[U-Boot] [PATCH v3] MPC8349ITX: several config issues fixed
The previous version rebooted forever with DDR bigger than 256MB. Access the DS1339 RTC chip is on I2C1 bus. Allow DHCP.
Signed-off-by: Valeriy Glushkov gvv@lstec.com --- include/configs/MPC8349ITX.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 14cbc45..f1b5566 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -98,6 +98,7 @@ #define CONFIG_SYS_I2C_OFFSET 0x3000 #define CONFIG_SYS_I2C2_OFFSET 0x3100 #define CONFIG_SYS_SPD_BUS_NUM 1 /* The I2C bus for SPD */ +#define CONFIG_SYS_RTC_BUS_NUM 1 /* The I2C bus for RTC */
#define CONFIG_SYS_I2C_8574_ADDR1 0x20 /* I2C1, PCF8574 */ #define CONFIG_SYS_I2C_8574_ADDR2 0x21 /* I2C1, PCF8574 */ @@ -158,6 +159,9 @@ #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075)
+#define CONFIG_VERY_BIG_RAM +#define CONFIG_MAX_MEM_MAPPED ((phys_size_t)256 << 20) + #ifdef CONFIG_HARD_I2C #define CONFIG_SPD_EEPROM /* use SPD EEPROM for DDR setup*/ #endif @@ -447,6 +451,7 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_CMD_IRQ #define CONFIG_CMD_NET #define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP #define CONFIG_CMD_SDRAM
#ifdef CONFIG_COMPACT_FLASH
Hi Valeriy,
Are you not getting these warnings?:
Configuring for MPC8349ITX board... In file included from /home/kim/git/u-boot/include/config.h:5, from include/common.h:35: /home/kim/git/u-boot/include/configs/MPC8349ITX.h:173:1: warning: "CONFIG_MAX_MEM_MAPPED" redefined In file included from /home/kim/git/u-boot/include/config.h:4, from include/common.h:35: /home/kim/git/u-boot/include/asm/config.h:28:1: warning: this is the location of the previous definition
please fix.
Kim
On Mon, Feb 16, 2009 at 7:28 PM, Kim Phillips kim.phillips@freescale.com wrote:
Becky posted a patch very similar to this, but for all of 86xx. Maybe there's some kind of conflict?
Also, shouldn't this change be made for all 83xx, not just this one board?
The default value is 256M so I don't thing the change is need anymore.
- k
Huh? I think his patch is supposed to address the fact that 256MB is the limit, and he wants to add more.
so this commit started producing warnings for boards that defined their own CONFIG_MAX_MEM_MAPPED, such as the SIMPC8313 (with 512MB):
commit 87c9063963561d3d01064be34d0c30855a56587b Author: Kumar Gala galak@kernel.crashing.org Date: Thu Feb 5 20:40:58 2009 -0600
ppc: Move CONFIG_MAX_MEM_MAPPED to common config.h
Moved CONFIG_MAX_MEM_MAPPED to the asm/config.h so its kept consistent between the two current users (lib_ppc/board.c, 44x SPD DDR2).
Signed-off-by: Kumar Gala galak@kernel.crashing.org Acked-by: Stefan Roese sr@denx.de
the warnings are:
In file included from /home/r1aaha/git/u-boot/include/config.h:5, from /home/r1aaha/git/u-boot/include/common.h:35, from simpc8313.c:26: /home/r1aaha/git/u-boot/include/configs/SIMPC8313.h:81:1: warning: "CONFIG_MAX_MEM_MAPPED" redefined In file included from /home/r1aaha/git/u-boot/include/config.h:4, from /home/r1aaha/git/u-boot/include/common.h:35, from simpc8313.c:26: /home/r1aaha/git/u-boot/include/asm/config.h:28:1: warning: this is the location of the previous definition
which is probably all due to include/config.h including the file with the default value prior to the board's config:
/* Automatically generated - do not edit */ #include <asm/config.h> #include <configs/SIMPC8313.h>
So how are boards supposed to define their own CONFIG_MAX_MEM_MAPPED now? In the Makefile? Or is there a better place for this default value?
Kim
On Tue, Feb 17, 2009 at 3:49 PM, Kumar Gala <galak@kernel.crashing.org
wrote: The default value is 256M so I don't thing the change is need anymore.
the warnings are:
We can probably swap the order of the generated config.h to have <asm/ config.h> be second.
- k
On Mon, 16 Feb 2009 19:28:32 -0600 Kim Phillips kim.phillips@freescale.com wrote:
these warnings are no longer occurring, thus applied.
Thanks Valeriy,
Kim
Kim Phillips
Kumar Gala
Timur Tabi
Valeriy Glushkov
