[PATCH v1 1/1] board: ns3: check bnxt chimp handshake status
Chimp is a core in Broadcom netxtream controller (bnxt). Add support to check bnxt's chimp component status.
Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- board/broadcom/bcmns3/ns3.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/board/broadcom/bcmns3/ns3.c b/board/broadcom/bcmns3/ns3.c index 0357cd0e32..8540c99286 100644 --- a/board/broadcom/bcmns3/ns3.c +++ b/board/broadcom/bcmns3/ns3.c @@ -12,6 +12,7 @@ #include <asm/armv8/mmu.h> #include <asm/arch-bcmns3/bl33_info.h> #include <dt-bindings/memory/bcm-ns3-mc.h> +#include <broadcom/chimp.h>
/* Default reset-level = 3 and strap-val = 0 */ #define L3_RESET 30 @@ -210,8 +211,20 @@ void reset_cpu(ulong level) #ifdef CONFIG_OF_BOARD_SETUP int ft_board_setup(void *fdt, struct bd_info *bd) { + u32 chimp_hs = CHIMP_HANDSHAKE_WAIT_TIMEOUT; + gic_lpi_tables_init();
+ /* + * Check for chimp handshake status. + * Zero timeout value will actually fall to default timeout. + */ + chimp_handshake_status_optee(0, &chimp_hs); + if (chimp_hs == CHIMP_HANDSHAKE_SUCCESS) + printf("ChiMP handshake successful\n"); + else + printf("ERROR: ChiMP handshake status 0x%x\n", chimp_hs); + return mem_info_parse_fixup(fdt); } #endif /* CONFIG_OF_BOARD_SETUP */
Hi Rayagonda,
On Thu, 20 Aug 2020 at 11:42, Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com wrote:
else
Where is this error handled? Don't you need to return the error from this function?
2.17.1
Hi Simon,
On Sat, Aug 22, 2020 at 8:39 PM Simon Glass sjg@chromium.org wrote:
Hi Rayagonda,
else
System boot is independent of chimp hand shake. Chimp/bnxt handshake failure is not a catastrophic error. We just want to warn the user that the chimp handshake has failed.
Best regards, Rayagonda
2.17.1
Hi Rayagonda,
On Mon, 24 Aug 2020 at 10:35, Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com wrote:
Hi Simon,
Hi Rayagonda,
else
OK then I really think you need some comments here in the code. E.g. if this fails it means x which is not critical because y...
Regards, SImon
Rayagonda Kokatanur
