[U-Boot] [PATCH] [U-BOOT] Zoom2 & Zoom3: introduced a macro to use a different buffer size when compiling for Zoom2 or Zoom3.
From: Aldo Brett Cedillo Martinez aldo.cedillo@ti.com
Zoom2 and Zoom2 used to hang with "md" command. It was due to a problem with a buffer size in print_buffer() function. A macro was introduced to use a different buffer size in case of compiling for Zoom2 and Zoom3.
Jeff could you please test it on your board with the Zoom3 initial support patch.
Sandeep I also saw this behaving in Zoom2, so maybe I could send a patch that introduces only Zoom2 change, which could be introduced in TI tree without waiting for Zoom3 initial support for going mainline.
Signed-off-by: Aldo Brett Cedillo Martinez aldo.cedillo@ti.com --- lib/display_options.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/lib/display_options.c b/lib/display_options.c index 20319e6..99e43f7 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -101,7 +101,12 @@ void print_size(unsigned long long size, const char *s) #define DEFAULT_LINE_LENGTH_BYTES (16) int print_buffer (ulong addr, void* data, uint width, uint count, uint linelen) { +#if defined(CONFIG_OMAP3_ZOOM2) || defined(CONFIG_OMAP3_ZOOM3) + uint8_t linebuf[DEFAULT_LINE_LENGTH_BYTES]; +#else uint8_t linebuf[MAX_LINE_LENGTH_BYTES + 1]; +#endif /* CONFIG_OMAP3 */ + uint32_t *uip = (void*)linebuf; uint16_t *usp = (void*)linebuf; uint8_t *ucp = (void*)linebuf;
Dear Aldo Cedillo,
NAK to this patch.
Forst, I thinkt he problem is not with buffer size, but with buffer alignemnt as observed elasewhere, so most probably Albert's "display_buffer: fix misaligned buffer" patch will fix this issue, too.
- uint8_t linebuf[DEFAULT_LINE_LENGTH_BYTES];
Second, it is broken to use DEFAULT_LINE_LENGTH_BYTES in the declaration of the buffer, but then use MAX_LINE_LENGTH_BYTES+1 when accessing it.
[Actually I think we should kill one of these defines.]
Dear Wolfgang,
NAK to this patch.
You are right, the problem is the buffer alignment, and the patch you mentioned solves this problem.
Thanks for the comments and best regards, Aldo
Aldo Cedillo
Martinez, Aldo
