[U-Boot] [RFC/PATCH 0/2] Support for NI Ettus Research Project Sulfur
Hi Michal,
this series adds (basic) support for the NI Ettus Research Project Sulfur SDR.
I have a bunch of follow up patches that still need cleanup, so maybe we can start with this.
I'm not entirely happy with duplicating a large amount of code from the board/xilinx/zynq/board.c file so suggestions are welcome.
My reasoning was that future modifications might be easier if I don't have to mess with the common file via #if defined() for stuff that is NI/Ettus specific in the board/xilinx/zynq directory.
Thanks,
Moritz
Moritz Fischer (2): ni: zynq: Add support for NI Ettus Research Project Sulfur Rev2 SDR ni: zynq: Add support for NI Ettus Research Project Sulfur Rev3 SDR
arch/arm/dts/Makefile | 2 + arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi | 16 ++ arch/arm/dts/zynq-ni-sulfur-rev2.dts | 275 +++++++++++++++++++ arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi | 26 ++ arch/arm/dts/zynq-ni-sulfur-rev3.dts | 325 +++++++++++++++++++++++ board/ni/zynq/MAINTAINERS | 6 + board/ni/zynq/Makefile | 10 + board/ni/zynq/board.c | 242 +++++++++++++++++ board/ni/zynq/ps7_init_common.c | 119 +++++++++ board/ni/zynq/ps7_init_gpl.h | 34 +++ board/ni/zynq/sulfur-eeprom.h | 66 +++++ board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c | 313 ++++++++++++++++++++++ board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c | 307 +++++++++++++++++++++ configs/ni_sulfur_rev2_defconfig | 74 ++++++ configs/ni_sulfur_rev3_defconfig | 69 +++++ include/configs/ni_sulfur_rev2.h | 65 +++++ include/configs/ni_sulfur_rev3.h | 42 +++ 17 files changed, 1991 insertions(+) create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev2.dts create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev3.dts create mode 100644 board/ni/zynq/MAINTAINERS create mode 100644 board/ni/zynq/Makefile create mode 100644 board/ni/zynq/board.c create mode 100644 board/ni/zynq/ps7_init_common.c create mode 100644 board/ni/zynq/ps7_init_gpl.h create mode 100644 board/ni/zynq/sulfur-eeprom.h create mode 100644 board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c create mode 100644 board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c create mode 100644 configs/ni_sulfur_rev2_defconfig create mode 100644 configs/ni_sulfur_rev3_defconfig create mode 100644 include/configs/ni_sulfur_rev2.h create mode 100644 include/configs/ni_sulfur_rev3.h
Add support for second revision of NI Ettus Research Project Sulfur Revision 2 SDR board.
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi | 16 ++ arch/arm/dts/zynq-ni-sulfur-rev2.dts | 275 ++++++++++++++++++++ board/ni/zynq/MAINTAINERS | 6 + board/ni/zynq/Makefile | 10 + board/ni/zynq/board.c | 204 +++++++++++++++ board/ni/zynq/ps7_init_common.c | 119 +++++++++ board/ni/zynq/ps7_init_gpl.h | 34 +++ board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c | 313 +++++++++++++++++++++++ configs/ni_sulfur_rev2_defconfig | 74 ++++++ include/configs/ni_sulfur_rev2.h | 65 +++++ 11 files changed, 1117 insertions(+) create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev2.dts create mode 100644 board/ni/zynq/MAINTAINERS create mode 100644 board/ni/zynq/Makefile create mode 100644 board/ni/zynq/board.c create mode 100644 board/ni/zynq/ps7_init_common.c create mode 100644 board/ni/zynq/ps7_init_gpl.h create mode 100644 board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c create mode 100644 configs/ni_sulfur_rev2_defconfig create mode 100644 include/configs/ni_sulfur_rev2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a01c9b6..c3be80f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -126,6 +126,7 @@ dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-zybo.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \ + zynq-ni-sulfur-rev2.dtb \ zynq-topic-miami.dtb \ zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \ diff --git a/arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi b/arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi new file mode 100644 index 0000000..28344c5 --- /dev/null +++ b/arch/arm/dts/zynq-ni-sulfur-rev2-uboot.dtsi @@ -0,0 +1,16 @@ +/* + * U-Boot addition to handle Sulfur Rev2 pins + * + * (C) Copyright 2016 National Instruments Corp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/gpio/gpio.h> + +&gpio0 { + sys_pwron_33 { + u-boot,dm-pre-reloc; + gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>; + }; +}; diff --git a/arch/arm/dts/zynq-ni-sulfur-rev2.dts b/arch/arm/dts/zynq-ni-sulfur-rev2.dts new file mode 100644 index 0000000..86f2b1c --- /dev/null +++ b/arch/arm/dts/zynq-ni-sulfur-rev2.dts @@ -0,0 +1,275 @@ +/* + * National Instruments Ettus Research Project Sulfur SDR Revision 2 + * devicetree source. + * + * Copyright (c) 2016 National Instruments Corp. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/gpio/gpio.h> +#include "zynq-7000.dtsi" + +/ { + model = "NI Ettus Research Project Sulfur SDR Rev2"; + compatible = "ettus,zynq-sulfur-rev2", "xlnx,zynq-7000"; + + aliases { + ethernet0 = &gem0; + serial0 = &uart0; + serial1 = &uart1; + spi0 = &spi1; + i2c20 = &tun; + i2c0 = &i2c0; + i2c0700 = &i2c0_70_0; + i2c0701 = &i2c0_70_1; + i2c0702 = &i2c0_70_2; + i2c0703 = &i2c0_70_3; + i2c0704 = &i2c0_70_4; + i2c0705 = &i2c0_70_5; + i2c0706 = &i2c0_70_6; + i2c0707 = &i2c0_70_7; + mmc0 = &sdhci0; + }; + + memory { + device_type = "memory"; + reg = <0x0 0x40000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + usb_phy0: phy0 { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + }; + + gpio-poweroff { + compatible = "gpio-poweroff"; + gpios = <&gpio0 4 GPIO_ACTIVE_LOW>; + }; +}; + +&cpu0 { + operating-points = <800000 1000000>; +}; + +&sdhci0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&uart0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +/* we use the ARM global timer */ +&ttc0 { + status = "disabled"; +}; + +/* we use the ARM global timer */ +&ttc1 { + status = "disabled"; +}; + +&i2c0 { + u-boot,dm-pre-reloc; + status = "okay"; + clock-frequency = <400000>; + + i2cswitch@70 { + compatible = "ti,pca9548", "nxp,pca9548"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x70>; + status = "okay"; + + i2c0_70_0: i2c@0 { + reg = <0x0>; + #address-cells = <1>; + #size-cells = <0>; + + status = "okay"; + }; + + i2c0_70_1: i2c@1 { + reg = <0x1>; + status = "disabled"; + }; + + i2c0_70_2: i2c@2 { + reg = <0x2>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + }; + + i2c0_70_3: i2c@3 { + reg = <0x3>; + status = "disabled"; + }; + + i2c0_70_4: i2c@4 { + reg = <0x4>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + tpm: tpm@20 { + compatible = "infineon,slb9645tt"; + reg = <0x20>; + powered-while-suspended; + }; + }; + + i2c0_70_5: i2c@5 { + reg = <0x5>; + status = "disabled"; + }; + + i2c0_70_6: i2c@6 { + reg = <0x6>; + status = "disabled"; + }; + + i2c0_70_7: i2c@7 { + reg = <0x7>; + status = "disabled"; + }; + }; +}; + +&spi1 { + u-boot,dm-pre-reloc; + status = "okay"; + spi-activate-delay = <60>; + spi-deactivate-delay = <200>; + + cros_ec: ec@0 { + compatible = "ni,cros-ec-spi", "google,cros-ec-spi"; + reg = <0>; + google,cros-ec-spi-pre-delay = <60>; + google,has-vbc-nvram; + spi-max-frequency = <3000000>; + + interrupts = <5 IRQ_TYPE_EDGE_FALLING>; + interrupt-parent = <&gpio0>; + + tun: i2c-tunnel { + compatible = "google,cros-ec-i2c-tunnel"; + #address-cells = <1>; + #size-cells = <0>; + google,remote-bus = <1>; + + hwmon0: hwmon@48 { + compatible = "tmp112"; + reg = <0x48>; + }; + + nvmem0: eeprom@50 { + compatible = "at,24c256"; + reg = <0x50>; + }; + + rtc0: rtc@68 { + compatible = "dallas,ds1374"; + reg = <0x68>; + }; + }; + }; +}; + + +&clkc { + ps-clk-frequency = <33333333>; +}; + +&gem0 { + status = "okay"; + phy-mode = "rgmii-id"; + phy-handle = <ðernet_phy0>; + + ethernet_phy0: ethernet-phy@0 { + reg = <0>; + interrupt-parent = <&gpio0>; + interrupts = <0 IRQ_TYPE_LEVEL_HIGH>; + reset-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; + }; +}; + +&usb0 { + status = "okay"; + dr_mode = "otg"; + usb-phy = <&usb_phy0>; +}; + +&gpio0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&amba { + fpga_region0: fpga-region@40000000 { + reg = <0x40000000>; + compatible = "fpga-region"; + fpga-mgr = <&devcfg>; + #address-cells = <0x1>; + #size-cells = <0x1>; + ranges; + }; + + ocm: sram@fffc0000 { + compatible = "mmio-sram"; + reg = <0xfffc0000 0x10000>; + }; +}; + +#include "zynq-ni-sulfur-rev2-uboot.dtsi" diff --git a/board/ni/zynq/MAINTAINERS b/board/ni/zynq/MAINTAINERS new file mode 100644 index 0000000..ff7595e --- /dev/null +++ b/board/ni/zynq/MAINTAINERS @@ -0,0 +1,6 @@ +NI BOARD +M: Moritz Fischer moritz.fischer@ettus.com +S: Maintained +F: board/ni/zynq/ +F: include/configs/ni*.h +F: configs/ni_*_defconfig diff --git a/board/ni/zynq/Makefile b/board/ni/zynq/Makefile new file mode 100644 index 0000000..eaf59cd --- /dev/null +++ b/board/ni/zynq/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := board.o + +# Remove quotes +hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE)) + +obj-$(CONFIG_SPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o ps7_init_common.o diff --git a/board/ni/zynq/board.c b/board/ni/zynq/board.c new file mode 100644 index 0000000..be818da --- /dev/null +++ b/board/ni/zynq/board.c @@ -0,0 +1,204 @@ +/* + * (C) Copyright 2012 Michal Simek monstr@monstr.eu + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <fpga.h> +#include <mmc.h> +#include <dm.h> +#include <asm/gpio.h> +#include <zynqpl.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if (defined(CONFIG_FPGA) && !defined(CONFIG_SPL_BUILD)) || \ + (defined(CONFIG_SPL_FPGA_SUPPORT) && defined(CONFIG_SPL_BUILD)) +static xilinx_desc fpga; + +/* It can be done differently */ +static xilinx_desc fpga007s = XILINX_XC7Z007S_DESC(0x7); +static xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); +static xilinx_desc fpga012s = XILINX_XC7Z012S_DESC(0x12); +static xilinx_desc fpga014s = XILINX_XC7Z014S_DESC(0x14); +static xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); +static xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); +static xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); +static xilinx_desc fpga035 = XILINX_XC7Z035_DESC(0x35); +static xilinx_desc fpga045 = XILINX_XC7Z045_DESC(0x45); +static xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100); +#endif + +enum board_power_type { + BOARD_POWER_TYPE_ON, + BOARD_POWER_TYPE_OFF, }; + +#if (!defined(CONFIG_SPL_BUILD)) +int board_power(enum board_power_type type) +{ + struct gpio_desc sys_pwron_33; + struct udevice *zynq_gpio; + const void *blob = gd->fdt_blob; + int node, ret; + + ret = uclass_get_device_by_seq(UCLASS_GPIO, 0, &zynq_gpio); + if (ret < 0) { + printf("Failed to find GPIO controller node. Check device tree\n"); + return 0; + } + + node = fdt_subnode_offset(blob, dev_of_offset(zynq_gpio), + "sys_pwron_33"); + + ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "gpios", 0, + &sys_pwron_33, 0); + if (ret < 0) { + printf("Failed to request 'sys_pwron_33' gpio.\n"); + return ret; + } + + + if (type == BOARD_POWER_TYPE_OFF) { + dm_gpio_set_dir_flags(&sys_pwron_33, GPIOD_IS_OUT); + } else { + dm_gpio_set_dir_flags(&sys_pwron_33, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + } + + return 0; +} +#endif + +int board_init(void) +{ +#if (defined(CONFIG_FPGA) && !defined(CONFIG_SPL_BUILD)) || \ + (defined(CONFIG_SPL_FPGA_SUPPORT) && defined(CONFIG_SPL_BUILD)) + u32 idcode; + + idcode = zynq_slcr_get_idcode(); + + switch (idcode) { + case XILINX_ZYNQ_7007S: + fpga = fpga007s; + break; + case XILINX_ZYNQ_7010: + fpga = fpga010; + break; + case XILINX_ZYNQ_7012S: + fpga = fpga012s; + break; + case XILINX_ZYNQ_7014S: + fpga = fpga014s; + break; + case XILINX_ZYNQ_7015: + fpga = fpga015; + break; + case XILINX_ZYNQ_7020: + fpga = fpga020; + break; + case XILINX_ZYNQ_7030: + fpga = fpga030; + break; + case XILINX_ZYNQ_7035: + fpga = fpga035; + break; + case XILINX_ZYNQ_7045: + fpga = fpga045; + break; + case XILINX_ZYNQ_7100: + fpga = fpga100; + break; + } +#endif + +#if (defined(CONFIG_FPGA) && !defined(CONFIG_SPL_BUILD)) || \ + (defined(CONFIG_SPL_FPGA_SUPPORT) && defined(CONFIG_SPL_BUILD)) + fpga_init(); + fpga_add(fpga_xilinx, &fpga); +#endif + + return 0; +} + +int board_late_init(void) +{ + switch ((zynq_slcr_get_boot_mode()) & ZYNQ_BM_MASK) { + case ZYNQ_BM_QSPI: + setenv("modeboot", "qspiboot"); + break; + case ZYNQ_BM_NAND: + setenv("modeboot", "nandboot"); + break; + case ZYNQ_BM_NOR: + setenv("modeboot", "norboot"); + break; + case ZYNQ_BM_SD: + setenv("modeboot", "sdboot"); + break; + case ZYNQ_BM_JTAG: + setenv("modeboot", "jtagboot"); + break; + default: + setenv("modeboot", ""); + break; + } + +#if (!defined(CONFIG_SPL_BUILD)) + board_power(BOARD_POWER_TYPE_ON); +#endif + + return 0; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + puts("Board: NI Sulfur SDR Board\n"); + return 0; +} +#endif + +int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) +{ +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, + ethaddr, 6)) + printf("I2C EEPROM MAC address read failed\n"); +#endif + + return 0; +} + +#if !defined(CONFIG_SYS_SDRAM_BASE) && !defined(CONFIG_SYS_SDRAM_SIZE) +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize(); + + return 0; +} + +int dram_init(void) +{ + if (fdtdec_setup_memory_size() != 0) + return -EINVAL; + + zynq_ddrc_init(); + + return 0; +} +#else +int dram_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + zynq_ddrc_init(); + + return 0; +} +#endif diff --git a/board/ni/zynq/ps7_init_common.c b/board/ni/zynq/ps7_init_common.c new file mode 100644 index 0000000..b182436 --- /dev/null +++ b/board/ni/zynq/ps7_init_common.c @@ -0,0 +1,119 @@ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + * (c) Copyright 2016 Topic Embedded Products. + * (c) Copyright 2016 National Instruments Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "ps7_init_gpl.h" +#include <asm/io.h> + +/* For delay calculation using global registers*/ +#define SCU_GLOBAL_TIMER_COUNT_L32 0xF8F00200 +#define SCU_GLOBAL_TIMER_COUNT_U32 0xF8F00204 +#define SCU_GLOBAL_TIMER_CONTROL 0xF8F00208 +#define SCU_GLOBAL_TIMER_AUTO_INC 0xF8F00218 +#define APU_FREQ 800000000 + +#define PS7_MASK_POLL_TIME 100000000 + +/* IO accessors. No memory barriers desired. */ +static inline void iowrite(unsigned long val, unsigned long addr) +{ + __raw_writel(val, addr); +} + +static inline unsigned long ioread(unsigned long addr) +{ + return __raw_readl(addr); +} + +/* start timer */ +static void perf_start_clock(void) +{ + iowrite((1 << 0) | /* Timer Enable */ + (1 << 3) | /* Auto-increment */ + (0 << 8), /* Pre-scale */ + SCU_GLOBAL_TIMER_CONTROL); +} + +/* Compute mask for given delay in miliseconds*/ +static int get_number_of_cycles_for_delay(unsigned int delay) +{ + return (APU_FREQ / (2 * 1000)) * delay; +} + +/* stop timer */ +static void perf_disable_clock(void) +{ + iowrite(0, SCU_GLOBAL_TIMER_CONTROL); +} + +/* stop timer and reset timer count regs */ +static void perf_reset_clock(void) +{ + perf_disable_clock(); + iowrite(0, SCU_GLOBAL_TIMER_COUNT_L32); + iowrite(0, SCU_GLOBAL_TIMER_COUNT_U32); +} + +static void perf_reset_and_start_timer(void) +{ + perf_reset_clock(); + perf_start_clock(); +} + + +int ps7_config(unsigned long *ps7_config_init) +{ + unsigned long *ptr = ps7_config_init; + unsigned long opcode; + unsigned long addr; + unsigned long val; + unsigned long mask; + unsigned int numargs; + int i; + int delay; + + for (;;) { + opcode = ptr[0]; + if (opcode == OPCODE_EXIT) + return PS7_INIT_SUCCESS; + addr = (opcode & OPCODE_ADDRESS_MASK); + + switch (opcode & ~OPCODE_ADDRESS_MASK) { + case OPCODE_MASKWRITE: + numargs = 3; + mask = ptr[1]; + val = ptr[2]; + iowrite((ioread(addr) & ~mask) | (val & mask), addr); + break; + + case OPCODE_MASKPOLL: + numargs = 2; + mask = ptr[1]; + i = 0; + while (!(ioread(addr) & mask)) { + if (i == PS7_MASK_POLL_TIME) + return PS7_INIT_TIMEOUT; + i++; + } + break; + + case OPCODE_MASKDELAY: + numargs = 2; + mask = ptr[1]; + delay = get_number_of_cycles_for_delay(mask); + perf_reset_and_start_timer(); + while (ioread(addr) < delay) + ; + break; + + default: + return PS7_INIT_CORRUPT; + } + + ptr += numargs; + } +} diff --git a/board/ni/zynq/ps7_init_gpl.h b/board/ni/zynq/ps7_init_gpl.h new file mode 100644 index 0000000..ef719ac --- /dev/null +++ b/board/ni/zynq/ps7_init_gpl.h @@ -0,0 +1,34 @@ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + * (c) Copyright 2016 Topic Embedded Products. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define OPCODE_EXIT 0U +#define OPCODE_MASKWRITE 0U +#define OPCODE_MASKPOLL 1U +#define OPCODE_MASKDELAY 2U +#define OPCODE_ADDRESS_MASK (~3U) + +/* Sentinel */ +#define EMIT_EXIT() OPCODE_EXIT +/* Opcode is in lower 2 bits of address, address is always 4-byte aligned */ +#define EMIT_MASKWRITE(addr, mask, val) OPCODE_MASKWRITE | addr, mask, val +#define EMIT_MASKPOLL(addr, mask) OPCODE_MASKPOLL | addr, mask +#define EMIT_MASKDELAY(addr, mask) OPCODE_MASKDELAY | addr, mask + +/* Returns codes of ps7_init* */ +#define PS7_INIT_SUCCESS (0) +#define PS7_INIT_CORRUPT (1) +#define PS7_INIT_TIMEOUT (2) +#define PS7_POLL_FAILED_DDR_INIT (3) +#define PS7_POLL_FAILED_DMA (4) +#define PS7_POLL_FAILED_PLL (5) + +/* Called by spl.c */ +int ps7_init(void); +int ps7_post_config(void); + +/* Defined in ps7_init_common.c */ +int ps7_config(unsigned long *ps7_config_init); diff --git a/board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c b/board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c new file mode 100644 index 0000000..43a9655 --- /dev/null +++ b/board/ni/zynq/zynq-ni-sulfur-rev2/ps7_init_gpl.c @@ -0,0 +1,313 @@ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + * (c) Copyright 2016 National Instruments Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "../ps7_init_gpl.h" + +unsigned long ps7_pll_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA240U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00030000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00302301U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00100801U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A03U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000603U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00100A00U), + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00101400U), + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00101400U), + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00101400U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x017CC44DU), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU, 0x00001081U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004281AU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44E458D2U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0x720238E5U), + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU, 0x270872D0U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000008U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040930U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0F666666U), + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284141U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x00200066U), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000003U), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU, 0x00040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FC82U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C61CU), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001200U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00001200U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x000002E0U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x000012E1U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x00001261U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x00001260U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001261U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001261U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000012E1U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000012E0U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x000012A0U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x000012A0U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x000012A0U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x000012A0U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00001240U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00001240U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_MASKWRITE(0XE0001034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0001000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0001004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU, 0x000000C8U), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFF7F0080U), + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU, 0x000000C8U), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFF7F0000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFF7F0080U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU, 0x000000C8U), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFBF0040U), + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU, 0x000000C8U), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFBF0000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFBF0040U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU, 0x000000C8U), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFF70008U), + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU, 0x000000C8U), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFF70000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFF70008U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_debug_3_0[] = { + EMIT_MASKWRITE(0XF8898FB0, 0xFFFFFFFFU, 0xC5ACCE55U), + EMIT_MASKWRITE(0XF8899FB0, 0xFFFFFFFFU, 0xC5ACCE55U), + EMIT_MASKWRITE(0XF8809FB0, 0xFFFFFFFFU, 0xC5ACCE55U), + EMIT_EXIT(), +}; + +int ps7_post_config(void) +{ + return ps7_config(ps7_post_config_3_0); +} + + +int ps7_init(void) +{ + int ret; + + /* MIO init */ + ret = ps7_config(ps7_mio_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* PLL init */ + ret = ps7_config(ps7_pll_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* Clock init */ + ret = ps7_config(ps7_clock_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* DDR init */ + ret = ps7_config(ps7_ddr_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* Peripherals init */ + ret = ps7_config(ps7_peripherals_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + return PS7_INIT_SUCCESS; +} diff --git a/configs/ni_sulfur_rev2_defconfig b/configs/ni_sulfur_rev2_defconfig new file mode 100644 index 0000000..f9ac81f --- /dev/null +++ b/configs/ni_sulfur_rev2_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SYS_VENDOR="ni" +CONFIG_SYS_CONFIG_NAME="ni_sulfur_rev2" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-ni-sulfur-rev2" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ni-sulfur-rev2> " +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADFS=y +CONFIG_CMD_FPGA_LOADMK=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TPM=y +CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DM_I2C=y +CONFIG_I2C_CROS_EC_TUNNEL=y +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_CROS_EC=y +CONFIG_CROS_EC_SPI=y +CONFIG_I2C_EEPROM=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_ZYNQ_GEM=y +CONFIG_ZYNQ_SPI=y +CONFIG_TPM_TIS_INFINEON=y +CONFIG_TPM_AUTH_SESSIONS=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="National Instruments Inc" +CONFIG_G_DNL_VENDOR_NUM=0x3923 +CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_TPM=y diff --git a/include/configs/ni_sulfur_rev2.h b/include/configs/ni_sulfur_rev2.h new file mode 100644 index 0000000..4f9082a --- /dev/null +++ b/include/configs/ni_sulfur_rev2.h @@ -0,0 +1,65 @@ +/* + * (C) Copyright 2016 National Instruments + * + * Configuration for NI Ettus Research Project Sulfur Rev2 + * See zynq-common.h for Zynq common configs + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_NI_SULFUR_REV2 +#define __CONFIG_NI_SULFUR_REV2 + +#define CONFIG_ENV_IS_NOWHERE +#include "zynq-common.h" +#undef CONFIG_ENV_IS_NOWHERE + +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET 0xE0000 + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fit_image=fit.itb\0" \ + "load_addr=0x2000000\0" \ + "fit_size=0x800000\0" \ + "fdt_high=0x20000000\0" \ + "initrd_high=0x20000000\0" \ + "loadbootenv_addr=0x2000000\0" \ + "bootenv=uEnv.txt\0" \ + "bootenv_dev=mmc\0" \ + "loadbootenv=load ${bootenv_dev} 0 ${loadbootenv_addr} ${bootenv}\0" \ + "importbootenv=echo Importing environment from ${bootenv_dev} ...; " \ + "env import -t ${loadbootenv_addr} $filesize\0" \ + "bootenv_existence_test=test -e ${bootenv_dev} 0 /${bootenv}\0" \ + "setbootenv=if env run bootenv_existence_test; then " \ + "if env run loadbootenv; then " \ + "env run importbootenv; " \ + "fi; " \ + "fi; \0" \ + "sd_loadbootenv=set bootenv_dev mmc && " \ + "mmcinfo && "\ + "run setbootenv \0" \ + "usb_loadbootenv=set bootenv_dev usb && usb start && " \ + "run setbootenv \0" \ + "preboot=if test $modeboot = sdboot; then " \ + "run sd_loadbootenv; " \ + "echo Checking if uenvcmd is set ...; " \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...; " \ + "run uenvcmd; " \ + "fi; " \ + "fi; \0" \ + "sdboot=echo Copying FIT from SD to RAM... && " \ + "load mmc 0 ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}\0" \ + "jtagboot=echo TFTPing FIT to RAM... && " \ + "tftpboot ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}\0" \ + "usbboot=if usb start; then " \ + "echo Copying FIT from USB to RAM... && " \ + "load usb 0 ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}; fi\0" \ + DFU_ALT_INFO + +#endif /* __CONFIG_NI_SULFUR_REV2 */
- zynq-ni-sulfur-rev2.dtb \ zynq-topic-miami.dtb \ zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \
- U-Boot addition to handle Sulfur Rev2 pins
- (C) Copyright 2016 National Instruments Corp
+&gpio0 {
- sys_pwron_33 {
- National Instruments Ettus Research Project Sulfur SDR Revision 2
- devicetree source.
- Copyright (c) 2016 National Instruments Corp.
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
This should be handled via SPDX - both are in source code.
+/dts-v1/;
- model = "NI Ettus Research Project Sulfur SDR Rev2";
- compatible = "ettus,zynq-sulfur-rev2", "xlnx,zynq-7000";
- aliases {
ethernet0 = &gem0;
serial0 = &uart0;
serial1 = &uart1;
spi0 = &spi1;
i2c20 = &tun;
i2c0 = &i2c0;
Is this handled properly now?
mmc0 = &sdhci0;
- memory {
- chosen {
- usb_phy0: phy0 {
#phy-cells = <0>;
- gpio-poweroff {
+&cpu0 {
- operating-points = <800000 1000000>;
+&sdhci0 {
- u-boot,dm-pre-reloc;
- status = "okay";
+&uart0 {
- status = "okay";
+&uart1 {
- status = "okay";
- status = "disabled";
+&i2c0 {
- status = "okay";
- clock-frequency = <400000>;
- i2cswitch@70 {
#size-cells = <0>;
reg = <0x70>;
status = "okay";
i2c0_70_0: i2c@0 {
reg = <0x0>;
#size-cells = <0>;
no reason for this line.
status = "okay";
i2c0_70_1: i2c@1 {
reg = <0x1>;
What's the reason for these statuses here? Is this handled by u-boot core now?
i2c0_70_2: i2c@2 {
reg = <0x2>;
#size-cells = <0>;
status = "okay";
i2c0_70_3: i2c@3 {
reg = <0x3>;
i2c0_70_4: i2c@4 {
reg = <0x4>;
#size-cells = <0>;
status = "okay";
tpm: tpm@20 {
reg = <0x20>;
i2c0_70_5: i2c@5 {
reg = <0x5>;
i2c0_70_6: i2c@6 {
reg = <0x6>;
i2c0_70_7: i2c@7 {
reg = <0x7>;
+&spi1 {
- status = "okay";
tab instead of spaces here.
- spi-deactivate-delay = <200>;
- cros_ec: ec@0 {
reg = <0>;
tun: i2c-tunnel {
#size-cells = <0>;
hwmon0: hwmon@48 {
reg = <0x48>;
nvmem0: eeprom@50 {
reg = <0x50>;
rtc0: rtc@68 {
reg = <0x68>;
+&clkc {
- ps-clk-frequency = <33333333>;
+&gem0 {
- status = "okay";
- phy-mode = "rgmii-id";
- phy-handle = <ðernet_phy0>;
- ethernet_phy0: ethernet-phy@0 {
reg = <0>;
+&usb0 {
- status = "okay";
- dr_mode = "otg";
- usb-phy = <&usb_phy0>;
+&gpio0 {
- status = "okay";
+&amba {
- fpga_region0: fpga-region@40000000 {
reg = <0x40000000>;
This reg property is weird.
arch/arm/dts/zynq-ni-sulfur-rev2.dtb: Warning (reg_format): "reg" property in /amba/fpga-region@40000000 has invalid length (4 bytes) (#address-cells == 1, #size-cells == 1)
Anyway I have enabled fpga-region in xilinx vendor tree and we should add it there than we would avoid this.
I have sent a patch for that that to enable it for all zynq devices.
ranges;
- ocm: sram@fffc0000 {
+obj-y := board.o
- (C) Copyright 2012 Michal Simek monstr@monstr.eu
- (defined(CONFIG_SPL_FPGA_SUPPORT) && defined(CONFIG_SPL_BUILD))
It will be better to extend board.c in xilinx tree and add functionality which you are missing.
- BOARD_POWER_TYPE_ON,
- BOARD_POWER_TYPE_OFF, };
- struct gpio_desc sys_pwron_33;
- struct udevice *zynq_gpio;
- const void *blob = gd->fdt_blob;
- int node, ret;
- ret = uclass_get_device_by_seq(UCLASS_GPIO, 0, &zynq_gpio);
- if (ret < 0) {
- node = fdt_subnode_offset(blob, dev_of_offset(zynq_gpio),
"sys_pwron_33");
- ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "gpios", 0,
&sys_pwron_33, 0);
- if (ret < 0) {
return ret;
- if (type == BOARD_POWER_TYPE_OFF) {
- } else {
+} +#endif
This looks more like a gpio power driver. If there is no driver for it directly you can use for example misc_init_r which you will define just in your file that you don't need to hoookup board_late_init().
- u32 idcode;
- idcode = zynq_slcr_get_idcode();
- switch (idcode) {
- case XILINX_ZYNQ_7007S:
fpga = fpga007s;
break;
- case XILINX_ZYNQ_7010:
fpga = fpga010;
break;
- case XILINX_ZYNQ_7012S:
fpga = fpga012s;
break;
- case XILINX_ZYNQ_7014S:
fpga = fpga014s;
break;
- case XILINX_ZYNQ_7015:
fpga = fpga015;
break;
- case XILINX_ZYNQ_7020:
fpga = fpga020;
break;
- case XILINX_ZYNQ_7030:
fpga = fpga030;
break;
- case XILINX_ZYNQ_7035:
fpga = fpga035;
break;
- case XILINX_ZYNQ_7045:
fpga = fpga045;
break;
- case XILINX_ZYNQ_7100:
fpga = fpga100;
break;
- fpga_init();
- fpga_add(fpga_xilinx, &fpga);
- switch ((zynq_slcr_get_boot_mode()) & ZYNQ_BM_MASK) {
- case ZYNQ_BM_QSPI:
break;
- case ZYNQ_BM_NAND:
break;
- case ZYNQ_BM_NOR:
break;
- case ZYNQ_BM_SD:
break;
- case ZYNQ_BM_JTAG:
break;
- default:
break;
- board_power(BOARD_POWER_TYPE_ON);
- puts("Board: NI Sulfur SDR Board\n");
We should probably patch this and read this from DT instead.
+} +#endif
- defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET)
- if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR,
ethaddr, 6))
- fdtdec_setup_memory_banksize();
- if (fdtdec_setup_memory_size() != 0)
return -EINVAL;
- zynq_ddrc_init();
- gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
- zynq_ddrc_init();
+} +#endif
ok - it means we should probably fine with using default board file.
- (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved.
- (c) Copyright 2016 Topic Embedded Products.
- (c) Copyright 2016 National Instruments Corp.
- __raw_writel(val, addr);
- return __raw_readl(addr);
- iowrite((1 << 0) | /* Timer Enable */
- return (APU_FREQ / (2 * 1000)) * delay;
- iowrite(0, SCU_GLOBAL_TIMER_CONTROL);
- perf_disable_clock();
- iowrite(0, SCU_GLOBAL_TIMER_COUNT_L32);
- iowrite(0, SCU_GLOBAL_TIMER_COUNT_U32);
- perf_reset_clock();
- perf_start_clock();
- unsigned long *ptr = ps7_config_init;
- unsigned long opcode;
- unsigned long addr;
- unsigned long val;
- unsigned long mask;
- unsigned int numargs;
- int i;
- int delay;
- for (;;) {
opcode = ptr[0];
numargs = 3;
mask = ptr[1];
val = ptr[2];
break;
numargs = 2;
mask = ptr[1];
i = 0;
i++;
break;
numargs = 2;
mask = ptr[1];
break;
default:
ptr += numargs;
- EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU),
- EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA240U),
- EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00030000U),
- EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0XF800010C, 0x00000001U),
- EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U),
- EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U),
- EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U),
- EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0XF800010C, 0x00000002U),
- EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U),
- EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U),
- EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U),
- EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U),
- EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U),
- EMIT_MASKPOLL(0XF800010C, 0x00000004U),
- EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U),
- EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00302301U),
- EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00100801U),
- EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U),
- EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A03U),
- EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000603U),
- EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U),
- EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00100A00U),
- EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00101400U),
- EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00101400U),
- EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00101400U),
- EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x017CC44DU),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU, 0x00001081U),
- EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU),
- EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U),
- EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U),
- EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004281AU),
- EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44E458D2U),
- EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0x720238E5U),
- EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU, 0x270872D0U),
- EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U, 0x00000000U),
- EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U),
- EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000008U),
- EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040930U),
- EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U),
- EMIT_MASKWRITE(0XF8006038, 0x00000003U, 0x00000000U),
- EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U),
- EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U),
- EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0F666666U),
- EMIT_MASKWRITE(0XF8006048, 0x0003F03FU, 0x0003C008U),
- EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U),
- EMIT_MASKWRITE(0XF8006058, 0x00010000U, 0x00000000U),
- EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U),
- EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU),
- EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U),
- EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284141U),
- EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U),
- EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U),
- EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U),
- EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U),
- EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U),
- EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU),
- EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU),
- EMIT_MASKWRITE(0XF80060B4, 0x00000200U, 0x00000200U),
- EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x00200066U),
- EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000003U),
- EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U),
- EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U),
- EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U),
- EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U),
- EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U),
- EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U),
- EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU, 0x40000001U),
- EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x00018000U),
- EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x00018000U),
- EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x00018000U),
- EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x00018000U),
- EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U),
- EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x00000080U),
- EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000B5U),
- EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000B5U),
- EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000B5U),
- EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000B5U),
- EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000C0U),
- EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000C0U),
- EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U),
- EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000C0U),
- EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU, 0x00040080U),
- EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FC82U),
- EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U),
- EMIT_MASKWRITE(0XF8006208, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF800620C, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006210, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006214, 0x000703FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU),
- EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U, 0x00000000U),
- EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U),
- EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U),
- EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U),
- EMIT_MASKPOLL(0XF8000B74, 0x00002000U),
- EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U),
- EMIT_MASKPOLL(0XF8006054, 0x00000007U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U),
- EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U),
- EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U),
- EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U),
- EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C61CU),
- EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F9861CU),
- EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F9861CU),
- EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F9861CU),
- EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U),
- EMIT_MASKWRITE(0XF8000B70, 0x00000001U, 0x00000001U),
- EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U),
- EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU, 0x00000823U),
- EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001200U),
- EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00001200U),
- EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000200U),
- EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000200U),
- EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000200U),
- EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000200U),
- EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000200U),
- EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000200U),
- EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x000002E0U),
- EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x000012E1U),
- EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x00001261U),
- EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x00001260U),
- EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001261U),
- EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001261U),
- EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x000012E1U),
- EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x000012E0U),
- EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00001202U),
- EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00001202U),
- EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00001202U),
- EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00001202U),
- EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00001202U),
- EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00001202U),
- EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00001203U),
- EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00001203U),
- EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00001203U),
- EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00001203U),
- EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00001203U),
- EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00001203U),
- EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00001205U),
- EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00001205U),
- EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00001205U),
- EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00001204U),
- EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x000012A0U),
- EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x000012A0U),
- EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x000012A0U),
- EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x000012A0U),
- EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00001240U),
- EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00001240U),
- EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00001280U),
- EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U),
- EMIT_MASKWRITE(0XE0001034, 0x000000FFU, 0x00000006U),
- EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000007CU),
- EMIT_MASKWRITE(0XE0001000, 0x000001FFU, 0x00000017U),
- EMIT_MASKWRITE(0XE0001004, 0x000003FFU, 0x00000020U),
- EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U),
- EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU),
- EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U),
- EMIT_MASKWRITE(0XE0000004, 0x000003FFU, 0x00000020U),
- EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U),
- EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U),
- EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU, 0x000000C8U),
- EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFF7F0080U),
- EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU, 0x000000C8U),
- EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFF7F0000U),
- EMIT_MASKDELAY(0XF8F00200, 1),
- EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFBF0040U),
- EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFBF0000U),
- EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFF70008U),
- EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU, 0xFFF70000U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU),
- EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8898FB0, 0xFFFFFFFFU, 0xC5ACCE55U),
- EMIT_MASKWRITE(0XF8899FB0, 0xFFFFFFFFU, 0xC5ACCE55U),
- EMIT_MASKWRITE(0XF8809FB0, 0xFFFFFFFFU, 0xC5ACCE55U),
- EMIT_EXIT(),
- return ps7_config(ps7_post_config_3_0);
- int ret;
- /* MIO init */
- ret = ps7_config(ps7_mio_init_data_3_0);
- if (ret != PS7_INIT_SUCCESS)
return ret;
- /* PLL init */
- ret = ps7_config(ps7_pll_init_data_3_0);
return ret;
- /* Clock init */
- ret = ps7_config(ps7_clock_init_data_3_0);
return ret;
- /* DDR init */
- ret = ps7_config(ps7_ddr_init_data_3_0);
return ret;
- /* Peripherals init */
- ret = ps7_config(ps7_peripherals_init_data_3_0);
return ret;
- return PS7_INIT_SUCCESS;
- Configuration for NI Ettus Research Project Sulfur Rev2
- See zynq-common.h for Zynq common configs
- "fit_image=fit.itb\0" \
- "load_addr=0x2000000\0" \
- "fit_size=0x800000\0" \
- "fdt_high=0x20000000\0" \
- "initrd_high=0x20000000\0" \
- "loadbootenv_addr=0x2000000\0" \
- "bootenv=uEnv.txt\0" \
- "bootenv_dev=mmc\0" \
- "loadbootenv=load ${bootenv_dev} 0 ${loadbootenv_addr} ${bootenv}\0" \
- "importbootenv=echo Importing environment from ${bootenv_dev} ...; " \
- "bootenv_existence_test=test -e ${bootenv_dev} 0 /${bootenv}\0" \
- "setbootenv=if env run bootenv_existence_test; then " \
"fi; " \
"fi; \0" \
- "sd_loadbootenv=set bootenv_dev mmc && " \
"mmcinfo && "\
- "usb_loadbootenv=set bootenv_dev usb && usb start && " \
- "preboot=if test $modeboot = sdboot; then " \
"run uenvcmd; " \
"fi; " \
"fi; \0" \
- "sdboot=echo Copying FIT from SD to RAM... && " \
- "jtagboot=echo TFTPing FIT to RAM... && " \
- "usbboot=if usb start; then " \
DFU_ALT_INFO
The rest looks good.
Thanks, Michal
+&gpio0 {
sys_pwron_33 {
- whole.
conditions:
Will fix.
+/dts-v1/;
aliases {
ethernet0 = &gem0;
serial0 = &uart0;
serial1 = &uart1;
spi0 = &spi1;
i2c20 = &tun;
i2c0 = &i2c0;
It seemed to work.
mmc0 = &sdhci0;
memory {
chosen {
usb_phy0: phy0 {
#phy-cells = <0>;
gpio-poweroff {
+&cpu0 {
+&sdhci0 {
status = "okay";
+&uart0 {
status = "okay";
+&uart1 {
status = "okay";
+&i2c0 {
status = "okay";
i2cswitch@70 {
#size-cells = <0>;
reg = <0x70>;
status = "okay";
i2c0_70_0: i2c@0 {
reg = <0x0>;
#size-cells = <0>;
Will drop.
status = "okay";
i2c0_70_1: i2c@1 {
reg = <0x1>;
Nope, will drop them.
i2c0_70_2: i2c@2 {
reg = <0x2>;
#size-cells = <0>;
status = "okay";
i2c0_70_3: i2c@3 {
reg = <0x3>;
i2c0_70_4: i2c@4 {
reg = <0x4>;
#size-cells = <0>;
status = "okay";
tpm: tpm@20 {
reg = <0x20>;
i2c0_70_5: i2c@5 {
reg = <0x5>;
i2c0_70_6: i2c@6 {
reg = <0x6>;
i2c0_70_7: i2c@7 {
reg = <0x7>;
+&spi1 {
status = "okay";
Will fix
cros_ec: ec@0 {
reg = <0>;
tun: i2c-tunnel {
#size-cells = <0>;
hwmon0: hwmon@48 {
reg = <0x48>;
nvmem0: eeprom@50 {
reg = <0x50>;
rtc0: rtc@68 {
reg = <0x68>;
+&clkc {
+&gem0 {
status = "okay";
reg = <0>;
+&usb0 {
status = "okay";
dr_mode = "otg";
+&gpio0 {
status = "okay";
+&amba {
reg = <0x40000000>;
Agreed.
Will fix.
Cool, will take that then.
ranges;
+obj-y := board.o
int node, ret;
if (ret < 0) {
"sys_pwron_33");
&sys_pwron_33, 0);
if (ret < 0) {
return ret;
} else {
+} +#endif
Basically need to tell the MCU to not shut us off by asserting a GPIO, so kinda the inverse of a gpio_power driver if I understand correctly. I didn't see any code for gpio-power class in u-boot, so I could look at adding that, but this could be a follow up patch I suppose.
u32 idcode;
switch (idcode) {
fpga = fpga007s;
break;
fpga = fpga010;
break;
fpga = fpga012s;
break;
fpga = fpga014s;
break;
fpga = fpga015;
break;
fpga = fpga020;
break;
fpga = fpga030;
break;
fpga = fpga035;
break;
fpga = fpga045;
break;
fpga = fpga100;
break;
fpga_init();
case ZYNQ_BM_QSPI:
break;
case ZYNQ_BM_NAND:
break;
case ZYNQ_BM_NOR:
break;
case ZYNQ_BM_SD:
break;
case ZYNQ_BM_JTAG:
break;
default:
break;
The 'model' property?
+} +#endif
ethaddr, 6))
return -EINVAL;
zynq_ddrc_init();
zynq_ddrc_init();
+} +#endif
perf_reset_clock();
perf_start_clock();
unsigned long addr;
unsigned long val;
unsigned long mask;
int i;
int delay;
for (;;) {
opcode = ptr[0];
numargs = 3;
mask = ptr[1];
val = ptr[2];
break;
numargs = 2;
mask = ptr[1];
i = 0;
i++;
break;
numargs = 2;
mask = ptr[1];
break;
default:
ptr += numargs;
EMIT_EXIT(),
EMIT_EXIT(),
EMIT_EXIT(),
EMIT_EXIT(),
EMIT_EXIT(),
EMIT_EXIT(),
EMIT_EXIT(),
int ret;
/* MIO init */
return ret;
/* PLL init */
return ret;
/* Clock init */
return ret;
/* DDR init */
return ret;
return ret;
"fi; " \
"fi; \0" \
"mmcinfo && "\
"run uenvcmd; " \
"fi; " \
"fi; \0" \
DFU_ALT_INFO
To clarify: You're suggesting to dump all that stuff into the xilinx/zynq/board.c with ifdefs?
Any comments on the ps7_init_common part?
Thanks for the review,
Moritz
<snip>
yes
"fi; " \
"fi; \0" \
"mmcinfo && "\
"run uenvcmd; " \
"fi; " \
"fi; \0" \
DFU_ALT_INFO
I mean that making these option generic that any board can use them is the best way.
ps part is nice.
Thanks, Michal
Add support for second revision of NI Ettus Research Project Sulfur Revision 3 SDR board.
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi | 26 ++ arch/arm/dts/zynq-ni-sulfur-rev3.dts | 325 +++++++++++++++++++++++ board/ni/zynq/board.c | 38 +++ board/ni/zynq/sulfur-eeprom.h | 66 +++++ board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c | 307 +++++++++++++++++++++ configs/ni_sulfur_rev3_defconfig | 69 +++++ include/configs/ni_sulfur_rev3.h | 42 +++ 8 files changed, 874 insertions(+) create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi create mode 100644 arch/arm/dts/zynq-ni-sulfur-rev3.dts create mode 100644 board/ni/zynq/sulfur-eeprom.h create mode 100644 board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c create mode 100644 configs/ni_sulfur_rev3_defconfig create mode 100644 include/configs/ni_sulfur_rev3.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c3be80f..2a29b9c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -127,6 +127,7 @@ dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-microzed.dtb \ zynq-picozed.dtb \ zynq-ni-sulfur-rev2.dtb \ + zynq-ni-sulfur-rev3.dtb \ zynq-topic-miami.dtb \ zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \ diff --git a/arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi b/arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi new file mode 100644 index 0000000..9a8b4e7 --- /dev/null +++ b/arch/arm/dts/zynq-ni-sulfur-rev3-uboot.dtsi @@ -0,0 +1,26 @@ +/* + * U-Boot addition to handle Sulfur Rev3 pins + * + * (C) Copyright 2017 National Instruments Corp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/gpio/gpio.h> + +&gpio0 { + u-boot,dm-pre-reloc; + + sys_pwron_33 { + u-boot,dm-pre-reloc; + gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&sdhci0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/zynq-ni-sulfur-rev3.dts b/arch/arm/dts/zynq-ni-sulfur-rev3.dts new file mode 100644 index 0000000..3e2c69e --- /dev/null +++ b/arch/arm/dts/zynq-ni-sulfur-rev3.dts @@ -0,0 +1,325 @@ +/* + * National Instruments Ettus Research Project Sulfur SDR Revision 2 + * devicetree source. + * + * Copyright (c) 2016 National Instruments Corp. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/gpio/gpio.h> +#include "zynq-7000.dtsi" + +/ { + model = "NI Ettus Research Project Sulfur SDR Rev3"; + compatible = "ettus,zynq-sulfur-rev3", "xlnx,zynq-7000"; + + aliases { + ethernet0 = &gem0; + serial0 = &uart0; + serial1 = &uart1; + spi0 = &spi0; + spi1 = &spi1; + gpio0 = &gpio0; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c20 = &tun; + }; + + memory { + device_type = "memory"; + reg = <0x0 0x40000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + + power-button { + label = "Power Button"; + linux,code = <KEY_POWER>; + gpios = <&gpio0 1 GPIO_ACTIVE_HIGH>; + }; + }; + + gpio-poweroff { + compatible = "gpio-poweroff"; + gpios = <&gpio0 3 GPIO_ACTIVE_LOW>; + }; + + leds { + compatible = "gpio-leds"; + led0 { + label = "sulfur:ledp"; + gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "keep"; + }; + }; + + usb_phy0: phy0 { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + reset-gpios = <&gpio0 51 GPIO_ACTIVE_LOW>; + }; + +}; + +&cpu0 { + operating-points = <800000 1000000>; +}; + +&sdhci0 { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +/* we use the ARM global timer */ +&ttc0 { + status = "disabled"; +}; + +/* we use the ARM global timer */ +&ttc1 { + status = "disabled"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + i2cswitch@70 { + compatible = "ti,pca9548"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x70>; + + reset-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; + + i2c@0 { + reg = <0>; + status = "disabled"; + }; + + i2c@1 { + reg = <1>; + status = "disabled"; + }; + + i2c@2 { + reg = <2>; + status = "disabled"; + }; + + i2c@3 { + reg = <3>; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + gpio1: gpio@22 { + compatible = "ti,tca6424"; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + }; + }; + + i2c@4 { + reg = <4>; + status = "disabled"; + }; + + i2c@5 { + reg = <5>; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + rtc0: rtc@68 { + compatible = "dallas,ds1374"; + reg = <0x68>; + }; + }; + + usrpio_i2c0: i2c@6 { + reg = <6>; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + }; + }; + + usrpio_i2c1: i2c@7 { + reg = <7>; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + }; + + }; + }; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + embedded-controller@1e { + reg = <0x1e>; + compatible = "ni,embedded-controller-i2c", + "google,cros-ec-i2c"; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + interrupt-parent = <&gpio0>; + google,has-vbc-nvram; + + wakeup-source; + + tun: i2c-tunnel { + compatible = "google,cros-ec-i2c-tunnel"; + #address-cells = <1>; + #size-cells = <0>; + google,remote-bus = <0>; + clock-frequency = <100000>; + + nvmem0: eeprom@50 { + compatible = "at24,24c02"; + reg = <0x50>; + #address-cells = <1>; + #size-cells = <0>; + read-only; + + eth0_addr: eth-addr@24 { + reg = <0x24 0x6>; + }; + + eth1_addr: eth-addr@2c { + reg = <0x2c 0x6>; + }; + + eth2_addr: eth-addr@34 { + reg = <0x34 0x6>; + }; + }; + }; + }; + +}; + +&gpio0 { + status = "okay"; + + ledn { + gpio-hog; + gpios = <4 GPIO_ACTIVE_LOW>; + output-high; + }; +}; + +&clkc { + ps-clk-frequency = <33333333>; + fclk-enable = <0xf>; +}; + +&spi0 { + status = "disabled"; +}; + +&spi1 { + status = "disabled"; +}; + +&gem0 { + status = "okay"; + phy-mode = "rgmii-id"; + phy-handle = <ðernet_phy0>; + + + ethernet_phy0: ethernet-phy@0 { + reg = <0>; + reset-gpios = <&gpio0 50 GPIO_ACTIVE_LOW>; + }; +}; + +&usb0 { + status = "okay"; + dr_mode = "otg"; + usb-phy = <&usb_phy0>; +}; + +&amba { + fpga_region0: fpga-region@40000000 { + compatible = "fpga-region"; + fpga-mgr = <&devcfg>; + #address-cells = <0x1>; + #size-cells = <0x1>; + ranges; + }; + + ocm: sram@fffc0000 { + compatible = "mmio-sram"; + reg = <0xfffc0000 0x10000>; + }; +}; + +#include "zynq-ni-sulfur-rev3-uboot.dtsi" diff --git a/board/ni/zynq/board.c b/board/ni/zynq/board.c index be818da..3dc30ad 100644 --- a/board/ni/zynq/board.c +++ b/board/ni/zynq/board.c @@ -14,6 +14,9 @@ #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h>
+#include "sulfur-eeprom.h" +#include <i2c.h> + DECLARE_GLOBAL_DATA_PTR;
#if (defined(CONFIG_FPGA) && !defined(CONFIG_SPL_BUILD)) || \ @@ -162,6 +165,39 @@ int checkboard(void) } #endif
+int sulfur_read_ethaddr(unsigned char *ethaddr) +{ + struct udevice *i2c_tun, *eeprom_chip; + struct sulfur_mboard_eeprom eeprom; + int err, i; + u32 crc; + + err = uclass_get_device_by_seq(UCLASS_I2C, 20, &i2c_tun); + if (err < 0) + return err; + + err = dm_i2c_probe(i2c_tun, 0x50, 0, &eeprom_chip); + if (err < 0) + return err; + + for (i = 0; i < sizeof(eeprom); i++) { + err = dm_i2c_reg_read(eeprom_chip, i); + if (err < 0) + break; + *(((u8 *)(&eeprom)) + i) = err & 0xff; + } + + crc = crc32(0, (const u8 *)&eeprom, sizeof(eeprom) - 4); + if (htonl(crc) != eeprom.crc) { + printf("%s: CRC for eeprom doesn't match! %08x vs %08x\n", + __func__, htonl(crc), eeprom.crc); + return -EINVAL; + } + memcpy(ethaddr, &eeprom.eth_addr0, ETH_ALEN); + + return 0; +} + int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) { #if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ @@ -172,6 +208,8 @@ int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) printf("I2C EEPROM MAC address read failed\n"); #endif
+ sulfur_read_ethaddr(ethaddr); + return 0; }
diff --git a/board/ni/zynq/sulfur-eeprom.h b/board/ni/zynq/sulfur-eeprom.h new file mode 100644 index 0000000..ed1c8a3 --- /dev/null +++ b/board/ni/zynq/sulfur-eeprom.h @@ -0,0 +1,66 @@ +/* + * NI Ettus Research Sulfur EEPROM helpers + * + * Copyright (c) 2017 National Instruments Corp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef NI_ZYNQ_SULFUR_EEPROM_H +#define NI_ZYNQ_SULFUR_EEPROM_H + +#define ETH_ALEN 6 + +/** + * sulfur_mboard_eeprom - The memory map of the USRP Sulfur SDR EEPROM + * + * @magic: Magic constant to indicate that one is looking at a MB eeprom + * @version: Data layout version + * @mcu_flags: Flags for the EC + * @pid: Product Identifier + * @rev: Revision Number (zero based) + * @serial: (Non zero terminated) String containing the serial number + * @eth_addr0: Contains ethernet address for eth0 + * @__pad0: Padding + * @eth_addr1: Contains ethernet address for eth1 + * @__pad1: Padding + * @eth_addr2: Contains ethernet address for eth2 + * @__pad2: Padding + * @crc: Contains checksum over the entire struct minus the crc member + */ +struct sulfur_mboard_eeprom { + u32 magic; + u32 version; + u32 mcu_flags[4]; + u16 pid; + u16 rev; + u8 serial[8]; + u8 eth_addr0[ETH_ALEN]; + u8 __pad_0[2]; + u8 eth_addr1[ETH_ALEN]; + u8 __pad_1[2]; + u8 eth_addr2[ETH_ALEN]; + u8 __pad_2[2]; + u32 crc; +} __packed; + +/** + * sulfur_dboard_eeprom - The memory map of the USRP Sulfur SDR EEPROM + * + * @magic: Magic constant to indicate that one is looking at a DB eeprom + * @version: Data layout version + * @pid: Product Identifier + * @rev: Revision Number (zero based) + * @serial: (Non zero terminated) String containing the serial number + * @crc: Contains checksum over the entire struct minus the crc member + */ +struct sulfur_dboard_eeprom { + u32 magic; + u32 version; + u16 pid; + u16 rev; + u8 serial[8]; + u32 crc; +} __packed; + +#endif /* NI_ZYNQ_SULFUR_EEPROM_H */ diff --git a/board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c b/board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c new file mode 100644 index 0000000..92a0a74 --- /dev/null +++ b/board/ni/zynq/zynq-ni-sulfur-rev3/ps7_init_gpl.c @@ -0,0 +1,307 @@ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + * (c) Copyright 2017 National Instruments Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "../ps7_init_gpl.h" + +unsigned long ps7_pll_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U, 0x000FA240U), + EMIT_MASKWRITE(0XF8000100, 0x0007F000U, 0x00030000U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + EMIT_MASKWRITE(0XF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0XF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + EMIT_MASKWRITE(0XF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0XF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + EMIT_MASKWRITE(0XF8000108, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_clock_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0XF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U, 0x00100801U), + EMIT_MASKWRITE(0XF8000150, 0x00003F33U, 0x00000A01U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A03U), + EMIT_MASKWRITE(0XF8000158, 0x00003F33U, 0x00000603U), + EMIT_MASKWRITE(0XF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00200500U), + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00500500U), + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00200300U), + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00100500U), + EMIT_MASKWRITE(0XF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU, 0x017CC44DU), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU, 0x00001081U), + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004281BU), + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU, 0x44E458D2U), + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU, 0x720238E5U), + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU, 0x270872D0U), + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU, 0x00000008U), + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU, 0x00040930U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0XF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU, 0x0F666666U), + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0XF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0XF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU, 0x00284141U), + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0XF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU, 0x00200066U), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000003U), + EMIT_MASKWRITE(0XF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0XF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU, 0x00018000U), + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU, 0x00000080U), + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU, 0x000000B5U), + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU, 0x000000C0U), + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU, 0x00040080U), + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU, 0x0001FC82U), + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +unsigned long ps7_mio_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU, 0x0018C61CU), + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0XF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0XF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001600U), + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00001600U), + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x000006E0U), + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000016E0U), + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001640U), + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001640U), + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x00001640U), + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x00001640U), + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00001261U), + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00001260U), + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00001261U), + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00001261U), + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00001200U), + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00001200U), + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0XF8000830, 0x003F003FU, 0x00380037U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000B54, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_MASKWRITE(0XE0001034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0001000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0001004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0XE0000034, 0x000000FFU, 0x00000006U), + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU, 0x0000007CU), + EMIT_MASKWRITE(0XE0000000, 0x000001FFU, 0x00000017U), + EMIT_MASKWRITE(0XE0000004, 0x000003FFU, 0x00000020U), + EMIT_MASKWRITE(0XE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0XF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU, 0x000C0000U), + EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x00370008U), + EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU, 0x000C0000U), + EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x00370000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x00370008U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU, 0x000C0000U), + EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x003B0004U), + EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU, 0x000C0000U), + EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x003B0000U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x003B0004U), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_MASKDELAY(0XF8F00200, 1), + EMIT_EXIT(), +}; + +unsigned long ps7_post_config_3_0[] = { + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU, 0x0000DF0DU), + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU, 0x0000767BU), + EMIT_EXIT(), +}; + +unsigned long ps7_debug_3_0[] = { + EMIT_MASKWRITE(0XF8898FB0, 0xFFFFFFFFU, 0xC5ACCE55U), + EMIT_MASKWRITE(0XF8899FB0, 0xFFFFFFFFU, 0xC5ACCE55U), + EMIT_MASKWRITE(0XF8809FB0, 0xFFFFFFFFU, 0xC5ACCE55U), + EMIT_EXIT(), +}; + +int ps7_post_config(void) +{ + return ps7_config(ps7_post_config_3_0); +} + +int ps7_init(void) +{ + int ret; + + /* MIO init */ + ret = ps7_config(ps7_mio_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* PLL init */ + ret = ps7_config(ps7_pll_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* Clock init */ + ret = ps7_config(ps7_clock_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* DDR init */ + ret = ps7_config(ps7_ddr_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + /* Peripherals init */ + ret = ps7_config(ps7_peripherals_init_data_3_0); + if (ret != PS7_INIT_SUCCESS) + return ret; + + return PS7_INIT_SUCCESS; +} diff --git a/configs/ni_sulfur_rev3_defconfig b/configs/ni_sulfur_rev3_defconfig new file mode 100644 index 0000000..51ea087 --- /dev/null +++ b/configs/ni_sulfur_rev3_defconfig @@ -0,0 +1,69 @@ +CONFIG_ARM=y +CONFIG_SYS_VENDOR="ni" +CONFIG_SYS_CONFIG_NAME="ni_sulfur_rev3" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-ni-sulfur-rev3" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ni-sulfur-rev3> " +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TPM=y +CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DM_I2C=y +CONFIG_I2C_CROS_EC_TUNNEL=y +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_CROS_EC=y +CONFIG_CROS_EC_I2C=y +CONFIG_I2C_EEPROM=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_ZYNQ_GEM=y +CONFIG_ZYNQ_SPI=y +CONFIG_TPM_AUTH_SESSIONS=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="National Instruments Inc" +CONFIG_G_DNL_VENDOR_NUM=0x3923 +CONFIG_G_DNL_PRODUCT_NUM=0x0301 +CONFIG_TPM=y diff --git a/include/configs/ni_sulfur_rev3.h b/include/configs/ni_sulfur_rev3.h new file mode 100644 index 0000000..1925513 --- /dev/null +++ b/include/configs/ni_sulfur_rev3.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2017 National Instruments + * + * Configuration for NI Ettus Research Project Sulfur Rev3 + * See zynq-common.h for Zynq common configs + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_NI_SULFUR_REV3 +#define __CONFIG_NI_SULFUR_REV3 + +#define CONFIG_ENV_IS_NOWHERE +#include "zynq-common.h" +#undef CONFIG_ENV_IS_NOWHERE + +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET 0xE0000 + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fit_image=fit.itb\0" \ + "bootargs=root=/dev/mmcblk0p2 rw rootwait " \ + "uio_pdrv_genirq.of_id=usrp-uio\0" \ + "load_addr=0x2000000\0" \ + "fit_size=0x800000\0" \ + "fdt_high=0x20000000\0" \ + "initrd_high=0x20000000\0" \ + "sdboot=echo Copying FIT from SD to RAM... && " \ + "load mmc 0 ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}\0" \ + "jtagboot=echo TFTPing FIT to RAM... && " \ + "tftpboot ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}\0" \ + "usbboot=if usb start; then " \ + "echo Copying FIT from USB to RAM... && " \ + "load usb 0 ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}; fi\0" \ + DFU_ALT_INFO + +#endif /* __CONFIG_NI_SULFUR_REV3 */
Save comments as before for this file.
- zynq-ni-sulfur-rev3.dtb \ zynq-topic-miami.dtb \ zynq-topic-miamilite.dtb \ zynq-topic-miamiplus.dtb \
- U-Boot addition to handle Sulfur Rev3 pins
- (C) Copyright 2017 National Instruments Corp
+&gpio0 {
- sys_pwron_33 {
+&uart0 {
+&sdhci0 {
- whole.
conditions:
+/dts-v1/;
- model = "NI Ettus Research Project Sulfur SDR Rev3";
- compatible = "ettus,zynq-sulfur-rev3", "xlnx,zynq-7000";
- aliases {
ethernet0 = &gem0;
serial0 = &uart0;
serial1 = &uart1;
spi0 = &spi0;
spi1 = &spi1;
gpio0 = &gpio0;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c20 = &tun;
- memory {
- chosen {
- gpio-keys {
#size-cells = <0>;
power-button {
- gpio-poweroff {
- leds {
led0 {
- usb_phy0: phy0 {
#phy-cells = <0>;
+&cpu0 {
+&sdhci0 {
- status = "okay";
+&uart0 {
- status = "okay";
+&uart1 {
- status = "okay";
+&i2c0 {
- status = "okay";
- i2cswitch@70 {
#size-cells = <0>;
reg = <0x70>;
i2c@0 {
reg = <0>;
i2c@1 {
reg = <1>;
i2c@2 {
reg = <2>;
i2c@3 {
reg = <3>;
status = "okay";
#size-cells = <0>;
gpio1: gpio@22 {
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
i2c@4 {
reg = <4>;
i2c@5 {
reg = <5>;
status = "okay";
#size-cells = <0>;
rtc0: rtc@68 {
reg = <0x68>;
reg = <6>;
status = "okay";
#size-cells = <0>;
eeprom@50 {
reg = <0x50>;
reg = <7>;
status = "okay";
#size-cells = <0>;
eeprom@50 {
reg = <0x50>;
+&i2c1 {
- status = "okay";
- embedded-controller@1e {
reg = <0x1e>;
wakeup-source;
tun: i2c-tunnel {
#size-cells = <0>;
nvmem0: eeprom@50 {
reg = <0x50>;
#size-cells = <0>;
read-only;
reg = <0x24 0x6>;
reg = <0x2c 0x6>;
reg = <0x34 0x6>;
+&gpio0 {
- status = "okay";
- ledn {
gpio-hog;
output-high;
+&clkc {
- fclk-enable = <0xf>;
+&spi0 {
+&spi1 {
+&gem0 {
- status = "okay";
reg = <0>;
+&usb0 {
- status = "okay";
- dr_mode = "otg";
+&amba {
ranges;
- struct udevice *i2c_tun, *eeprom_chip;
- struct sulfur_mboard_eeprom eeprom;
- int err, i;
- u32 crc;
- err = uclass_get_device_by_seq(UCLASS_I2C, 20, &i2c_tun);
- if (err < 0)
return err;
- err = dm_i2c_probe(i2c_tun, 0x50, 0, &eeprom_chip);
- if (err < 0)
return err;zynq_board_read_rom_ethaddr
- for (i = 0; i < sizeof(eeprom); i++) {
if (err < 0)
break;
- crc = crc32(0, (const u8 *)&eeprom, sizeof(eeprom) - 4);
- if (htonl(crc) != eeprom.crc) {
return -EINVAL;
- memcpy(ethaddr, &eeprom.eth_addr0, ETH_ALEN);
- sulfur_read_ethaddr(ethaddr);
there was initiative to do this in generic way. Please check that patchset if that went trough because idea was to remove this function completely and use generic code which would cover what you have above.
return 0; }
- NI Ettus Research Sulfur EEPROM helpers
- Copyright (c) 2017 National Instruments Corp
+#define ETH_ALEN 6
- sulfur_mboard_eeprom - The memory map of the USRP Sulfur SDR EEPROM
- @magic: Magic constant to indicate that one is looking at a MB eeprom
- @version: Data layout version
- @mcu_flags: Flags for the EC
- @pid: Product Identifier
- @rev: Revision Number (zero based)
- @serial: (Non zero terminated) String containing the serial number
- @eth_addr0: Contains ethernet address for eth0
- @__pad0: Padding
- @eth_addr1: Contains ethernet address for eth1
- @__pad1: Padding
- @eth_addr2: Contains ethernet address for eth2
- @__pad2: Padding
- @crc: Contains checksum over the entire struct minus the crc member
- u32 magic;
- u32 version;
- u32 mcu_flags[4];
- u16 pid;
- u16 rev;
- u8 serial[8];
- u8 eth_addr0[ETH_ALEN];
- u8 __pad_0[2];
- u8 eth_addr1[ETH_ALEN];
- u8 __pad_1[2];
- u8 eth_addr2[ETH_ALEN];
- u8 __pad_2[2];
- u32 crc;
+} __packed;
- sulfur_dboard_eeprom - The memory map of the USRP Sulfur SDR EEPROM
- @magic: Magic constant to indicate that one is looking at a DB eeprom
- u32 magic;
- u32 version;
- u16 pid;
- u16 rev;
- u8 serial[8];
- u32 crc;
+} __packed;
- (c) Copyright 2017 National Instruments Corp.
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000128, 0x03F03F01U, 0x00700F01U),
- EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00200500U),
- EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00500500U),
- EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00200300U),
- EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00100500U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU, 0x0004281BU),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001600U),
- EMIT_MASKWRITE(0XF8000704, 0x00003FFFU, 0x00001600U),
- EMIT_MASKWRITE(0XF8000708, 0x00003FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF800070C, 0x00003FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000710, 0x00003FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000714, 0x00003FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000600U),
- EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x000006E0U),
- EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x000016E1U),
- EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x000016E1U),
- EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x000016E0U),
- EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001640U),
- EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001640U),
- EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x00001640U),
- EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x00001640U),
- EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00001261U),
- EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU, 0x00001260U),
- EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU, 0x00001261U),
- EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x00001261U),
- EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00001200U),
- EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00001200U),
- EMIT_EXIT(),
- EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU, 0x000C0000U),
- EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x00370008U),
- EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU, 0x000C0000U),
- EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x00370000U),
- EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x003B0004U),
- EMIT_MASKWRITE(0XE000A00C, 0x003F003FU, 0x003B0000U),
- EMIT_EXIT(),
- EMIT_EXIT(),
- EMIT_EXIT(),
- int ret;
- /* MIO init */
return ret;
- /* PLL init */
return ret;
- /* Clock init */
return ret;
- /* DDR init */
return ret;
return ret;
- Configuration for NI Ettus Research Project Sulfur Rev3
- "bootargs=root=/dev/mmcblk0p2 rw rootwait " \
DFU_ALT_INFO
The rest is just the same as 1/2.
Thanks, Michal
Michal Simek
Michal Simek
Moritz Fischer
