[PULL] u-boot-riscv/master
Hi Tom,
The following changes since commit c9204859bbdb924cda811813c545032971656480:
Merge branch 'master' of git://source.denx.de/u-boot-sh (2021-07-20 19:31:40 -0400)
git@source.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to 219cb173114c9cfaf1dc7fed21281f2c43c88c9f:
board: sifive: unmatched: reset USB hub, PCIe-USB bridge, and ULPI device in SPL (2021-07-21 22:25:15 +0800)
CI result show no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/8344
---------------------------------------------------------------- Vincent Chen (2): board: sifive: unmatched: refine GEMGXL initialized function in SPL board: sifive: unmatched: reset USB hub, PCIe-USB bridge, and ULPI device in SPL
Vitaly Wool (1): riscv: booti: do not force relocation if force_reloc is not set
Zong Li (2): board: sifive: remove the command for setting serial number board: sifive: drop stuff related to unmatched revision 1
arch/riscv/dts/Makefile | 2 +- .../dts/fu740-hifive-unmatched-a00-ddr-rev1.dtsi | 1489 -------------------- .../dts/hifive-unmatched-a00-rev1-u-boot.dtsi | 7 - arch/riscv/dts/hifive-unmatched-a00-rev1.dts | 4 - arch/riscv/lib/image.c | 7 +- .../sifive/unmatched/hifive-platform-i2c-eeprom.c | 23 +- board/sifive/unmatched/spl.c | 114 +- configs/sifive_unmatched_defconfig | 4 - 8 files changed, 81 insertions(+), 1569 deletions(-) delete mode 100644 arch/riscv/dts/fu740-hifive-unmatched-a00-ddr-rev1.dtsi delete mode 100644 arch/riscv/dts/hifive-unmatched-a00-rev1-u-boot.dtsi delete mode 100644 arch/riscv/dts/hifive-unmatched-a00-rev1.dts
Best regards, Leo
On Thu, Jul 22, 2021 at 10:15:10AM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
