[U-Boot] [PATCH v3 00/13] Add fastboot UDP support
This series merges the fastboot UDP support from AOSP into mainline U-Boot.
Changes in UDP behaviour from the AOSP code, so it follows the existing USB behaviour:
- 'boot' now follows the USB code and does 'bootm CONFIG_FASTBOOT_BUF_ADDR'. I've added 'fastboot_bootcmd' which if set overrides the boot command and allows the existing UDP behaviour to be preserved. - 'continue' in UDP now exits the fastboot server rather than executing 'run bootcmd' - 'reboot-bootloader' no longer writes 'reboot-bootloader' to CONFIG_FASTBOOT_BUF_ADDR as its marker for the subsequent boot. The code which is in AOSP common/android_bootloader.c expects this marker, but we have prior art in the USB code using the weak function fastboot_set_reboot_flag - 'getvar' in the UDP path now supports fetching 'fastboot.' prefixed variables (inherited from the USB path), these override the defaults
I'll post the USB migration as a separate patch.
Changes in v3: - move imply ANDROID_BOOT_IMAGE, CMD_FASTBOOT to FASTBOOT from USB_FUNCTION_FASTBOOT - add depend on USB_FUNCTION_FASTBOOT to FASTBOOT_USB_DEV - leave images-sparse.c in common to acommodate 2f83f21 - move Kconfig changes to previous patch - refactor for changes in master - Merge subsequent patch for formatting response strings into this one - allow NULL to fastboot_okay() when there's no message to send - guard FASTBOOT_GPT_NAME/FASTBOOT_MBR_NAME with EFI/DOS_PARTITION - use FASTBOOT as our guard in Kconfig not a list of USB || UDP - correct mis-translation from AOSP introduced when cleaning up for checkpatch - we should write when buffer is not NULL, rather than erasing, and erase when buffer is NULL - use CMD_RET_USAGE from do_fastboot - remove do_fastboot_udp from cmd/net.c and rewrite using net_loop() - rename timed_send_info to fastboot_send_info, rename fastboot_send_info to fastboot_udp_send_info - replace FASTBOOT_HEADER_SIZE with sizeof(struct fastboot_header) - move start time into timed_send_info() rather than passing it in - make calls to fastboot_udp_send_info a runtime dependency, not a compile time one - set ${filesize} to size of downloaded image - add progress meter from USB path during download - add support for 'oem format' command from the USB path - rename 'fastbootcmd' to 'fastboot_bootcmd' to make clear that this is the fastboot boot command - make getvar implementation table driven - add fastboot_buf_addr, fastboot_buf_size to override buffer address and size - return correct filesystem type in getvar partition-type on MMC - process "fastboot." prefixed env variables in getvar first so you can override the normal values (this also lets you set a fs type for NAND devices) - squash subsequent patches which change this code into this one: - If the fastboot flash/erase commands are disabled, remove that support so we still build correctly. - Add NAND support to fastboot UDP flash/erase commands - If we don't have a partition name passed, report it as not found. - Change the behaviour of the fastboot net code such that "reboot-bootloader" is no longer written to CONFIG_FASTBOOT_BUF_ADDR for use as a marker on reboot (the AOSP code in common/android-bootloader.c uses this marker - this code could be reinstated there if that gets merged). - Merge USB and UDP boot code. The USB implementation stays the same, but UDP no longer passes an fdt. We introduce a new environment variable 'fastboot_bootcmd' which if set overrides the hardcoded boot command, setting this then allows the UDP implementation to remain the same. If after running 'fastboot_bootcmd' the board has not booted, control is returned to U-Boot and the fastboot process ends. - Separate the fastboot protocol handling from the fastboot UDP code in preparation for reusing it in the USB code.
Changes in v2: - ensure fastboot syntax is backward compatible - 'fastboot 0' means 'fastboot usb 0'
Alex Kiernan (13): fastboot: Move fastboot to drivers/fastboot fastboot: Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT fastboot: Refactor fastboot_okay/fail to take response fastboot: Extract fastboot_okay/fail to fb_common.c fastboot: Correct dependencies in FASTBOOT_FLASH fastboot: Add missing newlines fastboot: Remove FIXME for CONFIG_FASTBOOT_...NAME fastboot: Fix parameter types in _fb_nand_write fastboot: Rename fb_set_reboot_flag to fastboot_set_reboot_flag fastboot: Extract common definitions from USB fastboot ti: fastboot: Move weak overrides to board files fs: Add fs_get_type_name to return current filesystem name net: fastboot: Merge AOSP UDP fastboot
arch/arm/Kconfig | 2 - arch/arm/mach-omap2/boot-common.c | 10 - arch/arm/mach-omap2/utils.c | 4 +- arch/arm/mach-rockchip/rk3128-board.c | 4 +- arch/arm/mach-rockchip/rk322x-board.c | 4 +- board/amazon/kc1/kc1.c | 2 +- board/lg/sniper/sniper.c | 2 +- board/ti/am57xx/board.c | 10 + board/ti/common/Kconfig | 1 - board/ti/dra7xx/evm.c | 10 + cmd/Kconfig | 14 +- cmd/fastboot.c | 91 ++++++- cmd/mmc.c | 2 +- common/Makefile | 15 +- common/image-sparse.c | 32 ++- configs/am335x_boneblack_defconfig | 2 +- configs/am335x_boneblack_vboot_defconfig | 2 +- configs/am335x_evm_defconfig | 2 +- configs/am335x_evm_nor_defconfig | 2 +- configs/am335x_evm_norboot_defconfig | 2 +- configs/am335x_evm_spiboot_defconfig | 2 +- configs/am335x_evm_usbspl_defconfig | 2 +- configs/am57xx_evm_defconfig | 2 +- configs/am57xx_hs_evm_defconfig | 2 +- configs/bcm23550_w1d_defconfig | 2 +- configs/bcm28155_ap_defconfig | 2 +- configs/birdland_bav335a_defconfig | 2 +- configs/birdland_bav335b_defconfig | 2 +- configs/cgtqmx6eval_defconfig | 2 +- configs/dra7xx_evm_defconfig | 2 +- configs/dra7xx_hs_evm_defconfig | 2 +- configs/kc1_defconfig | 2 +- configs/mx6qsabrelite_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/nitrogen6dl2g_defconfig | 2 +- configs/nitrogen6dl_defconfig | 2 +- configs/nitrogen6q2g_defconfig | 2 +- configs/nitrogen6q_defconfig | 2 +- configs/nitrogen6s1g_defconfig | 2 +- configs/nitrogen6s_defconfig | 2 +- configs/omap3_beagle_defconfig | 2 +- configs/omap3_evm_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/sniper_defconfig | 2 +- configs/stih410-b2260_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 +- configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 2 +- configs/xilinx_zynqmp_zcu102_revA_defconfig | 2 +- configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 +- configs/xilinx_zynqmp_zcu106_revA_defconfig | 2 +- drivers/Kconfig | 2 + drivers/Makefile | 1 + {cmd => drivers}/fastboot/Kconfig | 52 ++-- drivers/fastboot/Makefile | 8 + drivers/fastboot/fb_command.c | 258 +++++++++++++++++++ drivers/fastboot/fb_common.c | 102 ++++++++ drivers/fastboot/fb_getvar.c | 222 ++++++++++++++++ {common => drivers/fastboot}/fb_mmc.c | 183 ++++++++----- {common => drivers/fastboot}/fb_nand.c | 46 ++-- drivers/usb/gadget/f_fastboot.c | 67 ++--- fs/fs.c | 5 + include/common.h | 13 + include/fastboot.h | 57 ++++- include/fb_mmc.h | 10 +- include/fb_nand.h | 12 +- include/fs.h | 5 + include/image-sparse.h | 4 +- include/net.h | 2 +- include/net/fastboot.h | 21 ++ net/Makefile | 1 + net/fastboot.c | 310 +++++++++++++++++++++++ net/net.c | 7 + 73 files changed, 1402 insertions(+), 261 deletions(-) rename {cmd => drivers}/fastboot/Kconfig (83%) create mode 100644 drivers/fastboot/Makefile create mode 100644 drivers/fastboot/fb_command.c create mode 100644 drivers/fastboot/fb_common.c create mode 100644 drivers/fastboot/fb_getvar.c rename {common => drivers/fastboot}/fb_mmc.c (67%) rename {common => drivers/fastboot}/fb_nand.c (81%) create mode 100644 include/net/fastboot.h create mode 100644 net/fastboot.c
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
arch/arm/Kconfig | 2 -- board/ti/common/Kconfig | 1 - cmd/Kconfig | 14 ++++++++++++-- common/Makefile | 15 +-------------- drivers/Kconfig | 2 ++ drivers/Makefile | 1 + {cmd => drivers}/fastboot/Kconfig | 35 ++++++++++++---------------------- drivers/fastboot/Makefile | 8 ++++++++ {common => drivers/fastboot}/fb_mmc.c | 0 {common => drivers/fastboot}/fb_nand.c | 0 10 files changed, 36 insertions(+), 42 deletions(-) rename {cmd => drivers}/fastboot/Kconfig (88%) create mode 100644 drivers/fastboot/Makefile rename {common => drivers/fastboot}/fb_mmc.c (100%) rename {common => drivers/fastboot}/fb_nand.c (100%)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c9d6e0a..c4acd10 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1246,9 +1246,7 @@ config ARCH_ROCKCHIP select DM_REGULATOR select ENABLE_ARM_SOC_BOOT0_HOOK select SPI - imply CMD_FASTBOOT imply DISTRO_DEFAULTS - imply FASTBOOT imply FAT_WRITE imply USB_FUNCTION_FASTBOOT imply SPL_SYSRESET diff --git a/board/ti/common/Kconfig b/board/ti/common/Kconfig index c21eb8c..b1956b8 100644 --- a/board/ti/common/Kconfig +++ b/board/ti/common/Kconfig @@ -25,7 +25,6 @@ config TI_COMMON_CMD_OPTIONS imply CMD_EXT2 imply CMD_EXT4 imply CMD_EXT4_WRITE - imply CMD_FASTBOOT if FASTBOOT imply CMD_FAT imply FAT_WRITE if CMD_FAT imply CMD_FS_GENERIC diff --git a/cmd/Kconfig b/cmd/Kconfig index eb14e08..fcfcff9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -137,8 +137,6 @@ config AUTOBOOT_STOP_STR_SHA256
endmenu
-source "cmd/fastboot/Kconfig" - config BUILD_BIN2C bool
@@ -650,6 +648,18 @@ config CMD_DM can be useful to see the state of driver model for debugging or interest.
+config CMD_FASTBOOT + bool "fastboot - Android fastboot support" + depends on USB_FUNCTION_FASTBOOT || UDP_FUNCTION_FASTBOOT + help + This enables the command "fastboot" which enables the Android + fastboot mode for the platform. Fastboot is a protocol for + downloading images, flashing and device control used on + Android devices. Fastboot requires either network stack + enabled or support for acting as a USB device. + + See doc/README.android-fastboot for more information. + config CMD_FDC bool "fdcboot - Boot from floppy device" help diff --git a/common/Makefile b/common/Makefile index d0681c7..9ec40b9 100644 --- a/common/Makefile +++ b/common/Makefile @@ -29,7 +29,7 @@ obj-$(CONFIG_CMD_BOOTI) += bootm.o bootm_os.o
obj-$(CONFIG_CMD_BEDBUG) += bedbug.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdt_support.o - +obj-$(CONFIG_FASTBOOT_FLASH) += image-sparse.o obj-$(CONFIG_MII) += miiphyutil.o obj-$(CONFIG_CMD_MII) += miiphyutil.o obj-$(CONFIG_PHYLIB) += miiphyutil.o @@ -109,19 +109,6 @@ obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o
-ifndef CONFIG_SPL_BUILD -# This option is not just y/n - it can have a numeric value -ifdef CONFIG_FASTBOOT_FLASH -obj-y += image-sparse.o -ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV -obj-y += fb_mmc.o -endif -ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV -obj-y += fb_nand.o -endif -endif -endif - ifdef CONFIG_CMD_EEPROM_LAYOUT obj-y += eeprom/eeprom_field.o eeprom/eeprom_layout.o endif diff --git a/drivers/Kconfig b/drivers/Kconfig index c2e813f..8424898 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -28,6 +28,8 @@ source "drivers/dfu/Kconfig"
source "drivers/dma/Kconfig"
+source "drivers/fastboot/Kconfig" + source "drivers/firmware/Kconfig"
source "drivers/fpga/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index b3f1b60..d29a6e4 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -71,6 +71,7 @@ obj-y += block/ obj-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount/ obj-$(CONFIG_CPU) += cpu/ obj-y += crypto/ +obj-$(CONFIG_FASTBOOT) += fastboot/ obj-y += firmware/ obj-$(CONFIG_FPGA) += fpga/ obj-y += misc/ diff --git a/cmd/fastboot/Kconfig b/drivers/fastboot/Kconfig similarity index 88% rename from cmd/fastboot/Kconfig rename to drivers/fastboot/Kconfig index 0d2c2f1..93a8ac6 100644 --- a/cmd/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -1,32 +1,20 @@ -comment "FASTBOOT" +menu "Fastboot support"
-menuconfig FASTBOOT - bool "Fastboot support" - depends on USB_GADGET - default y if ARCH_SUNXI && USB_MUSB_GADGET - -if FASTBOOT +config FASTBOOT + bool + imply ANDROID_BOOT_IMAGE + imply CMD_FASTBOOT
config USB_FUNCTION_FASTBOOT bool "Enable USB fastboot gadget" - default y + depends on USB_GADGET + default y if ARCH_SUNXI && USB_MUSB_GADGET + select FASTBOOT select USB_GADGET_DOWNLOAD - imply ANDROID_BOOT_IMAGE - imply CMD_FASTBOOT help This enables the USB part of the fastboot gadget.
-config CMD_FASTBOOT - bool "Enable FASTBOOT command" - help - This enables the command "fastboot" which enables the Android - fastboot mode for the platform's USB device. Fastboot is a USB - protocol for downloading images, flashing and device control - used on Android devices. - - See doc/README.android-fastboot for more information. - -if USB_FUNCTION_FASTBOOT +if FASTBOOT
config FASTBOOT_BUF_ADDR hex "Define FASTBOOT buffer address" @@ -58,6 +46,7 @@ config FASTBOOT_BUF_SIZE
config FASTBOOT_USB_DEV int "USB controller number" + depends on USB_FUNCTION_FASTBOOT default 0 help Some boards have USB OTG controller other than 0. Define this @@ -129,6 +118,6 @@ config FASTBOOT_MBR_NAME specified on the "fastboot flash" command line matches the value defined here. The default target name for updating MBR is "mbr".
-endif # USB_FUNCTION_FASTBOOT - endif # FASTBOOT + +endmenu diff --git a/drivers/fastboot/Makefile b/drivers/fastboot/Makefile new file mode 100644 index 0000000..651fbf0 --- /dev/null +++ b/drivers/fastboot/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ + +ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +obj-y += fb_mmc.o +endif +ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV +obj-y += fb_nand.o +endif diff --git a/common/fb_mmc.c b/drivers/fastboot/fb_mmc.c similarity index 100% rename from common/fb_mmc.c rename to drivers/fastboot/fb_mmc.c diff --git a/common/fb_nand.c b/drivers/fastboot/fb_nand.c similarity index 100% rename from common/fb_nand.c rename to drivers/fastboot/fb_nand.c
Anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v3: - move Kconfig changes to previous patch
Changes in v2: None
configs/am335x_boneblack_defconfig | 2 +- configs/am335x_boneblack_vboot_defconfig | 2 +- configs/am335x_evm_defconfig | 2 +- configs/am335x_evm_nor_defconfig | 2 +- configs/am335x_evm_norboot_defconfig | 2 +- configs/am335x_evm_spiboot_defconfig | 2 +- configs/am335x_evm_usbspl_defconfig | 2 +- configs/am57xx_evm_defconfig | 2 +- configs/am57xx_hs_evm_defconfig | 2 +- configs/bcm23550_w1d_defconfig | 2 +- configs/bcm28155_ap_defconfig | 2 +- configs/birdland_bav335a_defconfig | 2 +- configs/birdland_bav335b_defconfig | 2 +- configs/cgtqmx6eval_defconfig | 2 +- configs/dra7xx_evm_defconfig | 2 +- configs/dra7xx_hs_evm_defconfig | 2 +- configs/kc1_defconfig | 2 +- configs/mx6qsabrelite_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/nitrogen6dl2g_defconfig | 2 +- configs/nitrogen6dl_defconfig | 2 +- configs/nitrogen6q2g_defconfig | 2 +- configs/nitrogen6q_defconfig | 2 +- configs/nitrogen6s1g_defconfig | 2 +- configs/nitrogen6s_defconfig | 2 +- configs/omap3_beagle_defconfig | 2 +- configs/omap3_evm_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/sniper_defconfig | 2 +- configs/stih410-b2260_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 +- configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 2 +- configs/xilinx_zynqmp_zcu102_revA_defconfig | 2 +- configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 +- configs/xilinx_zynqmp_zcu106_revA_defconfig | 2 +- 36 files changed, 36 insertions(+), 36 deletions(-)
diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 5c01b20..bd3a374 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -16,7 +16,7 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_CMD_SPL=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index abbacdc..baaae36 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -19,7 +19,7 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 6732013..cc556d1 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -13,7 +13,7 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00080000 # CONFIG_CMD_FLASH is not set diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index bbde07f..41a5c79 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -12,7 +12,7 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00080000 CONFIG_CMD_NAND=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 3ddcf64..75d0793 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -12,7 +12,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.0" diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 10eb0fe..b267887 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -15,7 +15,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MTDPARTS=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index dc9ac21..4401291 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -19,7 +19,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_GADGET_SUPPORT=y CONFIG_SPL_USB_ETHER=y # CONFIG_SPL_YMODEM_SUPPORT is not set -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00080000 # CONFIG_CMD_FLASH is not set diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 0e99268..3b83b69 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -24,7 +24,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_USB_DEV=1 diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 165c2a4..9c2aef4 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -29,7 +29,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_USB_DEV=1 diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index 9a986ca..de4fa60 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -7,7 +7,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x80000000 CONFIG_FASTBOOT_BUF_SIZE=0x1D000000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index d26cde5..4f7a58e 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -8,7 +8,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x80000000 CONFIG_FASTBOOT_BUF_SIZE=0x7FF00000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 51b3e6b..3efd566 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -25,7 +25,7 @@ CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 29b223a..2f98116 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -25,7 +25,7 @@ CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y CONFIG_CMD_ASKENV=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index d4204aa..241e958 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -24,7 +24,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_DFU=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 9b81b0c..b766ba2 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -25,7 +25,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 536946e..39a6801 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 534d604..ce71e37 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -12,7 +12,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 CONFIG_SYS_PROMPT="kc1 # " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2000000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index e9d193c..159ff16 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index ca37d8b..5c8e9de 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -22,7 +22,7 @@ CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET_SUPPORT=y CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FASTBOOT_BUF_SIZE=0x10000000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 6ef4226..cfb2ed8 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index b9784a2..9cb7ac2 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 61688ba..e31521a 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index cfee7ba..85c352c 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 0f29a56..1f37320 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 7ad1584..0696f09 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -9,7 +9,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 7b81b03..05dc737 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -13,7 +13,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="BeagleBoard # " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x280000 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 20795c3..52285cc 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -12,7 +12,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="OMAP3_EVM # " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x280000 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 5a31e46..953980c 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="OMAP Logic # " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 # CONFIG_CMD_IMI is not set CONFIG_CMD_SPL=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index ad22a1c..70e485f 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -13,7 +13,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SYS_PROMPT="sniper # " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2000000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 67391bd..7d990f9 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -10,7 +10,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAS1,115200 CONSOLE=/dev/ttyAS1 consoleblank=0 root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait mem=992M@0x40000000 vmalloc=256m" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SYS_PROMPT="stih410-b2260 => " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x40000000 CONFIG_FASTBOOT_BUF_SIZE=0x3DF00000 CONFIG_FASTBOOT_FLASH=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 3aa3930..26180c7 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -19,7 +19,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 1bd52ab..0f8b361 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -20,7 +20,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 0ddec99..1b8bb7c 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -19,7 +19,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 94dc62a..7c14a76 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -19,7 +19,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 8889f19..cd7a894 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -19,7 +19,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 017940e..c566251 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -18,7 +18,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " -CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y
Add the response string as a parameter to fastboot_okay/fail, instead of modifying a global, to match the contract expected by the AOSP U-Boot code.
Changes in v3: - refactor for changes in master
Changes in v2: None
cmd/mmc.c | 2 +- common/image-sparse.c | 32 +++++++++------- drivers/fastboot/fb_mmc.c | 83 +++++++++++++++++++++++------------------ drivers/fastboot/fb_nand.c | 34 +++++++++-------- drivers/usb/gadget/f_fastboot.c | 35 +++++++---------- include/fastboot.h | 4 +- include/fb_mmc.h | 4 +- include/fb_nand.h | 4 +- include/image-sparse.h | 4 +- 9 files changed, 105 insertions(+), 97 deletions(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index 68bbf1f..cc44525 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -367,7 +367,7 @@ static int do_mmc_sparse_write(cmd_tbl_t *cmdtp, int flag, sparse.mssg = NULL; sprintf(dest, "0x" LBAF, sparse.start * sparse.blksz);
- if (write_sparse_image(&sparse, dest, addr)) + if (write_sparse_image(&sparse, dest, addr, NULL)) return CMD_RET_FAILURE; else return CMD_RET_SUCCESS; diff --git a/common/image-sparse.c b/common/image-sparse.c index 9223b9a..1ae7a4d 100644 --- a/common/image-sparse.c +++ b/common/image-sparse.c @@ -48,10 +48,10 @@ #define CONFIG_FASTBOOT_FLASH_FILLBUF_SIZE (1024 * 512) #endif
-static void default_log(const char *ignored) {} +static void default_log(const char *ignored, char *response) {}
int write_sparse_image(struct sparse_storage *info, - const char *part_name, void *data) + const char *part_name, void *data, char *response) { lbaint_t blk; lbaint_t blkcnt; @@ -104,7 +104,7 @@ int write_sparse_image(struct sparse_storage *info, if (offset) { printf("%s: Sparse image block size issue [%u]\n", __func__, sparse_header->blk_sz); - info->mssg("sparse image block size issue"); + info->mssg("sparse image block size issue", response); return -1; }
@@ -139,7 +139,8 @@ int write_sparse_image(struct sparse_storage *info, case CHUNK_TYPE_RAW: if (chunk_header->total_sz != (sparse_header->chunk_hdr_sz + chunk_data_sz)) { - info->mssg("Bogus chunk size for chunk type Raw"); + info->mssg("Bogus chunk size for chunk type Raw", + response); return -1; }
@@ -147,7 +148,8 @@ int write_sparse_image(struct sparse_storage *info, printf( "%s: Request would exceed partition size!\n", __func__); - info->mssg("Request would exceed partition size!"); + info->mssg("Request would exceed partition size!", + response); return -1; }
@@ -157,7 +159,7 @@ int write_sparse_image(struct sparse_storage *info, printf("%s: %s" LBAFU " [" LBAFU "]\n", __func__, "Write failed, block #", blk, blks); - info->mssg("flash write failure"); + info->mssg("flash write failure", response); return -1; } blk += blks; @@ -169,7 +171,7 @@ int write_sparse_image(struct sparse_storage *info, case CHUNK_TYPE_FILL: if (chunk_header->total_sz != (sparse_header->chunk_hdr_sz + sizeof(uint32_t))) { - info->mssg("Bogus chunk size for chunk type FILL"); + info->mssg("Bogus chunk size for chunk type FILL", response); return -1; }
@@ -179,7 +181,8 @@ int write_sparse_image(struct sparse_storage *info, info->blksz * fill_buf_num_blks, ARCH_DMA_MINALIGN)); if (!fill_buf) { - info->mssg("Malloc failed for: CHUNK_TYPE_FILL"); + info->mssg("Malloc failed for: CHUNK_TYPE_FILL", + response); return -1; }
@@ -196,7 +199,8 @@ int write_sparse_image(struct sparse_storage *info, printf( "%s: Request would exceed partition size!\n", __func__); - info->mssg("Request would exceed partition size!"); + info->mssg("Request would exceed partition size!", + response); return -1; }
@@ -211,7 +215,8 @@ int write_sparse_image(struct sparse_storage *info, __func__, "Write failed, block #", blk, j); - info->mssg("flash write failure"); + info->mssg("flash write failure", + response); free(fill_buf); return -1; } @@ -231,7 +236,8 @@ int write_sparse_image(struct sparse_storage *info, case CHUNK_TYPE_CRC32: if (chunk_header->total_sz != sparse_header->chunk_hdr_sz) { - info->mssg("Bogus chunk size for chunk type Dont Care"); + info->mssg("Bogus chunk size for chunk type Dont Care", + response); return -1; } total_blocks += chunk_header->chunk_sz; @@ -241,7 +247,7 @@ int write_sparse_image(struct sparse_storage *info, default: printf("%s: Unknown chunk type: %x\n", __func__, chunk_header->chunk_type); - info->mssg("Unknown chunk type"); + info->mssg("Unknown chunk type", response); return -1; } } @@ -251,7 +257,7 @@ int write_sparse_image(struct sparse_storage *info, printf("........ wrote %u bytes to '%s'\n", bytes_written, part_name);
if (total_blocks != sparse_header->total_blks) { - info->mssg("sparse image write failure"); + info->mssg("sparse image write failure", response); return -1; }
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index 46f0073..1bcb2e5 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -73,7 +73,7 @@ static lbaint_t fb_mmc_sparse_reserve(struct sparse_storage *info,
static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info, const char *part_name, void *buffer, - unsigned int download_bytes) + unsigned int download_bytes, char *response) { lbaint_t blkcnt; lbaint_t blks; @@ -84,7 +84,7 @@ static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info,
if (blkcnt > info->size) { pr_err("too large for partition: '%s'\n", part_name); - fastboot_fail("too large for partition"); + fastboot_fail("too large for partition", response); return; }
@@ -93,13 +93,13 @@ static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info, blks = blk_dwrite(dev_desc, info->start, blkcnt, buffer); if (blks != blkcnt) { pr_err("failed writing to device %d\n", dev_desc->devnum); - fastboot_fail("failed writing to device"); + fastboot_fail("failed writing to device", response); return; }
printf("........ wrote " LBAFU " bytes to '%s'\n", blkcnt * info->blksz, part_name); - fastboot_okay(""); + fastboot_okay(NULL, response); }
#ifdef CONFIG_ANDROID_BOOT_IMAGE @@ -114,7 +114,8 @@ static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info, */ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, disk_partition_t *info, - struct andr_img_hdr *hdr) + struct andr_img_hdr *hdr, + char *response) { ulong sector_size; /* boot partition sector size */ lbaint_t hdr_sectors; /* boot image header sectors count */ @@ -125,7 +126,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, hdr_sectors = DIV_ROUND_UP(sizeof(struct andr_img_hdr), sector_size); if (hdr_sectors == 0) { pr_err("invalid number of boot sectors: 0"); - fastboot_fail("invalid number of boot sectors: 0"); + fastboot_fail("invalid number of boot sectors: 0", response); return 0; }
@@ -133,7 +134,8 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, res = blk_dread(dev_desc, info->start, hdr_sectors, (void *)hdr); if (res != hdr_sectors) { pr_err("cannot read header from boot partition"); - fastboot_fail("cannot read header from boot partition"); + fastboot_fail("cannot read header from boot partition", + response); return 0; }
@@ -141,7 +143,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, res = android_image_check_header(hdr); if (res != 0) { pr_err("bad boot image magic"); - fastboot_fail("boot partition not initialized"); + fastboot_fail("boot partition not initialized", response); return 0; }
@@ -159,7 +161,8 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, */ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, void *download_buffer, - unsigned int download_bytes) + unsigned int download_bytes, + char *response) { uintptr_t hdr_addr; /* boot image header address */ struct andr_img_hdr *hdr; /* boot image header */ @@ -179,7 +182,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = part_get_info_by_name(dev_desc, BOOT_PARTITION_NAME, &info); if (res < 0) { pr_err("cannot find boot partition"); - fastboot_fail("cannot find boot partition"); + fastboot_fail("cannot find boot partition", response); return -1; }
@@ -188,17 +191,18 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, hdr = (struct andr_img_hdr *)hdr_addr;
/* Read boot image header */ - hdr_sectors = fb_mmc_get_boot_header(dev_desc, &info, hdr); + hdr_sectors = fb_mmc_get_boot_header(dev_desc, &info, hdr, response); if (hdr_sectors == 0) { pr_err("unable to read boot image header"); - fastboot_fail("unable to read boot image header"); + fastboot_fail("unable to read boot image header", response); return -1; }
/* Check if boot image has second stage in it (we don't support it) */ if (hdr->second_size > 0) { pr_err("moving second stage is not supported yet"); - fastboot_fail("moving second stage is not supported yet"); + fastboot_fail("moving second stage is not supported yet", + response); return -1; }
@@ -216,7 +220,8 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, ramdisk_buffer); if (res != ramdisk_sectors) { pr_err("cannot read ramdisk from boot partition"); - fastboot_fail("cannot read ramdisk from boot partition"); + fastboot_fail("cannot read ramdisk from boot partition", + response); return -1; }
@@ -225,7 +230,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dwrite(dev_desc, info.start, hdr_sectors, (void *)hdr); if (res == 0) { pr_err("cannot writeback boot image header"); - fastboot_fail("cannot write back boot image header"); + fastboot_fail("cannot write back boot image header", response); return -1; }
@@ -237,7 +242,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, download_buffer); if (res == 0) { pr_err("cannot write new kernel"); - fastboot_fail("cannot write new kernel"); + fastboot_fail("cannot write new kernel", response); return -1; }
@@ -249,18 +254,18 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, ramdisk_buffer); if (res == 0) { pr_err("cannot write back original ramdisk"); - fastboot_fail("cannot write back original ramdisk"); + fastboot_fail("cannot write back original ramdisk", response); return -1; }
puts("........ zImage was updated in boot partition\n"); - fastboot_okay(""); + fastboot_okay(NULL, response); return 0; } #endif
void fb_mmc_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes) + unsigned int download_bytes, char *response) { struct blk_desc *dev_desc; disk_partition_t info; @@ -268,7 +273,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { pr_err("invalid mmc device\n"); - fastboot_fail("invalid mmc device"); + fastboot_fail("invalid mmc device", response); return; }
@@ -279,16 +284,17 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, if (is_valid_gpt_buf(dev_desc, download_buffer)) { printf("%s: invalid GPT - refusing to write to flash\n", __func__); - fastboot_fail("invalid GPT partition"); + fastboot_fail("invalid GPT partition", response); return; } if (write_mbr_and_gpt_partitions(dev_desc, download_buffer)) { printf("%s: writing GPT partitions failed\n", __func__); - fastboot_fail("writing GPT partitions failed"); + fastboot_fail("writing GPT partitions failed", + response); return; } printf("........ success\n"); - fastboot_okay(""); + fastboot_okay(NULL, response); return; } #endif @@ -299,30 +305,32 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, if (is_valid_dos_buf(download_buffer)) { printf("%s: invalid MBR - refusing to write to flash\n", __func__); - fastboot_fail("invalid MBR partition"); + fastboot_fail("invalid MBR partition", response); return; } if (write_mbr_partition(dev_desc, download_buffer)) { printf("%s: writing MBR partition failed\n", __func__); - fastboot_fail("writing MBR partition failed"); + fastboot_fail("writing MBR partition failed", + response); return; } printf("........ success\n"); - fastboot_okay(""); + fastboot_okay(NULL, response); return; } #endif
#ifdef CONFIG_ANDROID_BOOT_IMAGE if (strncasecmp(cmd, "zimage", 6) == 0) { - fb_mmc_update_zimage(dev_desc, download_buffer, download_bytes); + fb_mmc_update_zimage(dev_desc, download_buffer, + download_bytes, response); return; } #endif
if (part_get_info_by_name_or_alias(dev_desc, cmd, &info) < 0) { pr_err("cannot find partition: '%s'\n", cmd); - fastboot_fail("cannot find partition"); + fastboot_fail("cannot find partition", response); return; }
@@ -344,16 +352,17 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, sparse.start);
sparse.priv = &sparse_priv; - err = write_sparse_image(&sparse, cmd, download_buffer); + err = write_sparse_image(&sparse, cmd, download_buffer, + response); if (!err) - fastboot_okay(""); + fastboot_okay(NULL, response); } else { write_raw_image(dev_desc, &info, cmd, download_buffer, - download_bytes); + download_bytes, response); } }
-void fb_mmc_erase(const char *cmd) +void fb_mmc_erase(const char *cmd, char *response) { int ret; struct blk_desc *dev_desc; @@ -363,21 +372,21 @@ void fb_mmc_erase(const char *cmd)
if (mmc == NULL) { pr_err("invalid mmc device"); - fastboot_fail("invalid mmc device"); + fastboot_fail("invalid mmc device", response); return; }
dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { pr_err("invalid mmc device"); - fastboot_fail("invalid mmc device"); + fastboot_fail("invalid mmc device", response); return; }
ret = part_get_info_by_name_or_alias(dev_desc, cmd, &info); if (ret < 0) { pr_err("cannot find partition: '%s'", cmd); - fastboot_fail("cannot find partition"); + fastboot_fail("cannot find partition", response); return; }
@@ -396,11 +405,11 @@ void fb_mmc_erase(const char *cmd) blks = blk_derase(dev_desc, blks_start, blks_size); if (blks != blks_size) { pr_err("failed erasing from device %d", dev_desc->devnum); - fastboot_fail("failed erasing from device"); + fastboot_fail("failed erasing from device", response); return; }
printf("........ erased " LBAFU " bytes from '%s'\n", blks_size * info.blksz, cmd); - fastboot_okay(""); + fastboot_okay(NULL, response); } diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index c07655e..2ee0d64 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -31,7 +31,8 @@ __weak int board_fastboot_write_partition_setup(char *name)
static int fb_nand_lookup(const char *partname, struct mtd_info **mtd, - struct part_info **part) + struct part_info **part, + char *response) { struct mtd_device *dev; int ret; @@ -40,21 +41,21 @@ static int fb_nand_lookup(const char *partname, ret = mtdparts_init(); if (ret) { pr_err("Cannot initialize MTD partitions\n"); - fastboot_fail("cannot init mtdparts"); + fastboot_fail("cannot init mtdparts", response); return ret; }
ret = find_dev_and_part(partname, &dev, &pnum, part); if (ret) { pr_err("cannot find partition: '%s'", partname); - fastboot_fail("cannot find partition"); + fastboot_fail("cannot find partition", response); return ret; }
if (dev->id->type != MTD_DEV_TYPE_NAND) { pr_err("partition '%s' is not stored on a NAND device", partname); - fastboot_fail("not a NAND device"); + fastboot_fail("not a NAND device", response); return -EINVAL; }
@@ -145,16 +146,16 @@ static lbaint_t fb_nand_sparse_reserve(struct sparse_storage *info, }
void fb_nand_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes) + unsigned int download_bytes, char *response) { struct part_info *part; struct mtd_info *mtd = NULL; int ret;
- ret = fb_nand_lookup(cmd, &mtd, &part); + ret = fb_nand_lookup(cmd, &mtd, &part, response); if (ret) { pr_err("invalid NAND device"); - fastboot_fail("invalid NAND device"); + fastboot_fail("invalid NAND device", response); return; }
@@ -180,9 +181,10 @@ void fb_nand_flash_write(const char *cmd, void *download_buffer, sparse.start);
sparse.priv = &sparse_priv; - ret = write_sparse_image(&sparse, cmd, download_buffer); + ret = write_sparse_image(&sparse, cmd, download_buffer, + response); if (!ret) - fastboot_okay(""); + fastboot_okay(NULL, response); } else { printf("Flashing raw image at offset 0x%llx\n", part->offset); @@ -195,23 +197,23 @@ void fb_nand_flash_write(const char *cmd, void *download_buffer, }
if (ret) { - fastboot_fail("error writing the image"); + fastboot_fail("error writing the image", response); return; }
-void fb_nand_erase(const char *cmd) +void fb_nand_erase(const char *cmd, char *response) { struct part_info *part; struct mtd_info *mtd = NULL; int ret;
@@ -222,9 +224,9 @@ void fb_nand_erase(const char *cmd) ret = _fb_nand_erase(mtd, part); if (ret) { pr_err("failed erasing from device %s", mtd->name); - fastboot_fail("failed erasing from device"); + fastboot_fail("failed erasing from device", response); return; }
- fastboot_okay(""); + fastboot_okay(NULL, response); } diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 3acadae..bb60612 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -150,18 +150,16 @@ static void rx_handler_command(struct usb_ep *ep, struct usb_request *req); static int strcmp_l1(const char *s1, const char *s2);
-static char *fb_response_str; - -void fastboot_fail(const char *reason) +void fastboot_fail(const char *reason, char *response) { - strncpy(fb_response_str, "FAIL\0", 5); - strncat(fb_response_str, reason, FASTBOOT_RESPONSE_LEN - 4 - 1); + strncpy(response, "FAIL\0", 5); + strncat(response, reason, FASTBOOT_RESPONSE_LEN - 4 - 1); }
-void fastboot_okay(const char *reason) +void fastboot_okay(const char *reason, char *response) { - strncpy(fb_response_str, "OKAY\0", 5); - strncat(fb_response_str, reason, FASTBOOT_RESPONSE_LEN - 4 - 1); + strncpy(response, "OKAY\0", 5); + strncat(response, reason, FASTBOOT_RESPONSE_LEN - 4 - 1); }
static void fastboot_complete(struct usb_ep *ep, struct usb_request *req) @@ -597,18 +595,14 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) return; }
- /* initialize the response buffer */ - fb_response_str = response; - - fastboot_fail("no flash device defined"); + fastboot_fail("no flash device defined", response); #ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV fb_mmc_flash_write(cmd, (void *)CONFIG_FASTBOOT_BUF_ADDR, - download_bytes); + download_bytes, response); #endif #ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV - fb_nand_flash_write(cmd, - (void *)CONFIG_FASTBOOT_BUF_ADDR, - download_bytes); + fb_nand_flash_write(cmd, (void *)CONFIG_FASTBOOT_BUF_ADDR, + download_bytes, response); #endif fastboot_tx_write_str(response); } @@ -649,15 +643,12 @@ static void cb_erase(struct usb_ep *ep, struct usb_request *req) return; }
- /* initialize the response buffer */ - fb_response_str = response; - - fastboot_fail("no flash device defined"); + fastboot_fail("no flash device defined", response); #ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV - fb_mmc_erase(cmd); + fb_mmc_erase(cmd, response); #endif #ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV - fb_nand_erase(cmd); + fb_nand_erase(cmd, response); #endif fastboot_tx_write_str(response); } diff --git a/include/fastboot.h b/include/fastboot.h index 009f1a7..ed52dae 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -15,7 +15,7 @@ /* The 64 defined bytes plus \0 */ #define FASTBOOT_RESPONSE_LEN (64 + 1)
-void fastboot_fail(const char *reason); -void fastboot_okay(const char *reason); +void fastboot_fail(const char *reason, char *response); +void fastboot_okay(const char *reason, char *response);
#endif /* _FASTBOOT_H_ */ diff --git a/include/fb_mmc.h b/include/fb_mmc.h index a2d7c48..39a960c 100644 --- a/include/fb_mmc.h +++ b/include/fb_mmc.h @@ -4,5 +4,5 @@ */
void fb_mmc_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes); -void fb_mmc_erase(const char *cmd); + unsigned int download_bytes, char *response); +void fb_mmc_erase(const char *cmd, char *response); diff --git a/include/fb_nand.h b/include/fb_nand.h index 3daae8c..2c92a4e 100644 --- a/include/fb_nand.h +++ b/include/fb_nand.h @@ -5,5 +5,5 @@ */
void fb_nand_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes); -void fb_nand_erase(const char *cmd); + unsigned int download_bytes, char *response); +void fb_nand_erase(const char *cmd, char *response); diff --git a/include/image-sparse.h b/include/image-sparse.h index f39dc16..234c237 100644 --- a/include/image-sparse.h +++ b/include/image-sparse.h @@ -23,7 +23,7 @@ struct sparse_storage { lbaint_t blk, lbaint_t blkcnt);
- void (*mssg)(const char *str); + void (*mssg)(const char *str, char *response); };
static inline int is_sparse_image(void *buf) @@ -38,4 +38,4 @@ static inline int is_sparse_image(void *buf) }
int write_sparse_image(struct sparse_storage *info, const char *part_name, - void *data); + void *data, char *response);
Add drivers/fastboot/fb_common.c, where fastboot_okay/fail are implemented so we can call them from a non-USB implementation.
Introduce fastboot_response which takes varargs parameters so we can use it to generate formatted response strings. Refactor fastboot_okay/fail to use it.
Changes in v3: - Merge subsequent patch for formatting response strings into this one - allow NULL to fastboot_okay() when there's no message to send
Changes in v2: None
drivers/fastboot/Makefile | 2 ++ drivers/fastboot/fb_common.c | 49 +++++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/f_fastboot.c | 13 ----------- include/fastboot.h | 4 ++++ 4 files changed, 55 insertions(+), 13 deletions(-) create mode 100644 drivers/fastboot/fb_common.c
diff --git a/drivers/fastboot/Makefile b/drivers/fastboot/Makefile index 651fbf0..b38dcff 100644 --- a/drivers/fastboot/Makefile +++ b/drivers/fastboot/Makefile @@ -1,5 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
+obj-y += fb_common.o + ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV obj-y += fb_mmc.o endif diff --git a/drivers/fastboot/fb_common.c b/drivers/fastboot/fb_common.c new file mode 100644 index 0000000..c9638f1 --- /dev/null +++ b/drivers/fastboot/fb_common.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2008 - 2009 + * Windriver, <www.windriver.com> + * Tom Rix Tom.Rix@windriver.com + * + * Copyright 2011 Sebastian Andrzej Siewior bigeasy@linutronix.de + * + * Copyright 2014 Linaro, Ltd. + * Rob Herring robh@kernel.org + */ + +#include <common.h> +#include <fastboot.h> + +/** + * Writes a response to response buffer of the form "$tag$reason". + * + * @param tag The first part of the response + * @param response Pointer to fastboot response buffer + * @param format printf style format string + */ +void fastboot_response(const char *tag, char *response, + const char *format, ...) +{ + va_list args; + + strlcpy(response, tag, FASTBOOT_RESPONSE_LEN); + if (format) { + va_start(args, format); + vsnprintf(response + strlen(response), + FASTBOOT_RESPONSE_LEN - strlen(response) - 1, + format, args); + va_end(args); + } +} + +void fastboot_fail(const char *reason, char *response) +{ + fastboot_response("FAIL", response, "%s", reason); +} + +void fastboot_okay(const char *reason, char *response) +{ + if (reason) + fastboot_response("OKAY", response, "%s", reason); + else + fastboot_response("OKAY", response, NULL); +} diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index bb60612..2e6e161 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -149,19 +149,6 @@ static struct usb_gadget_strings *fastboot_strings[] = { static void rx_handler_command(struct usb_ep *ep, struct usb_request *req); static int strcmp_l1(const char *s1, const char *s2);
- -void fastboot_fail(const char *reason, char *response) -{ - strncpy(response, "FAIL\0", 5); - strncat(response, reason, FASTBOOT_RESPONSE_LEN - 4 - 1); -} - -void fastboot_okay(const char *reason, char *response) -{ - strncpy(response, "OKAY\0", 5); - strncat(response, reason, FASTBOOT_RESPONSE_LEN - 4 - 1); -} - static void fastboot_complete(struct usb_ep *ep, struct usb_request *req) { int status = req->status; diff --git a/include/fastboot.h b/include/fastboot.h index ed52dae..434c46b 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -15,6 +15,10 @@ /* The 64 defined bytes plus \0 */ #define FASTBOOT_RESPONSE_LEN (64 + 1)
+void fastboot_response(const char *tag, char *response, + const char *format, ...) + __attribute__ ((format (__printf__, 3, 4))); + void fastboot_fail(const char *reason, char *response); void fastboot_okay(const char *reason, char *response);
Ensure that when selecting FASTBOOT_FLASH you end up with a buildable configuration. Prior to this you could select NAND without MTDPARTS and end up with an image which (surprisingly) excluded NAND.
Also fix dependencies on FASTBOOT_GPT_NAME/FASTBOOT_MBR_NAME which require you have EFI_PARTITION/DOS_PARTITION enabled.
Changes in v3: - guard FASTBOOT_GPT_NAME/FASTBOOT_MBR_NAME with EFI/DOS_PARTITION
Changes in v2: None
arch/arm/mach-omap2/utils.c | 4 ++-- drivers/fastboot/Kconfig | 8 ++++---- drivers/fastboot/Makefile | 8 ++------ drivers/usb/gadget/f_fastboot.c | 14 +++++++------- 4 files changed, 15 insertions(+), 19 deletions(-)
diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index dc7b37f..edf5edc 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -85,7 +85,7 @@ static void omap_set_fastboot_board_rev(void) env_set("fastboot.board_rev", board_rev); }
-#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#ifdef CONFIG_FASTBOOT_FLASH_MMC static u32 omap_mmc_get_part_size(const char *part) { int res; @@ -128,7 +128,7 @@ static void omap_set_fastboot_userdata_size(void) static inline void omap_set_fastboot_userdata_size(void) { } -#endif /* CONFIG_FASTBOOT_FLASH_MMC_DEV */ +#endif /* CONFIG_FASTBOOT_FLASH_MMC */ void omap_set_fastboot_vars(void) { omap_set_fastboot_cpu(); diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index 93a8ac6..51c5789 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -56,6 +56,7 @@ config FASTBOOT_USB_DEV config FASTBOOT_FLASH bool "Enable FASTBOOT FLASH command" default y if ARCH_SUNXI + depends on MMC || (NAND && CMD_MTDPARTS) help The fastboot protocol includes a "flash" command for writing the downloaded image to a non-volatile storage device. Define @@ -71,7 +72,7 @@ config FASTBOOT_FLASH_MMC
config FASTBOOT_FLASH_NAND bool "FASTBOOT on NAND" - depends on NAND + depends on NAND && CMD_MTDPARTS
endchoice
@@ -88,7 +89,6 @@ config FASTBOOT_FLASH_MMC_DEV config FASTBOOT_FLASH_NAND_DEV int "Define FASTBOOT NAND FLASH default device" depends on FASTBOOT_FLASH_NAND - depends on CMD_MTDPARTS default 0 if ARCH_SUNXI && NAND_SUNXI help The fastboot "flash" command requires additional information @@ -97,7 +97,7 @@ config FASTBOOT_FLASH_NAND_DEV
config FASTBOOT_GPT_NAME string "Target name for updating GPT" - depends on FASTBOOT_FLASH + depends on FASTBOOT_FLASH_MMC && EFI_PARTITION default "gpt" help The fastboot "flash" command supports writing the downloaded @@ -110,7 +110,7 @@ config FASTBOOT_GPT_NAME
config FASTBOOT_MBR_NAME string "Target name for updating MBR" - depends on FASTBOOT_FLASH + depends on FASTBOOT_FLASH_MMC && DOS_PARTITION default "mbr" help The fastboot "flash" command allows to write the downloaded image diff --git a/drivers/fastboot/Makefile b/drivers/fastboot/Makefile index b38dcff..e4bd389 100644 --- a/drivers/fastboot/Makefile +++ b/drivers/fastboot/Makefile @@ -2,9 +2,5 @@
-ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV -obj-y += fb_mmc.o -endif -ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV -obj-y += fb_nand.o -endif +obj-$(CONFIG_FASTBOOT_FLASH_MMC) += fb_mmc.o +obj-$(CONFIG_FASTBOOT_FLASH_NAND) += fb_nand.o diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 2e6e161..323ac89 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -20,10 +20,10 @@ #include <linux/compiler.h> #include <version.h> #include <g_dnl.h> -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#ifdef CONFIG_FASTBOOT_FLASH_MMC #include <fb_mmc.h> #endif -#ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV +#ifdef CONFIG_FASTBOOT_FLASH_NAND #include <fb_nand.h> #endif
@@ -583,11 +583,11 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) }
fastboot_fail("no flash device defined", response); -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#ifdef CONFIG_FASTBOOT_FLASH_MMC fb_mmc_flash_write(cmd, (void *)CONFIG_FASTBOOT_BUF_ADDR, download_bytes, response); #endif -#ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV +#ifdef CONFIG_FASTBOOT_FLASH_NAND fb_nand_flash_write(cmd, (void *)CONFIG_FASTBOOT_BUF_ADDR, download_bytes, response); #endif @@ -598,7 +598,7 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) static void cb_oem(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#ifdef CONFIG_FASTBOOT_FLASH_MMC if (strncmp("format", cmd + 4, 6) == 0) { char cmdbuf[32]; sprintf(cmdbuf, "gpt write mmc %x $partitions", @@ -631,10 +631,10 @@ static void cb_erase(struct usb_ep *ep, struct usb_request *req) }
fastboot_fail("no flash device defined", response); -#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#ifdef CONFIG_FASTBOOT_FLASH_MMC fb_mmc_erase(cmd, response); #endif -#ifdef CONFIG_FASTBOOT_FLASH_NAND_DEV +#ifdef CONFIG_FASTBOOT_FLASH_NAND fb_nand_erase(cmd, response); #endif fastboot_tx_write_str(response);
Add newlines so we format our output correctly.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com Acked-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Jocelyn Bohr bohr@google.com ---
drivers/fastboot/fb_mmc.c | 28 ++++++++++++++-------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index 1bcb2e5..b1db296 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -125,7 +125,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, sector_size = info->blksz; hdr_sectors = DIV_ROUND_UP(sizeof(struct andr_img_hdr), sector_size); if (hdr_sectors == 0) { - pr_err("invalid number of boot sectors: 0"); + pr_err("invalid number of boot sectors: 0\n"); fastboot_fail("invalid number of boot sectors: 0", response); return 0; } @@ -133,7 +133,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, /* Read the boot image header */ res = blk_dread(dev_desc, info->start, hdr_sectors, (void *)hdr); if (res != hdr_sectors) { - pr_err("cannot read header from boot partition"); + pr_err("cannot read header from boot partition\n"); fastboot_fail("cannot read header from boot partition", response); return 0; @@ -142,7 +142,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, /* Check boot header magic string */ res = android_image_check_header(hdr); if (res != 0) { - pr_err("bad boot image magic"); + pr_err("bad boot image magic\n"); fastboot_fail("boot partition not initialized", response); return 0; } @@ -181,7 +181,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, /* Get boot partition info */ res = part_get_info_by_name(dev_desc, BOOT_PARTITION_NAME, &info); if (res < 0) { - pr_err("cannot find boot partition"); + pr_err("cannot find boot partition\n"); fastboot_fail("cannot find boot partition", response); return -1; } @@ -193,14 +193,14 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, /* Read boot image header */ hdr_sectors = fb_mmc_get_boot_header(dev_desc, &info, hdr, response); if (hdr_sectors == 0) { - pr_err("unable to read boot image header"); + pr_err("unable to read boot image header\n"); fastboot_fail("unable to read boot image header", response); return -1; }
/* Check if boot image has second stage in it (we don't support it) */ if (hdr->second_size > 0) { - pr_err("moving second stage is not supported yet"); + pr_err("moving second stage is not supported yet\n"); fastboot_fail("moving second stage is not supported yet", response); return -1; @@ -219,7 +219,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dread(dev_desc, ramdisk_sector_start, ramdisk_sectors, ramdisk_buffer); if (res != ramdisk_sectors) { - pr_err("cannot read ramdisk from boot partition"); + pr_err("cannot read ramdisk from boot partition\n"); fastboot_fail("cannot read ramdisk from boot partition", response); return -1; @@ -229,7 +229,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, hdr->kernel_size = download_bytes; res = blk_dwrite(dev_desc, info.start, hdr_sectors, (void *)hdr); if (res == 0) { - pr_err("cannot writeback boot image header"); + pr_err("cannot writeback boot image header\n"); fastboot_fail("cannot write back boot image header", response); return -1; } @@ -241,7 +241,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dwrite(dev_desc, kernel_sector_start, kernel_sectors, download_buffer); if (res == 0) { - pr_err("cannot write new kernel"); + pr_err("cannot write new kernel\n"); fastboot_fail("cannot write new kernel", response); return -1; } @@ -253,7 +253,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dwrite(dev_desc, ramdisk_sector_start, ramdisk_sectors, ramdisk_buffer); if (res == 0) { - pr_err("cannot write back original ramdisk"); + pr_err("cannot write back original ramdisk\n"); fastboot_fail("cannot write back original ramdisk", response); return -1; } @@ -371,21 +371,21 @@ void fb_mmc_erase(const char *cmd, char *response) struct mmc *mmc = find_mmc_device(CONFIG_FASTBOOT_FLASH_MMC_DEV);
if (mmc == NULL) { - pr_err("invalid mmc device"); + pr_err("invalid mmc device\n"); fastboot_fail("invalid mmc device", response); return; }
dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { - pr_err("invalid mmc device"); + pr_err("invalid mmc device\n"); fastboot_fail("invalid mmc device", response); return; }
ret = part_get_info_by_name_or_alias(dev_desc, cmd, &info); if (ret < 0) { - pr_err("cannot find partition: '%s'", cmd); + pr_err("cannot find partition: '%s'\n", cmd); fastboot_fail("cannot find partition", response); return; } @@ -404,7 +404,7 @@ void fb_mmc_erase(const char *cmd, char *response)
blks = blk_derase(dev_desc, blks_start, blks_size); if (blks != blks_size) { - pr_err("failed erasing from device %d", dev_desc->devnum); + pr_err("failed erasing from device %d\n", dev_desc->devnum); fastboot_fail("failed erasing from device", response); return; }
CONFIG_FASTBOOT_GPT_NAME and CONFIG_FASTBOOT_MBR_NAME are always defined by Kconfig if you're compiling this code, so remove these redundant defaults.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
Changes in v3: - new
Changes in v2: None
drivers/fastboot/fb_mmc.c | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index b1db296..038905f 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -15,19 +15,6 @@ #include <linux/compat.h> #include <android_image.h>
-/* - * FIXME: Ensure we always set these names via Kconfig once xxx_PARTITION is - * migrated - */ -#ifndef CONFIG_FASTBOOT_GPT_NAME -#define CONFIG_FASTBOOT_GPT_NAME "gpt" -#endif - - -#ifndef CONFIG_FASTBOOT_MBR_NAME -#define CONFIG_FASTBOOT_MBR_NAME "mbr" -#endif - #define BOOT_PARTITION_NAME "boot"
struct fb_mmc_sparse {
Changes in v3:
- new
Changes in v2: None
Compiling on a 64 bit target the arguments to _fb_nand_write are incompatible:
drivers/fastboot/fb_nand.c: In function ‘_fb_nand_write’: drivers/fastboot/fb_nand.c:101:42: warning: passing argument 3 of ‘nand_write_skip_bad’ from incompatible pointer type [-Wincompatible-pointer-types] return nand_write_skip_bad(mtd, offset, &length, written, ^ In file included from drivers/fastboot/fb_nand.c:16:0: include/nand.h:107:5: note: expected ‘size_t * {aka long unsigned int *}’ but argument is of type ‘unsigned int *’ int nand_write_skip_bad(struct mtd_info *mtd, loff_t offset, size_t *length, ^~~~~~~~~~~~~~~~~~~ Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
Changes in v2: None
drivers/fastboot/fb_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index 2ee0d64..849a6f1 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -89,7 +89,7 @@ static int _fb_nand_erase(struct mtd_info *mtd, struct part_info *part)
static int _fb_nand_write(struct mtd_info *mtd, struct part_info *part, void *buffer, unsigned int offset, - unsigned int length, size_t *written) + size_t length, size_t *written) { int flags = WITH_WR_VERIFY;
Changes in v3:
- new
Changes in v2: None
Rename fb_set_reboot_flag to fastboot_set_reboot_flag so it matches all other fastboot code in the global name space. Fix the guards around them so that they're dependent on FASTBOOT, not just USB_FUNCTION_FASTBOOT.
Move the weak implementation of fastboot_set_reboot_flag to fb_common.c so we can call it from non-USB fastboot code.
Changes in v2: None
arch/arm/mach-omap2/boot-common.c | 4 ++-- arch/arm/mach-rockchip/rk3128-board.c | 4 ++-- arch/arm/mach-rockchip/rk322x-board.c | 4 ++-- board/amazon/kc1/kc1.c | 2 +- board/lg/sniper/sniper.c | 2 +- drivers/fastboot/fb_common.c | 5 +++++ drivers/usb/gadget/f_fastboot.c | 7 +------ include/fastboot.h | 2 +- 8 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index 0e9fd03..b22b671 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -237,8 +237,8 @@ void arch_preboot_os(void) } #endif
-#if defined(CONFIG_USB_FUNCTION_FASTBOOT) && !defined(CONFIG_ENV_IS_NOWHERE) -int fb_set_reboot_flag(void) +#if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) +int fastboot_set_reboot_flag(void) { printf("Setting reboot to fastboot flag ...\n"); env_set("dofastboot", "1"); diff --git a/arch/arm/mach-rockchip/rk3128-board.c b/arch/arm/mach-rockchip/rk3128-board.c index 48cd8ba..7fd667a 100644 --- a/arch/arm/mach-rockchip/rk3128-board.c +++ b/arch/arm/mach-rockchip/rk3128-board.c @@ -111,8 +111,8 @@ int board_usb_cleanup(int index, enum usb_init_type init) } #endif
-#if defined(CONFIG_USB_FUNCTION_FASTBOOT) -int fb_set_reboot_flag(void) +#if CONFIG_IS_ENABLED(FASTBOOT) +int fastboot_set_reboot_flag(void) { struct rk3128_grf *grf;
diff --git a/arch/arm/mach-rockchip/rk322x-board.c b/arch/arm/mach-rockchip/rk322x-board.c index 99a60c4..7366d45 100644 --- a/arch/arm/mach-rockchip/rk322x-board.c +++ b/arch/arm/mach-rockchip/rk322x-board.c @@ -139,8 +139,8 @@ int board_usb_cleanup(int index, enum usb_init_type init) } #endif
-#if defined(CONFIG_USB_FUNCTION_FASTBOOT) -int fb_set_reboot_flag(void) +#if CONFIG_IS_ENABLED(FASTBOOT) +int fastboot_set_reboot_flag(void) { struct rk322x_grf *grf;
diff --git a/board/amazon/kc1/kc1.c b/board/amazon/kc1/kc1.c index d9ca183..031fd11 100644 --- a/board/amazon/kc1/kc1.c +++ b/board/amazon/kc1/kc1.c @@ -161,7 +161,7 @@ void get_board_serial(struct tag_serialnr *serialnr) omap_die_id_get_board_serial(serialnr); }
-int fb_set_reboot_flag(void) +int fastboot_set_reboot_flag(void) { return omap_reboot_mode_store("b"); } diff --git a/board/lg/sniper/sniper.c b/board/lg/sniper/sniper.c index 34a7a11..a7de4c2 100644 --- a/board/lg/sniper/sniper.c +++ b/board/lg/sniper/sniper.c @@ -173,7 +173,7 @@ void reset_misc(void) omap_reboot_mode_store(reboot_mode); }
-int fb_set_reboot_flag(void) +int fastboot_set_reboot_flag(void) { return omap_reboot_mode_store("b"); } diff --git a/drivers/fastboot/fb_common.c b/drivers/fastboot/fb_common.c index c9638f1..e74f3a0 100644 --- a/drivers/fastboot/fb_common.c +++ b/drivers/fastboot/fb_common.c @@ -47,3 +47,8 @@ void fastboot_okay(const char *reason, char *response) else fastboot_response("OKAY", response, NULL); } + +int __weak fastboot_set_reboot_flag(void) +{ + return -ENOSYS; +} diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 323ac89..697eee5 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -357,16 +357,11 @@ static void compl_do_reset(struct usb_ep *ep, struct usb_request *req) do_reset(NULL, 0, 0, NULL); }
-int __weak fb_set_reboot_flag(void) -{ - return -ENOSYS; -} - static void cb_reboot(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; if (!strcmp_l1("reboot-bootloader", cmd)) { - if (fb_set_reboot_flag()) { + if (fastboot_set_reboot_flag()) { fastboot_tx_write_str("FAILCannot set reboot flag"); return; } diff --git a/include/fastboot.h b/include/fastboot.h index 434c46b..f2ef51c 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -21,5 +21,5 @@ void fastboot_response(const char *tag, char *response,
void fastboot_fail(const char *reason, char *response); void fastboot_okay(const char *reason, char *response); - +int fastboot_set_reboot_flag(void); #endif /* _FASTBOOT_H_ */
Changes in v3:
- new
Changes in v2: None
Move strcmp_l1() to include/common.h so we can can call it from elsewhere. Move FASTBOOT_VERSION to include/fastboot.h so when we merge the UDP code we only have one definition.
Changes in v2: None
drivers/usb/gadget/f_fastboot.c | 10 ---------- include/common.h | 13 +++++++++++++ include/fastboot.h | 2 ++ 3 files changed, 15 insertions(+), 10 deletions(-)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 697eee5..ad76351 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -27,8 +27,6 @@ #include <fb_nand.h> #endif
-#define FASTBOOT_VERSION "0.4" - #define FASTBOOT_INTERFACE_CLASS 0xff #define FASTBOOT_INTERFACE_SUB_CLASS 0x42 #define FASTBOOT_INTERFACE_PROTOCOL 0x03 @@ -147,7 +145,6 @@ static struct usb_gadget_strings *fastboot_strings[] = { };
static void rx_handler_command(struct usb_ep *ep, struct usb_request *req); -static int strcmp_l1(const char *s1, const char *s2);
static void fastboot_complete(struct usb_ep *ep, struct usb_request *req) { @@ -370,13 +367,6 @@ static void cb_reboot(struct usb_ep *ep, struct usb_request *req) fastboot_tx_write_str("OKAY"); }
-static int strcmp_l1(const char *s1, const char *s2) -{ - if (!s1 || !s2) - return -1; - return strncmp(s1, s2, strlen(s1)); -} - static void cb_getvar(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; diff --git a/include/common.h b/include/common.h index 60c7913..5ba111d 100644 --- a/include/common.h +++ b/include/common.h @@ -524,6 +524,19 @@ static inline struct in_addr env_get_ip(char *var)
int pcmcia_init (void);
+/** + * Compare strings over the length of s1 + * + * @param s1 Pointer to string which limits the comparison + * @param s2 Second string + */ +static inline int strcmp_l1(const char *s1, const char *s2) +{ + if (!s1 || !s2) + return -1; + return strncmp(s1, s2, strlen(s1)); +} + #ifdef CONFIG_LED_STATUS # include <status_led.h> #endif diff --git a/include/fastboot.h b/include/fastboot.h index f2ef51c..593e6a7 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -12,6 +12,8 @@ #ifndef _FASTBOOT_H_ #define _FASTBOOT_H_
+#define FASTBOOT_VERSION "0.4" + /* The 64 defined bytes plus \0 */ #define FASTBOOT_RESPONSE_LEN (64 + 1)
Changes in v3:
- new
Changes in v2: None
Can you please add this to string.h instead? We are trying to reduce / remove common.h
elsewhere.
code
Changes in v3:
- new
Changes in v2: None
When I was looking through the size changes, I realised that by the time I was done I'd removed this completely, so I'll just drop it altogether.
Overriding fastboot_set_reboot_flag() in arch/arm/mach-omap2/boot-common.c leaves it applying all boards that derive from this, not just the ones which have support for Android bootloader flow. Move the weak function override to the relevant board files.
Changes in v2: None
arch/arm/mach-omap2/boot-common.c | 10 ---------- board/ti/am57xx/board.c | 10 ++++++++++ board/ti/dra7xx/evm.c | 10 ++++++++++ 3 files changed, 20 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index b22b671..d4a1e2e 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -236,13 +236,3 @@ void arch_preboot_os(void) ahci_reset((void __iomem *)DWC_AHSATA_BASE); } #endif - -#if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) -int fastboot_set_reboot_flag(void) -{ - printf("Setting reboot to fastboot flag ...\n"); - env_set("dofastboot", "1"); - env_save(); - return 0; -} -#endif diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index fd9d207..177a324 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -1178,5 +1178,15 @@ void board_tee_image_process(ulong tee_image, size_t tee_size) secure_tee_install((u32)tee_image); }
+#if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) +int fastboot_set_reboot_flag(void) +{ + printf("Setting reboot to fastboot flag ...\n"); + env_set("dofastboot", "1"); + env_save(); + return 0; +} +#endif + U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_TEE, board_tee_image_process); #endif diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 6918f4d..bbe5445 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -1188,5 +1188,15 @@ void board_tee_image_process(ulong tee_image, size_t tee_size) secure_tee_install((u32)tee_image); }
Changes in v3:
- new
Changes in v2: None
Add fs_get_type_name so we can get the current filesystem type.
Changes in v2: None
fs/fs.c | 5 +++++ include/fs.h | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/fs/fs.c b/fs/fs.c index 94cdc37..1c095a3 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -265,6 +265,11 @@ static struct fstype_info *fs_get_info(int fstype) return info; }
+const char *fs_get_type_name(void) +{ + return fs_get_info(fs_type)->name; +} + int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype) { struct fstype_info *info; diff --git a/include/fs.h b/include/fs.h index d703ed5..47dc51c 100644 --- a/include/fs.h +++ b/include/fs.h @@ -38,6 +38,11 @@ int fs_set_blk_dev(const char *ifname, const char *dev_part_str, int fstype); int fs_set_blk_dev_with_part(struct blk_desc *desc, int part);
/* + * fs_get_type_name - Get type of current filesystem + */ +const char *fs_get_type_name(void); + +/* * Print the list of files on the partition previously set by fs_set_blk_dev(), * in directory "dirname". *
Changes in v3:
- new
Changes in v2: None
Note this comment style does not match docbook, but I suppose it is OK, since the rest of fs.h doesn't either.
Merge UDP fastboot support from AOSP:
https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-io...
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com Signed-off-by: Alex Deymo deymo@google.com Signed-off-by: Jocelyn Bohr bohr@google.com ---
Changes in v3: - use FASTBOOT as our guard in Kconfig not a list of USB || UDP - correct mis-translation from AOSP introduced when cleaning up for checkpatch - we should write when buffer is not NULL, rather than erasing, and erase when buffer is NULL - use CMD_RET_USAGE from do_fastboot - remove do_fastboot_udp from cmd/net.c and rewrite using net_loop() - rename timed_send_info to fastboot_send_info, rename fastboot_send_info to fastboot_udp_send_info - replace FASTBOOT_HEADER_SIZE with sizeof(struct fastboot_header) - move start time into timed_send_info() rather than passing it in - make calls to fastboot_udp_send_info a runtime dependency, not a compile time one - set ${filesize} to size of downloaded image - add progress meter from USB path during download - add support for 'oem format' command from the USB path - rename 'fastbootcmd' to 'fastboot_bootcmd' to make clear that this is the fastboot boot command - make getvar implementation table driven - add fastboot_buf_addr, fastboot_buf_size to override buffer address and size - return correct filesystem type in getvar partition-type on MMC - process "fastboot." prefixed env variables in getvar first so you can override the normal values (this also lets you set a fs type for NAND devices) - squash subsequent patches which change this code into this one: - If the fastboot flash/erase commands are disabled, remove that support so we still build correctly. - Add NAND support to fastboot UDP flash/erase commands - If we don't have a partition name passed, report it as not found. - Change the behaviour of the fastboot net code such that "reboot-bootloader" is no longer written to CONFIG_FASTBOOT_BUF_ADDR for use as a marker on reboot (the AOSP code in common/android-bootloader.c uses this marker - this code could be reinstated there if that gets merged). - Merge USB and UDP boot code. The USB implementation stays the same, but UDP no longer passes an fdt. We introduce a new environment variable 'fastboot_bootcmd' which if set overrides the hardcoded boot command, setting this then allows the UDP implementation to remain the same. If after running 'fastboot_bootcmd' the board has not booted, control is returned to U-Boot and the fastboot process ends. - Separate the fastboot protocol handling from the fastboot UDP code in preparation for reusing it in the USB code.
Changes in v2: - ensure fastboot syntax is backward compatible - 'fastboot 0' means 'fastboot usb 0'
cmd/fastboot.c | 91 ++++++++++++- drivers/fastboot/Kconfig | 15 ++ drivers/fastboot/Makefile | 2 + drivers/fastboot/fb_command.c | 258 +++++++++++++++++++++++++++++++++++ drivers/fastboot/fb_common.c | 48 +++++++ drivers/fastboot/fb_getvar.c | 222 ++++++++++++++++++++++++++++++ drivers/fastboot/fb_mmc.c | 67 ++++++++- drivers/fastboot/fb_nand.c | 12 +- include/fastboot.h | 47 +++++++ include/fb_mmc.h | 8 +- include/fb_nand.h | 10 +- include/net.h | 2 +- include/net/fastboot.h | 21 +++ net/Makefile | 1 + net/fastboot.c | 310 ++++++++++++++++++++++++++++++++++++++++++ net/net.c | 7 + 16 files changed, 1105 insertions(+), 16 deletions(-) create mode 100644 drivers/fastboot/fb_command.c create mode 100644 drivers/fastboot/fb_getvar.c create mode 100644 include/net/fastboot.h create mode 100644 net/fastboot.c
diff --git a/cmd/fastboot.c b/cmd/fastboot.c index a5ec5f4..557257a 100644 --- a/cmd/fastboot.c +++ b/cmd/fastboot.c @@ -10,10 +10,32 @@ #include <command.h> #include <console.h> #include <g_dnl.h> +#include <fastboot.h> +#include <net.h> #include <usb.h>
-static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +static int do_fastboot_udp(int argc, char *const argv[], + uintptr_t buf_addr, size_t buf_size) { +#if CONFIG_IS_ENABLED(UDP_FUNCTION_FASTBOOT) + int err = net_loop(FASTBOOT); + + if (err < 0) { + printf("fastboot udp error: %d\n", err); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +#else + pr_err("Fastboot UDP not enabled\n"); + return CMD_RET_FAILURE; +#endif +} + +static int do_fastboot_usb(int argc, char *const argv[], + uintptr_t buf_addr, size_t buf_size) +{ +#if CONFIG_IS_ENABLED(USB_FUNCTION_FASTBOOT) int controller_index; char *usb_controller; int ret; @@ -58,11 +80,70 @@ exit: board_usb_cleanup(controller_index, USB_INIT_DEVICE);
return ret; +#else + pr_err("Fastboot USB not enabled\n"); + return CMD_RET_FAILURE; +#endif +} + +static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + uintptr_t buf_addr = (uintptr_t)NULL; + size_t buf_size = 0; + + if (argc < 2) + return CMD_RET_USAGE; + + while (argc > 1 && **(argv + 1) == '-') { + char *arg = *++argv; + + --argc; + while (*++arg) { + switch (*arg) { + case 'l': + if (--argc <= 0) + return CMD_RET_USAGE; + buf_addr = simple_strtoul(*++argv, NULL, 16); + goto NXTARG; + + case 's': + if (--argc <= 0) + return CMD_RET_USAGE; + buf_size = simple_strtoul(*++argv, NULL, 16); + goto NXTARG; + + default: + return CMD_RET_USAGE; + } + } +NXTARG: + ; + } + + fastboot_init((void *)buf_addr, buf_size); + + if (!strcmp(argv[1], "udp")) + return do_fastboot_udp(argc, argv, buf_addr, buf_size); + + if (!strcmp(argv[1], "usb")) { + argv++; + argc--; + } + + return do_fastboot_usb(argc, argv, buf_addr, buf_size); }
+#ifdef CONFIG_SYS_LONGHELP +static char fastboot_help_text[] = + "[-l addr] [-s size] usb <controller> | udp\n" + "\taddr - address of buffer used during data transfers (" + __stringify(CONFIG_FASTBOOT_BUF_ADDR) ")\n" + "\tsize - size of buffer used during data transfers (" + __stringify(CONFIG_FASTBOOT_BUF_SIZE) ")" + ; +#endif + U_BOOT_CMD( - fastboot, 2, 1, do_fastboot, - "use USB Fastboot protocol", - "<USB_controller>\n" - " - run as a fastboot usb device" + fastboot, CONFIG_SYS_MAXARGS, 1, do_fastboot, + "run as a fastboot usb or udp device", fastboot_help_text ); diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index 51c5789..a79f456 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -14,6 +14,13 @@ config USB_FUNCTION_FASTBOOT help This enables the USB part of the fastboot gadget.
+config UDP_FUNCTION_FASTBOOT + depends on NET + select FASTBOOT + bool "Enable fastboot protocol over UDP" + help + This enables the fastboot protocol over UDP. + if FASTBOOT
config FASTBOOT_BUF_ADDR @@ -118,6 +125,14 @@ config FASTBOOT_MBR_NAME specified on the "fastboot flash" command line matches the value defined here. The default target name for updating MBR is "mbr".
+config FASTBOOT_CMD_OEM_FORMAT + bool "Enable the 'oem format' command" + depends on FASTBOOT_FLASH_MMC && CMD_GPT + help + Add support for the "oem format" command from a client. This + relies on the env variable partitions to contain the list of + partitions as required by the gpt command. + endif # FASTBOOT
endmenu diff --git a/drivers/fastboot/Makefile b/drivers/fastboot/Makefile index e4bd389..149bd02 100644 --- a/drivers/fastboot/Makefile +++ b/drivers/fastboot/Makefile @@ -1,6 +1,8 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += fb_common.o +obj-y += fb_getvar.o +obj-y += fb_command.o
obj-$(CONFIG_FASTBOOT_FLASH_MMC) += fb_mmc.o obj-$(CONFIG_FASTBOOT_FLASH_NAND) += fb_nand.o diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c new file mode 100644 index 0000000..34bf9a2 --- /dev/null +++ b/drivers/fastboot/fb_command.c @@ -0,0 +1,258 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * Copyright (C) 2016 The Android Open Source Project + */ + +#include <common.h> +#include <fastboot.h> +#include <fb_mmc.h> +#include <fb_nand.h> +#include <part.h> +#include <stdlib.h> + +/* Fastboot download parameters */ +static u32 image_size; +u32 fastboot_bytes_received; +u32 fastboot_bytes_expected; + +static void fb_okay(char *, char *); +static void fb_getvar(char *, char *); +static void fb_download(char *, char *); +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) +static void fb_flash(char *, char *); +static void fb_erase(char *, char *); +#endif +static void fb_reboot_bootloader(char *, char *); +#if CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_FORMAT) +static void fb_oem_format(char *, char *); +#endif + +static const struct { + const char *command; + void (*dispatch)(char *cmd_parameter, char *response); +} fb_commands[FASTBOOT_COMMAND_COUNT] = { + [FASTBOOT_COMMAND_GETVAR] = { + .command = "getvar", + .dispatch = fb_getvar + }, + [FASTBOOT_COMMAND_DOWNLOAD] = { + .command = "download", + .dispatch = fb_download + }, +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) + [FASTBOOT_COMMAND_FLASH] = { + .command = "flash", + .dispatch = fb_flash + }, + [FASTBOOT_COMMAND_ERASE] = { + .command = "erase", + .dispatch = fb_erase + }, +#endif + [FASTBOOT_COMMAND_BOOT] = { + .command = "boot", + .dispatch = fb_okay + }, + [FASTBOOT_COMMAND_CONTINUE] = { + .command = "continue", + .dispatch = fb_okay + }, + [FASTBOOT_COMMAND_REBOOT] = { + .command = "reboot", + .dispatch = fb_okay + }, + [FASTBOOT_COMMAND_REBOOT_BOOTLOADER] = { + .command = "reboot-bootloader", + .dispatch = fb_reboot_bootloader + }, + [FASTBOOT_COMMAND_SET_ACTIVE] = { + .command = "set_active", + .dispatch = fb_okay + }, +#if CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_FORMAT) + [FASTBOOT_COMMAND_OEM_FORMAT] = { + .command = "oem format", + .dispatch = fb_oem_format, + }, +#endif +}; + +int fastboot_handle_command(char *cmd_string, char *response) +{ + int i; + char *cmd_parameter; + + cmd_parameter = cmd_string; + strsep(&cmd_parameter, ":"); + + for (i = 0; i < FASTBOOT_COMMAND_COUNT; i++) { + if (!strcmp(fb_commands[i].command, cmd_string)) { + if (fb_commands[i].dispatch) { + fb_commands[i].dispatch(cmd_parameter, + response); + return i; + } else { + break; + } + } + } + + pr_err("command %s not recognized.\n", cmd_string); + fastboot_fail("unrecognized command", response); + return -1; +} + +static void fb_okay(char *cmd_parameter, char *response) +{ + fastboot_okay(NULL, response); +} + +static void fb_getvar(char *cmd_parameter, char *response) +{ + fastboot_getvar(cmd_parameter, response); +} + +static void fb_download(char *cmd_parameter, char *response) +{ + char *tmp; + + if (!cmd_parameter) { + fastboot_fail("Expected command parameter", response); + return; + } + fastboot_bytes_received = 0; + fastboot_bytes_expected = simple_strtoul(cmd_parameter, &tmp, 16); + if (fastboot_bytes_expected == 0) { + fastboot_fail("Expected nonzero image size", response); + return; + } + /* + * Nothing to download yet. Response is of the form: + * [DATA|FAIL]$cmd_parameter + * + * where cmd_parameter is an 8 digit hexadecimal number + */ + if (fastboot_bytes_expected > fastboot_buf_size) { + fastboot_fail(cmd_parameter, response); + } else { + printf("Starting download of %d bytes\n", + fastboot_bytes_expected); + fastboot_response("DATA", response, "%s", cmd_parameter); + } +} + +/** + * Copies image data from fastboot_data to fastboot_buf_addr. + * Writes to response. + * + * @param fastboot_data Pointer to received fastboot data + * @param fastboot_data_len Length of received fastboot data + * @param response Pointer to fastboot response buffer + */ +void fastboot_download_data(const void *fastboot_data, + unsigned int fastboot_data_len, + char *response) +{ + if (fastboot_data_len == 0 && + fastboot_bytes_received >= fastboot_bytes_expected) { + /* Download complete. Respond with "OKAY" */ + fastboot_okay(NULL, response); + printf("\ndownloading of %d bytes finished\n", + fastboot_bytes_received); + image_size = fastboot_bytes_received; + env_set_hex("filesize", image_size); + fastboot_bytes_expected = 0; + fastboot_bytes_received = 0; + } else { +#define BYTES_PER_DOT 0x20000 + u32 pre_dot_num, now_dot_num; + + if (fastboot_data_len == 0 || + (fastboot_bytes_received + fastboot_data_len) > + fastboot_bytes_expected) { + fastboot_fail("Received invalid data length", + response); + return; + } + /* Download data to fastboot_buf_addr */ + memcpy(fastboot_buf_addr + fastboot_bytes_received, + fastboot_data, fastboot_data_len); + + pre_dot_num = fastboot_bytes_received / BYTES_PER_DOT; + fastboot_bytes_received += fastboot_data_len; + now_dot_num = fastboot_bytes_received / BYTES_PER_DOT; + + if (pre_dot_num != now_dot_num) { + putc('.'); + if (!(now_dot_num % 74)) + putc('\n'); + } + } +} + +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) +/** + * Writes the previously downloaded image to the partition indicated by + * cmd_parameter. Writes to response. + * + * @param response Pointer to fastboot response buffer + */ +static void fb_flash(char *cmd_parameter, char *response) +{ +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) + fb_mmc_flash_write(cmd_parameter, fastboot_buf_addr, image_size, + response); +#endif +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_NAND) + fb_nand_flash_write(cmd_parameter, fastboot_buf_addr, image_size, + response); +#endif +} + +/** + * Erases the partition indicated by cmd_parameter (clear to 0x00s). Writes + * to response. + * + * @param response Pointer to fastboot response buffer + */ +static void fb_erase(char *cmd_parameter, char *response) +{ +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) + fb_mmc_erase(cmd_parameter, response); +#endif +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_NAND) + fb_nand_erase(cmd_parameter, response); +#endif +} +#endif + +/** + * Sets reboot bootloader flag if requested. Writes to response. + * + * @param response Pointer to fastboot response buffer + */ +static void fb_reboot_bootloader(char *cmd_parameter, char *response) +{ + if (fastboot_set_reboot_flag()) + fastboot_fail("Cannot set reboot flag", response); + else + fastboot_okay(NULL, response); +} + +#if CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_FORMAT) +static void fb_oem_format(char *cmd_parameter, char *response) +{ + char cmdbuf[32]; + + if (!env_get("partitions")) { + fastboot_fail("partitions not set", response); + } else { + sprintf(cmdbuf, "gpt write mmc %x $partitions", + CONFIG_FASTBOOT_FLASH_MMC_DEV); + if (run_command(cmdbuf, 0)) + fastboot_fail("", response); + else + fastboot_okay(NULL, response); + } +} +#endif diff --git a/drivers/fastboot/fb_common.c b/drivers/fastboot/fb_common.c index e74f3a0..4cbcbb1 100644 --- a/drivers/fastboot/fb_common.c +++ b/drivers/fastboot/fb_common.c @@ -12,6 +12,13 @@
#include <common.h> #include <fastboot.h> +#include <net/fastboot.h> + +/* fastboot download buffer */ +void *fastboot_buf_addr; +u32 fastboot_buf_size; + +void (*fastboot_progress_callback)(const char *msg);
/** * Writes a response to response buffer of the form "$tag$reason". @@ -52,3 +59,44 @@ int __weak fastboot_set_reboot_flag(void) { return -ENOSYS; } + +void fastboot_boot(void *addr) +{ + char *s; + + s = env_get("fastboot_bootcmd"); + if (s) { + run_command(s, CMD_FLAG_ENV); + } else { + static char boot_addr_start[12]; + static char *const bootm_args[] = { + "bootm", boot_addr_start, NULL + }; + + snprintf(boot_addr_start, sizeof(boot_addr_start) - 1, + "0x%lx", (long)addr); + printf("Booting kernel at %s...\n\n\n", boot_addr_start); + + do_bootm(NULL, 0, 2, bootm_args); + + /* + * This only happens if image is somehow faulty so we start + * over. We deliberately leave this policy to the invocation + * of fastbootcmd if that's what's being run + */ + do_reset(NULL, 0, 0, NULL); + } +} + +void fastboot_set_progress_callback(void (*progress)(const char *msg)) +{ + fastboot_progress_callback = progress; +} + +void fastboot_init(void *buf_addr, u32 buf_size) +{ + fastboot_buf_addr = buf_addr ? buf_addr : + (void *)CONFIG_FASTBOOT_BUF_ADDR; + fastboot_buf_size = buf_size ? buf_size : CONFIG_FASTBOOT_BUF_SIZE; + fastboot_set_progress_callback(NULL); +} diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c new file mode 100644 index 0000000..7fc46c3 --- /dev/null +++ b/drivers/fastboot/fb_getvar.c @@ -0,0 +1,222 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * Copyright (C) 2016 The Android Open Source Project + */ + +#include <common.h> +#include <fastboot.h> +#include <fb_mmc.h> +#include <fb_nand.h> +#include <fs.h> +#include <version.h> + +static void fb_getvar_version(char *var_parameter, char *response); +static void fb_getvar_bootloader_version(char *var_parameter, char *response); +static void fb_getvar_downloadsize(char *var_parameter, char *response); +static void fb_getvar_serialno(char *var_parameter, char *response); +static void fb_getvar_version_baseband(char *var_parameter, char *response); +static void fb_getvar_product(char *var_parameter, char *response); +static void fb_getvar_current_slot(char *var_parameter, char *response); +static void fb_getvar_slot_suffixes(char *var_parameter, char *response); +static void fb_getvar_has_slot(char *var_parameter, char *response); +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) +static void fb_getvar_partition_type(char *part_name, char *response); +#endif +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) +static void fb_getvar_partition_size(char *part_name, char *response); +#endif + +static const struct { + const char *variable; + void (*dispatch)(char *var_parameter, char *response); +} fb_getvar_dispatch[] = { + { + .variable = "version", + .dispatch = fb_getvar_version + }, { + .variable = "bootloader-version", + .dispatch = fb_getvar_bootloader_version + }, { + .variable = "version-bootloader", + .dispatch = fb_getvar_bootloader_version + }, { + .variable = "downloadsize", + .dispatch = fb_getvar_downloadsize + }, { + .variable = "max-download-size", + .dispatch = fb_getvar_downloadsize + }, { + .variable = "serialno", + .dispatch = fb_getvar_serialno + }, { + .variable = "version-baseband", + .dispatch = fb_getvar_version_baseband + }, { + .variable = "product", + .dispatch = fb_getvar_product + }, { + .variable = "current-slot", + .dispatch = fb_getvar_current_slot + }, { + .variable = "slot-suffixes", + .dispatch = fb_getvar_slot_suffixes + }, { + .variable = "has_slot", + .dispatch = fb_getvar_has_slot +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) + }, { + .variable = "partition-type", + .dispatch = fb_getvar_partition_type +#endif +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) + }, { + .variable = "partition-size", + .dispatch = fb_getvar_partition_size +#endif + } +}; + +static void fb_getvar_version(char *var_parameter, char *response) +{ + fastboot_okay(FASTBOOT_VERSION, response); +} + +static void fb_getvar_bootloader_version(char *var_parameter, char *response) +{ + fastboot_okay(U_BOOT_VERSION, response); +} + +static void fb_getvar_downloadsize(char *var_parameter, char *response) +{ + fastboot_response("OKAY", response, "0x%08x", fastboot_buf_size); +} + +static void fb_getvar_serialno(char *var_parameter, char *response) +{ + const char *tmp = env_get("serial#"); + + if (tmp) + fastboot_okay(tmp, response); + else + fastboot_fail("Value not set", response); +} + +static void fb_getvar_version_baseband(char *var_parameter, char *response) +{ + fastboot_okay("N/A", response); +} + +static void fb_getvar_product(char *var_parameter, char *response) +{ + const char *board = env_get("board"); + + if (board) + fastboot_okay(board, response); + else + fastboot_fail("Board not set", response); +} + +static void fb_getvar_current_slot(char *var_parameter, char *response) +{ + /* A/B not implemented, for now always return _a */ + fastboot_okay("_a", response); +} + +static void fb_getvar_slot_suffixes(char *var_parameter, char *response) +{ + fastboot_okay("_a,_b", response); +} + +static void fb_getvar_has_slot(char *part_name, char *response) +{ + if (part_name && (!strcmp(part_name, "boot") || + !strcmp(part_name, "system"))) + fastboot_okay("yes", response); + else + fastboot_okay("no", response); +} + +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) +static void fb_getvar_partition_type(char *part_name, char *response) +{ + int r; + struct blk_desc *dev_desc; + disk_partition_t part_info; + + r = fastboot_mmc_get_part_info(part_name, &dev_desc, &part_info, + response); + if (r >= 0) { + r = fs_set_blk_dev_with_part(dev_desc, r); + if (r < 0) + fastboot_fail("failed to set partition", response); + else + fastboot_okay(fs_get_type_name(), response); + } +} +#endif + +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) +static void fb_getvar_partition_size(char *part_name, char *response) +{ + int r; + size_t size; + +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) + struct blk_desc *dev_desc; + disk_partition_t part_info; + + r = fastboot_mmc_get_part_info(part_name, &dev_desc, &part_info, + response); + if (r >= 0) + size = part_info.size; +#endif +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_NAND) + struct part_info *part_info; + + r = fastboot_nand_get_part_info(part_name, &part_info, response); + if (r >= 0) + size = part_info->size; +#endif + if (r >= 0) + fastboot_response("OKAY", response, "0x%016zx", size); +} +#endif + +/** + * Writes ascii string specified by cmd_parameter to response. + * + * @param cmd_parameter Point to command parameter + * @param response Pointer to fastboot response buffer + */ +void fastboot_getvar(char *cmd_parameter, char *response) +{ + if (!cmd_parameter) { + fastboot_fail("missing var", response); + } else { +#define FASTBOOT_ENV_PREFIX "fastboot." + int i; + char *var_parameter = cmd_parameter; + char envstr[FASTBOOT_RESPONSE_LEN]; + const char *s; + + snprintf(envstr, sizeof(envstr) - 1, + FASTBOOT_ENV_PREFIX "%s", cmd_parameter); + s = env_get(envstr); + if (s) { + fastboot_response("OKAY", response, "%s", s); + return; + } + + strsep(&var_parameter, ":"); + for (i = 0; i < ARRAY_SIZE(fb_getvar_dispatch); ++i) { + if (!strcmp(fb_getvar_dispatch[i].variable, + cmd_parameter)) { + fb_getvar_dispatch[i].dispatch(var_parameter, + response); + return; + } + } + pr_warn("WARNING: unknown variable: %s\n", cmd_parameter); + fastboot_fail("Variable not implemented", response); + } +} diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index 038905f..69a78be 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -15,6 +15,8 @@ #include <linux/compat.h> #include <android_image.h>
+#define FASTBOOT_MAX_BLK_WRITE 16384 + #define BOOT_PARTITION_NAME "boot"
struct fb_mmc_sparse { @@ -43,13 +45,40 @@ static int part_get_info_by_name_or_alias(struct blk_desc *dev_desc, return ret; }
+static lbaint_t fb_mmc_blk_write(struct blk_desc *block_dev, lbaint_t start, + lbaint_t blkcnt, const void *buffer) +{ + lbaint_t blk = start; + lbaint_t blks_written; + lbaint_t cur_blkcnt; + lbaint_t blks = 0; + int i; + + for (i = 0; i < blkcnt; i += FASTBOOT_MAX_BLK_WRITE) { + cur_blkcnt = min((int)blkcnt - i, FASTBOOT_MAX_BLK_WRITE); + if (buffer) { + if (fastboot_progress_callback) + fastboot_progress_callback("writing"); + blks_written = blk_dwrite(block_dev, blk, cur_blkcnt, + buffer + (i * block_dev->blksz)); + } else { + if (fastboot_progress_callback) + fastboot_progress_callback("erasing"); + blks_written = blk_derase(block_dev, blk, cur_blkcnt); + } + blk += blks_written; + blks += blks_written; + } + return blks; +} + static lbaint_t fb_mmc_sparse_write(struct sparse_storage *info, lbaint_t blk, lbaint_t blkcnt, const void *buffer) { struct fb_mmc_sparse *sparse = info->priv; struct blk_desc *dev_desc = sparse->dev_desc;
- return blk_dwrite(dev_desc, blk, blkcnt, buffer); + return fb_mmc_blk_write(dev_desc, blk, blkcnt, buffer); }
static lbaint_t fb_mmc_sparse_reserve(struct sparse_storage *info, @@ -60,7 +89,7 @@ static lbaint_t fb_mmc_sparse_reserve(struct sparse_storage *info,
static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info, const char *part_name, void *buffer, - unsigned int download_bytes, char *response) + u32 download_bytes, char *response) { lbaint_t blkcnt; lbaint_t blks; @@ -77,7 +106,8 @@ static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info,
puts("Flashing Raw Image\n");
- blks = blk_dwrite(dev_desc, info->start, blkcnt, buffer); + blks = fb_mmc_blk_write(dev_desc, info->start, blkcnt, buffer); + if (blks != blkcnt) { pr_err("failed writing to device %d\n", dev_desc->devnum); fastboot_fail("failed writing to device", response); @@ -148,7 +178,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, */ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, void *download_buffer, - unsigned int download_bytes, + u32 download_bytes, char *response) { uintptr_t hdr_addr; /* boot image header address */ @@ -251,8 +281,32 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, } #endif
+int fastboot_mmc_get_part_info(char *part_name, struct blk_desc **dev_desc, + disk_partition_t *part_info, char *response) +{ + int r; + + *dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); + if (!*dev_desc) { + fastboot_fail("block device not found", response); + return -ENOENT; + } + if (!part_name) { + fastboot_fail("partition not found", response); + return -ENOENT; + } + + r = part_get_info_by_name_or_alias(*dev_desc, part_name, part_info); + if (r < 0) { + fastboot_fail("partition not found", response); + return r; + } + + return r; +} + void fb_mmc_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes, char *response) + u32 download_bytes, char *response) { struct blk_desc *dev_desc; disk_partition_t info; @@ -389,7 +443,8 @@ void fb_mmc_erase(const char *cmd, char *response) printf("Erasing blocks " LBAFU " to " LBAFU " due to alignment\n", blks_start, blks_start + blks_size);
- blks = blk_derase(dev_desc, blks_start, blks_size); + blks = fb_mmc_blk_write(dev_desc, blks_start, blks_size, NULL); + if (blks != blks_size) { pr_err("failed erasing from device %d\n", dev_desc->devnum); fastboot_fail("failed erasing from device", response); diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index 849a6f1..a7cbc34 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -88,7 +88,7 @@ static int _fb_nand_erase(struct mtd_info *mtd, struct part_info *part) }
static int _fb_nand_write(struct mtd_info *mtd, struct part_info *part, - void *buffer, unsigned int offset, + void *buffer, u32 offset, size_t length, size_t *written) { int flags = WITH_WR_VERIFY; @@ -145,8 +145,16 @@ static lbaint_t fb_nand_sparse_reserve(struct sparse_storage *info, return blkcnt + bad_blocks; }
+int fastboot_nand_get_part_info(char *part_name, struct part_info **part_info, + char *response) +{ + struct mtd_info *mtd = NULL; + + return fb_nand_lookup(part_name, &mtd, part_info, response); +} + void fb_nand_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes, char *response) + u32 download_bytes, char *response) { struct part_info *part; struct mtd_info *mtd = NULL; diff --git a/include/fastboot.h b/include/fastboot.h index 593e6a7..3d9ffc6 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -15,8 +15,39 @@ #define FASTBOOT_VERSION "0.4"
/* The 64 defined bytes plus \0 */ +#define FASTBOOT_COMMAND_LEN (64 + 1) #define FASTBOOT_RESPONSE_LEN (64 + 1)
+/** + * All known commands to fastboot + */ +enum { + FASTBOOT_COMMAND_GETVAR = 0, + FASTBOOT_COMMAND_DOWNLOAD, +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) + FASTBOOT_COMMAND_FLASH, + FASTBOOT_COMMAND_ERASE, +#endif + FASTBOOT_COMMAND_BOOT, + FASTBOOT_COMMAND_CONTINUE, + FASTBOOT_COMMAND_REBOOT, + FASTBOOT_COMMAND_REBOOT_BOOTLOADER, + FASTBOOT_COMMAND_SET_ACTIVE, +#if CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_FORMAT) + FASTBOOT_COMMAND_OEM_FORMAT, +#endif + + FASTBOOT_COMMAND_COUNT +}; + +extern void *fastboot_buf_addr; +extern u32 fastboot_buf_size; + +extern u32 fastboot_bytes_received; +extern u32 fastboot_bytes_expected; + +extern void (*fastboot_progress_callback)(const char *msg); + void fastboot_response(const char *tag, char *response, const char *format, ...) __attribute__ ((format (__printf__, 3, 4))); @@ -24,4 +55,20 @@ void fastboot_response(const char *tag, char *response, void fastboot_fail(const char *reason, char *response); void fastboot_okay(const char *reason, char *response); int fastboot_set_reboot_flag(void); + +/** + * Writes ascii string specified by cmd_parameter to response. + * + * @param cmd_parameter Pointer to variable name + * @param response Pointer to fastboot response buffer + */ +void fastboot_getvar(char *cmd_parameter, char *response); + +void fastboot_init(void *buf_addr, u32 buf_size); +void fastboot_set_progress_callback(void (*progress)(const char *msg)); + +void fastboot_boot(void *addr); +int fastboot_handle_command(char *cmd_string, char *response); +void fastboot_download_data(const void *fastboot_data, + unsigned int fastboot_data_len, char *response); #endif /* _FASTBOOT_H_ */ diff --git a/include/fb_mmc.h b/include/fb_mmc.h index 39a960c..ae01f99 100644 --- a/include/fb_mmc.h +++ b/include/fb_mmc.h @@ -3,6 +3,12 @@ * Copyright 2014 Broadcom Corporation. */
+#ifndef _FB_MMC_H_ +#define _FB_MMC_H_ + +int fastboot_mmc_get_part_info(char *part_name, struct blk_desc **dev_desc, + disk_partition_t *part_info, char *response); void fb_mmc_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes, char *response); + u32 download_bytes, char *response); void fb_mmc_erase(const char *cmd, char *response); +#endif diff --git a/include/fb_nand.h b/include/fb_nand.h index 2c92a4e..937f9e4 100644 --- a/include/fb_nand.h +++ b/include/fb_nand.h @@ -4,6 +4,14 @@ * Copyright 2015 Free Electrons. */
+#ifndef _FB_NAND_H_ +#define _FB_NAND_H_ + +#include <jffs2/load_kernel.h> + +int fastboot_nand_get_part_info(char *part_name, struct part_info **part_info, + char *response); void fb_nand_flash_write(const char *cmd, void *download_buffer, - unsigned int download_bytes, char *response); + u32 download_bytes, char *response); void fb_nand_erase(const char *cmd, char *response); +#endif diff --git a/include/net.h b/include/net.h index 65f51d7..5760685 100644 --- a/include/net.h +++ b/include/net.h @@ -535,7 +535,7 @@ extern int net_restart_wrap; /* Tried all network devices */
enum proto_t { BOOTP, RARP, ARP, TFTPGET, DHCP, PING, DNS, NFS, CDP, NETCONS, SNTP, - TFTPSRV, TFTPPUT, LINKLOCAL + TFTPSRV, TFTPPUT, LINKLOCAL, FASTBOOT };
extern char net_boot_file_name[1024];/* Boot File name */ diff --git a/include/net/fastboot.h b/include/net/fastboot.h new file mode 100644 index 0000000..6860209 --- /dev/null +++ b/include/net/fastboot.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: BSD-2-Clause + * + * Copyright (C) 2016 The Android Open Source Project + */ + +#ifndef __NET_FASTBOOT_H__ +#define __NET_FASTBOOT_H__ + +/**********************************************************************/ +/* + * Global functions and variables. + */ + +/** + * Wait for incoming fastboot comands. + */ +void fastboot_start_server(void); + +/**********************************************************************/ + +#endif /* __NET_FASTBOOT_H__ */ diff --git a/net/Makefile b/net/Makefile index d1e8e01..0746687 100644 --- a/net/Makefile +++ b/net/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_TFTPBOOT) += tftp.o +obj-$(CONFIG_UDP_FUNCTION_FASTBOOT) += fastboot.o
# Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) diff --git a/net/fastboot.c b/net/fastboot.c new file mode 100644 index 0000000..8ec2aa5 --- /dev/null +++ b/net/fastboot.c @@ -0,0 +1,310 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * Copyright (C) 2016 The Android Open Source Project + */ + +#include <common.h> +#include <fastboot.h> +#include <net.h> +#include <net/fastboot.h> + +/* Fastboot port # defined in spec */ +#define WELL_KNOWN_PORT 5554 + +enum { + FASTBOOT_ERROR = 0, + FASTBOOT_QUERY = 1, + FASTBOOT_INIT = 2, + FASTBOOT_FASTBOOT = 3, +}; + +struct __packed fastboot_header { + uchar id; + uchar flags; + unsigned short seq; +}; + +#define PACKET_SIZE 1024 +#define DATA_SIZE (PACKET_SIZE - sizeof(struct fastboot_header)) + +/* Sequence number sent for every packet */ +static unsigned short fb_sequence_number = 1; +static const unsigned short fb_packet_size = PACKET_SIZE; +static const unsigned short fb_udp_version = 1; + +/* Keep track of last packet for resubmission */ +static uchar last_packet[PACKET_SIZE]; +static unsigned int last_packet_len; + +static struct in_addr fastboot_remote_ip; +/* The UDP port at their end */ +static int fastboot_remote_port; +/* The UDP port at our end */ +static int fastboot_our_port; + +static void boot_downloaded_image(void); + +#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) +/** + * Send an INFO packet during long commands + * + * @param msg: String describing the reason for waiting + */ +static void fastboot_udp_send_info(const char *msg) +{ + uchar *packet; + uchar *packet_base; + int len = 0; + char response[FASTBOOT_RESPONSE_LEN] = {0}; + + struct fastboot_header fb_response_header = { + .id = FASTBOOT_FASTBOOT, + .flags = 0, + .seq = htons(fb_sequence_number) + }; + ++fb_sequence_number; + packet = net_tx_packet + net_eth_hdr_size() + IP_UDP_HDR_SIZE; + packet_base = packet; + + /* Write headers */ + memcpy(packet, &fb_response_header, sizeof(fb_response_header)); + packet += sizeof(fb_response_header); + /* Write response */ + fastboot_response("INFO", response, "%s", msg); + memcpy(packet, response, strlen(response)); + packet += strlen(response); + + len = packet - packet_base; + + /* Save packet for retransmitting */ + last_packet_len = len; + memcpy(last_packet, packet_base, last_packet_len); + + net_send_udp_packet(net_server_ethaddr, fastboot_remote_ip, + fastboot_remote_port, fastboot_our_port, len); +} + +/** + * Send an INFO packet during long commands based on timer. An INFO packet + * is sent if the time is 30 seconds after start. Else, noop. + * + * @param msg: String describing the reason for waiting + */ +static void fastboot_timed_send_info(const char *msg) +{ + static ulong start; + + /* Initialize timer */ + if (start == 0) + start = get_timer(0); + ulong time = get_timer(start); + /* Send INFO packet to host every 30 seconds */ + if (time >= 30000) { + start = get_timer(0); + fastboot_udp_send_info(msg); + } +} +#endif + +/** + * Constructs and sends a packet in response to received fastboot packet + * + * @param fb_header Header for response packet + * @param fastboot_data Pointer to received fastboot data + * @param fastboot_data_len Length of received fastboot data + * @param retransmit Nonzero if sending last sent packet + */ +static void fastboot_send(struct fastboot_header fb_header, char *fastboot_data, + unsigned int fastboot_data_len, uchar retransmit) +{ + uchar *packet; + uchar *packet_base; + int len = 0; + const char *error_msg = "An error occurred."; + short tmp; + struct fastboot_header fb_response_header = fb_header; + static char command[FASTBOOT_COMMAND_LEN]; + static int cmd = -1; + static bool pending_command; + char response[FASTBOOT_RESPONSE_LEN] = {0}; + + /* + * We will always be sending some sort of packet, so + * cobble together the packet headers now. + */ + packet = net_tx_packet + net_eth_hdr_size() + IP_UDP_HDR_SIZE; + packet_base = packet; + + /* Resend last packet */ + if (retransmit) { + memcpy(packet, last_packet, last_packet_len); + net_send_udp_packet(net_server_ethaddr, fastboot_remote_ip, + fastboot_remote_port, fastboot_our_port, + last_packet_len); + return; + } + + fb_response_header.seq = htons(fb_response_header.seq); + memcpy(packet, &fb_response_header, sizeof(fb_response_header)); + packet += sizeof(fb_response_header); + + switch (fb_header.id) { + case FASTBOOT_QUERY: + tmp = htons(fb_sequence_number); + memcpy(packet, &tmp, sizeof(tmp)); + packet += sizeof(tmp); + break; + case FASTBOOT_INIT: + tmp = htons(fb_udp_version); + memcpy(packet, &tmp, sizeof(tmp)); + packet += sizeof(tmp); + tmp = htons(fb_packet_size); + memcpy(packet, &tmp, sizeof(tmp)); + packet += sizeof(tmp); + break; + case FASTBOOT_ERROR: + memcpy(packet, error_msg, strlen(error_msg)); + packet += strlen(error_msg); + break; + case FASTBOOT_FASTBOOT: + if (cmd == FASTBOOT_COMMAND_DOWNLOAD) { + fastboot_download_data(fastboot_data, fastboot_data_len, + response); + } else if (!pending_command) { + strlcpy(command, fastboot_data, + min((size_t)fastboot_data_len + 1, + sizeof(command))); + pending_command = true; + } else { + cmd = fastboot_handle_command(command, response); + pending_command = false; + } + /* + * Sent some INFO packets, need to update sequence number in + * header + */ + if (fb_header.seq != fb_sequence_number) { + fb_response_header.seq = htons(fb_sequence_number); + memcpy(packet_base, &fb_response_header, + sizeof(fb_response_header)); + } + /* Write response to packet */ + memcpy(packet, response, strlen(response)); + packet += strlen(response); + break; + default: + pr_err("ID %d not implemented.\n", fb_header.id); + return; + } + + len = packet - packet_base; + + /* Save packet for retransmitting */ + last_packet_len = len; + memcpy(last_packet, packet_base, last_packet_len); + + net_send_udp_packet(net_server_ethaddr, fastboot_remote_ip, + fastboot_remote_port, fastboot_our_port, len); + + /* Continue boot process after sending response */ + if (!strncmp("OKAY", response, 4)) { + switch (cmd) { + case FASTBOOT_COMMAND_BOOT: + boot_downloaded_image(); + break; + + case FASTBOOT_COMMAND_CONTINUE: + net_set_state(NETLOOP_SUCCESS); + break; + + case FASTBOOT_COMMAND_REBOOT: + case FASTBOOT_COMMAND_REBOOT_BOOTLOADER: + do_reset(NULL, 0, 0, NULL); + break; + } + } + + if (!strncmp("OKAY", response, 4) || !strncmp("FAIL", response, 4)) + cmd = -1; +} + +/** + * Boots into downloaded image. + */ +static void boot_downloaded_image(void) +{ + fastboot_boot(fastboot_buf_addr); + net_set_state(NETLOOP_SUCCESS); +} + +/** + * Incoming UDP packet handler. + * + * @param packet Pointer to incoming UDP packet + * @param dport Destination UDP port + * @param sip Source IP address + * @param sport Source UDP port + * @param len Packet length + */ +static void fastboot_handler(uchar *packet, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len) +{ + struct fastboot_header fb_header; + char fastboot_data[DATA_SIZE] = {0}; + unsigned int fastboot_data_len = 0; + + if (dport != fastboot_our_port) + return; + + fastboot_remote_ip = sip; + fastboot_remote_port = sport; + + if (len < sizeof(struct fastboot_header) || len > PACKET_SIZE) + return; + memcpy(&fb_header, packet, sizeof(fb_header)); + fb_header.flags = 0; + fb_header.seq = ntohs(fb_header.seq); + packet += sizeof(fb_header); + len -= sizeof(fb_header); + + switch (fb_header.id) { + case FASTBOOT_QUERY: + fastboot_send(fb_header, fastboot_data, 0, 0); + break; + case FASTBOOT_INIT: + case FASTBOOT_FASTBOOT: + fastboot_data_len = len; + if (len > 0) + memcpy(fastboot_data, packet, len); + if (fb_header.seq == fb_sequence_number) { + fastboot_send(fb_header, fastboot_data, + fastboot_data_len, 0); + fb_sequence_number++; + } else if (fb_header.seq == fb_sequence_number - 1) { + /* Retransmit last sent packet */ + fastboot_send(fb_header, fastboot_data, + fastboot_data_len, 1); + } + break; + default: + pr_err("ID %d not implemented.\n", fb_header.id); + fb_header.id = FASTBOOT_ERROR; + fastboot_send(fb_header, fastboot_data, 0, 0); + break; + } +} + +void fastboot_start_server(void) +{ + printf("Using %s device\n", eth_get_name()); + printf("Listening for fastboot command on %pI4\n", &net_ip); + + fastboot_our_port = WELL_KNOWN_PORT; + + fastboot_set_progress_callback(fastboot_timed_send_info); + net_set_udp_handler(fastboot_handler); + + /* zero out server ether in case the server ip has changed */ + memset(net_server_ethaddr, 0, 6); +} diff --git a/net/net.c b/net/net.c index 7f85211..a4932f4 100644 --- a/net/net.c +++ b/net/net.c @@ -87,6 +87,7 @@ #include <environment.h> #include <errno.h> #include <net.h> +#include <net/fastboot.h> #include <net/tftp.h> #if defined(CONFIG_LED_STATUS) #include <miiphy.h> @@ -451,6 +452,11 @@ restart: tftp_start_server(); break; #endif +#ifdef CONFIG_UDP_FUNCTION_FASTBOOT + case FASTBOOT: + fastboot_start_server(); + break; +#endif #if defined(CONFIG_CMD_DHCP) case DHCP: bootp_reset(); @@ -1322,6 +1328,7 @@ common: /* Fall through */
case NETCONS: + case FASTBOOT: case TFTPSRV: if (net_ip.s_addr == 0) { puts("*** ERROR: `ipaddr' not set\n");
Hi Alex,
Changes in v3:
Changes in v2:
Please can you add function comments to the rest of the fastboot.h stuff, see if you can remove the global variables in that file, and also add function comments to non-trivial static functions?
Hi Alex,
Changes in v3:
compile
time one
the
and
size
support
but
command,
If
is
in
Changes in v2:
Will do... I don't think I can easily make the remaining globals go away, but I can certainly put them behind accessor functions.
-- Alex Kiernan
Hi Alex,
Hi Alex,
Changes in v3:
compile
time one
the
and
size
support
but
command,
If
is
in
Changes in v2:
If you can't make them go away, or put them in a struct, then I don't think you should bother with accessor function, which just mess up the code IMO.
On Tue, May 15, 2018 at 5:05 PM Simon Glass sjg@chromium.org wrote:
Hi Alex,
Hi Alex,
Changes in v3:
compile
time one
is
the
and
size
for
NAND devices)
support
gets
merged).
same,
but
variable
command,
same.
If
control
is
code
in
Changes in v2:
away,
So it was a worthwhile exercise to go through it again... I got two more of the globals into statics (and a function to return the amount of data we still expect to transfer), which left the buffer address, buffer size, and the progress callback to keep the protocol alive, all of which are only used inside drivers/fastboot itself, which I'll move to a fastboot-internal.h
-- Alex Kiernan
Alex Kiernan
