Hi Tom,
Please have a look on the first pull request for RPi for the future v2020.10 release.
With this patches accepted we will have USB support on 64 bit. 32 bit support is in the works and should land in v2020.10 as well.
Please pull :)
Regards, Matthias
--- The following changes since commit 61608f395e7dcb2be6060407a72a1149b046430a:
Merge branch '2020-07-08-misc-features-and-fixes' (2020-07-08 20:20:24 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-raspberrypi.git tags/rpi-next-2020.10
for you to fetch changes up to d6ecb71a1f0c764c94f1bb381f085734d57e94e9:
config: Enable USB Keyboard support on RPi4 (2020-07-10 11:50:36 +0200)
---------------------------------------------------------------- - add support for PCI and XHCI for RPi4 (64 bit only) - optionally reset XHCI device on registration - enable USB_KEYBOARD for rpi_4_defconfig
---------------------------------------------------------------- Marek Szyprowski (3): rpi4: shorten a mapping for the DRAM rpi4: add a mapping for the PCIe XHCI controller MMIO registers (ARM 64bit) configs: Enable support for the XHCI controller on RPI4 board (ARM 64-bit)
Nicolas Saenz Julienne (6): linux/bitfield.h: Add primitives for manipulating bitfields both in host- and fixed-endian arm: rpi: Add function to trigger VL805's firmware load reset: Add Raspberry Pi 4 firmware reset controller configs: Enable support for reset controllers on RPi4 usb: xhci: Add reset controller support config: Enable USB Keyboard support on RPi4
Sylwester Nawrocki (5): usb: xhci: Add missing cache flush in the scratchpad array initialization usb: xhci: Use only 32-bit accesses in xhci_writeq/xhci_readq pci: Move some PCIe register offset definitions to a common header pci: Add some PCI Express capability register offset definitions pci: Add driver for Broadcom BCM2711 SoC PCIe controller
arch/arm/mach-bcm283x/include/mach/mbox.h | 13 + arch/arm/mach-bcm283x/include/mach/msg.h | 7 + arch/arm/mach-bcm283x/init.c | 20 +- arch/arm/mach-bcm283x/msg.c | 46 ++ configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 11 + configs/rpi_arm64_defconfig | 9 +- drivers/pci/Kconfig | 9 + drivers/pci/Makefile | 1 + drivers/pci/pci-rcar-gen3.c | 8 - drivers/pci/pcie_brcmstb.c | 623 +++++++++++++++++++++ drivers/pci/pcie_intel_fpga.c | 3 - drivers/reset/Kconfig | 11 + drivers/reset/Makefile | 1 + drivers/reset/reset-raspberrypi.c | 60 ++ drivers/usb/host/xhci-mem.c | 5 + drivers/usb/host/xhci.c | 35 ++ .../dt-bindings/reset/raspberrypi,firmware-reset.h | 13 + include/linux/bitfield.h | 53 ++ include/pci.h | 22 +- include/usb/xhci.h | 10 +- 21 files changed, 935 insertions(+), 26 deletions(-) create mode 100644 drivers/pci/pcie_brcmstb.c create mode 100644 drivers/reset/reset-raspberrypi.c create mode 100644 include/dt-bindings/reset/raspberrypi,firmware-reset.h
On 10/07/2020 16:50, Matthias Brugger wrote:
Hi Tom,
Like many times I forgot to add the links to the CI pipelines: https://travis-ci.org/github/mbgg/u-boot/builds/706819202 https://gitlab.denx.de/u-boot/custodians/u-boot-raspberrypi/pipelines/3987
The branch is rpi-next but the commit ID should be the same as the tag.
Regards, Matthias
Please pull :)
Regards, Matthias
On Fri, Jul 10, 2020 at 04:50:08PM +0200, Matthias Brugger wrote:
Hi Tom,
Please pull :)
Regards, Matthias
Matthias Brugger
