[U-Boot] PPC440GX TLB setting problem.
Hi all,
I'm working on trying to get VxWorks to boot on a PPC440GX processor using U-Boot, using an ALPR board. In order to boot VxWorks properly (it expects caching on the SDRAM to be disabled), I created a new board directory and such (based on the ALPR board), and then changed the TLB settings in init.S.
My problem is that when my new U-Boot has booted, the TLBs are not configured as I have programmed them. I verified this using a BDI debugger. The TLB settings are still the same as the settings the original ALPR U-Boot used. I'm really at a loss here. It seems that no matter what I try (I tried quite a few variantions of the TLB settings), the TLB settings won't change.
So now I several, related, questions: - What could be the cause of this? Have I done something wrong? - Is U-Boot reconfiguring the TLBs after init.S has executed? - If so, how can I control those TLBs?
Here's a code snippet from my init.S: /*********************************************************************** *** * TLB TABLE * * This table is used by the cpu boot code to setup the initial tlb * entries. Rather than make broad assumptions in the cpu source tree, * this table lets each board set things up however they like. * * Pointer to the table is returned in r1 *
************************************************************************ */ /* Updated to reflect TLB entries in VxWorks. */ .section .bootpg,"ax" .globl tlbtab
tlbtab: tlbtab_start tlbentry( CFG_SDRAM_BASE, SZ_256M, 0x00000000, 0, AC_R|AC_W|AC_X|SA_G|SA_I ) tlbentry( 0x80000000, SZ_256M, 0x00000000, 0, AC_R|AC_W|AC_X|SA_I ) tlbentry( CFG_PERIPHERAL_BASE, SZ_256M, 0x40000000, 1, AC_R|AC_W|SA_G|SA_I ) tlbentry( 0xf0000000, SZ_256M, 0xf0000000, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) tlbentry( CFG_ISRAM_BASE, SZ_256K, 0x80000000, 0, AC_R|AC_W|AC_X )
#ifdef CFG_INIT_RAM_DCACHE /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ tlbentry( CFG_INIT_RAM_ADDR, SZ_64K, CFG_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G ) #endif tlbtab_end
And here's the BDI's listing of the TLBs after U-Boot has booted (no auto boot): - TARGET: processing target startup .... - TARGET: processing target startup passed ALPR>go ALPR>halt Core number : 0 Core state : debug mode Debug entry cause : JTAG stop request Current PC : 0x0ffe372c Current CR : 0x28dcff82 Current MSR : 0x00029000 Current LR : 0x0ffe378c ALPR>tlb 0 15 IDX TID EPN SIZE VTS RPN USER WIMGE USRSVC 0 : 00 ff000000 16MB V0 -> 1_ff000000 U:0000 -I-G- XWRXWR 1 : 00 e0000000 256MB V0 -> 1_40000000 U:0000 -I-G- -WR-WR 2 : 00 c0000000 4KB V0 -> 0_80000000 U:0000 ----- XWRXWR 3 : 00 c0001000 4KB V0 -> 0_80001000 U:0000 ----- XWRXWR 4 : 00 00000000 256MB V0 -> 0_00000000 U:0000 ---G- XWRXWR 5 : 00 d0000000 256MB V0 -> 2_00000000 U:0000 -I-G- -WR-WR 6 : 00 80000000 256MB V0 -> 3_80000000 U:0000 -I-G- -WR-WR 7 : 00 90000000 256MB V0 -> 3_90000000 U:0000 -I-G- -WR-WR 8 : 00 a0000000 256MB V0 -> 3_a0000000 U:0000 -I-G- -WR-WR 9 : 00 f0000000 4KB V0 -> 1_f0000000 U:0000 -I-G- XWRXWR 10 : 00 00000000 1KB -0 -> 0_00000000 U:0000 ----- ------ 11 : 00 00000000 1KB -0 -> 0_00000000 U:0000 ----- ------ 12 : 00 00000000 1KB -0 -> 0_00000000 U:0000 ----- ------ 13 : 00 00000000 1KB -0 -> 0_00000000 U:0000 ----- ------ 14 : 00 00000000 1KB -0 -> 0_00000000 U:0000 ----- ------ 15 : 00 00000000 1KB -0 -> 0_00000000 U:0000 ----- ------ ALPR>
Thanks in advance!
Met vriendelijke groet, With kind regards,
Wouter Eckhardt Engineer wouter.eckhardt@prodrive.nl tel. +31 40 2676187 Prodrive B.V. Postbus 28030 5602 JA Eindhoven Ekkersrijt 5025 5692 EB Son The Netherlands tel. +31 40 2676200 fax: +31 40 2676201 www.prodrive.nl
Disclaimer: The information contained in this email, including any attachments is confidential and is for the sole use of the intended recipient(s). Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please notify the sender immediately by replying to this message and destroy all copies of this message and any attachments.
Hi Wouter,
Are you sure that the cache needs to be disabled? Perhaps it just needs to get properly flushed before booting VxWorks? Just checking.
This could have multiple reasons. Are you sure that you are running the freshly compiled image on the board? Did you check the build time?
Yes. But only one (IIRC). The first TLB for bootrom access. Caching will be disabled before relocating to SDRAM.
All other TLB's should be the same.
Not sure what's going wrong here.
Best regards, Stefan
Hi Stefan,
Thanks for the quick reply.
(it
TLB
settings in init.S.
needs to
Yes, I've checked the VxWorks kernel code. The comments mention that if caching is enabled, the cache should be flushed before the call to MMU TLB initialization is done. However, the calling code never actually flushes the cache. So they're not even following their own advice. In the calling code, they just assume that caching is disabled.
no
settings),
the
The build date and time of the U-Boot image I'm running is correct. I've also verified this because #undef-ing the 4XX_DCACHE config causes U-Boot to not function properly (Ethernet problem). So I'm confident that I really am running my own build. I've also verified that I'm compiling the right source, by forcing syntax errors.
will
Hmmm. This should be a problem since I changed the TLB settings to have SDRAM at the first TLB. However, the SDRAM gets remapped in a different TLB as well. Where in the code can I find this? I tried looking for something like that, but couldn't find it. Perhaps that piece of code is actually replacing all TLBs, not just the bootrom access one.
Kind regards, Wouter Eckhardt.
Hi Wouter,
OK.
Take a look at Sequoia. It has support for VxWorks booting. You need to switch the sequence of the TLB entries. init.S:
/* vxWorks needs this as first entry for the Machine Check interrupt */ tlbentry( 0x40000000, SZ_256M, 0, 0, AC_R|AC_W|AC_X|SA_G|SA_I )
And you need to set CONFIG_SYS_TLB_FOR_BOOT_FLASH in your board config header to the number of the boot TLB entry.
Let me know if this helps.
Stefan Roese
Wouter Eckhardt
