[U-Boot] [PATCH][v2] mpc8260: move FDT memory node fixup into common CPU code.
Move the memory node fixup of the MPC8260ADS, ids8247, mgcoge and muas3001 boards into common mpc8260 CPU code.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com --- board/freescale/mpc8260ads/mpc8260ads.c | 13 ------------- board/ids8247/ids8247.c | 16 ---------------- board/keymile/mgcoge/mgcoge.c | 8 +------- board/muas3001/muas3001.c | 16 ---------------- cpu/mpc8260/cpu.c | 1 + 5 files changed, 2 insertions(+), 52 deletions(-)
diff --git a/board/freescale/mpc8260ads/mpc8260ads.c b/board/freescale/mpc8260ads/mpc8260ads.c index 49a88bb..be55626 100644 --- a/board/freescale/mpc8260ads/mpc8260ads.c +++ b/board/freescale/mpc8260ads/mpc8260ads.c @@ -550,24 +550,11 @@ void pci_init_board(void) #endif
#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -void ft_blob_update(void *blob, bd_t *bd) -{ - int ret; - - ret = fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); - - if (ret < 0) { - printf("ft_blob_update(): cannot set /memory/reg " - "property err:%s\n", fdt_strerror(ret)); - } -} - void ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd); #ifdef CONFIG_PCI ft_pci_setup(blob, bd); #endif - ft_blob_update(blob, bd); } #endif diff --git a/board/ids8247/ids8247.c b/board/ids8247/ids8247.c index 79fe9da..d621833 100644 --- a/board/ids8247/ids8247.c +++ b/board/ids8247/ids8247.c @@ -400,24 +400,8 @@ int board_nand_init(struct nand_chip *nand) #endif /* CONFIG_CMD_NAND */
#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) -/* - * update "memory" property in the blob - */ -void ft_blob_update(void *blob, bd_t *bd) -{ - int ret; - - ret = fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); - - if (ret < 0) { - printf("ft_blob_update(): cannot set /memory/reg " - "property err:%s\n", fdt_strerror(ret)); - } -} - void ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup( blob, bd); - ft_blob_update(blob, bd); } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index b16a01c..932a805 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -312,11 +312,10 @@ int hush_init_var (void)
#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) /* - * update "memory" property in the blob + * update "flash" property in the blob */ void ft_blob_update (void *blob, bd_t *bd) { - ulong memory_data[2] = {0}; ulong *flash_data = NULL; ulong flash_reg[6] = {0}; flash_info_t *info; @@ -324,11 +323,6 @@ void ft_blob_update (void *blob, bd_t *bd) int size; int i = 0;
- memory_data[0] = cpu_to_be32 (bd->bi_memstart); - memory_data[1] = cpu_to_be32 (bd->bi_memsize); - fdt_set_node_and_value (blob, "/memory", "reg", memory_data, - sizeof (memory_data)); - len = fdt_get_node_and_value (blob, "/localbus", "ranges", (void *)&flash_data);
diff --git a/board/muas3001/muas3001.c b/board/muas3001/muas3001.c index 36caed8..e0a7f32 100644 --- a/board/muas3001/muas3001.c +++ b/board/muas3001/muas3001.c @@ -308,25 +308,9 @@ int board_early_init_r (void) void ft_blob_update (void *blob, bd_t *bd) { int ret, nodeoffset = 0; - ulong memory_data[2] = {0}; ulong flash_data[4] = {0}; ulong speed = 0;
- memory_data[0] = cpu_to_be32 (bd->bi_memstart); - memory_data[1] = cpu_to_be32 (bd->bi_memsize); - - nodeoffset = fdt_path_offset (blob, "/memory"); - if (nodeoffset >= 0) { - ret = fdt_setprop (blob, nodeoffset, "reg", memory_data, - sizeof(memory_data)); - if (ret < 0) - printf ("ft_blob_update): cannot set /memory/reg " - "property err:%s\n", fdt_strerror (ret)); - } else { - /* memory node is required in dts */ - printf ("ft_blob_update(): cannot find /memory node " - "err:%s\n", fdt_strerror(nodeoffset)); - } /* update Flash addr, size */ flash_data[2] = cpu_to_be32 (CONFIG_SYS_FLASH_BASE); flash_data[3] = cpu_to_be32 (CONFIG_SYS_FLASH_SIZE); diff --git a/cpu/mpc8260/cpu.c b/cpu/mpc8260/cpu.c index 17e6248..aedbf29 100644 --- a/cpu/mpc8260/cpu.c +++ b/cpu/mpc8260/cpu.c @@ -318,6 +318,7 @@ void ft_cpu_setup (void *blob, bd_t *bd) "timebase-frequency", OF_TBCLK, 1); do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, "clock-frequency", bd->bi_intfreq, 1); + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); } #endif /* CONFIG_OF_LIBFDT */
Dear Marcel Ziswiler,
In which way is this patch version 2? I have not seen any v1 of such a patch?
You want to put the respective board maintainers on Cc:
Also, what is the impact for the other MPC826x board, that are not listed here?
Hi Wolfgang Denk
What about http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67275? A pair of glasses might help (;-p).
Most are maintained by Heiko, who I did actually put on CC. Forgot to add Yuli as the MPC8260 maintainer, sorry. Did so now.
I can assure you there is no impact at all as they are not using FDT at all.
Cheers
Marcel Ziswiler
Heh. If that was sufficient. I'm alrady wearing glasses _and_ contact lenses, and it didn't help.
Um... but why didn't you set the In-Reply-To: and References: headers, then?
Dear Wolfgang Denk
I do know that as I saw you at the EW in Nürnberg this spring.
Sorry about that, my understanding was to post new versions of a patch as a new thread. Is that not so?
What exactly is that references header you are talking about?
Cheers
Marcel Ziswiler
No, on contrary. New versions of a patch should always make sure to thread correctly to the old version(s). It seems that preferences here are a matter of taste - my personal preference is to link to the preceeding version of the patch, but most others seem to prefer to link to the first version always.
It's a standard Mail header like this one:
| In-reply-to: 1251879636-9115-1-git-send-email-wd@denx.de | References: 1251879636-9115-1-git-send-email-wd@denx.de
when enables MUAs to display a "threaded view", i. e. you can see the whole history of previous patch submissions, review comments, etc. and thus for example check easily if the new version incorporates all requested changes.
When you use "git send-email" to submit your patches, it will (in standard configuration) ask you:
Message-ID to be used as In-Reply-To for the first email?
Here you can simply enter the message ID of the original posting you are referring to ("1251879636-9115-1-git-send-email-wd@denx.de") in the example above.
Note that the message ID of a posting is also a very convenient method to look it up in the gmane archives: just append the message ID to the URL "http://mid.gmane.org/" - i. e. try:
http://mid.gmane.org/1251879636-9115-1-git-send-email-wd@denx.de
Then click on the link in the "Subject: line to see the whole thread.
That's kind of what I thought at first as well, but then I saw many others posting patches not adhering to that and still getting your ack no problem: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/67581 http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/67462 http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/67394 http://article.gmane.org/gmane.comp.boot-loaders.u-boot/67187
Hello Marcel,
Tested on the mgcoge board. (ids8247 and muas3001 I have no access anymore)
Tested-by: Heiko Schocher hs@denx.de
Thanks
bye Heiko
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com Tested-by: Heiko Schocher hs@denx.de --- Changes since v1: - Added previously missed mgcoge board as pointed out by Peter Tyser and Heiko - Moved the board-specific Ethernet modifications into separate patch Changes since v2: - Added Heiko's tested-by
Changes since v1:
Changes since v2:
Patch does not apply:
Applying: mpc8260: move FDT memory node fixup into common CPU code. error: patch failed: board/muas3001/muas3001.c:308 error: board/muas3001/muas3001.c: patch does not apply fatal: sha1 information is lacking or useless (board/keymile/mgcoge/mgcoge.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001.
Please fix and repost.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com Tested-by: Heiko Schocher hs@denx.de --- Changes since v1: - Added previously missed mgcoge board as pointed out by Peter Tyser and Heiko - Moved the board-specific Ethernet modifications into separate patch Changes since v2: - Added Heiko's tested-by Changes since v3: - Re-based to origin/master
Changes since v1:
Changes since v2:
Changes since v3:
Apoplied, thanks.
Heiko Schocher
Marcel Ziswiler
