[U-Boot] [PATCH] eth: dm: fec: Add gpio phy reset binding
Add the missing gpio phy reset binding to the gpio and it's reset time configuration
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/net/fec_mxc.c | 42 ++++++++++++++++++++++++++++++++++++------ drivers/net/fec_mxc.h | 5 ++++- 2 files changed, 40 insertions(+), 7 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 694a0b2..9eb2693 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -15,7 +15,6 @@ #include <miiphy.h> #include <net.h> #include <netdev.h> -#include "fec_mxc.h"
#include <asm/io.h> #include <linux/errno.h> @@ -24,6 +23,9 @@ #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/mach-imx/sys_proto.h> +#include <asm-generic/gpio.h> + +#include "fec_mxc.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -1245,6 +1247,19 @@ static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) return 0; }
+#ifdef CONFIG_DM_GPIO +/* FEC GPIO reset */ +static void fec_gpio_reset(struct fec_priv *priv) +{ + debug("fec_gpio_reset: fec_gpio_reset(dev)\n"); + if (dm_gpio_is_valid(&priv->phy_reset_gpio)) { + dm_gpio_set_value(&priv->phy_reset_gpio, 1); + udelay(priv->reset_delay); + dm_gpio_set_value(&priv->phy_reset_gpio, 0); + } +} +#endif + static int fecmxc_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); @@ -1257,6 +1272,9 @@ static int fecmxc_probe(struct udevice *dev) if (ret) return ret;
+#ifdef CONFIG_DM_GPIO + fec_gpio_reset(priv); +#endif /* Reset chip. */ writel(readl(&priv->eth->ecntrl) | FEC_ECNTRL_RESET, &priv->eth->ecntrl); @@ -1314,6 +1332,7 @@ static int fecmxc_remove(struct udevice *dev)
static int fecmxc_ofdata_to_platdata(struct udevice *dev) { + int ret = 0; struct eth_pdata *pdata = dev_get_platdata(dev); struct fec_priv *priv = dev_get_priv(dev); const char *phy_mode; @@ -1331,12 +1350,23 @@ static int fecmxc_ofdata_to_platdata(struct udevice *dev) return -EINVAL; }
- /* TODO - * Need to get the reset-gpio and related properties from DT - * and implemet the enet reset code on .probe call - */ +#ifdef CONFIG_DM_GPIO + ret = gpio_request_by_name(dev, "phy-reset-gpios", 0, + &priv->phy_reset_gpio, GPIOD_IS_OUT); + if (ret == 0) { + ret = dev_read_u32_array(dev, "phy-reset-duration", + &priv->reset_delay, 1000); + } else if (ret == -ENOENT) { + ret = 0; + }
- return 0; + if (priv->reset_delay > 1000) { + printf("FEX MXC: gpio reset timeout should be less the 1000\n"); + priv->reset_delay = 1000; + } +#endif + + return ret; }
static const struct udevice_id fecmxc_ids[] = { diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index 3b935af..fd89443 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -250,7 +250,10 @@ struct fec_priv { int phy_id; int (*mii_postcall)(int); #endif - +#ifdef CONFIG_DM_GPIO + struct gpio_desc phy_reset_gpio; + uint32_t reset_delay; +#endif #ifdef CONFIG_DM_ETH u32 interface; #endif
Michael Trimarchi
