[U-Boot] [PATCH] mx53loco: Fix PMIC name
commit c73368150 (pmic: Extend PMIC framework to support multiple instances of PMIC devices) has incorrectly passed the PMIC name under the FSL PMIC case.
Fix that by passing "FSL_PMIC" as the parameter of pmic_get.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx53loco/mx53loco.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 81c511c..2c8cb7a 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -374,7 +374,7 @@ static int power_init(void) if (retval) return retval;
- p = pmic_get("DIALOG_PMIC"); + p = pmic_get("FSL_PMIC"); if (!p) return -ENODEV;
if (!p) return -ENODEV;p = pmic_get("FSL_PMIC");
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
On Tue, Dec 11, 2012 at 10:36 AM, Fabio Estevam fabio.estevam@freescale.com wrote:
-- 1.7.9.5
Hi Fabio,
It looks like we need one more fixup after commit c73368150 on the first run/older (non R, Dialog, bug wired extra Capacitor) version of this board.. Do you happen to have any in your lab?
U-Boot 2013.01-rc2-dirty (Dec 20 2012 - 15:55:01)
Board: MX53 LOCO I2C: ready DRAM: 1 GiB pmic_alloc: No available memory for allocation! pmic_init: POWER allocation error! CPU: Freescale i.MX53 family rev2.0 at 800 MHz Reset cause: POR MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment
(and it just keeps on resetting)
It looks to be failing after calloc... http://git.denx.de/?p=u-boot.git;a=blob;f=drivers/power/power_core.c#l100
100 p = calloc(sizeof(*p), 1); 101 if (!p) { 102 printf("%s: No available memory for allocation!\n", __func__); 103 return NULL; 104 }
Regards,
Hi Robert,
On Thu, Dec 20, 2012 at 8:04 PM, Robert Nelson robertcnelson@gmail.com wrote:
Hi Fabio,
Thanks for reporting this issue. I will try to get access to mx53qsb dialog next week to investigate this further.
Regards,
Fabio Estevam
Robert,
Hi Fabio,
I can reproduce this issue using top of head U-boot tree.
It seems indeed to be caused by:
Author: Łukasz Majewski l.majewski@samsung.com Date: Tue Nov 13 03:21:55 2012 +0000 commit c7336815078ff3745e3130aeff35991e3e98e61e Author: Łukasz Majewski l.majewski@samsung.com Date: Tue Nov 13 03:21:55 2012 +0000
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power".
Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de
I am Ccing Lukasz/Stefano in case they have any suggestion.
With the new PMIC framework: is it safe to call the PMIC API from board_init function?
Regards,
Fabio Estevam
Calling it from board_late_init fixes the issue for me.
Will send the patch soon.
Regards,
Fabio Estevam
Robert,
Can you try the patch below?
board/freescale/mx53loco/mx53loco.c | 10 ++++++++-- include/configs/mx53loco.h | 1 + 2 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 2c8cb7a..63a4f8b 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -462,12 +462,18 @@ int board_init(void)
mxc_set_sata_internal_clock(); setup_iomux_i2c(); + + lcd_enable(); + + return 0; +} + +int board_late_init(void) +{ if (!power_init()) clock_1GHz(); print_cpuinfo();
- lcd_enable(); - return 0; }
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index e30502b..c4181bd 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -39,6 +39,7 @@ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT #define CONFIG_MXC_GPIO #define CONFIG_REVISION_TAG
Hi Fabio,
On Wed, Dec 26, 2012 at 9:21 AM, Fabio Estevam festevam@gmail.com wrote:
Robert,
Thanks for taking a look at this..
lcd_enable();
lcd_enable();
Ah, i was missing this when heading down the "board_late_init" road on friday..
-- 1.7.9.5
It boots now, but I get resets now:
U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 13:13:28)
Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.1 at 1000 MHz Reset cause: WDOG Net: FEC Warning: FEC using MAC address from net device
Interesting, I'm still only getting this far on the old Dialog board..
U-Boot 2013.01-rc2-00173-gd781d95-dirty (Dec 26 2012 - 09:42:43)
I'm going to start printf'ing: http://git.denx.de/?p=u-boot.git;a=blob;f=drivers/power/power_dialog.c as we aren't getting the memory error, so it should be atleast past that...
Hit any key to stop autoboot: 0 data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<aff72220>] lr : [<aff721fc>] sp : af565e20 ip : af566918 fp : 00000000 r10: 00000003 r9 : affabb5b r8 : af565f58 r7 : 00000000 r6 : 36747fff r5 : af5668e8 r4 : 36747fff r3 : af5668ec r2 : af5668eb r1 : 00000000 r0 : af5668e8 Flags: NzcV IRQs off FIQs off Mode SVC_32 Resetting CPU ...
resetting ...
I've reverted this just to double check (no change for me...): http://git.denx.de/?p=u-boot.git;a=commit;h=28e5ac2d974547bde0c72aa0c1d66fd2...
but it looks like a separate issue?
Regards,
On Wed, Dec 26, 2012 at 1:51 PM, Robert Nelson robertcnelson@gmail.com wrote:
I tested with 2 mx53loco boards here: one with FSL PMIC and one with Dialog.
I recall we had 2 versions of boards with Dialog PMIC, but at least with the one I have here it boots fine now after applying the patch I just sent.
If you have any news, just let us know.
Thanks,
Fabio Estevam
Okay, good to hear it works with the Dialog PMIC you have, as that should cover a majority of the Dialog based boards customers actually have. As the one I have here was one of the very first ones and i know something changed later in production...
Regards,
On Wed, Dec 26, 2012 at 2:04 PM, Robert Nelson robertcnelson@gmail.com wrote:
Yes, but not happy to see a regression with your board and also the resets that started to happen now.
Which toolchain did you use? I am using gcc 4.6.3. If you have a chance to try the same toolchain to make sure we got the same results, that would be nice.
Regards,
Fabio Estevam
I'll keep debugging it here, did reverting this commit, help with the resets? http://git.denx.de/?p=u-boot.git;a=commit;h=28e5ac2d974547bde0c72aa0c1d66fd2...
That build was with Linaro's 4.7.1 2012.04 release, from: https://launchpad.net/linaro-toolchain-binaries/
./arm-linux-gnueabi-gcc --version arm-linux-gnueabi-gcc (crosstool-NG linaro-1.13.1-2012.04-20120426 - Linaro GCC 2012.04) 4.7.1 20120402 (prerelease)
Regards,
On Wed, Dec 26, 2012 at 3:08 PM, Robert Nelson robertcnelson@gmail.com wrote:
Tried reverting it and still see the data-aborts.
I am also testing on my mx53loco board with the mc34708 pmic and I see that it hangs on boot about 10% of the attempts: U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 15:15:27)
This did not happen prior to commit c73368150 (pmic: Extend PMIC framework to support multiple instances of PMIC devices).
Regards,
Fabio Estevam
Okay, now we are on the same page, upgraded to: "arm-linux-gnueabihf-gcc (crosstool-NG linaro-1.13.1-4.7-2012.12-20121214 - Linaro GCC 2012.12) 4.7.3 20121205 (prerelease)"..
With your Dialog patch, it is properly setting 1Ghz, and just keeps rebooting.. :)
U-Boot 2013.01-rc2-00173-ga0d04f3 (Dec 26 2012 - 11:47:34)
Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.0 at 1000 MHz Reset cause: WDOG Net: FEC Warning: FEC using MAC address from net device
data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<aff72250>] lr : [<aff72228>] sp : af565d68 ip : fffffff4 fp : 00000000 r10: 00000003 r9 : affab8d9 r8 : af565f58 r7 : 00000000 r6 : e5bc345d r5 : af6df330 r4 : e5bc345d r3 : af6df334 r2 : af6df333 r1 : 00000000 r0 : af6df330 Flags: nzCv IRQs off FIQs off Mode SVC_32
Resetting CPU ... resetting ...
Reset cause: WDOG
Regards,
On Wed, Dec 26, 2012 at 11:51 AM, Robert Nelson robertcnelson@gmail.com wrote:
Okay success on another bisect run to find what was causing the Data Abort with linaro's gcc toolchain.. gcc version 4.7.3 20121205 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2012.12-20121214 - Linaro GCC 2012.12)
Reverting, Troy's last 4 imximage changes:
ab857f2613be39274d0870768720067ff9d859c0 (imximage: make set_imx_hdr_v1/v2 easier to read) ad0826dcd81ba6cf4cc93a4ca8337e1bc676c238 (imximage: change parameters to set_imx_hdr) 243319825fa6e79885d57b6b78e72f3fe10ef69c (imximage: delay setting of image size) 348ca8efb79652d2b259fbd0ed6d317a77a8cbb9 (imximage: fix size of image to load.) (this was the first bad bisect, the previous 3 are needed for a clean revert)
Along with Fabio's "mx53loco: Call PMIC related functions from board_late_init()"
The Dialog based mx53loco is no operating correctly with linaro's toolchain...
U-Boot 2013.01-rc2-00176-gbc67175-dirty (Jan 02 2013 - 12:14:51)
In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.0 at 1000 MHz Reset cause: POR Net: FEC Warning: FEC using MAC address from net device
Hit any key to stop autoboot: 0 mmc0 is current device ** Unrecognized filesystem type ** ** Unrecognized filesystem type ** Booting from net ... BOOTP broadcast 1
Regards,
Thanks for bisecting, Robert.
Troy/Stefano,
Any suggestions about this? It would be really nice if we could keep mx53loco functional when using gcc 4.6.2.
Regards,
Fabio Estevam
On 1/2/2013 11:33 AM, Fabio Estevam wrote:
Thanks for bisecting, Robert. Troy/Stefano, Any suggestions about this? It would be really nice if we could keep mx53loco functional when using gcc 4.6.2. Regards, Fabio Estevam
Could you see if this patch makes any difference? It still needs cleaned up some before mainline [PATCH V4 01/11] imximage: mx53 needs transfer length a multiple of 512
diff --git a/tools/imximage.c b/tools/imximage.c index 63f88b6..7e54e97 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -494,6 +494,8 @@ static void imximage_print_header(const void *ptr) } }
+#define ALIGN(a, b) (((a) + (b) - 1) & ~((b) - 1)) + static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd, struct mkimage_params *params) { @@ -515,7 +517,13 @@ static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd,
/* Set the imx header */ (*set_imx_hdr)(imxhdr, dcd_len, params->ep, imxhdr->flash_offset); - *header_size_ptr = sbuf->st_size + imxhdr->flash_offset; + /* + * ROM bug alert + * mx53 only loads 512 byte multiples. + * The remaining fraction of a block bytes would + * not be loaded. + */ + *header_size_ptr = ALIGN(sbuf->st_size + imxhdr->flash_offset, 512); }
int imximage_check_params(struct mkimage_params *params) -- 1.7.9.5
On Wed, Jan 2, 2013 at 1:42 PM, Troy Kisky troy.kisky@boundarydevices.com wrote:
diff --git a/tools/imximage.c b/tools/imximage.c index 63f88b6..7e54e97 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -494,6 +494,8 @@ static void imximage_print_header(const void *ptr) } } +#define ALIGN(a, b) (((a) + (b) - 1) & ~((b) - 1))
static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd, struct mkimage_params *params) { @@ -515,7 +517,13 @@ static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd, /* Set the imx header */ (*set_imx_hdr)(imxhdr, dcd_len, params->ep, imxhdr->flash_offset);
* ROM bug alert
* not be loaded.
} int imximage_check_params(struct mkimage_params *params) -- 1.7.9.5
Sweet! Thanks Troy,
That fixes it on my Dialog based mx53loco with linaro's 4.7.3 gcc toolchain...
Regards,
On Wed, Jan 2, 2013 at 5:58 PM, Robert Nelson robertcnelson@gmail.com wrote:
Sweet! Thanks Troy,
Excellent, Troy!
Fixes the issue for me with gcc 4.6.2 as well.
It would be really nice to have this one applied for 2013.01.
Thanks,
Fabio Estevam
Sweet! Thanks Troy,
Excellent, Troy!
Hi all,
the patch was only blocked for Wolfgang's comment regarding the introduced ALIGN() macro. I think the other doubts regarding issues on other Socs (i.e., MX6) can be considered closed as well. IMHO it is enough to rename the macro to ROUND_UP (as Troy have already proposed), and then I will apply to i.MX tree.
Regards, Stefano Babic
Hi Stefano,
On Thu, Jan 3, 2013 at 6:53 AM, Stefano Babic sbabic@denx.de wrote:
Hi all,
I tried using DIV_ROUND_UP definition from common.h and the board does not boot.
I rename it to ROUND, which matches the definition in common.h.
Just sent the patch.
Regards,
Fabio Estevam
Dear Fabio Estevam,
Hi Stefano,
Hi all,
Ugh, why can't the stuff from common.h be used ?
Regards,
Fabio Estevam
Best regards, Marek Vasut
Yes, I tried it initially, but it throws a lot of errors that I am not sure that they can be easily fixed:
.... gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -idirafter /home/fabio/denx/u-boot-imx/include -idirafter /home/fabio/denx/u-boot-imx/include2 -idirafter /home/fabio/denx/u-boot-imx/include -I /home/fabio/denx/u-boot-imx/lib/libfdt -I /home/fabio/denx/u-boot-imx/tools -DCONFIG_SYS_TEXT_BASE=0x77800000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -o imximage.o imximage.c -c make[1]: Leaving directory `/home/fabio/denx/u-boot-imx/arch/arm/cpu/armv7' make[2]: Entering directory `/home/fabio/denx/u-boot-imx/tools/kernel-doc' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/fabio/denx/u-boot-imx/tools/kernel-doc' In file included from /home/fabio/denx/u-boot-imx/include/common.h:39:0, from imximage.c:34: /home/fabio/denx/u-boot-imx/include/linux/bitops.h: In function ‘generic_set_bit’: /home/fabio/denx/u-boot-imx/include/linux/bitops.h:141:23: error: ‘BITS_PER_LONG’ undeclared (first use in this function) /home/fabio/denx/u-boot-imx/include/linux/bitops.h:141:23: note: each undeclared identifier is reported only once for each function it appears in /home/fabio/denx/u-boot-imx/include/linux/bitops.h: In function ‘generic_clear_bit’: /home/fabio/denx/u-boot-imx/include/linux/bitops.h:149:23: error: ‘BITS_PER_LONG’ undeclared (first use in this function) In file included from /home/fabio/denx/u-boot-imx/include/common.h:174:0, from imximage.c:34: /home/fabio/denx/u-boot-imx/include/asm/global_data.h: At top level: /home/fabio/denx/u-boot-imx/include/asm/global_data.h:69:2: error: unknown type name ‘phys_size_t’ In file included from imximage.c:34:0: /home/fabio/denx/u-boot-imx/include/common.h:270:1: error: unknown type name ‘phys_size_t’ /home/fabio/denx/u-boot-imx/include/common.h:311:1: error: unknown type name ‘u8’ /home/fabio/denx/u-boot-imx/include/common.h:328:14: error: unknown type name ‘cmd_tbl_t’ /home/fabio/denx/u-boot-imx/include/common.h:331:19: error: unknown type name ‘cmd_tbl_t’ /home/fabio/denx/u-boot-imx/include/common.h:334:17: error: unknown type name ‘cmd_tbl_t’ /home/fabio/denx/u-boot-imx/include/common.h:344:5: error: conflicting types for ‘setenv’ /usr/include/stdlib.h:585:12: note: previous declaration of ‘setenv’ was here /home/fabio/denx/u-boot-imx/include/common.h:562:1: error: unknown type name ‘u32’ In file included from imximage.c:34:0: /home/fabio/denx/u-boot-imx/include/common.h:787:5: error: conflicting types for ‘_IO_getc’ /usr/include/libio.h:462:12: note: previous declaration of ‘_IO_getc’ was here /home/fabio/denx/u-boot-imx/include/common.h:791:23: error: macro "putc" requires 2 arguments, but only 1 given /home/fabio/denx/u-boot-imx/include/common.h:791:6: error: ‘putc’ redeclared as different kind of symbol /home/fabio/denx/u-boot-imx/include/common.h:792:6: error: conflicting types for ‘puts’ /home/fabio/denx/u-boot-imx/include/common.h:810:5: error: conflicting types for ‘fprintf’ /home/fabio/denx/u-boot-imx/include/common.h:812:6: error: conflicting types for ‘fputs’ /home/fabio/denx/u-boot-imx/include/common.h:813:6: error: conflicting types for ‘fputc’ /home/fabio/denx/u-boot-imx/include/common.h:815:5: error: conflicting types for ‘fgetc’ /usr/include/stdio.h:537:12: note: previous declaration of ‘fgetc’ was here In file included from /home/fabio/denx/u-boot-imx/include/common.h:825:0, from imximage.c:34: /home/fabio/denx/u-boot-imx/include/net.h:42:1: error: unknown type name ‘u32’ /home/fabio/denx/u-boot-imx/include/net.h:632:1: error: unknown type name ‘u8’ /home/fabio/denx/u-boot-imx/include/net.h:644:1: error: unknown type name ‘u8’ /home/fabio/denx/u-boot-imx/include/net.h:655:1: error: unknown type name ‘u8’ /home/fabio/denx/u-boot-imx/include/net.h:670:1: error: unknown type name ‘u8’ make[1]: *** [imximage.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory `/home/fabio/denx/u-boot-imx/tools' make: *** [tools] Error 2
Regards,
Fabio Estevam
Dear Fabio Estevam,
Only with #include <common.h> ?
Regards,
Fabio Estevam
On 03/01/2013 14:49, Marek Vasut wrote:
Dear Fabio Estevam,
I will remark a previous comment - even if including common.h seems a good idea to avoid duplications, it makes tools like mkimage to depend on the selected board, because <board>_config must run. Even if this is not a problem for us u-boot developers, it becomes an issue when these tools are included in distros (like u-boot-tools in Ubuntu) and cannot be packaged.
Dear Fabio Estevam,
It would be good to include this in commit log if not already committed.
Thanks Troy
On Thu, Jan 3, 2013 at 4:18 PM, Troy Kisky troy.kisky@boundarydevices.com wrote:
Ok, just sent a v2 with such comment.
Regards,
Fabio Estevam
On Thu, Jan 3, 2013 at 11:49 AM, Marek Vasut marex@denx.de wrote:
Dear Fabio Estevam,
Yes, correct.
On 03/01/2013 14:25, Fabio Estevam wrote:
Hi Stefano,
Hi all,
I agree with this solution - I do not like that common.h is included, because _config must run and tools should be independent from the selected board.
Then I apply it !
Thanks, Stefano Babic
participants (6)
Fabio Estevam
Fabio Estevam
Robert Nelson
Stefano Babic
Troy Kisky
