[U-Boot] [PATCH] ARM: fix warning: 'print_eth' defined but not used
This warning got issued for all ARM systems that don't have CONFIG_CMD_NET enabled.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_bdinfo.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 700314b..b230924 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -31,7 +31,9 @@ DECLARE_GLOBAL_DATA_PTR;
static void print_num(const char *, ulong);
+#if !defined(CONFIG_ARM) || defined(CONFIG_CMD_NET) static void print_eth(int idx); +#endif
#ifndef CONFIG_ARM /* PowerPC and other */ static void print_lnum(const char *, u64); @@ -347,6 +349,7 @@ static void print_num(const char *name, ulong value) printf ("%-12s= 0x%08lX\n", name, value); }
+#if !defined(CONFIG_ARM) || defined(CONFIG_CMD_NET) static void print_eth(int idx) { char name[10], *val; @@ -359,6 +362,7 @@ static void print_eth(int idx) val = "(not set)"; printf("%-12s= %s\n", name, val); } +#endif
#ifndef CONFIG_ARM static void print_lnum(const char *name, u64 value)
