[PATCH] efi_loader: Fix -Wextra warning for EFI TCG2
Compiling with -Wextra produces a number of (harmless) warnings for the EFI TCG2 protocol. Let's fix those in case we ever enable the flag on the EFI subsystem
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_tcg2.c | 40 +++++++++++++++++++++------------------ 1 file changed, 22 insertions(+), 18 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 39ef250bf9c4..39074f754772 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -53,7 +53,7 @@ struct digest_info { u16 hash_len; };
-const static struct digest_info hash_algo_list[] = { +static const struct digest_info hash_algo_list[] = { { TPM2_ALG_SHA1, EFI_TCG2_BOOT_HASH_ALG_SHA1, @@ -87,7 +87,7 @@ const static struct digest_info hash_algo_list[] = { */ static u32 alg_to_mask(u16 hash_alg) { - int i; + size_t i;
for (i = 0; i < MAX_HASH_COUNT; i++) { if (hash_algo_list[i].hash_alg == hash_alg) @@ -106,7 +106,7 @@ static u32 alg_to_mask(u16 hash_alg) */ static u16 alg_to_len(u16 hash_alg) { - int i; + size_t i;
for (i = 0; i < MAX_HASH_COUNT; i++) { if (hash_algo_list[i].hash_alg == hash_alg) @@ -119,7 +119,7 @@ static u16 alg_to_len(u16 hash_alg) static u32 tcg_event_final_size(struct tpml_digest_values *digest_list) { u32 len; - int i; + size_t i;
len = offsetof(struct tcg_pcr_event2, digests); len += offsetof(struct tpml_digest_values, digests); @@ -145,7 +145,7 @@ static efi_status_t tcg2_pcr_extend(struct udevice *dev, u32 pcr_index, struct tpml_digest_values *digest_list) { u32 rc; - int i; + size_t i;
for (i = 0; i < digest_list->count; i++) { u32 alg = digest_list->digests[i].hash_alg; @@ -178,7 +178,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, { void *log = (void *)((uintptr_t)event_log.buffer + event_log.pos); size_t pos; - int i; + size_t i; u32 event_size;
if (event_log.get_event_called) @@ -400,7 +400,8 @@ static int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr, u8 response[TPM2_RESPONSE_BUFFER_SIZE]; struct tpml_pcr_selection pcrs; u32 ret, num_pcr; - int i, tpm_ret; + size_t i; + int tpm_ret;
memset(response, 0, sizeof(response)); ret = tpm2_get_capability(dev, TPM2_CAP_PCRS, 0, response, 1); @@ -518,7 +519,7 @@ static efi_status_t tcg2_create_digest(const u8 *input, u32 length, u8 final[TPM2_SHA512_DIGEST_SIZE]; efi_status_t ret; u32 active; - int i; + size_t i;
ret = __get_active_pcr_banks(&active); if (ret != EFI_SUCCESS) @@ -749,8 +750,7 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, goto out; }
- if (efi_tcg_event->header.pcr_index < 0 || - efi_tcg_event->header.pcr_index > TPM2_MAX_PCRS) { + if (efi_tcg_event->header.pcr_index > TPM2_MAX_PCRS) { ret = EFI_INVALID_PARAMETER; goto out; } @@ -810,9 +810,11 @@ out: * Return: status code */ static efi_status_t EFIAPI -efi_tcg2_submit_command(struct efi_tcg2_protocol *this, - u32 input_param_block_size, u8 *input_param_block, - u32 output_param_block_size, u8 *output_param_block) +efi_tcg2_submit_command(__maybe_unused struct efi_tcg2_protocol *this, + u32 __maybe_unused input_param_block_size, + u8 __maybe_unused *input_param_block, + u32 __maybe_unused output_param_block_size, + u8 __maybe_unused *output_param_block) { return EFI_UNSUPPORTED; } @@ -847,8 +849,8 @@ efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, * Return: status code */ static efi_status_t EFIAPI -efi_tcg2_set_active_pcr_banks(struct efi_tcg2_protocol *this, - u32 active_pcr_banks) +efi_tcg2_set_active_pcr_banks(__maybe_unused struct efi_tcg2_protocol *this, + u32 __maybe_unused active_pcr_banks) { return EFI_UNSUPPORTED; } @@ -866,8 +868,9 @@ efi_tcg2_set_active_pcr_banks(struct efi_tcg2_protocol *this, * Return: status code */ static efi_status_t EFIAPI -efi_tcg2_get_result_of_set_active_pcr_banks(struct efi_tcg2_protocol *this, - u32 *operation_present, u32 *response) +efi_tcg2_get_result_of_set_active_pcr_banks(__maybe_unused struct efi_tcg2_protocol *this, + u32 __maybe_unused *operation_present, + u32 __maybe_unused *response) { return EFI_UNSUPPORTED; } @@ -898,7 +901,8 @@ static efi_status_t create_specid_event(struct udevice *dev, void *buffer, size_t spec_event_size; efi_status_t ret = EFI_DEVICE_ERROR; u32 active, supported; - int err, i; + int err; + size_t i;
/* * Create Spec event. This needs to be the first event in the log
Ilias Apalodimas
