[U-Boot] BUG: bootz/bootm command mandates a fdt blob
Hello Simon, This mail is addressed to you as the FDT support was added by you. I am not sure who else to address it to.
I find that if CONFIG_OF_LIBFDT is defined then the user is forced to provide a FDT blob. In most of the cases it makes sense. However, this removes the ability to boot older linux (non FDT). For example, I was looking at the Hardkernel Odroid kernels for the U2/U3, and they are 3.8 based. Of course newer kernels 3.17 work. For users to use the same boot loader for 3.8 and for 3.17, they cannot use the mainline uboot.
I was wondering if teh third argument to bootz/bootm etc could also take the route of initrd (optional if - is specified) could be implemented.
The fix seems to be trivial (or so I think), in file common/image-fdt.c, but wanted to know your comments on this. Also the command help (for bootz etc) states that if the 3rd argument is not passed, then the bd_info struct is passed, and I do not see it being passed in the code anywhere. In the absence of the third parameter, it just gives a "No fdt found" message.
diff --git a/common/image-fdt.c b/common/image-fdt.c index a39ae1b..e685700 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -243,7 +243,10 @@ int boot_get_fdt(int flag, int argc, char * const argv[], u
if (argc > 2) select = argv[2]; - if (select || genimg_has_config(images)) { + if (select && strcmp(select, "-") == 0) { + debug("## Skipping fdt\n"); + return 0; + } else if (select || genimg_has_config(images)) { #if defined(CONFIG_FIT) if (select) { /*
Regards - Suriyan
Hi Suriyan,
I've hit the same problem myself recently, see the thread titled:
"Booting non devicetree enabled kernels using u-boot build with CONFIG_OF_LIBFDT"
Thanks for working on a fix, as discussed in the earlier thread, requiring a third argument which is '-' will break old boot.scr files and the likes, so a better fix is to:
1) Always try to find an ftd (to keep things like appended ftd-s working) 2) If not found see if there is a third argument, if there is, treat this as a fatal error, abort the bootm (iow behave as before) 3) If there is not a third argument warn and continue as before.
If you could respin your patch to do this, then that would be great.
Regards,
Hans
Regards
- Suriyan
On 20 November 2014 16:04, Hans de Goede hdegoede@redhat.com wrote:
Hi Suriyan,
Just to be clear, I didn't add FDT support, this predates my involvement in U-Boot. I added CONFIG_OF_CONTROL etc. though. Han's solution sounds good to me.
- Always try to find an ftd (to keep things like appended ftd-s working)
- If not found see if there is a third argument, if there is, treat this
Regards,
Hans
Regards
- Suriyan
Hello Simon,
Hi Suriyan,
Sorry about that. In no way was I accusing you :-) I stand corrected though.
CONFIG_OF_LIBFDT"
requiring
likes,
working)
this
Hello Hans/Simon, I have been tracing the code paths and see that function bootm_find_fdt() is the final fdt prep function. To retain all its previous functionality, but introducing a warning condition if no third argument is present, but go ahead and boot without fdt should keep the peace. The easiest way to achieve this is: (takes care of 2 and 3 above)
diff --git a/common/image-fdt.c b/common/image-fdt.c index a39ae1b..1a02166 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -430,6 +430,10 @@ int boot_get_fdt(int flag, int argc, char * const argv[], u error: *of_flat_tree = NULL; *of_size = 0; + if (argc <= 2) { + debug("Continuing to boot without FDT\n"); + return 0; + } return 1; }
For case 1, is this already handled in the code? I need some more information on this. I did run a 3.17 zImage with an appended dtb and it did boot up, but I am guessing that it is the linux kernel separating the dtb out?
Thanks
- Suriyan
Regards,
Hans
argv[], u
Regards
- Suriyan
On 11/20/2014 08:41 PM, Suriyan Ramasami wrote:
Hello Simon,
Hi Suriyan,
CONFIG_OF_LIBFDT"
requiring
likes,
working)
this
if (argc <= 2) {
} return 1;
Yes it is, so your above patch should do the trick nicely, thanks for working on this.
Can you re-send as a proper patch, with commit message, rather then inline in a mail ? (Please use git send-email if possible).
Regards,
Hans
Hans de Goede
Suriyan Ramasami
