[U-Boot] [PATCH] arm: zynq: correct the argument to lldiv
Typecast the argument with unsigned long long for proper calculation of lldiv
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- -Fixes the issue of rounding of the multiplication result to 32-bit value --- arch/arm/cpu/armv7/zynq/timer.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/zynq/timer.c b/arch/arm/cpu/armv7/zynq/timer.c index 2be253c..09a5547 100644 --- a/arch/arm/cpu/armv7/zynq/timer.c +++ b/arch/arm/cpu/armv7/zynq/timer.c @@ -107,7 +107,8 @@ void __udelay(unsigned long usec) if (usec == 0) return;
- countticks = lldiv(TIMER_TICK_HZ * usec, 1000000); + countticks = lldiv(((unsigned long long)TIMER_TICK_HZ * usec), + 1000000);
/* decrementing timer */ timeend = readl(&timer_base->counter) - countticks;
We found this in connection to eeprom write test.
Signed-off-by: Michal Simek michal.simek@xilinx.com
Albert: This is the bug fixed I was talking you about on IRC. Will add it to my zynq pull request if this is fine for others.
Thanks, Michal
Hi Michal,
Fine for me at least. As soon as my current PR to u-boot/master is applied (cc: Tom), I'll resume applying patches, starting with your Zynq PR, so if it was updated meanwhile, I'll apply the updated one.
Thanks, Michal
Amicalement,
On 02/17/2014 10:07 AM, Albert ARIBAUD wrote:
Hi Michal,
I am keeping my eyes on it too.
Thanks, Michal
Albert ARIBAUD
Michal Simek
