[U-Boot] [PATCH] tb100 - add Abilis TB100 board
Development board for headless gateway platform from Abilis Systems. Initial commit with working UART and DW GMAC.
For now with generic Ethernet PHY due to problems in Realtek PHY driver.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com
Cc: Vineet Gupta vgupta@synopsys.com Cc: Christian Ruppert christian.ruppert@abilis.com Cc: Pierrick Hascoet pierrick.hascoet@abilis.com --- board/abilis/tb100/Makefile | 7 +++ board/abilis/tb100/tb100.c | 23 +++++++++ boards.cfg | 1 + include/configs/tb100.h | 123 ++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 154 insertions(+) create mode 100644 board/abilis/tb100/Makefile create mode 100644 board/abilis/tb100/tb100.c create mode 100644 include/configs/tb100.h
diff --git a/board/abilis/tb100/Makefile b/board/abilis/tb100/Makefile new file mode 100644 index 0000000..4f273b3 --- /dev/null +++ b/board/abilis/tb100/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2014 Pierrick Hascoet, Abilis Systems +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += tb100.o diff --git a/board/abilis/tb100/tb100.c b/board/abilis/tb100/tb100.c new file mode 100644 index 0000000..ff3632f --- /dev/null +++ b/board/abilis/tb100/tb100.c @@ -0,0 +1,23 @@ +/* + * (C) Copyright 2014 Pierrick Hascoet, Abilis Systems + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> + +void reset_cpu(ulong addr) +{ +#define CRM_SWRESET 0xff101044 + writel(0x1, (void *)CRM_SWRESET); +} + +int board_eth_init(bd_t *bis) +{ + if (designware_initialize(ETH0_BASE_ADDRESS, 0) >= 0) + return 1; + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 0497a91..64f3dca 100644 --- a/boards.cfg +++ b/boards.cfg @@ -47,6 +47,7 @@ Active aarch64 armv8 - armltd vexpress64 Active arc arc700 - synopsys - axs101 - Alexey Brodkin abrodkin@synopsys.com Active arc arc700 - synopsys <none> arcangel4 - Alexey Brodkin abrodkin@synopsys.com Active arc arc700 - synopsys <none> arcangel4-be - Alexey Brodkin abrodkin@synopsys.com +Active arc arc700 - abilis - tb100 - Alexey Brodkin abrodkin@synopsys.com Active arm arm1136 - armltd integrator integratorcp_cm1136 integratorcp:CM1136 Linus Walleij linus.walleij@linaro.org Active arm arm1136 mx31 - - imx31_phycore - - Active arm arm1136 mx31 davedenx - qong - Wolfgang Denk wd@denx.de diff --git a/include/configs/tb100.h b/include/configs/tb100.h new file mode 100644 index 0000000..8a861a8 --- /dev/null +++ b/include/configs/tb100.h @@ -0,0 +1,123 @@ +/* + * Copyright (C) 2011-2014 Pierrick Hascoet, Abilis Systems + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CONFIG_TB100_H_ +#define _CONFIG_TB100_H_ + +#include <linux/sizes.h> + +/* + * CPU configuration + */ +#define CONFIG_ARC700 +#define CONFIG_ARC_MMU_VER 3 +#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_SYS_CLK_FREQ 500000000 +#define CONFIG_SYS_TIMER_RATE CONFIG_SYS_CLK_FREQ + +/* + * Board configuration + */ +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_ARCH_EARLY_INIT_R + +/* + * Memory configuration + */ +#define CONFIG_SYS_TEXT_BASE 0x84000000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_SYS_SDRAM_SIZE SZ_128M + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 0x1000 - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MALLOC_LEN SZ_128K +#define CONFIG_SYS_BOOTM_LEN SZ_32M +#define CONFIG_SYS_LOAD_ADDR 0x82000000 + +#define CONFIG_SYS_NO_FLASH + +/* + * UART configuration + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_CLK 166666666 +#define CONFIG_SYS_NS16550_COM1 0xFF100000 +#define CONFIG_SYS_NS16550_MEM32 + +#define CONFIG_BAUDRATE 115200 + +/* + * Ethernet PHY configuration + */ +#define CONFIG_PHYLIB +#define CONFIG_PHY_GIGE + +/* + * Even though the board houses Realtek RTL8211E PHY + * corresponding PHY driver (drivers/net/phy/realtek.c) behaves unexpectedly. + * In particular "parse_status" reports link is down. + * + * Until Realtek PHY driver is fixed fall back to generic PHY driver + * which implements all required functionality and behaves much more stable. + * + * #define CONFIG_PHY_REALTEK + * + */ + +/* + * Ethernet configuration + */ +#define CONFIG_DESIGNWARE_ETH +#define ETH0_BASE_ADDRESS 0xFE100000 +#define ETH1_BASE_ADDRESS 0xFE110000 + +/* + * Command line configuration + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_PING + +#define CONFIG_OF_LIBFDT + +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_MAXARGS 16 + +/* + * Environment settings + */ +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE SZ_2K +#define CONFIG_ENV_OFFSET 0 + +/* + * Environment configuration + */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTARGS "console=ttyS0,115200n8" +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +/* + * Console configuration + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "[tb100]:~# " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#endif /* _CONFIG_TB100_H_ */
Alexey Brodkin
