[U-Boot] [PATCH v3 1/2] watchdog: tangier: Replace unused constant with a comment
The default timeout value had been left in order to leave some traces about default setup of watchdog done by firmware.
For better understanding and compiler burden, replace it with a comment.
Suggested-by: Stefan Roese sr@denx.de Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- drivers/watchdog/tangier_wdt.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/watchdog/tangier_wdt.c b/drivers/watchdog/tangier_wdt.c index be4a8f467a..b2f40ef057 100644 --- a/drivers/watchdog/tangier_wdt.c +++ b/drivers/watchdog/tangier_wdt.c @@ -10,7 +10,12 @@ #define WDT_PRETIMEOUT 15 #define WDT_TIMEOUT_MIN (1 + WDT_PRETIMEOUT) #define WDT_TIMEOUT_MAX 170 -#define WDT_DEFAULT_TIMEOUT 90 + +/* + * Note, firmware chooses 90 seconds as a default timeout for watchdog on + * Intel Tangier SoC. It means that without handling it in the running code + * the reboot will happen. + */
#ifndef CONFIG_WATCHDOG_TIMEOUT_MSECS #define WATCHDOG_HEARTBEAT 60000
Convert legacy driver to use watchdog class.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com Reviewed-by: Stefan Roese sr@denx.de --- arch/x86/cpu/tangier/Kconfig | 1 - arch/x86/dts/edison.dts | 4 ++ configs/edison_defconfig | 2 + drivers/watchdog/Kconfig | 17 ++++---- drivers/watchdog/Makefile | 2 +- drivers/watchdog/tangier_wdt.c | 73 +++++++++++++++++++++------------- 6 files changed, 60 insertions(+), 39 deletions(-)
diff --git a/arch/x86/cpu/tangier/Kconfig b/arch/x86/cpu/tangier/Kconfig index a3bd16799d..d2b7edecd6 100644 --- a/arch/x86/cpu/tangier/Kconfig +++ b/arch/x86/cpu/tangier/Kconfig @@ -10,7 +10,6 @@ config INTEL_TANGIER imply MMC_SDHCI imply MMC_SDHCI_SDMA imply MMC_SDHCI_TANGIER - imply TANGIER_WATCHDOG imply USB imply USB_DWC3
diff --git a/arch/x86/dts/edison.dts b/arch/x86/dts/edison.dts index e8564bbb8a..c0487656d3 100644 --- a/arch/x86/dts/edison.dts +++ b/arch/x86/dts/edison.dts @@ -104,6 +104,10 @@ reg = <0xff009000 0x1000>; };
+ watchdog: wdt@0 { + compatible = "intel,tangier-wdt"; + }; + reset { compatible = "intel,reset-tangier"; u-boot,dm-pre-reloc; diff --git a/configs/edison_defconfig b/configs/edison_defconfig index 840c87ac5a..468754493e 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -39,5 +39,7 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x8087 CONFIG_USB_GADGET_PRODUCT_NUM=0x0a99 CONFIG_USB_GADGET_DOWNLOAD=y # CONFIG_USB_HOST_ETHER is not set +CONFIG_WDT=y +CONFIG_WDT_TANGIER=y CONFIG_FAT_WRITE=y CONFIG_SHA1=y diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index b01dbc446d..2270ed2e39 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -34,15 +34,6 @@ config OMAP_WATCHDOG help Say Y here to enable the OMAP3+ watchdog driver.
-config TANGIER_WATCHDOG - bool "Intel Tangier watchdog" - depends on INTEL_MID - select HW_WATCHDOG - help - This enables support for watchdog controller available on - Intel Tangier SoC. If you're using a board with Intel Tangier - SoC, say Y here. - config ULP_WATCHDOG bool "i.MX7ULP watchdog" help @@ -161,4 +152,12 @@ config WDT_MPC8xx help Select this to enable mpc8xx watchdog timer
+config WDT_TANGIER + bool "Intel Tangier watchdog timer support" + depends on WDT && INTEL_MID + help + This enables support for watchdog controller available on + Intel Tangier SoC. If you're using a board with Intel Tangier + SoC, say Y here. + endmenu diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 6f20e73810..2dfc8a37b0 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -14,7 +14,6 @@ obj-$(CONFIG_S5P) += s5p_wdt.o obj-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o obj-$(CONFIG_OMAP_WATCHDOG) += omap_wdt.o obj-$(CONFIG_DESIGNWARE_WATCHDOG) += designware_wdt.o -obj-$(CONFIG_TANGIER_WATCHDOG) += tangier_wdt.o obj-$(CONFIG_ULP_WATCHDOG) += ulp_wdog.o obj-$(CONFIG_WDT) += wdt-uclass.o obj-$(CONFIG_WDT_SANDBOX) += sandbox_wdt.o @@ -28,3 +27,4 @@ obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o obj-$(CONFIG_WDT_MTK) += mtk_wdt.o obj-$(CONFIG_WDT_SP805) += sp805_wdt.o +obj-$(CONFIG_WDT_TANGIER) += tangier_wdt.o diff --git a/drivers/watchdog/tangier_wdt.c b/drivers/watchdog/tangier_wdt.c index b2f40ef057..ba265cf223 100644 --- a/drivers/watchdog/tangier_wdt.c +++ b/drivers/watchdog/tangier_wdt.c @@ -3,7 +3,9 @@ * Copyright (c) 2017 Intel Corporation */ #include <common.h> -#include <watchdog.h> +#include <dm.h> +#include <wdt.h> +#include <div64.h> #include <asm/scu.h>
/* Hardware timeout in seconds */ @@ -17,12 +19,6 @@ * the reboot will happen. */
-#ifndef CONFIG_WATCHDOG_TIMEOUT_MSECS -#define WATCHDOG_HEARTBEAT 60000 -#else -#define WATCHDOG_HEARTBEAT CONFIG_WATCHDOG_TIMEOUT_MSECS -#endif - enum { SCU_WATCHDOG_START = 0, SCU_WATCHDOG_STOP = 1, @@ -30,39 +26,33 @@ enum { SCU_WATCHDOG_SET_ACTION_ON_TIMEOUT = 3, };
-void hw_watchdog_reset(void) +static int tangier_wdt_reset(struct udevice *dev) { - static unsigned long last; - unsigned long now; - - if (gd->timer) - now = timer_get_us(); - else - now = rdtsc() / 1000; - - /* Do not flood SCU */ - if (last > now) - last = 0; - - if (unlikely((now - last) > (WDT_PRETIMEOUT / 2) * 1000000)) { - last = now; - scu_ipc_simple_command(IPCMSG_WATCHDOG_TIMER, SCU_WATCHDOG_KEEPALIVE); - } + scu_ipc_simple_command(IPCMSG_WATCHDOG_TIMER, SCU_WATCHDOG_KEEPALIVE); + return 0; }
-int hw_watchdog_disable(void) +static int tangier_wdt_stop(struct udevice *dev) { return scu_ipc_simple_command(IPCMSG_WATCHDOG_TIMER, SCU_WATCHDOG_STOP); }
-void hw_watchdog_init(void) +static int tangier_wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) { - u32 timeout = WATCHDOG_HEARTBEAT / 1000; + u32 timeout_sec; int in_size; struct ipc_wd_start { u32 pretimeout; u32 timeout; - } ipc_wd_start = { timeout - WDT_PRETIMEOUT, timeout }; + } ipc_wd_start; + + /* Calculate timeout in seconds and restrict to min and max value */ + do_div(timeout_ms, 1000); + timeout_sec = clamp_t(u32, timeout_ms, WDT_TIMEOUT_MIN, WDT_TIMEOUT_MAX); + + /* Update values in the IPC request */ + ipc_wd_start.pretimeout = timeout_sec - WDT_PRETIMEOUT; + ipc_wd_start.timeout = timeout_sec;
/* * SCU expects the input size for watchdog IPC @@ -72,4 +62,31 @@ void hw_watchdog_init(void)
scu_ipc_command(IPCMSG_WATCHDOG_TIMER, SCU_WATCHDOG_START, (u32 *)&ipc_wd_start, in_size, NULL, 0); + + return 0; +} + +static const struct wdt_ops tangier_wdt_ops = { + .reset = tangier_wdt_reset, + .start = tangier_wdt_start, + .stop = tangier_wdt_stop, +}; + +static const struct udevice_id tangier_wdt_ids[] = { + { .compatible = "intel,tangier-wdt" }, + { /* sentinel */ } +}; + +static int tangier_wdt_probe(struct udevice *dev) +{ + debug("%s: Probing wdt%u\n", __func__, dev->seq); + return 0; } + +U_BOOT_DRIVER(wdt_tangier) = { + .name = "wdt_tangier", + .id = UCLASS_WDT, + .of_match = tangier_wdt_ids, + .ops = &tangier_wdt_ops, + .probe = tangier_wdt_probe, +};
On Fri, Jun 21, 2019 at 6:28 PM Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
applied to u-boot-x86, thanks!
Andy Shevchenko
Bin Meng
