins[] = { + /* SYNC */ + RCAR_GP_PIN(3, 7), +}; +static const unsigned int msiof1_sync_g_mux[] = { + MSIOF1_SYNC_G_MARK, +}; +static const unsigned int msiof1_ss1_g_pins[] = { + /* SS1 */ + RCAR_GP_PIN(3, 10), +}; +static const unsigned int msiof1_ss1_g_mux[] = { + MSIOF1_SS1_G_MARK, +}; +static const unsigned int msiof1_ss2_g_pins[] = { + /* SS2 */ + RCAR_GP_PIN(3, 11), +}; +static const unsigned int msiof1_ss2_g_mux[] = { + MSIOF1_SS2_G_MARK, +}; +static const unsigned int msiof1_txd_g_pins[] = { + /* TXD */ + RCAR_GP_PIN(3, 9), +}; +static const unsigned int msiof1_txd_g_mux[] = { + MSIOF1_TXD_G_MARK, +}; +static const unsigned int msiof1_rxd_g_pins[] = { + /* RXD */ + RCAR_GP_PIN(3, 8), +}; +static const unsigned int msiof1_rxd_g_mux[] = { + MSIOF1_RXD_G_MARK, +}; +/* - MSIOF2 ----------------------------------------------------------------- */ +static const unsigned int msiof2_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 9), +}; +static const unsigned int msiof2_clk_a_mux[] = { + MSIOF2_SCK_A_MARK, +}; +static const unsigned int msiof2_sync_a_pins[] = { + /* SYNC */ + RCAR_GP_PIN(1, 8), +}; +static const unsigned int msiof2_sync_a_mux[] = { + MSIOF2_SYNC_A_MARK, +}; +static const unsigned int msiof2_ss1_a_pins[] = { + /* SS1 */ + RCAR_GP_PIN(1, 6), +}; +static const unsigned int msiof2_ss1_a_mux[] = { + MSIOF2_SS1_A_MARK, +}; +static const unsigned int msiof2_ss2_a_pins[] = { + /* SS2 */ + RCAR_GP_PIN(1, 7), +}; +static const unsigned int msiof2_ss2_a_mux[] = { + MSIOF2_SS2_A_MARK, +}; +static const unsigned int msiof2_txd_a_pins[] = { + /* TXD */ + RCAR_GP_PIN(1, 11), +}; +static const unsigned int msiof2_txd_a_mux[] = { + MSIOF2_TXD_A_MARK, +}; +static const unsigned int msiof2_rxd_a_pins[] = { + /* RXD */ + RCAR_GP_PIN(1, 10), +}; +static const unsigned int msiof2_rxd_a_mux[] = { + MSIOF2_RXD_A_MARK, +}; +static const unsigned int msiof2_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(0, 4), +}; +static const unsigned int msiof2_clk_b_mux[] = { + MSIOF2_SCK_B_MARK, +}; +static const unsigned int msiof2_sync_b_pins[] = { + /* SYNC */ + RCAR_GP_PIN(0, 5), +}; +static const unsigned int msiof2_sync_b_mux[] = { + MSIOF2_SYNC_B_MARK, +}; +static const unsigned int msiof2_ss1_b_pins[] = { + /* SS1 */ + RCAR_GP_PIN(0, 0), +}; +static const unsigned int msiof2_ss1_b_mux[] = { + MSIOF2_SS1_B_MARK, +}; +static const unsigned int msiof2_ss2_b_pins[] = { + /* SS2 */ + RCAR_GP_PIN(0, 1), +}; +static const unsigned int msiof2_ss2_b_mux[] = { + MSIOF2_SS2_B_MARK, +}; +static const unsigned int msiof2_txd_b_pins[] = { + /* TXD */ + RCAR_GP_PIN(0, 7), +}; +static const unsigned int msiof2_txd_b_mux[] = { + MSIOF2_TXD_B_MARK, +}; +static const unsigned int msiof2_rxd_b_pins[] = { + /* RXD */ + RCAR_GP_PIN(0, 6), +}; +static const unsigned int msiof2_rxd_b_mux[] = { + MSIOF2_RXD_B_MARK, +}; +static const unsigned int msiof2_clk_c_pins[] = { + /* SCK */ + RCAR_GP_PIN(2, 12), +}; +static const unsigned int msiof2_clk_c_mux[] = { + MSIOF2_SCK_C_MARK, +}; +static const unsigned int msiof2_sync_c_pins[] = { + /* SYNC */ + RCAR_GP_PIN(2, 11), +}; +static const unsigned int msiof2_sync_c_mux[] = { + MSIOF2_SYNC_C_MARK, +}; +static const unsigned int msiof2_ss1_c_pins[] = { + /* SS1 */ + RCAR_GP_PIN(2, 10), +}; +static const unsigned int msiof2_ss1_c_mux[] = { + MSIOF2_SS1_C_MARK, +}; +static const unsigned int msiof2_ss2_c_pins[] = { + /* SS2 */ + RCAR_GP_PIN(2, 9), +}; +static const unsigned int msiof2_ss2_c_mux[] = { + MSIOF2_SS2_C_MARK, +}; +static const unsigned int msiof2_txd_c_pins[] = { + /* TXD */ + RCAR_GP_PIN(2, 14), +}; +static const unsigned int msiof2_txd_c_mux[] = { + MSIOF2_TXD_C_MARK, +}; +static const unsigned int msiof2_rxd_c_pins[] = { + /* RXD */ + RCAR_GP_PIN(2, 13), +}; +static const unsigned int msiof2_rxd_c_mux[] = { + MSIOF2_RXD_C_MARK, +}; +static const unsigned int msiof2_clk_d_pins[] = { + /* SCK */ + RCAR_GP_PIN(0, 8), +}; +static const unsigned int msiof2_clk_d_mux[] = { + MSIOF2_SCK_D_MARK, +}; +static const unsigned int msiof2_sync_d_pins[] = { + /* SYNC */ + RCAR_GP_PIN(0, 9), +}; +static const unsigned int msiof2_sync_d_mux[] = { + MSIOF2_SYNC_D_MARK, +}; +static const unsigned int msiof2_ss1_d_pins[] = { + /* SS1 */ + RCAR_GP_PIN(0, 12), +}; +static const unsigned int msiof2_ss1_d_mux[] = { + MSIOF2_SS1_D_MARK, +}; +static const unsigned int msiof2_ss2_d_pins[] = { + /* SS2 */ + RCAR_GP_PIN(0, 13), +}; +static const unsigned int msiof2_ss2_d_mux[] = { + MSIOF2_SS2_D_MARK, +}; +static const unsigned int msiof2_txd_d_pins[] = { + /* TXD */ + RCAR_GP_PIN(0, 11), +}; +static const unsigned int msiof2_txd_d_mux[] = { + MSIOF2_TXD_D_MARK, +}; +static const unsigned int msiof2_rxd_d_pins[] = { + /* RXD */ + RCAR_GP_PIN(0, 10), +}; +static const unsigned int msiof2_rxd_d_mux[] = { + MSIOF2_RXD_D_MARK, +}; +/* - MSIOF3 ----------------------------------------------------------------- */ +static const unsigned int msiof3_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(0, 0), +}; +static const unsigned int msiof3_clk_a_mux[] = { + MSIOF3_SCK_A_MARK, +}; +static const unsigned int msiof3_sync_a_pins[] = { + /* SYNC */ + RCAR_GP_PIN(0, 1), +}; +static const unsigned int msiof3_sync_a_mux[] = { + MSIOF3_SYNC_A_MARK, +}; +static const unsigned int msiof3_ss1_a_pins[] = { + /* SS1 */ + RCAR_GP_PIN(0, 14), +}; +static const unsigned int msiof3_ss1_a_mux[] = { + MSIOF3_SS1_A_MARK, +}; +static const unsigned int msiof3_ss2_a_pins[] = { + /* SS2 */ + RCAR_GP_PIN(0, 15), +}; +static const unsigned int msiof3_ss2_a_mux[] = { + MSIOF3_SS2_A_MARK, +}; +static const unsigned int msiof3_txd_a_pins[] = { + /* TXD */ + RCAR_GP_PIN(0, 3), +}; +static const unsigned int msiof3_txd_a_mux[] = { + MSIOF3_TXD_A_MARK, +}; +static const unsigned int msiof3_rxd_a_pins[] = { + /* RXD */ + RCAR_GP_PIN(0, 2), +}; +static const unsigned int msiof3_rxd_a_mux[] = { + MSIOF3_RXD_A_MARK, +}; +static const unsigned int msiof3_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 2), +}; +static const unsigned int msiof3_clk_b_mux[] = { + MSIOF3_SCK_B_MARK, +}; +static const unsigned int msiof3_sync_b_pins[] = { + /* SYNC */ + RCAR_GP_PIN(1, 0), +}; +static const unsigned int msiof3_sync_b_mux[] = { + MSIOF3_SYNC_B_MARK, +}; +static const unsigned int msiof3_ss1_b_pins[] = { + /* SS1 */ + RCAR_GP_PIN(1, 4), +}; +static const unsigned int msiof3_ss1_b_mux[] = { + MSIOF3_SS1_B_MARK, +}; +static const unsigned int msiof3_ss2_b_pins[] = { + /* SS2 */ + RCAR_GP_PIN(1, 5), +}; +static const unsigned int msiof3_ss2_b_mux[] = { + MSIOF3_SS2_B_MARK, +}; +static const unsigned int msiof3_txd_b_pins[] = { + /* TXD */ + RCAR_GP_PIN(1, 1), +}; +static const unsigned int msiof3_txd_b_mux[] = { + MSIOF3_TXD_B_MARK, +}; +static const unsigned int msiof3_rxd_b_pins[] = { + /* RXD */ + RCAR_GP_PIN(1, 3), +}; +static const unsigned int msiof3_rxd_b_mux[] = { + MSIOF3_RXD_B_MARK, +}; +static const unsigned int msiof3_clk_c_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 12), +}; +static const unsigned int msiof3_clk_c_mux[] = { + MSIOF3_SCK_C_MARK, +}; +static const unsigned int msiof3_sync_c_pins[] = { + /* SYNC */ + RCAR_GP_PIN(1, 13), +}; +static const unsigned int msiof3_sync_c_mux[] = { + MSIOF3_SYNC_C_MARK, +}; +static const unsigned int msiof3_txd_c_pins[] = { + /* TXD */ + RCAR_GP_PIN(1, 15), +}; +static const unsigned int msiof3_txd_c_mux[] = { + MSIOF3_TXD_C_MARK, +}; +static const unsigned int msiof3_rxd_c_pins[] = { + /* RXD */ + RCAR_GP_PIN(1, 14), +}; +static const unsigned int msiof3_rxd_c_mux[] = { + MSIOF3_RXD_C_MARK, +}; +static const unsigned int msiof3_clk_d_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 22), +}; +static const unsigned int msiof3_clk_d_mux[] = { + MSIOF3_SCK_D_MARK, +}; +static const unsigned int msiof3_sync_d_pins[] = { + /* SYNC */ + RCAR_GP_PIN(1, 23), +}; +static const unsigned int msiof3_sync_d_mux[] = { + MSIOF3_SYNC_D_MARK, +}; +static const unsigned int msiof3_ss1_d_pins[] = { + /* SS1 */ + RCAR_GP_PIN(1, 26), +}; +static const unsigned int msiof3_ss1_d_mux[] = { + MSIOF3_SS1_D_MARK, +}; +static const unsigned int msiof3_txd_d_pins[] = { + /* TXD */ + RCAR_GP_PIN(1, 25), +}; +static const unsigned int msiof3_txd_d_mux[] = { + MSIOF3_TXD_D_MARK, +}; +static const unsigned int msiof3_rxd_d_pins[] = { + /* RXD */ + RCAR_GP_PIN(1, 24), +}; +static const unsigned int msiof3_rxd_d_mux[] = { + MSIOF3_RXD_D_MARK, +}; + +static const unsigned int msiof3_clk_e_pins[] = { + /* SCK */ + RCAR_GP_PIN(2, 3), +}; +static const unsigned int msiof3_clk_e_mux[] = { + MSIOF3_SCK_E_MARK, +}; +static const unsigned int msiof3_sync_e_pins[] = { + /* SYNC */ + RCAR_GP_PIN(2, 2), +}; +static const unsigned int msiof3_sync_e_mux[] = { + MSIOF3_SYNC_E_MARK, +}; +static const unsigned int msiof3_ss1_e_pins[] = { + /* SS1 */ + RCAR_GP_PIN(2, 1), +}; +static const unsigned int msiof3_ss1_e_mux[] = { + MSIOF3_SS1_E_MARK, +}; +static const unsigned int msiof3_ss2_e_pins[] = { + /* SS1 */ + RCAR_GP_PIN(2, 0), +}; +static const unsigned int msiof3_ss2_e_mux[] = { + MSIOF3_SS2_E_MARK, +}; +static const unsigned int msiof3_txd_e_pins[] = { + /* TXD */ + RCAR_GP_PIN(2, 5), +}; +static const unsigned int msiof3_txd_e_mux[] = { + MSIOF3_TXD_E_MARK, +}; +static const unsigned int msiof3_rxd_e_pins[] = { + /* RXD */ + RCAR_GP_PIN(2, 4), +}; +static const unsigned int msiof3_rxd_e_mux[] = { + MSIOF3_RXD_E_MARK, +}; + +/* - PWM0 --------------------------------------------------------------------*/ +static const unsigned int pwm0_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 6), +}; +static const unsigned int pwm0_mux[] = { + PWM0_MARK, +}; +/* - PWM1 --------------------------------------------------------------------*/ +static const unsigned int pwm1_a_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 7), +}; +static const unsigned int pwm1_a_mux[] = { + PWM1_A_MARK, +}; +static const unsigned int pwm1_b_pins[] = { + /* PWM */ + RCAR_GP_PIN(1, 8), +}; +static const unsigned int pwm1_b_mux[] = { + PWM1_B_MARK, +}; +/* - PWM2 --------------------------------------------------------------------*/ +static const unsigned int pwm2_a_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 8), +}; +static const unsigned int pwm2_a_mux[] = { + PWM2_A_MARK, +}; +static const unsigned int pwm2_b_pins[] = { + /* PWM */ + RCAR_GP_PIN(1, 11), +}; +static const unsigned int pwm2_b_mux[] = { + PWM2_B_MARK, +}; +/* - PWM3 --------------------------------------------------------------------*/ +static const unsigned int pwm3_a_pins[] = { + /* PWM */ + RCAR_GP_PIN(1, 0), +}; +static const unsigned int pwm3_a_mux[] = { + PWM3_A_MARK, +}; +static const unsigned int pwm3_b_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 2), +}; +static const unsigned int pwm3_b_mux[] = { + PWM3_B_MARK, +}; +/* - PWM4 --------------------------------------------------------------------*/ +static const unsigned int pwm4_a_pins[] = { + /* PWM */ + RCAR_GP_PIN(1, 1), +}; +static const unsigned int pwm4_a_mux[] = { + PWM4_A_MARK, +}; +static const unsigned int pwm4_b_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 3), +}; +static const unsigned int pwm4_b_mux[] = { + PWM4_B_MARK, +}; +/* - PWM5 --------------------------------------------------------------------*/ +static const unsigned int pwm5_a_pins[] = { + /* PWM */ + RCAR_GP_PIN(1, 2), +}; +static const unsigned int pwm5_a_mux[] = { + PWM5_A_MARK, +}; +static const unsigned int pwm5_b_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 4), +}; +static const unsigned int pwm5_b_mux[] = { + PWM5_B_MARK, +}; +/* - PWM6 --------------------------------------------------------------------*/ +static const unsigned int pwm6_a_pins[] = { + /* PWM */ + RCAR_GP_PIN(1, 3), +}; +static const unsigned int pwm6_a_mux[] = { + PWM6_A_MARK, +}; +static const unsigned int pwm6_b_pins[] = { + /* PWM */ + RCAR_GP_PIN(2, 5), +}; +static const unsigned int pwm6_b_mux[] = { + PWM6_B_MARK, +}; + +/* - SATA ------------------------------------------------------------------- */ +static const unsigned int sata0_devslp_a_pins[] = { + /* DEVSLP */ + RCAR_GP_PIN(6, 16), +}; + +static const unsigned int sata0_devslp_a_mux[] = { + SATA_DEVSLP_A_MARK, +}; + +/* - SCIF0 ------------------------------------------------------------------ */ +static const unsigned int scif0_data_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 1), RCAR_GP_PIN(5, 2), +}; +static const unsigned int scif0_data_mux[] = { + RX0_MARK, TX0_MARK, +}; +static const unsigned int scif0_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 0), +}; +static const unsigned int scif0_clk_mux[] = { + SCK0_MARK, +}; +static const unsigned int scif0_ctrl_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(5, 4), RCAR_GP_PIN(5, 3), +}; +static const unsigned int scif0_ctrl_mux[] = { + RTS0_N_MARK, CTS0_N_MARK, +}; +/* - SCIF1 ------------------------------------------------------------------ */ +static const unsigned int scif1_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 5), RCAR_GP_PIN(5, 6), +}; +static const unsigned int scif1_data_a_mux[] = { + RX1_A_MARK, TX1_A_MARK, +}; +static const unsigned int scif1_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 21), +}; +static const unsigned int scif1_clk_mux[] = { + SCK1_MARK, +}; +static const unsigned int scif1_ctrl_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(5, 8), RCAR_GP_PIN(5, 7), +}; +static const unsigned int scif1_ctrl_mux[] = { + RTS1_N_MARK, CTS1_N_MARK, +}; + +static const unsigned int scif1_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 24), RCAR_GP_PIN(5, 25), +}; +static const unsigned int scif1_data_b_mux[] = { + RX1_B_MARK, TX1_B_MARK, +}; +/* - SCIF2 ------------------------------------------------------------------ */ +static const unsigned int scif2_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 11), RCAR_GP_PIN(5, 10), +}; +static const unsigned int scif2_data_a_mux[] = { + RX2_A_MARK, TX2_A_MARK, +}; +static const unsigned int scif2_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 9), +}; +static const unsigned int scif2_clk_mux[] = { + SCK2_MARK, +}; +static const unsigned int scif2_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 15), RCAR_GP_PIN(5, 16), +}; +static const unsigned int scif2_data_b_mux[] = { + RX2_B_MARK, TX2_B_MARK, +}; +/* - SCIF3 ------------------------------------------------------------------ */ +static const unsigned int scif3_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(1, 23), RCAR_GP_PIN(1, 24), +}; +static const unsigned int scif3_data_a_mux[] = { + RX3_A_MARK, TX3_A_MARK, +}; +static const unsigned int scif3_clk_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 22), +}; +static const unsigned int scif3_clk_mux[] = { + SCK3_MARK, +}; +static const unsigned int scif3_ctrl_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(1, 26), RCAR_GP_PIN(1, 25), +}; +static const unsigned int scif3_ctrl_mux[] = { + RTS3_N_MARK, CTS3_N_MARK, +}; +static const unsigned int scif3_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(1, 8), RCAR_GP_PIN(1, 11), +}; +static const unsigned int scif3_data_b_mux[] = { + RX3_B_MARK, TX3_B_MARK, +}; +/* - SCIF4 ------------------------------------------------------------------ */ +static const unsigned int scif4_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(2, 11), RCAR_GP_PIN(2, 12), +}; +static const unsigned int scif4_data_a_mux[] = { + RX4_A_MARK, TX4_A_MARK, +}; +static const unsigned int scif4_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(2, 10), +}; +static const unsigned int scif4_clk_a_mux[] = { + SCK4_A_MARK, +}; +static const unsigned int scif4_ctrl_a_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(2, 14), RCAR_GP_PIN(2, 13), +}; +static const unsigned int scif4_ctrl_a_mux[] = { + RTS4_N_A_MARK, CTS4_N_A_MARK, +}; +static const unsigned int scif4_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 7), +}; +static const unsigned int scif4_data_b_mux[] = { + RX4_B_MARK, TX4_B_MARK, +}; +static const unsigned int scif4_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(1, 5), +}; +static const unsigned int scif4_clk_b_mux[] = { + SCK4_B_MARK, +}; +static const unsigned int scif4_ctrl_b_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(1, 10), RCAR_GP_PIN(1, 9), +}; +static const unsigned int scif4_ctrl_b_mux[] = { + RTS4_N_B_MARK, CTS4_N_B_MARK, +}; +static const unsigned int scif4_data_c_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(0, 12), RCAR_GP_PIN(0, 13), +}; +static const unsigned int scif4_data_c_mux[] = { + RX4_C_MARK, TX4_C_MARK, +}; +static const unsigned int scif4_clk_c_pins[] = { + /* SCK */ + RCAR_GP_PIN(0, 8), +}; +static const unsigned int scif4_clk_c_mux[] = { + SCK4_C_MARK, +}; +static const unsigned int scif4_ctrl_c_pins[] = { + /* RTS, CTS */ + RCAR_GP_PIN(0, 11), RCAR_GP_PIN(0, 10), +}; +static const unsigned int scif4_ctrl_c_mux[] = { + RTS4_N_C_MARK, CTS4_N_C_MARK, +}; +/* - SCIF5 ------------------------------------------------------------------ */ +static const unsigned int scif5_data_a_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 19), RCAR_GP_PIN(5, 21), +}; +static const unsigned int scif5_data_a_mux[] = { + RX5_A_MARK, TX5_A_MARK, +}; +static const unsigned int scif5_clk_a_pins[] = { + /* SCK */ + RCAR_GP_PIN(6, 21), +}; +static const unsigned int scif5_clk_a_mux[] = { + SCK5_A_MARK, +}; + +static const unsigned int scif5_data_b_pins[] = { + /* RX, TX */ + RCAR_GP_PIN(5, 12), RCAR_GP_PIN(5, 18), +}; +static const unsigned int scif5_data_b_mux[] = { + RX5_B_MARK, TX5_B_MARK, +}; +static const unsigned int scif5_clk_b_pins[] = { + /* SCK */ + RCAR_GP_PIN(5, 0), +}; +static const unsigned int scif5_clk_b_mux[] = { + SCK5_B_MARK, +}; + +/* - SCIF Clock ------------------------------------------------------------- */ +static const unsigned int scif_clk_a_pins[] = { + /* SCIF_CLK */ + RCAR_GP_PIN(6, 23), +}; +static const unsigned int scif_clk_a_mux[] = { + SCIF_CLK_A_MARK, +}; +static const unsigned int scif_clk_b_pins[] = { + /* SCIF_CLK */ + RCAR_GP_PIN(5, 9), +}; +static const unsigned int scif_clk_b_mux[] = { + SCIF_CLK_B_MARK, +}; + +/* - SDHI0 ------------------------------------------------------------------ */ +static const unsigned int sdhi0_data1_pins[] = { + /* D0 */ + RCAR_GP_PIN(3, 2), +}; +static const unsigned int sdhi0_data1_mux[] = { + SD0_DAT0_MARK, +}; +static const unsigned int sdhi0_data4_pins[] = { + /* D[0:3] */ + RCAR_GP_PIN(3, 2), RCAR_GP_PIN(3, 3), + RCAR_GP_PIN(3, 4), RCAR_GP_PIN(3, 5), +}; +static const unsigned int sdhi0_data4_mux[] = { + SD0_DAT0_MARK, SD0_DAT1_MARK, + SD0_DAT2_MARK, SD0_DAT3_MARK, +}; +static const unsigned int sdhi0_ctrl_pins[] = { + /* CLK, CMD */ + RCAR_GP_PIN(3, 0), RCAR_GP_PIN(3, 1), +}; +static const unsigned int sdhi0_ctrl_mux[] = { + SD0_CLK_MARK, SD0_CMD_MARK, +}; +static const unsigned int sdhi0_cd_pins[] = { + /* CD */ + RCAR_GP_PIN(3, 12), +}; +static const unsigned int sdhi0_cd_mux[] = { + SD0_CD_MARK, +}; +static const unsigned int sdhi0_wp_pins[] = { + /* WP */ + RCAR_GP_PIN(3, 13), +}; +static const unsigned int sdhi0_wp_mux[] = { + SD0_WP_MARK, +}; +/* - SDHI1 ------------------------------------------------------------------ */ +static const unsigned int sdhi1_data1_pins[] = { + /* D0 */ + RCAR_GP_PIN(3, 8), +}; +static const unsigned int sdhi1_data1_mux[] = { + SD1_DAT0_MARK, +}; +static const unsigned int sdhi1_data4_pins[] = { + /* D[0:3] */ + RCAR_GP_PIN(3, 8), RCAR_GP_PIN(3, 9), + RCAR_GP_PIN(3, 10), RCAR_GP_PIN(3, 11), +}; +static const unsigned int sdhi1_data4_mux[] = { + SD1_DAT0_MARK, SD1_DAT1_MARK, + SD1_DAT2_MARK, SD1_DAT3_MARK, +}; +static const unsigned int sdhi1_ctrl_pins[] = { + /* CLK, CMD */ + RCAR_GP_PIN(3, 6), RCAR_GP_PIN(3, 7), +}; +static const unsigned int sdhi1_ctrl_mux[] = { + SD1_CLK_MARK, SD1_CMD_MARK, +}; +static const unsigned int sdhi1_cd_pins[] = { + /* CD */ + RCAR_GP_PIN(3, 14), +}; +static const unsigned int sdhi1_cd_mux[] = { + SD1_CD_MARK, +}; +static const unsigned int sdhi1_wp_pins[] = { + /* WP */ + RCAR_GP_PIN(3, 15), +}; +static const unsigned int sdhi1_wp_mux[] = { + SD1_WP_MARK, +}; +/* - SDHI2 ------------------------------------------------------------------ */ +static const unsigned int sdhi2_data1_pins[] = { + /* D0 */ + RCAR_GP_PIN(4, 2), +}; +static const unsigned int sdhi2_data1_mux[] = { + SD2_DAT0_MARK, +}; +static const unsigned int sdhi2_data4_pins[] = { + /* D[0:3] */ + RCAR_GP_PIN(4, 2), RCAR_GP_PIN(4, 3), + RCAR_GP_PIN(4, 4), RCAR_GP_PIN(4, 5), +}; +static const unsigned int sdhi2_data4_mux[] = { + SD2_DAT0_MARK, SD2_DAT1_MARK, + SD2_DAT2_MARK, SD2_DAT3_MARK, +}; +static const unsigned int sdhi2_data8_pins[] = { + /* D[0:7] */ + RCAR_GP_PIN(4, 2), RCAR_GP_PIN(4, 3), + RCAR_GP_PIN(4, 4), RCAR_GP_PIN(4, 5), + RCAR_GP_PIN(3, 8), RCAR_GP_PIN(3, 9), + RCAR_GP_PIN(3, 10), RCAR_GP_PIN(3, 11), +}; +static const unsigned int sdhi2_data8_mux[] = { + SD2_DAT0_MARK, SD2_DAT1_MARK, + SD2_DAT2_MARK, SD2_DAT3_MARK, + SD2_DAT4_MARK, SD2_DAT5_MARK, + SD2_DAT6_MARK, SD2_DAT7_MARK, +}; +static const unsigned int sdhi2_ctrl_pins[] = { + /* CLK, CMD */ + RCAR_GP_PIN(4, 0), RCAR_GP_PIN(4, 1), +}; +static const unsigned int sdhi2_ctrl_mux[] = { + SD2_CLK_MARK, SD2_CMD_MARK, +}; +static const unsigned int sdhi2_cd_a_pins[] = { + /* CD */ + RCAR_GP_PIN(4, 13), +}; +static const unsigned int sdhi2_cd_a_mux[] = { + SD2_CD_A_MARK, +}; +static const unsigned int sdhi2_cd_b_pins[] = { + /* CD */ + RCAR_GP_PIN(5, 10), +}; +static const unsigned int sdhi2_cd_b_mux[] = { + SD2_CD_B_MARK, +}; +static const unsigned int sdhi2_wp_a_pins[] = { + /* WP */ + RCAR_GP_PIN(4, 14), +}; +static const unsigned int sdhi2_wp_a_mux[] = { + SD2_WP_A_MARK, +}; +static const unsigned int sdhi2_wp_b_pins[] = { + /* WP */ + RCAR_GP_PIN(5, 11), +}; +static const unsigned int sdhi2_wp_b_mux[] = { + SD2_WP_B_MARK, +}; +static const unsigned int sdhi2_ds_pins[] = { + /* DS */ + RCAR_GP_PIN(4, 6), +}; +static const unsigned int sdhi2_ds_mux[] = { + SD2_DS_MARK, +}; +/* - SDHI3 ------------------------------------------------------------------ */ +static const unsigned int sdhi3_data1_pins[] = { + /* D0 */ + RCAR_GP_PIN(4, 9), +}; +static const unsigned int sdhi3_data1_mux[] = { + SD3_DAT0_MARK, +}; +static const unsigned int sdhi3_data4_pins[] = { + /* D[0:3] */ + RCAR_GP_PIN(4, 9), RCAR_GP_PIN(4, 10), + RCAR_GP_PIN(4, 11), RCAR_GP_PIN(4, 12), +}; +static const unsigned int sdhi3_data4_mux[] = { + SD3_DAT0_MARK, SD3_DAT1_MARK, + SD3_DAT2_MARK, SD3_DAT3_MARK, +}; +static const unsigned int sdhi3_data8_pins[] = { + /* D[0:7] */ + RCAR_GP_PIN(4, 9), RCAR_GP_PIN(4, 10), + RCAR_GP_PIN(4, 11), RCAR_GP_PIN(4, 12), + RCAR_GP_PIN(4, 13), RCAR_GP_PIN(4, 14), + RCAR_GP_PIN(4, 15), RCAR_GP_PIN(4, 16), +}; +static const unsigned int sdhi3_data8_mux[] = { + SD3_DAT0_MARK, SD3_DAT1_MARK, + SD3_DAT2_MARK, SD3_DAT3_MARK, + SD3_DAT4_MARK, SD3_DAT5_MARK, + SD3_DAT6_MARK, SD3_DAT7_MARK, +}; +static const unsigned int sdhi3_ctrl_pins[] = { + /* CLK, CMD */ + RCAR_GP_PIN(4, 7), RCAR_GP_PIN(4, 8), +}; +static const unsigned int sdhi3_ctrl_mux[] = { + SD3_CLK_MARK, SD3_CMD_MARK, +}; +static const unsigned int sdhi3_cd_pins[] = { + /* CD */ + RCAR_GP_PIN(4, 15), +}; +static const unsigned int sdhi3_cd_mux[] = { + SD3_CD_MARK, +}; +static const unsigned int sdhi3_wp_pins[] = { + /* WP */ + RCAR_GP_PIN(4, 16), +}; +static const unsigned int sdhi3_wp_mux[] = { + SD3_WP_MARK, +}; +static const unsigned int sdhi3_ds_pins[] = { + /* DS */ + RCAR_GP_PIN(4, 17), +}; +static const unsigned int sdhi3_ds_mux[] = { + SD3_DS_MARK, +}; + +/* - SSI -------------------------------------------------------------------- */ +static const unsigned int ssi0_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 2), +}; +static const unsigned int ssi0_data_mux[] = { + SSI_SDATA0_MARK, +}; +static const unsigned int ssi01239_ctrl_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 0), RCAR_GP_PIN(6, 1), +}; +static const unsigned int ssi01239_ctrl_mux[] = { + SSI_SCK01239_MARK, SSI_WS01239_MARK, +}; +static const unsigned int ssi1_data_a_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 3), +}; +static const unsigned int ssi1_data_a_mux[] = { + SSI_SDATA1_A_MARK, +}; +static const unsigned int ssi1_data_b_pins[] = { + /* SDATA */ + RCAR_GP_PIN(5, 12), +}; +static const unsigned int ssi1_data_b_mux[] = { + SSI_SDATA1_B_MARK, +}; +static const unsigned int ssi1_ctrl_a_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 26), RCAR_GP_PIN(6, 27), +}; +static const unsigned int ssi1_ctrl_a_mux[] = { + SSI_SCK1_A_MARK, SSI_WS1_A_MARK, +}; +static const unsigned int ssi1_ctrl_b_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 4), RCAR_GP_PIN(6, 21), +}; +static const unsigned int ssi1_ctrl_b_mux[] = { + SSI_SCK1_B_MARK, SSI_WS1_B_MARK, +}; +static const unsigned int ssi2_data_a_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 4), +}; +static const unsigned int ssi2_data_a_mux[] = { + SSI_SDATA2_A_MARK, +}; +static const unsigned int ssi2_data_b_pins[] = { + /* SDATA */ + RCAR_GP_PIN(5, 13), +}; +static const unsigned int ssi2_data_b_mux[] = { + SSI_SDATA2_B_MARK, +}; +static const unsigned int ssi2_ctrl_a_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(5, 19), RCAR_GP_PIN(5, 21), +}; +static const unsigned int ssi2_ctrl_a_mux[] = { + SSI_SCK2_A_MARK, SSI_WS2_A_MARK, +}; +static const unsigned int ssi2_ctrl_b_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 28), RCAR_GP_PIN(6, 29), +}; +static const unsigned int ssi2_ctrl_b_mux[] = { + SSI_SCK2_B_MARK, SSI_WS2_B_MARK, +}; +static const unsigned int ssi3_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 7), +}; +static const unsigned int ssi3_data_mux[] = { + SSI_SDATA3_MARK, +}; +static const unsigned int ssi349_ctrl_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 5), RCAR_GP_PIN(6, 6), +}; +static const unsigned int ssi349_ctrl_mux[] = { + SSI_SCK349_MARK, SSI_WS349_MARK, +}; +static const unsigned int ssi4_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 10), +}; +static const unsigned int ssi4_data_mux[] = { + SSI_SDATA4_MARK, +}; +static const unsigned int ssi4_ctrl_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 8), RCAR_GP_PIN(6, 9), +}; +static const unsigned int ssi4_ctrl_mux[] = { + SSI_SCK4_MARK, SSI_WS4_MARK, +}; +static const unsigned int ssi5_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 13), +}; +static const unsigned int ssi5_data_mux[] = { + SSI_SDATA5_MARK, +}; +static const unsigned int ssi5_ctrl_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 11), RCAR_GP_PIN(6, 12), +}; +static const unsigned int ssi5_ctrl_mux[] = { + SSI_SCK5_MARK, SSI_WS5_MARK, +}; +static const unsigned int ssi6_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 16), +}; +static const unsigned int ssi6_data_mux[] = { + SSI_SDATA6_MARK, +}; +static const unsigned int ssi6_ctrl_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 14), RCAR_GP_PIN(6, 15), +}; +static const unsigned int ssi6_ctrl_mux[] = { + SSI_SCK6_MARK, SSI_WS6_MARK, +}; +static const unsigned int ssi7_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 19), +}; +static const unsigned int ssi7_data_mux[] = { + SSI_SDATA7_MARK, +}; +static const unsigned int ssi78_ctrl_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 17), RCAR_GP_PIN(6, 18), +}; +static const unsigned int ssi78_ctrl_mux[] = { + SSI_SCK78_MARK, SSI_WS78_MARK, +}; +static const unsigned int ssi8_data_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 20), +}; +static const unsigned int ssi8_data_mux[] = { + SSI_SDATA8_MARK, +}; +static const unsigned int ssi9_data_a_pins[] = { + /* SDATA */ + RCAR_GP_PIN(6, 21), +}; +static const unsigned int ssi9_data_a_mux[] = { + SSI_SDATA9_A_MARK, +}; +static const unsigned int ssi9_data_b_pins[] = { + /* SDATA */ + RCAR_GP_PIN(5, 14), +}; +static const unsigned int ssi9_data_b_mux[] = { + SSI_SDATA9_B_MARK, +}; +static const unsigned int ssi9_ctrl_a_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(5, 15), RCAR_GP_PIN(5, 16), +}; +static const unsigned int ssi9_ctrl_a_mux[] = { + SSI_SCK9_A_MARK, SSI_WS9_A_MARK, +}; +static const unsigned int ssi9_ctrl_b_pins[] = { + /* SCK, WS */ + RCAR_GP_PIN(6, 30), RCAR_GP_PIN(6, 31), +}; +static const unsigned int ssi9_ctrl_b_mux[] = { + SSI_SCK9_B_MARK, SSI_WS9_B_MARK, +}; + +/* - TMU -------------------------------------------------------------------- */ +static const unsigned int tmu_tclk1_a_pins[] = { + /* TCLK */ + RCAR_GP_PIN(6, 23), +}; +static const unsigned int tmu_tclk1_a_mux[] = { + TCLK1_A_MARK, +}; +static const unsigned int tmu_tclk1_b_pins[] = { + /* TCLK */ + RCAR_GP_PIN(5, 19), +}; +static const unsigned int tmu_tclk1_b_mux[] = { + TCLK1_B_MARK, +}; +static const unsigned int tmu_tclk2_a_pins[] = { + /* TCLK */ + RCAR_GP_PIN(6, 19), +}; +static const unsigned int tmu_tclk2_a_mux[] = { + TCLK2_A_MARK, +}; +static const unsigned int tmu_tclk2_b_pins[] = { + /* TCLK */ + RCAR_GP_PIN(6, 28), +}; +static const unsigned int tmu_tclk2_b_mux[] = { + TCLK2_B_MARK, +}; + +/* - USB0 ------------------------------------------------------------------- */ +static const unsigned int usb0_pins[] = { + /* PWEN, OVC */ + RCAR_GP_PIN(6, 24), RCAR_GP_PIN(6, 25), +}; +static const unsigned int usb0_mux[] = { + USB0_PWEN_MARK, USB0_OVC_MARK, +}; +/* - USB1 ------------------------------------------------------------------- */ +static const unsigned int usb1_pins[] = { + /* PWEN, OVC */ + RCAR_GP_PIN(6, 26), RCAR_GP_PIN(6, 27), +}; +static const unsigned int usb1_mux[] = { + USB1_PWEN_MARK, USB1_OVC_MARK, +}; + +/* - USB30 ------------------------------------------------------------------ */ +static const unsigned int usb30_pins[] = { + /* PWEN, OVC */ + RCAR_GP_PIN(6, 28), RCAR_GP_PIN(6, 29), +}; +static const unsigned int usb30_mux[] = { + USB30_PWEN_MARK, USB30_OVC_MARK, +}; + +/* - VIN4 ------------------------------------------------------------------- */ +static const unsigned int vin4_data18_a_pins[] = { + RCAR_GP_PIN(0, 10), RCAR_GP_PIN(0, 11), + RCAR_GP_PIN(0, 12), RCAR_GP_PIN(0, 13), + RCAR_GP_PIN(0, 14), RCAR_GP_PIN(0, 15), + RCAR_GP_PIN(1, 2), RCAR_GP_PIN(1, 3), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 7), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), +}; +static const unsigned int vin4_data18_a_mux[] = { + VI4_DATA2_A_MARK, VI4_DATA3_A_MARK, + VI4_DATA4_A_MARK, VI4_DATA5_A_MARK, + VI4_DATA6_A_MARK, VI4_DATA7_A_MARK, + VI4_DATA10_MARK, VI4_DATA11_MARK, + VI4_DATA12_MARK, VI4_DATA13_MARK, + VI4_DATA14_MARK, VI4_DATA15_MARK, + VI4_DATA18_MARK, VI4_DATA19_MARK, + VI4_DATA20_MARK, VI4_DATA21_MARK, + VI4_DATA22_MARK, VI4_DATA23_MARK, +}; +static const unsigned int vin4_data18_b_pins[] = { + RCAR_GP_PIN(2, 2), RCAR_GP_PIN(2, 3), + RCAR_GP_PIN(2, 4), RCAR_GP_PIN(2, 5), + RCAR_GP_PIN(2, 6), RCAR_GP_PIN(2, 7), + RCAR_GP_PIN(1, 2), RCAR_GP_PIN(1, 3), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 7), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), +}; +static const unsigned int vin4_data18_b_mux[] = { + VI4_DATA2_B_MARK, VI4_DATA3_B_MARK, + VI4_DATA4_B_MARK, VI4_DATA5_B_MARK, + VI4_DATA6_B_MARK, VI4_DATA7_B_MARK, + VI4_DATA10_MARK, VI4_DATA11_MARK, + VI4_DATA12_MARK, VI4_DATA13_MARK, + VI4_DATA14_MARK, VI4_DATA15_MARK, + VI4_DATA18_MARK, VI4_DATA19_MARK, + VI4_DATA20_MARK, VI4_DATA21_MARK, + VI4_DATA22_MARK, VI4_DATA23_MARK, +}; +static const union vin_data vin4_data_a_pins = { + .data24 = { + RCAR_GP_PIN(0, 8), RCAR_GP_PIN(0, 9), + RCAR_GP_PIN(0, 10), RCAR_GP_PIN(0, 11), + RCAR_GP_PIN(0, 12), RCAR_GP_PIN(0, 13), + RCAR_GP_PIN(0, 14), RCAR_GP_PIN(0, 15), + RCAR_GP_PIN(1, 0), RCAR_GP_PIN(1, 1), + RCAR_GP_PIN(1, 2), RCAR_GP_PIN(1, 3), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 7), + RCAR_GP_PIN(0, 0), RCAR_GP_PIN(0, 1), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), + }, +}; +static const union vin_data vin4_data_a_mux = { + .data24 = { + VI4_DATA0_A_MARK, VI4_DATA1_A_MARK, + VI4_DATA2_A_MARK, VI4_DATA3_A_MARK, + VI4_DATA4_A_MARK, VI4_DATA5_A_MARK, + VI4_DATA6_A_MARK, VI4_DATA7_A_MARK, + VI4_DATA8_MARK, VI4_DATA9_MARK, + VI4_DATA10_MARK, VI4_DATA11_MARK, + VI4_DATA12_MARK, VI4_DATA13_MARK, + VI4_DATA14_MARK, VI4_DATA15_MARK, + VI4_DATA16_MARK, VI4_DATA17_MARK, + VI4_DATA18_MARK, VI4_DATA19_MARK, + VI4_DATA20_MARK, VI4_DATA21_MARK, + VI4_DATA22_MARK, VI4_DATA23_MARK, + }, +}; +static const union vin_data vin4_data_b_pins = { + .data24 = { + RCAR_GP_PIN(2, 0), RCAR_GP_PIN(2, 1), + RCAR_GP_PIN(2, 2), RCAR_GP_PIN(2, 3), + RCAR_GP_PIN(2, 4), RCAR_GP_PIN(2, 5), + RCAR_GP_PIN(2, 6), RCAR_GP_PIN(2, 7), + RCAR_GP_PIN(1, 0), RCAR_GP_PIN(1, 1), + RCAR_GP_PIN(1, 2), RCAR_GP_PIN(1, 3), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 7), + RCAR_GP_PIN(0, 0), RCAR_GP_PIN(0, 1), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), + }, +}; +static const union vin_data vin4_data_b_mux = { + .data24 = { + VI4_DATA0_B_MARK, VI4_DATA1_B_MARK, + VI4_DATA2_B_MARK, VI4_DATA3_B_MARK, + VI4_DATA4_B_MARK, VI4_DATA5_B_MARK, + VI4_DATA6_B_MARK, VI4_DATA7_B_MARK, + VI4_DATA8_MARK, VI4_DATA9_MARK, + VI4_DATA10_MARK, VI4_DATA11_MARK, + VI4_DATA12_MARK, VI4_DATA13_MARK, + VI4_DATA14_MARK, VI4_DATA15_MARK, + VI4_DATA16_MARK, VI4_DATA17_MARK, + VI4_DATA18_MARK, VI4_DATA19_MARK, + VI4_DATA20_MARK, VI4_DATA21_MARK, + VI4_DATA22_MARK, VI4_DATA23_MARK, + }, +}; +static const unsigned int vin4_sync_pins[] = { + /* HSYNC#, VSYNC# */ + RCAR_GP_PIN(1, 18), RCAR_GP_PIN(1, 17), +}; +static const unsigned int vin4_sync_mux[] = { + VI4_HSYNC_N_MARK, VI4_VSYNC_N_MARK, +}; +static const unsigned int vin4_field_pins[] = { + /* FIELD */ + RCAR_GP_PIN(1, 16), +}; +static const unsigned int vin4_field_mux[] = { + VI4_FIELD_MARK, +}; +static const unsigned int vin4_clkenb_pins[] = { + /* CLKENB */ + RCAR_GP_PIN(1, 19), +}; +static const unsigned int vin4_clkenb_mux[] = { + VI4_CLKENB_MARK, +}; +static const unsigned int vin4_clk_pins[] = { + /* CLK */ + RCAR_GP_PIN(1, 27), +}; +static const unsigned int vin4_clk_mux[] = { + VI4_CLK_MARK, +}; + +/* - VIN5 ------------------------------------------------------------------- */ +static const unsigned int vin5_data8_pins[] = { + RCAR_GP_PIN(0, 0), RCAR_GP_PIN(0, 1), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), +}; +static const unsigned int vin5_data8_mux[] = { + VI5_DATA0_MARK, VI5_DATA1_MARK, + VI5_DATA2_MARK, VI5_DATA3_MARK, + VI5_DATA4_MARK, VI5_DATA5_MARK, + VI5_DATA6_MARK, VI5_DATA7_MARK, +}; +static const unsigned int vin5_data10_pins[] = { + RCAR_GP_PIN(0, 0), RCAR_GP_PIN(0, 1), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), + RCAR_GP_PIN(1, 12), RCAR_GP_PIN(1, 13), +}; +static const unsigned int vin5_data10_mux[] = { + VI5_DATA0_MARK, VI5_DATA1_MARK, + VI5_DATA2_MARK, VI5_DATA3_MARK, + VI5_DATA4_MARK, VI5_DATA5_MARK, + VI5_DATA6_MARK, VI5_DATA7_MARK, + VI5_DATA8_MARK, VI5_DATA9_MARK, +}; +static const unsigned int vin5_data12_pins[] = { + RCAR_GP_PIN(0, 0), RCAR_GP_PIN(0, 1), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), + RCAR_GP_PIN(1, 12), RCAR_GP_PIN(1, 13), + RCAR_GP_PIN(1, 14), RCAR_GP_PIN(1, 15), +}; +static const unsigned int vin5_data12_mux[] = { + VI5_DATA0_MARK, VI5_DATA1_MARK, + VI5_DATA2_MARK, VI5_DATA3_MARK, + VI5_DATA4_MARK, VI5_DATA5_MARK, + VI5_DATA6_MARK, VI5_DATA7_MARK, + VI5_DATA8_MARK, VI5_DATA9_MARK, + VI5_DATA10_MARK, VI5_DATA11_MARK, +}; +static const unsigned int vin5_data16_pins[] = { + RCAR_GP_PIN(0, 0), RCAR_GP_PIN(0, 1), + RCAR_GP_PIN(0, 2), RCAR_GP_PIN(0, 3), + RCAR_GP_PIN(0, 4), RCAR_GP_PIN(0, 5), + RCAR_GP_PIN(0, 6), RCAR_GP_PIN(0, 7), + RCAR_GP_PIN(1, 12), RCAR_GP_PIN(1, 13), + RCAR_GP_PIN(1, 14), RCAR_GP_PIN(1, 15), + RCAR_GP_PIN(1, 4), RCAR_GP_PIN(1, 5), + RCAR_GP_PIN(1, 6), RCAR_GP_PIN(1, 7), +}; +static const unsigned int vin5_data16_mux[] = { + VI5_DATA0_MARK, VI5_DATA1_MARK, + VI5_DATA2_MARK, VI5_DATA3_MARK, + VI5_DATA4_MARK, VI5_DATA5_MARK, + VI5_DATA6_MARK, VI5_DATA7_MARK, + VI5_DATA8_MARK, VI5_DATA9_MARK, + VI5_DATA10_MARK, VI5_DATA11_MARK, + VI5_DATA12_MARK, VI5_DATA13_MARK, + VI5_DATA14_MARK, VI5_DATA15_MARK, +}; +static const unsigned int vin5_sync_pins[] = { + /* HSYNC#, VSYNC# */ + RCAR_GP_PIN(1, 10), RCAR_GP_PIN(1, 9), +}; +static const unsigned int vin5_sync_mux[] = { + VI5_HSYNC_N_MARK, VI5_VSYNC_N_MARK, +}; +static const unsigned int vin5_field_pins[] = { + RCAR_GP_PIN(1, 11), +}; +static const unsigned int vin5_field_mux[] = { + /* FIELD */ + VI5_FIELD_MARK, +}; +static const unsigned int vin5_clkenb_pins[] = { + RCAR_GP_PIN(1, 20), +}; +static const unsigned int vin5_clkenb_mux[] = { + /* CLKENB */ + VI5_CLKENB_MARK, +}; +static const unsigned int vin5_clk_pins[] = { + RCAR_GP_PIN(1, 21), +}; +static const unsigned int vin5_clk_mux[] = { + /* CLK */ + VI5_CLK_MARK, +}; + +static const struct sh_pfc_pin_group pinmux_groups[] = { + SH_PFC_PIN_GROUP(audio_clk_a_a), + SH_PFC_PIN_GROUP(audio_clk_a_b), + SH_PFC_PIN_GROUP(audio_clk_a_c), + SH_PFC_PIN_GROUP(audio_clk_b_a), + SH_PFC_PIN_GROUP(audio_clk_b_b), + SH_PFC_PIN_GROUP(audio_clk_c_a), + SH_PFC_PIN_GROUP(audio_clk_c_b), + SH_PFC_PIN_GROUP(audio_clkout_a), + SH_PFC_PIN_GROUP(audio_clkout_b), + SH_PFC_PIN_GROUP(audio_clkout_c), + SH_PFC_PIN_GROUP(audio_clkout_d), + SH_PFC_PIN_GROUP(audio_clkout1_a), + SH_PFC_PIN_GROUP(audio_clkout1_b), + SH_PFC_PIN_GROUP(audio_clkout2_a), + SH_PFC_PIN_GROUP(audio_clkout2_b), + SH_PFC_PIN_GROUP(audio_clkout3_a), + SH_PFC_PIN_GROUP(audio_clkout3_b), + SH_PFC_PIN_GROUP(avb_link), + SH_PFC_PIN_GROUP(avb_magic), + SH_PFC_PIN_GROUP(avb_phy_int), + SH_PFC_PIN_GROUP_ALIAS(avb_mdc, avb_mdio), /* Deprecated */ + SH_PFC_PIN_GROUP(avb_mdio), + SH_PFC_PIN_GROUP(avb_mii), + SH_PFC_PIN_GROUP(avb_avtp_pps), + SH_PFC_PIN_GROUP(avb_avtp_match_a), + SH_PFC_PIN_GROUP(avb_avtp_capture_a), + SH_PFC_PIN_GROUP(avb_avtp_match_b), + SH_PFC_PIN_GROUP(avb_avtp_capture_b), + SH_PFC_PIN_GROUP(can0_data_a), + SH_PFC_PIN_GROUP(can0_data_b), + SH_PFC_PIN_GROUP(can1_data), + SH_PFC_PIN_GROUP(can_clk), + SH_PFC_PIN_GROUP(canfd0_data_a), + SH_PFC_PIN_GROUP(canfd0_data_b), + SH_PFC_PIN_GROUP(canfd1_data), + SH_PFC_PIN_GROUP(drif0_ctrl_a), + SH_PFC_PIN_GROUP(drif0_data0_a), + SH_PFC_PIN_GROUP(drif0_data1_a), + SH_PFC_PIN_GROUP(drif0_ctrl_b), + SH_PFC_PIN_GROUP(drif0_data0_b), + SH_PFC_PIN_GROUP(drif0_data1_b), + SH_PFC_PIN_GROUP(drif0_ctrl_c), + SH_PFC_PIN_GROUP(drif0_data0_c), + SH_PFC_PIN_GROUP(drif0_data1_c), + SH_PFC_PIN_GROUP(drif1_ctrl_a), + SH_PFC_PIN_GROUP(drif1_data0_a), + SH_PFC_PIN_GROUP(drif1_data1_a), + SH_PFC_PIN_GROUP(drif1_ctrl_b), + SH_PFC_PIN_GROUP(drif1_data0_b), + SH_PFC_PIN_GROUP(drif1_data1_b), + SH_PFC_PIN_GROUP(drif1_ctrl_c), + SH_PFC_PIN_GROUP(drif1_data0_c), + SH_PFC_PIN_GROUP(drif1_data1_c), + SH_PFC_PIN_GROUP(drif2_ctrl_a), + SH_PFC_PIN_GROUP(drif2_data0_a), + SH_PFC_PIN_GROUP(drif2_data1_a), + SH_PFC_PIN_GROUP(drif2_ctrl_b), + SH_PFC_PIN_GROUP(drif2_data0_b), + SH_PFC_PIN_GROUP(drif2_data1_b), + SH_PFC_PIN_GROUP(drif3_ctrl_a), + SH_PFC_PIN_GROUP(drif3_data0_a), + SH_PFC_PIN_GROUP(drif3_data1_a), + SH_PFC_PIN_GROUP(drif3_ctrl_b), + SH_PFC_PIN_GROUP(drif3_data0_b), + SH_PFC_PIN_GROUP(drif3_data1_b), + SH_PFC_PIN_GROUP(du_rgb666), + SH_PFC_PIN_GROUP(du_rgb888), + SH_PFC_PIN_GROUP(du_clk_out_0), + SH_PFC_PIN_GROUP(du_clk_out_1), + SH_PFC_PIN_GROUP(du_sync), + SH_PFC_PIN_GROUP(du_oddf), + SH_PFC_PIN_GROUP(du_cde), + SH_PFC_PIN_GROUP(du_disp), + SH_PFC_PIN_GROUP(gp7_02), + SH_PFC_PIN_GROUP(gp7_03), + SH_PFC_PIN_GROUP(hscif0_data), + SH_PFC_PIN_GROUP(hscif0_clk), + SH_PFC_PIN_GROUP(hscif0_ctrl), + SH_PFC_PIN_GROUP(hscif1_data_a), + SH_PFC_PIN_GROUP(hscif1_clk_a), + SH_PFC_PIN_GROUP(hscif1_ctrl_a), + SH_PFC_PIN_GROUP(hscif1_data_b), + SH_PFC_PIN_GROUP(hscif1_clk_b), + SH_PFC_PIN_GROUP(hscif1_ctrl_b), + SH_PFC_PIN_GROUP(hscif2_data_a), + SH_PFC_PIN_GROUP(hscif2_clk_a), + SH_PFC_PIN_GROUP(hscif2_ctrl_a), + SH_PFC_PIN_GROUP(hscif2_data_b), + SH_PFC_PIN_GROUP(hscif2_clk_b), + SH_PFC_PIN_GROUP(hscif2_ctrl_b), + SH_PFC_PIN_GROUP(hscif2_data_c), + SH_PFC_PIN_GROUP(hscif2_clk_c), + SH_PFC_PIN_GROUP(hscif2_ctrl_c), + SH_PFC_PIN_GROUP(hscif3_data_a), + SH_PFC_PIN_GROUP(hscif3_clk), + SH_PFC_PIN_GROUP(hscif3_ctrl), + SH_PFC_PIN_GROUP(hscif3_data_b), + SH_PFC_PIN_GROUP(hscif3_data_c), + SH_PFC_PIN_GROUP(hscif3_data_d), + SH_PFC_PIN_GROUP(hscif4_data_a), + SH_PFC_PIN_GROUP(hscif4_clk), + SH_PFC_PIN_GROUP(hscif4_ctrl), + SH_PFC_PIN_GROUP(hscif4_data_b), + SH_PFC_PIN_GROUP(i2c1_a), + SH_PFC_PIN_GROUP(i2c1_b), + SH_PFC_PIN_GROUP(i2c2_a), + SH_PFC_PIN_GROUP(i2c2_b), + SH_PFC_PIN_GROUP(i2c6_a), + SH_PFC_PIN_GROUP(i2c6_b), + SH_PFC_PIN_GROUP(i2c6_c), + SH_PFC_PIN_GROUP(intc_ex_irq0), + SH_PFC_PIN_GROUP(intc_ex_irq1), + SH_PFC_PIN_GROUP(intc_ex_irq2), + SH_PFC_PIN_GROUP(intc_ex_irq3), + SH_PFC_PIN_GROUP(intc_ex_irq4), + SH_PFC_PIN_GROUP(intc_ex_irq5), + SH_PFC_PIN_GROUP(msiof0_clk), + SH_PFC_PIN_GROUP(msiof0_sync), + SH_PFC_PIN_GROUP(msiof0_ss1), + SH_PFC_PIN_GROUP(msiof0_ss2), + SH_PFC_PIN_GROUP(msiof0_txd), + SH_PFC_PIN_GROUP(msiof0_rxd), + SH_PFC_PIN_GROUP(msiof1_clk_a), + SH_PFC_PIN_GROUP(msiof1_sync_a), + SH_PFC_PIN_GROUP(msiof1_ss1_a), + SH_PFC_PIN_GROUP(msiof1_ss2_a), + SH_PFC_PIN_GROUP(msiof1_txd_a), + SH_PFC_PIN_GROUP(msiof1_rxd_a), + SH_PFC_PIN_GROUP(msiof1_clk_b), + SH_PFC_PIN_GROUP(msiof1_sync_b), + SH_PFC_PIN_GROUP(msiof1_ss1_b), + SH_PFC_PIN_GROUP(msiof1_ss2_b), + SH_PFC_PIN_GROUP(msiof1_txd_b), + SH_PFC_PIN_GROUP(msiof1_rxd_b), + SH_PFC_PIN_GROUP(msiof1_clk_c), + SH_PFC_PIN_GROUP(msiof1_sync_c), + SH_PFC_PIN_GROUP(msiof1_ss1_c), + SH_PFC_PIN_GROUP(msiof1_ss2_c), + SH_PFC_PIN_GROUP(msiof1_txd_c), + SH_PFC_PIN_GROUP(msiof1_rxd_c), + SH_PFC_PIN_GROUP(msiof1_clk_d), + SH_PFC_PIN_GROUP(msiof1_sync_d), + SH_PFC_PIN_GROUP(msiof1_ss1_d), + SH_PFC_PIN_GROUP(msiof1_ss2_d), + SH_PFC_PIN_GROUP(msiof1_txd_d), + SH_PFC_PIN_GROUP(msiof1_rxd_d), + SH_PFC_PIN_GROUP(msiof1_clk_e), + SH_PFC_PIN_GROUP(msiof1_sync_e), + SH_PFC_PIN_GROUP(msiof1_ss1_e), + SH_PFC_PIN_GROUP(msiof1_ss2_e), + SH_PFC_PIN_GROUP(msiof1_txd_e), + SH_PFC_PIN_GROUP(msiof1_rxd_e), + SH_PFC_PIN_GROUP(msiof1_clk_f), + SH_PFC_PIN_GROUP(msiof1_sync_f), + SH_PFC_PIN_GROUP(msiof1_ss1_f), + SH_PFC_PIN_GROUP(msiof1_ss2_f), + SH_PFC_PIN_GROUP(msiof1_txd_f), + SH_PFC_PIN_GROUP(msiof1_rxd_f), + SH_PFC_PIN_GROUP(msiof1_clk_g), + SH_PFC_PIN_GROUP(msiof1_sync_g), + SH_PFC_PIN_GROUP(msiof1_ss1_g), + SH_PFC_PIN_GROUP(msiof1_ss2_g), + SH_PFC_PIN_GROUP(msiof1_txd_g), + SH_PFC_PIN_GROUP(msiof1_rxd_g), + SH_PFC_PIN_GROUP(msiof2_clk_a), + SH_PFC_PIN_GROUP(msiof2_sync_a), + SH_PFC_PIN_GROUP(msiof2_ss1_a), + SH_PFC_PIN_GROUP(msiof2_ss2_a), + SH_PFC_PIN_GROUP(msiof2_txd_a), + SH_PFC_PIN_GROUP(msiof2_rxd_a), + SH_PFC_PIN_GROUP(msiof2_clk_b), + SH_PFC_PIN_GROUP(msiof2_sync_b), + SH_PFC_PIN_GROUP(msiof2_ss1_b), + SH_PFC_PIN_GROUP(msiof2_ss2_b), + SH_PFC_PIN_GROUP(msiof2_txd_b), + SH_PFC_PIN_GROUP(msiof2_rxd_b), + SH_PFC_PIN_GROUP(msiof2_clk_c), + SH_PFC_PIN_GROUP(msiof2_sync_c), + SH_PFC_PIN_GROUP(msiof2_ss1_c), + SH_PFC_PIN_GROUP(msiof2_ss2_c), + SH_PFC_PIN_GROUP(msiof2_txd_c), + SH_PFC_PIN_GROUP(msiof2_rxd_c), + SH_PFC_PIN_GROUP(msiof2_clk_d), + SH_PFC_PIN_GROUP(msiof2_sync_d), + SH_PFC_PIN_GROUP(msiof2_ss1_d), + SH_PFC_PIN_GROUP(msiof2_ss2_d), + SH_PFC_PIN_GROUP(msiof2_txd_d), + SH_PFC_PIN_GROUP(msiof2_rxd_d), + SH_PFC_PIN_GROUP(msiof3_clk_a), + SH_PFC_PIN_GROUP(msiof3_sync_a), + SH_PFC_PIN_GROUP(msiof3_ss1_a), + SH_PFC_PIN_GROUP(msiof3_ss2_a), + SH_PFC_PIN_GROUP(msiof3_txd_a), + SH_PFC_PIN_GROUP(msiof3_rxd_a), + SH_PFC_PIN_GROUP(msiof3_clk_b), + SH_PFC_PIN_GROUP(msiof3_sync_b), + SH_PFC_PIN_GROUP(msiof3_ss1_b), + SH_PFC_PIN_GROUP(msiof3_ss2_b), + SH_PFC_PIN_GROUP(msiof3_txd_b), + SH_PFC_PIN_GROUP(msiof3_rxd_b), + SH_PFC_PIN_GROUP(msiof3_clk_c), + SH_PFC_PIN_GROUP(msiof3_sync_c), + SH_PFC_PIN_GROUP(msiof3_txd_c), + SH_PFC_PIN_GROUP(msiof3_rxd_c), + SH_PFC_PIN_GROUP(msiof3_clk_d), + SH_PFC_PIN_GROUP(msiof3_sync_d), + SH_PFC_PIN_GROUP(msiof3_ss1_d), + SH_PFC_PIN_GROUP(msiof3_txd_d), + SH_PFC_PIN_GROUP(msiof3_rxd_d), + SH_PFC_PIN_GROUP(msiof3_clk_e), + SH_PFC_PIN_GROUP(msiof3_sync_e), + SH_PFC_PIN_GROUP(msiof3_ss1_e), + SH_PFC_PIN_GROUP(msiof3_ss2_e), + SH_PFC_PIN_GROUP(msiof3_txd_e), + SH_PFC_PIN_GROUP(msiof3_rxd_e), + SH_PFC_PIN_GROUP(pwm0), + SH_PFC_PIN_GROUP(pwm1_a), + SH_PFC_PIN_GROUP(pwm1_b), + SH_PFC_PIN_GROUP(pwm2_a), + SH_PFC_PIN_GROUP(pwm2_b), + SH_PFC_PIN_GROUP(pwm3_a), + SH_PFC_PIN_GROUP(pwm3_b), + SH_PFC_PIN_GROUP(pwm4_a), + SH_PFC_PIN_GROUP(pwm4_b), + SH_PFC_PIN_GROUP(pwm5_a), + SH_PFC_PIN_GROUP(pwm5_b), + SH_PFC_PIN_GROUP(pwm6_a), + SH_PFC_PIN_GROUP(pwm6_b), + SH_PFC_PIN_GROUP(sata0_devslp_a), + SH_PFC_PIN_GROUP(scif0_data), + SH_PFC_PIN_GROUP(scif0_clk), + SH_PFC_PIN_GROUP(scif0_ctrl), + SH_PFC_PIN_GROUP(scif1_data_a), + SH_PFC_PIN_GROUP(scif1_clk), + SH_PFC_PIN_GROUP(scif1_ctrl), + SH_PFC_PIN_GROUP(scif1_data_b), + SH_PFC_PIN_GROUP(scif2_data_a), + SH_PFC_PIN_GROUP(scif2_clk), + SH_PFC_PIN_GROUP(scif2_data_b), + SH_PFC_PIN_GROUP(scif3_data_a), + SH_PFC_PIN_GROUP(scif3_clk), + SH_PFC_PIN_GROUP(scif3_ctrl), + SH_PFC_PIN_GROUP(scif3_data_b), + SH_PFC_PIN_GROUP(scif4_data_a), + SH_PFC_PIN_GROUP(scif4_clk_a), + SH_PFC_PIN_GROUP(scif4_ctrl_a), + SH_PFC_PIN_GROUP(scif4_data_b), + SH_PFC_PIN_GROUP(scif4_clk_b), + SH_PFC_PIN_GROUP(scif4_ctrl_b), + SH_PFC_PIN_GROUP(scif4_data_c), + SH_PFC_PIN_GROUP(scif4_clk_c), + SH_PFC_PIN_GROUP(scif4_ctrl_c), + SH_PFC_PIN_GROUP(scif5_data_a), + SH_PFC_PIN_GROUP(scif5_clk_a), + SH_PFC_PIN_GROUP(scif5_data_b), + SH_PFC_PIN_GROUP(scif5_clk_b), + SH_PFC_PIN_GROUP(scif_clk_a), + SH_PFC_PIN_GROUP(scif_clk_b), + SH_PFC_PIN_GROUP(sdhi0_data1), + SH_PFC_PIN_GROUP(sdhi0_data4), + SH_PFC_PIN_GROUP(sdhi0_ctrl), + SH_PFC_PIN_GROUP(sdhi0_cd), + SH_PFC_PIN_GROUP(sdhi0_wp), + SH_PFC_PIN_GROUP(sdhi1_data1), + SH_PFC_PIN_GROUP(sdhi1_data4), + SH_PFC_PIN_GROUP(sdhi1_ctrl), + SH_PFC_PIN_GROUP(sdhi1_cd), + SH_PFC_PIN_GROUP(sdhi1_wp), + SH_PFC_PIN_GROUP(sdhi2_data1), + SH_PFC_PIN_GROUP(sdhi2_data4), + SH_PFC_PIN_GROUP(sdhi2_data8), + SH_PFC_PIN_GROUP(sdhi2_ctrl), + SH_PFC_PIN_GROUP(sdhi2_cd_a), + SH_PFC_PIN_GROUP(sdhi2_wp_a), + SH_PFC_PIN_GROUP(sdhi2_cd_b), + SH_PFC_PIN_GROUP(sdhi2_wp_b), + SH_PFC_PIN_GROUP(sdhi2_ds), + SH_PFC_PIN_GROUP(sdhi3_data1), + SH_PFC_PIN_GROUP(sdhi3_data4), + SH_PFC_PIN_GROUP(sdhi3_data8), + SH_PFC_PIN_GROUP(sdhi3_ctrl), + SH_PFC_PIN_GROUP(sdhi3_cd), + SH_PFC_PIN_GROUP(sdhi3_wp), + SH_PFC_PIN_GROUP(sdhi3_ds), + SH_PFC_PIN_GROUP(ssi0_data), + SH_PFC_PIN_GROUP(ssi01239_ctrl), + SH_PFC_PIN_GROUP(ssi1_data_a), + SH_PFC_PIN_GROUP(ssi1_data_b), + SH_PFC_PIN_GROUP(ssi1_ctrl_a), + SH_PFC_PIN_GROUP(ssi1_ctrl_b), + SH_PFC_PIN_GROUP(ssi2_data_a), + SH_PFC_PIN_GROUP(ssi2_data_b), + SH_PFC_PIN_GROUP(ssi2_ctrl_a), + SH_PFC_PIN_GROUP(ssi2_ctrl_b), + SH_PFC_PIN_GROUP(ssi3_data), + SH_PFC_PIN_GROUP(ssi349_ctrl), + SH_PFC_PIN_GROUP(ssi4_data), + SH_PFC_PIN_GROUP(ssi4_ctrl), + SH_PFC_PIN_GROUP(ssi5_data), + SH_PFC_PIN_GROUP(ssi5_ctrl), + SH_PFC_PIN_GROUP(ssi6_data), + SH_PFC_PIN_GROUP(ssi6_ctrl), + SH_PFC_PIN_GROUP(ssi7_data), + SH_PFC_PIN_GROUP(ssi78_ctrl), + SH_PFC_PIN_GROUP(ssi8_data), + SH_PFC_PIN_GROUP(ssi9_data_a), + SH_PFC_PIN_GROUP(ssi9_data_b), + SH_PFC_PIN_GROUP(ssi9_ctrl_a), + SH_PFC_PIN_GROUP(ssi9_ctrl_b), + SH_PFC_PIN_GROUP(tmu_tclk1_a), + SH_PFC_PIN_GROUP(tmu_tclk1_b), + SH_PFC_PIN_GROUP(tmu_tclk2_a), + SH_PFC_PIN_GROUP(tmu_tclk2_b), + SH_PFC_PIN_GROUP(usb0), + SH_PFC_PIN_GROUP(usb1), + SH_PFC_PIN_GROUP(usb30), + VIN_DATA_PIN_GROUP(vin4_data_a, 8), + VIN_DATA_PIN_GROUP(vin4_data_a, 10), + VIN_DATA_PIN_GROUP(vin4_data_a, 12), + VIN_DATA_PIN_GROUP(vin4_data_a, 16), + SH_PFC_PIN_GROUP(vin4_data18_a), + VIN_DATA_PIN_GROUP(vin4_data_a, 20), + VIN_DATA_PIN_GROUP(vin4_data_a, 24), + VIN_DATA_PIN_GROUP(vin4_data_b, 8), + VIN_DATA_PIN_GROUP(vin4_data_b, 10), + VIN_DATA_PIN_GROUP(vin4_data_b, 12), + VIN_DATA_PIN_GROUP(vin4_data_b, 16), + SH_PFC_PIN_GROUP(vin4_data18_b), + VIN_DATA_PIN_GROUP(vin4_data_b, 20), + VIN_DATA_PIN_GROUP(vin4_data_b, 24), + SH_PFC_PIN_GROUP(vin4_sync), + SH_PFC_PIN_GROUP(vin4_field), + SH_PFC_PIN_GROUP(vin4_clkenb), + SH_PFC_PIN_GROUP(vin4_clk), + SH_PFC_PIN_GROUP(vin5_data8), + SH_PFC_PIN_GROUP(vin5_data10), + SH_PFC_PIN_GROUP(vin5_data12), + SH_PFC_PIN_GROUP(vin5_data16), + SH_PFC_PIN_GROUP(vin5_sync), + SH_PFC_PIN_GROUP(vin5_field), + SH_PFC_PIN_GROUP(vin5_clkenb), + SH_PFC_PIN_GROUP(vin5_clk), +}; + +static const char * const audio_clk_groups[] = { + "audio_clk_a_a", + "audio_clk_a_b", + "audio_clk_a_c", + "audio_clk_b_a", + "audio_clk_b_b", + "audio_clk_c_a", + "audio_clk_c_b", + "audio_clkout_a", + "audio_clkout_b", + "audio_clkout_c", + "audio_clkout_d", + "audio_clkout1_a", + "audio_clkout1_b", + "audio_clkout2_a", + "audio_clkout2_b", + "audio_clkout3_a", + "audio_clkout3_b", +}; + +static const char * const avb_groups[] = { + "avb_link", + "avb_magic", + "avb_phy_int", + "avb_mdc", /* Deprecated, please use "avb_mdio" instead */ + "avb_mdio", + "avb_mii", + "avb_avtp_pps", + "avb_avtp_match_a", + "avb_avtp_capture_a", + "avb_avtp_match_b", + "avb_avtp_capture_b", +}; + +static const char * const can0_groups[] = { + "can0_data_a", + "can0_data_b", +}; + +static const char * const can1_groups[] = { + "can1_data", +}; + +static const char * const can_clk_groups[] = { + "can_clk", +}; + +static const char * const canfd0_groups[] = { + "canfd0_data_a", + "canfd0_data_b", +}; + +static const char * const canfd1_groups[] = { + "canfd1_data", +}; + +static const char * const drif0_groups[] = { + "drif0_ctrl_a", + "drif0_data0_a", + "drif0_data1_a", + "drif0_ctrl_b", + "drif0_data0_b", + "drif0_data1_b", + "drif0_ctrl_c", + "drif0_data0_c", + "drif0_data1_c", +}; + +static const char * const drif1_groups[] = { + "drif1_ctrl_a", + "drif1_data0_a", + "drif1_data1_a", + "drif1_ctrl_b", + "drif1_data0_b", + "drif1_data1_b", + "drif1_ctrl_c", + "drif1_data0_c", + "drif1_data1_c", +}; + +static const char * const drif2_groups[] = { + "drif2_ctrl_a", + "drif2_data0_a", + "drif2_data1_a", + "drif2_ctrl_b", + "drif2_data0_b", + "drif2_data1_b", +}; + +static const char * const drif3_groups[] = { + "drif3_ctrl_a", + "drif3_data0_a", + "drif3_data1_a", + "drif3_ctrl_b", + "drif3_data0_b", + "drif3_data1_b", +}; + +static const char * const du_groups[] = { + "du_rgb666", + "du_rgb888", + "du_clk_out_0", + "du_clk_out_1", + "du_sync", + "du_oddf", + "du_cde", + "du_disp", +}; + +static const char * const gp7_02_groups[] = { + "gp7_02", +}; + +static const char * const gp7_03_groups[] = { + "gp7_03", +}; + +static const char * const hscif0_groups[] = { + "hscif0_data", + "hscif0_clk", + "hscif0_ctrl", +}; + +static const char * const hscif1_groups[] = { + "hscif1_data_a", + "hscif1_clk_a", + "hscif1_ctrl_a", + "hscif1_data_b", + "hscif1_clk_b", + "hscif1_ctrl_b", +}; + +static const char * const hscif2_groups[] = { + "hscif2_data_a", + "hscif2_clk_a", + "hscif2_ctrl_a", + "hscif2_data_b", + "hscif2_clk_b", + "hscif2_ctrl_b", + "hscif2_data_c", + "hscif2_clk_c", + "hscif2_ctrl_c", +}; + +static const char * const hscif3_groups[] = { + "hscif3_data_a", + "hscif3_clk", + "hscif3_ctrl", + "hscif3_data_b", + "hscif3_data_c", + "hscif3_data_d", +}; + +static const char * const hscif4_groups[] = { + "hscif4_data_a", + "hscif4_clk", + "hscif4_ctrl", + "hscif4_data_b", +}; + +static const char * const i2c1_groups[] = { + "i2c1_a", + "i2c1_b", +}; + +static const char * const i2c2_groups[] = { + "i2c2_a", + "i2c2_b", +}; + +static const char * const i2c6_groups[] = { + "i2c6_a", + "i2c6_b", + "i2c6_c", +}; + +static const char * const intc_ex_groups[] = { + "intc_ex_irq0", + "intc_ex_irq1", + "intc_ex_irq2", + "intc_ex_irq3", + "intc_ex_irq4", + "intc_ex_irq5", +}; + +static const char * const msiof0_groups[] = { + "msiof0_clk", + "msiof0_sync", + "msiof0_ss1", + "msiof0_ss2", + "msiof0_txd", + "msiof0_rxd", +}; + +static const char * const msiof1_groups[] = { + "msiof1_clk_a", + "msiof1_sync_a", + "msiof1_ss1_a", + "msiof1_ss2_a", + "msiof1_txd_a", + "msiof1_rxd_a", + "msiof1_clk_b", + "msiof1_sync_b", + "msiof1_ss1_b", + "msiof1_ss2_b", + "msiof1_txd_b", + "msiof1_rxd_b", + "msiof1_clk_c", + "msiof1_sync_c", + "msiof1_ss1_c", + "msiof1_ss2_c", + "msiof1_txd_c", + "msiof1_rxd_c", + "msiof1_clk_d", + "msiof1_sync_d", + "msiof1_ss1_d", + "msiof1_ss2_d", + "msiof1_txd_d", + "msiof1_rxd_d", + "msiof1_clk_e", + "msiof1_sync_e", + "msiof1_ss1_e", + "msiof1_ss2_e", + "msiof1_txd_e", + "msiof1_rxd_e", + "msiof1_clk_f", + "msiof1_sync_f", + "msiof1_ss1_f", + "msiof1_ss2_f", + "msiof1_txd_f", + "msiof1_rxd_f", + "msiof1_clk_g", + "msiof1_sync_g", + "msiof1_ss1_g", + "msiof1_ss2_g", + "msiof1_txd_g", + "msiof1_rxd_g", +}; + +static const char * const msiof2_groups[] = { + "msiof2_clk_a", + "msiof2_sync_a", + "msiof2_ss1_a", + "msiof2_ss2_a", + "msiof2_txd_a", + "msiof2_rxd_a", + "msiof2_clk_b", + "msiof2_sync_b", + "msiof2_ss1_b", + "msiof2_ss2_b", + "msiof2_txd_b", + "msiof2_rxd_b", + "msiof2_clk_c", + "msiof2_sync_c", + "msiof2_ss1_c", + "msiof2_ss2_c", + "msiof2_txd_c", + "msiof2_rxd_c", + "msiof2_clk_d", + "msiof2_sync_d", + "msiof2_ss1_d", + "msiof2_ss2_d", + "msiof2_txd_d", + "msiof2_rxd_d", +}; + +static const char * const msiof3_groups[] = { + "msiof3_clk_a", + "msiof3_sync_a", + "msiof3_ss1_a", + "msiof3_ss2_a", + "msiof3_txd_a", + "msiof3_rxd_a", + "msiof3_clk_b", + "msiof3_sync_b", + "msiof3_ss1_b", + "msiof3_ss2_b", + "msiof3_txd_b", + "msiof3_rxd_b", + "msiof3_clk_c", + "msiof3_sync_c", + "msiof3_txd_c", + "msiof3_rxd_c", + "msiof3_clk_d", + "msiof3_sync_d", + "msiof3_ss1_d", + "msiof3_txd_d", + "msiof3_rxd_d", + "msiof3_clk_e", + "msiof3_sync_e", + "msiof3_ss1_e", + "msiof3_ss2_e", + "msiof3_txd_e", + "msiof3_rxd_e", +}; + +static const char * const pwm0_groups[] = { + "pwm0", +}; + +static const char * const pwm1_groups[] = { + "pwm1_a", + "pwm1_b", +}; + +static const char * const pwm2_groups[] = { + "pwm2_a", + "pwm2_b", +}; + +static const char * const pwm3_groups[] = { + "pwm3_a", + "pwm3_b", +}; + +static const char * const pwm4_groups[] = { + "pwm4_a", + "pwm4_b", +}; + +static const char * const pwm5_groups[] = { + "pwm5_a", + "pwm5_b", +}; + +static const char * const pwm6_groups[] = { + "pwm6_a", + "pwm6_b", +}; + +static const char * const sata0_groups[] = { + "sata0_devslp_a", +}; + +static const char * const scif0_groups[] = { + "scif0_data", + "scif0_clk", + "scif0_ctrl", +}; + +static const char * const scif1_groups[] = { + "scif1_data_a", + "scif1_clk", + "scif1_ctrl", + "scif1_data_b", +}; + +static const char * const scif2_groups[] = { + "scif2_data_a", + "scif2_clk", + "scif2_data_b", +}; + +static const char * const scif3_groups[] = { + "scif3_data_a", + "scif3_clk", + "scif3_ctrl", + "scif3_data_b", +}; + +static const char * const scif4_groups[] = { + "scif4_data_a", + "scif4_clk_a", + "scif4_ctrl_a", + "scif4_data_b", + "scif4_clk_b", + "scif4_ctrl_b", + "scif4_data_c", + "scif4_clk_c", + "scif4_ctrl_c", +}; + +static const char * const scif5_groups[] = { + "scif5_data_a", + "scif5_clk_a", + "scif5_data_b", + "scif5_clk_b", +}; + +static const char * const scif_clk_groups[] = { + "scif_clk_a", + "scif_clk_b", +}; + +static const char * const sdhi0_groups[] = { + "sdhi0_data1", + "sdhi0_data4", + "sdhi0_ctrl", + "sdhi0_cd", + "sdhi0_wp", +}; + +static const char * const sdhi1_groups[] = { + "sdhi1_data1", + "sdhi1_data4", + "sdhi1_ctrl", + "sdhi1_cd", + "sdhi1_wp", +}; + +static const char * const sdhi2_groups[] = { + "sdhi2_data1", + "sdhi2_data4", + "sdhi2_data8", + "sdhi2_ctrl", + "sdhi2_cd_a", + "sdhi2_wp_a", + "sdhi2_cd_b", + "sdhi2_wp_b", + "sdhi2_ds", +}; + +static const char * const sdhi3_groups[] = { + "sdhi3_data1", + "sdhi3_data4", + "sdhi3_data8", + "sdhi3_ctrl", + "sdhi3_cd", + "sdhi3_wp", + "sdhi3_ds", +}; + +static const char * const ssi_groups[] = { + "ssi0_data", + "ssi01239_ctrl", + "ssi1_data_a", + "ssi1_data_b", + "ssi1_ctrl_a", + "ssi1_ctrl_b", + "ssi2_data_a", + "ssi2_data_b", + "ssi2_ctrl_a", + "ssi2_ctrl_b", + "ssi3_data", + "ssi349_ctrl", + "ssi4_data", + "ssi4_ctrl", + "ssi5_data", + "ssi5_ctrl", + "ssi6_data", + "ssi6_ctrl", + "ssi7_data", + "ssi78_ctrl", + "ssi8_data", + "ssi9_data_a", + "ssi9_data_b", + "ssi9_ctrl_a", + "ssi9_ctrl_b", +}; + +static const char * const tmu_groups[] = { + "tmu_tclk1_a", + "tmu_tclk1_b", + "tmu_tclk2_a", + "tmu_tclk2_b", +}; + +static const char * const usb0_groups[] = { + "usb0", +}; + +static const char * const usb1_groups[] = { + "usb1", +}; + +static const char * const usb30_groups[] = { + "usb30", +}; + +static const char * const vin4_groups[] = { + "vin4_data8_a", + "vin4_data10_a", + "vin4_data12_a", + "vin4_data16_a", + "vin4_data18_a", + "vin4_data20_a", + "vin4_data24_a", + "vin4_data8_b", + "vin4_data10_b", + "vin4_data12_b", + "vin4_data16_b", + "vin4_data18_b", + "vin4_data20_b", + "vin4_data24_b", + "vin4_sync", + "vin4_field", + "vin4_clkenb", + "vin4_clk", +}; + +static const char * const vin5_groups[] = { + "vin5_data8", + "vin5_data10", + "vin5_data12", + "vin5_data16", + "vin5_sync", + "vin5_field", + "vin5_clkenb", + "vin5_clk", +}; + +static const struct sh_pfc_function pinmux_functions[] = { + SH_PFC_FUNCTION(audio_clk), + SH_PFC_FUNCTION(avb), + SH_PFC_FUNCTION(can0), + SH_PFC_FUNCTION(can1), + SH_PFC_FUNCTION(can_clk), + SH_PFC_FUNCTION(canfd0), + SH_PFC_FUNCTION(canfd1), + SH_PFC_FUNCTION(drif0), + SH_PFC_FUNCTION(drif1), + SH_PFC_FUNCTION(drif2), + SH_PFC_FUNCTION(drif3), + SH_PFC_FUNCTION(du), + SH_PFC_FUNCTION(gp7_02), + SH_PFC_FUNCTION(gp7_03), + SH_PFC_FUNCTION(hscif0), + SH_PFC_FUNCTION(hscif1), + SH_PFC_FUNCTION(hscif2), + SH_PFC_FUNCTION(hscif3), + SH_PFC_FUNCTION(hscif4), + SH_PFC_FUNCTION(i2c1), + SH_PFC_FUNCTION(i2c2), + SH_PFC_FUNCTION(i2c6), + SH_PFC_FUNCTION(intc_ex), + SH_PFC_FUNCTION(msiof0), + SH_PFC_FUNCTION(msiof1), + SH_PFC_FUNCTION(msiof2), + SH_PFC_FUNCTION(msiof3), + SH_PFC_FUNCTION(pwm0), + SH_PFC_FUNCTION(pwm1), + SH_PFC_FUNCTION(pwm2), + SH_PFC_FUNCTION(pwm3), + SH_PFC_FUNCTION(pwm4), + SH_PFC_FUNCTION(pwm5), + SH_PFC_FUNCTION(pwm6), + SH_PFC_FUNCTION(sata0), + SH_PFC_FUNCTION(scif0), + SH_PFC_FUNCTION(scif1), + SH_PFC_FUNCTION(scif2), + SH_PFC_FUNCTION(scif3), + SH_PFC_FUNCTION(scif4), + SH_PFC_FUNCTION(scif5), + SH_PFC_FUNCTION(scif_clk), + SH_PFC_FUNCTION(sdhi0), + SH_PFC_FUNCTION(sdhi1), + SH_PFC_FUNCTION(sdhi2), + SH_PFC_FUNCTION(sdhi3), + SH_PFC_FUNCTION(ssi), + SH_PFC_FUNCTION(tmu), + SH_PFC_FUNCTION(usb0), + SH_PFC_FUNCTION(usb1), + SH_PFC_FUNCTION(usb30), + SH_PFC_FUNCTION(vin4), + SH_PFC_FUNCTION(vin5), +}; + +static const struct pinmux_cfg_reg pinmux_config_regs[] = { +#define F_(x, y) FN_##y +#define FM(x) FN_##x + { PINMUX_CFG_REG("GPSR0", 0xe6060100, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + GP_0_15_FN, GPSR0_15, + GP_0_14_FN, GPSR0_14, + GP_0_13_FN, GPSR0_13, + GP_0_12_FN, GPSR0_12, + GP_0_11_FN, GPSR0_11, + GP_0_10_FN, GPSR0_10, + GP_0_9_FN, GPSR0_9, + GP_0_8_FN, GPSR0_8, + GP_0_7_FN, GPSR0_7, + GP_0_6_FN, GPSR0_6, + GP_0_5_FN, GPSR0_5, + GP_0_4_FN, GPSR0_4, + GP_0_3_FN, GPSR0_3, + GP_0_2_FN, GPSR0_2, + GP_0_1_FN, GPSR0_1, + GP_0_0_FN, GPSR0_0, )) + }, + { PINMUX_CFG_REG("GPSR1", 0xe6060104, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + GP_1_28_FN, GPSR1_28, + GP_1_27_FN, GPSR1_27, + GP_1_26_FN, GPSR1_26, + GP_1_25_FN, GPSR1_25, + GP_1_24_FN, GPSR1_24, + GP_1_23_FN, GPSR1_23, + GP_1_22_FN, GPSR1_22, + GP_1_21_FN, GPSR1_21, + GP_1_20_FN, GPSR1_20, + GP_1_19_FN, GPSR1_19, + GP_1_18_FN, GPSR1_18, + GP_1_17_FN, GPSR1_17, + GP_1_16_FN, GPSR1_16, + GP_1_15_FN, GPSR1_15, + GP_1_14_FN, GPSR1_14, + GP_1_13_FN, GPSR1_13, + GP_1_12_FN, GPSR1_12, + GP_1_11_FN, GPSR1_11, + GP_1_10_FN, GPSR1_10, + GP_1_9_FN, GPSR1_9, + GP_1_8_FN, GPSR1_8, + GP_1_7_FN, GPSR1_7, + GP_1_6_FN, GPSR1_6, + GP_1_5_FN, GPSR1_5, + GP_1_4_FN, GPSR1_4, + GP_1_3_FN, GPSR1_3, + GP_1_2_FN, GPSR1_2, + GP_1_1_FN, GPSR1_1, + GP_1_0_FN, GPSR1_0, )) + }, + { PINMUX_CFG_REG("GPSR2", 0xe6060108, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + GP_2_14_FN, GPSR2_14, + GP_2_13_FN, GPSR2_13, + GP_2_12_FN, GPSR2_12, + GP_2_11_FN, GPSR2_11, + GP_2_10_FN, GPSR2_10, + GP_2_9_FN, GPSR2_9, + GP_2_8_FN, GPSR2_8, + GP_2_7_FN, GPSR2_7, + GP_2_6_FN, GPSR2_6, + GP_2_5_FN, GPSR2_5, + GP_2_4_FN, GPSR2_4, + GP_2_3_FN, GPSR2_3, + GP_2_2_FN, GPSR2_2, + GP_2_1_FN, GPSR2_1, + GP_2_0_FN, GPSR2_0, )) + }, + { PINMUX_CFG_REG("GPSR3", 0xe606010c, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + GP_3_15_FN, GPSR3_15, + GP_3_14_FN, GPSR3_14, + GP_3_13_FN, GPSR3_13, + GP_3_12_FN, GPSR3_12, + GP_3_11_FN, GPSR3_11, + GP_3_10_FN, GPSR3_10, + GP_3_9_FN, GPSR3_9, + GP_3_8_FN, GPSR3_8, + GP_3_7_FN, GPSR3_7, + GP_3_6_FN, GPSR3_6, + GP_3_5_FN, GPSR3_5, + GP_3_4_FN, GPSR3_4, + GP_3_3_FN, GPSR3_3, + GP_3_2_FN, GPSR3_2, + GP_3_1_FN, GPSR3_1, + GP_3_0_FN, GPSR3_0, )) + }, + { PINMUX_CFG_REG("GPSR4", 0xe6060110, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + GP_4_17_FN, GPSR4_17, + GP_4_16_FN, GPSR4_16, + GP_4_15_FN, GPSR4_15, + GP_4_14_FN, GPSR4_14, + GP_4_13_FN, GPSR4_13, + GP_4_12_FN, GPSR4_12, + GP_4_11_FN, GPSR4_11, + GP_4_10_FN, GPSR4_10, + GP_4_9_FN, GPSR4_9, + GP_4_8_FN, GPSR4_8, + GP_4_7_FN, GPSR4_7, + GP_4_6_FN, GPSR4_6, + GP_4_5_FN, GPSR4_5, + GP_4_4_FN, GPSR4_4, + GP_4_3_FN, GPSR4_3, + GP_4_2_FN, GPSR4_2, + GP_4_1_FN, GPSR4_1, + GP_4_0_FN, GPSR4_0, )) + }, + { PINMUX_CFG_REG("GPSR5", 0xe6060114, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + GP_5_25_FN, GPSR5_25, + GP_5_24_FN, GPSR5_24, + GP_5_23_FN, GPSR5_23, + GP_5_22_FN, GPSR5_22, + GP_5_21_FN, GPSR5_21, + GP_5_20_FN, GPSR5_20, + GP_5_19_FN, GPSR5_19, + GP_5_18_FN, GPSR5_18, + GP_5_17_FN, GPSR5_17, + GP_5_16_FN, GPSR5_16, + GP_5_15_FN, GPSR5_15, + GP_5_14_FN, GPSR5_14, + GP_5_13_FN, GPSR5_13, + GP_5_12_FN, GPSR5_12, + GP_5_11_FN, GPSR5_11, + GP_5_10_FN, GPSR5_10, + GP_5_9_FN, GPSR5_9, + GP_5_8_FN, GPSR5_8, + GP_5_7_FN, GPSR5_7, + GP_5_6_FN, GPSR5_6, + GP_5_5_FN, GPSR5_5, + GP_5_4_FN, GPSR5_4, + GP_5_3_FN, GPSR5_3, + GP_5_2_FN, GPSR5_2, + GP_5_1_FN, GPSR5_1, + GP_5_0_FN, GPSR5_0, )) + }, + { PINMUX_CFG_REG("GPSR6", 0xe6060118, 32, 1, GROUP( + GP_6_31_FN, GPSR6_31, + GP_6_30_FN, GPSR6_30, + GP_6_29_FN, GPSR6_29, + GP_6_28_FN, GPSR6_28, + GP_6_27_FN, GPSR6_27, + GP_6_26_FN, GPSR6_26, + GP_6_25_FN, GPSR6_25, + GP_6_24_FN, GPSR6_24, + GP_6_23_FN, GPSR6_23, + GP_6_22_FN, GPSR6_22, + GP_6_21_FN, GPSR6_21, + GP_6_20_FN, GPSR6_20, + GP_6_19_FN, GPSR6_19, + GP_6_18_FN, GPSR6_18, + GP_6_17_FN, GPSR6_17, + GP_6_16_FN, GPSR6_16, + GP_6_15_FN, GPSR6_15, + GP_6_14_FN, GPSR6_14, + GP_6_13_FN, GPSR6_13, + GP_6_12_FN, GPSR6_12, + GP_6_11_FN, GPSR6_11, + GP_6_10_FN, GPSR6_10, + GP_6_9_FN, GPSR6_9, + GP_6_8_FN, GPSR6_8, + GP_6_7_FN, GPSR6_7, + GP_6_6_FN, GPSR6_6, + GP_6_5_FN, GPSR6_5, + GP_6_4_FN, GPSR6_4, + GP_6_3_FN, GPSR6_3, + GP_6_2_FN, GPSR6_2, + GP_6_1_FN, GPSR6_1, + GP_6_0_FN, GPSR6_0, )) + }, + { PINMUX_CFG_REG("GPSR7", 0xe606011c, 32, 1, GROUP( + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + GP_7_3_FN, GPSR7_3, + GP_7_2_FN, GPSR7_2, + GP_7_1_FN, GPSR7_1, + GP_7_0_FN, GPSR7_0, )) + }, +#undef F_ +#undef FM + +#define F_(x, y) x, +#define FM(x) FN_##x, + { PINMUX_CFG_REG("IPSR0", 0xe6060200, 32, 4, GROUP( + IP0_31_28 + IP0_27_24 + IP0_23_20 + IP0_19_16 + IP0_15_12 + IP0_11_8 + IP0_7_4 + IP0_3_0 )) + }, + { PINMUX_CFG_REG("IPSR1", 0xe6060204, 32, 4, GROUP( + IP1_31_28 + IP1_27_24 + IP1_23_20 + IP1_19_16 + IP1_15_12 + IP1_11_8 + IP1_7_4 + IP1_3_0 )) + }, + { PINMUX_CFG_REG("IPSR2", 0xe6060208, 32, 4, GROUP( + IP2_31_28 + IP2_27_24 + IP2_23_20 + IP2_19_16 + IP2_15_12 + IP2_11_8 + IP2_7_4 + IP2_3_0 )) + }, + { PINMUX_CFG_REG("IPSR3", 0xe606020c, 32, 4, GROUP( + IP3_31_28 + IP3_27_24 + IP3_23_20 + IP3_19_16 + IP3_15_12 + IP3_11_8 + IP3_7_4 + IP3_3_0 )) + }, + { PINMUX_CFG_REG("IPSR4", 0xe6060210, 32, 4, GROUP( + IP4_31_28 + IP4_27_24 + IP4_23_20 + IP4_19_16 + IP4_15_12 + IP4_11_8 + IP4_7_4 + IP4_3_0 )) + }, + { PINMUX_CFG_REG("IPSR5", 0xe6060214, 32, 4, GROUP( + IP5_31_28 + IP5_27_24 + IP5_23_20 + IP5_19_16 + IP5_15_12 + IP5_11_8 + IP5_7_4 + IP5_3_0 )) + }, + { PINMUX_CFG_REG("IPSR6", 0xe6060218, 32, 4, GROUP( + IP6_31_28 + IP6_27_24 + IP6_23_20 + IP6_19_16 + IP6_15_12 + IP6_11_8 + IP6_7_4 + IP6_3_0 )) + }, + { PINMUX_CFG_REG("IPSR7", 0xe606021c, 32, 4, GROUP( + IP7_31_28 + IP7_27_24 + IP7_23_20 + IP7_19_16 + /* IP7_15_12 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + IP7_11_8 + IP7_7_4 + IP7_3_0 )) + }, + { PINMUX_CFG_REG("IPSR8", 0xe6060220, 32, 4, GROUP( + IP8_31_28 + IP8_27_24 + IP8_23_20 + IP8_19_16 + IP8_15_12 + IP8_11_8 + IP8_7_4 + IP8_3_0 )) + }, + { PINMUX_CFG_REG("IPSR9", 0xe6060224, 32, 4, GROUP( + IP9_31_28 + IP9_27_24 + IP9_23_20 + IP9_19_16 + IP9_15_12 + IP9_11_8 + IP9_7_4 + IP9_3_0 )) + }, + { PINMUX_CFG_REG("IPSR10", 0xe6060228, 32, 4, GROUP( + IP10_31_28 + IP10_27_24 + IP10_23_20 + IP10_19_16 + IP10_15_12 + IP10_11_8 + IP10_7_4 + IP10_3_0 )) + }, + { PINMUX_CFG_REG("IPSR11", 0xe606022c, 32, 4, GROUP( + IP11_31_28 + IP11_27_24 + IP11_23_20 + IP11_19_16 + IP11_15_12 + IP11_11_8 + IP11_7_4 + IP11_3_0 )) + }, + { PINMUX_CFG_REG("IPSR12", 0xe6060230, 32, 4, GROUP( + IP12_31_28 + IP12_27_24 + IP12_23_20 + IP12_19_16 + IP12_15_12 + IP12_11_8 + IP12_7_4 + IP12_3_0 )) + }, + { PINMUX_CFG_REG("IPSR13", 0xe6060234, 32, 4, GROUP( + IP13_31_28 + IP13_27_24 + IP13_23_20 + IP13_19_16 + IP13_15_12 + IP13_11_8 + IP13_7_4 + IP13_3_0 )) + }, + { PINMUX_CFG_REG("IPSR14", 0xe6060238, 32, 4, GROUP( + IP14_31_28 + IP14_27_24 + IP14_23_20 + IP14_19_16 + IP14_15_12 + IP14_11_8 + IP14_7_4 + IP14_3_0 )) + }, + { PINMUX_CFG_REG("IPSR15", 0xe606023c, 32, 4, GROUP( + IP15_31_28 + IP15_27_24 + IP15_23_20 + IP15_19_16 + IP15_15_12 + IP15_11_8 + IP15_7_4 + IP15_3_0 )) + }, + { PINMUX_CFG_REG("IPSR16", 0xe6060240, 32, 4, GROUP( + IP16_31_28 + IP16_27_24 + IP16_23_20 + IP16_19_16 + IP16_15_12 + IP16_11_8 + IP16_7_4 + IP16_3_0 )) + }, + { PINMUX_CFG_REG("IPSR17", 0xe6060244, 32, 4, GROUP( + IP17_31_28 + IP17_27_24 + IP17_23_20 + IP17_19_16 + IP17_15_12 + IP17_11_8 + IP17_7_4 + IP17_3_0 )) + }, + { PINMUX_CFG_REG("IPSR18", 0xe6060248, 32, 4, GROUP( + /* IP18_31_28 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP18_27_24 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP18_23_20 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP18_19_16 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP18_15_12 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP18_11_8 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + IP18_7_4 + IP18_3_0 )) + }, +#undef F_ +#undef FM + +#define F_(x, y) x, +#define FM(x) FN_##x, + { PINMUX_CFG_REG_VAR("MOD_SEL0", 0xe6060500, 32, GROUP ( + 3, 2, 3, 1, 1, 1, 1, 1, 2, 1, + 1, 2, 1, 1, 1, 2, 2, 1, 2, 3), + GROUP( + MOD_SEL0_31_30_29 + MOD_SEL0_28_27 + MOD_SEL0_26_25_24 + MOD_SEL0_23 + MOD_SEL0_22 + MOD_SEL0_21 + MOD_SEL0_20 + MOD_SEL0_19 + MOD_SEL0_18_17 + MOD_SEL0_16 + 0, 0, /* RESERVED 15 */ + MOD_SEL0_14_13 + MOD_SEL0_12 + MOD_SEL0_11 + MOD_SEL0_10 + MOD_SEL0_9_8 + MOD_SEL0_7_6 + MOD_SEL0_5 + MOD_SEL0_4_3 + /* RESERVED 2, 1, 0 */ + 0, 0, 0, 0, 0, 0, 0, 0 )) + }, + { PINMUX_CFG_REG_VAR("MOD_SEL1", 0xe6060504, 32, GROUP( + 2, 3, 1, 2, 3, 1, 1, 2, 1, + 2, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1), + GROUP( + MOD_SEL1_31_30 + MOD_SEL1_29_28_27 + MOD_SEL1_26 + MOD_SEL1_25_24 + MOD_SEL1_23_22_21 + MOD_SEL1_20 + MOD_SEL1_19 + MOD_SEL1_18_17 + MOD_SEL1_16 + MOD_SEL1_15_14 + MOD_SEL1_13 + MOD_SEL1_12 + MOD_SEL1_11 + MOD_SEL1_10 + MOD_SEL1_9 + 0, 0, 0, 0, /* RESERVED 8, 7 */ + MOD_SEL1_6 + MOD_SEL1_5 + MOD_SEL1_4 + MOD_SEL1_3 + MOD_SEL1_2 + MOD_SEL1_1 + MOD_SEL1_0 )) + }, + { PINMUX_CFG_REG_VAR("MOD_SEL2", 0xe6060508, 32, GROUP( + 1, 1, 1, 2, 1, 3, 1, 1, 1, 1, 1, 1, 1, + 4, 4, 4, 3, 1), + GROUP( + MOD_SEL2_31 + MOD_SEL2_30 + MOD_SEL2_29 + MOD_SEL2_28_27 + MOD_SEL2_26 + MOD_SEL2_25_24_23 + MOD_SEL2_22 + MOD_SEL2_21 + MOD_SEL2_20 + MOD_SEL2_19 + MOD_SEL2_18 + MOD_SEL2_17 + /* RESERVED 16 */ + 0, 0, + /* RESERVED 15, 14, 13, 12 */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESERVED 11, 10, 9, 8 */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESERVED 7, 6, 5, 4 */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESERVED 3, 2, 1 */ + 0, 0, 0, 0, 0, 0, 0, 0, + MOD_SEL2_0 )) + }, + { }, +}; + +static const struct pinmux_drive_reg pinmux_drive_regs[] = { + { PINMUX_DRIVE_REG("DRVCTRL0", 0xe6060300) { + { PIN_NUMBER('W', 3), 28, 2 }, /* QSPI0_SPCLK */ + { PIN_A_NUMBER('C', 5), 24, 2 }, /* QSPI0_MOSI_IO0 */ + { PIN_A_NUMBER('B', 4), 20, 2 }, /* QSPI0_MISO_IO1 */ + { PIN_NUMBER('Y', 6), 16, 2 }, /* QSPI0_IO2 */ + { PIN_A_NUMBER('B', 6), 12, 2 }, /* QSPI0_IO3 */ + { PIN_NUMBER('Y', 3), 8, 2 }, /* QSPI0_SSL */ + { PIN_NUMBER('V', 3), 4, 2 }, /* QSPI1_SPCLK */ + { PIN_A_NUMBER('C', 7), 0, 2 }, /* QSPI1_MOSI_IO0 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL1", 0xe6060304) { + { PIN_A_NUMBER('E', 5), 28, 2 }, /* QSPI1_MISO_IO1 */ + { PIN_A_NUMBER('E', 4), 24, 2 }, /* QSPI1_IO2 */ + { PIN_A_NUMBER('C', 3), 20, 2 }, /* QSPI1_IO3 */ + { PIN_NUMBER('V', 5), 16, 2 }, /* QSPI1_SSL */ + { PIN_NUMBER('Y', 7), 12, 2 }, /* RPC_INT# */ + { PIN_NUMBER('V', 6), 8, 2 }, /* RPC_WP# */ + { PIN_NUMBER('V', 7), 4, 2 }, /* RPC_RESET# */ + { PIN_NUMBER('A', 16), 0, 3 }, /* AVB_RX_CTL */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL2", 0xe6060308) { + { PIN_NUMBER('B', 19), 28, 3 }, /* AVB_RXC */ + { PIN_NUMBER('A', 13), 24, 3 }, /* AVB_RD0 */ + { PIN_NUMBER('B', 13), 20, 3 }, /* AVB_RD1 */ + { PIN_NUMBER('A', 14), 16, 3 }, /* AVB_RD2 */ + { PIN_NUMBER('B', 14), 12, 3 }, /* AVB_RD3 */ + { PIN_NUMBER('A', 8), 8, 3 }, /* AVB_TX_CTL */ + { PIN_NUMBER('A', 19), 4, 3 }, /* AVB_TXC */ + { PIN_NUMBER('A', 18), 0, 3 }, /* AVB_TD0 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL3", 0xe606030c) { + { PIN_NUMBER('B', 18), 28, 3 }, /* AVB_TD1 */ + { PIN_NUMBER('A', 17), 24, 3 }, /* AVB_TD2 */ + { PIN_NUMBER('B', 17), 20, 3 }, /* AVB_TD3 */ + { PIN_NUMBER('A', 12), 16, 3 }, /* AVB_TXCREFCLK */ + { PIN_NUMBER('A', 9), 12, 3 }, /* AVB_MDIO */ + { RCAR_GP_PIN(2, 9), 8, 3 }, /* AVB_MDC */ + { RCAR_GP_PIN(2, 10), 4, 3 }, /* AVB_MAGIC */ + { RCAR_GP_PIN(2, 11), 0, 3 }, /* AVB_PHY_INT */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL4", 0xe6060310) { + { RCAR_GP_PIN(2, 12), 28, 3 }, /* AVB_LINK */ + { RCAR_GP_PIN(2, 13), 24, 3 }, /* AVB_AVTP_MATCH */ + { RCAR_GP_PIN(2, 14), 20, 3 }, /* AVB_AVTP_CAPTURE */ + { RCAR_GP_PIN(2, 0), 16, 3 }, /* IRQ0 */ + { RCAR_GP_PIN(2, 1), 12, 3 }, /* IRQ1 */ + { RCAR_GP_PIN(2, 2), 8, 3 }, /* IRQ2 */ + { RCAR_GP_PIN(2, 3), 4, 3 }, /* IRQ3 */ + { RCAR_GP_PIN(2, 4), 0, 3 }, /* IRQ4 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL5", 0xe6060314) { + { RCAR_GP_PIN(2, 5), 28, 3 }, /* IRQ5 */ + { RCAR_GP_PIN(2, 6), 24, 3 }, /* PWM0 */ + { RCAR_GP_PIN(2, 7), 20, 3 }, /* PWM1 */ + { RCAR_GP_PIN(2, 8), 16, 3 }, /* PWM2 */ + { RCAR_GP_PIN(1, 0), 12, 3 }, /* A0 */ + { RCAR_GP_PIN(1, 1), 8, 3 }, /* A1 */ + { RCAR_GP_PIN(1, 2), 4, 3 }, /* A2 */ + { RCAR_GP_PIN(1, 3), 0, 3 }, /* A3 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL6", 0xe6060318) { + { RCAR_GP_PIN(1, 4), 28, 3 }, /* A4 */ + { RCAR_GP_PIN(1, 5), 24, 3 }, /* A5 */ + { RCAR_GP_PIN(1, 6), 20, 3 }, /* A6 */ + { RCAR_GP_PIN(1, 7), 16, 3 }, /* A7 */ + { RCAR_GP_PIN(1, 8), 12, 3 }, /* A8 */ + { RCAR_GP_PIN(1, 9), 8, 3 }, /* A9 */ + { RCAR_GP_PIN(1, 10), 4, 3 }, /* A10 */ + { RCAR_GP_PIN(1, 11), 0, 3 }, /* A11 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL7", 0xe606031c) { + { RCAR_GP_PIN(1, 12), 28, 3 }, /* A12 */ + { RCAR_GP_PIN(1, 13), 24, 3 }, /* A13 */ + { RCAR_GP_PIN(1, 14), 20, 3 }, /* A14 */ + { RCAR_GP_PIN(1, 15), 16, 3 }, /* A15 */ + { RCAR_GP_PIN(1, 16), 12, 3 }, /* A16 */ + { RCAR_GP_PIN(1, 17), 8, 3 }, /* A17 */ + { RCAR_GP_PIN(1, 18), 4, 3 }, /* A18 */ + { RCAR_GP_PIN(1, 19), 0, 3 }, /* A19 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL8", 0xe6060320) { + { RCAR_GP_PIN(1, 28), 28, 3 }, /* CLKOUT */ + { RCAR_GP_PIN(1, 20), 24, 3 }, /* CS0 */ + { RCAR_GP_PIN(1, 21), 20, 3 }, /* CS1_A26 */ + { RCAR_GP_PIN(1, 22), 16, 3 }, /* BS */ + { RCAR_GP_PIN(1, 23), 12, 3 }, /* RD */ + { RCAR_GP_PIN(1, 24), 8, 3 }, /* RD_WR */ + { RCAR_GP_PIN(1, 25), 4, 3 }, /* WE0 */ + { RCAR_GP_PIN(1, 26), 0, 3 }, /* WE1 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL9", 0xe6060324) { + { RCAR_GP_PIN(1, 27), 28, 3 }, /* EX_WAIT0 */ + { PIN_NUMBER('C', 1), 24, 3 }, /* PRESETOUT# */ + { RCAR_GP_PIN(0, 0), 20, 3 }, /* D0 */ + { RCAR_GP_PIN(0, 1), 16, 3 }, /* D1 */ + { RCAR_GP_PIN(0, 2), 12, 3 }, /* D2 */ + { RCAR_GP_PIN(0, 3), 8, 3 }, /* D3 */ + { RCAR_GP_PIN(0, 4), 4, 3 }, /* D4 */ + { RCAR_GP_PIN(0, 5), 0, 3 }, /* D5 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL10", 0xe6060328) { + { RCAR_GP_PIN(0, 6), 28, 3 }, /* D6 */ + { RCAR_GP_PIN(0, 7), 24, 3 }, /* D7 */ + { RCAR_GP_PIN(0, 8), 20, 3 }, /* D8 */ + { RCAR_GP_PIN(0, 9), 16, 3 }, /* D9 */ + { RCAR_GP_PIN(0, 10), 12, 3 }, /* D10 */ + { RCAR_GP_PIN(0, 11), 8, 3 }, /* D11 */ + { RCAR_GP_PIN(0, 12), 4, 3 }, /* D12 */ + { RCAR_GP_PIN(0, 13), 0, 3 }, /* D13 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL11", 0xe606032c) { + { RCAR_GP_PIN(0, 14), 28, 3 }, /* D14 */ + { RCAR_GP_PIN(0, 15), 24, 3 }, /* D15 */ + { RCAR_GP_PIN(7, 0), 20, 3 }, /* AVS1 */ + { RCAR_GP_PIN(7, 1), 16, 3 }, /* AVS2 */ + { RCAR_GP_PIN(7, 2), 12, 3 }, /* GP7_02 */ + { RCAR_GP_PIN(7, 3), 8, 3 }, /* GP7_03 */ + { PIN_A_NUMBER('P', 7), 4, 2 }, /* DU_DOTCLKIN0 */ + { PIN_A_NUMBER('P', 8), 0, 2 }, /* DU_DOTCLKIN1 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL12", 0xe6060330) { + { PIN_A_NUMBER('R', 8), 28, 2 }, /* DU_DOTCLKIN2 */ + { PIN_A_NUMBER('D', 38), 20, 2 }, /* FSCLKST */ + { PIN_A_NUMBER('R', 30), 4, 2 }, /* TMS */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL13", 0xe6060334) { + { PIN_A_NUMBER('T', 28), 28, 2 }, /* TDO */ + { PIN_A_NUMBER('T', 30), 24, 2 }, /* ASEBRK */ + { RCAR_GP_PIN(3, 0), 20, 3 }, /* SD0_CLK */ + { RCAR_GP_PIN(3, 1), 16, 3 }, /* SD0_CMD */ + { RCAR_GP_PIN(3, 2), 12, 3 }, /* SD0_DAT0 */ + { RCAR_GP_PIN(3, 3), 8, 3 }, /* SD0_DAT1 */ + { RCAR_GP_PIN(3, 4), 4, 3 }, /* SD0_DAT2 */ + { RCAR_GP_PIN(3, 5), 0, 3 }, /* SD0_DAT3 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL14", 0xe6060338) { + { RCAR_GP_PIN(3, 6), 28, 3 }, /* SD1_CLK */ + { RCAR_GP_PIN(3, 7), 24, 3 }, /* SD1_CMD */ + { RCAR_GP_PIN(3, 8), 20, 3 }, /* SD1_DAT0 */ + { RCAR_GP_PIN(3, 9), 16, 3 }, /* SD1_DAT1 */ + { RCAR_GP_PIN(3, 10), 12, 3 }, /* SD1_DAT2 */ + { RCAR_GP_PIN(3, 11), 8, 3 }, /* SD1_DAT3 */ + { RCAR_GP_PIN(4, 0), 4, 3 }, /* SD2_CLK */ + { RCAR_GP_PIN(4, 1), 0, 3 }, /* SD2_CMD */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL15", 0xe606033c) { + { RCAR_GP_PIN(4, 2), 28, 3 }, /* SD2_DAT0 */ + { RCAR_GP_PIN(4, 3), 24, 3 }, /* SD2_DAT1 */ + { RCAR_GP_PIN(4, 4), 20, 3 }, /* SD2_DAT2 */ + { RCAR_GP_PIN(4, 5), 16, 3 }, /* SD2_DAT3 */ + { RCAR_GP_PIN(4, 6), 12, 3 }, /* SD2_DS */ + { RCAR_GP_PIN(4, 7), 8, 3 }, /* SD3_CLK */ + { RCAR_GP_PIN(4, 8), 4, 3 }, /* SD3_CMD */ + { RCAR_GP_PIN(4, 9), 0, 3 }, /* SD3_DAT0 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL16", 0xe6060340) { + { RCAR_GP_PIN(4, 10), 28, 3 }, /* SD3_DAT1 */ + { RCAR_GP_PIN(4, 11), 24, 3 }, /* SD3_DAT2 */ + { RCAR_GP_PIN(4, 12), 20, 3 }, /* SD3_DAT3 */ + { RCAR_GP_PIN(4, 13), 16, 3 }, /* SD3_DAT4 */ + { RCAR_GP_PIN(4, 14), 12, 3 }, /* SD3_DAT5 */ + { RCAR_GP_PIN(4, 15), 8, 3 }, /* SD3_DAT6 */ + { RCAR_GP_PIN(4, 16), 4, 3 }, /* SD3_DAT7 */ + { RCAR_GP_PIN(4, 17), 0, 3 }, /* SD3_DS */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL17", 0xe6060344) { + { RCAR_GP_PIN(3, 12), 28, 3 }, /* SD0_CD */ + { RCAR_GP_PIN(3, 13), 24, 3 }, /* SD0_WP */ + { RCAR_GP_PIN(3, 14), 20, 3 }, /* SD1_CD */ + { RCAR_GP_PIN(3, 15), 16, 3 }, /* SD1_WP */ + { RCAR_GP_PIN(5, 0), 12, 3 }, /* SCK0 */ + { RCAR_GP_PIN(5, 1), 8, 3 }, /* RX0 */ + { RCAR_GP_PIN(5, 2), 4, 3 }, /* TX0 */ + { RCAR_GP_PIN(5, 3), 0, 3 }, /* CTS0 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL18", 0xe6060348) { + { RCAR_GP_PIN(5, 4), 28, 3 }, /* RTS0 */ + { RCAR_GP_PIN(5, 5), 24, 3 }, /* RX1 */ + { RCAR_GP_PIN(5, 6), 20, 3 }, /* TX1 */ + { RCAR_GP_PIN(5, 7), 16, 3 }, /* CTS1 */ + { RCAR_GP_PIN(5, 8), 12, 3 }, /* RTS1 */ + { RCAR_GP_PIN(5, 9), 8, 3 }, /* SCK2 */ + { RCAR_GP_PIN(5, 10), 4, 3 }, /* TX2 */ + { RCAR_GP_PIN(5, 11), 0, 3 }, /* RX2 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL19", 0xe606034c) { + { RCAR_GP_PIN(5, 12), 28, 3 }, /* HSCK0 */ + { RCAR_GP_PIN(5, 13), 24, 3 }, /* HRX0 */ + { RCAR_GP_PIN(5, 14), 20, 3 }, /* HTX0 */ + { RCAR_GP_PIN(5, 15), 16, 3 }, /* HCTS0 */ + { RCAR_GP_PIN(5, 16), 12, 3 }, /* HRTS0 */ + { RCAR_GP_PIN(5, 17), 8, 3 }, /* MSIOF0_SCK */ + { RCAR_GP_PIN(5, 18), 4, 3 }, /* MSIOF0_SYNC */ + { RCAR_GP_PIN(5, 19), 0, 3 }, /* MSIOF0_SS1 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL20", 0xe6060350) { + { RCAR_GP_PIN(5, 20), 28, 3 }, /* MSIOF0_TXD */ + { RCAR_GP_PIN(5, 21), 24, 3 }, /* MSIOF0_SS2 */ + { RCAR_GP_PIN(5, 22), 20, 3 }, /* MSIOF0_RXD */ + { RCAR_GP_PIN(5, 23), 16, 3 }, /* MLB_CLK */ + { RCAR_GP_PIN(5, 24), 12, 3 }, /* MLB_SIG */ + { RCAR_GP_PIN(5, 25), 8, 3 }, /* MLB_DAT */ + { PIN_NUMBER('H', 37), 4, 3 }, /* MLB_REF */ + { RCAR_GP_PIN(6, 0), 0, 3 }, /* SSI_SCK01239 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL21", 0xe6060354) { + { RCAR_GP_PIN(6, 1), 28, 3 }, /* SSI_WS01239 */ + { RCAR_GP_PIN(6, 2), 24, 3 }, /* SSI_SDATA0 */ + { RCAR_GP_PIN(6, 3), 20, 3 }, /* SSI_SDATA1 */ + { RCAR_GP_PIN(6, 4), 16, 3 }, /* SSI_SDATA2 */ + { RCAR_GP_PIN(6, 5), 12, 3 }, /* SSI_SCK349 */ + { RCAR_GP_PIN(6, 6), 8, 3 }, /* SSI_WS349 */ + { RCAR_GP_PIN(6, 7), 4, 3 }, /* SSI_SDATA3 */ + { RCAR_GP_PIN(6, 8), 0, 3 }, /* SSI_SCK4 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL22", 0xe6060358) { + { RCAR_GP_PIN(6, 9), 28, 3 }, /* SSI_WS4 */ + { RCAR_GP_PIN(6, 10), 24, 3 }, /* SSI_SDATA4 */ + { RCAR_GP_PIN(6, 11), 20, 3 }, /* SSI_SCK5 */ + { RCAR_GP_PIN(6, 12), 16, 3 }, /* SSI_WS5 */ + { RCAR_GP_PIN(6, 13), 12, 3 }, /* SSI_SDATA5 */ + { RCAR_GP_PIN(6, 14), 8, 3 }, /* SSI_SCK6 */ + { RCAR_GP_PIN(6, 15), 4, 3 }, /* SSI_WS6 */ + { RCAR_GP_PIN(6, 16), 0, 3 }, /* SSI_SDATA6 */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL23", 0xe606035c) { + { RCAR_GP_PIN(6, 17), 28, 3 }, /* SSI_SCK78 */ + { RCAR_GP_PIN(6, 18), 24, 3 }, /* SSI_WS78 */ + { RCAR_GP_PIN(6, 19), 20, 3 }, /* SSI_SDATA7 */ + { RCAR_GP_PIN(6, 20), 16, 3 }, /* SSI_SDATA8 */ + { RCAR_GP_PIN(6, 21), 12, 3 }, /* SSI_SDATA9 */ + { RCAR_GP_PIN(6, 22), 8, 3 }, /* AUDIO_CLKA */ + { RCAR_GP_PIN(6, 23), 4, 3 }, /* AUDIO_CLKB */ + { RCAR_GP_PIN(6, 24), 0, 3 }, /* USB0_PWEN */ + } }, + { PINMUX_DRIVE_REG("DRVCTRL24", 0xe6060360) { + { RCAR_GP_PIN(6, 25), 28, 3 }, /* USB0_OVC */ + { RCAR_GP_PIN(6, 26), 24, 3 }, /* USB1_PWEN */ + { RCAR_GP_PIN(6, 27), 20, 3 }, /* USB1_OVC */ + { RCAR_GP_PIN(6, 28), 16, 3 }, /* USB30_PWEN */ + { RCAR_GP_PIN(6, 29), 12, 3 }, /* USB30_OVC */ + { RCAR_GP_PIN(6, 30), 8, 3 }, /* GP6_30 */ + { RCAR_GP_PIN(6, 31), 4, 3 }, /* GP6_31 */ + } }, + { }, +}; + +enum ioctrl_regs { + POCCTRL, +}; + +static const struct pinmux_ioctrl_reg pinmux_ioctrl_regs[] = { + [POCCTRL] = { 0xe6060380, }, + { /* sentinel */ }, +}; + +static int r8a774a1_pin_to_pocctrl(struct sh_pfc *pfc, unsigned int pin, u32 *pocctrl) +{ + int bit = -EINVAL; + + *pocctrl = pinmux_ioctrl_regs[POCCTRL].reg; + + if (pin >= RCAR_GP_PIN(3, 0) && pin <= RCAR_GP_PIN(3, 11)) + bit = pin & 0x1f; + + if (pin >= RCAR_GP_PIN(4, 0) && pin <= RCAR_GP_PIN(4, 17)) + bit = (pin & 0x1f) + 12; + + return bit; +} + +static const struct pinmux_bias_reg pinmux_bias_regs[] = { + { PINMUX_BIAS_REG("PUEN0", 0xe6060400, "PUD0", 0xe6060440) { + [ 0] = PIN_NUMBER('W', 3), /* QSPI0_SPCLK */ + [ 1] = PIN_A_NUMBER('C', 5), /* QSPI0_MOSI_IO0 */ + [ 2] = PIN_A_NUMBER('B', 4), /* QSPI0_MISO_IO1 */ + [ 3] = PIN_NUMBER('Y', 6), /* QSPI0_IO2 */ + [ 4] = PIN_A_NUMBER('B', 6), /* QSPI0_IO3 */ + [ 5] = PIN_NUMBER('Y', 3), /* QSPI0_SSL */ + [ 6] = PIN_NUMBER('V', 3), /* QSPI1_SPCLK */ + [ 7] = PIN_A_NUMBER('C', 7), /* QSPI1_MOSI_IO0 */ + [ 8] = PIN_A_NUMBER('E', 5), /* QSPI1_MISO_IO1 */ + [ 9] = PIN_A_NUMBER('E', 4), /* QSPI1_IO2 */ + [10] = PIN_A_NUMBER('C', 3), /* QSPI1_IO3 */ + [11] = PIN_NUMBER('V', 5), /* QSPI1_SSL */ + [12] = PIN_NUMBER('Y', 7), /* RPC_INT# */ + [13] = PIN_NUMBER('V', 6), /* RPC_WP# */ + [14] = PIN_NUMBER('V', 7), /* RPC_RESET# */ + [15] = PIN_NUMBER('A', 16), /* AVB_RX_CTL */ + [16] = PIN_NUMBER('B', 19), /* AVB_RXC */ + [17] = PIN_NUMBER('A', 13), /* AVB_RD0 */ + [18] = PIN_NUMBER('B', 13), /* AVB_RD1 */ + [19] = PIN_NUMBER('A', 14), /* AVB_RD2 */ + [20] = PIN_NUMBER('B', 14), /* AVB_RD3 */ + [21] = PIN_NUMBER('A', 8), /* AVB_TX_CTL */ + [22] = PIN_NUMBER('A', 19), /* AVB_TXC */ + [23] = PIN_NUMBER('A', 18), /* AVB_TD0 */ + [24] = PIN_NUMBER('B', 18), /* AVB_TD1 */ + [25] = PIN_NUMBER('A', 17), /* AVB_TD2 */ + [26] = PIN_NUMBER('B', 17), /* AVB_TD3 */ + [27] = PIN_NUMBER('A', 12), /* AVB_TXCREFCLK */ + [28] = PIN_NUMBER('A', 9), /* AVB_MDIO */ + [29] = RCAR_GP_PIN(2, 9), /* AVB_MDC */ + [30] = RCAR_GP_PIN(2, 10), /* AVB_MAGIC */ + [31] = RCAR_GP_PIN(2, 11), /* AVB_PHY_INT */ + } }, + { PINMUX_BIAS_REG("PUEN1", 0xe6060404, "PUD1", 0xe6060444) { + [ 0] = RCAR_GP_PIN(2, 12), /* AVB_LINK */ + [ 1] = RCAR_GP_PIN(2, 13), /* AVB_AVTP_MATCH_A */ + [ 2] = RCAR_GP_PIN(2, 14), /* AVB_AVTP_CAPTURE_A */ + [ 3] = RCAR_GP_PIN(2, 0), /* IRQ0 */ + [ 4] = RCAR_GP_PIN(2, 1), /* IRQ1 */ + [ 5] = RCAR_GP_PIN(2, 2), /* IRQ2 */ + [ 6] = RCAR_GP_PIN(2, 3), /* IRQ3 */ + [ 7] = RCAR_GP_PIN(2, 4), /* IRQ4 */ + [ 8] = RCAR_GP_PIN(2, 5), /* IRQ5 */ + [ 9] = RCAR_GP_PIN(2, 6), /* PWM0 */ + [10] = RCAR_GP_PIN(2, 7), /* PWM1_A */ + [11] = RCAR_GP_PIN(2, 8), /* PWM2_A */ + [12] = RCAR_GP_PIN(1, 0), /* A0 */ + [13] = RCAR_GP_PIN(1, 1), /* A1 */ + [14] = RCAR_GP_PIN(1, 2), /* A2 */ + [15] = RCAR_GP_PIN(1, 3), /* A3 */ + [16] = RCAR_GP_PIN(1, 4), /* A4 */ + [17] = RCAR_GP_PIN(1, 5), /* A5 */ + [18] = RCAR_GP_PIN(1, 6), /* A6 */ + [19] = RCAR_GP_PIN(1, 7), /* A7 */ + [20] = RCAR_GP_PIN(1, 8), /* A8 */ + [21] = RCAR_GP_PIN(1, 9), /* A9 */ + [22] = RCAR_GP_PIN(1, 10), /* A10 */ + [23] = RCAR_GP_PIN(1, 11), /* A11 */ + [24] = RCAR_GP_PIN(1, 12), /* A12 */ + [25] = RCAR_GP_PIN(1, 13), /* A13 */ + [26] = RCAR_GP_PIN(1, 14), /* A14 */ + [27] = RCAR_GP_PIN(1, 15), /* A15 */ + [28] = RCAR_GP_PIN(1, 16), /* A16 */ + [29] = RCAR_GP_PIN(1, 17), /* A17 */ + [30] = RCAR_GP_PIN(1, 18), /* A18 */ + [31] = RCAR_GP_PIN(1, 19), /* A19 */ + } }, + { PINMUX_BIAS_REG("PUEN2", 0xe6060408, "PUD2", 0xe6060448) { + [ 0] = RCAR_GP_PIN(1, 28), /* CLKOUT */ + [ 1] = RCAR_GP_PIN(1, 20), /* CS0_N */ + [ 2] = RCAR_GP_PIN(1, 21), /* CS1_N */ + [ 3] = RCAR_GP_PIN(1, 22), /* BS_N */ + [ 4] = RCAR_GP_PIN(1, 23), /* RD_N */ + [ 5] = RCAR_GP_PIN(1, 24), /* RD_WR_N */ + [ 6] = RCAR_GP_PIN(1, 25), /* WE0_N */ + [ 7] = RCAR_GP_PIN(1, 26), /* WE1_N */ + [ 8] = RCAR_GP_PIN(1, 27), /* EX_WAIT0_A */ + [ 9] = PIN_NUMBER('C', 1), /* PRESETOUT# */ + [10] = RCAR_GP_PIN(0, 0), /* D0 */ + [11] = RCAR_GP_PIN(0, 1), /* D1 */ + [12] = RCAR_GP_PIN(0, 2), /* D2 */ + [13] = RCAR_GP_PIN(0, 3), /* D3 */ + [14] = RCAR_GP_PIN(0, 4), /* D4 */ + [15] = RCAR_GP_PIN(0, 5), /* D5 */ + [16] = RCAR_GP_PIN(0, 6), /* D6 */ + [17] = RCAR_GP_PIN(0, 7), /* D7 */ + [18] = RCAR_GP_PIN(0, 8), /* D8 */ + [19] = RCAR_GP_PIN(0, 9), /* D9 */ + [20] = RCAR_GP_PIN(0, 10), /* D10 */ + [21] = RCAR_GP_PIN(0, 11), /* D11 */ + [22] = RCAR_GP_PIN(0, 12), /* D12 */ + [23] = RCAR_GP_PIN(0, 13), /* D13 */ + [24] = RCAR_GP_PIN(0, 14), /* D14 */ + [25] = RCAR_GP_PIN(0, 15), /* D15 */ + [26] = RCAR_GP_PIN(7, 0), /* AVS1 */ + [27] = RCAR_GP_PIN(7, 1), /* AVS2 */ + [28] = RCAR_GP_PIN(7, 2), /* GP7_02 */ + [29] = RCAR_GP_PIN(7, 3), /* GP7_03 */ + [30] = PIN_A_NUMBER('P', 7), /* DU_DOTCLKIN0 */ + [31] = PIN_A_NUMBER('P', 8), /* DU_DOTCLKIN1 */ + } }, + { PINMUX_BIAS_REG("PUEN3", 0xe606040c, "PUD3", 0xe606044c) { + [ 0] = PIN_A_NUMBER('R', 8), /* DU_DOTCLKIN2 */ + [ 1] = PIN_NONE, + [ 2] = PIN_A_NUMBER('D', 38), /* FSCLKST */ + [ 3] = PIN_A_NUMBER('D', 39), /* EXTALR*/ + [ 4] = PIN_A_NUMBER('R', 26), /* TRST# */ + [ 5] = PIN_A_NUMBER('T', 27), /* TCK */ + [ 6] = PIN_A_NUMBER('R', 30), /* TMS */ + [ 7] = PIN_A_NUMBER('R', 29), /* TDI */ + [ 8] = PIN_NONE, + [ 9] = PIN_A_NUMBER('T', 30), /* ASEBRK */ + [10] = RCAR_GP_PIN(3, 0), /* SD0_CLK */ + [11] = RCAR_GP_PIN(3, 1), /* SD0_CMD */ + [12] = RCAR_GP_PIN(3, 2), /* SD0_DAT0 */ + [13] = RCAR_GP_PIN(3, 3), /* SD0_DAT1 */ + [14] = RCAR_GP_PIN(3, 4), /* SD0_DAT2 */ + [15] = RCAR_GP_PIN(3, 5), /* SD0_DAT3 */ + [16] = RCAR_GP_PIN(3, 6), /* SD1_CLK */ + [17] = RCAR_GP_PIN(3, 7), /* SD1_CMD */ + [18] = RCAR_GP_PIN(3, 8), /* SD1_DAT0 */ + [19] = RCAR_GP_PIN(3, 9), /* SD1_DAT1 */ + [20] = RCAR_GP_PIN(3, 10), /* SD1_DAT2 */ + [21] = RCAR_GP_PIN(3, 11), /* SD1_DAT3 */ + [22] = RCAR_GP_PIN(4, 0), /* SD2_CLK */ + [23] = RCAR_GP_PIN(4, 1), /* SD2_CMD */ + [24] = RCAR_GP_PIN(4, 2), /* SD2_DAT0 */ + [25] = RCAR_GP_PIN(4, 3), /* SD2_DAT1 */ + [26] = RCAR_GP_PIN(4, 4), /* SD2_DAT2 */ + [27] = RCAR_GP_PIN(4, 5), /* SD2_DAT3 */ + [28] = RCAR_GP_PIN(4, 6), /* SD2_DS */ + [29] = RCAR_GP_PIN(4, 7), /* SD3_CLK */ + [30] = RCAR_GP_PIN(4, 8), /* SD3_CMD */ + [31] = RCAR_GP_PIN(4, 9), /* SD3_DAT0 */ + } }, + { PINMUX_BIAS_REG("PUEN4", 0xe6060410, "PUD4", 0xe6060450) { + [ 0] = RCAR_GP_PIN(4, 10), /* SD3_DAT1 */ + [ 1] = RCAR_GP_PIN(4, 11), /* SD3_DAT2 */ + [ 2] = RCAR_GP_PIN(4, 12), /* SD3_DAT3 */ + [ 3] = RCAR_GP_PIN(4, 13), /* SD3_DAT4 */ + [ 4] = RCAR_GP_PIN(4, 14), /* SD3_DAT5 */ + [ 5] = RCAR_GP_PIN(4, 15), /* SD3_DAT6 */ + [ 6] = RCAR_GP_PIN(4, 16), /* SD3_DAT7 */ + [ 7] = RCAR_GP_PIN(4, 17), /* SD3_DS */ + [ 8] = RCAR_GP_PIN(3, 12), /* SD0_CD */ + [ 9] = RCAR_GP_PIN(3, 13), /* SD0_WP */ + [10] = RCAR_GP_PIN(3, 14), /* SD1_CD */ + [11] = RCAR_GP_PIN(3, 15), /* SD1_WP */ + [12] = RCAR_GP_PIN(5, 0), /* SCK0 */ + [13] = RCAR_GP_PIN(5, 1), /* RX0 */ + [14] = RCAR_GP_PIN(5, 2), /* TX0 */ + [15] = RCAR_GP_PIN(5, 3), /* CTS0_N */ + [16] = RCAR_GP_PIN(5, 4), /* RTS0_N */ + [17] = RCAR_GP_PIN(5, 5), /* RX1_A */ + [18] = RCAR_GP_PIN(5, 6), /* TX1_A */ + [19] = RCAR_GP_PIN(5, 7), /* CTS1_N */ + [20] = RCAR_GP_PIN(5, 8), /* RTS1_N */ + [21] = RCAR_GP_PIN(5, 9), /* SCK2 */ + [22] = RCAR_GP_PIN(5, 10), /* TX2_A */ + [23] = RCAR_GP_PIN(5, 11), /* RX2_A */ + [24] = RCAR_GP_PIN(5, 12), /* HSCK0 */ + [25] = RCAR_GP_PIN(5, 13), /* HRX0 */ + [26] = RCAR_GP_PIN(5, 14), /* HTX0 */ + [27] = RCAR_GP_PIN(5, 15), /* HCTS0_N */ + [28] = RCAR_GP_PIN(5, 16), /* HRTS0_N */ + [29] = RCAR_GP_PIN(5, 17), /* MSIOF0_SCK */ + [30] = RCAR_GP_PIN(5, 18), /* MSIOF0_SYNC */ + [31] = RCAR_GP_PIN(5, 19), /* MSIOF0_SS1 */ + } }, + { PINMUX_BIAS_REG("PUEN5", 0xe6060414, "PUD5", 0xe6060454) { + [ 0] = RCAR_GP_PIN(5, 20), /* MSIOF0_TXD */ + [ 1] = RCAR_GP_PIN(5, 21), /* MSIOF0_SS2 */ + [ 2] = RCAR_GP_PIN(5, 22), /* MSIOF0_RXD */ + [ 3] = RCAR_GP_PIN(5, 23), /* MLB_CLK */ + [ 4] = RCAR_GP_PIN(5, 24), /* MLB_SIG */ + [ 5] = RCAR_GP_PIN(5, 25), /* MLB_DAT */ + [ 6] = PIN_NUMBER('H', 37), /* MLB_REF */ + [ 7] = RCAR_GP_PIN(6, 0), /* SSI_SCK01239 */ + [ 8] = RCAR_GP_PIN(6, 1), /* SSI_WS01239 */ + [ 9] = RCAR_GP_PIN(6, 2), /* SSI_SDATA0 */ + [10] = RCAR_GP_PIN(6, 3), /* SSI_SDATA1_A */ + [11] = RCAR_GP_PIN(6, 4), /* SSI_SDATA2_A */ + [12] = RCAR_GP_PIN(6, 5), /* SSI_SCK349 */ + [13] = RCAR_GP_PIN(6, 6), /* SSI_WS349 */ + [14] = RCAR_GP_PIN(6, 7), /* SSI_SDATA3 */ + [15] = RCAR_GP_PIN(6, 8), /* SSI_SCK4 */ + [16] = RCAR_GP_PIN(6, 9), /* SSI_WS4 */ + [17] = RCAR_GP_PIN(6, 10), /* SSI_SDATA4 */ + [18] = RCAR_GP_PIN(6, 11), /* SSI_SCK5 */ + [19] = RCAR_GP_PIN(6, 12), /* SSI_WS5 */ + [20] = RCAR_GP_PIN(6, 13), /* SSI_SDATA5 */ + [21] = RCAR_GP_PIN(6, 14), /* SSI_SCK6 */ + [22] = RCAR_GP_PIN(6, 15), /* SSI_WS6 */ + [23] = RCAR_GP_PIN(6, 16), /* SSI_SDATA6 */ + [24] = RCAR_GP_PIN(6, 17), /* SSI_SCK78 */ + [25] = RCAR_GP_PIN(6, 18), /* SSI_WS78 */ + [26] = RCAR_GP_PIN(6, 19), /* SSI_SDATA7 */ + [27] = RCAR_GP_PIN(6, 20), /* SSI_SDATA8 */ + [28] = RCAR_GP_PIN(6, 21), /* SSI_SDATA9_A */ + [29] = RCAR_GP_PIN(6, 22), /* AUDIO_CLKA_A */ + [30] = RCAR_GP_PIN(6, 23), /* AUDIO_CLKB_B */ + [31] = RCAR_GP_PIN(6, 24), /* USB0_PWEN */ + } }, + { PINMUX_BIAS_REG("PUEN6", 0xe6060418, "PUD6", 0xe6060458) { + [ 0] = RCAR_GP_PIN(6, 25), /* USB0_OVC */ + [ 1] = RCAR_GP_PIN(6, 26), /* USB1_PWEN */ + [ 2] = RCAR_GP_PIN(6, 27), /* USB1_OVC */ + [ 3] = RCAR_GP_PIN(6, 28), /* USB30_PWEN */ + [ 4] = RCAR_GP_PIN(6, 29), /* USB30_OVC */ + [ 5] = RCAR_GP_PIN(6, 30), /* GP6_30 */ + [ 6] = RCAR_GP_PIN(6, 31), /* GP6_31 */ + [ 7] = PIN_NONE, + [ 8] = PIN_NONE, + [ 9] = PIN_NONE, + [10] = PIN_NONE, + [11] = PIN_NONE, + [12] = PIN_NONE, + [13] = PIN_NONE, + [14] = PIN_NONE, + [15] = PIN_NONE, + [16] = PIN_NONE, + [17] = PIN_NONE, + [18] = PIN_NONE, + [19] = PIN_NONE, + [20] = PIN_NONE, + [21] = PIN_NONE, + [22] = PIN_NONE, + [23] = PIN_NONE, + [24] = PIN_NONE, + [25] = PIN_NONE, + [26] = PIN_NONE, + [27] = PIN_NONE, + [28] = PIN_NONE, + [29] = PIN_NONE, + [30] = PIN_NONE, + [31] = PIN_NONE, + } }, + { /* sentinel */ }, +}; + +static unsigned int r8a774a1_pinmux_get_bias(struct sh_pfc *pfc, + unsigned int pin) +{ + const struct pinmux_bias_reg *reg; + unsigned int bit; + + reg = sh_pfc_pin_to_bias_reg(pfc, pin, &bit); + if (!reg) + return PIN_CONFIG_BIAS_DISABLE; + + if (!(sh_pfc_read(pfc, reg->puen) & BIT(bit))) + return PIN_CONFIG_BIAS_DISABLE; + else if (sh_pfc_read(pfc, reg->pud) & BIT(bit)) + return PIN_CONFIG_BIAS_PULL_UP; + else + return PIN_CONFIG_BIAS_PULL_DOWN; +} + +static void r8a774a1_pinmux_set_bias(struct sh_pfc *pfc, unsigned int pin, + unsigned int bias) +{ + const struct pinmux_bias_reg *reg; + u32 enable, updown; + unsigned int bit; + + reg = sh_pfc_pin_to_bias_reg(pfc, pin, &bit); + if (!reg) + return; + + enable = sh_pfc_read(pfc, reg->puen) & ~BIT(bit); + if (bias != PIN_CONFIG_BIAS_DISABLE) + enable |= BIT(bit); + + updown = sh_pfc_read(pfc, reg->pud) & ~BIT(bit); + if (bias == PIN_CONFIG_BIAS_PULL_UP) + updown |= BIT(bit); + + sh_pfc_write(pfc, reg->pud, updown); + sh_pfc_write(pfc, reg->puen, enable); +} + +static const struct sh_pfc_soc_operations r8a774a1_pinmux_ops = { + .pin_to_pocctrl = r8a774a1_pin_to_pocctrl, + .get_bias = r8a774a1_pinmux_get_bias, + .set_bias = r8a774a1_pinmux_set_bias, +}; + +const struct sh_pfc_soc_info r8a774a1_pinmux_info = { + .name = "r8a774a10_pfc", + .ops = &r8a774a1_pinmux_ops, + .unlock_reg = 0xe6060000, /* PMMR */ + + .function = { PINMUX_FUNCTION_BEGIN, PINMUX_FUNCTION_END }, + + .pins = pinmux_pins, + .nr_pins = ARRAY_SIZE(pinmux_pins), + .groups = pinmux_groups, + .nr_groups = ARRAY_SIZE(pinmux_groups), + .functions = pinmux_functions, + .nr_functions = ARRAY_SIZE(pinmux_functions), + + .cfg_regs = pinmux_config_regs, + .drive_regs = pinmux_drive_regs, + .bias_regs = pinmux_bias_regs, + .ioctrl_regs = pinmux_ioctrl_regs, + + .pinmux_data = pinmux_data, + .pinmux_data_size = ARRAY_SIZE(pinmux_data), +};
On Thu, Jun 18, 2020 at 4:51 PM Marek Vasut marek.vasut@gmail.com wrote:
On 6/18/20 11:14 PM, Adam Ford wrote:
Add R8A774A1 PFC tables based on Renesas' repo based on 2018.09.
It seems linux/next uses the same file for 7796 and 774a1 , can we do the same for U-Boot ?
That looks encouraging. I'll try that. It makes sense since the 774a1 is the commercial version of the automotive 7796 if I understand it correctly.
adam
The renesas-shdi controller can drive the r8a774a1 and shares its quirks with R8A7796. This patch adds the compatibilty flag, to support the SDHI controller.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index d6ea99d2ce..8b8e300caf 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -20,7 +20,6 @@ #include <linux/sizes.h> #include <power/regulator.h> #include <asm/unaligned.h> - #include "tmio-common.h"
#if CONFIG_IS_ENABLED(MMC_UHS_SUPPORT) || \ @@ -843,6 +842,7 @@ static const struct udevice_id renesas_sdhi_match[] = { { .compatible = "renesas,sdhi-r8a7794", .data = RENESAS_GEN2_QUIRKS }, { .compatible = "renesas,sdhi-r8a7795", .data = RENESAS_GEN3_QUIRKS }, { .compatible = "renesas,sdhi-r8a7796", .data = RENESAS_GEN3_QUIRKS }, + { .compatible = "renesas,sdhi-r8a774a1", .data = RENESAS_GEN3_QUIRKS }, { .compatible = "renesas,sdhi-r8a77965", .data = RENESAS_GEN3_QUIRKS }, { .compatible = "renesas,sdhi-r8a77970", .data = RENESAS_GEN3_QUIRKS }, { .compatible = "renesas,sdhi-r8a77990", .data = RENESAS_GEN3_QUIRKS },
Adam Ford
