Hello Tom,
please pull from u-boot-i2c master:
The following changes since commit d3213c26b56e564207515f1e28e663718e015dc3:
Merge tag 'efi-2022-01-rc4-3' of https://source.denx.de/u-boot/custodians/u-boot-efi (2021-12-18 14:39:21 -0500)
https://source.denx.de/u-boot/custodians/u-boot-i2c.git tags/20211220-fixes-for-2022.01
for you to fetch changes up to ccea46c05b08b34ef829d460e50e2ce9bc17cdc7:
i2c: mvtwsi: Swab the register address if its size is > 1 (2021-12-20 07:57:48 +0100)
---------------------------------------------------------------- i2c changes for 20211220-fixes-for-2022.01
- mvtwsi: Swab the register address if its size is > 1
---------------------------------------------------------------- Stefan Roese (1): i2c: mvtwsi: Swab the register address if its size is > 1
drivers/i2c/mvtwsi.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
Azure build is fine:
https://dev.azure.com/hs0298/hs/_build/results?buildId=77&view=results
Thanks!
bye, Heiko
On Mon, Dec 20, 2021 at 11:14:16AM +0100, Heiko Schocher wrote:
Hello Tom,
Heiko Schocher
