[U-Boot-Users] Pull request u-boot-fdt.git / FDT bugfix patches
Dear Wolfgang,
On the FDT front, we have two outstanding bugfix patches:
------------------------------------------------------------------- Explanation: I authored 43ddd9c820fec44816188f53346b464e20b3142d and missed some pieces which Kim was kind enough to clean up. (You pulled 43ddd directly into u-boot.) ------------------------------------------------------------------- http://article.gmane.org/gmane.comp.boot-loaders.u-boot/38849
From: Kim Phillips <kim.phillips <at> freescale.com> Subject: [PATCH] remove remaining CONFIG_OF_HAS_{UBOOT_ENV, BD_T} code Newsgroups: gmane.comp.boot-loaders.u-boot Date: 2008-03-28 22:37:49 GMT (4 days and 55 minutes ago)
finish off what commit 43ddd9c820fec44816188f53346b464e20b3142d, "Remove deprecated CONFIG_OF_HAS_UBOOT_ENV and CONFIG_OF_HAS_BD_T" started.
Signed-off-by: Kim Phillips <kim.phillips <at> freescale.com> -------------------------------------------------------------------
------------------------------------------------------------------- I also created a 8xx patch to fix a compile warning for 8xx boards that don't use fdt.o. This looks good to me, but I don't have a 8xx board to test it on. PLEASE VERIFY. ------------------------------------------------------------------- http://article.gmane.org/gmane.comp.boot-loaders.u-boot/38885/
From: Jerry Van Baren <gvb.uboot <at> gmail.com> Subject: [PATCH] Fix 8xx build to conditionally compile fdt.o Newsgroups: gmane.comp.boot-loaders.u-boot Date: 2008-03-30 02:06:31 GMT (2 days, 21 hours and 30 minutes ago)
Change to COBJS-y method so that the fdt.o library can be properly conditionally compiled. Without this change, the mpc8xx boards that don't use CONFIG_OF_LIBFDT still build the fdt.o, causing code bloat and compile warnings.
Signed-off-by: Gerald Van Baren <vanbaren <at> cideas.com> -------------------------------------------------------------------
If it is handier, you can pull both from my u-boot-fdt repo:
The following changes since commit 3596d55eb22703d3f4f1b839fe4b000fabe081b3: Gerald Van Baren (1): Merge git://www.denx.de/git/u-boot into uboot
git://git.denx.de/u-boot-fdt.git master
Gerald Van Baren (1): Fix 8xx build to conditionally compile fdt.o
Kim Phillips (1): remove remaining CONFIG_OF_HAS_{UBOOT_ENV,BD_T} code
README | 13 ------ common/ft_build.c | 113 --------------------------------------------------- cpu/mpc8xx/Makefile | 24 +++++++++-- lib_ppc/bootm.c | 12 ----- 4 files changed, 19 insertions(+), 143 deletions(-)
Thanks, gvb
Jerry Van Baren wrote:
Dear Wolfgang,
On the FDT front, we have <del>two</del>THREE outstanding bugfix patches:
I confirmed my error, the <nnnn> notation is indeed 32 bit cells per the DTC documentation (and his other changes are valuable improvements). As a result, I've added Andy's patch to my queued-to-pull list.
Thanks, gvb
Andy Fleming (1): Fix fdt set command to conform to dts spec
Jean-Christophe PLAGNIOL-VILLARD (1): MPC8xx: Fix libfdt support introduced in commit 77ff7b74
README | 13 ----- common/cmd_fdt.c | 137 +++++++++++++++++++++++++-------------------------- common/ft_build.c | 113 ------------------------------------------ cpu/mpc8xx/Makefile | 33 +++++++++---- lib_ppc/bootm.c | 12 ----- 5 files changed, 90 insertions(+), 218 deletions(-)
Dear Wolfgang,
Thanks, gvb
Applied, thanks.
Jerry Van Baren
