[U-Boot] [PATCH] powerpc/t2080qds: undef CONFIG_FSL_DDR_INTERACTIVE
Usually CONFIG_FSL_DDR_INTERACTIVE feature is used for debug. we would not enable this by default to save the limited space of u-boot.
This avoid following compiling error: section .bootpg loaded at [00000000effff000,00000000effff577] overlap ssection .data loaded at [00000000efff31b8,00000000f00010c7] u-boot: section .bootpg lma 0xeffff000 adjusted to 0xf00010c8
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- include/configs/T2080QDS.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/T2080QDS.h b/include/configs/T2080QDS.h index ad09816..bff001f 100644 --- a/include/configs/T2080QDS.h +++ b/include/configs/T2080QDS.h @@ -155,7 +155,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) #define CONFIG_DDR_SPD #define CONFIG_SYS_FSL_DDR3 -#define CONFIG_FSL_DDR_INTERACTIVE +#undef CONFIG_FSL_DDR_INTERACTIVE #define CONFIG_SYS_SPD_BUS_NUM 0 #define CONFIG_SYS_SDRAM_SIZE 2048 /* for fixed parameter use */ #define SPD_EEPROM_ADDRESS1 0x51
Applied to u-boot-mpc85xx/master. Thanks.
York
Shengzhou Liu
York Sun
