[U-Boot] [PATCH v2 1/3] mxs: Rename CONFIG_SPL_MX28_PSWITCH_WAIT to CONFIG_SPL_MXS_PSWITCH_WAIT
The power switch option is compatible with i.MX23 and i.MX28 so the configration option needs to reflect it. We choose 'CONFIG_SPL_MXS_PSWITCH_WAIT' for the option name.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: - Rewrite short description as per Marek's request
arch/arm/cpu/arm926ejs/mxs/mxs_init.h | 2 +- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h index 2ddc5bc..084def5 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h +++ b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h @@ -30,7 +30,7 @@ void early_delay(int delay);
void mxs_power_init(void);
-#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT +#ifdef CONFIG_SPL_MXS_PSWITCH_WAIT void mxs_power_wait_pswitch(void); #else static inline void mxs_power_wait_pswitch(void) { } diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c index e9d6302..287c698 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c @@ -921,7 +921,7 @@ void mxs_power_init(void) early_delay(1000); }
-#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT +#ifdef CONFIG_SPL_MXS_PSWITCH_WAIT void mxs_power_wait_pswitch(void) { struct mxs_power_regs *power_regs =
This enables the 'Fast Auto Pre-Charge' found in the memory chip.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: - Improve commit message
arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c index 836e636..a9efd87 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c @@ -90,7 +90,7 @@ static uint32_t dram_vals[] = { #elif defined(CONFIG_MX23) 0x01010001, 0x00010100, 0x01000101, 0x00000001, 0x00000101, 0x00000000, 0x00010000, 0x01000001, - 0x00000000, 0x00000001, 0x07000200, 0x00070202, + 0x01000000, 0x00000001, 0x07000200, 0x00070202, 0x02020000, 0x04040a01, 0x00000201, 0x02040000, 0x02000000, 0x19000f08, 0x0d0d0000, 0x02021313, 0x02061521, 0x0000000a, 0x00080008, 0x00200020,
Dear Otavio Salvador,
The datasheet claims not all chips support this.
Changes in v2:
- 0x01000000, 0x00000001, 0x07000200, 0x00070202, 0x02020000, 0x04040a01, 0x00000201, 0x02040000, 0x02000000, 0x19000f08, 0x0d0d0000, 0x02021313, 0x02061521, 0x0000000a, 0x00080008, 0x00200020,
Best regards, Marek Vasut
By 'all chips' you mean memory chips, right?
It seems both used chips (mx23evk and olinuxlino) does. So I think this can be the default and we change it in board if need.
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Changes in v2:
I went through the u-boot mem init and detected you apparently added the following undocumented portion of code (the writel((1 << 24 ...) already:
112 static void initialize_dram_values(void) 113 { 114 int i; 115 116 mxs_adjust_memory_params(dram_vals); 117 118 for (i = 0; i < ARRAY_SIZE(dram_vals); i++) 119 writel(dram_vals[i], MXS_DRAM_BASE + (4 * i)); 120 121 #ifdef CONFIG_MX23 122 writel((1 << 24), MXS_DRAM_BASE + (4 * 8)); 123 #endif 124 }
It does enable the TRANS_LOCKOUT. So what the heck is going on here? Are you coding this stuff at random now ? WHAT THE FUCK IS HAPPENING HERE ?!
Dear Marek Vasut,
Changes in v2:
Sorry about me blowing. Anyway, I better put down the message I would like to relay. Otavio, please follow these steps:
* Work in proper sequence -- patches must apply one after another. The same way you cannot build house from the roof to the ground, you can not apply patches in anachronistic order against their dependencies. * Prove why your patch fixes issues -- apply proper reasoning. Do a proper research, there's no time-limit for sending a patch. There is no deadline, take your time. * Step back and slow down -- please do not roll one patch after another, wait for more reviews. This does put a great deal of strain on everyone in the ML, so please be considerate ; you are flooding the mailing list for no reason ; you are also pushing too much work on the reviewers. Thus, wait for some reviews, then fix the issues and repost. * Focus on the changes you make -- look at the stuff above, you need to properly study the code instead of rolling out random patches. Properly focus on a single task, finish it, then move on to the other task.
Hacking is not a race, it's an art .
On Tue, Jan 29, 2013 at 1:14 AM, Marek Vasut marex@denx.de wrote:
Dear Marek Vasut,
Changes in v2:
- Work in proper sequence -- patches must apply one after another. The same way
- Prove why your patch fixes issues -- apply proper reasoning. Do a proper
- Step back and slow down -- please do not roll one patch after another, wait
- Focus on the changes you make -- look at the stuff above, you need to properly
I've been trying to be cooperative and to improve on the way. I (as other humans) do mistakes but I try to fix them as soon as possible.
I've been trying to get MX23 in basic working state (for users) and do wish to have it for next release and that's why I am trying to make things fast; I am sorry by the patch but it is normal to make mistakes on the way.
I am glad you noticed it but not so glad by the way you communicated it.
Regards,
Dear Marek Vasut,
Changes in v2:
Slow down already. We can apply minor things after the MW. If you go at this pace, it helps noone really. So just take it easy, carefully review the patches etc.
Changes in v2:
What your tone, please.
Indeed, it does it. It has been done loooong time ago when we started looking at MX23 and it was not obvious for me it.
I will send a patch reverting it and adding a comment explaning it there so it is documented.
Changes in v2:
My tone reflects my frustration here.
No! Again, you are charging forward without thinking first!
Why was this code written like that in the first place? Why was this bit set later instead of during the register programming in the first place?
Changes in v2:
This does not give you the right to be hard at someone, specially when someone does not make a mistake by propose.
Check the patchset I sent before to shoot, please.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: None
board/freescale/mx23evk/spl_boot.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/board/freescale/mx23evk/spl_boot.c b/board/freescale/mx23evk/spl_boot.c index 6007433..b6f4e7e 100644 --- a/board/freescale/mx23evk/spl_boot.c +++ b/board/freescale/mx23evk/spl_boot.c @@ -98,6 +98,16 @@ const iomux_cfg_t iomux_setup[] = { (MXS_PAD_4MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), };
+#define HW_DRAM_CTL14 (0x38 >> 2) +#define CS_MAP 0x3 +#define INTAREF 0x2 +#define HW_DRAM_CTL14_CONFIG (INTAREF << 8 | CS_MAP) + +void mxs_adjust_memory_params(uint32_t *dram_vals) +{ + dram_vals[HW_DRAM_CTL14] = HW_DRAM_CTL14_CONFIG; +} + void board_init_ll(void) { mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup));
Otavio Salvador
