Pull request: u-boot-rockchip-20200916
Hi Tom,
Please pull the rockchip fixes: - Fix rv1108 grf access issue - make_fit_atf: ignore empty PT_LOAD segment
Gitlab ci: https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip/pipelines/4685
Thanks, - Kever
The following changes since commit 4dcced116976937f6f7dd9a0e39cde8120250c16:
Merge tag 'mmc-2020-9-15' of https://gitlab.denx.de/u-boot/custodians/u-boot-mmc (2020-09-15 08:59:32 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20200916
for you to fetch changes up to 5b861eea7927da63f016b75265e454a19ab19d0b:
rockchip: make_fit_atf: ignore empty PT_LOAD segment (2020-09-16 16:41:30 +0800)
---------------------------------------------------------------- Heinrich Schuchardt (1): rockchip: make_fit_atf: ignore empty PT_LOAD segment
Kever Yang (3): rockchip: rv1108: use correct API for board callback rockchip: rv1108: Enable grf as pre-reloc node rockchip: rv1108: enable board early init
arch/arm/dts/rv1108-u-boot.dtsi | 4 ++++ arch/arm/mach-rockchip/make_fit_atf.py | 5 +++-- board/elgin/elgin_rv1108/elgin_rv1108.c | 2 +- board/rockchip/evb_rv1108/evb_rv1108.c | 2 +- configs/elgin-rv1108_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + 6 files changed, 11 insertions(+), 4 deletions(-)
On Wed, Sep 16, 2020 at 05:47:49PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
