[U-Boot] [PATCH] mmc: fix to assign to corret clock value when clock is enabling
When clock is enabling, it's assigned to 0 as mmc->clock. Then it can't initialize any card. Fix to assign to correct clock value as mmc->cfg->f_min or f_max.
Fixes: 9546eb92cb6 ("mmc: fix the wrong disabling clock")
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 311f51f237..2d0e7bb3a2 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1501,7 +1501,7 @@ static int mmc_set_ios(struct mmc *mmc)
int mmc_set_clock(struct mmc *mmc, uint clock, bool disable) { - if (!disable && clock != 0) { + if (!disable) { if (clock > mmc->cfg->f_max) clock = mmc->cfg->f_max;
I tested your patch on top of u-boot-mmc and SD/MMC is working fine on snow config (Samsung Chromebook).
Tested-by: Guillaume GARDET guillaume.gardet@free.fr
- if (!disable) { if (clock > mmc->cfg->f_max) clock = mmc->cfg->f_max;
Hi Jaehoon
-- 2.15.1
Please add my, Tested on Odroid XU4
Tested-by: Anand Moon linux.amoon@gmail.com
Best Regards -Anand
Tested-by: Stephen Warren swarren@nvidia.com Thanks!
Nit: There's usually not a blank line between the Fixes: and Signed-off-by: lines.
Nit: s/corret/correct/ in the patch subject.
After fixing typo and changing with your commen, Applied to u-boot-mmc.
Best Regards, Jaehoon Chung
Anand Moon
Guillaume Gardet
Jaehoon Chung
Stephen Warren
