[U-Boot] [PATCH] pci: layerscape: Fixup iommu-map for LS208xA
"pci: layerscape: Fixup device tree node for ls2088a" added support for LS208xA devices but fixing iommu-map property is missing. This patch adds support for fixing iommu-map.
Signed-off-by: Bharat Bhushan Bharat.Bhushan@nxp.com Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- drivers/pci/pcie_layerscape_fixup.c | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index 9e6c2f5..3dae201 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -130,19 +130,28 @@ static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie *pcie, u32 iommu_map[4]; int nodeoffset; int lenp; + uint svr; + char *compat = NULL;
/* find pci controller node */ nodeoffset = fdt_node_offset_by_compat_reg(blob, "fsl,ls-pcie", pcie->dbi_res.start); if (nodeoffset < 0) { #ifdef CONFIG_FSL_PCIE_COMPAT /* Compatible with older version of dts node */ - nodeoffset = fdt_node_offset_by_compat_reg(blob, - CONFIG_FSL_PCIE_COMPAT, pcie->dbi_res.start); + svr = (get_svr() >> SVR_VAR_PER_SHIFT) & 0xFFFFFE; + if (svr == SVR_LS2088A || svr == SVR_LS2084A || + svr == SVR_LS2048A || svr == SVR_LS2044A || + svr == SVR_LS2081A || svr == SVR_LS2041A) + compat = "fsl,ls2088a-pcie"; + else + compat = CONFIG_FSL_PCIE_COMPAT; + + if (compat) + nodeoffset = fdt_node_offset_by_compat_reg(blob, + compat, pcie->dbi_res.start); +#endif if (nodeoffset < 0) return; -#else - return; -#endif }
/* get phandle to iommu controller */
Revised commit message. Applied to fsl-qoriq mater. Thanks.
York
Bharat Bhushan
York Sun
