[PATCH 1/2] timer: mtk_timer: initialize the timer before use
The timer being used by this driver may have already been used by first stage bootloader (e.g. ATF/preloader), and it's settings may differ from what this driver is going to use.
This may cause issues, such as inaccurate timer frequency due to incorrect clock divider.
This patch adds the initialization code to avoid them.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/timer/mtk_timer.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/timer/mtk_timer.c b/drivers/timer/mtk_timer.c index 448a76a7e1..f6b97f868c 100644 --- a/drivers/timer/mtk_timer.c +++ b/drivers/timer/mtk_timer.c @@ -61,6 +61,16 @@ static int mtk_timer_probe(struct udevice *dev) if (!uc_priv->clock_rate) return -EINVAL;
+ /* + * Initialize the timer: + * 1. set clock source to system clock with clock divider setting to 1 + * 2. set timer mode to free running + * 3. reset timer counter to 0 then enable the timer + */ + writel(GPT4_CLK_SYS | GPT4_CLK_DIV1, priv->base + MTK_GPT4_CLK); + writel(GPT4_FREERUN | GPT4_CLEAR | GPT4_ENABLE, + priv->base + MTK_GPT4_CTRL); + return 0; }
The input system clock for mt7622 timer is 10MHz and can be retrieved through the clk driver.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/arm/dts/mt7622.dtsi | 8 +------- 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/arch/arm/dts/mt7622.dtsi b/arch/arm/dts/mt7622.dtsi index d888545809..5c2e0251de 100644 --- a/arch/arm/dts/mt7622.dtsi +++ b/arch/arm/dts/mt7622.dtsi @@ -71,16 +71,10 @@ compatible = "mediatek,timer"; reg = <0x10004000 0x80>; interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_LOW>; - clocks = <&system_clk>; + clocks = <&infracfg CLK_INFRA_APXGPT_PD>; clock-names = "system-clk"; };
- system_clk: dummy13m { - compatible = "fixed-clock"; - clock-frequency = <13000000>; - #clock-cells = <0>; - }; - infracfg: infracfg@10000000 { compatible = "mediatek,mt7622-infracfg", "syscon";
- writel(GPT4_CLK_SYS | GPT4_CLK_DIV1, priv->base + MTK_GPT4_CLK);
- writel(GPT4_FREERUN | GPT4_CLEAR | GPT4_ENABLE,
GPT4_FREERUN is defined as GENMASK(5,4) while in the Linux kernel it has the value of 3. Can you explain where this difference comes from?
Regards, Matthias
-- 2.17.1
GENMASK(5,4) == 3 << 4, which is exactly the same as what's being used in kernel:
#define GPT_CTRL_OP(val) (((val) & 0x3) << 4) #define GPT_CTRL_OP_FREERUN (3)
Regards, Matthias
-- 2.17.1
You are right, sorry my fault: Reviewed-by: Matthias Brugger matthias.bgg@gmail.com
Regards, Matthias
-- 2.17.1
Matthias Brugger
Weijie Gao
