[U-Boot] [PATCH v2 0/4] vexpress64 fixes and NOR support
This series is a rework or repost of a few patches to fix vexpress64 FVP support and to add NOR flash support to the boards that support it, namely, Juno and the FVP AEMv8 models. The FVP Foundation model does not simulate NOR flash, but will fail gracefully with this series.
The first patch was originally posted by Linus Walleij, but I took it over with his permission when it needed reworking.
[PATCH v2 1/4] vexpress64: compile Juno PCIe conditionally [PATCH v2 2/4] vexpress64: use 2nd DRAM bank only on juno [PATCH v2 3/4] vexpress64: remove #error [PATCH v2 4/4] vexpress64: store env in flash
board/armltd/vexpress64/Makefile | 3 ++- board/armltd/vexpress64/pcie.c | 2 -- board/armltd/vexpress64/vexpress64.c | 9 +++++++++ configs/vexpress_aemv8a_dram_defconfig | 1 - configs/vexpress_aemv8a_semi_defconfig | 1 - include/configs/vexpress_aemv8a.h | 54 ++++++++++++++++++++++++++++--------------------------
Only compile in PCIe support if the board really uses it. Provide a __weak stub for the init function if e.g. FVP is being built.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Acked-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/vexpress64/Makefile | 3 ++- board/armltd/vexpress64/pcie.c | 2 -- board/armltd/vexpress64/vexpress64.c | 7 +++++++ 3 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/board/armltd/vexpress64/Makefile b/board/armltd/vexpress64/Makefile index a35db40..b4391a7 100644 --- a/board/armltd/vexpress64/Makefile +++ b/board/armltd/vexpress64/Makefile @@ -5,4 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := vexpress64.o pcie.o +obj-y := vexpress64.o +obj-$(CONFIG_TARGET_VEXPRESS64_JUNO) += pcie.o diff --git a/board/armltd/vexpress64/pcie.c b/board/armltd/vexpress64/pcie.c index 7b999e8..311c450 100644 --- a/board/armltd/vexpress64/pcie.c +++ b/board/armltd/vexpress64/pcie.c @@ -191,7 +191,5 @@ void xr3pci_init(void)
void vexpress64_pcie_init(void) { -#ifdef CONFIG_TARGET_VEXPRESS64_JUNO xr3pci_init(); -#endif } diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c index f4e8084..3add099 100644 --- a/board/armltd/vexpress64/vexpress64.c +++ b/board/armltd/vexpress64/vexpress64.c @@ -28,6 +28,13 @@ U_BOOT_DEVICE(vexpress_serials) = { .platdata = &serial_platdata, };
+/* This function gets replaced by platforms supporting PCIe. + * The replacement function, eg. on Juno, initialises the PCIe bus. + */ +__weak void vexpress64_pcie_init(void) +{ +} + int board_init(void) { vexpress64_pcie_init();
This patch makes the 2nd DRAM bank available on Juno only and not on other vexpress64 targets, eg. the FVP models.
The commit below added a 2nd bank of NOR flash for Juno, but also for all vexpress64 targets:
commit 2d0cee1ca2b9d977fa3214896bb2e30cfec77059 Author: Liviu Dudau Liviu.Dudau@foss.arm.com Date: Mon Oct 19 11:08:31 2015 +0100
vexpress64: Juno: Declare all 8GB of RAM and make them visible to the kernel.
Juno comes with 8GB RAM, but U-Boot only passes 2GB to the kernel. Declare a secondary memory bank and set the sizes correctly.
Signed-off-by: Liviu Dudau Liviu.Dudau@foss.arm.com Reviewed-by: Linus Walleij linus.walleij@linaro.org Reviewed-by: Ryan Harkin ryan.harkin@linaro.org Tested-by: Ryan Harkin ryan.harkin@linaro.org
Unfortunately, I only fully tested on Juno R0, R1 and the FVP Foundation model. Whilst FVP Base AEMV8 models run U-Boot OK, they fail to boot the kernel.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Acked-by: Liviu Dudau liviu.dudau@foss.arm.com Reviewed-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/vexpress64/vexpress64.c | 2 ++ include/configs/vexpress_aemv8a.h | 11 ++++++++--- 2 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c index 3add099..6efc8c1 100644 --- a/board/armltd/vexpress64/vexpress64.c +++ b/board/armltd/vexpress64/vexpress64.c @@ -51,8 +51,10 @@ void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; +#ifdef PHYS_SDRAM_2 gd->bd->bi_dram[1].start = PHYS_SDRAM_2; gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +#endif }
/* diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index a99d712..3c9faf4 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -165,15 +165,20 @@ #define CONFIG_SYS_LOAD_ADDR (V2M_BASE + 0x10000000)
/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 2 #define PHYS_SDRAM_1 (V2M_BASE) /* SDRAM Bank #1 */ -#define PHYS_SDRAM_2 (0x880000000) /* Top 16MB reserved for secure world use */ #define DRAM_SEC_SIZE 0x01000000 #define PHYS_SDRAM_1_SIZE 0x80000000 - DRAM_SEC_SIZE -#define PHYS_SDRAM_2_SIZE 0x180000000 #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
+#ifdef CONFIG_TARGET_VEXPRESS64_JUNO +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_2 (0x880000000) +#define PHYS_SDRAM_2_SIZE 0x180000000 +#else +#define CONFIG_NR_DRAM_BANKS 1 +#endif + /* Enable memtest */ #define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1
commit 2d0cee1ca2b9d977fa3214896bb2e30cfec77059 Author: Liviu Dudau <Liviu.Dudau@foss.arm.com> Date: Mon Oct 19 11:08:31 2015 +0100 vexpress64: Juno: Declare all 8GB of RAM and make them visible to the kernel. Juno comes with 8GB RAM, but U-Boot only passes 2GB to the kernel. Declare a secondary memory bank and set the sizes correctly. Signed-off-by: Liviu Dudau <Liviu.Dudau@foss.arm.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
This patch allows vexpress64 targets to be compiled when CONFIG_SYS_FLASH_CFI is enabled.
I considered using #warning instead of #error, but this just clutters up the build output and hides real warnings.
Without this patch, you see errors during compilation like this:
include/configs/vexpress_aemv8a.h:42:2: error: #error "Unknown board variant" #error "Unknown board variant" include/configs/vexpress_aemv8a.h:115:2: error: #error "Unknown board variant" #error "Unknown board variant" include/configs/vexpress_aemv8a.h:280:2: error: #error "Unknown board variant" #error "Unknown board variant" make[1]: *** [tools/envcrc.o] Error 1 make: *** [tools] Error 2 In file included from include/config.h:5:0, from tools/envcrc.c:19:
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Acked-by: Linus Walleij linus.walleij@linaro.org --- include/configs/vexpress_aemv8a.h | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 3c9faf4..6734d7e 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -35,8 +35,6 @@ #elif CONFIG_TARGET_VEXPRESS64_JUNO #define CONFIG_SYS_TEXT_BASE 0xe0000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) -#else -#error "Unknown board variant" #endif
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ @@ -108,8 +106,6 @@ #elif CONFIG_TARGET_VEXPRESS64_JUNO #define GICD_BASE (0x2C010000) #define GICC_BASE (0x2C02f000) -#else -#error "Unknown board variant" #endif #endif /* !CONFIG_GICV3 */
@@ -278,8 +274,6 @@
#define CONFIG_BOOTDELAY 1
/* Do not preserve environment */
Add support for storing the environment in CFI NOR flash on Juno and FVP models.
I also removed some config values that are not used by CFI flash parts.
Juno has 1 flash part with 259 sectors. The first 255 sectors are 0x40000 (256kb) and are followed by 4 sectors of 0x10000 (64KB).
FVP models simulate a 64MB NOR flash part at base address 0x0FFC0000. This part has 256 x 256kb sectors. We use the last sector to store the environment.
To save the NOR flash to a file, the following parameters should be passed to the model:
-C bp.flashloader1.fname=${FILENAME} -C bp.flashloader1.fnameWrite=${FILENAME}
Foundation models don't simulate the NOR flash, but having NOR support in the u-boot binary does not harm: attempting to write to the NOR will fail gracefully.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Acked-by: Linus Walleij linus.walleij@linaro.org --- configs/vexpress_aemv8a_dram_defconfig | 1 - configs/vexpress_aemv8a_semi_defconfig | 1 - include/configs/vexpress_aemv8a.h | 37 ++++++++++++++++++---------------- 3 files changed, 20 insertions(+), 19 deletions(-)
diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index e9fc870..a8e4daa 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -8,7 +8,6 @@ CONFIG_DEFAULT_DEVICE_TREE="vexpress64" # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADS is not set -# CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index a082d27..e899b90 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -10,7 +10,6 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADS is not set -# CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 6734d7e..c767f90 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -276,10 +276,6 @@
#endif
-/* Do not preserve environment */ -#define CONFIG_ENV_IS_NOWHERE 1 -#define CONFIG_ENV_SIZE 0x1000 - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ @@ -290,28 +286,35 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_MAXARGS 64 /* max command args */
-/* Flash memory is available on the Juno board only */ -#ifndef CONFIG_TARGET_VEXPRESS64_JUNO -#define CONFIG_SYS_NO_FLASH +#ifdef CONFIG_TARGET_VEXPRESS64_JUNO +#define CONFIG_SYS_FLASH_BASE 0x08000000 +/* 255 x 256KiB sectors + 4 x 64KiB sectors at the end = 259 */ +#define CONFIG_SYS_MAX_FLASH_SECT 259 +/* Store environment at top of flash in the same location as blank.img */ +/* in the Juno firmware. */ +#define CONFIG_ENV_ADDR 0x0BFC0000 +#define CONFIG_ENV_SECT_SIZE 0x00010000 #else +#define CONFIG_SYS_FLASH_BASE 0x0C000000 +/* 256 x 256KiB sectors */ +#define CONFIG_SYS_MAX_FLASH_SECT 256 +/* Store environment at top of flash */ +#define CONFIG_ENV_ADDR 0x0FFC0000 +#define CONFIG_ENV_SECT_SIZE 0x00040000 +#endif + #define CONFIG_CMD_ARMFLASH #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT -#define CONFIG_SYS_FLASH_BASE 0x08000000 -#define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MiB */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_MAX_FLASH_BANKS 1
-/* Timeout values in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Erase Timeout */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Write Timeout */ - -/* 255 0x40000 sectors + first or last sector may have 4 erase regions = 259 */ -#define CONFIG_SYS_MAX_FLASH_SECT 259 /* Max sectors */ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* use buffered writes */ #define CONFIG_SYS_FLASH_PROTECTION /* The devices have real protection */ #define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ +#define FLASH_MAX_SECTOR_SIZE 0x00040000 +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_IS_IN_FLASH 1
-#endif
#endif /* __VEXPRESS_AEMV8A_H */
Ryan Harkin
