This series depends on the fixes provided for j721e as that series also includes some base support for running the other HS platforms.
Link for dependent series - https://lore.kernel.org/u-boot/20230324-j721e-upstream-hs-v6-0-5aa43a4817a9@...
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- Manorit Chawdhry (3): configs: j721s2: Merge the HS and non-HS defconfigs Kconfig: j721s2: Change K3_MCU_SCRATCHPAD_BASE to non firewalled region configs: j7200: Merge the HS and non-HS defconfigs
MAINTAINERS | 4 - arch/arm/mach-k3/Kconfig | 2 +- configs/j7200_evm_a72_defconfig | 3 +- configs/j7200_evm_r5_defconfig | 1 + configs/j7200_hs_evm_a72_defconfig | 204 ---------------------------------- configs/j7200_hs_evm_r5_defconfig | 170 ----------------------------- configs/j721s2_evm_a72_defconfig | 3 +- configs/j721s2_evm_r5_defconfig | 1 + configs/j721s2_hs_evm_a72_defconfig | 212 ------------------------------------ configs/j721s2_hs_evm_r5_defconfig | 175 ----------------------------- 10 files changed, 7 insertions(+), 768 deletions(-) --- base-commit: 4ab3044bb08dbfebcccdf5aa091492a0cd7c6af6 change-id: 20230405-j721s2-hs-evm-upstream-bad9551303cd
K3 devices have runtime type board detection. Make the default defconfig include the secure configuration. Then remove the HS specific config.
Non-HS devices will continue to boot due to runtime device type detection. If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS devices these can be ignored.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- MAINTAINERS | 2 - configs/j721s2_evm_a72_defconfig | 3 +- configs/j721s2_evm_r5_defconfig | 1 + configs/j721s2_hs_evm_a72_defconfig | 212 ------------------------------------ configs/j721s2_hs_evm_r5_defconfig | 175 ----------------------------- 5 files changed, 3 insertions(+), 390 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 84a21da6302b..c0bde1a0ac4a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1463,8 +1463,6 @@ F: configs/am65x_hs_evm_r5_defconfig F: configs/am65x_hs_evm_a53_defconfig F: configs/j7200_hs_evm_a72_defconfig F: configs/j7200_hs_evm_r5_defconfig -F: configs/j721s2_hs_evm_a72_defconfig -F: configs/j721s2_hs_evm_r5_defconfig
TPM DRIVERS M: Ilias Apalodimas ilias.apalodimas@linaro.org diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index eae4c109e55c..44f22d587438 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y @@ -30,7 +31,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 343e3c16305f..7416ba2d38d7 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x10000 CONFIG_SPL_GPIO=y diff --git a/configs/j721s2_hs_evm_a72_defconfig b/configs/j721s2_hs_evm_a72_defconfig deleted file mode 100644 index dff12ab82b81..000000000000 --- a/configs/j721s2_hs_evm_a72_defconfig +++ /dev/null @@ -1,212 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_J721S2=y -CONFIG_TARGET_J721S2_A72_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j721s2-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -CONFIG_DISTRO_DEFAULTS=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_THERMAL=y -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_UFS=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_CCF=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_DM_I2C_GPIO=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_MT35XU=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_MULTIPLEXER=y -CONFIG_MUX_MMIO=y -CONFIG_PHY_TI_DP83867=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_SPL_PHY=y -CONFIG_PHY_CADENCE_TORRENT=y -CONFIG_PHY_J721E_WIZ=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_REMOTEPROC_TI_K3_DSP=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_RESET_TI_SCI=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_DM_THERMAL=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_USB_CDNS3_HOST=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 -CONFIG_UFS=y -CONFIG_CADENCE_UFS=y -CONFIG_TI_J721E_UFS=y -CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/j721s2_hs_evm_r5_defconfig b/configs/j721s2_hs_evm_r5_defconfig deleted file mode 100644 index c8433a1de950..000000000000 --- a/configs/j721s2_hs_evm_r5_defconfig +++ /dev/null @@ -1,175 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x10000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SOC_K3_J721S2=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_J721S2_R5_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c76000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j721s2-r5-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_SIZE_LIMIT=0x80000 -CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x4000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41c76000 -CONFIG_SPL_BSS_MAX_SIZE=0xa000 -CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_THERMAL=y -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_FS_LOADER=y -CONFIG_SPL_FS_LOADER=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_MT35XU=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_DM_THERMAL=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_PANIC_HANG=y -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
Please rebase this series on top of tree, thanks.
On K3 HS-SE devices all the firewalls are locked by default until sysfw comes up. Rom configures some of the firewall for its usage along with the SRAM for R5 but the PSRAM region is still locked.
The K3 MCU Scratchpad for j721s2 was set to a PSRAM region triggering the firewall exception before sysfw came up. The exception started happening after adding multi dtb support that accesses the scratchpad for reading EEPROM contents.
Old map: ┌─────────────────────────────────────┐ 0x41c00000 │ SPL │ ├─────────────────────────────────────┤ 0x41c61f20 (approx) │ STACK │ ├─────────────────────────────────────┤ 0x41c65f20 │ Global data │ │ sizeof(struct global_data) = 0xd8 │ ├─────────────────────────────────────┤ gd->malloc_base = 0x41c66000 │ HEAP │ │ CONFIG_SYS_MALLOC_F_LEN = 0x10000 │ ├─────────────────────────────────────┤ CONFIG_SPL_BSS_START_ADDR │ SPL BSS │ (0x41c76000) │ CONFIG_SPL_BSS_MAX_SIZE = 0xA000 │ ├─────────────────────────────────────┤ (0x41c80000) │ DM DATA │ ├─────────────────────────────────────┤ (0x41c84130) (approx) │ EMPTY │ └─────────────────────────────────────┘ CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX (0x41cffbfc)
New map: ┌─────────────────────────────────────┐ 0x41c00000 │ SPL │ ├─────────────────────────────────────┤ 0x41c61f20 (approx) │ STACK │ ├─────────────────────────────────────┤ 0x41c65f20 │ Global data │ │ sizeof(struct global_data) = 0xd8 │ ├─────────────────────────────────────┤ gd->malloc_base = 0x41c66000 │ HEAP │ │ CONFIG_SYS_MALLOC_F_LEN = 0x10000 │ ├─────────────────────────────────────┤ CONFIG_SPL_BSS_START_ADDR │ SPL BSS │ (0x41c76000) │ CONFIG_SPL_BSS_MAX_SIZE = 0xA000 │ ├─────────────────────────────────────┤ (0x41c80000) │ DM DATA │ ├─────────────────────────────────────┤ (0x41c84130) (approx) │ EMPTY │ ├─────────────────────────────────────┤ SYS_K3_MCU_SCRATCHPAD_BASE │ SCRATCHPAD │ (0x41cff9fc) │ SYS_K3_MCU_SCRATCHPAD_SIZE = 0x200 │ └─────────────────────────────────────┘ CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX (0x41cffbfc)
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/mach-k3/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index bae0a827c29f..bf1c3c51a41c 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -52,7 +52,7 @@ config SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE config SYS_K3_MCU_SCRATCHPAD_BASE hex default 0x40280000 if SOC_K3_AM654 - default 0x40280000 if SOC_K3_J721S2 + default 0x41cff9fc if SOC_K3_J721S2 default 0x41cff9fc if SOC_K3_J721E help Describes the base address of MCU Scratchpad RAM.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- MAINTAINERS | 2 - configs/j7200_evm_a72_defconfig | 3 +- configs/j7200_evm_r5_defconfig | 1 + configs/j7200_hs_evm_a72_defconfig | 204 ------------------------------------- configs/j7200_hs_evm_r5_defconfig | 170 ------------------------------- 5 files changed, 3 insertions(+), 377 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index c0bde1a0ac4a..d5e07e244ad7 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1461,8 +1461,6 @@ F: configs/k2g_hs_evm_defconfig F: configs/k2l_hs_evm_defconfig F: configs/am65x_hs_evm_r5_defconfig F: configs/am65x_hs_evm_a53_defconfig -F: configs/j7200_hs_evm_a72_defconfig -F: configs/j7200_hs_evm_r5_defconfig
TPM DRIVERS M: Ilias Apalodimas ilias.apalodimas@linaro.org diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 74903138e5ed..e33b3f17cbb1 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y @@ -32,7 +33,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 00ec48b83b78..dd4454943c36 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x70000 CONFIG_SPL_GPIO=y diff --git a/configs/j7200_hs_evm_a72_defconfig b/configs/j7200_hs_evm_a72_defconfig deleted file mode 100644 index e4f3c462ca5e..000000000000 --- a/configs/j7200_hs_evm_a72_defconfig +++ /dev/null @@ -1,204 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_J721E=y -CONFIG_TARGET_J7200_A72_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -CONFIG_DISTRO_DEFAULTS=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_UFS=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_CCF=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_DM_I2C_GPIO=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_MULTIPLEXER=y -CONFIG_MUX_MMIO=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_SPL_PHY=y -CONFIG_PHY_CADENCE_TORRENT=y -CONFIG_PHY_J721E_WIZ=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_RESET_TI_SCI=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_USB_CDNS3_HOST=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 -CONFIG_UFS=y -CONFIG_CADENCE_UFS=y -CONFIG_TI_J721E_UFS=y -CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/j7200_hs_evm_r5_defconfig b/configs/j7200_hs_evm_r5_defconfig deleted file mode 100644 index 94a6523f06c2..000000000000 --- a/configs/j7200_hs_evm_r5_defconfig +++ /dev/null @@ -1,170 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x70000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SOC_K3_J721E=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_J7200_R5_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-r5-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41cf5bfc -CONFIG_SPL_BSS_MAX_SIZE=0xa000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_FS_LOADER=y -CONFIG_SPL_FS_LOADER=y -CONFIG_K3_AVS0=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_TPS65941=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_TPS65941=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
Manorit Chawdhry m-chawdhry@ti.com writes:
All patches look good to me.
Reviewed-by: Kamlesh Gurudasani kamlesh@ti.com
Kamlesh Gurudasani
Manorit Chawdhry
