[U-Boot] [U-Boot 1/3] spl: common: Properly ignore spl/Makefile in .gitignore
The spl directory is ignored by git as these objects are created during spl creation. The only file not created is the Makefile.
This file can be modified and checked in via git.
Due to the order of rule precedence having the whole directory ignored first then indicating not to ignore the Makefile is not correct the message to force adding the Makefile is still shown.
So reorder the .gitignore for the Makefile and indicate that the Makefile does not need to be ignored first and then indicate everything else in spl should be ignored after wards.
Signed-off-by: Dan Murphy dmurphy@ti.com --- .gitignore | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/.gitignore b/.gitignore index 3b14c25..7f006c8 100644 --- a/.gitignore +++ b/.gitignore @@ -57,8 +57,8 @@ /errlog /reloc_off
-/spl/ !/spl/Makefile +/spl/* /tpl/
/include/generated/
Move the FAT functions to a common location for reuse.
Signed-off-by: Dan Murphy dmurphy@ti.com --- common/spl/Makefile | 1 + common/spl/spl_fat.c | 96 ++++++++++++++++++++++++++++++++++++++++++++++++++ common/spl/spl_mmc.c | 68 ++++------------------------------- include/spl.h | 5 +++ 4 files changed, 108 insertions(+), 62 deletions(-) create mode 100644 common/spl/spl_fat.c
diff --git a/common/spl/Makefile b/common/spl/Makefile index 5c0637b..c8d5963 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -16,4 +16,5 @@ obj-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o obj-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o obj-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o obj-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o +obj-$(CONFIG_SPL_FAT_SUPPORT) += spl_fat.o endif diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c new file mode 100644 index 0000000..9b40584 --- /dev/null +++ b/common/spl/spl_fat.c @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2014 + * Texas Instruments, <www.ti.com> + * + * Dan Murphy dmurphy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * FAT Image Functions copied from spl_mmc.c + */ + +#include <common.h> +#include <spl.h> +#include <asm/u-boot.h> +#include <fat.h> +#include <image.h> + +static int fat_registered; + +#ifdef CONFIG_SPL_FAT_SUPPORT +static int spl_register_fat_device(block_dev_desc_t *block_dev, int partition) +{ + int err = 0; + + if (fat_registered) + return err; + + err = fat_register_device(block_dev, partition); + if (err) { +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + printf("spl: fat register err - %d\n", err); +#endif + hang(); + } + + fat_registered = 1; + + return err; +} + +int spl_load_image_fat(block_dev_desc_t *block_dev, + int partition, + const char *filename) +{ + int err; + struct image_header *header; + + err = spl_register_fat_device(block_dev, partition); + if (err <= 0) + goto end; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + err = file_fat_read(filename, header, sizeof(struct image_header)); + if (err <= 0) + goto end; + + spl_parse_image_header(header); + + err = file_fat_read(filename, (u8 *)spl_image.load_addr, 0); + +end: +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + if (err <= 0) + printf("spl: error reading image %s, err - %d\n", + filename, err); +#endif + + return (err <= 0); +} + +#ifdef CONFIG_SPL_OS_BOOT +int spl_load_image_fat_os(block_dev_desc_t *block_dev, int partition) +{ + int err; + + err = spl_register_fat_device(block_dev, partition); + if (err <= 0) + return -1; + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_ARGS_NAME, + (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); + if (err <= 0) { +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + printf("spl: error reading image %s, err - %d\n", + CONFIG_SPL_FAT_LOAD_ARGS_NAME, err); +#endif + return -1; + } + + return spl_load_image_fat(block_dev, partition, + CONFIG_SPL_FAT_LOAD_KERNEL_NAME); +} +#endif +#endif diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index fc2f226..13fbff0 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -10,7 +10,6 @@ #include <spl.h> #include <asm/u-boot.h> #include <mmc.h> -#include <fat.h> #include <version.h> #include <image.h>
@@ -69,54 +68,6 @@ static int mmc_load_image_raw_os(struct mmc *mmc) } #endif
-#ifdef CONFIG_SPL_FAT_SUPPORT -static int mmc_load_image_fat(struct mmc *mmc, const char *filename) -{ - int err; - struct image_header *header; - - header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header)); - - err = file_fat_read(filename, header, sizeof(struct image_header)); - if (err <= 0) - goto end; - - spl_parse_image_header(header); - - err = file_fat_read(filename, (u8 *)spl_image.load_addr, 0); - -end: -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - if (err <= 0) - printf("spl: error reading image %s, err - %d\n", - filename, err); -#endif - - return (err <= 0); -} - -#ifdef CONFIG_SPL_OS_BOOT -static int mmc_load_image_fat_os(struct mmc *mmc) -{ - int err; - - err = file_fat_read(CONFIG_SPL_FAT_LOAD_ARGS_NAME, - (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); - if (err <= 0) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: error reading image %s, err - %d\n", - CONFIG_SPL_FAT_LOAD_ARGS_NAME, err); -#endif - return -1; - } - - return mmc_load_image_fat(mmc, CONFIG_SPL_FAT_LOAD_KERNEL_NAME); -} -#endif - -#endif - void spl_mmc_load_image(void) { struct mmc *mmc; @@ -148,24 +99,17 @@ void spl_mmc_load_image(void) if (spl_start_uboot() || mmc_load_image_raw_os(mmc)) #endif err = mmc_load_image_raw(mmc, - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); #ifdef CONFIG_SPL_FAT_SUPPORT } else if (boot_mode == MMCSD_MODE_FAT) { debug("boot mode - FAT\n"); - - err = fat_register_device(&mmc->block_dev, - CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); - if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: fat register err - %d\n", err); -#endif - hang(); - } - #ifdef CONFIG_SPL_OS_BOOT - if (spl_start_uboot() || mmc_load_image_fat_os(mmc)) + if (spl_start_uboot() || spl_load_image_fat_os(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION)) #endif - err = mmc_load_image_fat(mmc, CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME); + err = spl_load_image_fat(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION, + CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME); #endif } else { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT diff --git a/include/spl.h b/include/spl.h index 2bd6e16..cd5cd26 100644 --- a/include/spl.h +++ b/include/spl.h @@ -11,6 +11,7 @@ #include <linux/compiler.h> #include <asm/spl.h>
+ /* Boot type */ #define MMCSD_MODE_UNDEFINED 0 #define MMCSD_MODE_RAW 1 @@ -60,6 +61,10 @@ void spl_spi_load_image(void); /* Ethernet SPL functions */ void spl_net_load_image(const char *device);
+/* SPL FAT image functions */ +int spl_load_image_fat(block_dev_desc_t *block_dev, int partition, const char *filename); +int spl_load_image_fat_os(block_dev_desc_t *block_dev, int partition); + #ifdef CONFIG_SPL_BOARD_INIT void spl_board_init(void); #endif
Add SPL support to be able to detect a USB Mass Storage device connected to a USB host. Once a USB Mass storage device is detected the SPL will load the u-boot.img from a FAT partition to target address.
Signed-off-by: Dan Murphy dmurphy@ti.com --- arch/arm/include/asm/arch-am33xx/spl.h | 14 ++++++-- common/Makefile | 4 +++ common/spl/Makefile | 1 + common/spl/spl.c | 5 +++ common/spl/spl_fat.c | 16 ++++----- common/spl/spl_usb.c | 58 ++++++++++++++++++++++++++++++++ include/spl.h | 3 ++ spl/Makefile | 2 ++ 8 files changed, 92 insertions(+), 11 deletions(-) create mode 100644 common/spl/spl_usb.c
diff --git a/arch/arm/include/asm/arch-am33xx/spl.h b/arch/arm/include/asm/arch-am33xx/spl.h index 95de9aa..cd1d88d 100644 --- a/arch/arm/include/asm/arch-am33xx/spl.h +++ b/arch/arm/include/asm/arch-am33xx/spl.h @@ -20,6 +20,7 @@ #if defined(CONFIG_AM33XX) || defined(CONFIG_AM43XX) #define BOOT_DEVICE_MMC1 8 #define BOOT_DEVICE_MMC2 9 /* eMMC or daughter card */ +#define BOOT_DEVICE_USB 13 #elif defined(CONFIG_TI814X) #define BOOT_DEVICE_MMC1 9 #define BOOT_DEVICE_MMC2 8 /* ROM only supports 2nd instance */ @@ -31,9 +32,16 @@ #define BOOT_DEVICE_MMC2_2 0xFF #endif
-#if defined(CONFIG_AM33XX) || defined(CONFIG_AM43XX) -#define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC1 -#define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC2 +#if defined(CONFIG_AM33XX) +#define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC1 +#define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC2 +#elif defined(CONFIG_AM43XX) +#define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC1 +#ifdef CONFIG_SPL_USB_SUPPORT +#define MMC_BOOT_DEVICES_END BOOT_DEVICE_USB +#else +#define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC2 +#endif #elif defined(CONFIG_TI81XX) #define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC2 #define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC1 diff --git a/common/Makefile b/common/Makefile index d12cba5..4d99ecd 100644 --- a/common/Makefile +++ b/common/Makefile @@ -197,6 +197,10 @@ obj-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o obj-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o obj-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o obj-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o +ifdef CONFIG_SPL_USB_HOST_SUPPORT +obj-$(CONFIG_SPL_USB_SUPPORT) += usb.o usb_hub.o +obj-$(CONFIG_USB_STORAGE) += usb_storage.o +endif ifneq ($(CONFIG_SPL_NET_SUPPORT),y) obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o diff --git a/common/spl/Makefile b/common/spl/Makefile index c8d5963..65a1484f 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -16,5 +16,6 @@ obj-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o obj-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o obj-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o obj-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o +obj-$(CONFIG_SPL_USB_SUPPORT) += spl_usb.o obj-$(CONFIG_SPL_FAT_SUPPORT) += spl_fat.o endif diff --git a/common/spl/spl.c b/common/spl/spl.c index da31457..0645cee 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -205,6 +205,11 @@ void board_init_r(gd_t *dummy1, ulong dummy2) spl_net_load_image("usb_ether"); break; #endif +#ifdef CONFIG_SPL_USB_SUPPORT + case BOOT_DEVICE_USB: + spl_usb_load_image(); + break; +#endif default: debug("SPL: Un-supported Boot Device\n"); hang(); diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 9b40584..1e532d5 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -28,7 +28,7 @@ static int spl_register_fat_device(block_dev_desc_t *block_dev, int partition) err = fat_register_device(block_dev, partition); if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: fat register err - %d\n", err); + printf("%s: fat register err - %d\n", __func__, err); #endif hang(); } @@ -46,7 +46,7 @@ int spl_load_image_fat(block_dev_desc_t *block_dev, struct image_header *header;
err = spl_register_fat_device(block_dev, partition); - if (err <= 0) + if (err) goto end;
header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - @@ -63,8 +63,8 @@ int spl_load_image_fat(block_dev_desc_t *block_dev, end: #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT if (err <= 0) - printf("spl: error reading image %s, err - %d\n", - filename, err); + printf("%s: error reading image %s, err - %d\n", + __func__, filename, err); #endif
return (err <= 0); @@ -76,15 +76,15 @@ int spl_load_image_fat_os(block_dev_desc_t *block_dev, int partition) int err;
err = spl_register_fat_device(block_dev, partition); - if (err <= 0) - return -1; + if (err) + return err;
err = file_fat_read(CONFIG_SPL_FAT_LOAD_ARGS_NAME, (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); if (err <= 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: error reading image %s, err - %d\n", - CONFIG_SPL_FAT_LOAD_ARGS_NAME, err); + printf("%s: error reading image %s, err - %d\n", + __func__, CONFIG_SPL_FAT_LOAD_ARGS_NAME, err); #endif return -1; } diff --git a/common/spl/spl_usb.c b/common/spl/spl_usb.c new file mode 100644 index 0000000..53a9043 --- /dev/null +++ b/common/spl/spl_usb.c @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2014 + * Texas Instruments, <www.ti.com> + * + * Dan Murphy dmurphy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Derived work from spl_mmc.c + */ + +#include <common.h> +#include <spl.h> +#include <asm/u-boot.h> +#include <usb.h> +#include <fat.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_USB_STORAGE +static int usb_stor_curr_dev = -1; /* current device */ +#endif + +void spl_usb_load_image(void) +{ + int err; + block_dev_desc_t *stor_dev; + + usb_stop(); + err = usb_init(); + if (err) { +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + printf("%s: usb init failed: err - %d\n", __func__, err); +#endif + hang(); + } + +#ifdef CONFIG_USB_STORAGE + /* try to recognize storage devices immediately */ + usb_stor_curr_dev = usb_stor_scan(1); + stor_dev = usb_stor_get_dev(usb_stor_curr_dev); +#endif + + debug("boot mode - FAT\n"); + +#ifdef CONFIG_SPL_OS_BOOT + if (spl_start_uboot() || spl_load_image_fat_os(stor_dev, + CONFIG_SYS_USB_FAT_BOOT_PARTITION)) +#endif + err = spl_load_image_fat(stor_dev, + CONFIG_SYS_USB_FAT_BOOT_PARTITION, + CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME); + + if (err) { + puts("Error loading USB device\n"); + hang(); + } +} diff --git a/include/spl.h b/include/spl.h index cd5cd26..5e24856 100644 --- a/include/spl.h +++ b/include/spl.h @@ -61,6 +61,9 @@ void spl_spi_load_image(void); /* Ethernet SPL functions */ void spl_net_load_image(const char *device);
+/* USB SPL functions */ +void spl_usb_load_image(void); + /* SPL FAT image functions */ int spl_load_image_fat(block_dev_desc_t *block_dev, int partition, const char *filename); int spl_load_image_fat_os(block_dev_desc_t *block_dev, int partition); diff --git a/spl/Makefile b/spl/Makefile index 1e88d74..06edcf0 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -82,6 +82,8 @@ LIBS-$(CONFIG_SPL_USBETH_SUPPORT) += drivers/net/phy/ LIBS-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += drivers/usb/musb-new/ LIBS-$(CONFIG_SPL_USBETH_SUPPORT) += drivers/usb/gadget/ LIBS-$(CONFIG_SPL_WATCHDOG_SUPPORT) += drivers/watchdog/ +LIBS-$(CONFIG_SPL_USB_HOST_SUPPORT) += drivers/usb/host/ +LIBS-$(CONFIG_OMAP_USB_PHY) += drivers/usb/phy/
ifneq (,$(CONFIG_MX23)$(CONFIG_MX35)$(filter $(SOC), mx25 mx27 mx5 mx6 mx31 mx35)) LIBS-y += arch/$(ARCH)/imx-common/
After a rebase it appears this does not get merged to the right spot.
I can submit a V2 if the maintainer wants me to or it can be a fix up once applied.
<snip>
Dan Murphy
