[U-Boot] [PATCH] imx: Add variscite DART-6UL Evaluation Kit
Port for the DART-6UL Evaluation Kit SBC. Based on the variscite DART-6UL iMX6ULL SoM.
CPU: Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C) at 43C Reset cause: POR Model: Variscite DART-6UL Evaluation Kit Board: Variscite DART-6UL Evaluation Kit DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0
Working:
- Eth0
- i2c
- MMC/SD
- eMMC
- USB host
- UART 1
Note: LCDIF porting needs DM_VIDEO https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.d enx.de%2Fpipermail%2Fu-boot%2F2019-April%2F365506.html&data=02 %7C01%7Cpeng.fan%40nxp.com%7Ced2e2a78aa28409c4c1c08d6c380a738 %7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636911354661076 012&sdata=meF0d06pEsGDBXW83kDMr10Qu%2FafP76xBhdzFCzp8VY% 3D&reserved=0
Signed-off-by: Parthiban Nallathambi parthitce@gmail.com
arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6ull-dart-6ul.dts | 39 ++++ arch/arm/dts/imx6ull-dart-6ul.dtsi | 261 +++++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 12 ++ board/variscite/dart_6ul/Kconfig | 12 ++ board/variscite/dart_6ul/MAINTAINERS | 8 + board/variscite/dart_6ul/Makefile | 4 + board/variscite/dart_6ul/README | 41 +++++ board/variscite/dart_6ul/dart_6ul.c | 228 +++++++++++++++++++++++ board/variscite/dart_6ul/spl.c | 215 ++++++++++++++++++++++ configs/variscite_dart6ul_defconfig | 55 ++++++ include/configs/dart_6ul.h | 131 ++++++++++++++ 13 files changed, 1008 insertions(+) create mode 100644 arch/arm/dts/imx6ull-dart-6ul.dts create mode 100644 arch/arm/dts/imx6ull-dart-6ul.dtsi create mode 100644 board/variscite/dart_6ul/Kconfig create mode 100644 board/variscite/dart_6ul/MAINTAINERS create mode 100644 board/variscite/dart_6ul/Makefile create mode 100644 board/variscite/dart_6ul/README create mode 100644 board/variscite/dart_6ul/dart_6ul.c create mode 100644 board/variscite/dart_6ul/spl.c create mode 100644 configs/variscite_dart6ul_defconfig create mode 100644 include/configs/dart_6ul.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4640f3b3bd..c20866c86a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1635,6 +1635,7 @@ source "board/tcl/sl50/Kconfig" source "board/ucRobotics/bubblegum_96/Kconfig" source "board/birdland/bav335x/Kconfig" source "board/toradex/colibri_pxa270/Kconfig" +source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" source "board/woodburn/Kconfig" source "board/xilinx/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0aee8dfde0..6fb545dc9f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -549,6 +549,7 @@ dtb-$(CONFIG_MX6UL) += \ dtb-$(CONFIG_MX6ULL) += \ imx6ull-14x14-evk.dtb \ imx6ull-colibri.dtb \
imx6ull-dart-6ul.dtb
dtb-$(CONFIG_ARCH_MX6) += \ imx6-colibri.dtb diff --git a/arch/arm/dts/imx6ull-dart-6ul.dts b/arch/arm/dts/imx6ull-dart-6ul.dts new file mode 100644 index 0000000000..4cab1a048b --- /dev/null +++ b/arch/arm/dts/imx6ull-dart-6ul.dts @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2019 Parthiban Nallathambi parthitce@gmail.com */
+/dts-v1/;
+#include "imx6ull.dtsi" +#include "imx6ull-dart-6ul.dtsi"
model = "Variscite DART-6UL Evaluation Kit";
compatible = "variscite,imx6ull-dart-6ul", "fsl,imx6ull"; };
+&usdhc2 {
status = "okay";
+&usbotg1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usb_otg1_id>;
dr_mode = "otg";
srp-disable;
hnp-disable;
adp-disable;
status = "okay";
+&iomuxc {
pinctrl_usb_otg1_id: usbotg1idgrp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO00__ANATOP_OTG1_ID
0x17059
+}; diff --git a/arch/arm/dts/imx6ull-dart-6ul.dtsi b/arch/arm/dts/imx6ull-dart-6ul.dtsi new file mode 100644 index 0000000000..e96669f493 --- /dev/null +++ b/arch/arm/dts/imx6ull-dart-6ul.dtsi @@ -0,0 +1,261 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
model = "Variscite DART-6UL i.MX6 Ultra Low Lite SOM";
memory {
reg = <0x80000000 0x20000000>;
chosen {
stdout-path = &uart1;
+&fec1 {
pinctrl-0 = <&pinctrl_enet1>;
phy-mode = "rmii";
phy-handle = <ðphy0>;
status = "okay";
mdio1: mdio1 {
#address-cells = <1>;
#size-cells = <0>;
ethphy0: ethernet-phy@1 {
reg = <1>;
micrel,led-mode = <1>;
+&fec2 {
pinctrl-0 = <&pinctrl_enet2>;
phy-mode = "rmii";
phy-handle = <ðphy1>;
status = "okay";
mdio2: mdio2 {
#size-cells = <0>;
ethphy1: ethernet-phy@2 {
reg = <2>;
+&gpmi {
pinctrl-0 = <&pinctrl_gpmi_nand>;
nand-on-flash-bbt;
fsl,no-blockmark-swap;
status = "disabled";
#size-cells = <1>;
partition@0 {
label = "uboot";
reg = <0x0 0x400000>;
partition@400000 {
label = "uboot-env";
reg = <0x400000 0x100000>;
partition@500000 {
label = "root";
reg = <0x500000 0x0>;
+&i2c1 {
clock-frequency = <100000>;
pinctrl-names = "default", "gpio";
pinctrl-0 = <&pinctrl_i2c1>;
pinctrl-1 = <&pinctrl_i2c1_gpio>;
scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>;
status = "okay";
+&i2c2 {
pinctrl-0 = <&pinctrl_i2c2>;
pinctrl-1 = <&pinctrl_i2c2_gpio>;
scl-gpios = <&gpio1 30 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio1 31 GPIO_ACTIVE_HIGH>;
status = "okay";
eeprom@50 {
compatible = "cat,24c32";
reg = <0x50>;
+&pwm1 {
pinctrl-0 = <&pinctrl_pwm1>;
#pwm-cells = <3>;
status = "okay";
+&uart1 {
pinctrl-0 = <&pinctrl_uart1>;
status = "okay";
+&usdhc1 {
pinctrl-0 = <&pinctrl_usdhc1>;
cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>;
bus-width = <0x4>;
no-1-8-v;
status = "okay";
+&usdhc2 {
pinctrl-0 = <&pinctrl_usdhc2>;
bus-width = <8>;
no-1-8-v;
non-removable;
keep-power-in-suspend;
+&iomuxc {
pinctrl_enet1: enet1grp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO06__ENET1_MDIO
0x1b0b0
MX6UL_PAD_GPIO1_IO07__ENET1_MDC
0X1b0b0
MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN
0x1b0b0
MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER
0x1b0b0
MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0
MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0
MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN
0x1b0b0
MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0
MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0
MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031
pinctrl_enet2: enet2grp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO06__ENET2_MDIO
0x1b0b0
MX6UL_PAD_GPIO1_IO07__ENET2_MDC
0X1b0b0
MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN
0x1b0b0
MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER
0x1b0b0
MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0
MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0
MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN
0x1b0b0
MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0
MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0
MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031
pinctrl_gpmi_nand: gpminandgrp {
fsl,pins = <
MX6UL_PAD_NAND_DQS__RAWNAND_DQS
0x0b0b1
MX6UL_PAD_NAND_CLE__RAWNAND_CLE
0x0b0b1
MX6UL_PAD_NAND_ALE__RAWNAND_ALE
0x0b0b1
MX6UL_PAD_NAND_WP_B__RAWNAND_WP_B 0x0b0b1
MX6UL_PAD_NAND_READY_B__RAWNAND_READY_B 0x0b000
MX6UL_PAD_NAND_CE0_B__RAWNAND_CE0_B 0x0b0b1
MX6UL_PAD_NAND_CE1_B__RAWNAND_CE1_B 0x0b0b1
MX6UL_PAD_NAND_RE_B__RAWNAND_RE_B
0x0b0b1
MX6UL_PAD_NAND_WE_B__RAWNAND_WE_B 0x0b0b1
MX6UL_PAD_NAND_DATA00__RAWNAND_DATA00 0x0b0b1
MX6UL_PAD_NAND_DATA01__RAWNAND_DATA01 0x0b0b1
MX6UL_PAD_NAND_DATA02__RAWNAND_DATA02 0x0b0b1
MX6UL_PAD_NAND_DATA03__RAWNAND_DATA03 0x0b0b1
MX6UL_PAD_NAND_DATA04__RAWNAND_DATA04 0x0b0b1
MX6UL_PAD_NAND_DATA05__RAWNAND_DATA05 0x0b0b1
MX6UL_PAD_NAND_DATA06__RAWNAND_DATA06 0x0b0b1
MX6UL_PAD_NAND_DATA07__RAWNAND_DATA07 0x0b0b1
pinctrl_i2c1: i2cgrp {
fsl,pins = <
MX6UL_PAD_UART4_TX_DATA__I2C1_SCL
0x4001b8b0
MX6UL_PAD_UART4_RX_DATA__I2C1_SDA
0x4001b8b0
pinctrl_i2c1_gpio: i2c1grp_gpio {
fsl,pins = <
MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28
0x1b8b0
MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29
0x1b8b0
pinctrl_i2c2: i2cgrp {
fsl,pins = <
MX6UL_PAD_UART5_TX_DATA__I2C2_SCL
0x4001b8b0
MX6UL_PAD_UART5_RX_DATA__I2C2_SDA
0x4001b8b0
pinctrl_i2c2_gpio: i2c2grp_gpio {
fsl,pins = <
MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30
0x1b8b0
MX6UL_PAD_UART5_RX_DATA__GPIO1_IO31
0x1b8b0
pinctrl_pwm1: pwm1grp {
fsl,pins = <
MX6UL_PAD_LCD_DATA00__GPIO3_IO05
0x1b0b1
pinctrl_uart1: uart1grp {
fsl,pins = <
MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1
MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1
pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
MX6UL_PAD_SD1_CMD__USDHC1_CMD
0x17059
MX6UL_PAD_SD1_CLK__USDHC1_CLK
0x10059
MX6UL_PAD_SD1_DATA0__USDHC1_DATA0
0x17059
MX6UL_PAD_SD1_DATA1__USDHC1_DATA1
0x17059
MX6UL_PAD_SD1_DATA2__USDHC1_DATA2
0x17059
MX6UL_PAD_SD1_DATA3__USDHC1_DATA3
0x17059
MX6UL_PAD_UART1_RTS_B__GPIO1_IO19
0x17059
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX6UL_PAD_NAND_WE_B__USDHC2_CMD
0x170f9
MX6UL_PAD_NAND_RE_B__USDHC2_CLK
0x100f9
MX6UL_PAD_NAND_DATA00__USDHC2_DATA0
0x170f9
MX6UL_PAD_NAND_DATA01__USDHC2_DATA1
0x170f9
MX6UL_PAD_NAND_DATA02__USDHC2_DATA2
0x170f9
MX6UL_PAD_NAND_DATA03__USDHC2_DATA3
0x170f9
MX6UL_PAD_NAND_DATA04__USDHC2_DATA4
0x170f9
MX6UL_PAD_NAND_DATA05__USDHC2_DATA5
0x170f9
MX6UL_PAD_NAND_DATA06__USDHC2_DATA6
0x170f9
MX6UL_PAD_NAND_DATA07__USDHC2_DATA7
0x170f9
+}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index e782859b1e..f513c4c06f 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -161,6 +161,18 @@ config TARGET_COLIBRI_IMX6ULL select DM_THERMAL select MX6ULL
+config TARGET_DART_6UL
bool "Variscite imx6ULL dart(DART-SOM-6ULL)"
select MX6ULL
select DM
select DM_ETH
select DM_GPIO
select DM_I2C
select DM_MMC
select DM_SERIAL
select DM_THERMAL
select SUPPORT_SPL
config TARGET_DHCOMIMX6 bool "dh_imx6" select BOARD_EARLY_INIT_F diff --git a/board/variscite/dart_6ul/Kconfig b/board/variscite/dart_6ul/Kconfig new file mode 100644 index 0000000000..1765af1d82 --- /dev/null +++ b/board/variscite/dart_6ul/Kconfig @@ -0,0 +1,12 @@ +if TARGET_DART_6UL
+config SYS_BOARD
default "dart_6ul"
+config SYS_VENDOR
default "variscite"
+config SYS_CONFIG_NAME
default "dart_6ul"
+endif diff --git a/board/variscite/dart_6ul/MAINTAINERS b/board/variscite/dart_6ul/MAINTAINERS new file mode 100644 index 0000000000..339f93fa66 --- /dev/null +++ b/board/variscite/dart_6ul/MAINTAINERS @@ -0,0 +1,8 @@ +MX6UL_DART BOARD +M: Parthiban Nallathambi parthitce@gmail.com +S: Maintained +F: arch/arm/dts/imx6ull-dart-6ul.dts +F: arch/arm/dts/imx6ull-dart-6ul.dtsi +F: board/variscite/dart_6ul/ +F: configs/variscite_dart6ul_defconfig +F: include/configs/dart_6ul.h diff --git a/board/variscite/dart_6ul/Makefile b/board/variscite/dart_6ul/Makefile new file mode 100644 index 0000000000..48aa361bf2 --- /dev/null +++ b/board/variscite/dart_6ul/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+
+obj-y := dart_6ul.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/variscite/dart_6ul/README b/board/variscite/dart_6ul/README new file mode 100644 index 0000000000..d76b997e22 --- /dev/null +++ b/board/variscite/dart_6ul/README @@ -0,0 +1,41 @@ +How to use U-Boot on variscite DART-6UL Evaluation Kit +------------------------------------------------------
+- Configure and build U-Boot for DART-6UL iMX6ULL:
- $ make mrproper
- $ make variscite_dart6ul_defconfig
- $ make
- This will generate SPL and u-boot-dtb.img images.
+Boot from MMC/SD: +- The SPL and u-boot-dtb.img images need to be flashed into the micro SD card:
- $ sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync
- $ sudo dd if=u-boot-dtb.img of=/dev/mmcblk0 bs=1k seek=69; sync
+- Boot mode settings:
- Boot switch position: SW1 -> 0
SW2 -> 0
+Boot from eMMC: +- if bootpart is not enabled by default, to enable under Linux
echo 0 >/sys/block/mmcblk1boot0/force_ro
mmc bootpart enable 1 1 /dev/mmcblk1boot0
+- Flash the SPL and u-boot-dtb.img to mmcblk1boot0
- $ sudo dd if=SPL of=/dev/mmcblk1boot0 bs=1k seek=1; sync
- $ sudo dd if=u-boot-dtb.img of=/dev/mmcblk1boot0 bs=1k seek=69;
+sync
SW2 -> 1
+- Connect the Serial cable to UART0 and the PC for the console.
+- Insert the micro SD card in the board and power it up.
+- U-Boot messages should come up. diff --git a/board/variscite/dart_6ul/dart_6ul.c b/board/variscite/dart_6ul/dart_6ul.c new file mode 100644 index 0000000000..4765595af1 --- /dev/null +++ b/board/variscite/dart_6ul/dart_6ul.c @@ -0,0 +1,228 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2015-2019 Variscite Ltd.
+#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc.h> +#include <linux/bitops.h> +#include <miiphy.h> +#include <netdev.h> +#include <usb.h> +#include <usb/ehci-ci.h>
+DECLARE_GLOBAL_DATA_PTR;
+int dram_init(void) +{
gd->ram_size = imx_ddr_size();
+#ifdef CONFIG_NAND_MXS +#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | +PAD_CTL_PUS_100K_UP) #define GPMI_PAD_CTRL1 (PAD_CTL_DSE_40ohm | PAD_CTL_SPEED_MED | \
PAD_CTL_SRE_FAST) #define GPMI_PAD_CTRL2
+(GPMI_PAD_CTRL0 | GPMI_PAD_CTRL1) static iomux_v3_cfg_t const +nand_pads[] = {
Is it ok to switch to use pinctrl? I have not try drivers/mtd/nand/raw/mxs_nand_dt.c, but it will simplify board code if that could be used for your board.
MX6_PAD_NAND_DATA00__RAWNAND_DATA00 |
MUX_PAD_CTRL(GPMI_PAD_CTRL2),
MX6_PAD_NAND_DATA01__RAWNAND_DATA01 |
MX6_PAD_NAND_DATA02__RAWNAND_DATA02 |
MX6_PAD_NAND_DATA03__RAWNAND_DATA03 |
MX6_PAD_NAND_DATA04__RAWNAND_DATA04 |
MX6_PAD_NAND_DATA05__RAWNAND_DATA05 |
MX6_PAD_NAND_DATA06__RAWNAND_DATA06 |
MX6_PAD_NAND_DATA07__RAWNAND_DATA07 |
MX6_PAD_NAND_CLE__RAWNAND_CLE |
MX6_PAD_NAND_ALE__RAWNAND_ALE |
MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B |
MX6_PAD_NAND_RE_B__RAWNAND_RE_B |
MX6_PAD_NAND_WE_B__RAWNAND_WE_B |
MX6_PAD_NAND_WP_B__RAWNAND_WP_B |
MX6_PAD_NAND_READY_B__RAWNAND_READY_B |
MX6_PAD_NAND_DQS__RAWNAND_DQS |
MUX_PAD_CTRL(GPMI_PAD_CTRL2), };
+static void setup_gpmi_nand(void) +{
struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg
+*)CCM_BASE_ADDR;
/* config gpmi nand iomux */
imx_iomux_v3_setup_multiple_pads(nand_pads,
- ARRAY_SIZE(nand_pads));
clrbits_le32(&mxc_ccm->CCGR4,
MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK |
MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK |
MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK |
MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK |
MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK);
* config gpmi and bch clock to 100 MHz
* bch/gpmi select PLL2 PFD2 400M
* 100M = 400M / 4
clrbits_le32(&mxc_ccm->cscmr1,
MXC_CCM_CSCMR1_BCH_CLK_SEL |
MXC_CCM_CSCMR1_GPMI_CLK_SEL);
clrsetbits_le32(&mxc_ccm->cscdr1,
MXC_CCM_CSCDR1_BCH_PODF_MASK |
MXC_CCM_CSCDR1_GPMI_PODF_MASK,
(3 << MXC_CCM_CSCDR1_BCH_PODF_OFFSET)
(3 <<
MXC_CCM_CSCDR1_GPMI_PODF_OFFSET));
/* enable gpmi and bch clock gating */
setbits_le32(&mxc_ccm->CCGR4,
/* enable apbh clock gating */
setbits_le32(&mxc_ccm->CCGR0,
MXC_CCM_CCGR0_APBHDMA_MASK); } +#endif
+#ifdef CONFIG_FEC_MXC +#define ENET_CLK_PAD_CTRL (PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \
PAD_CTL_SPEED_HIGH |
PAD_CTL_DSE_48ohm | \
PAD_CTL_SRE_FAST)
+#define MDIO_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \
PAD_CTL_DSE_48ohm |
PAD_CTL_SRE_FAST | \
PAD_CTL_ODE)
- pin conflicts for fec1 and fec2, GPIO1_IO06 and GPIO1_IO07 can only
- be used for ENET1 or ENET2, cannot be used for both.
+static iomux_v3_cfg_t const fec1_pads[] = {
How about use DM_ETH?
Regards, Peng.
MX6_PAD_GPIO1_IO06__ENET1_MDIO |
MUX_PAD_CTRL(MDIO_PAD_CTRL),
MX6_PAD_GPIO1_IO07__ENET1_MDC |
MUX_PAD_CTRL(ENET_PAD_CTRL),
MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 |
MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 |
MX6_PAD_ENET1_TX_EN__ENET1_TX_EN |
MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 |
MUX_PAD_CTRL(ENET_CLK_PAD_CTRL),
MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 |
MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 |
MX6_PAD_ENET1_RX_ER__ENET1_RX_ER |
MX6_PAD_ENET1_RX_EN__ENET1_RX_EN |
MUX_PAD_CTRL(ENET_PAD_CTRL), +};
+static iomux_v3_cfg_t const fec2_pads[] = {
MX6_PAD_GPIO1_IO06__ENET2_MDIO |
MX6_PAD_GPIO1_IO07__ENET2_MDC |
MX6_PAD_ENET2_TX_DATA0__ENET2_TDATA00 |
MX6_PAD_ENET2_TX_DATA1__ENET2_TDATA01 |
MX6_PAD_ENET2_TX_EN__ENET2_TX_EN |
MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 |
MX6_PAD_ENET2_RX_DATA0__ENET2_RDATA00 |
MX6_PAD_ENET2_RX_DATA1__ENET2_RDATA01 |
MX6_PAD_ENET2_RX_ER__ENET2_RX_ER |
MX6_PAD_ENET2_RX_EN__ENET2_RX_EN |
+static void setup_iomux_fec(int fec_id) {
if (fec_id == 0)
imx_iomux_v3_setup_multiple_pads(fec1_pads,
ARRAY_SIZE(fec1_pads));
else
imx_iomux_v3_setup_multiple_pads(fec2_pads,
ARRAY_SIZE(fec2_pads)); +}
+int board_eth_init(bd_t *bis) +{
int ret = 0;
ret = fecmxc_initialize_multi(bis, CONFIG_FEC_ENET_DEV,
CONFIG_FEC_MXC_PHYADDR,
- IMX_FEC_BASE);
+#if defined(CONFIG_CI_UDC) && defined(CONFIG_USB_ETHER)
/* USB Ethernet Gadget */
usb_eth_initialize(bis);
return ret;
+static int setup_fec(int fec_id) +{
struct iomuxc *const iomuxc_regs = (struct iomuxc
*)IOMUXC_BASE_ADDR;
int ret;
if (fec_id == 0) {
* Use 50M anatop loopback REF_CLK1 for ENET1,
* clear gpr1[13], set gpr1[17].
clrsetbits_le32(&iomuxc_regs->gpr[1],
IOMUX_GPR1_FEC1_MASK,
IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK);
} else {
* Use 50M anatop loopback REF_CLK2 for ENET2,
* clear gpr1[14], set gpr1[18].
IOMUX_GPR1_FEC2_MASK,
IOMUX_GPR1_FEC2_CLOCK_MUX1_SEL_MASK);
ret = enable_fec_anatop_clock(fec_id, ENET_50MHZ);
if (ret)
return ret;
enable_enet_clk(1);
+int board_phy_config(struct phy_device *phydev) {
* Defaults + Enable status LEDs (LED1: Activity, LED0: Link) &
select
* 50 MHz RMII clock mode.
phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190);
if (phydev->drv->config)
phydev->drv->config(phydev);
+} +#endif /* CONFIG_FEC_MXC */
+int board_early_init_f(void) +{
setup_iomux_fec(CONFIG_FEC_ENET_DEV);
+int board_init(void) +{
/* Address of boot parameters */
gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
setup_fec(CONFIG_FEC_ENET_DEV);
setup_gpmi_nand();
+int checkboard(void) +{
puts("Board: Variscite DART-6UL Evaluation Kit\n");
+} diff --git a/board/variscite/dart_6ul/spl.c b/board/variscite/dart_6ul/spl.c new file mode 100644 index 0000000000..f7e6ab6325 --- /dev/null +++ b/board/variscite/dart_6ul/spl.c @@ -0,0 +1,215 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <spl.h> +#include <asm/arch/clock.h> +#include <asm/io.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/crm_regs.h> +#include <fsl_esdhc.h>
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED |
PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+static iomux_v3_cfg_t const uart1_pads[] = {
MX6_PAD_UART1_TX_DATA__UART1_DCE_TX |
MUX_PAD_CTRL(UART_PAD_CTRL),
MX6_PAD_UART1_RX_DATA__UART1_DCE_RX |
+MUX_PAD_CTRL(UART_PAD_CTRL), };
+static void setup_iomux_uart(void) +{
imx_iomux_v3_setup_multiple_pads(uart1_pads,
+ARRAY_SIZE(uart1_pads)); }
+static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = {
.grp_addds = 0x00000030,
.grp_ddrmode_ctl = 0x00020000,
.grp_b0ds = 0x00000030,
.grp_ctlds = 0x00000030,
.grp_b1ds = 0x00000030,
.grp_ddrpke = 0x00000000,
.grp_ddrmode = 0x00020000,
.grp_ddr_type = 0x000c0000,
+static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = {
.dram_dqm0 = 0x00000030,
.dram_dqm1 = 0x00000030,
.dram_ras = 0x00000030,
.dram_cas = 0x00000030,
.dram_odt0 = 0x00000030,
.dram_odt1 = 0x00000030,
.dram_sdba2 = 0x00000000,
.dram_sdclk_0 = 0x00000008,
.dram_sdqs0 = 0x00000038,
.dram_sdqs1 = 0x00000030,
.dram_reset = 0x00000030,
+static struct mx6_mmdc_calibration mx6_mmcd_calib = {
.p0_mpwldectrl0 = 0x00000000,
.p0_mpdgctrl0 = 0x414C0158,
.p0_mprddlctl = 0x40403A3A,
.p0_mpwrdlctl = 0x40405A56,
+struct mx6_ddr_sysinfo ddr_sysinfo = {
.dsize = 0,
.cs_density = 20,
.ncs = 1,
.cs1_mirror = 0,
.rtt_wr = 2,
.rtt_nom = 1, /* RTT_Nom = RZQ/2 */
.walat = 1, /* Write additional latency */
.ralat = 5, /* Read additional latency */
.mif3_mode = 3, /* Command prediction working mode
.bi_on = 1, /* Bank interleaving enabled */
.sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */
.rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */
+static struct mx6_ddr3_cfg mem_ddr = {
.mem_speed = 800,
.density = 4,
.width = 16,
.banks = 8,
.rowaddr = 15,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
+static void ccgr_init(void) +{
struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg
*)CCM_BASE_ADDR;
writel(0xFFFFFFFF, &ccm->CCGR0);
writel(0xFFFFFFFF, &ccm->CCGR1);
writel(0xFFFFFFFF, &ccm->CCGR2);
writel(0xFFFFFFFF, &ccm->CCGR3);
writel(0xFFFFFFFF, &ccm->CCGR4);
writel(0xFFFFFFFF, &ccm->CCGR5);
writel(0xFFFFFFFF, &ccm->CCGR6);
writel(0xFFFFFFFF, &ccm->CCGR7);
/* Enable Audio Clock for SOM codec */
writel(0x01130100, (long *)CCM_CCOSR); }
+static void spl_dram_init(void) +{
mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs,
&mx6_grp_ioregs);
mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); }
+#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW |
PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+static iomux_v3_cfg_t const usdhc1_pads[] = {
MX6_PAD_SD1_CLK__USDHC1_CLK |
MUX_PAD_CTRL(USDHC_PAD_CTRL),
MX6_PAD_SD1_CMD__USDHC1_CMD |
MX6_PAD_SD1_DATA0__USDHC1_DATA0 |
MX6_PAD_SD1_DATA1__USDHC1_DATA1 |
MX6_PAD_SD1_DATA2__USDHC1_DATA2 |
MX6_PAD_SD1_DATA3__USDHC1_DATA3 |
MUX_PAD_CTRL(USDHC_PAD_CTRL), +};
+#ifndef CONFIG_NAND_MXS +static iomux_v3_cfg_t const usdhc2_pads[] = {
MX6_PAD_NAND_RE_B__USDHC2_CLK |
MX6_PAD_NAND_WE_B__USDHC2_CMD |
MX6_PAD_NAND_DATA00__USDHC2_DATA0 |
MX6_PAD_NAND_DATA01__USDHC2_DATA1 |
MX6_PAD_NAND_DATA02__USDHC2_DATA2 |
MX6_PAD_NAND_DATA03__USDHC2_DATA3 |
MX6_PAD_NAND_DATA04__USDHC2_DATA4 |
MX6_PAD_NAND_DATA05__USDHC2_DATA5 |
MX6_PAD_NAND_DATA06__USDHC2_DATA6 |
MX6_PAD_NAND_DATA07__USDHC2_DATA7 |
+MUX_PAD_CTRL(USDHC_PAD_CTRL), }; #endif
+static struct fsl_esdhc_cfg usdhc_cfg[] = {
.esdhc_base = USDHC1_BASE_ADDR,
.max_bus_width = 4,
.esdhc_base = USDHC2_BASE_ADDR,
.max_bus_width = 8,
+#endif +};
+int board_mmc_getcd(struct mmc *mmc) +{
return 1;
+int board_mmc_init(bd_t *bis) +{
int i, ret;
for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) {
switch (i) {
case 0:
SETUP_IOMUX_PADS(usdhc1_pads);
usdhc_cfg[i].sdhc_clk =
mxc_get_clock(MXC_ESDHC_CLK);
break;
case 1:
SETUP_IOMUX_PADS(usdhc2_pads);
mxc_get_clock(MXC_ESDHC2_CLK);
break;
default:
printf("Warning - USDHC%d controller not
supporting\n",
i + 1);
ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]);
if (ret) {
printf("Warning: failed to initialize mmc
dev %d\n", i);
return ret;
+void board_init_f(ulong dummy) +{
/* setup AIPS and disable watchdog */
arch_cpu_init();
ccgr_init();
/* setup GP timer */
timer_init();
setup_iomux_uart();
/* iomux and setup of i2c */
board_early_init_f();
/* UART clocks enabled and gd valid - init serial console */
preloader_console_init();
/* DDR initialization */
spl_dram_init();
/* Clear the BSS. */
memset(__bss_start, 0, __bss_end - __bss_start);
/* load/boot image from boot device */
board_init_r(NULL, 0);
+} diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig new file mode 100644 index 0000000000..a1cdd05619 --- /dev/null +++ b/configs/variscite_dart6ul_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x86000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_DART_6UL=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +# CONFIG_CMD_DEKBLOB is not set +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=8 +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd. cfg" +CONFIG_BOOTDELAY=3 +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_NET=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ull-dart-6ul" +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_MXC=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_MXC_UART=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Variscite" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_LZO=y diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h new file mode 100644 index 0000000000..fb1b899d71 --- /dev/null +++ b/include/configs/dart_6ul.h @@ -0,0 +1,131 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Board configuration file for Variscite DART-6UL Evaluation Kit
+#ifndef __DART_6UL_H #define __DART_6UL_H
+#include <linux/sizes.h> +#include "mx6_common.h"
+/* SPL options */ +#include "imx6_spl.h"
+/* NAND pin conflicts with usdhc2 */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#else +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#endif
+#ifdef CONFIG_CMD_NET +#define CONFIG_FEC_ENET_DEV 0
+#if (CONFIG_FEC_ENET_DEV == 0) +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1 +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_ETHPRIME "eth0" +#elif (CONFIG_FEC_ENET_DEV == 1) +#define IMX_FEC_BASE ENET2_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x3 +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_ETHPRIME "eth1" +#endif +#endif
+/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
+/* Environment settings */ +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_OFFSET (14 * SZ_64K) +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_OFFSET_REDUND \
(CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
+/* Environment in SD */ +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 0 +#define MMC_ROOTFS_DEV 0 +#define MMC_ROOTFS_PART 2
+/* Console configs */ +#define CONFIG_MXC_UART_BASE UART1_BASE
+/* MMC Configs */ +#define CONFIG_FSL_USDHC
+#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR +#define CONFIG_SUPPORT_EMMC_BOOT
+/* I2C configs */ +#ifdef CONFIG_CMD_I2C +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_SPEED 100000 +#endif
+/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x8000000)
+#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000
+/* Physical Memory Map */ +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE SZ_512M
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE
+#define CONFIG_SYS_INIT_SP_OFFSET \
(CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#define +CONFIG_SYS_INIT_SP_ADDR \
(CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
+/* USB Configs */ +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2
+#define CONFIG_IMX_THERMAL
+#define ENV_MMC \
"mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \
"mmcpart=" __stringify(MMC_ROOTFS_PART) "\0" \
"fitpart=1\0" \
"bootdelay=3\0" \
"silent=1\0" \
"optargs=rw rootwait\0" \
"mmcautodetect=yes\0" \
"mmcrootfstype=ext4\0" \
"mmcfit_name=fitImage\0" \
"mmcloadfit=fatload mmc ${mmcdev}:${fitpart} ${fit_addr} " \
"${mmcfit_name}\0" \
"mmcargs=setenv bootargs " \
"root=/dev/mmcblk${mmcdev}p${mmcpart} ${optargs} "
"console=${console} rootfstype=${mmcrootfstype}\0" \
"mmc_mmc_fit=run mmcloadfit;run mmcargs addcon; bootm
+${fit_addr}\0" \
+/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \
"fdt_high=0xffffffff\0" \
"console=ttymxc0,115200n8\0" \
"addcon=setenv bootargs ${bootargs}
console=${console},${baudrate}\0" \
"fit_addr=0x82000000\0" \
ENV_MMC
+#define CONFIG_BOOTCOMMAND "run mmc_mmc_fit"
+#define BOOT_TARGET_DEVICES(func) \
func(MMC, mmc, 0) \
func(MMC, mmc, 1) \
func(DHCP, dhcp, na)
+#include <config_distro_bootcmd.h>
+#endif /* __DART_6UL_H */
2.17.2
Hello Peng,
Working:
- Eth0
- i2c
- MMC/SD
- eMMC
- USB host
- UART 1
+/dts-v1/;
+&usdhc2 {
status = "okay";
+&usbotg1 {
dr_mode = "otg";
srp-disable;
hnp-disable;
adp-disable;
status = "okay";
+&iomuxc {
fsl,pins = <
0x17059
memory {
chosen {
+&fec1 {
phy-mode = "rmii";
status = "okay";
mdio1: mdio1 {
#size-cells = <0>;
reg = <1>;
+&fec2 {
phy-mode = "rmii";
status = "okay";
mdio2: mdio2 {
#size-cells = <0>;
reg = <2>;
+&gpmi {
nand-on-flash-bbt;
#size-cells = <1>;
partition@0 {
label = "uboot";
partition@400000 {
partition@500000 {
label = "root";
+&i2c1 {
status = "okay";
+&i2c2 {
status = "okay";
eeprom@50 {
reg = <0x50>;
+&pwm1 {
#pwm-cells = <3>;
status = "okay";
+&uart1 {
status = "okay";
+&usdhc1 {
bus-width = <0x4>;
no-1-8-v;
status = "okay";
+&usdhc2 {
bus-width = <8>;
no-1-8-v;
non-removable;
+&iomuxc {
fsl,pins = <
0x1b0b0
0X1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x1b0b0
0X1b0b0
0x1b0b0
0x1b0b0
0x1b0b0
fsl,pins = <
0x0b0b1
0x0b0b1
0x0b0b1
0x0b0b1
fsl,pins = <
0x4001b8b0
0x4001b8b0
fsl,pins = <
0x1b8b0
0x1b8b0
fsl,pins = <
0x4001b8b0
0x4001b8b0
fsl,pins = <
0x1b8b0
0x1b8b0
fsl,pins = <
0x1b0b1
fsl,pins = <
fsl,pins = <
0x17059
0x10059
0x17059
0x17059
0x17059
0x17059
0x17059
fsl,pins = <
0x170f9
0x100f9
0x170f9
0x170f9
0x170f9
0x170f9
0x170f9
0x170f9
0x170f9
0x170f9
select MX6ULL
select DM
select DM_ETH
select DM_GPIO
select DM_I2C
select DM_MMC
select DM_SERIAL
select DM_THERMAL
select SUPPORT_SPL
- config TARGET_DHCOMIMX6 bool "dh_imx6" select BOARD_EARLY_INIT_F
+config SYS_BOARD
default "dart_6ul"
+config SYS_VENDOR
default "variscite"
default "dart_6ul"
- $ make mrproper
- $ make
SW2 -> 0
+sync
SW2 -> 1
I haven't checked it myself without the definitions in board file. Thanks, I will check that.
+*)CCM_BASE_ADDR;
* 100M = 400M / 4
(3 <<
PAD_CTL_SRE_FAST)
PAD_CTL_DSE_48ohm |
PAD_CTL_ODE)
DM_ETH is enabled, but I will adapt with static pad definitions here in board file.
Thanks, Parthiban N
Regards, Peng.
if (fec_id == 0)
else
int ret = 0;
- IMX_FEC_BASE);
return ret;
*)IOMUXC_BASE_ADDR;
int ret;
if (fec_id == 0) {
} else {
if (ret)
return ret;
enable_enet_clk(1);
select
setup_gpmi_nand();
.dsize = 0,
.cs_density = 20,
.ncs = 1,
.cs1_mirror = 0,
.rtt_wr = 2,
.mem_speed = 800,
.density = 4,
.width = 16,
.banks = 8,
.rowaddr = 15,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
*)CCM_BASE_ADDR;
&mx6_grp_ioregs);
.max_bus_width = 4,
.max_bus_width = 8,
+#endif +};
return 1;
int i, ret;
switch (i) {
case 0:
break;
case 1:
break;
default:
supporting\n",
i + 1);
if (ret) {
dev %d\n", i);
return ret;
arch_cpu_init();
ccgr_init();
timer_init();
setup_iomux_uart();
spl_dram_init();
+#define ENV_MMC \
"fitpart=1\0" \
"bootdelay=3\0" \
"silent=1\0" \
+${fit_addr}\0" \
ENV_MMC
func(MMC, mmc, 0) \
func(MMC, mmc, 1) \
2.17.2
Peng Fan
