[U-Boot] [PATCH] 85xx: Fix bug in device tree setup in 36-bit physical confg
In the 36-bit physical config for MPC8572DS when need the start address of memory and it size to be kept in phys_*_t instead of a ulong since we support >4G of memory in the config and ulong cant represent that. Otherwise we end up seeing the memory node in the device tree reporting back we have memory starting @ 0 and of size 0.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8572ds/mpc8572ds.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index e57f9ff..4c9af74 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -554,7 +554,8 @@ extern void ft_fsl_pci_setup(void *blob, const char *pci_alias,
void ft_board_setup(void *blob, bd_t *bd) { - ulong base, size; + phys_addr_t base; + phys_size_t size;
ft_cpu_setup(blob, bd);
When we introduced the 36-bit config of the MPC8572DS board we had the wrong PCI MEM bus address map. Additionally, the change to the address map exposes a small issue in our dummy read on the ULI bus. We need to use the new mapping functions to handle that read properly in the 36-bit config.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8572ds/mpc8572ds.c | 6 ++++-- include/configs/MPC8572DS.h | 9 ++++++--- 2 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 4c9af74..c8b3966 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -216,8 +216,10 @@ void pci_init_board(void) pci_hose_read_config_dword(hose, PCI_BDF(2, 0x1d, 0 ), PCI_BASE_ADDRESS_1, &temp32); if (temp32 >= CONFIG_SYS_PCIE3_MEM_BUS) { - debug(" uli1572 read to %x\n", temp32); - in_be32((unsigned *)temp32); + void *p = pci_mem_to_virt(PCI_BDF(2, 0x1d, 0), + temp32, 4, 0); + debug(" uli1572 read to %p\n", p); + in_be32(p); } } else { printf (" PCIE3: disabled\n"); diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index a2360d8..b60b364 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -404,10 +404,11 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
/* controller 3, direct to uli, tgtid 3, Base address 8000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 #ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc00000000ull #else +#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000 #endif #define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ @@ -422,10 +423,11 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
/* controller 2, Slot 2, tgtid 2, Base address 9000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 #ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull #else +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 #endif #define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ @@ -440,10 +442,11 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
/* controller 1, Slot 1, tgtid 1, Base address a000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 #ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc40000000ull #else +#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000 #endif #define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */
Kumar Gala
