[U-Boot] [PATCH] binman: README: fix default filename of u-boot-with-ucode-ptr
The suffix should be ".bin" instead of ".dtb" .
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
tools/binman/README.entries | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/README.entries b/tools/binman/README.entries index 10994335217c..26050da7702f 100644 --- a/tools/binman/README.entries +++ b/tools/binman/README.entries @@ -971,7 +971,7 @@ Entry: u-boot-with-ucode-ptr: U-Boot with embedded microcode pointer --------------------------------------------------------------------
Properties / Entry arguments: - - filename: Filename of u-boot-nodtb.dtb (default 'u-boot-nodtb.dtb') + - filename: Filename of u-boot-nodtb.bin (default 'u-boot-nodtb.bin') - optional-ucode: boolean property to make microcode optional. If the u-boot.bin image does not include microcode, no error will be generated.
On Mon, Nov 25, 2019 at 9:45 AM Masahiro Yamada yamada.masahiro@socionext.com wrote:
Actually I take that back...this should be modified in the source .py file, from which this README is generated.
Bin Meng
Masahiro Yamada
