[U-Boot] [PATCH] zynqmp: Add support for R5 sw loading
Add support for loading sw for R5 with enabling for zynqmp.
Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com ---
arch/arm/cpu/armv8/zynqmp/Makefile | 1 + arch/arm/cpu/armv8/zynqmp/mp.c | 242 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynqmp/hardware.h | 43 ++++- include/configs/xilinx_zynqmp.h | 2 + 4 files changed, 285 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv8/zynqmp/mp.c
diff --git a/arch/arm/cpu/armv8/zynqmp/Makefile b/arch/arm/cpu/armv8/zynqmp/Makefile index a997e045bd0a..efab5eabc97b 100644 --- a/arch/arm/cpu/armv8/zynqmp/Makefile +++ b/arch/arm/cpu/armv8/zynqmp/Makefile @@ -7,3 +7,4 @@
obj-y += clk.o obj-y += cpu.o +obj-$(CONFIG_MP) += mp.o diff --git a/arch/arm/cpu/armv8/zynqmp/mp.c b/arch/arm/cpu/armv8/zynqmp/mp.c new file mode 100644 index 000000000000..17e32a7b7ce8 --- /dev/null +++ b/arch/arm/cpu/armv8/zynqmp/mp.c @@ -0,0 +1,242 @@ +/* + * (C) Copyright 2014 - 2015 Xilinx, Inc. + * Michal Simek michal.simek@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> + +#define LOCK 0 +#define SPLIT 1 + +#define HALT 0 +#define RELEASE 1 + +#define ZYNQMP_BOOTADDR_HIGH_MASK 0xFFFFFFFF +#define ZYNQMP_R5_HIVEC_ADDR 0xFFFF0000 +#define ZYNQMP_R5_LOVEC_ADDR 0x0 +#define ZYNQMP_RPU_CFG_CPU_HALT_MASK 0x01 +#define ZYNQMP_RPU_CFG_HIVEC_MASK 0x04 +#define ZYNQMP_RPU_GLBL_CTRL_SPLIT_LOCK_MASK 0x08 +#define ZYNQMP_RPU_GLBL_CTRL_TCM_COMB_MASK 0x40 +#define ZYNQMP_RPU_GLBL_CTRL_SLCLAMP_MASK 0x10 + +#define ZYNQMP_CRLAPB_RST_LPD_AMBA_RST_MASK 0x04 +#define ZYNQMP_CRLAPB_RST_LPD_R50_RST_MASK 0x01 +#define ZYNQMP_CRLAPB_RST_LPD_R51_RST_MASK 0x02 +#define ZYNQMP_CRLAPB_CPU_R5_CTRL_CLKACT_MASK 0x1000000 + +#define ZYNQMP_TCM_START_ADDRESS 0xFFE00000 +#define ZYNQMP_TCM_BOTH_SIZE 0x40000 + +#define ZYNQMP_CORE_APU0 0 +#define ZYNQMP_CORE_APU3 3 + +#define ZYNQMP_MAX_CORES 6 + +int is_core_valid(unsigned int core) +{ + if (core < ZYNQMP_MAX_CORES) + return 1; + + return 0; +} + +int cpu_reset(int nr) +{ + puts("Feature is not implemented.\n"); + return 0; +} + +static void set_r5_halt_mode(u8 halt, u8 mode) +{ + u32 tmp; + + tmp = readl(&rpu_base->rpu0_cfg); + if (halt == HALT) + tmp &= ~ZYNQMP_RPU_CFG_CPU_HALT_MASK; + else + tmp |= ZYNQMP_RPU_CFG_CPU_HALT_MASK; + writel(tmp, &rpu_base->rpu0_cfg); + + if (mode == LOCK) { + tmp = readl(&rpu_base->rpu1_cfg); + if (halt == HALT) + tmp &= ~ZYNQMP_RPU_CFG_CPU_HALT_MASK; + else + tmp |= ZYNQMP_RPU_CFG_CPU_HALT_MASK; + writel(tmp, &rpu_base->rpu1_cfg); + } +} + +static void set_r5_tcm_mode(u8 mode) +{ + u32 tmp; + + tmp = readl(&rpu_base->rpu_glbl_ctrl); + if (mode == LOCK) { + tmp &= ~ZYNQMP_RPU_GLBL_CTRL_SPLIT_LOCK_MASK; + tmp |= ZYNQMP_RPU_GLBL_CTRL_TCM_COMB_MASK | + ZYNQMP_RPU_GLBL_CTRL_SLCLAMP_MASK; + } else { + tmp |= ZYNQMP_RPU_GLBL_CTRL_SPLIT_LOCK_MASK; + tmp &= ~(ZYNQMP_RPU_GLBL_CTRL_TCM_COMB_MASK | + ZYNQMP_RPU_GLBL_CTRL_SLCLAMP_MASK); + } + + writel(tmp, &rpu_base->rpu_glbl_ctrl); +} + +static void set_r5_reset(u8 mode) +{ + u32 tmp; + + tmp = readl(&crlapb_base->rst_lpd_top); + tmp |= (ZYNQMP_CRLAPB_RST_LPD_AMBA_RST_MASK | + ZYNQMP_CRLAPB_RST_LPD_R50_RST_MASK); + + if (mode == LOCK) + tmp |= ZYNQMP_CRLAPB_RST_LPD_R51_RST_MASK; + + writel(tmp, &crlapb_base->rst_lpd_top); +} + +static void release_r5_reset(u8 mode) +{ + u32 tmp; + + tmp = readl(&crlapb_base->rst_lpd_top); + tmp &= ~(ZYNQMP_CRLAPB_RST_LPD_AMBA_RST_MASK | + ZYNQMP_CRLAPB_RST_LPD_R50_RST_MASK); + + if (mode == LOCK) + tmp &= ~ZYNQMP_CRLAPB_RST_LPD_R51_RST_MASK; + + writel(tmp, &crlapb_base->rst_lpd_top); +} + +static void enable_clock_r5(void) +{ + u32 tmp; + + tmp = readl(&crlapb_base->cpu_r5_ctrl); + tmp |= ZYNQMP_CRLAPB_CPU_R5_CTRL_CLKACT_MASK; + writel(tmp, &crlapb_base->cpu_r5_ctrl); + + /* Give some delay for clock + * to propogate */ + udelay(0x500); +} + +int cpu_disable(int nr) +{ + if (nr >= ZYNQMP_CORE_APU0 && nr <= ZYNQMP_CORE_APU3) { + u32 val = readl(&crfapb_base->rst_fpd_apu); + val |= 1 << nr; + writel(val, &crfapb_base->rst_fpd_apu); + } else { + set_r5_reset(LOCK); + } + + return 0; +} + +int cpu_status(int nr) +{ + if (nr >= ZYNQMP_CORE_APU0 && nr <= ZYNQMP_CORE_APU3) { + u32 addr_low = readl(((u8 *)&apu_base->rvbar_addr0_l) + nr * 8); + u32 addr_high = readl(((u8 *)&apu_base->rvbar_addr0_h) + + nr * 8); + u32 val = readl(&crfapb_base->rst_fpd_apu); + val &= 1 << nr; + printf("APU CPU%d %s - starting address HI: %x, LOW: %x\n", + nr, val ? "OFF" : "ON" , addr_high, addr_low); + } else { + u32 val = readl(&crlapb_base->rst_lpd_top); + val &= 1 << (nr - 4); + printf("RPU CPU%d %s\n", nr - 4, val ? "OFF" : "ON"); + } + + return 0; +} + +static void set_r5_start(u8 high) +{ + u32 tmp; + + tmp = readl(&rpu_base->rpu0_cfg); + if (high) + tmp |= ZYNQMP_RPU_CFG_HIVEC_MASK; + else + tmp &= ~ZYNQMP_RPU_CFG_HIVEC_MASK; + writel(tmp, &rpu_base->rpu0_cfg); + + tmp = readl(&rpu_base->rpu1_cfg); + if (high) + tmp |= ZYNQMP_RPU_CFG_HIVEC_MASK; + else + tmp &= ~ZYNQMP_RPU_CFG_HIVEC_MASK; + writel(tmp, &rpu_base->rpu1_cfg); +} + +int cpu_release(int nr, int argc, char * const argv[]) +{ + if (nr >= ZYNQMP_CORE_APU0 && nr <= ZYNQMP_CORE_APU3) { + u64 boot_addr = simple_strtoull(argv[0], NULL, 16); + /* HIGH */ + writel((u32)(boot_addr >> 32), + ((u8 *)&apu_base->rvbar_addr0_h) + nr * 8); + /* LOW */ + writel((u32)(boot_addr & ZYNQMP_BOOTADDR_HIGH_MASK), + ((u8 *)&apu_base->rvbar_addr0_l) + nr * 8); + + u32 val = readl(&crfapb_base->rst_fpd_apu); + val &= ~(1 << nr); + writel(val, &crfapb_base->rst_fpd_apu); + } else { + if (argc != 2) { + printf("Invalid number of arguments to release.\n"); + printf("<addr> <mode>-Start addr lockstep or split\n"); + return 1; + } + + u32 boot_addr = simple_strtoul(argv[0], NULL, 16); + if (!(boot_addr == ZYNQMP_R5_LOVEC_ADDR || + boot_addr == ZYNQMP_R5_HIVEC_ADDR)) { + printf("Invalid starting address 0x%x\n", boot_addr); + printf("0 or 0xffff0000 are permitted\n"); + return 1; + } + + if (!strncmp(argv[1], "lockstep", 8)) { + printf("R5 lockstep mode\n"); + set_r5_tcm_mode(LOCK); + set_r5_halt_mode(HALT, LOCK); + + if (boot_addr == 0) + set_r5_start(0); + else + set_r5_start(1); + + enable_clock_r5(); + release_r5_reset(LOCK); + set_r5_halt_mode(RELEASE, LOCK); + } else if (!strncmp(argv[1], "split", 5)) { + printf("R5 split mode\n"); + set_r5_tcm_mode(SPLIT); + set_r5_halt_mode(HALT, SPLIT); + enable_clock_r5(); + release_r5_reset(SPLIT); + set_r5_halt_mode(RELEASE, SPLIT); + } else { + printf("Unsupported mode\n"); + return 1; + } + } + + return 0; +} diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 37f9a7d0719e..c9dc49d78317 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -24,11 +24,15 @@ #define ZYNQMP_CRL_APB_TIMESTAMP_REF_CTRL_CLKACT 0x1000000
struct crlapb_regs { - u32 reserved0[74]; + u32 reserved0[36]; + u32 cpu_r5_ctrl; /* 0x90 */ + u32 reserved1[37]; u32 timestamp_ref_ctrl; /* 0x128 */ - u32 reserved0_1[53]; + u32 reserved2[53]; u32 boot_mode; /* 0x200 */ - u32 reserved1[26]; + u32 reserved3[14]; + u32 rst_lpd_top; /* 0x23C */ + u32 reserved4[26]; };
#define crlapb_base ((struct crlapb_regs *)ZYNQMP_CRL_APB_BASEADDR) @@ -51,6 +55,39 @@ struct iou_scntr { #define EMMC_MODE 0x00000006 #define JTAG_MODE 0x00000000
+#define ZYNQMP_RPU_BASEADDR 0xFF9A0000 + +struct rpu_regs { + u32 rpu_glbl_ctrl; + u32 reserved0[63]; + u32 rpu0_cfg; /* 0x100 */ + u32 reserved1[63]; + u32 rpu1_cfg; /* 0x200 */ +}; + +#define rpu_base ((struct rpu_regs *)ZYNQMP_RPU_BASEADDR) + +#define ZYNQMP_CRF_APB_BASEADDR 0xFD1A0000 + +struct crfapb_regs { + u32 reserved0[65]; + u32 rst_fpd_apu; /* 0x104 */ + u32 reserved1; +}; + +#define crfapb_base ((struct crfapb_regs *)ZYNQMP_CRF_APB_BASEADDR) + +#define ZYNQMP_APU_BASEADDR 0xFD5C0000 + +struct apu_regs { + u32 reserved0[16]; + u32 rvbar_addr0_l; /* 0x40 */ + u32 rvbar_addr0_h; /* 0x44 */ + u32 reserved1[20]; +}; + +#define apu_base ((struct apu_regs *)ZYNQMP_APU_BASEADDR) + /* Board version value */ #define ZYNQMP_CSU_VERSION_SILICON 0x0 #define ZYNQMP_CSU_VERSION_EP108 0x1 diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 4c48f9449f02..6c608abfb9bb 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -71,6 +71,8 @@ #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MEMORY #define CONFIG_DOS_PARTITION +#define CONFIG_CMD_ELF +#define CONFIG_MP
/* SPI */ #ifdef CONFIG_ZYNQ_SPI
Michal Simek
